Why the system is crash?
I use the hardware are  "816X/389X EVM ASSY 512870 REV F" and "DM816X VIDEO SECURITY BOARD ASSY 513500 REV B" ,  the software i used is  "DVRRDK_01.06.00.11",  I change the "Rules.make" as this:
ifeq ($(DVR_RDK_BOARD_TYPE ), )
  DVR_RDK_BOARD_TYPE := DM816X_EVM
endif
# Default linux mem
ifeq ($(LINUX_MEM), )
#  LINUX_MEM := LINUX_MEM_128M
  LINUX_MEM := LINUX_MEM_256M
endif
I "make -s sys_all" and "make -s all", and load, but if i run "./init.sh" and "./load.sh" the system is crash.
 _   _ ___  _   _         _
| | | |    | ||| |___ ___| | _ ___
| |_| | |) |  ~  | . |  _| |/_|  -|
|_____|___ /____/ ___|_| |_| _|-__|
DVR_Netra Board (2011.04)
dvr login: root
root@dvr:~# cd /opt
root@dvr:~# cd /opt/
root@dvr:~# cd /opt/dvr_rdk/
root@dvr:~# cd /opt/dvr_rdk/ti816x/
root@dvr:/opt/dvr_rdk/ti816x# ./lo
root@dvr:/opt/dvr_rdk/ti816x# ./load.sh         init
root@dvr:/opt/dvr_rdk/ti816x# ./init.sh
numid=1,iface=MIXER,name='PCM Playback Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
  : values=127,127
  | dBscale-min=-63.50dB,step=0.50dB,mute=0
 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
 [m3video] Remote Debug Shared Memory @ 0xbff05020
 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.00.03.82
SysLink module created on Date:Nov  9 2011 Time:17:12:56
Trace enabled
Trace SetFailureReason enabled
 Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
 Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
 Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
 Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
  : values=127,127
Removed syslink kernel module
Trace enabled
root@dvr:/opt/dvr_rdk/ti816x# cd /opt/dvr_rdk/ti816x/
root@dvr:/opt/dvr_rdk/ti816x# ./init.sh         load.sh
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2.
Started slave procId 2.
 [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 250000000
 [m3vpss ] notify_attach  rtnVal  0
 [m3vpss ] initProxyServer  rtnVal  0
 [m3vpss ]
 [m3vpss ]  *** UTILS: CPU KHz = 500000 Khz ***
 [m3vpss ]
 [m3vpss ]  77: SYSTEM  : System Common Init in progress !!!
 [m3vpss ]  78: SYSTEM: IPC init in progress !!!
 [m3vpss ]  78: SYSTEM: Attaching to [HOST] ...
After Ipc_loadcallback status [0x00000000]
 [m3vpss ]  1078: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  1081: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
After Ipc_startcallback status [0x097d2000]
 [m3vpss ]  1081: SYSTEM: Attaching to [DSP] ...
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1.
Started slave procId 1.
 [m3video] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 250000000
 [m3vpss ]  2081: SYSTEM: Attaching to [DSP] ...
 [m3video]
 [m3video]  *** UTILS: CPU KHz = 500000 Khz ***
 [m3video]
 [m3video]  1264: SYSTEM  : System Common Init in progress !!!
 [m3video]  1264: SYSTEM: IPC init in progress !!!
 [m3video]  1264: SYSTEM: Attaching to [HOST] ...
 [m3video]  2264: SYSTEM: Attaching to [HOST] ...
 [m3video]  2268: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3video]  2269: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x00000000]
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0.
Started slave procId 0.
 [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 800000000, <NEW> - 800000000
 [c6xdsp ]
 [c6xdsp ]  *** UTILS: CPU KHz = 800000 Khz ***
 [c6xdsp ]
 [c6xdsp ]  2: SYSTEM  : System Common Init in progress !!!
 [c6xdsp ]  2: SYSTEM: IPC init in progress !!!
 [c6xdsp ]  2: SYSTEM: Attaching to [HOST] ...
 [c6xdsp ]  513: SYSTEM: Attaching to [HOST] ...
 [c6xdsp ]  517: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [c6xdsp ]  518: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3vpss ]  3081: SYSTEM: Attaching to [DSP] ...
 [m3video]  3268: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  1029: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3vpss ]  4081: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  1922: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  4268: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  1923: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  4269: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3video]  4269: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  2434: SYSTEM: Attaching to [VPSS-M3] ...
 [m3vpss ]  5081: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  2946: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  5268: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  3788: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  6081: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  3788: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  6081: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3vpss ]  6081: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  6268: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  4300: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [c6xdsp ]  4812: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3video]  7081: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  7081: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  7081: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  7081: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  7082: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
 [m3vpss ]  7081: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3video]  7082: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
 [m3vpss ]  7081: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
 [m3video]  7084: SYSTEM: Notify register to [HOST] line 0, event 12 ...
 [m3vpss ]  7082: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
 [m3video]  7084: SYSTEM: Notify register to [DSP] line 0, event 12 ...
 [m3vpss ]  7083: SYSTEM: Notify register to [HOST] line 0, event 12 ...
 [m3video]  7084: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
 [m3vpss ]  7084: SYSTEM: Notify register to [DSP] line 0, event 12 ...
 [m3video]  7084: SYSTEM: IPC init DONE !!!
 [m3vpss ]  7084: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
 [m3vpss ]  7084: SYSTEM: IPC init DONE !!!
 [m3video]  7091: MEM: Shared Region 3: Base = 0xa0000000, Length = 0x1e900000 (489 MB)
 [m3vpss ]  7092: MEM: Shared Region 3: Base = 0xa0000000, Length = 0x1e900000 (489 MB)
 [m3video]  7092: MEM: ERROR: SharedRegion_setEntry (3, 0x8dffb068) FAILED !!!  (status=-1)
 [m3vpss ]  7092: MEM: Shared Region 1: Base = 0x88000000, Length = 0x05780000 (87 MB)
 [m3vpss ]  7094: SYSTEM  : System Common Init Done !!!
 [m3vpss ]  7094: SYSTEM  : System VPSS Init in progress !!!
 [m3vpss ] === HDVPSS Clocks are enabled ===
 [m3vpss ] === HDVPSS is fully functional ===
 [m3vpss ] === HDVPSS module is not in standby ===
 [m3vpss ] === I2C1 Clk is active ===
 [m3vpss ]  7100: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_28
 [m3vpss ]  7100: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 2 ...
 [m3vpss ]  7100: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 2 ...
 [m3vpss ]  7100: SYSTEM: ListElem Shared Addr = 0x8d780280
 [m3video]  7101: MEM: Shared Region 1: Base = 0x88000000, Length = 0x05780000 (87 MB)
 [m3vpss ]  7102: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 2 ...
 [m3video]  7103: SYSTEM  : System Common Init Done !!!
 [m3vpss ]  7103: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 2 ...
 [m3video]  7103: SYSTEM  : System Video Init in progress !!!
 [m3vpss ]  7103: SYSTEM: ListElem Shared Addr = 0x8d783380
 [m3video]  7103: SYSTEM  : System Video Init Done !!!
 [m3video]  7104: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 2 ...
 [m3video]  7104: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 2 ...
 [m3video]  7104: SYSTEM: ListElem Shared Addr = 0x8d786480
 [m3video]  7106: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 2 ...
 [m3video]  7106: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 2 ...
 [m3video]  7106: SYSTEM: ListElem Shared Addr = 0x8d789580
 [m3video]  7115: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
 [m3vpss ]  7114: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
 [m3video]  7116: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
 [m3vpss ]  7114: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
 [m3video]  7116: SYSTEM: ListElem Shared Addr = 0xbeb2a880
 [m3vpss ]  7114: SYSTEM: ListElem Shared Addr = 0xbeb0b280
 [m3video]  7118: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
 [m3vpss ]  7117: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
 [m3video]  7118: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
 [m3vpss ]  7117: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
 [m3video]  7118: SYSTEM: ListElem Shared Addr = 0xbeb5d900
 [m3vpss ]  7117: SYSTEM: ListElem Shared Addr = 0xbeb3e300
 [m3video]  7120: HDVICP: Doing PRCM for IVAHD[0] ...
 [m3video]  7120: HDVICP: PRCM for IVAHD[0] ... DONE.
 [m3video]  7120: HDVICP: Doing PRCM for IVAHD[1] ...
 [m3video]  7120: HDVICP: PRCM for IVAHD[1] ... DONE.
 [m3video]  7120: HDVICP: Doing PRCM for IVAHD[2] ...
 [m3video]  7121: HDVICP: PRCM for IVAHD[2] ... DONE.
 [m3video]  7122: SYSTEM  : Initializing Links !!!
 [m3video]  7122: SYSTEM  : Heap Free Space (System = 2087936 bytes, FrmBuf = 512753536 bytes,
 [m3video]          BitBuf = 91750272 bytes, Mbx = 10240 msgs)
 [m3video]  7164: SYSTEM  : Initializing Links ... DONE !!!
 [c6xdsp ]  5324: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [c6xdsp ]  5324: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
 [c6xdsp ]  5324: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
 [c6xdsp ]  5324: SYSTEM: Notify register to [HOST] line 0, event 12 ...
 [c6xdsp ]  5324: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
 [c6xdsp ]  5324: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
 [c6xdsp ]  5324: SYSTEM: IPC init DONE !!!
 [c6xdsp ]  5326: MEM: Shared Region 3: Base = 0xa0000000, Length = 0x1e900000 (489 MB)
 [c6xdsp ]  5327: MEM: Shared Region 1: Base = 0x88000000, Length = 0x05780000 (87 MB)
 [c6xdsp ]  5327: SYSTEM  : System Common Init Done !!!
 [c6xdsp ]  10406: SYSTEM  : System DSP Init in progress !!!
 [c6xdsp ]  10406: SYSTEM  : System DSP Init Done !!!
 [c6xdsp ]  5329: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
 [c6xdsp ]  5329: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
 [c6xdsp ]  5329: SYSTEM: ListElem Shared Addr = 0xbeb71380
 [c6xdsp ]  5330: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
 [c6xdsp ]  5330: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
 [c6xdsp ]  5330: SYSTEM: ListElem Shared Addr = 0xbeb90980
 [c6xdsp ] !!WARNING.Resource already registered:2
 [c6xdsp ]  10412: SYSTEM  : Initializing Links !!!
 [c6xdsp ]  5331: SYSTEM  : Heap Free Space (System = 2089832 bytes, FrmBuf = 512753536 bytes,
 [c6xdsp ]          BitBuf = 91750272 bytes, Mbx = 10240 msgs)
 [c6xdsp ]  10414: SYSTEM  : Initializing Links ... DONE !!!
 [m3vpss ]  I2C1: Passed for address 0x20 !!!
 [m3vpss ]  I2C1: Passed for address 0x21 !!!
 [m3vpss ]  I2C1: Passed for address 0x39 !!!
 [m3vpss ]  I2C1: Passed for address 0x3d !!!
 [m3vpss ]  I2C1: Passed for address 0x58 !!!
 [m3vpss ]  I2C1: Passed for address 0x5a !!!
 [m3vpss ]  I2C1: Passed for address 0x5c !!!
 [m3vpss ]  I2C1: Passed for address 0x5e !!!
 [m3vpss ]  I2C1: Passed for address 0x60 !!!
 [m3vpss ]  9876: SYSTEM  : System VPSS Init Done !!!
 [m3vpss ]  9876: SYSTEM  : Initializing Links !!!
 [m3vpss ]  9876: SYSTEM  : Heap Free Space (System = 26072 bytes, FrmBuf = 508145536 bytes,
 [m3vpss ]          BitBuf = 91750272 bytes, Mbx = 10240 msgs)
 [m3vpss ] Received character 's'
 [m3vpss ]  11486: SYSTEM  : Initializing AVsync ********************** !!!
 [m3vpss ]  AVsync AVSYNC_M3_Init********************** !!!
 [m3vpss ]  11410 : AVsync AVSYNC_Init_WallTimer********************** !!!
 [m3vpss ]  11487: SYSTEM  : Initializing Links ... DONE !!!
 [m3video] Received character 's'
 [c6xdsp ] Received character 's'
/opt/dvr_rdk/ti816x
notify_shm_drv_sendevent failed! status = 0xfffffff0
notify_send_event failed! status = 0xfffffff0
vpss: probe of vpss failed with error -22
ti81xxfb ti81xxfb: no grpxs
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c5728000
[00000000] *pgd=84442031, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1]
last sysfs file: /sys/kernel/uevent_seqnum
Modules linked in: ti81xxfb(+) vpss syslink ipv6 [last unloaded: syslink]
CPU: 0    Not tainted  (2.6.37 #1)
PC is at unregister_framebuffer+0x18/0xec
LR is at ti81xxfb_free_all+0x1c/0xe0 [ti81xxfb]
pc : [<c01aad3c>]    lr : [<bf2e83c4>]    psr: a0000013
sp : c572fda0  ip : c572fdc8  fp : c572fdc4
r10: 00000000  r9 : c572e000  r8 : c4430300
r7 : c5762900  r6 : c4430300  r5 : 00000000  r4 : c04a9ef8
r3 : c05034b8  r2 : 00000001  r1 : 00003c72  r0 : 00000000
Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c5387d  Table: 85728019  DAC: 00000015
Process insmod (pid: 978, stack limit = 0xc572e2e8)
Stack: (0xc572fda0 to 0xc5730000)
fda0: c04dae80 bf2e9e5c c04a9ef8 ffffffea c4430300 c5762900 c572fde4 c572fdc8
fdc0: bf2e83c4 c01aad30 c04a9ef8 ffffffea bf2e9e5c c5762900 c572fe44 c572fde8
fde0: bf2e8cb4 bf2e83b4 c04a9ef8 c4430300 c572fe34 c572fe00 c6468720 00000000
fe00: c04a9ef8 00000000 c04a9f00 c5762900 c04c0ee0 00000000 c572fe34 c04a9ef8
fe20: c04a9ef8 bf2e9e5c c5762900 c04c0ee0 c572e000 00000000 c572fe54 c572fe48
fe40: c01dbbd8 bf2e8838 c572fe74 c572fe58 c01dab44 c01dbbc4 c04a9ef8 c04a9f2c
fe60: bf2e9e5c c5762900 c572fe94 c572fe78 c01dac6c c01daa80 00000000 c01dac04
fe80: bf2e9e5c c5762900 c572febc c572fe98 c01da2f0 c01dac10 c641bfb8 c6460530
fea0: c018bad8 00000000 bf2e9ef8 bf2e9e5c c572fecc c572fec0 c01da968 c01da2ac
fec0: c572fefc c572fed0 c01d9bc8 c01da954 bf2e94d2 c572fee0 00000000 bf2e9ef8
fee0: bf2e9e5c 00012018 bf2ed000 00000000 c572ff24 c572ff00 c01dafa4 c01d9b20
ff00: 00000000 bf2e9ef8 00012008 00012018 bf2ed000 c572e000 c572ff34 c572ff28
ff20: c01dbec4 c01daf00 c572ff44 c572ff38 bf2ed014 c01dbe84 c572ff7c c572ff48
ff40: c00383d8 bf2ed00c bf2e9ef8 00012008 00012018 c0042f48 00000000 bf2e9ef8
ff60: 00012008 00012018 c0042f48 00000000 c572ffa4 c572ff80 c0092bd4 c0038314
ff80: c00bd7c8 c00bd6e0 00000000 00008000 00000003 00000080 00000000 c572ffa8
ffa0: c0042da0 c0092b44 00000000 00008000 00012018 00004028 00012008 00000001
ffc0: 00000000 00008000 00000003 00000080 00012008 00000000 00012018 00000000
ffe0: bee49e8d bee49c1c 00008da0 402007d4 60000010 00012018 ebfffffe e3500000
Backtrace:
[<c01aad24>] (unregister_framebuffer+0x0/0xec) from [<bf2e83c4>] (ti81xxfb_free_all+0x1c/0xe0 [ti81xxfb])
 r7:c5762900 r6:c4430300 r5:ffffffea r4:c04a9ef8
[<bf2e83a8>] (ti81xxfb_free_all+0x0/0xe0 [ti81xxfb]) from [<bf2e8cb4>] (ti81xxfb_probe+0x488/0x518 [ti81xxfb])
 r7:c5762900 r6:bf2e9e5c r5:ffffffea r4:c04a9ef8
[<bf2e882c>] (ti81xxfb_probe+0x0/0x518 [ti81xxfb]) from [<c01dbbd8>] (platform_drv_probe+0x20/0x24)
[<c01dbbb8>] (platform_drv_probe+0x0/0x24) from [<c01dab44>] (driver_probe_device+0xd0/0x190)
[<c01daa74>] (driver_probe_device+0x0/0x190) from [<c01dac6c>] (__driver_attach+0x68/0x8c)
 r7:c5762900 r6:bf2e9e5c r5:c04a9f2c r4:c04a9ef8
[<c01dac04>] (__driver_attach+0x0/0x8c) from [<c01da2f0>] (bus_for_each_dev+0x50/0x84)
 r7:c5762900 r6:bf2e9e5c r5:c01dac04 r4:00000000
[<c01da2a0>] (bus_for_each_dev+0x0/0x84) from [<c01da968>] (driver_attach+0x20/0x28)
 r6:bf2e9e5c r5:bf2e9ef8 r4:00000000
[<c01da948>] (driver_attach+0x0/0x28) from [<c01d9bc8>] (bus_add_driver+0xb4/0x234)
[<c01d9b14>] (bus_add_driver+0x0/0x234) from [<c01dafa4>] (driver_register+0xb0/0x13c)
[<c01daef4>] (driver_register+0x0/0x13c) from [<c01dbec4>] (platform_driver_register+0x4c/0x60)
 r9:c572e000 r8:bf2ed000 r7:00012018 r6:00012008 r5:bf2e9ef8
r4:00000000
[<c01dbe78>] (platform_driver_register+0x0/0x60) from [<bf2ed014>] (ti81xxfb_init+0x14/0x34 [ti81xxfb])
[<bf2ed000>] (ti81xxfb_init+0x0/0x34 [ti81xxfb]) from [<c00383d8>] (do_one_initcall+0xd0/0x1a4)
[<c0038308>] (do_one_initcall+0x0/0x1a4) from [<c0092bd4>] (sys_init_module+0x9c/0x1bc)
[<c0092b38>] (sys_init_module+0x0/0x1bc) from [<c0042da0>] (ret_fast_syscall+0x0/0x30)
 r7:00000080 r6:00000003 r5:00008000 r4:00000000
Code: e24cb004 e24dd008 e59f30d0 e1a05000 (e5907000)
---[ end trace 659525c6a571a527 ]---
Segmentation fault
HDMI W1 rev 2.0
who can tell me how to do?
THANK YOU
zhou sheng
csuzhsh@gmail.com
15012490142
