Part Number: J784S4XEVM
Hi TI experts,
We received 3 J784S4 EVM with PCB# PROC141E5 from TI and 4 ordered from TI website and are in the same LOT# 1121202401.
We faced rebooting issue using prebuilt image from SDK 10.01.00.04 after approx. 13-15 min with the EVM. We have seen the rebooting issue with 4 EVMs so far.
Please see log from my last 'uptime' command till the reboot event occurred
[ OK ] Finished Print notice about GPLv3 packages.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Record Runlevel Change in UTMP...
[ OK ] Finished Record Runlevel Change in UTMP.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project j784s4-evm ttyS2
Arago 2023.10 j784s4-evm ttyS2
j784s4-evm login: [ 22.989730] platform connector-dp0: deferred probe pending
[ 22.995224] platform regulator-dp0-prw: deferred probe pending
[ 23.001049] platform regulator-dp1-prw: deferred probe pending
[ 23.006875] platform a000000.bridge: deferred probe pending
j784s4-evm login: root
[ 587.920056] kauditd_printk_skb: 8 callbacks suppressed
[ 587.920063] audit: type=1006 audit(1728488452.504:16): pid=1175 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[ 587.938856] audit: type=1300 audit(1728488452.504:16): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff953d918 a2=1 a3=1 items=0 ppid=1 pid=1175 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 )
[ 587.966452] audit: type=1327 audit(1728488452.504:16): proctitle="(systemd)"
[ 587.973601] audit: type=1334 audit(1728488452.520:17): prog-id=18 op=LOAD
[ 587.980418] audit: type=1300 audit(1728488452.520:17): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc0a8b9c8 a2=90 a3=0 items=0 ppid=1 pid=1175 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=)
[ 588.007258] audit: type=1327 audit(1728488452.520:17): proctitle="(systemd)"
[ 588.014310] audit: type=1334 audit(1728488452.524:18): prog-id=18 op=UNLOAD
[ 588.021274] audit: type=1300 audit(1728488452.524:18): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff98039c60 items=0 ppid=1 pid=1175 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 )
[ 588.047908] audit: type=1327 audit(1728488452.524:18): proctitle="(systemd)"
[ 588.054954] audit: type=1334 audit(1728488452.524:19): prog-id=19 op=LOAD
root@j784s4-evm:~# uptime
15:40:55 up 9 min, 1 user, load average: 0.00, 0.02, 0.00
root@j784s4-evm:~#
U-Boot SPL 2024.04-ti-ga970f6e51043 (Nov 13 2024 - 14:26:23 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.6--v10.01.06 (Fiery Fox)')
Initialized 4 DRAM controllers
SPL initial stack usage: 13456 bytes
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE: BL31: v2.11.0(release):v2.11.0-906-g58b25570c9-dirty
NOTICE: BL31: Built : 04:20:32, Nov 1 2024
I/TC:
I/TC: OP-TEE version: 4.4.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Oct 18 17:45:27 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.6--v10.01.06 (Fiery Fox)')
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: HUK Initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2024.04-ti-ga970f6e51043 (Nov 13 2024 - 14:26:23 +0000)
SoC: J784S4 SR1.0 GP
Model: Texas Instruments J784S4 EVM
DRAM: 2 GiB (effective 32 GiB)
Core: 143 devices, 35 uclasses, devicetree: separate
Flash: spi_nand nand@0: Winbond SPI NAND was found.
spi_nand nand@0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled
cadence_spi spi@47040000: Pattern not found. Skipping calibration
0 Bytes
MMC: mmc@4f80000: 0, mmc@4fb0000: 1
In: serial@2880000
Out: serial@2880000
Err: serial@2880000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1
Net: eth0: ethernet@46000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
1135 bytes read in 88 ms (11.7 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
gpio: pin gpio@22_17 (gpio 188) value is 1
gpio: pin gpio@22_16 (gpio 187) value is 0
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
1703496 bytes read in 111 ms (14.6 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 1703496 bytes: Success!
330996 bytes read in 96 ms (3.3 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 330996 bytes: Success!
154848 bytes read in 94 ms (1.6 MiB/s)
Load Remote Processor 4 with data@addr=0x82000000 154848 bytes: Success!
154848 bytes read in 95 ms (1.6 MiB/s)
Load Remote Processor 5 with data@addr=0x82000000 154848 bytes: Success!
498940 bytes read in 98 ms (4.9 MiB/s)
Load Remote Processor 6 with data@addr=0x82000000 498940 bytes: Success!
Load Remote Processor 7 with data@addr=0x82000000 154848 bytes: Success!
14283024 bytes read in 240 ms (56.8 MiB/s)
Load Remote Processor 8 with data@addr=0x82000000 14283024 bytes: Success!
14684488 bytes read in 244 ms (57.4 MiB/s)
Load Remote Processor 9 with data@addr=0x82000000 14684488 bytes: Success!
14283136 bytes read in 241 ms (56.5 MiB/s)
Load Remote Processor 10 with data@addr=0x82000000 14283136 bytes: Success!
14283136 bytes read in 240 ms (56.8 MiB/s)
Load Remote Processor 11 with data@addr=0x82000000 14283136 bytes: Success!
21029376 bytes read in 305 ms (65.8 MiB/s)
130033 bytes read in 91 ms (1.4 MiB/s)
Working FDT set to 88000000
2176 bytes read in 89 ms (23.4 KiB/s)
14481 bytes read in 89 ms (158.2 KiB/s)
ERROR: reserving fdt memory region failed (addr=880000000 size=80000000 flags=4)
Loading Device Tree to 000000008fedd000, end 000000008fffffff ... OK
Working FDT set to 8fedd000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 6.6.44-ti-01478-g541c20281af7-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Thu Nov 14 19:20:24 UTC 2024
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: Texas Instruments J784S4 EVM
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a0000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a0100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a1000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a1100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a2000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a3ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a2100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a4000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a4100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a50fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a5000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a5100000..0x00000000a5ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a5100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a6000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a6100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a7000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a7100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a80fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a8000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000a8100000..0x00000000a8ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a8100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000ac000000..0x00000000aeffffff (49152 KiB) nomap non-reusable vision-apps-rtos-ipc-memory-region@ac000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 48 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000af000000..0x00000000b1ffffff (49152 KiB) nomap non-reusable vision-apps-dma-memory@af000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b2000000..0x00000000b20fffff (1024 KiB) nomap non-reusable vision-apps-c71-dma-memory@b2000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b2100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b2100000..0x00000000b3ffffff (31744 KiB) nomap non-reusable vision-apps-c71_0-memory@b2100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b4000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b4000000..0x00000000b40fffff (1024 KiB) nomap non-reusable vision-apps-c71_1-dma-memory@b4000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b4100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b4100000..0x00000000b5ffffff (31744 KiB) nomap non-reusable vision-apps-c71_1-memory@b4100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@b6000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b6000000..0x00000000b60fffff (1024 KiB) nomap non-reusable vision-apps-c71_2-dma-memory@b6000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b6100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@b6100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b6100000..0x00000000b7ffffff (31744 KiB) nomap non-reusable vision-apps-c71_2-memory@b6100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@b8000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b8000000..0x00000000b80fffff (1024 KiB) nomap non-reusable vision-apps-c71_3-dma-memory@b8000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b8100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@b8100000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000b8100000..0x00000000b9ffffff (31744 KiB) nomap non-reusable vision-apps-c71_3-memory@b8100000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ba000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@ba000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000ba000000..0x00000000bdffffff (65536 KiB) nomap non-reusable vision-apps-core-heap-memory-lo@ba000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000be000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@be000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000be000000..0x00000000be7fffff (8192 KiB) nomap non-reusable vision-apps-r5f-virtual-eth-queues@be000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000be800000, size 24 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@be800000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000be800000..0x00000000bfffffff (24576 KiB) nomap non-reusable vision-apps-r5f-virtual-eth-buffers@be800000
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 2048 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000880000000..0x00000008ffffffff (2097152 KiB) nomap non-reusable vision-apps-core-heap-memory-hi@880000000
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] OF: reserved mem: 0x0000000900000000..0x000000093bffffff (983040 KiB) map non-reusable vision_apps_shared-memories
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 1792 MiB
[ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000980000000..0x00000009efffffff (1835008 KiB) map reusable linux-cma-buffers@980000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000fffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000abffffff]
[ 0.000000] node 0: [mem 0x00000000ac000000-0x00000000bfffffff]
[ 0.000000] node 0: [mem 0x00000000c0000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] node 0: [mem 0x0000000900000000-0x0000000fffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 20 pages/cpu s43176 r8192 d30552 u81920
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospt
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8257536
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 8.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] Memory: 27416672K/33554432K available (12480K kernel code, 1272K rwdata, 4184K rodata, 2496K init, 528K bss, 4302752K reserved, 1835008K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: [Firmware Bug]: GICR region 0x0000000001900000 has overlapping address
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @93c800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x000000093c060000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x000000093c070000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008502] Console: colour dummy device 80x25
[ 0.013078] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023749] pid_max: default: 32768 minimum: 301
[ 0.028514] LSM: initializing lsm=capability,selinux,integrity
[ 0.034490] SELinux: Initializing.
[ 0.038190] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.045989] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.055295] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[ 0.062555] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[ 0.070403] rcu: Hierarchical SRCU implementation.
[ 0.075299] rcu: Max phase no-delay instances is 1000.
[ 0.080805] Platform MSI: msi-controller@1820000 domain created
[ 0.087024] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.096538] EFI services will not be available.
[ 0.101406] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
[ 0.114515] Detected PIPT I-cache on CPU1
[ 0.114558] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.114572] GICv3: CPU1: using allocated LPI pending table @0x000000093c080000
[ 0.114607] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.123079] Detected PIPT I-cache on CPU2
[ 0.123107] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
[ 0.123120] GICv3: CPU2: using allocated LPI pending table @0x000000093c090000
[ 0.123144] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
[ 0.131581] Detected PIPT I-cache on CPU3
[ 0.131611] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
[ 0.131624] GICv3: CPU3: using allocated LPI pending table @0x000000093c0a0000
[ 0.131647] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
[ 0.140140] Detected PIPT I-cache on CPU4
[ 0.140199] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
[ 0.140213] GICv3: CPU4: using allocated LPI pending table @0x000000093c0b0000
[ 0.140246] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
[ 0.148733] Detected PIPT I-cache on CPU5
[ 0.148768] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
[ 0.148781] GICv3: CPU5: using allocated LPI pending table @0x000000093c0c0000
[ 0.148806] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
[ 0.157258] Detected PIPT I-cache on CPU6
[ 0.157297] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
[ 0.157310] GICv3: CPU6: using allocated LPI pending table @0x000000093c0d0000
[ 0.157335] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
[ 0.165795] Detected PIPT I-cache on CPU7
[ 0.165835] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
[ 0.165849] GICv3: CPU7: using allocated LPI pending table @0x000000093c0e0000
[ 0.165873] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
[ 0.165923] smp: Brought up 1 node, 8 CPUs
[ 0.346907] SMP: Total of 8 processors activated.
[ 0.351713] CPU features: detected: 32-bit EL0 Support
[ 0.356970] CPU features: detected: CRC32 instructions
[ 0.362261] CPU: All CPU(s) started at EL2
[ 0.366451] alternatives: applying system-wide alternatives
[ 0.373198] devtmpfs: initialized
[ 0.388887] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.398865] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.429134] pinctrl core: initialized pinctrl subsystem
[ 0.434768] DMI not present or invalid.
[ 0.439034] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.446271] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.454283] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.463006] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.471216] audit: initializing netlink subsys (disabled)
[ 0.476833] audit: type=2000 audit(0.324:1): state=initialized audit_enabled=0 res=1
[ 0.477046] thermal_sys: Registered thermal governor 'step_wise'
[ 0.484760] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.490916] cpuidle: using governor menu
[ 0.501662] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.508691] ASID allocator initialised with 65536 entries
[ 0.526322] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
[ 0.537116] platform a000000.bridge: Fixed dependency cycle(s) with /connector-dp0
[ 0.544881] platform connector-dp0: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
[ 0.554392] Modules: 27488 pages in range for non-PLT usage
[ 0.554396] Modules: 519008 pages in range for PLT usage
[ 0.560518] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.572889] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.579292] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.586227] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.592629] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.599564] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.605966] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.612901] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.620076] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[ 0.629140] iommu: Default domain type: Translated
[ 0.634041] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.640502] SCSI subsystem initialized
[ 0.644477] usbcore: registered new interface driver usbfs
[ 0.650096] usbcore: registered new interface driver hub
[ 0.655537] usbcore: registered new device driver usb
[ 0.660959] pps_core: LinuxPPS API ver. 1 registered
[ 0.666032] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.675371] PTP clock support registered
[ 0.679498] EDAC MC: Ver: 3.0.0
[ 0.682927] scmi_core: SCMI protocol bus registered
[ 0.688058] FPGA manager framework
[ 0.691567] Advanced Linux Sound Architecture Driver Initialized.
[ 0.698239] vgaarb: loaded
[ 0.701159] clocksource: Switched to clocksource arch_sys_counter
[ 0.707517] VFS: Disk quotas dquot_6.6.0
[ 0.711544] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.722089] Carveout Heap: Exported 960 MiB at 0x0000000900000000
[ 0.728370] NET: Registered PF_INET protocol family
[ 0.733647] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.746500] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.755534] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.763470] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.772547] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.780979] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.787863] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.795219] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.803107] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.809221] RPC: Registered named UNIX socket transport module.
[ 0.815273] RPC: Registered udp transport module.
[ 0.820076] RPC: Registered tcp transport module.
[ 0.824878] RPC: Registered tcp-with-tls transport module.
[ 0.830481] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.837064] NET: Registered PF_XDP protocol family
[ 0.841969] PCI: CLS 0 bytes, default 64
[ 0.846994] Initialise system trusted keyrings
[ 0.851656] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.858414] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.864498] NFS: Registering the id_resolver key type
[ 0.869680] Key type id_resolver registered
[ 0.873951] Key type id_legacy registered
[ 0.878054] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.884902] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.906259] Key type asymmetric registered
[ 0.910444] Asymmetric key parser 'x509' registered
[ 0.915456] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.923093] io scheduler mq-deadline registered
[ 0.927724] io scheduler kyber registered
[ 0.931831] io scheduler bfq registered
[ 0.938221] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[ 0.944199] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[ 0.950241] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[ 0.956498] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[ 0.962345] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[ 0.968437] pinctrl-single 104200.pinctrl: 20 pins, size 80
[ 0.974195] pinctrl-single 104280.pinctrl: 8 pins, size 32
[ 0.980211] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[ 0.990145] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[ 1.003302] loop: module loaded
[ 1.007112] megasas: 07.725.01.00-rc1
[ 1.012798] tun: Universal TUN/TAP device driver, 1.6
[ 1.018514] VFIO - User Level meta-driver version: 0.3
[ 1.024452] usbcore: registered new interface driver usb-storage
[ 1.030972] i2c_dev: i2c /dev entries driver
[ 1.036023] sdhci: Secure Digital Host Controller Interface driver
[ 1.042341] sdhci: Copyright(c) Pierre Ossman
[ 1.046927] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.053179] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.059518] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.066495] usbcore: registered new interface driver usbhid
[ 1.072236] usbhid: USB HID core driver
[ 1.076980] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.085725] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 1.090283] optee: revision 4.4 (8f645256efc0dc66)
[ 1.106717] optee: dynamic shared memory is enabled
[ 1.117009] random: crng init done
[ 1.120544] optee: initialized driver
[ 1.125585] Initializing XFRM netlink socket
[ 1.129973] NET: Registered PF_PACKET protocol family
[ 1.135179] Key type dns_resolver registered
[ 1.143296] registered taskstats version 1
[ 1.147628] Loading compiled-in X.509 certificates
[ 1.160075] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.1.6--v10.01.06 (Fiery Fox)')
[ 1.207136] ti-sci-clk 44083000.system-controller:clock-controller: get-parent failed for dev=157, clk=34, ret=-19
[ 1.217808] ti-sci-clk 44083000.system-controller:clock-controller: get-parent failed for dev=157, clk=34, ret=-19
[ 1.228511] ti-sci-clk 44083000.system-controller:clock-controller: get-parent failed for dev=157, clk=34, ret=-19
[ 1.259412] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.265764] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 1.272595] pca953x 3-0020: using no AI
[ 1.298118] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 1.304928] pca953x 3-0022: using AI
[ 1.309705] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.315917] pca953x 4-0020: supply vcc not found, using dummy regulator
[ 1.322727] pca953x 4-0020: using no AI
[ 1.349605] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz
[ 1.355440] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
[ 1.363975] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
[ 1.373241] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[ 1.381897] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[ 1.394466] ti-udma 311a0000.dma-controller: Number of rings: 48
[ 1.401448] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
[ 1.410816] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[ 1.420698] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 1.427458] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.436911] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[ 1.447066] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 1.453826] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[ 1.461910] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 223, base_baud = 6000000) is a 8250
[ 1.471470] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 224, base_baud = 3000000) is a 8250
[ 1.480341] printk: console [ttyS2] enabled
[ 1.488839] printk: bootconsole [ns16550a0] disabled
[ 1.541160] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.552152] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.560424] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.573235] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 1.580443] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 1.586595] pps pps0: new PPS source ptp0
[ 1.590759] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[ 1.641157] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.651835] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[ 1.659928] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 1.672688] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 1.678944] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 1.686063] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 1.692190] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
[ 1.702456] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
[ 1.711441] mmc0: CQHCI version 5.10
[ 1.755734] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 1.848913] mmc0: Command Queue Engine enabled
[ 1.853356] mmc0: new HS400 MMC card at address 0001
[ 1.858678] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[ 1.864222] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[ 1.869801] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[ 1.875258] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[ 1.910417] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[ 1.917110] tps6594-rtc tps6594-rtc.4.auto: setting system clock to 2024-10-09T15:44:05 UTC (1728488645)
[ 1.928523] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 1.936019] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 1.944103] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 1.952184] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.069699] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[ 3.075974] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.081462] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 3.090922] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 3.097810] pci 0000:00:00.0: [104c:b012] type 01 class 0x060400
[ 3.103805] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 3.113542] pci 0000:00:00.0: supports D1
[ 3.117542] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 3.125379] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.133488] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.140100] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 3.145118] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[ 3.151898] pcieport 0000:00:00.0: PME: Signaling with IRQ 486
[ 3.157891] pcieport 0000:00:00.0: AER: enabled with IRQ 486
[ 3.163797] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 3.171283] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 3.179366] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 3.187447] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.305418] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[ 4.311686] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 4.317162] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[ 4.326795] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 4.333673] pci 0001:00:00.0: [104c:b012] type 01 class 0x060400
[ 4.339668] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 4.349426] pci 0001:00:00.0: supports D1
[ 4.353424] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 4.359180] pci 0001:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[ 4.366040] pci 0001:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[ 4.377969] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.386076] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 4.392687] pci 0001:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
[ 4.399984] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 4.404982] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
[ 4.411745] pcieport 0001:00:00.0: PME: Signaling with IRQ 488
[ 4.417701] pcieport 0001:00:00.0: AER: enabled with IRQ 488
[ 4.424148] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[ 4.434508] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[ 4.446569] spi-nand spi0.0: Winbond SPI NAND was found.
[ 4.451875] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
[ 4.460185] 7 fixed-partitions partitions found on MTD device spi0.0
[ 4.466532] Creating 7 MTD partitions on "spi0.0":
[ 4.471311] 0x000000000000-0x000000100000 : "ospi_nand.tiboot3"
[ 4.478335] 0x000000100000-0x000000300000 : "ospi_nand.tispl"
[ 4.485354] 0x000000300000-0x000000700000 : "ospi_nand.u-boot"
[ 4.493121] 0x000000700000-0x000000740000 : "ospi_nand.env"
[ 4.499335] 0x000000740000-0x000000780000 : "ospi_nand.env.backup"
[ 4.506154] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
[ 4.545472] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
[ 4.552435] cadence-qspi 47040000.spi: Pattern not found. Skipping calibration.
[ 4.561857] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[ 4.566936] 7 fixed-partitions partitions found on MTD device 47050000.spi.0
[ 4.573972] Creating 7 MTD partitions on "47050000.spi.0":
[ 4.579445] 0x000000000000-0x000000080000 : "qspi.tiboot3"
[ 4.585509] 0x000000080000-0x000000280000 : "qspi.tispl"
[ 4.591373] 0x000000280000-0x000000680000 : "qspi.u-boot"
[ 4.597316] 0x000000680000-0x0000006c0000 : "qspi.env"
[ 4.602990] 0x0000006c0000-0x000000700000 : "qspi.env.backup"
[ 4.609301] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
[ 4.615251] 0x000003fc0000-0x000004000000 : "qspi.phypattern"
[ 4.661160] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 4.672126] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 4.680395] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 4.693216] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 4.700423] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 4.706576] pps pps0: new PPS source ptp1
[ 4.710715] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[ 4.725188] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 4.773166] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 4.783943] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[ 4.792038] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[ 4.804822] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[ 4.811079] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[ 4.818198] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
[ 4.824376] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[ 4.839244] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[ 4.849585] mmc1: CQHCI version 5.10
[ 4.852846] clk: Disabling unused clocks
[ 4.866775] ALSA device list:
[ 4.869815] No soundcards found.
[ 4.889698] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 4.897278] Waiting for root device PARTUUID=20e58f0b-02...
[ 4.949080] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 4.956072] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[ 4.965063] mmcblk1: p1 p2
[ 5.184357] EXT4-fs (mmcblk1p2): recovery complete
[ 5.190202] EXT4-fs (mmcblk1p2): mounted filesystem d821de09-4189-47ae-940a-292176388a88 r/w with ordered data mode. Quota mode: none.
[ 5.202324] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 5.211954] devtmpfs: mounted
[ 5.215870] Freeing unused kernel memory: 2496K
[ 5.220500] Run /sbin/init as init process
[ 5.432213] NET: Registered PF_INET6 protocol family
[ 5.437858] Segment Routing with IPv6
[ 5.441528] In-situ OAM (IOAM) with IPv6
[ 5.470437] systemd[1]: Configuration file /usr/lib/systemd/system.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.486275] systemd[1]: Configuration file /usr/lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.506032] systemd[1]: systemd 255.13^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PW)
[ 5.537893] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[ 5.557848] systemd[1]: Hostname set to <j784s4-evm>.
[ 5.603766] (sd-exec-[134]: '/usr/lib/systemd/system-generators/systemd-debug-generator' is marked world-writable, which is a security risk as it is executed with privileges. Please remove world writability permission bits. Proceeding.
[ 5.625824] (sd-exec-[134]: '/usr/lib/systemd/system-generators/systemd-fstab-generator' is marked world-writable, which is a security risk as it is executed with privileges. Please remove world writability permission bits. Proceeding.
[ 5.647817] (sd-exec-[134]: '/usr/lib/systemd/system-generators/systemd-getty-generator' is marked world-writable, which is a security risk as it is executed with privileges. Please remove world writability permission bits. Proceeding.
[ 5.669818] (sd-exec-[134]: '/usr/lib/systemd/system-generators/systemd-gpt-auto-generator' is marked world-writable, which is a security risk as it is executed with privileges. Please remove world writability permission bits. Proceed.
[ 5.692109] (sd-exec-[134]: '/usr/lib/systemd/system-generators/systemd-hibernate-resume-generator' is marked world-writable, which is a security risk as it is executed with privileges. Please remove world writability permission bits..
[ 5.715064] (sd-exec-[134]: '/usr/lib/systemd/system-generators/systemd-rc-local-generator' is marked world-writable, which is a security risk as it is executed with privileges. Please remove world writability permission bits. Proceed.
[ 5.737370] (sd-exec-[134]: '/usr/lib/systemd/system-generators/systemd-run-generator' is marked world-writable, which is a security risk as it is executed with privileges. Please remove world writability permission bits. Proceeding a.
[ 5.759258] (sd-exec-[134]: '/usr/lib/systemd/system-generators/systemd-system-update-generator' is marked world-writable, which is a security risk as it is executed with privileges. Please remove world writability permission bits. Pr.
[ 5.781929] (sd-exec-[134]: '/usr/lib/systemd/system-generators/systemd-sysv-generator' is marked world-writable, which is a security risk as it is executed with privileges. Please remove world writability permission bits. Proceeding .
[ 5.833812] systemd[1]: Configuration file /usr/lib/systemd/system/blockdev@.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.848675] systemd[1]: Configuration file /usr/lib/systemd/system/blockdev@.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.867360] systemd[1]: Configuration file /usr/lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.882063] systemd[1]: Configuration file /usr/lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.900246] systemd[1]: Configuration file /usr/lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.915004] systemd[1]: Configuration file /usr/lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.936157] systemd[1]: Configuration file /usr/lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.950571] systemd[1]: Configuration file /usr/lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.968588] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.984040] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.003609] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-journald.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.019161] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.040191] systemd[1]: Configuration file /usr/lib/systemd/system/soft-reboot.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.055213] systemd[1]: Configuration file /usr/lib/systemd/system/soft-reboot.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.074199] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-soft-reboot.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.090000] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-soft-reboot.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.109867] systemd[1]: Configuration file /usr/lib/systemd/system/final.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.124366] systemd[1]: Configuration file /usr/lib/systemd/system/final.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.142481] systemd[1]: Configuration file /usr/lib/systemd/system/sysinit.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.157156] systemd[1]: Configuration file /usr/lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.178524] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-update-utmp.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.194325] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.214397] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-update-done.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.230201] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-update-done.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.251632] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udevd-kernel.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.267431] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udevd-kernel.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.287421] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udevd-control.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.303304] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udevd-control.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.323232] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udev-trigger.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.339114] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udev-trigger.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.358886] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.374942] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.395097] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-switch-root.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.410718] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-switch-root.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.430431] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-cleanup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.445795] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-cleanup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.464876] systemd[1]: Configuration file /usr/lib/systemd/system/initrd.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.479458] systemd[1]: Configuration file /usr/lib/systemd/system/initrd.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.498347] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-battery-check.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.514317] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-battery-check.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.534423] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-hibernate-resume.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.550653] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-hibernate-resume.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.570878] systemd[1]: Configuration file /usr/lib/systemd/system/rescue.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.585463] systemd[1]: Configuration file /usr/lib/systemd/system/rescue.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.604774] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-update-utmp-runlevel.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.621353] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-update-utmp-runlevel.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.642315] systemd[1]: Configuration file /usr/lib/systemd/system/graphical.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.657161] systemd[1]: Configuration file /usr/lib/systemd/system/graphical.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.677862] systemd[1]: Configuration file /usr/lib/systemd/system/weston.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.692533] systemd[1]: Configuration file /usr/lib/systemd/system/weston.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.711234] systemd[1]: Configuration file /usr/lib/systemd/system/weston.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.725829] systemd[1]: Configuration file /usr/lib/systemd/system/weston.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.744014] systemd[1]: Configuration file /usr/lib/systemd/system/dbus.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.758426] systemd[1]: Configuration file /usr/lib/systemd/system/dbus.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.776572] systemd[1]: Configuration file /usr/lib/systemd/system/dbus-broker.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.791677] systemd[1]: Configuration file /usr/lib/systemd/system/dbus-broker.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.811599] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-user-sessions.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.827589] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-user-sessions.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.847707] systemd[1]: Configuration file /usr/lib/systemd/system/network.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.862378] systemd[1]: Configuration file /usr/lib/systemd/system/network.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.880701] systemd[1]: Configuration file /usr/lib/systemd/system/network-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.895718] systemd[1]: Configuration file /usr/lib/systemd/system/network-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.914385] systemd[1]: Configuration file /usr/lib/systemd/system/nss-user-lookup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.929750] systemd[1]: Configuration file /usr/lib/systemd/system/nss-user-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.948938] systemd[1]: Configuration file /usr/lib/systemd/system/remote-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.963783] systemd[1]: Configuration file /usr/lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.982303] systemd[1]: Configuration file /usr/lib/systemd/system/remote-fs-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.997496] systemd[1]: Configuration file /usr/lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.016524] systemd[1]: Configuration file /usr/lib/systemd/system/multi-user.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.031456] systemd[1]: Configuration file /usr/lib/systemd/system/multi-user.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.054926] systemd[1]: Configuration file /usr/lib/systemd/system/telnetd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.069702] systemd[1]: Configuration file /usr/lib/systemd/system/telnetd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.088211] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-networkd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.103772] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-networkd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.124259] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-networkd.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.139709] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-networkd.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.158939] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-logind.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.174302] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-logind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.194837] systemd[1]: Configuration file /usr/lib/systemd/system/modprobe@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.209768] systemd[1]: Configuration file /usr/lib/systemd/system/modprobe@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.228805] systemd[1]: Configuration file /usr/lib/systemd/system/user.slice is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.243127] systemd[1]: Configuration file /usr/lib/systemd/system/user.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.261096] systemd[1]: Configuration file /usr/lib/systemd/system/slices.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.275679] systemd[1]: Configuration file /usr/lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.293894] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-ask-password-wall.path is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.309951] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-ask-password-wall.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.330336] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-ask-password-wall.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.346653] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-ask-password-wall.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.367139] systemd[1]: Configuration file /usr/lib/systemd/system/paths.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.381634] systemd[1]: Configuration file /usr/lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.399593] systemd[1]: Configuration file /usr/lib/systemd/system/strongswan-starter.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.415304] systemd[1]: Configuration file /usr/lib/systemd/system/strongswan-starter.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.434731] systemd[1]: Configuration file /usr/lib/systemd/system/network-online.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.450007] systemd[1]: Configuration file /usr/lib/systemd/system/network-online.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.470144] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-networkd-wait-online.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.486721] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-networkd-wait-online.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.507684] systemd[1]: Configuration file /usr/lib/systemd/system/snmpd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.522269] systemd[1]: Configuration file /usr/lib/systemd/system/snmpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.540429] systemd[1]: Configuration file /usr/lib/systemd/system/rpcbind.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.555184] systemd[1]: Configuration file /usr/lib/systemd/system/rpcbind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.573556] systemd[1]: Configuration file /usr/lib/systemd/system/rpcbind.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.588225] systemd[1]: Configuration file /usr/lib/systemd/system/rpcbind.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.606367] systemd[1]: Configuration file /usr/lib/systemd/system/rpcbind.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.621036] systemd[1]: Configuration file /usr/lib/systemd/system/rpcbind.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.639370] systemd[1]: Configuration file /usr/lib/systemd/system/resize_rootfs.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.654648] systemd[1]: Configuration file /usr/lib/systemd/system/resize_rootfs.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.673482] systemd[1]: Configuration file /usr/lib/systemd/system/ofono.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.688065] systemd[1]: Configuration file /usr/lib/systemd/system/ofono.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.706199] systemd[1]: Configuration file /usr/lib/systemd/system/nfs-statd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.721127] systemd[1]: Configuration file /usr/lib/systemd/system/nfs-statd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.739857] systemd[1]: Configuration file /usr/lib/systemd/system/nss-lookup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.754786] systemd[1]: Configuration file /usr/lib/systemd/system/nss-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.773351] systemd[1]: Configuration file /usr/lib/systemd/system/netserver.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.788279] systemd[1]: Configuration file /usr/lib/systemd/system/netserver.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.806718] systemd[1]: Configuration file /usr/lib/systemd/system/lldpd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.821301] systemd[1]: Configuration file /usr/lib/systemd/system/lldpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.839597] systemd[1]: Configuration file /usr/lib/systemd/system/kdump.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.854179] systemd[1]: Configuration file /usr/lib/systemd/system/kdump.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.872272] systemd[1]: Configuration file /usr/lib/systemd/system/irqbalanced.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.887375] systemd[1]: Configuration file /usr/lib/systemd/system/irqbalanced.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.906117] systemd[1]: Configuration file /usr/lib/systemd/system/iptables.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.920959] systemd[1]: Configuration file /usr/lib/systemd/system/iptables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.939362] systemd[1]: Configuration file /usr/lib/systemd/system/ip6tables.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.954291] systemd[1]: Configuration file /usr/lib/systemd/system/ip6tables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.972770] systemd[1]: Configuration file /usr/lib/systemd/system/gplv3-notice.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.987959] systemd[1]: Configuration file /usr/lib/systemd/system/gplv3-notice.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.006906] systemd[1]: Configuration file /usr/lib/systemd/system/getty.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.021402] systemd[1]: Configuration file /usr/lib/systemd/system/getty.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.040271] systemd[1]: Configuration file /usr/lib/systemd/system/serial-getty@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.055562] systemd[1]: Configuration file /usr/lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.075854] systemd[1]: Configuration file /usr/lib/systemd/system/rc-local.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.090699] systemd[1]: Configuration file /usr/lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.109310] systemd[1]: Configuration file /usr/lib/systemd/system/getty-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.124152] systemd[1]: Configuration file /usr/lib/systemd/system/getty-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.142985] systemd[1]: Configuration file /usr/lib/systemd/system/getty@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.157655] systemd[1]: Configuration file /usr/lib/systemd/system/getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.176877] systemd[1]: Configuration file /usr/lib/systemd/system/crond.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.191462] systemd[1]: Configuration file /usr/lib/systemd/system/crond.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.209723] systemd[1]: Configuration file /usr/lib/systemd/system/containerd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.224741] systemd[1]: Configuration file /usr/lib/systemd/system/containerd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.243390] systemd[1]: Configuration file /usr/lib/systemd/system/bt-enable.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.258323] systemd[1]: Configuration file /usr/lib/systemd/system/bt-enable.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.276544] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 8.296487] systemd[1]: Configuration file /usr/lib/systemd/system/avahi-daemon.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.311678] systemd[1]: Configuration file /usr/lib/systemd/system/avahi-daemon.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.330965] systemd[1]: Configuration file /usr/lib/systemd/system/avahi-daemon.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.346073] systemd[1]: Configuration file /usr/lib/systemd/system/avahi-daemon.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.365010] systemd[1]: Configuration file /usr/lib/systemd/system/atd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.379422] systemd[1]: Configuration file /usr/lib/systemd/system/atd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.397372] systemd[1]: Configuration file /usr/lib/systemd/system/rescue.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.412043] systemd[1]: Configuration file /usr/lib/systemd/system/rescue.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.430431] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-parse-etc.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.445967] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-parse-etc.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.465488] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-usr-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.480676] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-usr-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.499699] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-root-device.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.515321] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-root-device.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.534815] systemd[1]: Configuration file /usr/lib/systemd/system/basic.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.549310] systemd[1]: Configuration file /usr/lib/systemd/system/basic.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.567642] systemd[1]: Configuration file /usr/lib/systemd/system/timers.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.582224] systemd[1]: Configuration file /usr/lib/systemd/system/timers.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.601884] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-clean.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.617770] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-clean.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.637702] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-clean.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.653762] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.673878] systemd[1]: Configuration file /usr/lib/systemd/system/time-set.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.688634] systemd[1]: Configuration file /usr/lib/systemd/system/time-set.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.707031] systemd[1]: Configuration file /usr/lib/systemd/system/logrotate.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.721788] systemd[1]: Configuration file /usr/lib/systemd/system/logrotate.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.740316] systemd[1]: Configuration file /usr/lib/systemd/system/time-sync.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.755158] systemd[1]: Configuration file /usr/lib/systemd/system/time-sync.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.773805] systemd[1]: Configuration file /usr/lib/systemd/system/logrotate.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.788734] systemd[1]: Configuration file /usr/lib/systemd/system/logrotate.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.807517] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.822362] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.840884] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-root-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.856160] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-root-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.875258] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-udevadm-cleanup-db.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.891574] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-udevadm-cleanup-db.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.912047] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udev-settle.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.927844] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-udev-settle.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.947651] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-switch-root.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.963359] systemd[1]: Configuration file /usr/lib/systemd/system/initrd-switch-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.983099] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.999502] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.020321] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-setup-dev-early.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.037262] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-tmpfiles-setup-dev-early.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.058855] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-timesyncd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.074480] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-timesyncd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.095008] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-sysusers.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.110548] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-sysusers.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.130109] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-sysctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.145476] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.164733] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-resolved.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.180272] systemd[1]: Configuration file /usr/lib/systemd/system/systemd-resolved.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.200716] systemd[1]: Too many messages being logged to kmsg, ignoring
[ OK ] Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/serial-getty.
[ OK ] Created slice User and Session Slice.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
Expecting device /dev/ttyS2...
[ OK ] Reached target Path Units.
[ OK ] Reached target Remote File Systems.
[ OK ] Reached target Slice Units.
[ OK ] Reached target Swaps.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Reached target RPC Port Mapper.
[ OK ] Listening on Process Core Dump Socket.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on User Database Manager Socket.
Mounting Huge Pages File System...
Mounting POSIX Message Queue File System...
Mounting Kernel Debug File System...
Mounting Temporary Directory /tmp...
Starting Create List of Static Device Nodes...
Starting Load Kernel Module configfs...
Starting Load Kernel Module drm...
Starting Load Kernel Module fuse...
Starting Start psplash boot splash screen...
[ 9.826127] fuse: init (API version 7.39)
Starting RPC Bind...
Starting Journal Service...
Starting Load Kernel Modules...
Starting Generate network units from Kernel command line...
Starting Remount Root and Kernel File Systems 9.902338] cryptodev: loading out-of-tree module taints kernel.
[0m...
[ 9.902818] systemd-journald[164]: Configuration file /usr/lib/systemd/journald.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 9.929392] systemd-journald[164]: Configuration file /usr/lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 9.929758] cryptodev: driver 1.14 loaded.
Starting Coldplug All udev Devices...
[ 9.951974] systemd-journald[164]: Collecting audit messages is enabled.
[ OK ] Started RPC Bind.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 10.005574] EXT4-fs (mmcblk1p2): re-mounted d821de09-4189-47ae-940a-292176388a88 r/w. Quota mode: none.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Started Journal Service.
[ OK ] Mounted Temporary Directory /tmp.
[ OK ] Finished Create List of Static Device Nodes.
[ OK ] Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Start psplas�…temd progress communication helper.
[ OK ] Finished Load Kernel Modules.
[ OK ] Finished Generate network units from Kernel command line.
[ OK ] Finished Remount Root and Kernel File Systems.
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
Starting Apply Kernel Variables...
[ 10.355959] systemd-journald[164]: Received client request to flush runtime journal.
Starting Create Static Device Nodes in /dev gracefully...
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create Static Device Nodes in /dev gracefully.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /var/volatile...
[ 10.634570] audit: type=1334 audit(1728488654.216:2): prog-id=6 op=LOAD
[ 10.641218] audit: type=1334 audit(1728488654.224:3): prog-id=7 op=LOAD
Starting Rule-based Manager for Device Events and Files...
[ OK ] Mounted /var/volatile.
Starting Load/Save OS Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create System Files and Directories...
[ OK ] Finished Load/Save OS Random Seed.
[ OK ] Finished Create System Files and Directories.
[ 10.792167] audit: type=1334 audit(1728488654.372:4): prog-id=8 op=LOAD
Starting Network Name Resolution...
[ 10.859199] audit: type=1334 audit(1728488654.440:5): prog-id=9 op=LOAD
Starting Network Time Synchronization...
Starting Record System Boot/Shutdown in UTMP...
[ 10.904359] audit: type=1334 audit(1728488654.484:6): prog-id=10 op=LOAD
[ 10.911151] audit: type=1334 audit(1728488654.492:7): prog-id=11 op=LOAD
[ 10.917887] audit: type=1334 audit(1728488654.500:8): prog-id=12 op=LOAD
Starting User Database Manager...
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Started User Database Manager.
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Found device /dev/ttyS2.
[ 11.073344] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
[ 11.074237] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
[ 11.074456] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
[ 11.074940] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
[ 11.076577] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
[ 11.087282] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
[ 11.113071] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[ OK ] Started Network Time Synchronization.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Nam[ 11.373270] CAN device driver interface
e Lookups.
[ OK ] Reached target System Initializatio[ 11.392637] PVR_K: 261: Device: 4e20000000.gpu
n.
[ 11.401082] PVR_K: 261: Read BVNC 36.53.104.796 from HW device registers
[ 11.408496] PVR_K: 261: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[ OK ] Started Daily Cleanup of Temporary [ 11.417524] [drm] Initialized pvr 24.1.6554834 20170530 for 4e20000000.gpu on minor 0
Directories.
[ 11.439035] at24 0-0050: supply vcc not found, using dummy regulator
[ OK ] Reached target System Time Set.[ 11.446240] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 11.447827] mc: Linux media interface: v0.10
[ 11.468889] cdns-mhdp8546 a000000.bridge: invalid resource (null)
[ OK ] Started Daily rotation of log files[ 11.481298] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: k3_r5_cluster_rproc_init failed, ret = -517
[ 11.486198] videodev: Linux video capture interface: v2.00
[ 11.491359] cdns-mhdp8546 a000000.bridge: Failed to get SAPB memory resource, HDCP not supported
[ 11.491385] cdns-mhdp8546 a000000.bridge: no PHY configured
[ OK ] Reached target Timer Units.
[ 11.516788] cdns-mhdp8546 a000000.bridge: invalid resource (null)
[ 11.527734] cdns-mhdp8546 a000000.bridge: Failed to get SAPB memory resource, HDCP not supported
[ 11.531242] remoteproc remoteproc0: releasing 41000000.r5f
[ 11.536874] cdns-mhdp8546 a000000.bridge: no PHY configured
[ OK ] Listening on Avahi mDNS/DNS-SD Stac[ 11.549627] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
k Activation Socket.
[ 11.565406] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ 11.566761] m_can_platform 40528000.can: m_can device registered (irq=610, version=32)
[ 11.566946] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[ 11.567043] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[ 11.577391] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[ 11.578910] platform 5c00000.r5f: configured R5F for IPC-only mode
[ 11.579086] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 11.585367] remoteproc remoteproc0: 5c00000.r5f is available
[ 11.597380] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
[ 11.602750] m_can_platform 40568000.can: m_can device registered (irq=616, version=32)
[ 11.603463] remoteproc remoteproc0: attaching to 5c00000.r5f
[ 11.609817] m_can_platform 26a1000.can: m_can device registered (irq=618, version=32)
[ 11.618947] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[ 11.620265] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 11.620620] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 11.620633] rproc-virtio rproc-virtio.8.auto: registered virtio0 (type 7)
[ 11.620637] remoteproc remoteproc0: remote processor 5c00000.r5f is now attached
[ 11.621052] platform 5d00000.r5f: configured R5F for IPC-only mode
[ 11.621241] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 11.624064] remoteproc remoteproc1: 5d00000.r5f is available
[ 11.624124] remoteproc remoteproc1: attaching to 5d00000.r5f
[ 11.627845] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[ 11.630529] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 11.630972] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 11.639015] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[ 11.641388] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
[ 11.644538] rproc-virtio rproc-virtio.9.auto: registered virtio1 (type 7)
[ 11.652366] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 11.658880] remoteproc remoteproc1: remote processor 5d00000.r5f is now attached
[ 11.669653] platform 41000000.r5f: configured R5F for IPC-only mode
[ 11.724416] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 11.733057] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 11.733708] platform 5e00000.r5f: configured R5F for IPC-only mode
[ 11.733981] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a5000000
[ 11.735425] remoteproc remoteproc3: 5e00000.r5f is available
[ 11.735480] remoteproc remoteproc3: attaching to 5e00000.r5f
[ 11.735757] rproc-virtio rproc-virtio.10.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a5000000
[ 11.736166] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 11.736181] rproc-virtio rproc-virtio.10.auto: registered virtio2 (type 7)
[ 11.736185] remoteproc remoteproc3: remote processor 5e00000.r5f is now attached
[ 11.736761] platform 5f00000.r5f: configured R5F for IPC-only mode
[ 11.736949] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 11.738096] remoteproc remoteproc4: 5f00000.r5f is available
[ 11.738145] remoteproc remoteproc4: attaching to 5f00000.r5f
[ 11.738392] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 11.738576] m_can_platform 40528000.can mcu_mcan0: renamed from can0
[ 11.738588] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 11.738593] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 11.738596] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 11.742714] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[ 11.747094] remoteproc remoteproc2: 41000000.r5f is available
[ 11.749361] vdec 4210000.video-codec: OPP table not found in device tree
[ 11.752055] scsi host0: ufshcd
[ 11.752794] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 11.752811] rproc-virtio rproc-virtio.11.auto: registered virtio3 (type 7)
[ 11.752817] remoteproc remoteproc4: remote processor 5f00000.r5f is now attached
[ 11.754909] platform 5900000.r5f: configured R5F for IPC-only mode
[ 11.755120] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 11.755684] remoteproc remoteproc5: 5900000.r5f is available
[ 11.755734] remoteproc remoteproc5: attaching to 5900000.r5f
[ 11.755942] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 11.756292] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 11.756305] rproc-virtio rproc-virtio.12.auto: registered virtio4 (type 7)
[ 11.756309] remoteproc remoteproc5: remote processor 5900000.r5f is now attached
[ 11.756595] platform 5a00000.r5f: configured R5F for IPC-only mode
[ 11.756665] platform 5a00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
[ 11.757175] remoteproc remoteproc6: 5a00000.r5f is available
[ 11.757219] remoteproc remoteproc6: attaching to 5a00000.r5f
[ 11.757343] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
[ 11.757664] virtio_rpmsg_bus virtio5: rpmsg host is online
[ 11.757676] rproc-virtio rproc-virtio.13.auto: registered virtio5 (type 7)
[ 11.757680] remoteproc remoteproc6: remote processor 5a00000.r5f is now attached
[ 11.758920] remoteproc remoteproc2: attaching to 41000000.r5f
[ 11.759280] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[ 11.762557] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[ 11.763865] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[ 11.766993] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
[ 11.768982] vdec 4210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
[ 11.768992] vdec 4210000.video-codec: Product Code: 0x521c
[ 11.768996] vdec 4210000.video-codec: Firmware Revision: 334314
[ 11.806298] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 11.810280] rproc-virtio rproc-virtio.14.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 11.811352] vdec 4220000.video-codec: OPP table not found in device tree
[ 11.813652] vdec 4220000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
[ 11.813661] vdec 4220000.video-codec: Product Code: 0x521c
[ 11.813664] vdec 4220000.video-codec: Firmware Revision: 334314
[ 11.817995] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
[ 11.820177] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 11.821261] m_can_platform 26a1000.can main_mcan16: renamed from can2
[ 11.825127] virtio_rpmsg_bus virtio6: rpmsg host is online
[ 11.831974] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[ 11.838687] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[ 11.838886] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
[ 11.840531] rproc-virtio rproc-virtio.14.auto: registered virtio6 (type 7)
[ 12.249046] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
[ OK ] Listening on D-Bus System Message B[ 12.257560] cdns-mhdp8546 a000000.bridge: invalid resource (null)
us Socket.
[ 12.268510] cdns-mhdp8546 a000000.bridge: Failed to get SAPB memory resource, HDCP not supported
[ 12.279299] cdns-mhdp8546 a000000.bridge: no PHY configured
[ 12.285667] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[ 12.296475] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[ 12.297736] m_can_platform 40568000.can mcu_mcan1: renamed from can1
[ 12.307426] remoteproc remoteproc7: 64800000.dsp is available
[ 12.319534] remoteproc remoteproc7: attaching to 64800000.dsp
[ 12.325551] remoteproc remoteproc7: unsupported resource 65538
[ 12.331404] rproc-virtio rproc-virtio.15.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[ 12.342064] virtio_rpmsg_bus virtio7: rpmsg host is online
[ 12.344804] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
[ 12.352652] rproc-virtio rproc-virtio.15.auto: registered virtio7 (type 7)
[ 12.352657] remoteproc remoteproc7: remote processor 64800000.dsp is now attached
[ 12.359979] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b4000000
[ OK ] Listening on PC/SC Smart Card Daemo[ 12.384582] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
n Activation Socket.
[ 12.396303] remoteproc remoteproc8: 65800000.dsp is available
[ 12.404308] remoteproc remoteproc8: attaching to 65800000.dsp
[ 12.410380] remoteproc remoteproc8: unsupported resource 65538
[ 12.416245] rproc-virtio rproc-virtio.16.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b4000000
Starting Weston socket...
[ 12.427105] virtio_rpmsg_bus virtio8: rpmsg host is online
[ 12.429822] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd
[ 12.436617] rproc-virtio rproc-virtio.16.auto: registered virtio8 (type 7)
[ 12.450484] remoteproc remoteproc8: remote processor 65800000.dsp is now attached
[ 12.458810] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@b6000000
[ 12.469159] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
[ 12.475900] remoteproc remoteproc9: 66800000.dsp is available
[ 12.481675] remoteproc remoteproc9: attaching to 66800000.dsp
[ 12.487501] audit: type=1334 audit(1728488656.068:9): prog-id=13 op=LOAD
[ 12.487681] remoteproc remoteproc9: unsupported resource 65538
[ 12.500059] rproc-virtio rproc-virtio.17.auto: assigned reserved memory node vision-apps-c71_2-dma-memory@b6000000
Starting D-Bus System Message Bus...
[ 12.510928] virtio_rpmsg_bus virtio9: rpmsg host is online
[ 12.513625] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd
[ 12.521253] rproc-virtio rproc-virtio.17.auto: registered virtio9 (type 7)
[ 12.535153] remoteproc remoteproc9: remote processor 66800000.dsp is now attached
[ 12.536270] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@b8000000
Starting Reboot and dump vmcore via kexec.[ 12.553613] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
[ 12.564667] remoteproc remoteproc10: 67800000.dsp is available
[ 12.570796] remoteproc remoteproc10: attaching to 67800000.dsp
[ 12.576847] remoteproc remoteproc10: unsupported resource 65538
[ 12.582780] rproc-virtio rproc-virtio.18.auto: assigned reserved memory node vision-apps-c71_3-dma-memory@b8000000
[ OK ] Listening on Docker Socket for the [ 12.593669] virtio_rpmsg_bus virtio10: rpmsg host is online
API.
[ 12.596402] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0xd
[ 12.604431] rproc-virtio rproc-virtio.18.auto: registered virtio10 (type 7)
[ 12.604438] remoteproc remoteproc10: remote processor 67800000.dsp is now attached
[ 12.612575] cdns-mhdp8546 a000000.bridge: invalid resource (null)
[ 12.619700] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
[ 12.627015] cdns-mhdp8546 a000000.bridge: Failed to get SAPB memory resource, HDCP not supported
[ 12.627033] cdns-mhdp8546 a000000.bridge: no PHY configured
[ 12.633243] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15
[ 12.661817] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[ 12.669006] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[ 12.676178] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[ 12.683345] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[ 12.690510] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[ 12.697681] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[ 12.705288] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[ 12.713047] virtio_rpmsg_bus virtio0: creating channel ti.ethfw.notifyservice addr 0x18
[ 12.721147] virtio_rpmsg_bus virtio0: creating channel ti.ethfw.ethdevice addr 0x22
[ 12.728882] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[ 12.736480] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[ 12.744210] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[ 12.751808] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x15
[ 12.759200] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[ 12.766821] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
[ 12.774434] virtio_rpmsg_bus virtio10: creating channel ti.ipc4.ping-pong addr 0xe
[ 12.782143] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe
[ 12.789732] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15
[ 12.797505] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe
[ OK ] Listening on Weston socket.
[ 12.816570] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[ 12.834628] ti_cpsw_proxy_client virtio0.ti.ethfw.ethdevice.-1.34: 1 Virtual Switch Port(s), 1 Virtual MAC Only Port(s)
[ OK ] Started D-Bus System Message Bus 12.845820] ti_cpsw_proxy_client virtio0.ti.ethfw.ethdevice.-1.34: Virt Port: 0, Type: Switch Port, Iface: eth2, Num TX: 2, Num RX: 1, Token: 0
m.
[ 12.860659] dbus-broker-lau[593]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 12.864080] ti_cpsw_proxy_client virtio0.ti.ethfw.ethdevice.-1.34: Virt Port: 4, Type: MAC Port, Iface: eth3, Num TX: 1, Num RX: 1, Token: 400
[ OK ] Finished Reboot and dump vmcore via kexec.
[ OK ] Created slice Slice /system/tee-supplicant.
[ OK ] Reached target Socket Units.
[ OK ] Reached target Basic System.
Starting Save/Restore Sound Card State...
[ OK ] Started Job spooling tools.
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Periodic Command Scheduler.
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
Starting Telephony service...
Starting Expand the rootfs partiti�…to full size [ 13.160656] audit: type=1334 audit(1728488656.740:10): prog-id=14 op=LOAD
of the boot device....
[ OK ] Started 13.171043] audit: type=1334 audit(1728488656.752:11): prog-id=15 op=LOAD
9mstrongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
Starting User Login Management...
Starting Virtual Console Setup...
[ OK ] Started TEE Supplicant on teepriv0.
Starting Telnet Server...
[ OK ] Finished Save/Restore Sound Card State.
[ OK ] Finished IPv6 Packet Filtering Framework.
[ OK ] Finished IPv4 Packet Filtering Framework.
[ OK ] Finished Telnet Server.
[ OK ] Started User Login Management.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Telephony service.
[ OK ] Created slice Slice /system/systemd-fsck.
Expecting device /dev/mmcblk1p1...
[ OK ] Reached target Preparation for Network.
[ OK ] Reached target Sound Card.
Starting Network Configuration...
[ OK ] Found device /dev/mmcblk1p1.
[ 13.577582] Bluetooth: Core ver 2.22
[ 13.581239] NET: Registered PF_BLUETOOTH protocol family
[ 13.586557] Bluetooth: HCI device and connection manager initialized
[ 13.592921] Bluetooth: HCI socket layer initialized
[ 13.597807] Bluetooth: L2CAP socket layer initialized
[ 13.602879] Bluetooth: SCO socket layer initialized
[ OK ] Finished Expand the rootfs partition to full size of the boot device..
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting File System Check on /dev/mmcblk1p1...
[ OK ] Finished Virtual Console Setup.
[ 13.659214] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 13.675449] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 13.681524] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ OK ] Started Network Configuration.
[ OK ] Reached target Network.
[ 13.801176] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
Starting Enable and configure wl18xx bluetooth[ 13.811256] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
stack...
Starting containerd container runtime...
[ 13.842145] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 13.851489] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
Starting LLDP daemon...
[ OK ] Started Netperf Benchmark Server.
Starting Simple Network Management Protoc[ 13.873542] ti_cpsw_proxy_client virtio0.ti.ethfw.ethdevice.-1.34: started port 0 on interface eth2
ol (SNMP) Daemon....
Starting Permit User Sessions...
[ OK ] Finished File S[ 13.893598] ti_cpsw_proxy_client virtio0.ti.ethfw.ethdevice.-1.34: started port 4 on interface eth3
[ OK ] Finished Enable and configure wl18xx bluetooth stack.
Mounting /run/media/BOOT-mmcblk1p1...
[ 13.916955] ti_cpsw_proxy_client virtio0.ti.ethfw.ethdevice.-1.34: 01:80:c2:00:00:0e is reserved for EthFw
;32m OK ] Finished Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
Starting Weston, a Wayland compositor, as a system service...
[ OK ] Started LLDP daemon.
[ OK ] Mounted /run/media/BOOT-mmcblk1p1.
[ OK ] Created slice User Slice of UID 1000.
Starting User Runtime Directory /run/user/1000...
[ OK ] Finished User Runtime Directory /run/user/1000.
Starting User Manager for UID 1000...
[ OK ] Finished Synchronize System and HW clocks.
[ OK ] Started Simple Network Management Protocol (SNMP) Daemon..
[ OK ] Started User Manager for UID 1000.
[ OK ] Started Session c1 of User weston.
[FAILED] Failed to start Weston, a Wayland compositor, as a system service.
See 'systemctl status weston.service' for details.
[ OK ] Started containerd container runtime.
NOTICE: This file system contains the following GPL-3.0 packages:
adwaita-icon-theme-symbolic
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfstools
elfutils-dev
elfutils
findutils
g++-symlinks
g++
gawk
gcc-symlinks
gcc
gdb
gdbserver
gettext
glmark2
gnu-config
grub-common
grub-editenv
grub-efi
gzip
hidapi
kbd-dev
kbd-keymaps-pine
less
libasm1
libatomic-dev
libatomic1
libbfd
libdebuginfod1
libdw1
libelf1
libgcc-s-dev
libgcc1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp-dev
libgmp10
libgmpxx4
libgnutls-dev
libgnutls-openssl27
libidn2-0
libidn2-dev
libmpc3
libmpfr6
libopcodes
libqt5charts-examples
libqt5charts-plugins
libqt5charts-qmlplugins
libqt5charts5
libqt5serialport-examples
libqt5serialport-plugins
libqt5serialport-qmlplugins
libqt5serialport5
libqt5svg-examples
libqt5svg-plugins
libqt5svg-qmlplugins
libqt5svg5
libqt5virtualkeyboard-plugins
libqt5virtualkeyboard-qmlplugins
libqt5virtualkeyboard5
libreadline-dev
libreadline8
libstdc++-dev
libstdc++6
libtasn1-dev
libunistring-dev
libunistring5
m4
make
nettle-dev
nettle
parted
piglit
qt3d-plugins
qt3d-qmlplugins
qt3d
qtbase-examples
qtbase-plugins
qtbase-qmlplugins
qtbase
qtconnectivity-plugins
qtconnectivity-qmlplugins
qtconnectivity
qtdeclarative-plugins
qtdeclarative-qmlplugins
qtdeclarative-tools
qtdeclarative
qtgraphicaleffects-qmlplugins
qtlocation-examples
qtlocation-plugins
qtlocation-qmlplugins
qtlocation
qtmultimedia-examples
qtmultimedia-plugins
qtmultimedia-qmlplugins
qtmultimedia
qtquics-qmlplugins.control
qtquics2-plugins.control
qtquics2-qmlplugins.control
qtquics2.control
qtscript-examples
qtscript-plugins
qtscript-qmlplugins
qtscript
qtwayland-examples
qtwayland-plugins
qtwayland-qmlplugins
qtwayland
tar
which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Finished Print notice about GPLv3 packages.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Record Runlevel Change in UTMP...
[ OK ] Finished Record Runlevel Change in UTMP.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project j784s4-evm ttyS2
Arago 2023.10 j784s4-evm ttyS2
j784s4-evm login: [ 22.990004] platform connector-dp0: deferred probe pending
[ 22.995498] platform regulator-dp0-prw: deferred probe pending
[ 23.001325] platform regulator-dp1-prw: deferred probe pending
[ 23.007150] platform a000000.bridge: deferred probe pending
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7.1 | VT102 | Offline | ttyUSB0
Please help me to figure out what was the root cause of the issue.
Minh
