I am trying to port a DSP/BIOS code to SYS/BIOS. What is the equivalent of the ATM module in SYS/BIOS?
I checked the migration guide, but it says that there is no support for ATM in SYS/BIOS :-(
Please help.
Thanks.
Divya
Please help.
Thanks.
Divya
Which device are you running on? If you are running on one of the C6x devices, then you can still use ATM.
Add the following to your .cfg file:
xdc.loadPackage('ti.bios');
And then use #include <ti/bios/include/atm.h> in your code before you use the ATM_inc(), etc.
The ATM APIs were created to allow for simple inc/dec of variables. The TI compiler now provides built-in interrupt disable, enable and restore instrinsics which can be used in your code in place of the ATM APIs.
To increment a variable:
key = _disable_interrupts();
var++;
_restore_interrupts(key);
If you use ATM in a lot of your code, you might be able to write a MYATM module (.h file) some inline functions that use the above intrinsics.
-Karl-
