DRA821U: Enabling the MCU_CLKOUT0 output
Part Number: DRA821U
Other Parts Discussed in Thread: J7200XSOMXEVM
Hi Team,
We have designed a custom board based on the J7200XSOMXEVM reference design.
We are developing the software for the custom board with PROCESSOR-SDK-LINUX-RT-J7200 (10.00.07.03).
MCU_CPSW of the custom board has the following configuration.
To enable the MCU_CLKOUT0 clock output, bit 4 of the CTRL_MMR_CFG0_MCU_CLKOUT0_CTRL register (0x40F08010) was set to 1.
However, MCU_CLKOUT0 clock is not output.
[device tree]
&wkup_pmx2 {
	ethernet_pins_default: ethernet-pins_default-pins {
		pinctrl-single,pins = <
			J721E_WKUP_IOPAD(0x00, PIN_INPUT, 1) /* (D11) MCU_RGMII1_TX_CTL.MCU_RMII1_CRS_DV */
			J721E_WKUP_IOPAD(0x04, PIN_INPUT, 1) /* (A11) MCU_RGMII1_RX_CTL.MCU_RMII1_RX_ER */
			J721E_WKUP_IOPAD(0x10, PIN_OUTPUT, 1) /* (B11) MCU_RGMII1_TD1.MCU_RMII1_TXD1 */
			J721E_WKUP_IOPAD(0x14, PIN_OUTPUT, 1) /* (D10) MCU_RGMII1_TD0.MCU_RMII1_TXD0 */
			J721E_WKUP_IOPAD(0x18, PIN_OUTPUT, 1) /* (A12) MCU_RGMII1_TXC.MCU_RMII1_TX_EN */
			J721E_WKUP_IOPAD(0x1c, PIN_INPUT, 1) /* (B10) MCU_RGMII1_RXC.MCU_RMII1_REF_CLK */
			J721E_WKUP_IOPAD(0x28, PIN_INPUT, 1) /* (B9) MCU_RGMII1_RD1.MCU_RMII1_RXD1 */
			J721E_WKUP_IOPAD(0x2c, PIN_INPUT, 1) /* (A9) MCU_RGMII1_RD0.MCU_RMII1_RXD0 */
	dp83822_mdio_pins_default: dp83822-mdio-default-pins {
			J721E_WKUP_IOPAD(0x34, PIN_OUTPUT, 0) /* (D9) MCU_MDIO0_MDC */
			J721E_WKUP_IOPAD(0x30, PIN_INPUT, 0) /* (C9) MCU_MDIO0_MDIO */
	mcu_clkout_pins_default: mcu-clkout-default-pins {
			J721E_WKUP_IOPAD(0x83, PIN_OUTPUT, 6) /* (C16) WKUP_GPIO0_11.MCU_CLKOUT0 */
&mcu_cpsw {
	status = "okay";
	pinctrl-names = "default";
	pinctrl-0 = <&ethernet_pins_default>, <&dp83822_mdio_pins_default>;
&davinci_mdio {
	status = "okay";
	phy0: ethernet-phy@0 {
		reg = <0>;
		rx-internal-delay-ps = <1>;
		tx-internal-delay-ps = <1>;
&cpsw_port1 {
	status = "okay";
	phy-mode = "rmii";
	phy-handle = <&phy0>;
[CTRL_MMR_CFG0_MCU_CLKOUT0_CTRL]
~# devmem2 0x40F08010
/dev/mem opened.
Memory mapped at address 0xffff93904000.
Read at address  0x40F08010 (0xffff93904010): 0x00000000
~# devmem2 0x40F08010 w 0x10
/dev/mem opened.
Memory mapped at address 0xffffafc80000.
Read at address  0x40F08010 (0xffffafc80010): 0x00000000
Write at address 0x40F08010 (0xffffafc80010): 0x00000010, readback 0x00000010
/dev/mem opened.
Memory mapped at address 0xffff9e1f4000.
Read at address  0x40F08010 (0xffff9e1f4010): 0x00000010
How can we enable the MCU_CLKOUT0 clock output?
Also, is it possible to set the 4th bit of CTRL_MMR_CFG0_MCU_CLKOUT0_CTRL to 1 in the device tree settings?
mizutani
  • Hi Mizutani-san,
    After devmem2 is run, you should see the clock on the MCU_CLKOUT0 pin on osciloscope. Can you check if that is visible.
    Can you dump the clocks in the device by running the command "k3conf dump clock" and share the output of the command here.
    Regard,
    Tanmay
    We checked with an oscilloscope, but no clock waveform was output from the MCU_CLKOUT0 pin.
    The result of executing “k3conf dump clock” is shown below.
    ~# k3conf dump clock
    | VERSION INFO        |
    | K3CONF | (version 0.3-nogit built Thu Jul 25 14:13:02 UTC 2024)              |
    | SoC    | J7200 SR2.0                                                         |
    | SYSFW  | ABI: 4.0 (firmware version 0x000a '10.0.8--v10.00.08 (Fiery Fox))') |
    | Device ID | Clock ID | Clock Name        | Status              | Clock Frequency |
    |     4     |     0    | DEV_A72SS0_CORE0_ARM_CLK_CLK                                                      | CLK_STATE_READY     | 2000000000      |
    |     4     |     1    | DEV_A72SS0_CORE0_MSMC_CLK                                                         | CLK_STATE_READY     | 1000000000      |
    |     4     |     2    | DEV_A72SS0_CORE0_PLL_CTRL_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   202     |     2    | DEV_A72SS0_CORE0_0_ARM_CLK_CLK                                                    | CLK_STATE_READY     | 2000000000      |
    |   203     |     0    | DEV_A72SS0_CORE0_1_ARM_CLK_CLK                                                    | CLK_STATE_READY     | 2000000000      |
    |     2     |     0    | DEV_ATL0_VBUS_CLK        | CLK_STATE_READY     | 250000000       |
    |     2     |     1    | DEV_ATL0_ATL_CLK        | CLK_STATE_READY     | 294912000       |
    |     2     |     2    | DEV_ATL0_ATL_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT1_CLK                         | CLK_STATE_READY     | 294912000       |
    |     2     |     3    | DEV_ATL0_ATL_CLK_PARENT_HSDIV4_16FFT_MAIN_2_HSDIVOUT2_CLK                         | CLK_STATE_READY     | 200000000       |
    |     2     |     6    | DEV_ATL0_ATL_CLK_PARENT_POSTDIV2_16FFT_MAIN_0_HSDIVOUT7_CLK                       | CLK_STATE_READY     | 200000000       |
    |     2     |     7    | DEV_ATL0_ATL_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                               | CLK_STATE_READY     | 0               |
    |     2     |     8    | DEV_ATL0_ATL_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                                   | CLK_STATE_READY     | 0               |
    |     2     |    10    | DEV_ATL0_ATL_IO_PORT_ATCLK_OUT_1                                                  | CLK_STATE_READY     | 0               |
    |     2     |    11    | DEV_ATL0_ATL_IO_PORT_ATCLK_OUT_3                                                  | CLK_STATE_READY     | 0               |
    |     2     |    12    | DEV_ATL0_ATL_IO_PORT_ATCLK_OUT_2                                                  | CLK_STATE_READY     | 0               |
    |     2     |    13    | DEV_ATL0_ATL_IO_PORT_ATCLK_OUT                                                    | CLK_STATE_READY     | 0               |
    |   157     |     1    | DEV_BOARD0_I2C1_SCL_OUT                                                           | CLK_STATE_READY     | 0               |
    |   157     |     2    | DEV_BOARD0_MCASP0_ACLKR_OUT                                                       | CLK_STATE_READY     | 0               |
    |   157     |     3    | DEV_BOARD0_SPI2_CLK_IN                                                            | CLK_STATE_NOT_READY | 0               |
    |   157     |     4    | DEV_BOARD0_I2C3_SCL_OUT                                                           | CLK_STATE_READY     | 0               |
    |   157     |     5    | DEV_BOARD0_OBSCLK2_IN                                                             | CLK_STATE_READY     | 500000000       |
    |   157     |     6    | DEV_BOARD0_MCU_I3C0_SCL_IN                                                        | CLK_STATE_NOT_READY | 0               |
    |   157     |     7    | DEV_BOARD0_MCU_HYPERBUS0_CKN_IN                                                   | CLK_STATE_READY     | 0               |
    |   157     |     8    | DEV_BOARD0_I2C4_SCL_OUT                                                           | CLK_STATE_READY     | 0               |
    |   157     |     9    | DEV_BOARD0_RGMII3_TXC_IN                                                          | CLK_STATE_READY     | 0               |
    |   157     |    11    | DEV_BOARD0_EXT_REFCLK1_OUT                                                        | CLK_STATE_READY     | 0               |
    |   157     |    12    | DEV_BOARD0_SPI1_CLK_IN                                                            | CLK_STATE_NOT_READY | 0               |
    |   157     |    13    | DEV_BOARD0_GPMC0_CLKOUT_IN                                                        | CLK_STATE_READY     | 0               |
    |   157     |    14    | DEV_BOARD0_MCU_OBSCLK0_IN                                                         | CLK_STATE_READY     | 1000000000      |
    |   157     |    15    | DEV_BOARD0_MCU_OBSCLK0_IN_PARENT_MCU_OBSCLK_DIV_OUT0                              | CLK_STATE_READY     | 1000000000      |
    |   157     |    16    | DEV_BOARD0_MCU_OBSCLK0_IN_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   157     |    31    | DEV_BOARD0_MCU_I3C0_SCL_OUT                                                       | CLK_STATE_READY     | 0               |
    |   157     |    32    | DEV_BOARD0_SPI3_CLK_IN                                                            | CLK_STATE_NOT_READY | 0               |
    |   157     |    33    | DEV_BOARD0_MCASP0_ACLKX_OUT                                                       | CLK_STATE_READY     | 0               |
    |   157     |    34    | DEV_BOARD0_MCASP1_ACLKR_IN                                                        | CLK_STATE_READY     | 0               |
    |   157     |    35    | DEV_BOARD0_CLKOUT_IN                                                              | CLK_STATE_READY     | 50000000        |
    |   157     |    36    | DEV_BOARD0_CLKOUT_IN_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT0_CLK5                    | CLK_STATE_READY     | 50000000        |
    |   157     |    37    | DEV_BOARD0_CLKOUT_IN_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT0_CLK10                   | CLK_STATE_READY     | 25000000        |
    |   157     |    38    | DEV_BOARD0_OBSCLK1_IN                                                             | CLK_STATE_READY     | 500000000       |
    |   157     |    39    | DEV_BOARD0_MCU_RMII1_REF_CLK_OUT                                                  | CLK_STATE_READY     | 0               |
    |   157     |    40    | DEV_BOARD0_GPMC0_CLK_OUT                                                          | CLK_STATE_READY     | 0               |
    |   157     |    41    | DEV_BOARD0_I3C0_SCL_OUT                                                           | CLK_STATE_READY     | 0               |
    |   157     |    43    | DEV_BOARD0_TCK_OUT        | CLK_STATE_READY     | 0               |
    |   157     |    44    | DEV_BOARD0_HFOSC1_CLK_OUT                                                         | CLK_STATE_READY     | 0               |
    |   157     |    45    | DEV_BOARD0_AUDIO_EXT_REFCLK0_OUT                                                  | CLK_STATE_READY     | 0               |
    |   157     |    46    | DEV_BOARD0_I2C6_SCL_OUT                                                           | CLK_STATE_READY     | 0               |
    |   157     |    48    | DEV_BOARD0_I2C5_SCL_OUT                                                           | CLK_STATE_READY     | 0               |
    |   157     |    49    | DEV_BOARD0_MCU_OSPI0_DQS_OUT                                                      | CLK_STATE_READY     | 0               |
    |   157     |    52    | DEV_BOARD0_RGMII2_RXC_OUT                                                         | CLK_STATE_READY     | 0               |
    |   157     |    53    | DEV_BOARD0_MCASP2_ACLKX_IN                                                        | CLK_STATE_READY     | 0               |
    |   157     |    54    | DEV_BOARD0_I2C0_SCL_OUT                                                           | CLK_STATE_READY     | 0               |
    |   157     |    57    | DEV_BOARD0_MCU_HYPERBUS0_CK_IN                                                    | CLK_STATE_READY     | 0               |
    |   157     |    59    | DEV_BOARD0_MCASP1_ACLKX_OUT                                                       | CLK_STATE_READY     | 0               |
    |   157     |    61    | DEV_BOARD0_MCU_CPTS0_RFT_CLK_OUT                                                  | CLK_STATE_READY     | 0               |
    |   157     |    62    | DEV_BOARD0_MDIO0_MDC_IN                                                           | CLK_STATE_READY     | 0               |
    |   157     |    63    | DEV_BOARD0_RGMII1_TXC_IN                                                          | CLK_STATE_READY     | 0               |
    |   157     |    65    | DEV_BOARD0_MMC1_CLK_IN                                                            | CLK_STATE_READY     | 0               |
    |   157     |    66    | DEV_BOARD0_MCASP2_ACLKR_IN                                                        | CLK_STATE_READY     | 0               |
    |   157     |    68    | DEV_BOARD0_WKUP_I2C0_SCL_OUT                                                      | CLK_STATE_READY     | 0               |
    |   157     |    69    | DEV_BOARD0_MCU_CLKOUT0_IN                                                         | CLK_STATE_READY     | 50000000        |
    |   157     |    70    | DEV_BOARD0_MCU_CLKOUT0_IN_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT0_CLK5                | CLK_STATE_READY     | 50000000        |
    |   157     |    71    | DEV_BOARD0_MCU_CLKOUT0_IN_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT0_CLK10               | CLK_STATE_READY     | 25000000        |
    |   157     |    73    | DEV_BOARD0_MCASP0_ACLKR_IN                                                        | CLK_STATE_READY     | 0               |
    |   157     |    74    | DEV_BOARD0_MCU_MDIO0_MDC_IN                                                       | CLK_STATE_READY     | 0               |
    |   157     |    77    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN                                                   | CLK_STATE_NOT_READY | 0               |
    |   157     |    78    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_MCASP_MAIN_0_MCASP_AHCLKR_POUT             | CLK_STATE_READY     | 0               |
    |   157     |    79    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_MCASP_MAIN_1_MCASP_AHCLKR_POUT             | CLK_STATE_READY     | 0               |
    |   157     |    80    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_MCASP_MAIN_2_MCASP_AHCLKR_POUT             | CLK_STATE_READY     | 0               |
    |   157     |    90    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_MCASP_MAIN_0_MCASP_AHCLKX_POUT             | CLK_STATE_READY     | 0               |
    |   157     |    91    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_MCASP_MAIN_1_MCASP_AHCLKX_POUT             | CLK_STATE_READY     | 0               |
    |   157     |    92    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_MCASP_MAIN_2_MCASP_AHCLKX_POUT             | CLK_STATE_READY     | 0               |
    |   157     |   102    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT           | CLK_STATE_NOT_READY | 0               |
    |   157     |   103    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1         | CLK_STATE_NOT_READY | 0               |
    |   157     |   104    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2         | CLK_STATE_NOT_READY | 0               |
    |   157     |   105    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3         | CLK_STATE_NOT_READY | 0               |
    |   157     |   106    | DEV_BOARD0_AUDIO_EXT_REFCLK1_IN_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK          | CLK_STATE_READY     | 196608000       |
    |   157     |   110    | DEV_BOARD0_MCU_OSPI0_CLK_IN                                                       | CLK_STATE_NOT_READY | 0               |
    |   157     |   114    | DEV_BOARD0_MCU_SYSCLKOUT0_IN                                                      | CLK_STATE_READY     | 1000000000      |
    |   157     |   115    | DEV_BOARD0_RGMII1_RXC_OUT                                                         | CLK_STATE_READY     | 0               |
    |   157     |   116    | DEV_BOARD0_LED_CLK_OUT                                                            | CLK_STATE_READY     | 0               |
    |   157     |   118    | DEV_BOARD0_RGMII2_TXC_IN                                                          | CLK_STATE_READY     | 0               |
    |   157     |   119    | DEV_BOARD0_I3C0_SCL_IN                                                            | CLK_STATE_NOT_READY | 0               |
    |   157     |   120    | DEV_BOARD0_MCU_I2C0_SCL_OUT                                                       | CLK_STATE_READY     | 0               |
    |   157     |   122    | DEV_BOARD0_SPI6_CLK_IN                                                            | CLK_STATE_NOT_READY | 0               |
    |   157     |   123    | DEV_BOARD0_WKUP_I2C0_SCL_IN                                                       | CLK_STATE_READY     | 0               |
    |   157     |   124    | DEV_BOARD0_WKUP_LF_CLKIN_OUT                                                      | CLK_STATE_READY     | 0               |
    |   157     |   126    | DEV_BOARD0_MCU_SPI1_CLK_IN                                                        | CLK_STATE_READY     | 0               |
    |   157     |   127    | DEV_BOARD0_MCASP0_ACLKX_IN                                                        | CLK_STATE_READY     | 0               |
    |   157     |   128    | DEV_BOARD0_MCASP1_ACLKX_IN                                                        | CLK_STATE_READY     | 0               |
    |   157     |   130    | DEV_BOARD0_MCU_SPI0_CLK_IN                                                        | CLK_STATE_READY     | 0               |
    |   157     |   131    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN                                                   | CLK_STATE_NOT_READY | 0               |
    |   157     |   132    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_MCASP_MAIN_0_MCASP_AHCLKR_POUT             | CLK_STATE_READY     | 0               |
    |   157     |   133    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_MCASP_MAIN_1_MCASP_AHCLKR_POUT             | CLK_STATE_READY     | 0               |
    |   157     |   134    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_MCASP_MAIN_2_MCASP_AHCLKR_POUT             | CLK_STATE_READY     | 0               |
    |   157     |   144    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_MCASP_MAIN_0_MCASP_AHCLKX_POUT             | CLK_STATE_READY     | 0               |
    |   157     |   145    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_MCASP_MAIN_1_MCASP_AHCLKX_POUT             | CLK_STATE_READY     | 0               |
    |   157     |   146    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_MCASP_MAIN_2_MCASP_AHCLKX_POUT             | CLK_STATE_READY     | 0               |
    |   157     |   156    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT           | CLK_STATE_NOT_READY | 0               |
    |   157     |   157    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1         | CLK_STATE_NOT_READY | 0               |
    |   157     |   158    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2         | CLK_STATE_NOT_READY | 0               |
    |   157     |   159    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3         | CLK_STATE_NOT_READY | 0               |
    |   157     |   160    | DEV_BOARD0_AUDIO_EXT_REFCLK0_IN_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK          | CLK_STATE_READY     | 196608000       |
    |   157     |   164    | DEV_BOARD0_MCU_RGMII1_TXC_IN                                                      | CLK_STATE_READY     | 0               |
    |   157     |   165    | DEV_BOARD0_CPTS0_RFT_CLK_OUT                                                      | CLK_STATE_READY     | 0               |
    |   157     |   166    | DEV_BOARD0_MCU_I2C1_SCL_OUT                                                       | CLK_STATE_READY     | 0               |
    |   157     |   168    | DEV_BOARD0_MCASP2_ACLKR_OUT                                                       | CLK_STATE_READY     | 0               |
    |   157     |   169    | DEV_BOARD0_MCU_I2C0_SCL_IN                                                        | CLK_STATE_READY     | 0               |
    |   157     |   170    | DEV_BOARD0_RMII_REF_CLK_OUT                                                       | CLK_STATE_READY     | 0               |
    |   157     |   171    | DEV_BOARD0_GPMC0_CLK_IN                                                           | CLK_STATE_READY     | 0               |
    |   157     |   172    | DEV_BOARD0_TRC_CLK_IN                                                             | CLK_STATE_READY     | 0               |
    |   157     |   174    | DEV_BOARD0_MCASP2_ACLKX_OUT                                                       | CLK_STATE_READY     | 0               |
    |   157     |   176    | DEV_BOARD0_RGMII4_RXC_OUT                                                         | CLK_STATE_READY     | 0               |
    |   157     |   177    | DEV_BOARD0_SYSCLKOUT0_IN                                                          | CLK_STATE_READY     | 500000000       |
    |   157     |   178    | DEV_BOARD0_MCASP1_ACLKR_OUT                                                       | CLK_STATE_READY     | 0               |
    |   157     |   179    | DEV_BOARD0_SPI5_CLK_IN                                                            | CLK_STATE_NOT_READY | 0               |
    |   157     |   180    | DEV_BOARD0_MCU_RGMII1_RXC_OUT                                                     | CLK_STATE_READY     | 0               |
    |   157     |   181    | DEV_BOARD0_RGMII3_RXC_OUT                                                         | CLK_STATE_READY     | 0               |
    |   157     |   183    | DEV_BOARD0_SPI0_CLK_IN                                                            | CLK_STATE_NOT_READY | 0               |
    |   157     |   184    | DEV_BOARD0_GPMC0_FCLK_MUX_IN                                                      | CLK_STATE_READY     | 133333333       |
    |   157     |   185    | DEV_BOARD0_I2C2_SCL_OUT                                                           | CLK_STATE_READY     | 0               |
    |   157     |   186    | DEV_BOARD0_MCU_EXT_REFCLK0_OUT                                                    | CLK_STATE_READY     | 0               |
    |   157     |   187    | DEV_BOARD0_MCU_OSPI0_LBCLKO_IN                                                    | CLK_STATE_NOT_READY | 0               |
    |   157     |   189    | DEV_BOARD0_SPI7_CLK_IN                                                            | CLK_STATE_NOT_READY | 0               |
    |   157     |   190    | DEV_BOARD0_RGMII4_TXC_IN                                                          | CLK_STATE_READY     | 0               |
    |   157     |   191    | DEV_BOARD0_AUDIO_EXT_REFCLK1_OUT                                                  | CLK_STATE_READY     | 0               |
    |   157     |   192    | DEV_BOARD0_OBSCLK0_IN                                                             | CLK_STATE_READY     | 500000000       |
    |   157     |   193    | DEV_BOARD0_OBSCLK0_IN_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT0_CLK                    | CLK_STATE_READY     | 500000000       |
    |   157     |   194    | DEV_BOARD0_OBSCLK0_IN_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT0_CLK                    | CLK_STATE_READY     | 192000000       |
    |   157     |   195    | DEV_BOARD0_OBSCLK0_IN_PARENT_HSDIV4_16FFT_MAIN_2_HSDIVOUT0_CLK                    | CLK_STATE_READY     | 1800000000      |
    |   157     |   196    | DEV_BOARD0_OBSCLK0_IN_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT0_CLK                    | CLK_STATE_READY     | 250000000       |
    |   157     |   197    | DEV_BOARD0_OBSCLK0_IN_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT0_CLK                    | CLK_STATE_READY     | 196608000       |
    |   157     |   205    | DEV_BOARD0_OBSCLK0_IN_PARENT_HSDIV0_16FFT_MAIN_12_HSDIVOUT0_CLK                   | CLK_STATE_READY     | 800000000       |
    |   157     |   206    | DEV_BOARD0_OBSCLK0_IN_PARENT_OBSCLK1_MUX_OUT0                                     | CLK_STATE_NOT_READY | 0               |
    |   157     |   207    | DEV_BOARD0_OBSCLK0_IN_PARENT_HSDIV1_16FFT_MAIN_14_HSDIVOUT0_CLK                   | CLK_STATE_READY     | 1000000000      |
    |   157     |   219    | DEV_BOARD0_OBSCLK0_IN_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                       | CLK_STATE_READY     | 0               |
    |   157     |   220    | DEV_BOARD0_OBSCLK0_IN_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK         | CLK_STATE_READY     | 12500000        |
    |   157     |   221    | DEV_BOARD0_OBSCLK0_IN_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                            | CLK_STATE_READY     | 0               |
    |   157     |   222    | DEV_BOARD0_OBSCLK0_IN_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT0_CLK_DUP0               | CLK_STATE_READY     | 500000000       |
    |   157     |   223    | DEV_BOARD0_OBSCLK0_IN_PARENT_BOARD_0_HFOSC1_CLK_OUT                               | CLK_STATE_READY     | 0               |
    |   157     |   224    | DEV_BOARD0_OBSCLK0_IN_PARENT_GLUELOGIC_HFOSC0_CLKOUT                              | CLK_STATE_READY     | 19200000        |
    |   123     |     0    | DEV_CMPEVENT_INTRTR0_INTR_CLK                                                     | CLK_STATE_READY     | 125000000       |
    |     3     |     0    | DEV_COMPUTE_CLUSTER0_DDR32SS_EMIF0_PLL_CTRL_CLK                                   | CLK_STATE_READY     | 500000000       |
    |     3     |     2    | DEV_COMPUTE_CLUSTER0_TB_SOC_VBUSP_DBG_CLK                                         | CLK_STATE_READY     | 250000000       |
    |     3     |     3    | DEV_COMPUTE_CLUSTER0_TB_SOC_GIC_CLK                                               | CLK_STATE_READY     | 250000000       |
    |     3     |     4    | DEV_COMPUTE_CLUSTER0_DDR32SS_EMIF0_DDR_PLL_CLK                                    | CLK_STATE_READY     | 800000000       |
    |     3     |     5    | DEV_COMPUTE_CLUSTER0_TB_SOC_VBUSP_CFG_CLK                                         | CLK_STATE_READY     | 125000000       |
    |     3     |     6    | DEV_COMPUTE_CLUSTER0_TB_SOC_VBUSP_DMSC_CLK                                        | CLK_STATE_READY     | 125000000       |
    |    17     |     4    | DEV_COMPUTE_CLUSTER0_PBIST_WRAP_DIVH_CLK4_CLK_CLK                                 | CLK_STATE_READY     | 1000000000      |
    |    19     |     0    | DEV_CPSW0_MDIO_MDCLK_O                                                            | CLK_STATE_READY     | 0               |
    |    19     |     1    | DEV_CPSW0_GMII3_MT_CLK                                                            | CLK_STATE_READY     | 25000000        |
    |    19     |     2    | DEV_CPSW0_GMII2_MR_CLK                                                            | CLK_STATE_READY     | 25000000        |
    |    19     |     3    | DEV_CPSW0_SERDES4_RXCLK                                                           | CLK_STATE_READY     | 0               |
    |    19     |     4    | DEV_CPSW0_CPTS_GENF0                                                              | CLK_STATE_READY     | 0               |
    |    19     |     5    | DEV_CPSW0_PRE_RGMII4_TCLK                                                         | CLK_STATE_READY     | 0               |
    |    19     |     6    | DEV_CPSW0_RGMII3_RXC_I                                                            | CLK_STATE_READY     | 0               |
    |    19     |     7    | DEV_CPSW0_RGMII4_RXC_I                                                            | CLK_STATE_READY     | 0               |
    |    19     |     8    | DEV_CPSW0_PRE_RGMII3_TCLK                                                         | CLK_STATE_READY     | 0               |
    |    19     |     9    | DEV_CPSW0_RGMII1_RXC_I                                                            | CLK_STATE_READY     | 0               |
    |    19     |    10    | DEV_CPSW0_RGMII_MHZ_250_CLK                                                       | CLK_STATE_READY     | 250000000       |
    |    19     |    11    | DEV_CPSW0_GMII4_MT_CLK                                                            | CLK_STATE_READY     | 25000000        |
    |    19     |    13    | DEV_CPSW0_GMII3_MR_CLK                                                            | CLK_STATE_READY     | 25000000        |
    |    19     |    14    | DEV_CPSW0_SERDES4_RXFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    15    | DEV_CPSW0_CPTS_RFT_CLK                                                            | CLK_STATE_READY     | 200000000       |
    |    19     |    16    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT1_CLK                   | CLK_STATE_READY     | 200000000       |
    |    19     |    17    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_POSTDIV2_16FFT_MAIN_0_HSDIVOUT6_CLK                 | CLK_STATE_READY     | 200000000       |
    |    19     |    18    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_BOARD_0_MCU_CPTS0_RFT_CLK_OUT                       | CLK_STATE_READY     | 0               |
    |    19     |    19    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |    19     |    20    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                         | CLK_STATE_READY     | 0               |
    |    19     |    21    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                             | CLK_STATE_READY     | 0               |
    |    19     |    22    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN0_TXMCLK                  | CLK_STATE_READY     | 0               |
    |    19     |    23    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN1_TXMCLK                  | CLK_STATE_READY     | 0               |
    |    19     |    24    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN2_TXMCLK                  | CLK_STATE_READY     | 0               |
    |    19     |    25    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN3_TXMCLK                  | CLK_STATE_READY     | 0               |
    |    19     |    30    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT1_CLK                    | CLK_STATE_READY     | 500000000       |
    |    19     |    31    | DEV_CPSW0_CPTS_RFT_CLK_PARENT_K3_PLL_CTRL_WRAP_MAIN_0_CHIP_DIV1_CLK_CLK           | CLK_STATE_READY     | 500000000       |
    |    19     |    32    | DEV_CPSW0_SERDES1_TXCLK                                                           | CLK_STATE_READY     | 0               |
    |    19     |    33    | DEV_CPSW0_CPPI_CLK_CLK                                                            | CLK_STATE_READY     | 320000000       |
    |    19     |    34    | DEV_CPSW0_SERDES2_RXCLK                                                           | CLK_STATE_READY     | 0               |
    |    19     |    35    | DEV_CPSW0_SERDES1_RXFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    36    | DEV_CPSW0_GMII_RFT_CLK                                                            | CLK_STATE_READY     | 125000000       |
    |    19     |    37    | DEV_CPSW0_SERDES1_TXMCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    38    | DEV_CPSW0_SERDES1_REFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    39    | DEV_CPSW0_RMII_MHZ_50_CLK                                                         | CLK_STATE_READY     | 0               |
    |    19     |    40    | DEV_CPSW0_GMII4_MR_CLK                                                            | CLK_STATE_READY     | 25000000        |
    |    19     |    41    | DEV_CPSW0_RGMII_MHZ_50_CLK                                                        | CLK_STATE_READY     | 50000000        |
    |    19     |    42    | DEV_CPSW0_SERDES3_TXFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    43    | DEV_CPSW0_SERDES3_RXFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    45    | DEV_CPSW0_PRE_RGMII2_TCLK                                                         | CLK_STATE_READY     | 0               |
    |    19     |    46    | DEV_CPSW0_SERDES2_TXCLK                                                           | CLK_STATE_READY     | 0               |
    |    19     |    47    | DEV_CPSW0_SERDES1_RXCLK                                                           | CLK_STATE_READY     | 0               |
    |    19     |    48    | DEV_CPSW0_SERDES1_TXFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    49    | DEV_CPSW0_RGMII2_RXC_I                                                            | CLK_STATE_READY     | 0               |
    |    19     |    50    | DEV_CPSW0_SERDES2_TXFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    51    | DEV_CPSW0_PRE_RGMII1_TCLK                                                         | CLK_STATE_READY     | 0               |
    |    19     |    52    | DEV_CPSW0_RGMII_MHZ_5_CLK                                                         | CLK_STATE_READY     | 5000000         |
    |    19     |    53    | DEV_CPSW0_GMII2_MT_CLK                                                            | CLK_STATE_READY     | 25000000        |
    |    19     |    54    | DEV_CPSW0_SERDES4_TXMCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    55    | DEV_CPSW0_SERDES3_TXCLK                                                           | CLK_STATE_READY     | 0               |
    |    19     |    56    | DEV_CPSW0_SERDES2_TXMCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    57    | DEV_CPSW0_GMII1_MR_CLK                                                            | CLK_STATE_READY     | 25000000        |
    |    19     |    58    | DEV_CPSW0_SERDES4_REFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    59    | DEV_CPSW0_SERDES3_TXMCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    60    | DEV_CPSW0_SERDES2_REFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    61    | DEV_CPSW0_SERDES3_REFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    62    | DEV_CPSW0_SERDES3_RXCLK                                                           | CLK_STATE_READY     | 0               |
    |    19     |    63    | DEV_CPSW0_GMII1_MT_CLK                                                            | CLK_STATE_READY     | 25000000        |
    |    19     |    64    | DEV_CPSW0_SERDES2_RXFCLK                                                          | CLK_STATE_READY     | 0               |
    |    19     |    66    | DEV_CPSW0_SERDES4_TXCLK                                                           | CLK_STATE_READY     | 0               |
    |    19     |    67    | DEV_CPSW0_SERDES4_TXFCLK                                                          | CLK_STATE_READY     | 0               |
    |    26     |     0    | DEV_CPSW_TX_RGMII0_IO__RGMII4_TXC__A                                              | CLK_STATE_READY     | 0               |
    |    26     |     1    | DEV_CPSW_TX_RGMII0_IO__RGMII3_TXC__A                                              | CLK_STATE_READY     | 0               |
    |    26     |     2    | DEV_CPSW_TX_RGMII0_IO__RGMII2_TXC__A                                              | CLK_STATE_READY     | 0               |
    |    26     |     3    | DEV_CPSW_TX_RGMII0_IO__RGMII1_TXC__A                                              | CLK_STATE_READY     | 0               |
    |    26     |     4    | DEV_CPSW_TX_RGMII0_PRE_RGMII2_TCLK                                                | CLK_STATE_READY     | 0               |
    |    26     |     5    | DEV_CPSW_TX_RGMII0_PRE_RGMII4_TCLK                                                | CLK_STATE_READY     | 0               |
    |    26     |     6    | DEV_CPSW_TX_RGMII0_PRE_RGMII3_TCLK                                                | CLK_STATE_READY     | 0               |
    |    26     |     7    | DEV_CPSW_TX_RGMII0_PRE_RGMII1_TCLK                                                | CLK_STATE_READY     | 0               |
    |    20     |     0    | DEV_CPT2_AGGR0_VCLK_CLK                                                           | CLK_STATE_READY     | 500000000       |
    |    21     |     0    | DEV_CPT2_AGGR1_VCLK_CLK                                                           | CLK_STATE_READY     | 500000000       |
    |    23     |     0    | DEV_CPT2_AGGR2_VCLK_CLK                                                           | CLK_STATE_READY     | 250000000       |
    |    25     |     0    | DEV_CPT2_AGGR3_VCLK_CLK                                                           | CLK_STATE_READY     | 500000000       |
    |    30     |     0    | DEV_DCC0_DCC_INPUT10_CLK                                                          | CLK_STATE_READY     | 250000000       |
    |    30     |     1    | DEV_DCC0_DCC_INPUT01_CLK                                                          | CLK_STATE_READY     | 0               |
    |    30     |     2    | DEV_DCC0_DCC_CLKSRC2_CLK                                                          | CLK_STATE_READY     | 133333333       |
    |    30     |     4    | DEV_DCC0_DCC_CLKSRC0_CLK                                                          | CLK_STATE_READY     | 200000000       |
    |    30     |     5    | DEV_DCC0_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    30     |     6    | DEV_DCC0_DCC_CLKSRC4_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |    30     |     7    | DEV_DCC0_DCC_CLKSRC1_CLK                                                          | CLK_STATE_READY     | 200000000       |
    |    30     |     8    | DEV_DCC0_DCC_CLKSRC3_CLK                                                          | CLK_STATE_READY     | 80000000        |
    |    30     |     9    | DEV_DCC0_DCC_INPUT00_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |    30     |    10    | DEV_DCC0_DCC_CLKSRC5_CLK                                                          | CLK_STATE_READY     | 0               |
    |    30     |    11    | DEV_DCC0_DCC_CLKSRC6_CLK                                                          | CLK_STATE_READY     | 500000000       |
    |    30     |    12    | DEV_DCC0_DCC_INPUT02_CLK                                                          | CLK_STATE_READY     | 12500000        |
    |    31     |     0    | DEV_DCC1_DCC_INPUT10_CLK                                                          | CLK_STATE_READY     | 125000000       |
    |    31     |     1    | DEV_DCC1_DCC_INPUT01_CLK                                                          | CLK_STATE_READY     | 0               |
    |    31     |     2    | DEV_DCC1_DCC_CLKSRC2_CLK                                                          | CLK_STATE_READY     | 200000000       |
    |    31     |     4    | DEV_DCC1_DCC_CLKSRC0_CLK                                                          | CLK_STATE_READY     | 50000000        |
    |    31     |     5    | DEV_DCC1_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    31     |     6    | DEV_DCC1_DCC_CLKSRC4_CLK                                                          | CLK_STATE_READY     | 320000000       |
    |    31     |     7    | DEV_DCC1_DCC_CLKSRC1_CLK                                                          | CLK_STATE_READY     | 200000000       |
    |    31     |     8    | DEV_DCC1_DCC_CLKSRC3_CLK                                                          | CLK_STATE_READY     | 192000000       |
    |    31     |     9    | DEV_DCC1_DCC_INPUT00_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |    31     |    10    | DEV_DCC1_DCC_CLKSRC5_CLK                                                          | CLK_STATE_READY     | 192000000       |
    |    31     |    11    | DEV_DCC1_DCC_CLKSRC6_CLK                                                          | CLK_STATE_READY     | 192000000       |
    |    31     |    12    | DEV_DCC1_DCC_INPUT02_CLK                                                          | CLK_STATE_READY     | 12500000        |
    |    32     |     0    | DEV_DCC2_DCC_INPUT10_CLK                                                          | CLK_STATE_READY     | 125000000       |
    |    32     |     1    | DEV_DCC2_DCC_INPUT01_CLK                                                          | CLK_STATE_READY     | 0               |
    |    32     |     2    | DEV_DCC2_DCC_CLKSRC2_CLK                                                          | CLK_STATE_READY     | 200000000       |
    |    32     |     3    | DEV_DCC2_DCC_CLKSRC7_CLK                                                          | CLK_STATE_READY     | 250000000       |
    |    32     |     4    | DEV_DCC2_DCC_CLKSRC0_CLK                                                          | CLK_STATE_READY     | 24000000        |
    |    32     |     5    | DEV_DCC2_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    32     |     6    | DEV_DCC2_DCC_CLKSRC4_CLK                                                          | CLK_STATE_READY     | 225000000       |
    |    32     |     8    | DEV_DCC2_DCC_CLKSRC3_CLK                                                          | CLK_STATE_READY     | 100000000       |
    |    32     |     9    | DEV_DCC2_DCC_INPUT00_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |    32     |    10    | DEV_DCC2_DCC_CLKSRC5_CLK                                                          | CLK_STATE_READY     | 300000000       |
    |    32     |    11    | DEV_DCC2_DCC_CLKSRC6_CLK                                                          | CLK_STATE_READY     | 200000000       |
    |    32     |    12    | DEV_DCC2_DCC_INPUT02_CLK                                                          | CLK_STATE_READY     | 12500000        |
    |    33     |     0    | DEV_DCC3_DCC_INPUT10_CLK                                                          | CLK_STATE_READY     | 125000000       |
    |    33     |     1    | DEV_DCC3_DCC_INPUT01_CLK                                                          | CLK_STATE_READY     | 0               |
    |    33     |     2    | DEV_DCC3_DCC_CLKSRC2_CLK                                                          | CLK_STATE_READY     | 196608000       |
    |    33     |     3    | DEV_DCC3_DCC_CLKSRC7_CLK                                                          | CLK_STATE_READY     | 250000000       |
    |    33     |     4    | DEV_DCC3_DCC_CLKSRC0_CLK                                                          | CLK_STATE_READY     | 196608000       |
    |    33     |     5    | DEV_DCC3_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    33     |     6    | DEV_DCC3_DCC_CLKSRC4_CLK                                                          | CLK_STATE_READY     | 125000000       |
    |    33     |     8    | DEV_DCC3_DCC_CLKSRC3_CLK                                                          | CLK_STATE_READY     | 200000000       |
    |    33     |     9    | DEV_DCC3_DCC_INPUT00_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |    33     |    10    | DEV_DCC3_DCC_CLKSRC5_CLK                                                          | CLK_STATE_READY     | 83              |
    |    33     |    11    | DEV_DCC3_DCC_CLKSRC6_CLK                                                          | CLK_STATE_READY     | 250000000       |
    |    33     |    12    | DEV_DCC3_DCC_INPUT02_CLK                                                          | CLK_STATE_READY     | 12500000        |
    |    34     |     0    | DEV_DCC4_DCC_INPUT10_CLK                                                          | CLK_STATE_READY     | 250000000       |
    |    34     |     1    | DEV_DCC4_DCC_INPUT01_CLK                                                          | CLK_STATE_READY     | 0               |
    |    34     |     2    | DEV_DCC4_DCC_CLKSRC2_CLK                                                          | CLK_STATE_READY     | 200000000       |
    |    34     |     3    | DEV_DCC4_DCC_CLKSRC7_CLK                                                          | CLK_STATE_READY     | 0               |
    |    34     |     4    | DEV_DCC4_DCC_CLKSRC0_CLK                                                          | CLK_STATE_READY     | 0               |
    |    34     |     5    | DEV_DCC4_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    34     |     6    | DEV_DCC4_DCC_CLKSRC4_CLK                                                          | CLK_STATE_READY     | 250000000       |
    |    34     |     7    | DEV_DCC4_DCC_CLKSRC1_CLK                                                          | CLK_STATE_READY     | 0               |
    |    34     |     8    | DEV_DCC4_DCC_CLKSRC3_CLK                                                          | CLK_STATE_READY     | 0               |
    |    34     |     9    | DEV_DCC4_DCC_INPUT00_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |    34     |    10    | DEV_DCC4_DCC_CLKSRC5_CLK                                                          | CLK_STATE_READY     | 0               |
    |    34     |    11    | DEV_DCC4_DCC_CLKSRC6_CLK                                                          | CLK_STATE_READY     | 0               |
    |    34     |    12    | DEV_DCC4_DCC_INPUT02_CLK                                                          | CLK_STATE_READY     | 12500000        |
    |    36     |     0    | DEV_DCC5_DCC_INPUT10_CLK                                                          | CLK_STATE_READY     | 500000000       |
    |    36     |     1    | DEV_DCC5_DCC_INPUT01_CLK                                                          | CLK_STATE_READY     | 0               |
    |    36     |     4    | DEV_DCC5_DCC_CLKSRC0_CLK                                                          | CLK_STATE_READY     | 0               |
    |    36     |     5    | DEV_DCC5_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    36     |     6    | DEV_DCC5_DCC_CLKSRC4_CLK                                                          | CLK_STATE_READY     | 0               |
    |    36     |     7    | DEV_DCC5_DCC_CLKSRC1_CLK                                                          | CLK_STATE_READY     | 0               |
    |    36     |     9    | DEV_DCC5_DCC_INPUT00_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |    36     |    11    | DEV_DCC5_DCC_CLKSRC6_CLK                                                          | CLK_STATE_READY     | 0               |
    |    36     |    12    | DEV_DCC5_DCC_INPUT02_CLK                                                          | CLK_STATE_READY     | 12500000        |
    |    37     |     0    | DEV_DCC6_DCC_INPUT10_CLK                                                          | CLK_STATE_READY     | 125000000       |
    |    37     |     1    | DEV_DCC6_DCC_INPUT01_CLK                                                          | CLK_STATE_READY     | 0               |
    |    37     |     2    | DEV_DCC6_DCC_CLKSRC2_CLK                                                          | CLK_STATE_READY     | 0               |
    |    37     |     3    | DEV_DCC6_DCC_CLKSRC7_CLK                                                          | CLK_STATE_READY     | 200000000       |
    |    37     |     4    | DEV_DCC6_DCC_CLKSRC0_CLK                                                          | CLK_STATE_READY     | 0               |
    |    37     |     5    | DEV_DCC6_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    37     |     6    | DEV_DCC6_DCC_CLKSRC4_CLK                                                          | CLK_STATE_READY     | 0               |
    |    37     |     7    | DEV_DCC6_DCC_CLKSRC1_CLK                                                          | CLK_STATE_READY     | 0               |
    |    37     |     8    | DEV_DCC6_DCC_CLKSRC3_CLK                                                          | CLK_STATE_READY     | 0               |
    |    37     |     9    | DEV_DCC6_DCC_INPUT00_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |    37     |    10    | DEV_DCC6_DCC_CLKSRC5_CLK                                                          | CLK_STATE_READY     | 0               |
    |    37     |    11    | DEV_DCC6_DCC_CLKSRC6_CLK                                                          | CLK_STATE_READY     | 200000000       |
    |    37     |    12    | DEV_DCC6_DCC_INPUT02_CLK                                                          | CLK_STATE_READY     | 12500000        |
    |     8     |     0    | DEV_DDR0_PLL_CTRL_CLK                                                             | CLK_STATE_READY     | 500000000       |
    |     8     |     5    | DEV_DDR0_DDRSS_DDR_PLL_CLK                                                        | CLK_STATE_READY     | 800000000       |
    |   304     |     5    | DEV_DEBUGSS_WRAP0_TREXPT_CLK                                                      | CLK_STATE_READY     | 300000000       |
    |   304     |     9    | DEV_DEBUGSS_WRAP0_CORE_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |   304     |    25    | DEV_DEBUGSS_WRAP0_JTAG_TCK                                                        | CLK_STATE_READY     | 0               |
    |   304     |    34    | DEV_DEBUGSS_WRAP0_ATB_CLK                                                         | CLK_STATE_READY     | 250000000       |
    |   304     |    49    | DEV_DEBUGSS_WRAP0_CSTPIU_TRACECLK                                                 | CLK_STATE_READY     | 0               |
    |    80     |     0    | DEV_ECAP0_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    81     |     0    | DEV_ECAP1_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    82     |     0    | DEV_ECAP2_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    83     |     0    | DEV_EHRPWM0_VBUSP_CLK                                                             | CLK_STATE_READY     | 125000000       |
    |    84     |     0    | DEV_EHRPWM1_VBUSP_CLK                                                             | CLK_STATE_READY     | 125000000       |
    |    85     |     0    | DEV_EHRPWM2_VBUSP_CLK                                                             | CLK_STATE_READY     | 125000000       |
    |    86     |     0    | DEV_EHRPWM3_VBUSP_CLK                                                             | CLK_STATE_READY     | 125000000       |
    |    87     |     0    | DEV_EHRPWM4_VBUSP_CLK                                                             | CLK_STATE_READY     | 125000000       |
    |    88     |     0    | DEV_EHRPWM5_VBUSP_CLK                                                             | CLK_STATE_READY     | 125000000       |
    |    89     |     0    | DEV_ELM0_VBUSP_CLK        | CLK_STATE_READY     | 125000000       |
    |    94     |     0    | DEV_EQEP0_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    95     |     0    | DEV_EQEP1_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    96     |     0    | DEV_EQEP2_VBUS_CLK        | CLK_STATE_READY     | 125000000       |
    |    97     |     0    | DEV_ESM0_CLK        | CLK_STATE_READY     | 125000000       |
    |   105     |     0    | DEV_GPIO0_MMR_CLK        | CLK_STATE_READY     | 125000000       |
    |   107     |     0    | DEV_GPIO2_MMR_CLK        | CLK_STATE_READY     | 125000000       |
    |   109     |     0    | DEV_GPIO4_MMR_CLK        | CLK_STATE_READY     | 125000000       |
    |   111     |     0    | DEV_GPIO6_MMR_CLK        | CLK_STATE_READY     | 125000000       |
    |   131     |     0    | DEV_GPIOMUX_INTRTR0_INTR_CLK                                                      | CLK_STATE_READY     | 125000000       |
    |   115     |     0    | DEV_GPMC0_FUNC_CLK        | CLK_STATE_READY     | 133333333       |
    |   115     |     1    | DEV_GPMC0_FUNC_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT3_CLK                       | CLK_STATE_READY     | 133333333       |
    |   115     |     2    | DEV_GPMC0_FUNC_CLK_PARENT_HSDIV4_16FFT_MAIN_2_HSDIVOUT1_CLK6                      | CLK_STATE_READY     | 100000000       |
    |   115     |     3    | DEV_GPMC0_FUNC_CLK_PARENT_HSDIV4_16FFT_MAIN_2_HSDIVOUT1_CLK4                      | CLK_STATE_READY     | 150000000       |
    |   115     |     4    | DEV_GPMC0_FUNC_CLK_PARENT_K3_PLL_CTRL_WRAP_MAIN_0_CHIP_DIV1_CLK_CLK4              | CLK_STATE_READY     | 125000000       |
    |   115     |     5    | DEV_GPMC0_VBUSP_CLK                                                               | CLK_STATE_READY     | 250000000       |
    |   115     |     6    | DEV_GPMC0_PO_GPMC_DEV_CLK                                                         | CLK_STATE_READY     | 0               |
    |   115     |     7    | DEV_GPMC0_PI_GPMC_RET_CLK                                                         | CLK_STATE_READY     | 0               |
    |    61     |     0    | DEV_GTC0_VBUSP_CLK        | CLK_STATE_READY     | 125000000       |
    |    61     |     1    | DEV_GTC0_GTC_CLK        | CLK_STATE_READY     | 200000000       |
    |    61     |     2    | DEV_GTC0_GTC_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT1_CLK                         | CLK_STATE_READY     | 200000000       |
    |    61     |     3    | DEV_GTC0_GTC_CLK_PARENT_POSTDIV2_16FFT_MAIN_0_HSDIVOUT6_CLK                       | CLK_STATE_READY     | 200000000       |
    |    61     |     4    | DEV_GTC0_GTC_CLK_PARENT_BOARD_0_MCU_CPTS0_RFT_CLK_OUT                             | CLK_STATE_READY     | 0               |
    |    61     |     5    | DEV_GTC0_GTC_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                                 | CLK_STATE_READY     | 0               |
    |    61     |     6    | DEV_GTC0_GTC_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                               | CLK_STATE_READY     | 0               |
    |    61     |     7    | DEV_GTC0_GTC_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                                   | CLK_STATE_READY     | 0               |
    |    61     |     8    | DEV_GTC0_GTC_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN0_TXMCLK                        | CLK_STATE_READY     | 0               |
    |    61     |     9    | DEV_GTC0_GTC_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN1_TXMCLK                        | CLK_STATE_READY     | 0               |
    |    61     |    10    | DEV_GTC0_GTC_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN2_TXMCLK                        | CLK_STATE_READY     | 0               |
    |    61     |    11    | DEV_GTC0_GTC_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN3_TXMCLK                        | CLK_STATE_READY     | 0               |
    |    61     |    16    | DEV_GTC0_GTC_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT1_CLK                          | CLK_STATE_READY     | 500000000       |
    |    61     |    17    | DEV_GTC0_GTC_CLK_PARENT_K3_PLL_CTRL_WRAP_MAIN_0_CHIP_DIV1_CLK_CLK                 | CLK_STATE_READY     | 500000000       |
    |   187     |     0    | DEV_I2C0_PISCL        | CLK_STATE_READY     | 0               |
    |   187     |     1    | DEV_I2C0_PISYS_CLK        | CLK_STATE_READY     | 96000000        |
    |   187     |     2    | DEV_I2C0_CLK        | CLK_STATE_READY     | 125000000       |
    |   187     |     3    | DEV_I2C0_PORSCL        | CLK_STATE_READY     | 0               |
    |   188     |     0    | DEV_I2C1_PISCL        | CLK_STATE_READY     | 0               |
    |   188     |     1    | DEV_I2C1_PISYS_CLK        | CLK_STATE_READY     | 96000000        |
    |   188     |     2    | DEV_I2C1_CLK        | CLK_STATE_READY     | 125000000       |
    |   188     |     3    | DEV_I2C1_PORSCL        | CLK_STATE_READY     | 0               |
    |   189     |     0    | DEV_I2C2_PISCL        | CLK_STATE_READY     | 0               |
    |   189     |     1    | DEV_I2C2_PISYS_CLK        | CLK_STATE_READY     | 96000000        |
    |   189     |     2    | DEV_I2C2_CLK        | CLK_STATE_READY     | 125000000       |
    |   189     |     3    | DEV_I2C2_PORSCL        | CLK_STATE_READY     | 0               |
    |   190     |     0    | DEV_I2C3_PISCL        | CLK_STATE_READY     | 0               |
    |   190     |     1    | DEV_I2C3_PISYS_CLK        | CLK_STATE_READY     | 96000000        |
    |   190     |     2    | DEV_I2C3_CLK        | CLK_STATE_READY     | 125000000       |
    |   190     |     3    | DEV_I2C3_PORSCL        | CLK_STATE_READY     | 0               |
    |   191     |     0    | DEV_I2C4_PISCL        | CLK_STATE_READY     | 0               |
    |   191     |     1    | DEV_I2C4_PISYS_CLK        | CLK_STATE_READY     | 96000000        |
    |   191     |     2    | DEV_I2C4_CLK        | CLK_STATE_READY     | 125000000       |
    |   191     |     3    | DEV_I2C4_PORSCL        | CLK_STATE_READY     | 0               |
    |   192     |     0    | DEV_I2C5_PISCL        | CLK_STATE_READY     | 0               |
    |   192     |     1    | DEV_I2C5_PISYS_CLK        | CLK_STATE_READY     | 96000000        |
    |   192     |     2    | DEV_I2C5_CLK        | CLK_STATE_READY     | 125000000       |
    |   192     |     3    | DEV_I2C5_PORSCL        | CLK_STATE_READY     | 0               |
    |   193     |     0    | DEV_I2C6_PISCL        | CLK_STATE_READY     | 0               |
    |   193     |     1    | DEV_I2C6_PISYS_CLK        | CLK_STATE_READY     | 96000000        |
    |   193     |     2    | DEV_I2C6_CLK        | CLK_STATE_READY     | 125000000       |
    |   193     |     3    | DEV_I2C6_PORSCL        | CLK_STATE_READY     | 0               |
    |   116     |     0    | DEV_I3C0_I3C_SCL_DI                                                               | CLK_STATE_READY     | 0               |
    |   116     |     1    | DEV_I3C0_I3C_SCL_DO                                                               | CLK_STATE_READY     | 0               |
    |   116     |     2    | DEV_I3C0_I3C_PCLK_CLK                                                             | CLK_STATE_READY     | 125000000       |
    |   116     |     4    | DEV_I3C0_I3C_SCLK_CLK                                                             | CLK_STATE_READY     | 125000000       |
    |   127     |     0    | DEV_LED0_LED_CLK        | CLK_STATE_READY     | 0               |
    |   127     |     1    | DEV_LED0_VBUS_CLK        | CLK_STATE_READY     | 250000000       |
    |   156     |     0    | DEV_MCAN0_MCANSS_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |   156     |     2    | DEV_MCAN0_MCANSS_CCLK_CLK                                                         | CLK_STATE_READY     | 80000000        |
    |   156     |     3    | DEV_MCAN0_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK                | CLK_STATE_READY     | 80000000        |
    |   156     |     4    | DEV_MCAN0_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   156     |     5    | DEV_MCAN0_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   156     |     6    | DEV_MCAN0_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   158     |     0    | DEV_MCAN1_MCANSS_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |   158     |     2    | DEV_MCAN1_MCANSS_CCLK_CLK                                                         | CLK_STATE_READY     | 80000000        |
    |   158     |     3    | DEV_MCAN1_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK                | CLK_STATE_READY     | 80000000        |
    |   158     |     4    | DEV_MCAN1_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   158     |     5    | DEV_MCAN1_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   158     |     6    | DEV_MCAN1_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   168     |     0    | DEV_MCAN10_MCANSS_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |   168     |     2    | DEV_MCAN10_MCANSS_CCLK_CLK                                                        | CLK_STATE_READY     | 80000000        |
    |   168     |     3    | DEV_MCAN10_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK               | CLK_STATE_READY     | 80000000        |
    |   168     |     4    | DEV_MCAN10_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |   168     |     5    | DEV_MCAN10_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |   168     |     6    | DEV_MCAN10_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |   169     |     0    | DEV_MCAN11_MCANSS_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |   169     |     2    | DEV_MCAN11_MCANSS_CCLK_CLK                                                        | CLK_STATE_READY     | 80000000        |
    |   169     |     3    | DEV_MCAN11_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK               | CLK_STATE_READY     | 80000000        |
    |   169     |     4    | DEV_MCAN11_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |   169     |     5    | DEV_MCAN11_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |   169     |     6    | DEV_MCAN11_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |   170     |     0    | DEV_MCAN12_MCANSS_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |   170     |     2    | DEV_MCAN12_MCANSS_CCLK_CLK                                                        | CLK_STATE_READY     | 80000000        |
    |   170     |     3    | DEV_MCAN12_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK               | CLK_STATE_READY     | 80000000        |
    |   170     |     4    | DEV_MCAN12_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |   170     |     5    | DEV_MCAN12_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |   170     |     6    | DEV_MCAN12_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |   171     |     0    | DEV_MCAN13_MCANSS_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |   171     |     2    | DEV_MCAN13_MCANSS_CCLK_CLK                                                        | CLK_STATE_READY     | 80000000        |
    |   171     |     3    | DEV_MCAN13_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK               | CLK_STATE_READY     | 80000000        |
    |   171     |     4    | DEV_MCAN13_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |   171     |     5    | DEV_MCAN13_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |   171     |     6    | DEV_MCAN13_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |   150     |     0    | DEV_MCAN14_MCANSS_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |   150     |     2    | DEV_MCAN14_MCANSS_CCLK_CLK                                                        | CLK_STATE_READY     | 80000000        |
    |   150     |     3    | DEV_MCAN14_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK               | CLK_STATE_READY     | 80000000        |
    |   150     |     4    | DEV_MCAN14_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |   150     |     5    | DEV_MCAN14_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |   150     |     6    | DEV_MCAN14_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |   151     |     0    | DEV_MCAN15_MCANSS_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |   151     |     2    | DEV_MCAN15_MCANSS_CCLK_CLK                                                        | CLK_STATE_READY     | 80000000        |
    |   151     |     3    | DEV_MCAN15_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK               | CLK_STATE_READY     | 80000000        |
    |   151     |     4    | DEV_MCAN15_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |   151     |     5    | DEV_MCAN15_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |   151     |     6    | DEV_MCAN15_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |   152     |     0    | DEV_MCAN16_MCANSS_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |   152     |     2    | DEV_MCAN16_MCANSS_CCLK_CLK                                                        | CLK_STATE_READY     | 80000000        |
    |   152     |     3    | DEV_MCAN16_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK               | CLK_STATE_READY     | 80000000        |
    |   152     |     4    | DEV_MCAN16_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |   152     |     5    | DEV_MCAN16_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |   152     |     6    | DEV_MCAN16_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |   153     |     0    | DEV_MCAN17_MCANSS_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |   153     |     2    | DEV_MCAN17_MCANSS_CCLK_CLK                                                        | CLK_STATE_READY     | 80000000        |
    |   153     |     3    | DEV_MCAN17_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK               | CLK_STATE_READY     | 80000000        |
    |   153     |     4    | DEV_MCAN17_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |   153     |     5    | DEV_MCAN17_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |   153     |     6    | DEV_MCAN17_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |   160     |     0    | DEV_MCAN2_MCANSS_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |   160     |     2    | DEV_MCAN2_MCANSS_CCLK_CLK                                                         | CLK_STATE_READY     | 80000000        |
    |   160     |     3    | DEV_MCAN2_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK                | CLK_STATE_READY     | 80000000        |
    |   160     |     4    | DEV_MCAN2_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   160     |     5    | DEV_MCAN2_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   160     |     6    | DEV_MCAN2_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   161     |     0    | DEV_MCAN3_MCANSS_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |   161     |     2    | DEV_MCAN3_MCANSS_CCLK_CLK                                                         | CLK_STATE_READY     | 80000000        |
    |   161     |     3    | DEV_MCAN3_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK                | CLK_STATE_READY     | 80000000        |
    |   161     |     4    | DEV_MCAN3_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   161     |     5    | DEV_MCAN3_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   161     |     6    | DEV_MCAN3_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   162     |     0    | DEV_MCAN4_MCANSS_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |   162     |     2    | DEV_MCAN4_MCANSS_CCLK_CLK                                                         | CLK_STATE_READY     | 80000000        |
    |   162     |     3    | DEV_MCAN4_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK                | CLK_STATE_READY     | 80000000        |
    |   162     |     4    | DEV_MCAN4_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   162     |     5    | DEV_MCAN4_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   162     |     6    | DEV_MCAN4_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   163     |     0    | DEV_MCAN5_MCANSS_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |   163     |     2    | DEV_MCAN5_MCANSS_CCLK_CLK                                                         | CLK_STATE_READY     | 80000000        |
    |   163     |     3    | DEV_MCAN5_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK                | CLK_STATE_READY     | 80000000        |
    |   163     |     4    | DEV_MCAN5_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   163     |     5    | DEV_MCAN5_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   163     |     6    | DEV_MCAN5_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   164     |     0    | DEV_MCAN6_MCANSS_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |   164     |     2    | DEV_MCAN6_MCANSS_CCLK_CLK                                                         | CLK_STATE_READY     | 80000000        |
    |   164     |     3    | DEV_MCAN6_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK                | CLK_STATE_READY     | 80000000        |
    |   164     |     4    | DEV_MCAN6_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   164     |     5    | DEV_MCAN6_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   164     |     6    | DEV_MCAN6_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   165     |     0    | DEV_MCAN7_MCANSS_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |   165     |     2    | DEV_MCAN7_MCANSS_CCLK_CLK                                                         | CLK_STATE_READY     | 80000000        |
    |   165     |     3    | DEV_MCAN7_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK                | CLK_STATE_READY     | 80000000        |
    |   165     |     4    | DEV_MCAN7_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   165     |     5    | DEV_MCAN7_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   165     |     6    | DEV_MCAN7_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   166     |     0    | DEV_MCAN8_MCANSS_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |   166     |     2    | DEV_MCAN8_MCANSS_CCLK_CLK                                                         | CLK_STATE_READY     | 80000000        |
    |   166     |     3    | DEV_MCAN8_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK                | CLK_STATE_READY     | 80000000        |
    |   166     |     4    | DEV_MCAN8_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   166     |     5    | DEV_MCAN8_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   166     |     6    | DEV_MCAN8_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   167     |     0    | DEV_MCAN9_MCANSS_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |   167     |     2    | DEV_MCAN9_MCANSS_CCLK_CLK                                                         | CLK_STATE_READY     | 80000000        |
    |   167     |     3    | DEV_MCAN9_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT4_CLK                | CLK_STATE_READY     | 80000000        |
    |   167     |     4    | DEV_MCAN9_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   167     |     5    | DEV_MCAN9_MCANSS_CCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   167     |     6    | DEV_MCAN9_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   174     |     0    | DEV_MCASP0_MCASP_AHCLKX_POUT                                                      | CLK_STATE_READY     | 0               |
    |   174     |     2    | DEV_MCASP0_MCASP_AHCLKR_PIN                                                       | CLK_STATE_READY     | 0               |
    |   174     |     3    | DEV_MCASP0_MCASP_AHCLKR_PIN_PARENT_BOARD_0_HFOSC1_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   174     |     4    | DEV_MCASP0_MCASP_AHCLKR_PIN_PARENT_GLUELOGIC_HFOSC0_CLKOUT                        | CLK_STATE_READY     | 19200000        |
    |   174     |     5    | DEV_MCASP0_MCASP_AHCLKR_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |   174     |     6    | DEV_MCASP0_MCASP_AHCLKR_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK1_OUT                  | CLK_STATE_READY     | 0               |
    |   174     |    11    | DEV_MCASP0_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT               | CLK_STATE_NOT_READY | 0               |
    |   174     |    12    | DEV_MCASP0_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1             | CLK_STATE_NOT_READY | 0               |
    |   174     |    13    | DEV_MCASP0_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2             | CLK_STATE_NOT_READY | 0               |
    |   174     |    14    | DEV_MCASP0_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3             | CLK_STATE_NOT_READY | 0               |
    |   174     |    19    | DEV_MCASP0_MCASP_ACLKR_PIN                                                        | CLK_STATE_READY     | 0               |
    |   174     |    21    | DEV_MCASP0_MCASP_AHCLKX_PIN                                                       | CLK_STATE_READY     | 0               |
    |   174     |    22    | DEV_MCASP0_MCASP_AHCLKX_PIN_PARENT_BOARD_0_HFOSC1_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   174     |    23    | DEV_MCASP0_MCASP_AHCLKX_PIN_PARENT_GLUELOGIC_HFOSC0_CLKOUT                        | CLK_STATE_READY     | 19200000        |
    |   174     |    24    | DEV_MCASP0_MCASP_AHCLKX_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |   174     |    25    | DEV_MCASP0_MCASP_AHCLKX_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK1_OUT                  | CLK_STATE_READY     | 0               |
    |   174     |    30    | DEV_MCASP0_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT               | CLK_STATE_NOT_READY | 0               |
    |   174     |    31    | DEV_MCASP0_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1             | CLK_STATE_NOT_READY | 0               |
    |   174     |    32    | DEV_MCASP0_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2             | CLK_STATE_NOT_READY | 0               |
    |   174     |    33    | DEV_MCASP0_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3             | CLK_STATE_NOT_READY | 0               |
    |   174     |    38    | DEV_MCASP0_MCASP_AHCLKR_POUT                                                      | CLK_STATE_READY     | 0               |
    |   174     |    39    | DEV_MCASP0_MCASP_ACLKX_PIN                                                        | CLK_STATE_READY     | 0               |
    |   174     |    40    | DEV_MCASP0_AUX_CLK        | CLK_STATE_READY     | 196608000       |
    |   174     |    41    | DEV_MCASP0_AUX_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT0_CLK                       | CLK_STATE_READY     | 196608000       |
    |   174     |    42    | DEV_MCASP0_AUX_CLK_PARENT_HSDIV4_16FFT_MAIN_2_HSDIVOUT2_CLK                       | CLK_STATE_READY     | 200000000       |
    |   174     |    45    | DEV_MCASP0_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT                        | CLK_STATE_NOT_READY | 0               |
    |   174     |    46    | DEV_MCASP0_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1                      | CLK_STATE_NOT_READY | 0               |
    |   174     |    47    | DEV_MCASP0_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2                      | CLK_STATE_NOT_READY | 0               |
    |   174     |    48    | DEV_MCASP0_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3                      | CLK_STATE_NOT_READY | 0               |
    |   174     |    49    | DEV_MCASP0_VBUSP_CLK                                                              | CLK_STATE_READY     | 250000000       |
    |   174     |    50    | DEV_MCASP0_MCASP_ACLKR_POUT                                                       | CLK_STATE_READY     | 0               |
    |   174     |    51    | DEV_MCASP0_MCASP_ACLKX_POUT                                                       | CLK_STATE_READY     | 0               |
    |   175     |     0    | DEV_MCASP1_MCASP_AHCLKX_POUT                                                      | CLK_STATE_READY     | 0               |
    |   175     |     2    | DEV_MCASP1_MCASP_AHCLKR_PIN                                                       | CLK_STATE_READY     | 0               |
    |   175     |     3    | DEV_MCASP1_MCASP_AHCLKR_PIN_PARENT_BOARD_0_HFOSC1_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   175     |     4    | DEV_MCASP1_MCASP_AHCLKR_PIN_PARENT_GLUELOGIC_HFOSC0_CLKOUT                        | CLK_STATE_READY     | 19200000        |
    |   175     |     5    | DEV_MCASP1_MCASP_AHCLKR_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |   175     |     6    | DEV_MCASP1_MCASP_AHCLKR_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK1_OUT                  | CLK_STATE_READY     | 0               |
    |   175     |    11    | DEV_MCASP1_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT               | CLK_STATE_NOT_READY | 0               |
    |   175     |    12    | DEV_MCASP1_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1             | CLK_STATE_NOT_READY | 0               |
    |   175     |    13    | DEV_MCASP1_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2             | CLK_STATE_NOT_READY | 0               |
    |   175     |    14    | DEV_MCASP1_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3             | CLK_STATE_NOT_READY | 0               |
    |   175     |    19    | DEV_MCASP1_MCASP_ACLKR_PIN                                                        | CLK_STATE_READY     | 0               |
    |   175     |    21    | DEV_MCASP1_MCASP_AHCLKX_PIN                                                       | CLK_STATE_READY     | 0               |
    |   175     |    22    | DEV_MCASP1_MCASP_AHCLKX_PIN_PARENT_BOARD_0_HFOSC1_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   175     |    23    | DEV_MCASP1_MCASP_AHCLKX_PIN_PARENT_GLUELOGIC_HFOSC0_CLKOUT                        | CLK_STATE_READY     | 19200000        |
    |   175     |    24    | DEV_MCASP1_MCASP_AHCLKX_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |   175     |    25    | DEV_MCASP1_MCASP_AHCLKX_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK1_OUT                  | CLK_STATE_READY     | 0               |
    |   175     |    30    | DEV_MCASP1_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT               | CLK_STATE_NOT_READY | 0               |
    |   175     |    31    | DEV_MCASP1_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1             | CLK_STATE_NOT_READY | 0               |
    |   175     |    32    | DEV_MCASP1_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2             | CLK_STATE_NOT_READY | 0               |
    |   175     |    33    | DEV_MCASP1_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3             | CLK_STATE_NOT_READY | 0               |
    |   175     |    38    | DEV_MCASP1_MCASP_AHCLKR_POUT                                                      | CLK_STATE_READY     | 0               |
    |   175     |    39    | DEV_MCASP1_MCASP_ACLKX_PIN                                                        | CLK_STATE_READY     | 0               |
    |   175     |    40    | DEV_MCASP1_AUX_CLK        | CLK_STATE_READY     | 196608000       |
    |   175     |    41    | DEV_MCASP1_AUX_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT0_CLK                       | CLK_STATE_READY     | 196608000       |
    |   175     |    42    | DEV_MCASP1_AUX_CLK_PARENT_HSDIV4_16FFT_MAIN_2_HSDIVOUT2_CLK                       | CLK_STATE_READY     | 200000000       |
    |   175     |    45    | DEV_MCASP1_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT                        | CLK_STATE_NOT_READY | 0               |
    |   175     |    46    | DEV_MCASP1_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1                      | CLK_STATE_NOT_READY | 0               |
    |   175     |    47    | DEV_MCASP1_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2                      | CLK_STATE_NOT_READY | 0               |
    |   175     |    48    | DEV_MCASP1_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3                      | CLK_STATE_NOT_READY | 0               |
    |   175     |    49    | DEV_MCASP1_VBUSP_CLK                                                              | CLK_STATE_READY     | 250000000       |
    |   175     |    50    | DEV_MCASP1_MCASP_ACLKR_POUT                                                       | CLK_STATE_READY     | 0               |
    |   175     |    51    | DEV_MCASP1_MCASP_ACLKX_POUT                                                       | CLK_STATE_READY     | 0               |
    |   176     |     0    | DEV_MCASP2_MCASP_AHCLKX_POUT                                                      | CLK_STATE_READY     | 0               |
    |   176     |     2    | DEV_MCASP2_MCASP_AHCLKR_PIN                                                       | CLK_STATE_READY     | 0               |
    |   176     |     3    | DEV_MCASP2_MCASP_AHCLKR_PIN_PARENT_BOARD_0_HFOSC1_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   176     |     4    | DEV_MCASP2_MCASP_AHCLKR_PIN_PARENT_GLUELOGIC_HFOSC0_CLKOUT                        | CLK_STATE_READY     | 19200000        |
    |   176     |     5    | DEV_MCASP2_MCASP_AHCLKR_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |   176     |     6    | DEV_MCASP2_MCASP_AHCLKR_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK1_OUT                  | CLK_STATE_READY     | 0               |
    |   176     |    11    | DEV_MCASP2_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT               | CLK_STATE_NOT_READY | 0               |
    |   176     |    12    | DEV_MCASP2_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1             | CLK_STATE_NOT_READY | 0               |
    |   176     |    13    | DEV_MCASP2_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2             | CLK_STATE_NOT_READY | 0               |
    |   176     |    14    | DEV_MCASP2_MCASP_AHCLKR_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3             | CLK_STATE_NOT_READY | 0               |
    |   176     |    19    | DEV_MCASP2_MCASP_ACLKR_PIN                                                        | CLK_STATE_READY     | 0               |
    |   176     |    21    | DEV_MCASP2_MCASP_AHCLKX_PIN                                                       | CLK_STATE_READY     | 0               |
    |   176     |    22    | DEV_MCASP2_MCASP_AHCLKX_PIN_PARENT_BOARD_0_HFOSC1_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   176     |    23    | DEV_MCASP2_MCASP_AHCLKX_PIN_PARENT_GLUELOGIC_HFOSC0_CLKOUT                        | CLK_STATE_READY     | 19200000        |
    |   176     |    24    | DEV_MCASP2_MCASP_AHCLKX_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |   176     |    25    | DEV_MCASP2_MCASP_AHCLKX_PIN_PARENT_BOARD_0_AUDIO_EXT_REFCLK1_OUT                  | CLK_STATE_READY     | 0               |
    |   176     |    30    | DEV_MCASP2_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT               | CLK_STATE_NOT_READY | 0               |
    |   176     |    31    | DEV_MCASP2_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1             | CLK_STATE_NOT_READY | 0               |
    |   176     |    32    | DEV_MCASP2_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2             | CLK_STATE_NOT_READY | 0               |
    |   176     |    33    | DEV_MCASP2_MCASP_AHCLKX_PIN_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3             | CLK_STATE_NOT_READY | 0               |
    |   176     |    38    | DEV_MCASP2_MCASP_AHCLKR_POUT                                                      | CLK_STATE_READY     | 0               |
    |   176     |    39    | DEV_MCASP2_MCASP_ACLKX_PIN                                                        | CLK_STATE_READY     | 0               |
    |   176     |    40    | DEV_MCASP2_AUX_CLK        | CLK_STATE_READY     | 196608000       |
    |   176     |    41    | DEV_MCASP2_AUX_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT0_CLK                       | CLK_STATE_READY     | 196608000       |
    |   176     |    42    | DEV_MCASP2_AUX_CLK_PARENT_HSDIV4_16FFT_MAIN_2_HSDIVOUT2_CLK                       | CLK_STATE_READY     | 200000000       |
    |   176     |    45    | DEV_MCASP2_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT                        | CLK_STATE_NOT_READY | 0               |
    |   176     |    46    | DEV_MCASP2_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_1                      | CLK_STATE_NOT_READY | 0               |
    |   176     |    47    | DEV_MCASP2_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_2                      | CLK_STATE_NOT_READY | 0               |
    |   176     |    48    | DEV_MCASP2_AUX_CLK_PARENT_ATL_MAIN_0_ATL_IO_PORT_ATCLK_OUT_3                      | CLK_STATE_NOT_READY | 0               |
    |   176     |    49    | DEV_MCASP2_VBUSP_CLK                                                              | CLK_STATE_READY     | 250000000       |
    |   176     |    50    | DEV_MCASP2_MCASP_ACLKR_POUT                                                       | CLK_STATE_READY     | 0               |
    |   176     |    51    | DEV_MCASP2_MCASP_ACLKX_POUT                                                       | CLK_STATE_READY     | 0               |
    |   266     |     3    | DEV_MCSPI0_VBUSP_CLK                                                              | CLK_STATE_READY     | 125000000       |
    |   266     |     4    | DEV_MCSPI0_CLKSPIREF_CLK                                                          | CLK_STATE_READY     | 50000000        |
    |   266     |     5    | DEV_MCSPI0_IO_CLKSPIO_CLK                                                         | CLK_STATE_READY     | 0               |
    |   267     |     3    | DEV_MCSPI1_VBUSP_CLK                                                              | CLK_STATE_READY     | 125000000       |
    |   267     |     4    | DEV_MCSPI1_CLKSPIREF_CLK                                                          | CLK_STATE_READY     | 50000000        |
    |   267     |     5    | DEV_MCSPI1_IO_CLKSPIO_CLK                                                         | CLK_STATE_READY     | 0               |
    |   268     |     3    | DEV_MCSPI2_VBUSP_CLK                                                              | CLK_STATE_READY     | 125000000       |
    |   268     |     4    | DEV_MCSPI2_CLKSPIREF_CLK                                                          | CLK_STATE_READY     | 50000000        |
    |   268     |     5    | DEV_MCSPI2_IO_CLKSPIO_CLK                                                         | CLK_STATE_READY     | 0               |
    |   269     |     0    | DEV_MCSPI3_IO_CLKSPII_CLK                                                         | CLK_STATE_NOT_READY | 0               |
    |   269     |     1    | DEV_MCSPI3_IO_CLKSPII_CLK_PARENT_SPI_MAIN_3_IO_CLKSPIO_CLK                        | CLK_STATE_NOT_READY | 0               |
    |   269     |     3    | DEV_MCSPI3_VBUSP_CLK                                                              | CLK_STATE_READY     | 125000000       |
    |   269     |     4    | DEV_MCSPI3_CLKSPIREF_CLK                                                          | CLK_STATE_READY     | 50000000        |
    |   269     |     5    | DEV_MCSPI3_IO_CLKSPIO_CLK                                                         | CLK_STATE_READY     | 0               |
    |   270     |     0    | DEV_MCSPI4_IO_CLKSPII_CLK                                                         | CLK_STATE_NOT_READY | 0               |
    |   270     |     1    | DEV_MCSPI4_VBUSP_CLK                                                              | CLK_STATE_READY     | 125000000       |
    |   270     |     2    | DEV_MCSPI4_CLKSPIREF_CLK                                                          | CLK_STATE_READY     | 50000000        |
    |   270     |     3    | DEV_MCSPI4_IO_CLKSPIO_CLK                                                         | CLK_STATE_READY     | 0               |
    |   271     |     3    | DEV_MCSPI5_VBUSP_CLK                                                              | CLK_STATE_READY     | 125000000       |
    |   271     |     4    | DEV_MCSPI5_CLKSPIREF_CLK                                                          | CLK_STATE_READY     | 50000000        |
    |   271     |     5    | DEV_MCSPI5_IO_CLKSPIO_CLK                                                         | CLK_STATE_READY     | 0               |
    |   272     |     3    | DEV_MCSPI6_VBUSP_CLK                                                              | CLK_STATE_READY     | 125000000       |
    |   272     |     4    | DEV_MCSPI6_CLKSPIREF_CLK                                                          | CLK_STATE_READY     | 50000000        |
    |   272     |     5    | DEV_MCSPI6_IO_CLKSPIO_CLK                                                         | CLK_STATE_READY     | 0               |
    |   273     |     3    | DEV_MCSPI7_VBUSP_CLK                                                              | CLK_STATE_READY     | 125000000       |
    |   273     |     4    | DEV_MCSPI7_CLKSPIREF_CLK                                                          | CLK_STATE_READY     | 50000000        |
    |   273     |     5    | DEV_MCSPI7_IO_CLKSPIO_CLK                                                         | CLK_STATE_READY     | 0               |
    |     0     |     0    | DEV_MCU_ADC0_SYS_CLK                                                              | CLK_STATE_READY     | 500000000       |
    |     0     |     1    | DEV_MCU_ADC0_ADC_CLK                                                              | CLK_STATE_READY     | 19200000        |
    |     0     |     2    | DEV_MCU_ADC0_ADC_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                               | CLK_STATE_READY     | 19200000        |
    |     0     |     3    | DEV_MCU_ADC0_ADC_CLK_PARENT_HSDIV4_16FFT_MCU_1_HSDIVOUT1_CLK                      | CLK_STATE_READY     | 60000000        |
    |     0     |     4    | DEV_MCU_ADC0_ADC_CLK_PARENT_HSDIV1_16FFT_MCU_0_HSDIVOUT1_CLK                      | CLK_STATE_READY     | 58823529        |
    |     0     |     5    | DEV_MCU_ADC0_ADC_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                           | CLK_STATE_READY     | 0               |
    |     0     |     6    | DEV_MCU_ADC0_VBUS_CLK                                                             | CLK_STATE_READY     | 333333333       |
    |     1     |     0    | DEV_MCU_ADC1_SYS_CLK                                                              | CLK_STATE_READY     | 500000000       |
    |     1     |     1    | DEV_MCU_ADC1_ADC_CLK                                                              | CLK_STATE_READY     | 19200000        |
    |     1     |     2    | DEV_MCU_ADC1_ADC_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                               | CLK_STATE_READY     | 19200000        |
    |     1     |     3    | DEV_MCU_ADC1_ADC_CLK_PARENT_HSDIV4_16FFT_MCU_1_HSDIVOUT1_CLK                      | CLK_STATE_READY     | 60000000        |
    |     1     |     4    | DEV_MCU_ADC1_ADC_CLK_PARENT_HSDIV1_16FFT_MCU_0_HSDIVOUT1_CLK                      | CLK_STATE_READY     | 58823529        |
    |     1     |     5    | DEV_MCU_ADC1_ADC_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                           | CLK_STATE_READY     | 0               |
    |     1     |     6    | DEV_MCU_ADC1_VBUS_CLK                                                             | CLK_STATE_READY     | 333333333       |
    |    18     |     0    | DEV_MCU_CPSW0_MDIO_MDCLK_O                                                        | CLK_STATE_READY     | 0               |
    |    18     |     2    | DEV_MCU_CPSW0_CPTS_RFT_CLK                                                        | CLK_STATE_READY     | 500000000       |
    |    18     |     3    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT1_CLK               | CLK_STATE_READY     | 200000000       |
    |    18     |     4    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_POSTDIV2_16FFT_MAIN_0_HSDIVOUT6_CLK             | CLK_STATE_READY     | 200000000       |
    |    18     |     5    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_BOARD_0_MCU_CPTS0_RFT_CLK_OUT                   | CLK_STATE_READY     | 0               |
    |    18     |     6    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                       | CLK_STATE_READY     | 0               |
    |    18     |     7    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |    18     |     8    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                         | CLK_STATE_READY     | 0               |
    |    18     |     9    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN0_TXMCLK              | CLK_STATE_READY     | 0               |
    |    18     |    10    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN1_TXMCLK              | CLK_STATE_READY     | 0               |
    |    18     |    11    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN2_TXMCLK              | CLK_STATE_READY     | 0               |
    |    18     |    12    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN3_TXMCLK              | CLK_STATE_READY     | 0               |
    |    18     |    17    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT1_CLK                | CLK_STATE_READY     | 500000000       |
    |    18     |    18    | DEV_MCU_CPSW0_CPTS_RFT_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK2      | CLK_STATE_READY     | 500000000       |
    |    18     |    20    | DEV_MCU_CPSW0_GMII1_MR_CLK                                                        | CLK_STATE_READY     | 25000000        |
    |    18     |    21    | DEV_MCU_CPSW0_CPPI_CLK_CLK                                                        | CLK_STATE_READY     | 333333333       |
    |    18     |    22    | DEV_MCU_CPSW0_CPTS_GENF0                                                          | CLK_STATE_READY     | 0               |
    |    18     |    24    | DEV_MCU_CPSW0_GMII_RFT_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    18     |    27    | DEV_MCU_CPSW0_GMII1_MT_CLK                                                        | CLK_STATE_READY     | 25000000        |
    |    18     |    28    | DEV_MCU_CPSW0_RGMII1_TXC_O                                                        | CLK_STATE_READY     | 0               |
    |    18     |    29    | DEV_MCU_CPSW0_RMII_MHZ_50_CLK                                                     | CLK_STATE_READY     | 0               |
    |    18     |    30    | DEV_MCU_CPSW0_RGMII_MHZ_5_CLK                                                     | CLK_STATE_READY     | 5000000         |
    |    18     |    31    | DEV_MCU_CPSW0_RGMII1_RXC_I                                                        | CLK_STATE_READY     | 0               |
    |    18     |    32    | DEV_MCU_CPSW0_RGMII_MHZ_250_CLK                                                   | CLK_STATE_READY     | 250000000       |
    |    18     |    33    | DEV_MCU_CPSW0_RGMII_MHZ_50_CLK                                                    | CLK_STATE_READY     | 50000000        |
    |    24     |     0    | DEV_MCU_CPT2_AGGR0_VCLK_CLK                                                       | CLK_STATE_READY     | 333333333       |
    |    44     |     0    | DEV_MCU_DCC0_DCC_INPUT10_CLK                                                      | CLK_STATE_READY     | 333333333       |
    |    44     |     1    | DEV_MCU_DCC0_DCC_INPUT01_CLK                                                      | CLK_STATE_READY     | 83              |
    |    44     |     2    | DEV_MCU_DCC0_DCC_CLKSRC2_CLK                                                      | CLK_STATE_READY     | 80000000        |
    |    44     |     3    | DEV_MCU_DCC0_DCC_CLKSRC7_CLK                                                      | CLK_STATE_READY     | 0               |
    |    44     |     4    | DEV_MCU_DCC0_DCC_CLKSRC0_CLK                                                      | CLK_STATE_READY     | 200000000       |
    |    44     |     5    | DEV_MCU_DCC0_VBUS_CLK                                                             | CLK_STATE_READY     | 166666666       |
    |    44     |     6    | DEV_MCU_DCC0_DCC_CLKSRC4_CLK                                                      | CLK_STATE_READY     | 133333333       |
    |    44     |     7    | DEV_MCU_DCC0_DCC_CLKSRC1_CLK                                                      | CLK_STATE_READY     | 60000000        |
    |    44     |     8    | DEV_MCU_DCC0_DCC_CLKSRC3_CLK                                                      | CLK_STATE_READY     | 96000000        |
    |    44     |     9    | DEV_MCU_DCC0_DCC_INPUT00_CLK                                                      | CLK_STATE_READY     | 19200000        |
    |    44     |    10    | DEV_MCU_DCC0_DCC_CLKSRC5_CLK                                                      | CLK_STATE_READY     | 83              |
    |    44     |    11    | DEV_MCU_DCC0_DCC_CLKSRC6_CLK                                                      | CLK_STATE_READY     | 0               |
    |    44     |    12    | DEV_MCU_DCC0_DCC_INPUT02_CLK                                                      | CLK_STATE_READY     | 12500000        |
    |    45     |     0    | DEV_MCU_DCC1_DCC_INPUT10_CLK                                                      | CLK_STATE_READY     | 250000000       |
    |    45     |     1    | DEV_MCU_DCC1_DCC_INPUT01_CLK                                                      | CLK_STATE_READY     | 0               |
    |    45     |     2    | DEV_MCU_DCC1_DCC_CLKSRC2_CLK                                                      | CLK_STATE_READY     | 80000000        |
    |    45     |     3    | DEV_MCU_DCC1_DCC_CLKSRC7_CLK                                                      | CLK_STATE_READY     | 0               |
    |    45     |     4    | DEV_MCU_DCC1_DCC_CLKSRC0_CLK                                                      | CLK_STATE_READY     | 250000000       |
    |    45     |     5    | DEV_MCU_DCC1_VBUS_CLK                                                             | CLK_STATE_READY     | 166666666       |
    |    45     |     6    | DEV_MCU_DCC1_DCC_CLKSRC4_CLK                                                      | CLK_STATE_READY     | 250000000       |
    |    45     |     7    | DEV_MCU_DCC1_DCC_CLKSRC1_CLK                                                      | CLK_STATE_READY     | 200000000       |
    |    45     |     8    | DEV_MCU_DCC1_DCC_CLKSRC3_CLK                                                      | CLK_STATE_READY     | 166666666       |
    |    45     |     9    | DEV_MCU_DCC1_DCC_INPUT00_CLK                                                      | CLK_STATE_READY     | 19200000        |
    |    45     |    10    | DEV_MCU_DCC1_DCC_CLKSRC5_CLK                                                      | CLK_STATE_READY     | 58823529        |
    |    45     |    11    | DEV_MCU_DCC1_DCC_CLKSRC6_CLK                                                      | CLK_STATE_READY     | 0               |
    |    45     |    12    | DEV_MCU_DCC1_DCC_INPUT02_CLK                                                      | CLK_STATE_READY     | 12500000        |
    |    46     |     0    | DEV_MCU_DCC2_DCC_INPUT10_CLK                                                      | CLK_STATE_READY     | 333333333       |
    |    46     |     1    | DEV_MCU_DCC2_DCC_INPUT01_CLK                                                      | CLK_STATE_READY     | 0               |
    |    46     |     3    | DEV_MCU_DCC2_DCC_CLKSRC7_CLK                                                      | CLK_STATE_READY     | 19200000        |
    |    46     |     4    | DEV_MCU_DCC2_DCC_CLKSRC0_CLK                                                      | CLK_STATE_READY     | 0               |
    |    46     |     5    | DEV_MCU_DCC2_VBUS_CLK                                                             | CLK_STATE_READY     | 166666666       |
    |    46     |     7    | DEV_MCU_DCC2_DCC_CLKSRC1_CLK                                                      | CLK_STATE_READY     | 0               |
    |    46     |     8    | DEV_MCU_DCC2_DCC_CLKSRC3_CLK                                                      | CLK_STATE_READY     | 192000000       |
    |    46     |     9    | DEV_MCU_DCC2_DCC_INPUT00_CLK                                                      | CLK_STATE_READY     | 19200000        |
    |    46     |    11    | DEV_MCU_DCC2_DCC_CLKSRC6_CLK                                                      | CLK_STATE_READY     | 12500000        |
    |    46     |    12    | DEV_MCU_DCC2_DCC_INPUT02_CLK                                                      | CLK_STATE_READY     | 12500000        |
    |    98     |     0    | DEV_MCU_ESM0_CLK        | CLK_STATE_READY     | 166666666       |
    |   101     |     0    | DEV_MCU_FSS0_FSAS_0_GCLK                                                          | CLK_STATE_READY     | 1000000000      |
    |   102     |     0    | DEV_MCU_FSS0_HYPERBUS1P0_0_HPB_OUT_CLK_N                                          | CLK_STATE_READY     | 0               |
    |   102     |     1    | DEV_MCU_FSS0_HYPERBUS1P0_0_HPB_CLKX2_INV_CLK                                      | CLK_STATE_READY     | 166666666       |
    |   102     |     2    | DEV_MCU_FSS0_HYPERBUS1P0_0_HPB_CLKX1_INV_CLK                                      | CLK_STATE_READY     | 83333333        |
    |   102     |     4    | DEV_MCU_FSS0_HYPERBUS1P0_0_CBA_CLK                                                | CLK_STATE_READY     | 1000000000      |
    |   102     |     5    | DEV_MCU_FSS0_HYPERBUS1P0_0_HPB_CLKX2_CLK                                          | CLK_STATE_READY     | 166666666       |
    |   102     |     7    | DEV_MCU_FSS0_HYPERBUS1P0_0_HPB_CLKX1_CLK                                          | CLK_STATE_READY     | 83333333        |
    |   102     |    10    | DEV_MCU_FSS0_HYPERBUS1P0_0_HPB_OUT_CLK_P                                          | CLK_STATE_READY     | 0               |
    |   103     |     0    | DEV_MCU_FSS0_OSPI_0_OSPI_RCLK_CLK                                                 | CLK_STATE_READY     | 166666666       |
    |   103     |     1    | DEV_MCU_FSS0_OSPI_0_OSPI_RCLK_CLK_PARENT_HSDIV4_16FFT_MCU_1_HSDIVOUT4_CLK         | CLK_STATE_READY     | 133333333       |
    |   103     |     2    | DEV_MCU_FSS0_OSPI_0_OSPI_RCLK_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT4_CLK         | CLK_STATE_READY     | 166666666       |
    |   103     |     3    | DEV_MCU_FSS0_OSPI_0_OSPI_HCLK_CLK                                                 | CLK_STATE_READY     | 1000000000      |
    |   103     |     4    | DEV_MCU_FSS0_OSPI_0_OSPI_DQS_CLK                                                  | CLK_STATE_READY     | 0               |
    |   103     |     5    | DEV_MCU_FSS0_OSPI_0_OSPI_ICLK_CLK                                                 | CLK_STATE_READY     | 0               |
    |   103     |     6    | DEV_MCU_FSS0_OSPI_0_OSPI_ICLK_CLK_PARENT_BOARD_0_MCU_OSPI0_DQS_OUT                | CLK_STATE_READY     | 0               |
    |   103     |     7    | DEV_MCU_FSS0_OSPI_0_OSPI_ICLK_CLK_PARENT_FSS_MCU_0_OSPI_0_OSPI_OCLK_CLK           | CLK_STATE_NOT_READY | 0               |
    |   103     |     8    | DEV_MCU_FSS0_OSPI_0_OSPI_PCLK_CLK                                                 | CLK_STATE_READY     | 1000000000      |
    |   103     |     9    | DEV_MCU_FSS0_OSPI_0_OSPI_OCLK_CLK                                                 | CLK_STATE_READY     | 0               |
    |   104     |     0    | DEV_MCU_FSS0_OSPI_1_OSPI_RCLK_CLK                                                 | CLK_STATE_READY     | 133333333       |
    |   104     |     1    | DEV_MCU_FSS0_OSPI_1_OSPI_HCLK_CLK                                                 | CLK_STATE_READY     | 1000000000      |
    |   104     |     7    | DEV_MCU_FSS0_OSPI_1_OSPI_PCLK_CLK                                                 | CLK_STATE_READY     | 1000000000      |
    |   194     |     0    | DEV_MCU_I2C0_PISCL        | CLK_STATE_READY     | 0               |
    |   194     |     1    | DEV_MCU_I2C0_PISYS_CLK                                                            | CLK_STATE_READY     | 96000000        |
    |   194     |     2    | DEV_MCU_I2C0_CLK        | CLK_STATE_READY     | 166666666       |
    |   195     |     0    | DEV_MCU_I2C1_PISCL        | CLK_STATE_READY     | 0               |
    |   195     |     1    | DEV_MCU_I2C1_PISYS_CLK                                                            | CLK_STATE_READY     | 96000000        |
    |   195     |     2    | DEV_MCU_I2C1_CLK        | CLK_STATE_READY     | 166666666       |
    |   195     |     3    | DEV_MCU_I2C1_PORSCL                                                               | CLK_STATE_READY     | 0               |
    |   117     |     0    | DEV_MCU_I3C0_I3C_SCL_DI                                                           | CLK_STATE_READY     | 0               |
    |   117     |     1    | DEV_MCU_I3C0_I3C_SCL_DO                                                           | CLK_STATE_READY     | 0               |
    |   117     |     2    | DEV_MCU_I3C0_I3C_PCLK_CLK                                                         | CLK_STATE_READY     | 166666666       |
    |   117     |     4    | DEV_MCU_I3C0_I3C_SCLK_CLK                                                         | CLK_STATE_READY     | 166666666       |
    |   118     |     2    | DEV_MCU_I3C1_I3C_PCLK_CLK                                                         | CLK_STATE_READY     | 166666666       |
    |   118     |     4    | DEV_MCU_I3C1_I3C_SCLK_CLK                                                         | CLK_STATE_READY     | 166666666       |
    |   172     |     0    | DEV_MCU_MCAN0_MCANSS_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |   172     |     2    | DEV_MCU_MCAN0_MCANSS_CCLK_CLK                                                     | CLK_STATE_READY     | 80000000        |
    |   172     |     3    | DEV_MCU_MCAN0_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT3_CLK             | CLK_STATE_READY     | 80000000        |
    |   172     |     4    | DEV_MCU_MCAN0_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |   172     |     5    | DEV_MCU_MCAN0_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MCU_1_HSDIVOUT2_CLK             | CLK_STATE_READY     | 80000000        |
    |   172     |     6    | DEV_MCU_MCAN0_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                      | CLK_STATE_READY     | 19200000        |
    |   173     |     0    | DEV_MCU_MCAN1_MCANSS_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |   173     |     2    | DEV_MCU_MCAN1_MCANSS_CCLK_CLK                                                     | CLK_STATE_READY     | 80000000        |
    |   173     |     3    | DEV_MCU_MCAN1_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT3_CLK             | CLK_STATE_READY     | 80000000        |
    |   173     |     4    | DEV_MCU_MCAN1_MCANSS_CCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |   173     |     5    | DEV_MCU_MCAN1_MCANSS_CCLK_CLK_PARENT_HSDIV4_16FFT_MCU_1_HSDIVOUT2_CLK             | CLK_STATE_READY     | 80000000        |
    |   173     |     6    | DEV_MCU_MCAN1_MCANSS_CCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                      | CLK_STATE_READY     | 19200000        |
    |   274     |     3    | DEV_MCU_MCSPI0_VBUSP_CLK                                                          | CLK_STATE_READY     | 166666666       |
    |   274     |     4    | DEV_MCU_MCSPI0_CLKSPIREF_CLK                                                      | CLK_STATE_READY     | 50000000        |
    |   274     |     5    | DEV_MCU_MCSPI0_IO_CLKSPIO_CLK                                                     | CLK_STATE_READY     | 0               |
    |   275     |     0    | DEV_MCU_MCSPI1_IO_CLKSPII_CLK                                                     | CLK_STATE_NOT_READY | 0               |
    |   275     |     1    | DEV_MCU_MCSPI1_IO_CLKSPII_CLK_PARENT_SPI_MAIN_3_IO_CLKSPIO_CLK                    | CLK_STATE_NOT_READY | 0               |
    |   275     |     3    | DEV_MCU_MCSPI1_VBUSP_CLK                                                          | CLK_STATE_READY     | 166666666       |
    |   275     |     4    | DEV_MCU_MCSPI1_CLKSPIREF_CLK                                                      | CLK_STATE_READY     | 50000000        |
    |   275     |     5    | DEV_MCU_MCSPI1_IO_CLKSPIO_CLK                                                     | CLK_STATE_READY     | 0               |
    |   276     |     0    | DEV_MCU_MCSPI2_IO_CLKSPII_CLK                                                     | CLK_STATE_READY     | 0               |
    |   276     |     1    | DEV_MCU_MCSPI2_VBUSP_CLK                                                          | CLK_STATE_READY     | 166666666       |
    |   276     |     2    | DEV_MCU_MCSPI2_CLKSPIREF_CLK                                                      | CLK_STATE_READY     | 50000000        |
    |   276     |     3    | DEV_MCU_MCSPI2_IO_CLKSPIO_CLK                                                     | CLK_STATE_READY     | 0               |
    |   237     |     0    | DEV_MCU_NAVSS0_INTR_0_INTR_CLK                                                    | CLK_STATE_READY     | 1000000000      |
    |   238     |     0    | DEV_MCU_NAVSS0_MCRC_0_CLK                                                         | CLK_STATE_READY     | 1000000000      |
    |   302     |     0    | DEV_MCU_NAVSS0_MODSS_VD2CLK                                                       | CLK_STATE_READY     | 1000000000      |
    |   234     |     0    | DEV_MCU_NAVSS0_PROXY0_CLK_CLK                                                     | CLK_STATE_READY     | 1000000000      |
    |   235     |     0    | DEV_MCU_NAVSS0_RINGACC0_SYS_CLK                                                   | CLK_STATE_READY     | 1000000000      |
    |   236     |     0    | DEV_MCU_NAVSS0_UDMAP_0_SYS_CLK                                                    | CLK_STATE_READY     | 1000000000      |
    |   303     |     0    | DEV_MCU_NAVSS0_UDMASS_VD2CLK                                                      | CLK_STATE_READY     | 1000000000      |
    |   233     |     0    | DEV_MCU_NAVSS0_UDMASS_INTA_0_SYS_CLK                                              | CLK_STATE_READY     | 1000000000      |
    |   142     |     1    | DEV_MCU_PBIST0_CLK7_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   142     |     2    | DEV_MCU_PBIST0_CLK3_CLK                                                           | CLK_STATE_READY     | 166666666       |
    |   142     |     3    | DEV_MCU_PBIST0_CLK5_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   142     |     4    | DEV_MCU_PBIST0_CLK1_CLK                                                           | CLK_STATE_READY     | 500000000       |
    |   142     |     5    | DEV_MCU_PBIST0_CLK8_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   142     |     6    | DEV_MCU_PBIST0_CLK6_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   142     |     8    | DEV_MCU_PBIST0_CLK4_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   142     |     9    | DEV_MCU_PBIST0_CLK2_CLK                                                           | CLK_STATE_READY     | 333333333       |
    |   143     |     1    | DEV_MCU_PBIST1_CLK7_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   143     |     2    | DEV_MCU_PBIST1_CLK3_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   143     |     3    | DEV_MCU_PBIST1_CLK5_CLK                                                           | CLK_STATE_READY     | 166666666       |
    |   143     |     4    | DEV_MCU_PBIST1_CLK1_CLK                                                           | CLK_STATE_READY     | 500000000       |
    |   143     |     5    | DEV_MCU_PBIST1_CLK8_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   143     |     6    | DEV_MCU_PBIST1_CLK6_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   143     |     8    | DEV_MCU_PBIST1_CLK4_CLK                                                           | CLK_STATE_READY     | 333333333       |
    |   143     |     9    | DEV_MCU_PBIST1_CLK2_CLK                                                           | CLK_STATE_READY     | 400000000       |
    |   144     |     1    | DEV_MCU_PBIST2_CLK7_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   144     |     2    | DEV_MCU_PBIST2_CLK3_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   144     |     3    | DEV_MCU_PBIST2_CLK5_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   144     |     4    | DEV_MCU_PBIST2_CLK1_CLK                                                           | CLK_STATE_READY     | 1000000000      |
    |   144     |     5    | DEV_MCU_PBIST2_CLK8_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   144     |     6    | DEV_MCU_PBIST2_CLK6_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   144     |     8    | DEV_MCU_PBIST2_CLK4_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   144     |     9    | DEV_MCU_PBIST2_CLK2_CLK                                                           | CLK_STATE_READY     | 83333333        |
    |   250     |     0    | DEV_MCU_R5FSS0_CORE0_CPU_CLK                                                      | CLK_STATE_READY     | 1000000000      |
    |   250     |     1    | DEV_MCU_R5FSS0_CORE0_CPU_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK     | CLK_STATE_READY     | 1000000000      |
    |   250     |     2    | DEV_MCU_R5FSS0_CORE0_CPU_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK3    | CLK_STATE_READY     | 333333333       |
    |   250     |     3    | DEV_MCU_R5FSS0_CORE0_INTERFACE_CLK                                                | CLK_STATE_READY     | 1000000000      |
    |   250     |     4    | DEV_MCU_R5FSS0_CORE0_INTERFACE_PHASE                                              | CLK_STATE_READY     | 333333333       |
    |   251     |     0    | DEV_MCU_R5FSS0_CORE1_CPU_CLK                                                      | CLK_STATE_READY     | 1000000000      |
    |   251     |     1    | DEV_MCU_R5FSS0_CORE1_CPU_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK     | CLK_STATE_READY     | 1000000000      |
    |   251     |     2    | DEV_MCU_R5FSS0_CORE1_CPU_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK3    | CLK_STATE_READY     | 333333333       |
    |   251     |     3    | DEV_MCU_R5FSS0_CORE1_INTERFACE_CLK                                                | CLK_STATE_READY     | 1000000000      |
    |   251     |     4    | DEV_MCU_R5FSS0_CORE1_INTERFACE_PHASE                                              | CLK_STATE_READY     | 333333333       |
    |   262     |     0    | DEV_MCU_RTI0_VBUSP_CLK                                                            | CLK_STATE_READY     | 166666666       |
    |   262     |     1    | DEV_MCU_RTI0_RTI_CLK                                                              | CLK_STATE_READY     | 19200000        |
    |   262     |     2    | DEV_MCU_RTI0_RTI_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                               | CLK_STATE_READY     | 19200000        |
    |   262     |     3    | DEV_MCU_RTI0_RTI_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                             | CLK_STATE_READY     | 0               |
    |   262     |     4    | DEV_MCU_RTI0_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK          | CLK_STATE_READY     | 12500000        |
    |   262     |     5    | DEV_MCU_RTI0_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK            | CLK_STATE_READY     | 32550           |
    |   263     |     0    | DEV_MCU_RTI1_VBUSP_CLK                                                            | CLK_STATE_READY     | 166666666       |
    |   263     |     1    | DEV_MCU_RTI1_RTI_CLK                                                              | CLK_STATE_READY     | 19200000        |
    |   263     |     2    | DEV_MCU_RTI1_RTI_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                               | CLK_STATE_READY     | 19200000        |
    |   263     |     3    | DEV_MCU_RTI1_RTI_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                             | CLK_STATE_READY     | 0               |
    |   263     |     4    | DEV_MCU_RTI1_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK          | CLK_STATE_READY     | 12500000        |
    |   263     |     5    | DEV_MCU_RTI1_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK            | CLK_STATE_READY     | 32550           |
    |   265     |     0    | DEV_MCU_SA2_UL0_X2_CLK                                                            | CLK_STATE_READY     | 333333333       |
    |   265     |     1    | DEV_MCU_SA2_UL0_PKA_IN_CLK                                                        | CLK_STATE_READY     | 400000000       |
    |   265     |     2    | DEV_MCU_SA2_UL0_X1_CLK                                                            | CLK_STATE_READY     | 166666666       |
    |    35     |     0    | DEV_MCU_TIMER0_TIMER_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |    35     |     1    | DEV_MCU_TIMER0_TIMER_TCLK_CLK                                                     | CLK_STATE_READY     | 62500000        |
    |    35     |     2    | DEV_MCU_TIMER0_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                      | CLK_STATE_READY     | 19200000        |
    |    35     |     3    | DEV_MCU_TIMER0_TIMER_TCLK_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK16  | CLK_STATE_READY     | 62500000        |
    |    35     |     4    | DEV_MCU_TIMER0_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK | CLK_STATE_READY     | 12500000        |
    |    35     |     5    | DEV_MCU_TIMER0_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT2_CLK             | CLK_STATE_READY     | 200000000       |
    |    35     |     6    | DEV_MCU_TIMER0_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |    35     |     7    | DEV_MCU_TIMER0_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                    | CLK_STATE_READY     | 0               |
    |    35     |     8    | DEV_MCU_TIMER0_TIMER_TCLK_CLK_PARENT_CPSW_2GUSS_MCU_0_CPTS_GENF0                  | CLK_STATE_READY     | 0               |
    |    35     |     9    | DEV_MCU_TIMER0_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK   | CLK_STATE_READY     | 32550           |
    |    35     |    11    | DEV_MCU_TIMER0_TIMER_PWM                                                          | CLK_STATE_READY     | 0               |
    |    71     |     0    | DEV_MCU_TIMER1_TIMER_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |    71     |     1    | DEV_MCU_TIMER1_TIMER_TCLK_CLK                                                     | CLK_STATE_READY     | 19200000        |
    |    71     |     2    | DEV_MCU_TIMER1_TIMER_TCLK_CLK_PARENT_MCU_TIMER_CLKSEL_OUT1                        | CLK_STATE_READY     | 19200000        |
    |    71     |     3    | DEV_MCU_TIMER1_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MCU_0_TIMER_PWM               | CLK_STATE_READY     | 0               |
    |   308     |     0    | DEV_MCU_TIMER1_CLKSEL_VD_CLK                                                      | CLK_STATE_READY     | 19200000        |
    |   308     |     1    | DEV_MCU_TIMER1_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                       | CLK_STATE_READY     | 19200000        |
    |   308     |     2    | DEV_MCU_TIMER1_CLKSEL_VD_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK16   | CLK_STATE_READY     | 62500000        |
    |   308     |     3    | DEV_MCU_TIMER1_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK  | CLK_STATE_READY     | 12500000        |
    |   308     |     4    | DEV_MCU_TIMER1_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT2_CLK              | CLK_STATE_READY     | 200000000       |
    |   308     |     5    | DEV_MCU_TIMER1_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                   | CLK_STATE_READY     | 0               |
    |   308     |     6    | DEV_MCU_TIMER1_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                     | CLK_STATE_READY     | 0               |
    |   308     |     7    | DEV_MCU_TIMER1_CLKSEL_VD_CLK_PARENT_CPSW_2GUSS_MCU_0_CPTS_GENF0                   | CLK_STATE_READY     | 0               |
    |   308     |     8    | DEV_MCU_TIMER1_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK    | CLK_STATE_READY     | 32550           |
    |    72     |     0    | DEV_MCU_TIMER2_TIMER_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |    72     |     1    | DEV_MCU_TIMER2_TIMER_TCLK_CLK                                                     | CLK_STATE_READY     | 19200000        |
    |    72     |     2    | DEV_MCU_TIMER2_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                      | CLK_STATE_READY     | 19200000        |
    |    72     |     3    | DEV_MCU_TIMER2_TIMER_TCLK_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK16  | CLK_STATE_READY     | 62500000        |
    |    72     |     4    | DEV_MCU_TIMER2_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK | CLK_STATE_READY     | 12500000        |
    |    72     |     5    | DEV_MCU_TIMER2_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT2_CLK             | CLK_STATE_READY     | 200000000       |
    |    72     |     6    | DEV_MCU_TIMER2_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |    72     |     7    | DEV_MCU_TIMER2_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                    | CLK_STATE_READY     | 0               |
    |    72     |     8    | DEV_MCU_TIMER2_TIMER_TCLK_CLK_PARENT_CPSW_2GUSS_MCU_0_CPTS_GENF0                  | CLK_STATE_READY     | 0               |
    |    72     |     9    | DEV_MCU_TIMER2_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK   | CLK_STATE_READY     | 32550           |
    |    72     |    11    | DEV_MCU_TIMER2_TIMER_PWM                                                          | CLK_STATE_READY     | 0               |
    |    73     |     0    | DEV_MCU_TIMER3_TIMER_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |    73     |     1    | DEV_MCU_TIMER3_TIMER_TCLK_CLK                                                     | CLK_STATE_READY     | 19200000        |
    |    73     |     2    | DEV_MCU_TIMER3_TIMER_TCLK_CLK_PARENT_MCU_TIMER_CLKSEL_OUT3                        | CLK_STATE_READY     | 19200000        |
    |    73     |     3    | DEV_MCU_TIMER3_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MCU_2_TIMER_PWM               | CLK_STATE_READY     | 0               |
    |   309     |     0    | DEV_MCU_TIMER3_CLKSEL_VD_CLK                                                      | CLK_STATE_READY     | 19200000        |
    |   309     |     1    | DEV_MCU_TIMER3_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                       | CLK_STATE_READY     | 19200000        |
    |   309     |     2    | DEV_MCU_TIMER3_CLKSEL_VD_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK16   | CLK_STATE_READY     | 62500000        |
    |   309     |     3    | DEV_MCU_TIMER3_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK  | CLK_STATE_READY     | 12500000        |
    |   309     |     4    | DEV_MCU_TIMER3_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT2_CLK              | CLK_STATE_READY     | 200000000       |
    |   309     |     5    | DEV_MCU_TIMER3_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                   | CLK_STATE_READY     | 0               |
    |   309     |     6    | DEV_MCU_TIMER3_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                     | CLK_STATE_READY     | 0               |
    |   309     |     7    | DEV_MCU_TIMER3_CLKSEL_VD_CLK_PARENT_CPSW_2GUSS_MCU_0_CPTS_GENF0                   | CLK_STATE_READY     | 0               |
    |   309     |     8    | DEV_MCU_TIMER3_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK    | CLK_STATE_READY     | 32550           |
    |    74     |     0    | DEV_MCU_TIMER4_TIMER_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |    74     |     1    | DEV_MCU_TIMER4_TIMER_TCLK_CLK                                                     | CLK_STATE_READY     | 19200000        |
    |    74     |     2    | DEV_MCU_TIMER4_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                      | CLK_STATE_READY     | 19200000        |
    |    74     |     3    | DEV_MCU_TIMER4_TIMER_TCLK_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK16  | CLK_STATE_READY     | 62500000        |
    |    74     |     4    | DEV_MCU_TIMER4_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK | CLK_STATE_READY     | 12500000        |
    |    74     |     5    | DEV_MCU_TIMER4_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT2_CLK             | CLK_STATE_READY     | 200000000       |
    |    74     |     6    | DEV_MCU_TIMER4_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |    74     |     7    | DEV_MCU_TIMER4_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                    | CLK_STATE_READY     | 0               |
    |    74     |     8    | DEV_MCU_TIMER4_TIMER_TCLK_CLK_PARENT_CPSW_2GUSS_MCU_0_CPTS_GENF0                  | CLK_STATE_READY     | 0               |
    |    74     |     9    | DEV_MCU_TIMER4_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK   | CLK_STATE_READY     | 32550           |
    |    74     |    11    | DEV_MCU_TIMER4_TIMER_PWM                                                          | CLK_STATE_READY     | 0               |
    |    75     |     0    | DEV_MCU_TIMER5_TIMER_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |    75     |     1    | DEV_MCU_TIMER5_TIMER_TCLK_CLK                                                     | CLK_STATE_READY     | 19200000        |
    |    75     |     2    | DEV_MCU_TIMER5_TIMER_TCLK_CLK_PARENT_MCU_TIMER_CLKSEL_OUT5                        | CLK_STATE_READY     | 19200000        |
    |    75     |     3    | DEV_MCU_TIMER5_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MCU_4_TIMER_PWM               | CLK_STATE_READY     | 0               |
    |   310     |     0    | DEV_MCU_TIMER5_CLKSEL_VD_CLK                                                      | CLK_STATE_READY     | 19200000        |
    |   310     |     1    | DEV_MCU_TIMER5_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                       | CLK_STATE_READY     | 19200000        |
    |   310     |     2    | DEV_MCU_TIMER5_CLKSEL_VD_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK16   | CLK_STATE_READY     | 62500000        |
    |   310     |     3    | DEV_MCU_TIMER5_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK  | CLK_STATE_READY     | 12500000        |
    |   310     |     4    | DEV_MCU_TIMER5_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT2_CLK              | CLK_STATE_READY     | 200000000       |
    |   310     |     5    | DEV_MCU_TIMER5_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                   | CLK_STATE_READY     | 0               |
    |   310     |     6    | DEV_MCU_TIMER5_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                     | CLK_STATE_READY     | 0               |
    |   310     |     7    | DEV_MCU_TIMER5_CLKSEL_VD_CLK_PARENT_CPSW_2GUSS_MCU_0_CPTS_GENF0                   | CLK_STATE_READY     | 0               |
    |   310     |     8    | DEV_MCU_TIMER5_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK    | CLK_STATE_READY     | 32550           |
    |    76     |     0    | DEV_MCU_TIMER6_TIMER_HCLK_CLK                                                     | CLK_STATE_READY     | 333333333       |
    |    76     |     1    | DEV_MCU_TIMER6_TIMER_TCLK_CLK                                                     | CLK_STATE_READY     | 19200000        |
    |    76     |     2    | DEV_MCU_TIMER6_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                      | CLK_STATE_READY     | 19200000        |
    |    76     |     3    | DEV_MCU_TIMER6_TIMER_TCLK_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK16  | CLK_STATE_READY     | 62500000        |
    |    76     |     4    | DEV_MCU_TIMER6_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK | CLK_STATE_READY     | 12500000        |
    |    76     |     5    | DEV_MCU_TIMER6_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT2_CLK             | CLK_STATE_READY     | 200000000       |
    |    76     |     6    | DEV_MCU_TIMER6_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |    76     |     7    | DEV_MCU_TIMER6_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                    | CLK_STATE_READY     | 0               |
    |    76     |     8    | DEV_MCU_TIMER6_TIMER_TCLK_CLK_PARENT_CPSW_2GUSS_MCU_0_CPTS_GENF0                  | CLK_STATE_READY     | 0               |
    |    76     |     9    | DEV_MCU_TIMER6_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK   | CLK_STATE_READY     | 32550           |
    |    76     |    11    | DEV_MCU_TIMER6_TIMER_PWM                                                          | CLK_STATE_READY     | 0               |
    |    77     |     0    | DEV_MCU_TIMER7_TIMER_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |    77     |     1    | DEV_MCU_TIMER7_TIMER_TCLK_CLK                                                     | CLK_STATE_READY     | 19200000        |
    |    77     |     2    | DEV_MCU_TIMER7_TIMER_TCLK_CLK_PARENT_MCU_TIMER_CLKSEL_OUT7                        | CLK_STATE_READY     | 19200000        |
    |    77     |     3    | DEV_MCU_TIMER7_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MCU_6_TIMER_PWM               | CLK_STATE_READY     | 0               |
    |   311     |     0    | DEV_MCU_TIMER7_CLKSEL_VD_CLK                                                      | CLK_STATE_READY     | 19200000        |
    |   311     |     1    | DEV_MCU_TIMER7_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                       | CLK_STATE_READY     | 19200000        |
    |   311     |     2    | DEV_MCU_TIMER7_CLKSEL_VD_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK16   | CLK_STATE_READY     | 62500000        |
    |   311     |     3    | DEV_MCU_TIMER7_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK  | CLK_STATE_READY     | 12500000        |
    |   311     |     4    | DEV_MCU_TIMER7_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT2_CLK              | CLK_STATE_READY     | 200000000       |
    |   311     |     5    | DEV_MCU_TIMER7_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                   | CLK_STATE_READY     | 0               |
    |   311     |     6    | DEV_MCU_TIMER7_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                     | CLK_STATE_READY     | 0               |
    |   311     |     7    | DEV_MCU_TIMER7_CLKSEL_VD_CLK_PARENT_CPSW_2GUSS_MCU_0_CPTS_GENF0                   | CLK_STATE_READY     | 0               |
    |   311     |     8    | DEV_MCU_TIMER7_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK    | CLK_STATE_READY     | 32550           |
    |    78     |     0    | DEV_MCU_TIMER8_TIMER_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |    78     |     1    | DEV_MCU_TIMER8_TIMER_TCLK_CLK                                                     | CLK_STATE_READY     | 19200000        |
    |    78     |     2    | DEV_MCU_TIMER8_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                      | CLK_STATE_READY     | 19200000        |
    |    78     |     3    | DEV_MCU_TIMER8_TIMER_TCLK_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK16  | CLK_STATE_READY     | 62500000        |
    |    78     |     4    | DEV_MCU_TIMER8_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK | CLK_STATE_READY     | 12500000        |
    |    78     |     5    | DEV_MCU_TIMER8_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT2_CLK             | CLK_STATE_READY     | 200000000       |
    |    78     |     6    | DEV_MCU_TIMER8_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                  | CLK_STATE_READY     | 0               |
    |    78     |     7    | DEV_MCU_TIMER8_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                    | CLK_STATE_READY     | 0               |
    |    78     |     8    | DEV_MCU_TIMER8_TIMER_TCLK_CLK_PARENT_CPSW_2GUSS_MCU_0_CPTS_GENF0                  | CLK_STATE_READY     | 0               |
    |    78     |     9    | DEV_MCU_TIMER8_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK   | CLK_STATE_READY     | 32550           |
    |    78     |    11    | DEV_MCU_TIMER8_TIMER_PWM                                                          | CLK_STATE_READY     | 0               |
    |    79     |     0    | DEV_MCU_TIMER9_TIMER_HCLK_CLK                                                     | CLK_STATE_READY     | 166666666       |
    |    79     |     1    | DEV_MCU_TIMER9_TIMER_TCLK_CLK                                                     | CLK_STATE_READY     | 62500000        |
    |    79     |     2    | DEV_MCU_TIMER9_TIMER_TCLK_CLK_PARENT_MCU_TIMER_CLKSEL_OUT9                        | CLK_STATE_READY     | 62500000        |
    |    79     |     3    | DEV_MCU_TIMER9_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MCU_8_TIMER_PWM               | CLK_STATE_READY     | 0               |
    |   312     |     0    | DEV_MCU_TIMER9_CLKSEL_VD_CLK                                                      | CLK_STATE_READY     | 62500000        |
    |   312     |     1    | DEV_MCU_TIMER9_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                       | CLK_STATE_READY     | 19200000        |
    |   312     |     2    | DEV_MCU_TIMER9_CLKSEL_VD_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK16   | CLK_STATE_READY     | 62500000        |
    |   312     |     3    | DEV_MCU_TIMER9_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK  | CLK_STATE_READY     | 12500000        |
    |   312     |     4    | DEV_MCU_TIMER9_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT2_CLK              | CLK_STATE_READY     | 200000000       |
    |   312     |     5    | DEV_MCU_TIMER9_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                   | CLK_STATE_READY     | 0               |
    |   312     |     6    | DEV_MCU_TIMER9_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                     | CLK_STATE_READY     | 0               |
    |   312     |     7    | DEV_MCU_TIMER9_CLKSEL_VD_CLK_PARENT_CPSW_2GUSS_MCU_0_CPTS_GENF0                   | CLK_STATE_READY     | 0               |
    |   312     |     8    | DEV_MCU_TIMER9_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK    | CLK_STATE_READY     | 32550           |
    |   149     |     2    | DEV_MCU_UART0_FCLK_CLK                                                            | CLK_STATE_READY     | 96000000        |
    |   149     |     3    | DEV_MCU_UART0_FCLK_CLK_PARENT_HSDIV4_16FFT_MCU_1_HSDIVOUT3_CLK                    | CLK_STATE_READY     | 96000000        |
    |   149     |     4    | DEV_MCU_UART0_FCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_1_HSDIVOUT5_CLK                 | CLK_STATE_READY     | 192000000       |
    |   149     |     5    | DEV_MCU_UART0_VBUSP_CLK                                                           | CLK_STATE_READY     | 166666666       |
    |    91     |     0    | DEV_MMCSD0_EMMCSS_VBUS_CLK                                                        | CLK_STATE_READY     | 250000000       |
    |    91     |     3    | DEV_MMCSD0_EMMCSS_XIN_CLK                                                         | CLK_STATE_READY     | 200000000       |
    |    91     |     4    | DEV_MMCSD0_EMMCSS_XIN_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT2_CLK                | CLK_STATE_READY     | 200000000       |
    |    91     |     5    | DEV_MMCSD0_EMMCSS_XIN_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT2_CLK                | CLK_STATE_READY     | 192000000       |
    |    91     |     6    | DEV_MMCSD0_EMMCSS_XIN_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT2_CLK                | CLK_STATE_READY     | 200000000       |
    |    91     |     7    | DEV_MMCSD0_EMMCSS_XIN_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT2_CLK_DUP0           | CLK_STATE_READY     | 200000000       |
    |    92     |     0    | DEV_MMCSD1_EMMCSDSS_IO_CLK_I                                                      | CLK_STATE_READY     | 0               |
    |    92     |     1    | DEV_MMCSD1_EMMCSDSS_VBUS_CLK                                                      | CLK_STATE_READY     | 250000000       |
    |    92     |     2    | DEV_MMCSD1_EMMCSDSS_XIN_CLK                                                       | CLK_STATE_READY     | 200000000       |
    |    92     |     3    | DEV_MMCSD1_EMMCSDSS_XIN_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT2_CLK              | CLK_STATE_READY     | 200000000       |
    |    92     |     4    | DEV_MMCSD1_EMMCSDSS_XIN_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT2_CLK              | CLK_STATE_READY     | 192000000       |
    |    92     |     5    | DEV_MMCSD1_EMMCSDSS_XIN_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT2_CLK              | CLK_STATE_READY     | 200000000       |
    |    92     |     6    | DEV_MMCSD1_EMMCSDSS_XIN_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT2_CLK_DUP0         | CLK_STATE_READY     | 200000000       |
    |    92     |     7    | DEV_MMCSD1_EMMCSDSS_IO_CLK_O                                                      | CLK_STATE_READY     | 0               |
    |   199     |     0    | DEV_NAVSS0_CPTS0_GENF2                                                            | CLK_STATE_READY     | 0               |
    |   199     |     1    | DEV_NAVSS0_CPTS0_GENF3                                                            | CLK_STATE_READY     | 0               |
    |   199     |     2    | DEV_NAVSS0_CPTS0_GENF4                                                            | CLK_STATE_READY     | 0               |
    |   201     |     0    | DEV_NAVSS0_CPTS_0_VBUSP_GCLK                                                      | CLK_STATE_READY     | 500000000       |
    |   201     |     1    | DEV_NAVSS0_CPTS_0_RCLK                                                            | CLK_STATE_READY     | 200000000       |
    |   201     |     2    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT1_CLK                   | CLK_STATE_READY     | 200000000       |
    |   201     |     3    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_POSTDIV2_16FFT_MAIN_0_HSDIVOUT6_CLK                 | CLK_STATE_READY     | 200000000       |
    |   201     |     4    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_BOARD_0_MCU_CPTS0_RFT_CLK_OUT                       | CLK_STATE_READY     | 0               |
    |   201     |     5    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   201     |     6    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                         | CLK_STATE_READY     | 0               |
    |   201     |     7    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                             | CLK_STATE_READY     | 0               |
    |   201     |     8    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN0_TXMCLK                  | CLK_STATE_READY     | 0               |
    |   201     |     9    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN1_TXMCLK                  | CLK_STATE_READY     | 0               |
    |   201     |    10    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN2_TXMCLK                  | CLK_STATE_READY     | 0               |
    |   201     |    11    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN3_TXMCLK                  | CLK_STATE_READY     | 0               |
    |   201     |    16    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT1_CLK                    | CLK_STATE_READY     | 500000000       |
    |   201     |    17    | DEV_NAVSS0_CPTS_0_RCLK_PARENT_K3_PLL_CTRL_WRAP_MAIN_0_CHIP_DIV1_CLK_CLK           | CLK_STATE_READY     | 500000000       |
    |   201     |    20    | DEV_NAVSS0_CPTS_0_TS_GENF0                                                        | CLK_STATE_READY     | 0               |
    |   201     |    21    | DEV_NAVSS0_CPTS_0_TS_GENF1                                                        | CLK_STATE_READY     | 0               |
    |   206     |     0    | DEV_NAVSS0_DTI_0_CLK_CLK                                                          | CLK_STATE_READY     | 500000000       |
    |   213     |     0    | DEV_NAVSS0_INTR_ROUTER_0_INTR_CLK                                                 | CLK_STATE_READY     | 500000000       |
    |   214     |     0    | DEV_NAVSS0_MAILBOX_0_VCLK_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   215     |     0    | DEV_NAVSS0_MAILBOX_1_VCLK_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   224     |     0    | DEV_NAVSS0_MAILBOX_10_VCLK_CLK                                                    | CLK_STATE_READY     | 500000000       |
    |   225     |     0    | DEV_NAVSS0_MAILBOX_11_VCLK_CLK                                                    | CLK_STATE_READY     | 500000000       |
    |   216     |     0    | DEV_NAVSS0_MAILBOX_2_VCLK_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   217     |     0    | DEV_NAVSS0_MAILBOX_3_VCLK_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   218     |     0    | DEV_NAVSS0_MAILBOX_4_VCLK_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   219     |     0    | DEV_NAVSS0_MAILBOX_5_VCLK_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   220     |     0    | DEV_NAVSS0_MAILBOX_6_VCLK_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   221     |     0    | DEV_NAVSS0_MAILBOX_7_VCLK_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   222     |     0    | DEV_NAVSS0_MAILBOX_8_VCLK_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   223     |     0    | DEV_NAVSS0_MAILBOX_9_VCLK_CLK                                                     | CLK_STATE_READY     | 500000000       |
    |   227     |     0    | DEV_NAVSS0_MCRC_0_CLK                                                             | CLK_STATE_READY     | 500000000       |
    |   299     |     0    | DEV_NAVSS0_MODSS_VD2CLK                                                           | CLK_STATE_READY     | 500000000       |
    |   207     |     0    | DEV_NAVSS0_MODSS_INTA_0_SYS_CLK                                                   | CLK_STATE_READY     | 500000000       |
    |   208     |     0    | DEV_NAVSS0_MODSS_INTA_1_SYS_CLK                                                   | CLK_STATE_READY     | 500000000       |
    |   210     |     0    | DEV_NAVSS0_PROXY_0_CLK_CLK                                                        | CLK_STATE_READY     | 500000000       |
    |   211     |     0    | DEV_NAVSS0_RINGACC_0_SYS_CLK                                                      | CLK_STATE_READY     | 500000000       |
    |   226     |     0    | DEV_NAVSS0_SPINLOCK_0_CLK                                                         | CLK_STATE_READY     | 500000000       |
    |   228     |     0    | DEV_NAVSS0_TBU_0_CLK_CLK                                                          | CLK_STATE_READY     | 500000000       |
    |   230     |     0    | DEV_NAVSS0_TIMERMGR_0_VCLK_CLK                                                    | CLK_STATE_READY     | 500000000       |
    |   230     |     1    | DEV_NAVSS0_TIMERMGR_0_EON_TICK_EVT                                                | CLK_STATE_READY     | 0               |
    |   231     |     0    | DEV_NAVSS0_TIMERMGR_1_VCLK_CLK                                                    | CLK_STATE_READY     | 500000000       |
    |   231     |     1    | DEV_NAVSS0_TIMERMGR_1_EON_TICK_EVT                                                | CLK_STATE_READY     | 0               |
    |   212     |     0    | DEV_NAVSS0_UDMAP_0_SYS_CLK                                                        | CLK_STATE_READY     | 500000000       |
    |   300     |     0    | DEV_NAVSS0_UDMASS_VD2CLK                                                          | CLK_STATE_READY     | 500000000       |
    |   209     |     0    | DEV_NAVSS0_UDMASS_INTA_0_SYS_CLK                                                  | CLK_STATE_READY     | 500000000       |
    |   301     |     0    | DEV_NAVSS0_VIRTSS_VD2CLK                                                          | CLK_STATE_READY     | 500000000       |
    |   139     |     1    | DEV_PBIST0_CLK7_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   139     |     2    | DEV_PBIST0_CLK3_CLK                                                               | CLK_STATE_READY     | 250000000       |
    |   139     |     3    | DEV_PBIST0_CLK5_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   139     |     4    | DEV_PBIST0_CLK1_CLK                                                               | CLK_STATE_READY     | 500000000       |
    |   139     |     5    | DEV_PBIST0_CLK8_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   139     |     6    | DEV_PBIST0_CLK6_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   139     |     8    | DEV_PBIST0_CLK4_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   139     |     9    | DEV_PBIST0_CLK2_CLK                                                               | CLK_STATE_READY     | 250000000       |
    |   140     |     1    | DEV_PBIST1_CLK7_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   140     |     2    | DEV_PBIST1_CLK3_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   140     |     3    | DEV_PBIST1_CLK5_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   140     |     4    | DEV_PBIST1_CLK1_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   140     |     5    | DEV_PBIST1_CLK8_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   140     |     6    | DEV_PBIST1_CLK6_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   140     |     8    | DEV_PBIST1_CLK4_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   140     |     9    | DEV_PBIST1_CLK2_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   141     |     1    | DEV_PBIST2_CLK7_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   141     |     2    | DEV_PBIST2_CLK3_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   141     |     3    | DEV_PBIST2_CLK5_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   141     |     4    | DEV_PBIST2_CLK1_CLK                                                               | CLK_STATE_READY     | 1000000000      |
    |   141     |     5    | DEV_PBIST2_CLK8_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   141     |     6    | DEV_PBIST2_CLK6_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   141     |     8    | DEV_PBIST2_CLK4_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   141     |     9    | DEV_PBIST2_CLK2_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   240     |     0    | DEV_PCIE1_PCIE_LANE0_TXCLK                                                        | CLK_STATE_READY     | 0               |
    |   240     |     1    | DEV_PCIE1_PCIE_LANE1_TXMCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |     2    | DEV_PCIE1_PCIE_LANE0_TXMCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |     3    | DEV_PCIE1_PCIE_LANE0_TXFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |     4    | DEV_PCIE1_PCIE_PM_CLK                                                             | CLK_STATE_READY     | 12500000        |
    |   240     |     5    | DEV_PCIE1_PCIE_LANE3_TXMCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |     6    | DEV_PCIE1_PCIE_CBA_CLK                                                            | CLK_STATE_READY     | 250000000       |
    |   240     |     7    | DEV_PCIE1_PCIE_LANE1_REFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |     8    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK                                                      | CLK_STATE_READY     | 200000000       |
    |   240     |     9    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT1_CLK             | CLK_STATE_READY     | 200000000       |
    |   240     |    10    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_0_HSDIVOUT6_CLK           | CLK_STATE_READY     | 200000000       |
    |   240     |    11    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_BOARD_0_MCU_CPTS0_RFT_CLK_OUT                 | CLK_STATE_READY     | 0               |
    |   240     |    12    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                     | CLK_STATE_READY     | 0               |
    |   240     |    13    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                   | CLK_STATE_READY     | 0               |
    |   240     |    14    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                       | CLK_STATE_READY     | 0               |
    |   240     |    15    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN0_TXMCLK            | CLK_STATE_READY     | 0               |
    |   240     |    16    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN1_TXMCLK            | CLK_STATE_READY     | 0               |
    |   240     |    17    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN2_TXMCLK            | CLK_STATE_READY     | 0               |
    |   240     |    18    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP2_LN3_TXMCLK            | CLK_STATE_READY     | 0               |
    |   240     |    23    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_HSDIV4_16FFT_MCU_2_HSDIVOUT1_CLK              | CLK_STATE_READY     | 500000000       |
    |   240     |    24    | DEV_PCIE1_PCIE_CPTS_RCLK_CLK_PARENT_K3_PLL_CTRL_WRAP_MAIN_0_CHIP_DIV1_CLK_CLK     | CLK_STATE_READY     | 500000000       |
    |   240     |    25    | DEV_PCIE1_PCIE_LANE1_RXFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    27    | DEV_PCIE1_PCIE_LANE2_RXCLK                                                        | CLK_STATE_READY     | 0               |
    |   240     |    28    | DEV_PCIE1_PCIE_LANE2_TXMCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    29    | DEV_PCIE1_PCIE_LANE1_TXCLK                                                        | CLK_STATE_READY     | 0               |
    |   240     |    30    | DEV_PCIE1_PCIE_LANE3_TXFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    31    | DEV_PCIE1_PCIE_LANE2_TXFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    32    | DEV_PCIE1_PCIE_LANE1_RXCLK                                                        | CLK_STATE_READY     | 0               |
    |   240     |    33    | DEV_PCIE1_PCIE_LANE2_TXCLK                                                        | CLK_STATE_READY     | 0               |
    |   240     |    34    | DEV_PCIE1_PCIE_LANE1_TXFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    35    | DEV_PCIE1_PCIE_LANE0_REFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    36    | DEV_PCIE1_PCIE_LANE3_RXFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    37    | DEV_PCIE1_PCIE_LANE2_RXFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    38    | DEV_PCIE1_PCIE_LANE3_RXCLK                                                        | CLK_STATE_READY     | 0               |
    |   240     |    39    | DEV_PCIE1_PCIE_LANE3_REFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    40    | DEV_PCIE1_PCIE_LANE2_REFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    41    | DEV_PCIE1_PCIE_LANE0_RXFCLK                                                       | CLK_STATE_READY     | 0               |
    |   240     |    42    | DEV_PCIE1_PCIE_LANE3_TXCLK                                                        | CLK_STATE_READY     | 0               |
    |   240     |    43    | DEV_PCIE1_PCIE_LANE0_RXCLK                                                        | CLK_STATE_READY     | 0               |
    |   133     |     0    | DEV_PSC0_SLOW_CLK        | CLK_STATE_READY     | 20833333        |
    |   133     |     1    | DEV_PSC0_CLK        | CLK_STATE_READY     | 125000000       |
    |   245     |     0    | DEV_R5FSS0_CORE0_CPU_CLK                                                          | CLK_STATE_READY     | 1000000000      |
    |   245     |     1    | DEV_R5FSS0_CORE0_INTERFACE_CLK                                                    | CLK_STATE_READY     | 1000000000      |
    |   245     |     2    | DEV_R5FSS0_CORE0_INTERFACE_PHASE                                                  | CLK_STATE_READY     | 1000000000      |
    |   246     |     0    | DEV_R5FSS0_CORE1_CPU_CLK                                                          | CLK_STATE_READY     | 1000000000      |
    |   246     |     1    | DEV_R5FSS0_CORE1_INTERFACE_CLK                                                    | CLK_STATE_READY     | 1000000000      |
    |   246     |     2    | DEV_R5FSS0_CORE1_INTERFACE_PHASE                                                  | CLK_STATE_READY     | 1000000000      |
    |   252     |     0    | DEV_RTI0_VBUSP_CLK        | CLK_STATE_READY     | 125000000       |
    |   252     |     1    | DEV_RTI0_RTI_CLK        | CLK_STATE_READY     | 32550           |
    |   252     |     2    | DEV_RTI0_RTI_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                                   | CLK_STATE_READY     | 19200000        |
    |   252     |     3    | DEV_RTI0_RTI_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                                 | CLK_STATE_READY     | 0               |
    |   252     |     4    | DEV_RTI0_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK              | CLK_STATE_READY     | 12500000        |
    |   252     |     5    | DEV_RTI0_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK                | CLK_STATE_READY     | 32550           |
    |   252     |     6    | DEV_RTI0_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                                    | CLK_STATE_READY     | 0               |
    |   252     |     7    | DEV_RTI0_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP0                               | CLK_STATE_READY     | 0               |
    |   252     |     8    | DEV_RTI0_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP1                               | CLK_STATE_READY     | 0               |
    |   252     |     9    | DEV_RTI0_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP2                               | CLK_STATE_READY     | 0               |
    |   253     |     0    | DEV_RTI1_VBUSP_CLK        | CLK_STATE_READY     | 125000000       |
    |   253     |     1    | DEV_RTI1_RTI_CLK        | CLK_STATE_READY     | 32550           |
    |   253     |     2    | DEV_RTI1_RTI_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                                   | CLK_STATE_READY     | 19200000        |
    |   253     |     3    | DEV_RTI1_RTI_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                                 | CLK_STATE_READY     | 0               |
    |   253     |     4    | DEV_RTI1_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK              | CLK_STATE_READY     | 12500000        |
    |   253     |     5    | DEV_RTI1_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK                | CLK_STATE_READY     | 32550           |
    |   253     |     6    | DEV_RTI1_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                                    | CLK_STATE_READY     | 0               |
    |   253     |     7    | DEV_RTI1_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP0                               | CLK_STATE_READY     | 0               |
    |   253     |     8    | DEV_RTI1_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP1                               | CLK_STATE_READY     | 0               |
    |   253     |     9    | DEV_RTI1_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP2                               | CLK_STATE_READY     | 0               |
    |   258     |     0    | DEV_RTI28_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   258     |     1    | DEV_RTI28_RTI_CLK        | CLK_STATE_READY     | 19200000        |
    |   258     |     2    | DEV_RTI28_RTI_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                                  | CLK_STATE_READY     | 19200000        |
    |   258     |     3    | DEV_RTI28_RTI_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                                | CLK_STATE_READY     | 0               |
    |   258     |     4    | DEV_RTI28_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK             | CLK_STATE_READY     | 12500000        |
    |   258     |     5    | DEV_RTI28_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK               | CLK_STATE_READY     | 32550           |
    |   258     |     6    | DEV_RTI28_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                                   | CLK_STATE_READY     | 0               |
    |   258     |     7    | DEV_RTI28_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP0                              | CLK_STATE_READY     | 0               |
    |   258     |     8    | DEV_RTI28_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP1                              | CLK_STATE_READY     | 0               |
    |   258     |     9    | DEV_RTI28_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP2                              | CLK_STATE_READY     | 0               |
    |   259     |     0    | DEV_RTI29_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   259     |     1    | DEV_RTI29_RTI_CLK        | CLK_STATE_READY     | 19200000        |
    |   259     |     2    | DEV_RTI29_RTI_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                                  | CLK_STATE_READY     | 19200000        |
    |   259     |     3    | DEV_RTI29_RTI_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                                | CLK_STATE_READY     | 0               |
    |   259     |     4    | DEV_RTI29_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK             | CLK_STATE_READY     | 12500000        |
    |   259     |     5    | DEV_RTI29_RTI_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK               | CLK_STATE_READY     | 32550           |
    |   259     |     6    | DEV_RTI29_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                                   | CLK_STATE_READY     | 0               |
    |   259     |     7    | DEV_RTI29_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP0                              | CLK_STATE_READY     | 0               |
    |   259     |     8    | DEV_RTI29_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP1                              | CLK_STATE_READY     | 0               |
    |   259     |     9    | DEV_RTI29_RTI_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT_DUP2                              | CLK_STATE_READY     | 0               |
    |   292     |     1    | DEV_SERDES_10G1_IP3_LN1_TXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |     3    | DEV_SERDES_10G1_IP2_LN2_REFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |     4    | DEV_SERDES_10G1_IP1_LN0_TXMCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |     6    | DEV_SERDES_10G1_IP3_LN3_RXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |     9    | DEV_SERDES_10G1_IP2_LN2_RXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    10    | DEV_SERDES_10G1_IP1_LN0_TXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    11    | DEV_SERDES_10G1_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   292     |    13    | DEV_SERDES_10G1_IP1_LN3_RXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    14    | DEV_SERDES_10G1_IP1_LN1_TXMCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    15    | DEV_SERDES_10G1_IP2_LN0_TXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    16    | DEV_SERDES_10G1_IP2_LN2_TXMCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    19    | DEV_SERDES_10G1_IP3_LN1_TXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    21    | DEV_SERDES_10G1_IP2_LN3_RXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    22    | DEV_SERDES_10G1_IP1_LN2_TXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    24    | DEV_SERDES_10G1_IP2_LN1_RXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    25    | DEV_SERDES_10G1_IP2_LN1_TXCLK                                                     | CLK_STATE_NOT_READY | 0               |
    |   292     |    29    | DEV_SERDES_10G1_IP1_LN2_TXMCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    32    | DEV_SERDES_10G1_IP2_LN1_TXMCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    33    | DEV_SERDES_10G1_IP2_LN1_TXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    34    | DEV_SERDES_10G1_IP1_LN1_TXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    38    | DEV_SERDES_10G1_IP1_LN2_RXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    40    | DEV_SERDES_10G1_IP2_LN1_REFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    41    | DEV_SERDES_10G1_IP2_LN0_TXMCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    42    | DEV_SERDES_10G1_IP2_LN3_RXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    43    | DEV_SERDES_10G1_IP2_LN2_TXCLK                                                     | CLK_STATE_NOT_READY | 0               |
    |   292     |    44    | DEV_SERDES_10G1_IP2_LN2_RXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    45    | DEV_SERDES_10G1_IP1_LN1_RXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    49    | DEV_SERDES_10G1_IP1_LN0_RXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    52    | DEV_SERDES_10G1_IP1_LN1_RXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    55    | DEV_SERDES_10G1_IP1_LN0_RXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    56    | DEV_SERDES_10G1_IP3_LN3_TXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    59    | DEV_SERDES_10G1_IP2_LN3_REFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    61    | DEV_SERDES_10G1_IP2_LN0_TXCLK                                                     | CLK_STATE_NOT_READY | 0               |
    |   292     |    62    | DEV_SERDES_10G1_IP2_LN3_TXMCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    63    | DEV_SERDES_10G1_IP1_LN1_REFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    65    | DEV_SERDES_10G1_IP1_LN3_TXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    66    | DEV_SERDES_10G1_IP3_LN1_TXMCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    67    | DEV_SERDES_10G1_IP2_LN2_TXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    73    | DEV_SERDES_10G1_IP3_LN1_RXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    74    | DEV_SERDES_10G1_IP3_LN1_REFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    75    | DEV_SERDES_10G1_IP1_LN3_REFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    77    | DEV_SERDES_10G1_IP1_LN0_REFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    80    | DEV_SERDES_10G1_IP1_LN2_REFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    81    | DEV_SERDES_10G1_IP2_LN0_REFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    82    | DEV_SERDES_10G1_IP2_LN0_RXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |    85    | DEV_SERDES_10G1_CORE_REF_CLK                                                      | CLK_STATE_READY     | 100000000       |
    |   292     |    86    | DEV_SERDES_10G1_CORE_REF_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                       | CLK_STATE_READY     | 19200000        |
    |   292     |    87    | DEV_SERDES_10G1_CORE_REF_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |   292     |    88    | DEV_SERDES_10G1_CORE_REF_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT4_CLK             | CLK_STATE_READY     | 125000000       |
    |   292     |    89    | DEV_SERDES_10G1_CORE_REF_CLK_PARENT_HSDIV4_16FFT_MAIN_2_HSDIVOUT4_CLK             | CLK_STATE_READY     | 100000000       |
    |   292     |    92    | DEV_SERDES_10G1_IP1_LN3_TXMCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    95    | DEV_SERDES_10G1_IP2_LN3_TXCLK                                                     | CLK_STATE_NOT_READY | 0               |
    |   292     |    96    | DEV_SERDES_10G1_IP3_LN3_RXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |    98    | DEV_SERDES_10G1_IP3_LN3_REFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |   100    | DEV_SERDES_10G1_IP2_LN1_RXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |   102    | DEV_SERDES_10G1_IP3_LN1_RXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |   104    | DEV_SERDES_10G1_IP1_LN1_TXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |   107    | DEV_SERDES_10G1_IP3_LN3_TXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |   108    | DEV_SERDES_10G1_IP1_LN3_TXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |   109    | DEV_SERDES_10G1_IP2_LN3_TXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |   111    | DEV_SERDES_10G1_IP1_LN0_TXCLK                                                     | CLK_STATE_READY     | 0               |
    |   292     |   112    | DEV_SERDES_10G1_IP2_LN0_RXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |   113    | DEV_SERDES_10G1_IP1_LN2_RXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |   118    | DEV_SERDES_10G1_IP1_LN2_TXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |   124    | DEV_SERDES_10G1_IP1_LN3_RXFCLK                                                    | CLK_STATE_READY     | 0               |
    |   292     |   126    | DEV_SERDES_10G1_IP3_LN3_TXMCLK                                                    | CLK_STATE_READY     | 0               |
    |    29     |     0    | DEV_STM0_CORE_CLK        | CLK_STATE_READY     | 250000000       |
    |    29     |     1    | DEV_STM0_VBUSP_CLK        | CLK_STATE_READY     | 125000000       |
    |    29     |     2    | DEV_STM0_ATB_CLK        | CLK_STATE_READY     | 250000000       |
    |    49     |     0    | DEV_TIMER0_TIMER_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |    49     |     1    | DEV_TIMER0_TIMER_TCLK_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    49     |     2    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |    49     |     3    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |    49     |     4    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                | CLK_STATE_READY     | 200000000       |
    |    49     |     5    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK     | CLK_STATE_READY     | 12500000        |
    |    49     |     6    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                | CLK_STATE_READY     | 200000000       |
    |    49     |     7    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |    49     |     8    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                          | CLK_STATE_READY     | 0               |
    |    49     |     9    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                        | CLK_STATE_READY     | 0               |
    |    49     |    10    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |    49     |    11    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                | CLK_STATE_READY     | 192000000       |
    |    49     |    12    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK              | CLK_STATE_READY     | 225000000       |
    |    49     |    13    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                | CLK_STATE_READY     | 196608000       |
    |    49     |    14    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                   | CLK_STATE_READY     | 0               |
    |    49     |    15    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                   | CLK_STATE_READY     | 0               |
    |    49     |    16    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                     | CLK_STATE_READY     | 0               |
    |    49     |    17    | DEV_TIMER0_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                   | CLK_STATE_READY     | 0               |
    |    49     |    26    | DEV_TIMER0_TIMER_PWM                                                              | CLK_STATE_READY     | 0               |
    |    50     |     0    | DEV_TIMER1_TIMER_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |    50     |     1    | DEV_TIMER1_TIMER_TCLK_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    50     |     2    | DEV_TIMER1_TIMER_TCLK_CLK_PARENT_MAIN_TIMER_CLKSEL_OUT1                           | CLK_STATE_READY     | 19200000        |
    |    50     |     3    | DEV_TIMER1_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MAIN_0_TIMER_PWM                  | CLK_STATE_READY     | 0               |
    |    60     |     0    | DEV_TIMER10_TIMER_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    60     |     1    | DEV_TIMER10_TIMER_TCLK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |    60     |     2    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |    60     |     3    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |    60     |     4    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK               | CLK_STATE_READY     | 200000000       |
    |    60     |     5    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK    | CLK_STATE_READY     | 12500000        |
    |    60     |     6    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK               | CLK_STATE_READY     | 200000000       |
    |    60     |     7    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |    60     |     8    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                         | CLK_STATE_READY     | 0               |
    |    60     |     9    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                       | CLK_STATE_READY     | 0               |
    |    60     |    10    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                       | CLK_STATE_READY     | 0               |
    |    60     |    11    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK               | CLK_STATE_READY     | 192000000       |
    |    60     |    12    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK             | CLK_STATE_READY     | 225000000       |
    |    60     |    13    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK               | CLK_STATE_READY     | 196608000       |
    |    60     |    14    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                  | CLK_STATE_READY     | 0               |
    |    60     |    15    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                  | CLK_STATE_READY     | 0               |
    |    60     |    16    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                    | CLK_STATE_READY     | 0               |
    |    60     |    17    | DEV_TIMER10_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                  | CLK_STATE_READY     | 0               |
    |    60     |    26    | DEV_TIMER10_TIMER_PWM                                                             | CLK_STATE_READY     | 0               |
    |    62     |     0    | DEV_TIMER11_TIMER_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    62     |     1    | DEV_TIMER11_TIMER_TCLK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |    62     |     2    | DEV_TIMER11_TIMER_TCLK_CLK_PARENT_MAIN_TIMER_CLKSEL_OUT11                         | CLK_STATE_READY     | 19200000        |
    |    62     |     3    | DEV_TIMER11_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MAIN_10_TIMER_PWM                | CLK_STATE_NOT_READY | 0               |
    |   318     |     0    | DEV_TIMER11_CLKSEL_VD_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |   318     |     1    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   318     |     2    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   318     |     3    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                | CLK_STATE_READY     | 200000000       |
    |   318     |     4    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK     | CLK_STATE_READY     | 12500000        |
    |   318     |     5    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                | CLK_STATE_READY     | 200000000       |
    |   318     |     6    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   318     |     7    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                          | CLK_STATE_READY     | 0               |
    |   318     |     8    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                        | CLK_STATE_READY     | 0               |
    |   318     |     9    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |   318     |    10    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                | CLK_STATE_READY     | 192000000       |
    |   318     |    11    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK              | CLK_STATE_READY     | 225000000       |
    |   318     |    12    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                | CLK_STATE_READY     | 196608000       |
    |   318     |    13    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                   | CLK_STATE_READY     | 0               |
    |   318     |    14    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                   | CLK_STATE_READY     | 0               |
    |   318     |    15    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                     | CLK_STATE_READY     | 0               |
    |   318     |    16    | DEV_TIMER11_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                   | CLK_STATE_READY     | 0               |
    |    63     |     0    | DEV_TIMER12_TIMER_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    63     |     1    | DEV_TIMER12_TIMER_TCLK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |    63     |     2    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |    63     |     3    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |    63     |     4    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK               | CLK_STATE_READY     | 200000000       |
    |    63     |     5    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK    | CLK_STATE_READY     | 12500000        |
    |    63     |     6    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK               | CLK_STATE_READY     | 200000000       |
    |    63     |     7    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |    63     |     8    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                         | CLK_STATE_READY     | 0               |
    |    63     |     9    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                       | CLK_STATE_READY     | 0               |
    |    63     |    10    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                       | CLK_STATE_READY     | 0               |
    |    63     |    11    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK               | CLK_STATE_READY     | 192000000       |
    |    63     |    12    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK             | CLK_STATE_READY     | 225000000       |
    |    63     |    13    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK               | CLK_STATE_READY     | 196608000       |
    |    63     |    14    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                  | CLK_STATE_READY     | 0               |
    |    63     |    15    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                  | CLK_STATE_READY     | 0               |
    |    63     |    16    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                    | CLK_STATE_READY     | 0               |
    |    63     |    17    | DEV_TIMER12_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                  | CLK_STATE_READY     | 0               |
    |    63     |    26    | DEV_TIMER12_TIMER_PWM                                                             | CLK_STATE_READY     | 0               |
    |    64     |     0    | DEV_TIMER13_TIMER_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    64     |     1    | DEV_TIMER13_TIMER_TCLK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |    64     |     2    | DEV_TIMER13_TIMER_TCLK_CLK_PARENT_MAIN_TIMER_CLKSEL_OUT13                         | CLK_STATE_READY     | 19200000        |
    |    64     |     3    | DEV_TIMER13_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MAIN_12_TIMER_PWM                | CLK_STATE_NOT_READY | 0               |
    |   319     |     0    | DEV_TIMER13_CLKSEL_VD_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |   319     |     1    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   319     |     2    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   319     |     3    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                | CLK_STATE_READY     | 200000000       |
    |   319     |     4    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK     | CLK_STATE_READY     | 12500000        |
    |   319     |     5    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                | CLK_STATE_READY     | 200000000       |
    |   319     |     6    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   319     |     7    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                          | CLK_STATE_READY     | 0               |
    |   319     |     8    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                        | CLK_STATE_READY     | 0               |
    |   319     |     9    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |   319     |    10    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                | CLK_STATE_READY     | 192000000       |
    |   319     |    11    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK              | CLK_STATE_READY     | 225000000       |
    |   319     |    12    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                | CLK_STATE_READY     | 196608000       |
    |   319     |    13    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                   | CLK_STATE_READY     | 0               |
    |   319     |    14    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                   | CLK_STATE_READY     | 0               |
    |   319     |    15    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                     | CLK_STATE_READY     | 0               |
    |   319     |    16    | DEV_TIMER13_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                   | CLK_STATE_READY     | 0               |
    |    65     |     0    | DEV_TIMER14_TIMER_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    65     |     1    | DEV_TIMER14_TIMER_TCLK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |    65     |     2    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |    65     |     3    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |    65     |     4    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK               | CLK_STATE_READY     | 200000000       |
    |    65     |     5    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK    | CLK_STATE_READY     | 12500000        |
    |    65     |     6    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK               | CLK_STATE_READY     | 200000000       |
    |    65     |     7    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |    65     |     8    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                         | CLK_STATE_READY     | 0               |
    |    65     |     9    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                       | CLK_STATE_READY     | 0               |
    |    65     |    10    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                       | CLK_STATE_READY     | 0               |
    |    65     |    11    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK               | CLK_STATE_READY     | 192000000       |
    |    65     |    12    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK             | CLK_STATE_READY     | 225000000       |
    |    65     |    13    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK               | CLK_STATE_READY     | 196608000       |
    |    65     |    14    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                  | CLK_STATE_READY     | 0               |
    |    65     |    15    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                  | CLK_STATE_READY     | 0               |
    |    65     |    16    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                    | CLK_STATE_READY     | 0               |
    |    65     |    17    | DEV_TIMER14_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                  | CLK_STATE_READY     | 0               |
    |    65     |    26    | DEV_TIMER14_TIMER_PWM                                                             | CLK_STATE_READY     | 0               |
    |    66     |     0    | DEV_TIMER15_TIMER_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    66     |     1    | DEV_TIMER15_TIMER_TCLK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |    66     |     2    | DEV_TIMER15_TIMER_TCLK_CLK_PARENT_MAIN_TIMER_CLKSEL_OUT15                         | CLK_STATE_READY     | 19200000        |
    |    66     |     3    | DEV_TIMER15_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MAIN_14_TIMER_PWM                | CLK_STATE_NOT_READY | 0               |
    |   320     |     0    | DEV_TIMER15_CLKSEL_VD_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |   320     |     1    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   320     |     2    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   320     |     3    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                | CLK_STATE_READY     | 200000000       |
    |   320     |     4    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK     | CLK_STATE_READY     | 12500000        |
    |   320     |     5    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                | CLK_STATE_READY     | 200000000       |
    |   320     |     6    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   320     |     7    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                          | CLK_STATE_READY     | 0               |
    |   320     |     8    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                        | CLK_STATE_READY     | 0               |
    |   320     |     9    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |   320     |    10    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                | CLK_STATE_READY     | 192000000       |
    |   320     |    11    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK              | CLK_STATE_READY     | 225000000       |
    |   320     |    12    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                | CLK_STATE_READY     | 196608000       |
    |   320     |    13    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                   | CLK_STATE_READY     | 0               |
    |   320     |    14    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                   | CLK_STATE_READY     | 0               |
    |   320     |    15    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                     | CLK_STATE_READY     | 0               |
    |   320     |    16    | DEV_TIMER15_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                   | CLK_STATE_READY     | 0               |
    |    67     |     0    | DEV_TIMER16_TIMER_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    67     |     1    | DEV_TIMER16_TIMER_TCLK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |    67     |     2    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |    67     |     3    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |    67     |     4    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK               | CLK_STATE_READY     | 200000000       |
    |    67     |     5    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK    | CLK_STATE_READY     | 12500000        |
    |    67     |     6    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK               | CLK_STATE_READY     | 200000000       |
    |    67     |     7    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |    67     |     8    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                         | CLK_STATE_READY     | 0               |
    |    67     |     9    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                       | CLK_STATE_READY     | 0               |
    |    67     |    10    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                       | CLK_STATE_READY     | 0               |
    |    67     |    11    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK               | CLK_STATE_READY     | 192000000       |
    |    67     |    12    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK             | CLK_STATE_READY     | 225000000       |
    |    67     |    13    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK               | CLK_STATE_READY     | 196608000       |
    |    67     |    14    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                  | CLK_STATE_READY     | 0               |
    |    67     |    15    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                  | CLK_STATE_READY     | 0               |
    |    67     |    16    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                    | CLK_STATE_READY     | 0               |
    |    67     |    17    | DEV_TIMER16_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                  | CLK_STATE_READY     | 0               |
    |    67     |    26    | DEV_TIMER16_TIMER_PWM                                                             | CLK_STATE_READY     | 0               |
    |    68     |     0    | DEV_TIMER17_TIMER_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    68     |     1    | DEV_TIMER17_TIMER_TCLK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |    68     |     2    | DEV_TIMER17_TIMER_TCLK_CLK_PARENT_MAIN_TIMER_CLKSEL_OUT17                         | CLK_STATE_READY     | 19200000        |
    |    68     |     3    | DEV_TIMER17_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MAIN_16_TIMER_PWM                | CLK_STATE_NOT_READY | 0               |
    |   321     |     0    | DEV_TIMER17_CLKSEL_VD_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |   321     |     1    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   321     |     2    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   321     |     3    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                | CLK_STATE_READY     | 200000000       |
    |   321     |     4    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK     | CLK_STATE_READY     | 12500000        |
    |   321     |     5    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                | CLK_STATE_READY     | 200000000       |
    |   321     |     6    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   321     |     7    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                          | CLK_STATE_READY     | 0               |
    |   321     |     8    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                        | CLK_STATE_READY     | 0               |
    |   321     |     9    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |   321     |    10    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                | CLK_STATE_READY     | 192000000       |
    |   321     |    11    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK              | CLK_STATE_READY     | 225000000       |
    |   321     |    12    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                | CLK_STATE_READY     | 196608000       |
    |   321     |    13    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                   | CLK_STATE_READY     | 0               |
    |   321     |    14    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                   | CLK_STATE_READY     | 0               |
    |   321     |    15    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                     | CLK_STATE_READY     | 0               |
    |   321     |    16    | DEV_TIMER17_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                   | CLK_STATE_READY     | 0               |
    |    69     |     0    | DEV_TIMER18_TIMER_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    69     |     1    | DEV_TIMER18_TIMER_TCLK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |    69     |     2    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |    69     |     3    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |    69     |     4    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK               | CLK_STATE_READY     | 200000000       |
    |    69     |     5    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK    | CLK_STATE_READY     | 12500000        |
    |    69     |     6    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK               | CLK_STATE_READY     | 200000000       |
    |    69     |     7    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                     | CLK_STATE_READY     | 0               |
    |    69     |     8    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                         | CLK_STATE_READY     | 0               |
    |    69     |     9    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                       | CLK_STATE_READY     | 0               |
    |    69     |    10    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                       | CLK_STATE_READY     | 0               |
    |    69     |    11    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK               | CLK_STATE_READY     | 192000000       |
    |    69     |    12    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK             | CLK_STATE_READY     | 225000000       |
    |    69     |    13    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK               | CLK_STATE_READY     | 196608000       |
    |    69     |    14    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                  | CLK_STATE_READY     | 0               |
    |    69     |    15    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                  | CLK_STATE_READY     | 0               |
    |    69     |    16    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                    | CLK_STATE_READY     | 0               |
    |    69     |    17    | DEV_TIMER18_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                  | CLK_STATE_READY     | 0               |
    |    69     |    26    | DEV_TIMER18_TIMER_PWM                                                             | CLK_STATE_READY     | 0               |
    |    70     |     0    | DEV_TIMER19_TIMER_HCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |    70     |     1    | DEV_TIMER19_TIMER_TCLK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |    70     |     2    | DEV_TIMER19_TIMER_TCLK_CLK_PARENT_MAIN_TIMER_CLKSEL_OUT19                         | CLK_STATE_READY     | 19200000        |
    |    70     |     3    | DEV_TIMER19_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MAIN_18_TIMER_PWM                | CLK_STATE_NOT_READY | 0               |
    |   322     |     0    | DEV_TIMER19_CLKSEL_VD_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |   322     |     1    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |   322     |     2    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |   322     |     3    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                | CLK_STATE_READY     | 200000000       |
    |   322     |     4    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK     | CLK_STATE_READY     | 12500000        |
    |   322     |     5    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                | CLK_STATE_READY     | 200000000       |
    |   322     |     6    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |   322     |     7    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                          | CLK_STATE_READY     | 0               |
    |   322     |     8    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                        | CLK_STATE_READY     | 0               |
    |   322     |     9    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |   322     |    10    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                | CLK_STATE_READY     | 192000000       |
    |   322     |    11    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK              | CLK_STATE_READY     | 225000000       |
    |   322     |    12    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                | CLK_STATE_READY     | 196608000       |
    |   322     |    13    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                   | CLK_STATE_READY     | 0               |
    |   322     |    14    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                   | CLK_STATE_READY     | 0               |
    |   322     |    15    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                     | CLK_STATE_READY     | 0               |
    |   322     |    16    | DEV_TIMER19_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                   | CLK_STATE_READY     | 0               |
    |   313     |     0    | DEV_TIMER1_CLKSEL_VD_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |   313     |     1    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                           | CLK_STATE_READY     | 19200000        |
    |   313     |     2    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                            | CLK_STATE_READY     | 0               |
    |   313     |     3    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                 | CLK_STATE_READY     | 200000000       |
    |   313     |     4    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK      | CLK_STATE_READY     | 12500000        |
    |   313     |     5    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                 | CLK_STATE_READY     | 200000000       |
    |   313     |     6    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                       | CLK_STATE_READY     | 0               |
    |   313     |     7    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                           | CLK_STATE_READY     | 0               |
    |   313     |     8    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                         | CLK_STATE_READY     | 0               |
    |   313     |     9    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   313     |    10    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                 | CLK_STATE_READY     | 192000000       |
    |   313     |    11    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK               | CLK_STATE_READY     | 225000000       |
    |   313     |    12    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                 | CLK_STATE_READY     | 196608000       |
    |   313     |    13    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                    | CLK_STATE_READY     | 0               |
    |   313     |    14    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                    | CLK_STATE_READY     | 0               |
    |   313     |    15    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                      | CLK_STATE_READY     | 0               |
    |   313     |    16    | DEV_TIMER1_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                    | CLK_STATE_READY     | 0               |
    |    51     |     0    | DEV_TIMER2_TIMER_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |    51     |     1    | DEV_TIMER2_TIMER_TCLK_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    51     |     2    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |    51     |     3    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |    51     |     4    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                | CLK_STATE_READY     | 200000000       |
    |    51     |     5    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK     | CLK_STATE_READY     | 12500000        |
    |    51     |     6    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                | CLK_STATE_READY     | 200000000       |
    |    51     |     7    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |    51     |     8    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                          | CLK_STATE_READY     | 0               |
    |    51     |     9    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                        | CLK_STATE_READY     | 0               |
    |    51     |    10    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |    51     |    11    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                | CLK_STATE_READY     | 192000000       |
    |    51     |    12    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK              | CLK_STATE_READY     | 225000000       |
    |    51     |    13    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                | CLK_STATE_READY     | 196608000       |
    |    51     |    14    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                   | CLK_STATE_READY     | 0               |
    |    51     |    15    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                   | CLK_STATE_READY     | 0               |
    |    51     |    16    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                     | CLK_STATE_READY     | 0               |
    |    51     |    17    | DEV_TIMER2_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                   | CLK_STATE_READY     | 0               |
    |    51     |    26    | DEV_TIMER2_TIMER_PWM                                                              | CLK_STATE_READY     | 0               |
    |    52     |     0    | DEV_TIMER3_TIMER_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |    52     |     1    | DEV_TIMER3_TIMER_TCLK_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    52     |     2    | DEV_TIMER3_TIMER_TCLK_CLK_PARENT_MAIN_TIMER_CLKSEL_OUT3                           | CLK_STATE_READY     | 19200000        |
    |    52     |     3    | DEV_TIMER3_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MAIN_2_TIMER_PWM                  | CLK_STATE_READY     | 0               |
    |   314     |     0    | DEV_TIMER3_CLKSEL_VD_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |   314     |     1    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                           | CLK_STATE_READY     | 19200000        |
    |   314     |     2    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                            | CLK_STATE_READY     | 0               |
    |   314     |     3    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                 | CLK_STATE_READY     | 200000000       |
    |   314     |     4    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK      | CLK_STATE_READY     | 12500000        |
    |   314     |     5    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                 | CLK_STATE_READY     | 200000000       |
    |   314     |     6    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                       | CLK_STATE_READY     | 0               |
    |   314     |     7    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                           | CLK_STATE_READY     | 0               |
    |   314     |     8    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                         | CLK_STATE_READY     | 0               |
    |   314     |     9    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   314     |    10    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                 | CLK_STATE_READY     | 192000000       |
    |   314     |    11    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK               | CLK_STATE_READY     | 225000000       |
    |   314     |    12    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                 | CLK_STATE_READY     | 196608000       |
    |   314     |    13    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                    | CLK_STATE_READY     | 0               |
    |   314     |    14    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                    | CLK_STATE_READY     | 0               |
    |   314     |    15    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                      | CLK_STATE_READY     | 0               |
    |   314     |    16    | DEV_TIMER3_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                    | CLK_STATE_READY     | 0               |
    |    53     |     0    | DEV_TIMER4_TIMER_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |    53     |     1    | DEV_TIMER4_TIMER_TCLK_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    53     |     2    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |    53     |     3    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |    53     |     4    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                | CLK_STATE_READY     | 200000000       |
    |    53     |     5    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK     | CLK_STATE_READY     | 12500000        |
    |    53     |     6    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                | CLK_STATE_READY     | 200000000       |
    |    53     |     7    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |    53     |     8    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                          | CLK_STATE_READY     | 0               |
    |    53     |     9    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                        | CLK_STATE_READY     | 0               |
    |    53     |    10    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |    53     |    11    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                | CLK_STATE_READY     | 192000000       |
    |    53     |    12    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK              | CLK_STATE_READY     | 225000000       |
    |    53     |    13    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                | CLK_STATE_READY     | 196608000       |
    |    53     |    14    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                   | CLK_STATE_READY     | 0               |
    |    53     |    15    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                   | CLK_STATE_READY     | 0               |
    |    53     |    16    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                     | CLK_STATE_READY     | 0               |
    |    53     |    17    | DEV_TIMER4_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                   | CLK_STATE_READY     | 0               |
    |    53     |    26    | DEV_TIMER4_TIMER_PWM                                                              | CLK_STATE_READY     | 0               |
    |    54     |     0    | DEV_TIMER5_TIMER_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |    54     |     1    | DEV_TIMER5_TIMER_TCLK_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    54     |     2    | DEV_TIMER5_TIMER_TCLK_CLK_PARENT_MAIN_TIMER_CLKSEL_OUT5                           | CLK_STATE_READY     | 19200000        |
    |    54     |     3    | DEV_TIMER5_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MAIN_4_TIMER_PWM                  | CLK_STATE_READY     | 0               |
    |   315     |     0    | DEV_TIMER5_CLKSEL_VD_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |   315     |     1    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                           | CLK_STATE_READY     | 19200000        |
    |   315     |     2    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                            | CLK_STATE_READY     | 0               |
    |   315     |     3    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                 | CLK_STATE_READY     | 200000000       |
    |   315     |     4    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK      | CLK_STATE_READY     | 12500000        |
    |   315     |     5    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                 | CLK_STATE_READY     | 200000000       |
    |   315     |     6    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                       | CLK_STATE_READY     | 0               |
    |   315     |     7    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                           | CLK_STATE_READY     | 0               |
    |   315     |     8    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                         | CLK_STATE_READY     | 0               |
    |   315     |     9    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   315     |    10    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                 | CLK_STATE_READY     | 192000000       |
    |   315     |    11    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK               | CLK_STATE_READY     | 225000000       |
    |   315     |    12    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                 | CLK_STATE_READY     | 196608000       |
    |   315     |    13    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                    | CLK_STATE_READY     | 0               |
    |   315     |    14    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                    | CLK_STATE_READY     | 0               |
    |   315     |    15    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                      | CLK_STATE_READY     | 0               |
    |   315     |    16    | DEV_TIMER5_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                    | CLK_STATE_READY     | 0               |
    |    55     |     0    | DEV_TIMER6_TIMER_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |    55     |     1    | DEV_TIMER6_TIMER_TCLK_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    55     |     2    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |    55     |     3    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |    55     |     4    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                | CLK_STATE_READY     | 200000000       |
    |    55     |     5    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK     | CLK_STATE_READY     | 12500000        |
    |    55     |     6    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                | CLK_STATE_READY     | 200000000       |
    |    55     |     7    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |    55     |     8    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                          | CLK_STATE_READY     | 0               |
    |    55     |     9    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                        | CLK_STATE_READY     | 0               |
    |    55     |    10    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |    55     |    11    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                | CLK_STATE_READY     | 192000000       |
    |    55     |    12    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK              | CLK_STATE_READY     | 225000000       |
    |    55     |    13    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                | CLK_STATE_READY     | 196608000       |
    |    55     |    14    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                   | CLK_STATE_READY     | 0               |
    |    55     |    15    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                   | CLK_STATE_READY     | 0               |
    |    55     |    16    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                     | CLK_STATE_READY     | 0               |
    |    55     |    17    | DEV_TIMER6_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                   | CLK_STATE_READY     | 0               |
    |    55     |    26    | DEV_TIMER6_TIMER_PWM                                                              | CLK_STATE_READY     | 0               |
    |    57     |     0    | DEV_TIMER7_TIMER_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |    57     |     1    | DEV_TIMER7_TIMER_TCLK_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    57     |     2    | DEV_TIMER7_TIMER_TCLK_CLK_PARENT_MAIN_TIMER_CLKSEL_OUT7                           | CLK_STATE_READY     | 19200000        |
    |    57     |     3    | DEV_TIMER7_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MAIN_6_TIMER_PWM                  | CLK_STATE_READY     | 0               |
    |   316     |     0    | DEV_TIMER7_CLKSEL_VD_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |   316     |     1    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                           | CLK_STATE_READY     | 19200000        |
    |   316     |     2    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                            | CLK_STATE_READY     | 0               |
    |   316     |     3    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                 | CLK_STATE_READY     | 200000000       |
    |   316     |     4    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK      | CLK_STATE_READY     | 12500000        |
    |   316     |     5    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                 | CLK_STATE_READY     | 200000000       |
    |   316     |     6    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                       | CLK_STATE_READY     | 0               |
    |   316     |     7    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                           | CLK_STATE_READY     | 0               |
    |   316     |     8    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                         | CLK_STATE_READY     | 0               |
    |   316     |     9    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   316     |    10    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                 | CLK_STATE_READY     | 192000000       |
    |   316     |    11    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK               | CLK_STATE_READY     | 225000000       |
    |   316     |    12    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                 | CLK_STATE_READY     | 196608000       |
    |   316     |    13    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                    | CLK_STATE_READY     | 0               |
    |   316     |    14    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                    | CLK_STATE_READY     | 0               |
    |   316     |    15    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                      | CLK_STATE_READY     | 0               |
    |   316     |    16    | DEV_TIMER7_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                    | CLK_STATE_READY     | 0               |
    |    58     |     0    | DEV_TIMER8_TIMER_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |    58     |     1    | DEV_TIMER8_TIMER_TCLK_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    58     |     2    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                          | CLK_STATE_READY     | 19200000        |
    |    58     |     3    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                           | CLK_STATE_READY     | 0               |
    |    58     |     4    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                | CLK_STATE_READY     | 200000000       |
    |    58     |     5    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK     | CLK_STATE_READY     | 12500000        |
    |    58     |     6    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                | CLK_STATE_READY     | 200000000       |
    |    58     |     7    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                      | CLK_STATE_READY     | 0               |
    |    58     |     8    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                          | CLK_STATE_READY     | 0               |
    |    58     |     9    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                        | CLK_STATE_READY     | 0               |
    |    58     |    10    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                        | CLK_STATE_READY     | 0               |
    |    58     |    11    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                | CLK_STATE_READY     | 192000000       |
    |    58     |    12    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK              | CLK_STATE_READY     | 225000000       |
    |    58     |    13    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                | CLK_STATE_READY     | 196608000       |
    |    58     |    14    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                   | CLK_STATE_READY     | 0               |
    |    58     |    15    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                   | CLK_STATE_READY     | 0               |
    |    58     |    16    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                     | CLK_STATE_READY     | 0               |
    |    58     |    17    | DEV_TIMER8_TIMER_TCLK_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                   | CLK_STATE_READY     | 0               |
    |    58     |    26    | DEV_TIMER8_TIMER_PWM                                                              | CLK_STATE_READY     | 0               |
    |    59     |     0    | DEV_TIMER9_TIMER_HCLK_CLK                                                         | CLK_STATE_READY     | 125000000       |
    |    59     |     1    | DEV_TIMER9_TIMER_TCLK_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    59     |     2    | DEV_TIMER9_TIMER_TCLK_CLK_PARENT_MAIN_TIMER_CLKSEL_OUT9                           | CLK_STATE_READY     | 19200000        |
    |    59     |     3    | DEV_TIMER9_TIMER_TCLK_CLK_PARENT_DMTIMER_DMC1MS_MAIN_8_TIMER_PWM                  | CLK_STATE_NOT_READY | 0               |
    |   317     |     0    | DEV_TIMER9_CLKSEL_VD_CLK                                                          | CLK_STATE_READY     | 19200000        |
    |   317     |     1    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                           | CLK_STATE_READY     | 19200000        |
    |   317     |     2    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                            | CLK_STATE_READY     | 0               |
    |   317     |     3    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_0_HSDIVOUT1_CLK                 | CLK_STATE_READY     | 200000000       |
    |   317     |     4    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK      | CLK_STATE_READY     | 12500000        |
    |   317     |     5    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_3_HSDIVOUT3_CLK                 | CLK_STATE_READY     | 200000000       |
    |   317     |     6    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_BOARD_0_MCU_EXT_REFCLK0_OUT                       | CLK_STATE_READY     | 0               |
    |   317     |     7    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_BOARD_0_EXT_REFCLK1_OUT                           | CLK_STATE_READY     | 0               |
    |   317     |     8    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_BOARD_0_WKUP_LF_CLKIN_OUT                         | CLK_STATE_READY     | 0               |
    |   317     |     9    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_BOARD_0_CPTS0_RFT_CLK_OUT                         | CLK_STATE_READY     | 0               |
    |   317     |    10    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_HSDIV4_16FFT_MAIN_1_HSDIVOUT3_CLK                 | CLK_STATE_READY     | 192000000       |
    |   317     |    11    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_POSTDIV2_16FFT_MAIN_2_HSDIVOUT6_CLK               | CLK_STATE_READY     | 225000000       |
    |   317     |    12    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_HSDIV2_16FFT_MAIN_4_HSDIVOUT2_CLK                 | CLK_STATE_READY     | 196608000       |
    |   317     |    13    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF2                    | CLK_STATE_READY     | 0               |
    |   317     |    14    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF3                    | CLK_STATE_READY     | 0               |
    |   317     |    15    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_CPSW_5XUSS_MAIN_0_CPTS_GENF0                      | CLK_STATE_READY     | 0               |
    |   317     |    16    | DEV_TIMER9_CLKSEL_VD_CLK_PARENT_NAVSS256VCL_MAIN_0_CPTS0_GENF4                    | CLK_STATE_READY     | 0               |
    |   146     |     2    | DEV_UART0_FCLK_CLK        | CLK_STATE_READY     | 48000000        |
    |   146     |     3    | DEV_UART0_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   278     |     2    | DEV_UART1_FCLK_CLK        | CLK_STATE_READY     | 48000000        |
    |   278     |     3    | DEV_UART1_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   279     |     2    | DEV_UART2_FCLK_CLK        | CLK_STATE_READY     | 48000000        |
    |   279     |     3    | DEV_UART2_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   280     |     2    | DEV_UART3_FCLK_CLK        | CLK_STATE_READY     | 48000000        |
    |   280     |     3    | DEV_UART3_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   281     |     2    | DEV_UART4_FCLK_CLK        | CLK_STATE_READY     | 48000000        |
    |   281     |     3    | DEV_UART4_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   282     |     2    | DEV_UART5_FCLK_CLK        | CLK_STATE_READY     | 48000000        |
    |   282     |     3    | DEV_UART5_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   283     |     2    | DEV_UART6_FCLK_CLK        | CLK_STATE_READY     | 48000000        |
    |   283     |     3    | DEV_UART6_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   284     |     2    | DEV_UART7_FCLK_CLK        | CLK_STATE_READY     | 48000000        |
    |   284     |     3    | DEV_UART7_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   285     |     2    | DEV_UART8_FCLK_CLK        | CLK_STATE_READY     | 48000000        |
    |   285     |     3    | DEV_UART8_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   286     |     2    | DEV_UART9_FCLK_CLK        | CLK_STATE_READY     | 48000000        |
    |   286     |     3    | DEV_UART9_VBUSP_CLK                                                               | CLK_STATE_READY     | 125000000       |
    |   288     |     0    | DEV_USB0_PIPE_REFCLK                                                              | CLK_STATE_READY     | 0               |
    |   288     |     1    | DEV_USB0_PIPE_REFCLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP3_LN1_REFCLK                    | CLK_STATE_READY     | 0               |
    |   288     |     2    | DEV_USB0_PIPE_REFCLK_PARENT_WIZ16B8M4CT2_MAIN_1_IP3_LN3_REFCLK                    | CLK_STATE_READY     | 0               |
    |   288     |     3    | DEV_USB0_CLK_LPM_CLK                                                              | CLK_STATE_READY     | 24000000        |
    |   288     |     4    | DEV_USB0_BUF_CLK        | CLK_STATE_READY     | 250000000       |
    |   288     |     5    | DEV_USB0_PIPE_TXFCLK                                                              | CLK_STATE_READY     | 0               |
    |   288     |     6    | DEV_USB0_USB2_APB_PCLK_CLK                                                        | CLK_STATE_READY     | 125000000       |
    |   288     |     7    | DEV_USB0_PIPE_RXCLK                                                               | CLK_STATE_READY     | 0               |
    |   288     |     8    | DEV_USB0_PIPE_TXMCLK                                                              | CLK_STATE_READY     | 0               |
    |   288     |     9    | DEV_USB0_PIPE_RXFCLK                                                              | CLK_STATE_READY     | 0               |
    |   288     |    11    | DEV_USB0_PIPE_TXCLK                                                               | CLK_STATE_READY     | 0               |
    |   288     |    12    | DEV_USB0_USB2_REFCLOCK_CLK                                                        | CLK_STATE_READY     | 19200000        |
    |   288     |    13    | DEV_USB0_USB2_REFCLOCK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                         | CLK_STATE_READY     | 19200000        |
    |   288     |    14    | DEV_USB0_USB2_REFCLOCK_CLK_PARENT_BOARD_0_HFOSC1_CLK_OUT                          | CLK_STATE_READY     | 0               |
    |   288     |    15    | DEV_USB0_PCLK_CLK        | CLK_STATE_READY     | 125000000       |
    |   288     |    17    | DEV_USB0_ACLK_CLK        | CLK_STATE_READY     | 500000000       |
    |   145     |     0    | DEV_WKUP_DDPA0_DDPA_CLK                                                           | CLK_STATE_READY     | 166666666       |
    |    99     |     0    | DEV_WKUP_ESM0_CLK        | CLK_STATE_READY     | 166666666       |
    |   113     |     0    | DEV_WKUP_GPIO0_MMR_CLK                                                            | CLK_STATE_READY     | 166666666       |
    |   113     |     1    | DEV_WKUP_GPIO0_MMR_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK6          | CLK_STATE_READY     | 166666666       |
    |   113     |     2    | DEV_WKUP_GPIO0_MMR_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK6_DUP0     | CLK_STATE_READY     | 166666666       |
    |   113     |     3    | DEV_WKUP_GPIO0_MMR_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK          | CLK_STATE_READY     | 32550           |
    |   113     |     4    | DEV_WKUP_GPIO0_MMR_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK        | CLK_STATE_READY     | 12500000        |
    |   114     |     0    | DEV_WKUP_GPIO1_MMR_CLK                                                            | CLK_STATE_READY     | 166666666       |
    |   114     |     1    | DEV_WKUP_GPIO1_MMR_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK6          | CLK_STATE_READY     | 166666666       |
    |   114     |     2    | DEV_WKUP_GPIO1_MMR_CLK_PARENT_K3_PLL_CTRL_WRAP_WKUP_0_CHIP_DIV1_CLK_CLK6_DUP0     | CLK_STATE_READY     | 166666666       |
    |   114     |     3    | DEV_WKUP_GPIO1_MMR_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_32K_CLK          | CLK_STATE_READY     | 32550           |
    |   114     |     4    | DEV_WKUP_GPIO1_MMR_CLK_PARENT_J7VC_WAKEUP_16FF_WKUP_0_WKUP_RCOSC_12P5M_CLK        | CLK_STATE_READY     | 12500000        |
    |   197     |     0    | DEV_WKUP_I2C0_PISCL                                                               | CLK_STATE_READY     | 0               |
    |   197     |     1    | DEV_WKUP_I2C0_PISYS_CLK                                                           | CLK_STATE_READY     | 96000000        |
    |   197     |     2    | DEV_WKUP_I2C0_CLK        | CLK_STATE_READY     | 166666666       |
    |   197     |     3    | DEV_WKUP_I2C0_PORSCL                                                              | CLK_STATE_READY     | 0               |
    |   132     |     0    | DEV_WKUP_PORZ_SYNC0_CLK_12M_RC_CLK                                                | CLK_STATE_READY     | 12500000        |
    |   138     |     0    | DEV_WKUP_PSC0_SLOW_CLK                                                            | CLK_STATE_READY     | 41666666        |
    |   138     |     1    | DEV_WKUP_PSC0_CLK        | CLK_STATE_READY     | 166666666       |
    |   287     |     2    | DEV_WKUP_UART0_FCLK_CLK                                                           | CLK_STATE_READY     | 96000000        |
    |   287     |     3    | DEV_WKUP_UART0_FCLK_CLK_PARENT_WKUPUSART_CLK_SEL_OUT0                             | CLK_STATE_READY     | 96000000        |
    |   287     |     4    | DEV_WKUP_UART0_FCLK_CLK_PARENT_GLUELOGIC_HFOSC0_CLKOUT                            | CLK_STATE_READY     | 19200000        |
    |   287     |     5    | DEV_WKUP_UART0_VBUSP_CLK                                                          | CLK_STATE_READY     | 166666666       |
    |   154     |     0    | DEV_WKUP_VTM0_FIX_REF2_CLK                                                        | CLK_STATE_READY     | 12500000        |
    |   154     |     1    | DEV_WKUP_VTM0_VBUSP_CLK                                                           | CLK_STATE_READY     | 166666666       |
    |   154     |     2    | DEV_WKUP_VTM0_FIX_REF_CLK                                                         | CLK_STATE_READY     | 19200000        |
    |    40     |     0    | DEV_WKUP_WAKEUP0_PLL_CTRL_WKUP_CLK24_CLK                                          | CLK_STATE_READY     | 1000000000      |
    |    40     |     1    | DEV_WKUP_WAKEUP0_WKUP_RCOSC_32K_CLK                                               | CLK_STATE_READY     | 32550           |
    |    40     |     2    | DEV_WKUP_WAKEUP0_WKUP_RCOSC_12P5M_CLK                                             | CLK_STATE_READY     | 12500000        |
    mizutani
    Do you have any update on this issue?
    mizutani
    Can you check by referencing"mcu_clkout_pins_default" node under mcu_cpsw node?
    Also, read the register value of  "0x1C0EC" and share with us.
    Sudheer
    There is no "mcu_clkout_pins_default" node under the "mcu_cpsw" node.
    Can you please provide example code that adds the "mcu_clkout_pins_default" node?
    And the contents of CTRLMMR_PADCONFIG59 Register (Offset = 1C0ECh) are shown below.
    mizutani
    It shows Pinmux is not configured for MCU_CLKOUT pin.
    Above in your device tree file, you have added "mcu_clkout_pins_default" node under "wkup_pmx2", but "mcu_clkout_pins_default" is not referenced any where.
    mcu_clkout_pins_default: mcu-clkout-default-pins {
    pinctrl-single,pins = <
    J721E_WKUP_IOPAD(0x83, PIN_OUTPUT, 6) /* (C16) WKUP_GPIO0_11.MCU_CLKOUT0 */
    Please add "mcu_clkout_pins_default" node reference from mcu_cpsw as shown in below and check once.
    &mcu_cpsw {
    	status = "okay";
    	pinctrl-names = "default";
    	pinctrl-0 = <&ethernet_pins_default>, <&dp83822_mdio_pins_default>, <&mcu_clkout_pins_default>;
    Sudheer
    I modified the "mcu_cpsw" node, but it failed to start with the following log.
    Starting kernel ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 6.6.32-rt32 (COMPANY_NAME@COMPANY_NAME) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #0001 SMP PREEMPT_RT 2024/10/01
    [    0.000000] Machine model: COMPANY_NAME CUSTOM_BOARD
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] cma: Reserved 32 MiB at 0x00000000fe000000 on node -1
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 29 pages/cpu s81344 r8192 d29248 u118784
    [    0.000000] pcpu-alloc: s81344 r8192 d29248 u118784 alloc=29*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: kernel page table isolation disabled by kernel configuration
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/nfs nfsroot=192.168.22.250:/home/sanyo/sdk/targetNFS,nolock,v3,tcp,rsize=4096,wsize=4096 ro ip=dhcp SANYO_BOOTDEV=microsd SANYO_BOOTMODE=nfs SANYO_BOOTREV=0.0.0.1
    [    0.000000] Unknown kernel command line parameters "SANYO_BOOTDEV=microsd SANYO_BOOTMODE=nfs SANYO_BOOTREV=0.0.0.1", will be passed to user space.
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fa000000-0x00000000fe000000] (64MB)
    [    0.000000] Memory: 3975760K/4194304K available (11072K kernel code, 2142K rwdata, 4308K rodata, 4416K init, 436K bss, 185776K reserved, 32768K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] ftrace: allocating 40019 entries in 157 pages
    [    0.000000] ftrace: allocated 157 pages with 5 groups
    [    0.000000] trace event string verifier disabled
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000]  No expedited grace period (rcu_normal_after_boot).
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Rude variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008801a0000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008801b0000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000115] Console: colour dummy device 80x25
    [    0.000144] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000)
    [    0.000150] pid_max: default: 32768 minimum: 301
    [    0.000183] LSM: initializing lsm=capability,integrity
    [    0.000249] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.000265] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.001193] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.001244] RCU Tasks Rude: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.001393] rcu: Hierarchical SRCU implementation.
    [    0.001396] rcu:     Max phase no-delay instances is 400.
    [    0.001675] Platform MSI: msi-controller@1820000 domain created
    [    0.001779] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.001817] EFI services will not be available.
    [    0.001913] smp: Bringing up secondary CPUs ...
    [    0.010598] Detected PIPT I-cache on CPU1
    [    0.010642] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.010657] GICv3: CPU1: using allocated LPI pending table @0x00000008801c0000
    [    0.010692] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.010755] smp: Brought up 1 node, 2 CPUs
    [    0.010759] SMP: Total of 2 processors activated.
    [    0.010762] CPU features: detected: 32-bit EL0 Support
    [    0.010764] CPU features: detected: CRC32 instructions
    [    0.010796] CPU: All CPU(s) started at EL2
    [    0.010798] alternatives: applying system-wide alternatives
    [    0.011544] devtmpfs: initialized
    [    0.033164] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
    [    0.033178] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.033848] pinctrl core: initialized pinctrl subsystem
    [    0.034340] DMI not present or invalid.
    [    0.034606] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.035837] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.035988] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.036153] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.036191] audit: initializing netlink subsys (disabled)
    [    0.036281] audit: type=2000 audit(0.036:1): state=initialized audit_enabled=0 res=1
    [    0.036849] thermal_sys: Registered thermal governor 'step_wise'
    [    0.037031] ASID allocator initialised with 65536 entries
    [    0.060543] Modules: 27136 pages in range for non-PLT usage
    [    0.060550] Modules: 518656 pages in range for PLT usage
    [    0.061872] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.061877] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.061880] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.061882] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.061885] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.061887] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.061889] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.061891] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.063057] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR2.0 JTAGID[0x1bb6d02f] Detected
    [    0.063621] iommu: Default domain type: Translated
    [    0.063625] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.063868] SCSI subsystem initialized
    [    0.064126] usbcore: registered new interface driver usbfs
    [    0.064170] usbcore: registered new interface driver hub
    [    0.064205] usbcore: registered new device driver usb
    [    0.064636] pps_core: LinuxPPS API ver. 1 registered
    [    0.064640] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.064652] PTP clock support registered
    [    0.064810] EDAC MC: Ver: 3.0.0
    [    0.065409] scmi_core: SCMI protocol bus registered
    [    0.066452] FPGA manager framework
    [    0.067608] clocksource: Switched to clocksource arch_sys_counter
    [    0.067806] VFS: Disk quotas dquot_6.6.0
    [    0.067822] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.076725] NET: Registered PF_INET protocol family
    [    0.077034] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.078577] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes, linear)
    [    0.078645] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.078653] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.078877] TCP bind hash table entries: 32768 (order: 9, 2621440 bytes, linear)
    [    0.082293] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.082487] UDP hash table entries: 2048 (order: 5, 196608 bytes, linear)
    [    0.082722] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes, linear)
    [    0.083097] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.083490] RPC: Registered named UNIX socket transport module.
    [    0.083495] RPC: Registered udp transport module.
    [    0.083497] RPC: Registered tcp transport module.
    [    0.083499] RPC: Registered tcp-with-tls transport module.
    [    0.083502] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.083512] PCI: CLS 0 bytes, default 64
    [    0.369639] Initialise system trusted keyrings
    [    0.369777] workingset: timestamp_bits=62 max_order=20 bucket_order=0
    [    0.370025] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.370204] NFS: Registering the id_resolver key type
    [    0.370232] Key type id_resolver registered
    [    0.370236] Key type id_legacy registered
    [    0.370251] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.370254] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.384491] Key type asymmetric registered
    [    0.384498] Asymmetric key parser 'x509' registered
    [    0.384540] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.384545] io scheduler mq-deadline registered
    [    0.384548] io scheduler kyber registered
    [    0.384563] io scheduler bfq registered
    [    0.388143] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
    [    0.388357] pinctrl-single 4301c038.pinctrl: 2 pins, size 8
    [    0.388519] pinctrl-single 4301c068.pinctrl: 59 pins, size 236
    [    0.389096] pinctrl-single 4301c174.pinctrl: 8 pins, size 32
    [    0.389284] pinctrl-single 104200.pinctrl: 20 pins, size 80
    [    0.389403] pinctrl-single 104280.pinctrl: 8 pins, size 32
    [    0.389575] pinctrl-single 11c000.pinctrl: 67 pins, size 268
    [    0.390287] pinctrl-single 11c11c.pinctrl: 3 pins, size 12
    [    0.397701] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.411884] loop: module loaded
    [    0.412844] megasas: 07.725.01.00-rc1
    [    0.418050] tun: Universal TUN/TAP device driver, 1.6
    [    0.418834] VFIO - User Level meta-driver version: 0.3
    [    0.420027] usbcore: registered new interface driver usb-storage
    [    0.420674] i2c_dev: i2c /dev entries driver
    [    0.421471] sdhci: Secure Digital Host Controller Interface driver
    [    0.421474] sdhci: Copyright(c) Pierre Ossman
    [    0.421667] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.422452] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.423834] optee: probing for conduit method.
    [    0.423850] optee: revision 4.2 (12d7c4ee)
    [    0.440442] optee: dynamic shared memory is enabled
    [    0.440977] random: crng init done
    [    0.441039] optee: initialized driver
    [    0.442789] NET: Registered PF_PACKET protocol family
    [    0.442848] Key type dns_resolver registered
    [    0.459099] Loading compiled-in X.509 certificates
    [    0.476901] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    [    0.567176] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.568205] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
    [    0.568546] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
    [    0.568702] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
    [    0.568838] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
    [    0.569064] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
    [    0.574061] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
    [    0.574069] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    0.574072] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    0.585382] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
    [    0.585393] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    0.585396] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    0.586740] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 266, base_baud = 6000000) is a 8250
    [    0.588179] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 267, base_baud = 3000000) is a 8250
    [    0.588291] printk: console [ttyS2] enabled
    [    0.589785] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 268, base_baud = 3000000) is a 8250
    [    0.591400] Unable to handle kernel paging request at virtual address ffff8000816050eb
    [    0.591407] Mem abort info:
    [    0.591408]   ESR = 0x0000000096000021
    [    0.591410]   EC = 0x25: DABT (current EL), IL = 32 bits
    [    0.591413]   SET = 0, FnV = 0
    [    0.591414]   EA = 0, S1PTW = 0
    [    0.591416]   FSC = 0x21: alignment fault
    [    0.591418] Data abort info:
    [    0.591419]   ISV = 0, ISS = 0x00000021, ISS2 = 0x00000000
    [    0.591421]   CM = 0, WnR = 0, TnD = 0, TagAccess = 0
    [    0.591423]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
    [    0.591425] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000082f19000
    [    0.591428] [ffff8000816050eb] pgd=10000008fffff003, p4d=10000008fffff003, pud=10000008ffffe003, pmd=100000088017e003, pte=006800004301c713
    [    0.591439] Internal error: Oops: 0000000096000021 [#1] PREEMPT_RT SMP
    [    0.591443] Modules linked in:
    [    0.591447] CPU: 0 PID: 11 Comm: kworker/u4:0 Not tainted 6.6.32-rt32 #0001
    [    0.591452] Hardware name: COMPANY_NAME CUSTOM_BOARD (DT)
    [    0.591454] Workqueue: events_unbound deferred_probe_work_func
    [    0.591470] pstate: 400000c5 (nZcv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [    0.591474] pc : pcs_readl+0x8/0x28
    [    0.591480] lr : pcs_set_mux+0xd8/0x108
    [    0.591489] sp : ffff000800293ab0
    [    0.591491] x29: ffff000800293ab0 x28: 0000000000000000 x27: 0000000000000000
    [    0.591496] x26: ffff000801cabec0 x25: ffff000801cabec0 x24: 0000000000000000
    [    0.591500] x23: ffff000800e724e0 x22: ffff000801c1bd80 x21: 0000000000000000
    [    0.591505] x20: 0000000000000000 x19: ffff000800e72480 x18: ffffffffffffffff
    [    0.591509] x17: ffff800082f01000 x16: ffff0008000041c0 x15: ffff0008002938a8
    [    0.591513] x14: ffff000800d07aea x13: ffff000800d07ae8 x12: 652e303030303030
    [    0.591518] x11: 0000000000000040 x10: ffff0008002adea8 x9 : ffff800080551268
    [    0.591522] x8 : ffff0008004f8270 x7 : 0000000000000000 x6 : 0000000000000000
    [    0.591526] x5 : ffff0008004f8248 x4 : ffff000800293a20 x3 : 0000000000000000
    [    0.591530] x2 : 0000000000000001 x1 : ffff8000805516e8 x0 : ffff8000816050eb
    [    0.591535] Call trace:
    [    0.591537]  pcs_readl+0x8/0x28
    [    0.591540]  pinmux_enable_setting+0x194/0x260
    [    0.591545]  pinctrl_commit_state+0x13c/0x210
    [    0.591549]  pinctrl_select_state+0x20/0x38
    [    0.591553]  pinctrl_bind_pins+0x148/0x160
    [    0.591559]  really_probe+0x58/0x2b8
    [    0.591564]  __driver_probe_device+0x7c/0x138
    [    0.591568]  driver_probe_device+0x44/0x128
    [    0.591573]  __device_attach_driver+0xb4/0x140
    [    0.591577]  bus_for_each_drv+0x78/0xc8
    [    0.591581]  __device_attach+0xa0/0x188
    [    0.591585]  device_initial_probe+0x18/0x28
    [    0.591590]  bus_probe_device+0xa8/0xb8
    [    0.591594]  deferred_probe_work_func+0x90/0xd0
    [    0.591598]  process_one_work+0x144/0x3b0
    [    0.591604]  worker_thread+0x31c/0x450
    [    0.591608]  kthread+0x100/0x118
    [    0.591611]  ret_from_fork+0x10/0x20
    [    0.591617] Code: 80af7910 ffff8000 aa1e03e9 d503201f (b9400000)
    [    0.591619] ---[ end trace 0000000000000000 ]---
    [    0.591622] note: kworker/u4:0[11] exited with irqs disabled
    [    0.591638] note: kworker/u4:0[11] exited with preempt_count 1
    Please tell me how to solve this problem.
    mizutani
    Above offset should be 0x84 not 0x83.
    Please check with below.
    J721E_WKUP_IOPAD(0x84, PIN_OUTPUT, 6) /* (C16) WKUP_GPIO0_11.MCU_CLKOUT0 */
    Sudheer
    Thanks. I was able to confirm that by correcting the offset, the 50Mhz clock was output.
    Also, is it possible to set the 4th bit of CTRL_MMR_CFG0_MCU_CLKOUT0_CTRL to 1 in the device tree settings?
    mizutani
    Good to hear!
    Unfortunately we can't set this from device tree, you need driver to do it using some property in device tree.
    You can do it using devmem2.
    Sudheer
