DSP/BIOS to SYS/BIOS conversion
What are the equivalent macros in bios6 for "SYS_OK", "SYS_EALLOC", "SYS_EFREE",..... (defined in sys.h)?
Also what is the equivalent of HOOK_id in bios6?
I have read the dsp/bios to sys/bios migration guide.  But could not find the solution to the above questions.  Is there any other document which covers the topic in greater depth?
Thanks.
Divya
  • Divya,
    There are no "global" error codes defined in SYS/BIOS 6.x, so there is not an equivalent for the SYS_E* defines in sys.h. Each module defines its own errors.
    The way hook functions are handled has been changed so that a Hook_Id is no longer needed. There are a variety of hook points during the startup sequence (see Section 3.1 of SYS/BIOS User's Guide) and there are hook points for Task, Swi, and Hwi modules (See Table 3.1 in the user's guide).
    If there is a specific kind of behavior/functionality that you are trying to port, perhaps you could give an example and I could give more specific advice.
    Mark
  • Thanks Mark.  I have just started porting my code and will let you know if there are any issues.
    Divya
