Other Parts Discussed in Thread: DRA821U, SYSCONFIG, DRA821
Hi Kevin,
We are using DRA821U2-Q1 SoC with LPDDR4, MT53D1024M32D4DT which has 8GB density (dual channel, dual band).
We started with DRA821U TI EVM which has DDR: MT53D1024M32D4DT which has 4GB density.
Now we need to re-config the DDR register configuration with tool: https://www.ti.com/lit/zip/spracu8
I noticed that MT53D1024M32D4DT was used on TDA4VE (TI EVM).
Question:
- When select DRA821U(TI EVM) and Click on Load User Config, this will load EVM board config, correct? then I can revise for my board, right?
- Can I take the TDA4VE (TI EVM) DDR parameter configuration from the configuration spreadsheet for my DRA821U2-Q1 board since it uses the same DDR device as TDA4AE(TI EVM)?
Of course, I will take numbers for DDRSS_0 only since DAR821U2 has only DDRSS_0
Thank you !
Max
