I encountered some problems while upgrade “Exception handler module” from BIOS 5 to
BIOS6, the following is a detailed description:
In BIOS 5, I use the statement below:(ccs3.3,Device:C6487)
bios.HWI.instance("HWI_NMI").fxn=prog.extern("EXC_dispatch_mod")
when an exception happened,it can go to the exception isr “EXC_dispatch_mod” successfully.
That seems confict of the first sentence description in the post below:
http://e2e.ti.com/support/embedded/f/355/p/89509/309979.aspx#309979
Then in BIOS 6(ccs4.2,device:C66XX), Refer to the previous posts,when I enable the Exception module in bios,the
Exception work successfully.you can see the post below:
http://e2e.ti.com/support/embedded/f/355/p/144337/524561.aspx#524561
Now,my question is:
1.in BIOS6,can I hook the exception isr use HWI module like in bios5? We do not want to use “Exception Module” for saving resources.
2. What is the difference of the useage of NMI between bios5 and bios6?
Jimmy
