DRA821U: DRA821U4
Part Number: DRA821U
U-Boot 2023.04-g286de9bf-dirty (Oct 10 2024 - 10:37:46 +0900)
SoC: J7200 SR2.0 GP
Model: Texas Instruments K3 J7200 SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -121
Board: J721EX-PM1-SOM rev E2
DRAM: 2 GiB (effective 4 GiB)
Core: 85 devices, 32 uclasses, devicetree: separate
Flash: 0 Bytes
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
Loading Environment from nowhere... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
Net: eth0: ethernet@46000000port@1
Hit any key to stop autoboot: 0
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
Card did not respond to voltage select! : -110
mmc_init: -95, time 113
SD/MMC found on device 1
mmc_init: -95, time 71
** Bad device specification mmc 1 **
Couldn't find partition mmc 1
Can't set block device
pca953x gpio@21: Error reading output register
pca953x gpio@20: Error reading output register
GPIO: 'gpio@22_17' not found
Command 'gpio' failed: Error -22
GPIO: 'gpio@22_16' not found
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
Couldn't find partition mmc 1:2
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Bad Linux ARM64 Image magic!
switch to partitions #0, OK
mmc0(part 0) is current device
** No partition table - mmc 0 **
Couldn't find partition mmc 0:1
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled
am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 2
link up on port 1, speed 10, half duplex
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-58-a1-5f-bd-8c-93
*** ERROR: `serverip' not set
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-k3-j721e
Config file not found
starting USB...
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
When booting the DRA821U4T from the SD card, it fails to boot.
I would like to know if there are any suspected causes and solutions.
  • HI Lee,
    Just a couple of questions to ask:
    1:Are you using a custom board or TI j7200 evm.
    2:Are you using the prebuild SDK binaries or have you applied any changes to it.
    3:Can you also help us with the hardware schematics for the SD card in case you are using an SD card.
    4:Can you also help us with the SDK version you are using.
    Gokul
  • Dear TI
    Please find our answers below.
    : We are using a custom board.
    : We applied some changes based on SDK.
      And this problem is occurring only in one out of ten samples.
    : Lee will update schematic for the SD card soon.
    : We are using ti-processor-sdk-linux-j7200-evm-09_02_00_04
    BR
    Jace
  • Hi Lee,
    Can you also help us with the changes you made in the SDK,if possible?
    Also,just for confirmation, hope you had applied the sync command after copying all the files to the board.
    Gokul
  • 8.pdf
    See SD card Hardware circuit.
  • Hi Lee,
    We have informed the hardware expert to verify the schematics.We will get back to you as soon as it is verified.
    Gokul
  • SD card supports only 3.3V, thus will not support UHS-I data rates.  Ensure the SDCard interface is NOT switching to higher speeds (requires lower IO voltages).  I think the default software from TI reads the card and switches to lower voltage/higher speeds if supported by the card.  Customer will need to disable that switch, as their board will not support.
    Also the EVM (and TI software) expects EEPROM on board to contain configuration information.  If the EEPROM does not exist, then customer can remove that section of code and provide any missing information via other mechanism.
  • Hi Robert Eschler
    We set the I/O Power domain of the SD card to 3.3V and are using a '16GB/UHS-I 50' SD card.
    Please refer to the SD card in the link below.
    www.mouser.kr/.../SDSDQAB-016G
    Does the DRA821U4 not support UHS-I?
    Best Regard
  • Hi Lee,
    I/O Power domain of 3.3 V which you have given only supports SD and HS speed mode.However,to support UHS-1  speed mode,only I/O voltage of 1.8V is supported.
    According to your hardware schematics,a fixed I/O voltage of 3.3V is present thus preventing UHS1 speed modes.
    I am also attaching the supported I/O voltage to speed mode relationship in the figure below.
