TMS320VC5502: CCS 12.8 throws java.lang.nullpointer exception
Part Number: TMS320VC5502
Other Parts Discussed in Thread: SEGGER
I updated my CCS v12.6 to v12.8 today.  Two items were updated -- a driver for the SEGGER debug probe and a flash driver for an AMD chip (I believe).  I am using neither of these items.
I had been very stable but after the update (and PC reboot), I get regular java null pointer errors or CCS hangs.
Is this a known issue?  Should I try to roll back to v12.6?
-dean
  • Hi Dean,
    I am going to pass this along to the CCS team for further comment.
    I would definitely try and roll back to v12.6 if you can. You can also just install v12.6, or any other version, simultaneously to test out new device/feature support.
    Thank you,
    -Randy
  • I had been very stable but after the update (and PC reboot), I get regular java null pointer errors or CCS hangs.
    Can you provide any error logs? The log in <WORKSPACE FOLDER>/.log would be helpful to see.
    ki
  • !SESSION 2025-01-11 21:37:07.594 -----------------------------------------------
    eclipse.buildId=4.23.0.I20220308-0310
    java.version=11.0.13
    java.vendor=Eclipse Adoptium
    BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
    Framework arguments:  -product com.ti.ccstudio.branding.product
    Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product com.ti.ccstudio.branding.product
    This is a continuation of log file C:\Tools\ccs\workspace_v12\.metadata\.bak_0.log
    Created Time: 2025-01-11 21:37:28.301
    !ENTRY com.ti.ccstudio.project.ui.webcontent 1 0 2025-01-11 21:37:28.303
    !MESSAGE CCS HTTP adapter started! [ccs.port:56667] - Open 'http://localhost:56667/ide' in web browser to see listing of available APIs...
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:29.690
    !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/artifacts.xml.xz, see CVE-2021-41033. Consider using https instead.
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:30.500
    !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2linux/artifacts.xml.xz, see CVE-2021-41033. Consider using https instead.
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:30.927
    !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2mac/artifacts.xml.xz, see CVE-2021-41033. Consider using https instead.
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:31.265
    !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.xml.xz, see CVE-2021-41033. Consider using https instead.
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:32.690
    !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2linux/content.xml.xz, see CVE-2021-41033. Consider using https instead.
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:34.099
    !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2mac/content.xml.xz, see CVE-2021-41033. Consider using https instead.
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:35.251
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:35.497
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:35.736
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:36.002
    !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/, see CVE-2021-41033. Consider using https instead.
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:36.341
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:37.148
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:38.238
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:38.594
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:39.506
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:39.768
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:40.046
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:41.108
    !ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2025-01-11 21:37:48.280
    !MESSAGE No repository found at https://www.blackhawk-dsp.com/updates/ccsv9.
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:37:48.670
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:38:49.259
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:38:49.587
    !ENTRY org.eclipse.equinox.p2.repository 2 0 2025-01-11 21:38:50.577
     bak_0.log
    Here you go ki -- thanks!  (I found these in <WORKSPACE FOLDER>/.metadata/
    Sorry for the delay ... it looks like the .bak_0.log or .log didn't get past the acceptable file filters and I didn't notice that initially.
  • Thank you for the log. Unfortunately there was not much useful information for engineering regarding this issue.
     Since CCS 12.x is deprecated in support, I would suggest rolling back to CCS 12.6 also if that worked well for you.
