TDA4VM: Mini Display-port to HDMI broken in 9.1
Part Number: TDA4VM
I have a board similar to the J721E evm.  When I plug in an active Mini DP -> HDMI converter (from CableMatters - https://www.cablematters.com/pc-521-153-active-mini-displayport-to-hdmi-adapter-4k-ready.aspx), it works on versions 8.2 and 8.6.  But when I run it on 9.1, DSS fails and I can't run vision applications (see MCU2_0 logs below).
[MCU2_0]     14.815746 s: DSS: SoC init ... Done !!!
[MCU2_0]     14.815767 s: DSS: Board init ... !!!
[MCU2_0]     14.815789 s: DSS: Turning on DP_PWR pin for eDP adapters ... !!!
[MCU2_0]     14.819925 s: DSS: ERROR: Turning on DP_PWR pin for eDP adapters failed !!!
[MCU2_0]     14.819985 s: DSS: Board init ... Done !!!
[MCU2_0]     14.838366 s: Dss_dctrlDrvSetVpParamsIoctl[1142] ret: 0
[MCU2_0]     14.838446 s: Dss_dctrlDrvEnableVideoDP[275] ret: 0
[MCU2_0]     14.838493 s: Dss_dctrlDrvEnableVideoDP[291] ret: 0
[MCU2_0]     14.838534 s: Dss_dctrlDrvSetVpParamsIoctl[1174] ret: 0
[MCU2_0]     14.838603 s: DSS: Init ... Done !!!
Is this fixed in later versions like 10.0 or 10.1?  If not - is there some other way to fix this issue?
Thank you!
