omap3evm browser crash?
I was doing development and experienced this, then went back to the original image which behaves the same:
If the small world icon is used to launch the browser, the page loads about 90% of the way and then goes away.  If the browser is launched from the top search bar, it loads fine.  This started happening earlier this week, and I just verified this morning that it happens with the original image.  The logcat is below, and I must admit to not being very good with java (or dalvik) backtraces.   But, the fault address of deadd00d in the segv register dump is probably suspect.
I/ActivityManager( 1219): Starting: Intent { act=android.intent.action.MAIN flg=0x10000000 cmp=com.android.browser/.BrowserActivity } from pid 1343
D/dalvikvm( 4452): GC_EXTERNAL_ALLOC freed 66K, 51% free 3081K/6279K, external 998K/1038K, paused 27ms
I/ActivityManager( 1219): Displayed com.android.browser/.BrowserActivity: +229ms
D/dalvikvm( 4452): GC_CONCURRENT freed 112K, 47% free 3367K/6279K, external 1151K/1663K, paused 2ms+5ms
D/wpa_supplicant( 1361): CMD: DRIVER RSSI-APPROX
D/wpa_supplicant( 1361): wpa_driver_priv_driver_cmd RSSI-APPROX
D/wpa_supplicant( 1361): [REPLY]: belkin54g rssi -45
D/wpa_supplicant( 1361): CMD: DRIVER LINKSPEED
D/wpa_supplicant( 1361): wpa_driver_priv_driver_cmd LINKSPEED
D/wpa_supplicant( 1361): [REPLY]: LinkSpeed 54
W/dalvikvm( 4452): JNI WARNING: JNI method called with exception raised
W/dalvikvm( 4452):              in Landroid/webkit/JWebCoreJavaBridge;.sharedTimerFired ()V (NewLocalRef)
W/dalvikvm( 4452): Pending exception is:
I/dalvikvm( 4452): Ljava/lang/IllegalArgumentException;: provider=gps
I/dalvikvm( 4452):     at android.os.Parcel.readException(Parcel.java:1326)
I/dalvikvm( 4452):     at android.os.Parcel.readException(Parcel.java:1276)
I/dalvikvm( 4452):     at android.location.ILocationManager$Stub$Proxy.requestLocationUpdates(ILocationManager.java:646)
I/dalvikvm( 4452):     at android.location.LocationManager._requestLocationUpdates(LocationManager.java:582)
I/dalvikvm( 4452):     at android.location.LocationManager.requestLocationUpdates(LocationManager.java:446)
I/dalvikvm( 4452):     at android.webkit.GeolocationService.registerForLocationUpdates(GeolocationService.java:162)
I/dalvikvm( 4452):     at android.webkit.GeolocationService.start(GeolocationService.java:66)
I/dalvikvm( 4452):     at android.webkit.JWebCoreJavaBridge.sharedTimerFired(Native Method)
I/dalvikvm( 4452):     at android.webkit.JWebCoreJavaBridge.fireSharedTimer(JWebCoreJavaBridge.java:91)
I/dalvikvm( 4452):     at android.webkit.JWebCoreJavaBridge.handleMessage(JWebCoreJavaBridge.java:108)
I/dalvikvm( 4452):     at android.os.Handler.dispatchMessage(Handler.java:99)
I/dalvikvm( 4452):     at android.os.Looper.loop(Looper.java:130)
I/dalvikvm( 4452):     at android.webkit.WebViewCore$WebCoreThread.run(WebViewCore.java:629)
I/dalvikvm( 4452):     at java.lang.Thread.run(Thread.java:1019)
I/dalvikvm( 4452): "WebViewCoreThread" prio=5 tid=11 NATIVE
I/dalvikvm( 4452):   | group="main" sCount=0 dsCount=0 obj=0x407856a0 self=0x218e88
I/dalvikvm( 4452):   | sysTid=4465 nice=0 sched=0/0 cgrp=[fopen-error:2] handle=1004928
I/dalvikvm( 4452):
E/dalvikvm( 4452): VM aborting
I/DEBUG   ( 4379): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG   ( 4379): Build fingerprint: 'TI/omap3evm/omap3evm:2.3.4/GRJ22/eng.a0131746.20110707.223100:eng/test-keys'
I/DEBUG   ( 4379): pid: 4452, tid: 4465  >>> com.android.browser <<<
I/DEBUG   ( 4379): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr deadd00d
I/DEBUG   ( 4379):  r0 fffffe84  r1 deadd00d  r2 00000026  r3 00000000
I/DEBUG   ( 4379):  r4 800a5600  r5 00000000  r6 80087738  r7 00000000
I/DEBUG   ( 4379):  r8 43747b58  r9 40062f0c  10 40062ef4  fp 40798178
I/DEBUG   ( 4379):  ip 800a570c  sp 43747a60  lr afd191d9  pc 80046240  cpsr 20000030
I/DEBUG   ( 4379):  d0  74726f6261204d69  d1  436265572465726e
I/DEBUG   ( 4379):  d2  6f43776569566267  d3  6f4362655724650a
I/DEBUG   ( 4379):  d4  41597f3c41597f08  d5  4159912841597f70
I/DEBUG   ( 4379):  d6  415991904159915c  d7  00096f1400000851
I/DEBUG   ( 4379):  d8  fffffffffffffffa  d9  41cc36a5814e4620
I/DEBUG   ( 4379):  d10 0000000000000000  d11 0000000000000000
I/DEBUG   ( 4379):  d12 0000000000000000  d13 0000000000000000
I/DEBUG   ( 4379):  d14 0000000000000000  d15 0000000000000000
I/DEBUG   ( 4379):  d16 fffffffffffffffa  d17 3fe3c8c9320d9946
I/DEBUG   ( 4379):  d18 4122de2800000000  d19 412e848000000000
I/DEBUG   ( 4379):  d20 4059000000000000  d21 0000000000000000
I/DEBUG   ( 4379):  d22 0000000000000000  d23 0000000000000000
I/DEBUG   ( 4379):  d24 3ff0000000000000  d25 0000000000000000
I/DEBUG   ( 4379):  d26 0000000000000000  d27 0000000000000000
I/DEBUG   ( 4379):  d28 0000000000000000  d29 3ff0000000000000
I/DEBUG   ( 4379):  d30 0000000000000000  d31 3ff0000000000000
I/DEBUG   ( 4379):  scr 20000013
I/DEBUG   ( 4379):
I/DEBUG   ( 4379):          #00  pc 00046240  /system/lib/libdvm.so
I/DEBUG   ( 4379):          #01  pc 0003760c  /system/lib/libdvm.so
I/DEBUG   ( 4379):          #02  pc 00037726  /system/lib/libdvm.so
I/DEBUG   ( 4379):          #03  pc 00039046  /system/lib/libdvm.so
I/DEBUG   ( 4379):          #04  pc 001720ae  /system/lib/libwebcore.so
I/DEBUG   ( 4379):          #05  pc 0016f268  /system/lib/libwebcore.so
I/DEBUG   ( 4379):
I/DEBUG   ( 4379): code around pc:
I/DEBUG   ( 4379): 80046220 447a4479 f7d14c0b 2000e996 ea9af7d1
I/DEBUG   ( 4379): 80046230 447c4809 6bdb5823 4798b103 22264902
I/DEBUG   ( 4379): 80046240 f7d1700a bf00eb02 deadd00d 0004383f
I/DEBUG   ( 4379): 80046250 000453fd 0005f3ca fffffe84 4b09b40e
I/DEBUG   ( 4379): 80046260 4c09b517 aa05447b f852591b 6b5b1b04
I/DEBUG   ( 4379):
I/DEBUG   ( 4379): code around lr:
I/DEBUG   ( 4379): afd191b8 4a0e4b0d e92d447b 589c41f0 26004680
I/DEBUG   ( 4379): afd191c8 686768a5 f9b5e006 b113300c 47c04628
I/DEBUG   ( 4379): afd191d8 35544306 37fff117 6824d5f5 d1ef2c00
I/DEBUG   ( 4379): afd191e8 e8bd4630 bf0081f0 00028344 ffffff88
I/DEBUG   ( 4379): afd191f8 b086b570 f602fb01 9004460c a804a901
I/DEBUG   ( 4379):
I/DEBUG   ( 4379): stack:
I/DEBUG   ( 4379):     43747a20  afd42664
I/DEBUG   ( 4379):     43747a24  000a7dd8
I/DEBUG   ( 4379):     43747a28  00000015
I/DEBUG   ( 4379):     43747a2c  afd182a1  /system/lib/libc.so
I/DEBUG   ( 4379):     43747a30  afd4270c
I/DEBUG   ( 4379):     43747a34  afd426b8
I/DEBUG   ( 4379):     43747a38  00000000
I/DEBUG   ( 4379):     43747a3c  afd191d9  /system/lib/libc.so
I/DEBUG   ( 4379):     43747a40  0005f3ca
I/DEBUG   ( 4379):     43747a44  00000000
I/DEBUG   ( 4379):     43747a48  80087738  /system/lib/libdvm.so
I/DEBUG   ( 4379):     43747a4c  00000000
I/DEBUG   ( 4379):     43747a50  43747b58
I/DEBUG   ( 4379):     43747a54  afd182d1  /system/lib/libc.so
I/DEBUG   ( 4379):     43747a58  df002777
I/DEBUG   ( 4379):     43747a5c  e3a070ad
I/DEBUG   ( 4379): #00 43747a60  00000001
I/DEBUG   ( 4379):     43747a64  80037611  /system/lib/libdvm.so
I/DEBUG   ( 4379): #01 43747a68  00000001
I/DEBUG   ( 4379):     43747a6c  8003772b  /system/lib/libdvm.so
I/BootReceiver( 1219): Copying /data/tombstones/tombstone_04 to DropBox (SYSTEM_TOMBSTONE)
I/DEBUG   ( 4379): debuggerd committing suicide to free the zombie!
I/DEBUG   ( 4896): debuggerd: Jul  7 2011 23:36:31
D/dalvikvm( 1219): GC_FOR_MALLOC freed 705K, 49% free 4375K/8455K, external 1916K/2428K, paused 42ms
D/Zygote  ( 1119): Process 4452 terminated by signal (11)
E/InputDispatcher( 1219): channel '4082dc38 com.android.browser/com.android.browser.BrowserActivity (server)' ~ Consumer closed input channel or an error occurred.  events=0x8
E/InputDispatcher( 1219): channel '4082dc38 com.android.browser/com.android.browser.BrowserActivity (server)' ~ Channel is unrecoverably broken and will be disposed!
D/dalvikvm( 1219): GC_FOR_MALLOC freed 378K, 46% free 4573K/8455K, external 1916K/2428K, paused 31ms
I/WindowManager( 1219): WINDOW DIED Window{4082dc38 com.android.browser/com.android.browser.BrowserActivity paused=false}
I/ActivityManager( 1219): Process com.android.browser (pid 4452) has died.
E/InputDispatcher( 1219): channel '409586f0 com.android.browser/com.android.browser.BrowserActivity (server)' ~ Consumer closed input channel or an error occurred.  events=0x8
E/InputDispatcher( 1219): channel '409586f0 com.android.browser/com.android.browser.BrowserActivity (server)' ~ Channel is unrecoverably broken and will be disposed!
I/WindowManager( 1219): WINDOW DIED Window{409586f0 com.android.browser/com.android.browser.BrowserActivity paused=false}
W/WindowManager( 1219): Failed looking up window
W/WindowManager( 1219): java.lang.IllegalArgumentException: Requested window android.os.BinderProxy@4082da40 does not exist
W/WindowManager( 1219):     at com.android.server.WindowManagerService.windowForClientLocked(WindowManagerService.java:8206)
W/WindowManager( 1219):     at com.android.server.WindowManagerService.windowForClientLocked(WindowManagerService.java:8197)
W/WindowManager( 1219):     at com.android.server.WindowManagerService$WindowState$DeathRecipient.binderDied(WindowManagerService.java:7056)
W/WindowManager( 1219):     at android.os.BinderProxy.sendDeathNotice(Binder.java:381)
W/WindowManager( 1219):     at dalvik.system.NativeStart.run(Native Method)
I/WindowManager( 1219): WIN DEATH: null
W/WindowManager( 1219): java.lang.IllegalArgumentException: Requested window android.os.BinderProxy@409584f8 does not exist
W/InputManagerService( 1219): Got RemoteException sending setActive(false) notification to pid 4452 uid 10020
