RESIZER ON DM6446
hello:
I tried to resize the frame from 720*576 to 352 *288 by using the resizer module base on SEED DM6446 EVM, I found the color of image is changed by resize Coprocessor.
this is my initial program code:
#define IN_HEIGHT      576
#define IN_WIDTH      720
#define IN_PITCH      1440
#define OUT_HEIGHT      288
#define OUT_WIDTH      352
#define OUT_PITCH      704
  static rsz_params_t resizer_params = {
 720, /* in_hsize */
 576, /* in_vsize */
 1440, /* in_pitch */
 RSZ_INTYPE_YCBCR422_16BIT, /* inptyp */
 0, /* vert_starting_pixel */
 0, /* horz_starting_pixel */
 0, /* cbilin */
 RSZ_PIX_FMT_UYVY, /* pix_fmt */
 352, /* out_hsize */
 288, /* out_vsize */
 704, /* out_pitch */
 0, /* hstph */
 0, /* vstph */
 /*horizontal resizing filter coefficients: */
  -1,
  19,
  110,
  110,
  19,
  -1,
  0,
  0,
  0,
  7,
  87,
  125,
  38,
  -1,
  0,
  0,
  0,
  0,
  61,
  134,
  61,
  0,
  0,
  0,
  0,
  -1,
  38,
  125,
  87,
  7,
  0,
  0,
 /*vertical resizing filter coefficients: */
  39,
  178,
  39,
  0,
  25,
  175,
  56,
  0,
  14,
  164,
  78,
  0,
  8,
  146,
  101,
  1,
  4,
  124,
  124,
  4,
  1,
  101,
  146,
  8,
  0,
  78,
  164,
  14,
  0,
  56,
  175,
  25,
  RSZ_YENH_DISABLE,
 int ch_fd = open("/dev/davinci_resizer", O_RDWR);
 if (ch_fd < 0){
  printf("\n Resizer device open failed%d\n",ch_fd);
  return 0;
 /* ==========================RSZ_BUF_IN========================== */
 ch_req_inbufs.buf_type = RSZ_BUF_IN;
 ch_req_inbufs.size =  IN_HEIGHT * IN_WIDTH * 2;
 ch_req_inbufs.count = 1;
 if (ioctl(ch_fd, RSZ_REQBUF, &ch_req_inbufs) == -1) {
 printf("\n buffer allocation error \n%d",ch_fd);
 close(ch_fd);
 return 0;
 /* ==========================RSZ_BUF_OUT========================= */
 ch_req_outbufs.buf_type = RSZ_BUF_OUT;
 ch_req_outbufs.size = OUT_HEIGHT * OUT_WIDTH * 2;
 ch_req_outbufs.count = 1;
 if (ioctl(ch_fd, RSZ_REQBUF, &ch_req_outbufs) == -1) {
  close(ch_fd);
  return 0;
 /* ==========================RSZ_G_STATUS======================== */
 if (ioctl(ch_fd, RSZ_G_STATUS, &ch1_stat) == -1)
  printf("\n Get Status failed \n%d",ch_fd);
  close(ch_fd);
  return 0;
 /* ==========================RSZ_S_EXP=========================== */
 if (ioctl(ch_fd, RSZ_S_EXP, &ch1_dig) == -1)
  printf("\nGet Status failed \n%d",ch_fd);
  close(ch_fd);
  return 0;
 /* ==========================RSZ_QUERYBUF  IN==================== */
 ch_bufd.buf_type = RSZ_BUF_IN;
 ch_bufd.index = 0;
 if (ioctl(ch_fd, RSZ_QUERYBUF, &ch_bufd) == -1)
  printf("\nquery buffer failed \n%d",ch_fd);
  close(ch_fd);
  return 0;
 ch_resize.in_buf.offset = ch_bufd.offset;
 ch_inBuf =(char *) mmap(0, IN_HEIGHT * IN_WIDTH * 2, PROT_READ | PROT_WRITE,MAP_SHARED, ch_fd,  ch_bufd.offset);
 /* ==========================RSZ_QUERYBUF  OUT=================== */
 ch_bufd.buf_type = RSZ_BUF_OUT;
 ch_bufd.index = 0;
  close(ch_fd);
  return 0;
 ch_resize.out_buf.offset = ch_bufd.offset;
 ch_outBuf = (char *) mmap(0, OUT_HEIGHT * OUT_WIDTH * 2,PROT_READ | PROT_WRITE, MAP_SHARED, ch_fd,ch_bufd.offset);
 /* ==========================RSZ_S_PARAM========================= */
 resizer_params.yenh_params.type = RSZ_YENH_DISABLE;
 resizer_params.yenh_params.gain = 0x7f;
 resizer_params.yenh_params.slop = 0x7f;
 resizer_params.yenh_params.core = 0;
 if (ioctl(ch_fd, RSZ_S_PARAM, &resizer_params) == -1)
  printf("\nSetting parameters failed \n%d",ch_fd);
  close(ch_fd);
  return 0;
 /* ==========================RSZ_S_PRIORITY====================== */
 ch_prio.priority = 0;
 if (ioctl(ch_fd, RSZ_S_PRIORITY, &ch_prio) == -1)
  close(ch_fd);
  return 0;
 rszSpeed = 0;
 if (  ioctl( ch_fd, RSZ_S_EXP, &rszSpeed ) == -1 ) //set the resizer speed to fastest
  printf("\nSetting speed failed \n%d",ch_fd);
  close(ch_fd);
  return 0;
 ch_resize.in_buf.index  = -1;
 ch_resize.out_buf.index  = -1;
 ch_resize.in_buf.size   = IN_HEIGHT * IN_WIDTH * 2; //IN_HEIGHT * IN_WIDTH;
 ch_resize.out_buf.size  = OUT_HEIGHT * OUT_WIDTH * 2; //IN_HEIGHT * IN_WIDTH;
                     can any one suggest me where is the problem???
         yuan shu
  • Hi there
    I don't have specific experience on the 6446, but on my 6437 I had endless problems getting the resizer to do what I wanted.  After some to and fro with TI support, we came to the conclusion that arbitrary resizing was not possible, in any case not using the PSP drivers for my device. Luckily, my downscaling needs were such that I needed to pass the image through the resizer twice anyway. This enabled me to choose first and second pass scaling ratios that the resizer could handle, and which gave me the desired output size.
    Hope this helps a little
    Leon
