I download AM35x-OMAP35x-LINUX-PSP-04.02.00.07
and almost time I got "Waiting for service media.audio_policy..." forever loop. Sometimes it continue to work.
your comment?
-------- beginning of /dev/log/main
I/DEBUG ( 987): debuggerd: Nov 10 201
1 19:05:52
--------- beginning of /dev/log/system
I/Vold ( 985): Vold 2.1 (the revenge) firing up
D/Vold ( 985): USB mass storage support is not enabled in the kernel
D/Vold ( 985): usb_configuration switch is not enabled in the kernel
I/Netd ( 986): Netd 1.0 starting
D/Vold ( 985): Volume sdcard state changing -1 (Initializing) -> 0 (No-Media)
D/Vold ( 985): Volume usbstore state changing -1 (Initializing) -> 0 (No-Media)
D/Vold ( 985): Volume usbotg state changing -1 (Initializing) -> 0 (No-Media)
D/Vold ( 985): Volume sdcard state changing 0 (No-Media) -> 2 (Pending)
D/Vold ( 985): Volume sdcard state changing 2 (Pending) -> 1 (Idle-Unmounted)
D/AndroidRuntime( 988):
D/AndroidRuntime( 988): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 988): CheckJNI is ON
D/dalvikvm( 988): creating instr width table
I/ ( 989): ServiceManager: 0xad50
W/AudioHardwareInterface( 989): Using stubbed audio hardware. No sound will be produced.
D/AudioHardwareInterface( 989): setMode(NORMAL)
I/SamplingProfilerIntegration( 988): Profiler is disabled.
I/Zygote ( 988): Preloading classes...
D/dalvikvm( 988): GC_EXPLICIT freed 47K, 78% free 233K/1024K, external 0K/0K, paused 3ms
D/dalvikvm( 988): GC_EXPLICIT freed 1K, 73% free 283K/1024K, external 0K/0K, paused 2ms
D/dalvikvm( 988): GC_EXPLICIT freed 20K, 70% free 316K/1024K, external 0K/0K, paused 2ms
I/bluetooth_ScoSocket.cpp( 988): Entry name = MY-CAR ScoTypes = 0x7f
I/bluetooth_ScoSocket.cpp( 988): Entry name = Motorola HF850 ScoTypes = 0x7
D/dalvikvm( 988): GC_EXPLICIT freed 17K, 66% free 354K/1024K, external 0K/0K, paused 2ms
D/dalvikvm( 988): GC_EXPLICIT freed 26K, 63% free 382K/1024K, external 0K/0K, paused 3ms
D/dalvikvm( 988): GC_EXPLICIT freed 21K, 57% free 441K/1024K, external 0K/0K, paused 4ms
W/MediaProfiles( 988): could not find media config xml file
D/dalvikvm( 988): GC_EXPLICIT freed 98K, 47% free 543K/1024K, external 0K/0K, paused 5ms
D/dalvikvm( 988): GC_EXPLICIT freed 271K, 24% free 882K/1155K, external 0K/0K, paused 9ms
D/dalvikvm( 988): GC_EXPLICIT freed 21K, 20% free 930K/1155K, external 0K/0K, paused 7ms
D/RenderScript_jni( 988): RenderScript JNI library not found!
D/dalvikvm( 988): GC_EXPLICIT freed 24K, 21% free 970K/1219K, external 0K/0K, paused 7ms
D/dalvikvm( 988): GC_EXPLICIT freed 24K, 6% free 1276K/1347K, external 0K/0K, paused 10ms
D/dalvikvm( 988): GC_EXPLICIT freed 24K, 4% free 1306K/1347K, external 0K/0K, paused 11ms
D/dalvikvm( 988): GC_EXPLICIT freed 28K, 6% free 1331K/1411K, external 0K/0K, paused 11ms
D/dalvikvm( 988): GC_EXPLICIT freed 14K, 3% free 1372K/1411K, external 0K/0K, paused 11ms
W/Zygote ( 988): Class not found for preloading: android.widget.TextView$SelectionModifierCursorController$1
D/dalvikvm( 988): GC_EXPLICIT freed 28K, 6% free 1397K/1475K, external 0K/0K, paused 11ms
D/dalvikvm( 988): GC_EXPLICIT freed 31K, 3% free 1436K/1475K, external 0K/0K, paused 11ms
D/dalvikvm( 988): GC_EXPLICIT freed 38K, 6% free 1453K/1539K, external 0K/0K, paused 11ms
D/dalvikvm( 988): GC_EXPLICIT freed 41K, 5% free 1468K/1539K, external 0K/0K, paused 12ms
D/dalvikvm( 988): GC_EXPLICIT freed 55K, 8% free 1481K/1603K, external 0K/0K, paused 13ms
D/dalvikvm( 988): GC_FOR_MALLOC freed 2893K, 57% free 2230K/5123K, external 0K/0K, paused 35ms
D/dalvikvm( 988): GC_EXPLICIT freed 2436K, 52% free 2485K/5123K, external 0K/0K, paused 33ms
D/dalvikvm( 988): GC_EXPLICIT freed 148K, 51% free 2549K/5123K, external 0K/0K, paused 24ms
D/dalvikvm( 988): GC_EXPLICIT freed 73K, 50% free 2574K/5123K, external 0K/0K, paused 23ms
D/dalvikvm( 988): GC_EXPLICIT freed 36K, 50% free 2591K/5123K, external 0K/0K, paused 23ms
D/dalvikvm( 988): GC_EXPLICIT freed 31K, 49% free 2615K/5123K, external 0K/0K, paused 23ms
D/dalvikvm( 988): GC_EXPLICIT freed 38K, 49% free 2638K/5123K, external 0K/0K, paused 25ms
I/Zygote ( 988): ...preloaded 1829 classes in 5391ms.
D/dalvikvm( 988): GC_EXPLICIT freed 18K, 49% free 2635K/5123K, external 0K/0K, paused 24ms
I/Zygote ( 988): Preloading resources...
D/dalvikvm( 988): GC_EXTERNAL_ALLOC freed <1K, 49% free 2637K/5123K, external 0K/0K, paused 23ms
D/dalvikvm( 988): GC_EXPLICIT freed 15K, 48% free 2676K/5123K, external 414K/521K, paused 23ms
D/dalvikvm( 988): GC_EXTERNAL_ALLOC freed 7K, 48% free 2686K/5123K, external 516K/521K, paused 24ms
I/Zygote ( 988): ...preloaded 51 resources in 469ms.
I/Zygote ( 988): ...preloaded 15 resources in 41ms.
D/dalvikvm( 988): GC_EXPLICIT freed 14K, 48% free 2710K
/5123K, external 716K/1038K, paused 24ms
D/dalvikvm( 988): GC_EXPLICIT freed 8K, 48% free 2702K/5123K, external 716K/1038K, paused 25ms
D/dalvikvm( 988): GC_EXPLICIT freed 1K, 48% free 2701K/5123K, external 716K/1038K, paused 24ms
I/dalvikvm( 988): System server process 1043 has been created
I/Zygote ( 988): Accepting command socket connections
E/BatteryService( 1043): Could not open /sys/class/power_supply
I/sysproc ( 1043): Entered system_init()
I/sysproc ( 1043): ServiceManager: 0x8d6e0
I/SurfaceFlinger( 1043): SurfaceFlinger is starting
I/SurfaceFlinger( 1043): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
D/libEGL ( 1043): loaded /system/lib/egl/libGLES_android.so
D/libEGL ( 1043): loaded /system/lib/egl/libEGL_POWERVR_SGX530_125.so
D/libEGL ( 1043): loaded /system/lib/egl/libGLESv1_CM_POWERVR_SGX530_125.so
D/libEGL ( 1043): loaded /system/lib/egl/libGLESv2_POWERVR_SGX530_125.so
W/SurfaceFlinger( 1043): ro.sf.lcd_density not defined, using 160 dpi by default.
E/libEGL ( 1043): eglSetSwapRectangleANDROID:1844 error 3008 (EGL_BAD_DISPLAY)
I/SurfaceFlinger( 1043): EGL informations:
I/SurfaceFlinger( 1043): # of configs : 36
I/SurfaceFlinger( 1043): vendor : Android
I/SurfaceFlinger( 1043): version : 1.4 Android META-EGL
I/SurfaceFlinger( 1043): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_ANDROID_image_native_buffer EGL_ANDROID_swap_rectangle
I/SurfaceFlinger( 1043): Client API: OpenGL ES
I/SurfaceFlinger( 1043): EGLSurface: 8-8-8-8, config=0x1
I/SurfaceFlinger( 1043): OpenGL informations:
I/SurfaceFlinger( 1043): vendor : Imagination Technologies
I/SurfaceFlinger( 1043): renderer : PowerVR SGX 530
I/SurfaceFlinger( 1043): version : OpenGL ES-CM 1.1
I/SurfaceFlinger( 1043): extensions: GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_matrix_get GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_point_sprite GL_OES_point_size_array GL_OES_matrix_palette GL_OES_draw_texture GL_OES_query_matrix GL_OES_texture_env_crossbar GL_OES_texture_mirrored_repeat GL_OES_texture_cube_map GL_OES_blend_subtract GL_OES_blend_func_separate GL_OES_blend_equation_separate GL_OES_stencil_wrap GL_OES_extended_matrix_palette GL_OES_framebuffer_object GL_OES_rgb8_rgba8 GL_OES_depth24 GL_OES_stencil8 GL_OES_compressed_ETC1_RGB8_texture GL_OES_mapbuffer GL_OES_EGL_image GL_EXT_multi_draw_arrays GL_OES_required_internalformat GL_IMG_read_format GL_IMG_texture_compression_pvrtc GL_IMG_texture_format_BGRA8888 GL_EXT_texture_format_BGRA8888 GL_IMG_texture_stream GL_OES_egl_sync GL_IMG_vertex_array_object
I/SurfaceFlinger( 1043): GL_MAX_TEXTURE_SIZE = 2048
I/SurfaceFlinger( 1043): GL_MAX_VIEWPORT_DIMS = 2048
I/SurfaceFlinger( 1043): flags = 00010000
D/SensorService( 1043): nuSensorService starting...
E/SensorService( 1043): couldn't load sensors module (No such file or directory)
I/sysproc ( 1043): System server: starting Android runtime.
I/sysproc ( 1043): System server: starting Android services.
I/sysproc ( 1043): System server: entering thread pool.
I/SystemServer( 1043): Entered the Android system server!
I/SystemServer( 1043): Entropy Service
D/libEGL ( 1057): loaded /system/lib/egl/libGLES_android.so
D/libEGL ( 1057): loaded /system/lib/egl/libEGL_POWERVR_SGX530_125.so
D/libEGL ( 1057): loaded /system/lib/egl/libGLESv1_CM_POWERVR_SGX530_125.so
D/libEGL ( 1057): loaded /system/lib/egl/libGLESv2_POWERVR_SGX530_125.so
W/zipro ( 1057): Unable to open zip '/data/local/bootanimation.zip': No such file or directory
W/zipro ( 1057): Unable to open zip '/system/media/bootanimation.zip': No such file or directory
I/SystemServer( 1043): Power Manager
E/SurfaceFlinger( 1043): eglSwapBuffers: EGL error 0x3008 (EGL_BAD_DISPLAY)
I/SystemServer( 1043): Activity Manager
I/ActivityManager( 1043): Memory class: 16
W/UsageStats( 1043): Usage stats version changed; dropping
I/SystemServer( 1043): Telephony Registry
I/SystemServer( 1043): Package Manager
I/installd( 991): new connection
I/Installer( 1043): connecting...
D/dalvikvm( 1043): GC_CONCURRENT freed 204K, 47% free 3015K/5639K, external 716K/1038K, paused 3ms+3ms
W/PackageManager( 1043): Running ENG build: no pre-dexopt!
D/dalvikvm( 1043): GC_CONCURRENT freed 199K, 46% free 3216K/5895K, external 716K/1038K, paused 2ms+3ms
D/dalvikvm( 1043): GC_CONCURRENT freed 216K, 44% free 3467K/6151K, external 716K/1038K, paused 3ms+5ms
W/PackageParser( 1043): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #124
D/PackageManager( 1043): No files in app dir /vendor/app
I/PackageManager( 1043): Time to scan packages: 4.606 seconds
W/PackageManager( 1043): Unknown permission com.google.andr
oid.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts
W/PackageManager( 1043): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts
W/PackageManager( 1043): Unknown permission com.google.android.gm.permission.WRITE_GMAIL in package com.android.settings
W/PackageManager( 1043): Unknown permission com.google.android.gm.permission.READ_GMAIL in package com.android.settings
W/PackageManager( 1043): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 1043): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts
W/PackageManager( 1043): Unknown permission android.permission.ADD_SYSTEM_SERVICE in package com.android.phone
W/PackageManager( 1043): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 1043): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 1043): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 1043): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 1043): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 1043): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
W/PackageManager( 1043): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 1043): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 1043): Unknown permission android.permission.READ_OWNER_DATA in package com.android.email
W/PackageManager( 1043): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
D/dalvikvm( 1043): GC_EXPLICIT freed 312K, 45% free 3492K/6279K, external 716K/1038K, paused 33ms
I/SystemServer( 1043): Account Manager
I/SystemServer( 1043): Content Manager
I/SystemServer( 1043): System Content Providers
I/ActivityThread( 1043): Pub settings: com.android.providers.settings.SettingsProvider
I/SystemServer( 1043): Battery Service
I/SystemServer( 1043): Lights Service
D/SettingsProvider( 1043): cache for settings table 'secure' rows=25; fullycached=true
I/SystemServer( 1043): Vibrator Service
D/SettingsProvider( 1043): cache for settings table 'system' rows=49; fullycached=true
I/SystemServer( 1043): Alarm Manager
I/SystemServer( 1043): Init Watchdog
I/SystemServer( 1043): Window Manager
I/InputManager( 1043): Initializing input manager
I/InputManager( 1043): Starting input manager
I/SystemServer( 1043): Bluetooth Service
E/EventHub( 1043): could not get driver version for /dev/input/mice, Not a typewriter
I/EventHub( 1043): New device: path=/dev/input/event1 name=ADS7846 Touchscreen id=0x10000 (of 0x1) index=1 fd=86 classes=0x4
E/EventHub( 1043): could not get driver version for /dev/input/mouse0, Not a typewriter
I/BluetoothProfileState( 1043): Message:Entering Stable State
I/SystemServer( 1043): Device Policy
I/SystemServer( 1043): Status Bar
I/SystemServer( 1043): Clipboard Service
I/SystemServer( 1043): Input Method Service
I/EventHub( 1043): New keyboard: device->id=0x10001 devname=' USB Keyboard' propName='hw.keyboards.65537.devname' keylayout='/system/usr/keylayout/qwerty.kl'
I/EventHub( 1043): New device: path=/dev/input/event4 name= USB Keyboard id=0x10001 (of 0x2) index=2 fd=88 classes=0x1
I/EventHub( 1043): New keyboard: device->id=0x10002 devname=' USB Keyboard' propName='hw.keyboards.65538.devname' keylayout='/system/usr/keylayout/qwerty.kl'
I/EventHub( 1043): New device: path=/dev/input/event3 name= USB Keyboard id=0x10002 (of 0x3) index=3 fd=92 classes=0x3
I/EventHub( 1043): New keyboard: device->id=0x20003 devname='twl4030_pwrbutton' propName='hw.keyboards.131075.devname' keylayout='/system/usr/keylayout/qwerty.kl'
I/EventHub( 1043): New device: path=/dev/input/event2 name=twl4030_pwrbutton id=0x20003 (of 0x4) index=4 fd=93 classes=0x1
I/InputReader( 1043): Device added: id=0x20003, name=twl4030_pwrbutton, sources=00000101
I/InputReader( 1043): Device added: id=0x10002, name= USB Keyboard, sources=00000101
Device added: id=0x0, name= USB Keyboard, sources=00000101
I/InputReader( 1043): Device added: id=0x10000, name=ADS7846 Touchscreen, sources=00001002
I/InputManager-Callbacks( 1043): No input device calibration properties found for device twl4030_pwrbutton.
I/InputManager-Callbacks( 1043): No input device calibration properties found for device USB Keyboard.
I/InputManager-Callbacks( 1043): No input device calibration properties found for device ADS7846 Touchscreen.
I/InputManagerService( 1043): Enabled input methods: com.android.inputmethod.latin/.LatinIME
I/SystemServer( 1043): NetStat Service
I/SystemServer( 1043): NetworkManagement Service
I/SystemServer( 1043): Connectivity Service
I/WifiService( 1043): WifiService starting up with Wi-Fi disabled
D/NetworkManagmentService( 1043): Registering observer
I/SystemServer( 1043): Throttle Service
I/SystemServer( 1043): Accessibility Manager
I/SystemServer( 1043): Mount Service
I/SystemServer( 1043): Notification Manager
I/SystemServer( 1043): Device Storage Monitor
I/SystemServer( 1043): Location Manager
I/SystemServer( 1043): Search Service
I/SystemServer( 1043): DropBox Service
I/SystemServer( 1043): Wallpaper Service
I/PackageManager( 1043): Updating external media status from unmounted to unmounted
D/VoldCmdListener( 985): volume list
W/MountService( 1043): Skipping unknown volume '/mnt/usb'
W/MountService( 1043): Skipping unknown volume '/mnt/otg'
I/SystemServer( 1043): Audio Service
D/VoldCmdListener( 985): share status ums
I/ServiceManager( 1043): Waiting for service media.audio_policy...
D/dalvikvm( 1043): GC_CONCURRENT freed 210K, 42% free 3752K/6407K, external 716K/1038K, paused 3ms+3ms
W/AudioSystem( 1043): AudioPolicyService not published, waiting...
