Part Number: AUDIO-AM62D-EVM
Other Parts Discussed in Thread: UNIFLASH, SYSCONFIG
Hi experts,
BR
Hi experts,
Hi experts,
I have successfully burned the a53ss0-0_freertos, mcasp_stereo_playback.release.appimage.hs_fs, but after restarting the board, there is no response. The log is as follows:
python uart_uniflash.py -p /dev/ttyUSB1 --cfg=/home/roy-zhuang/ti/asdk-10.00.00/ti-asdk-bsp/mcu_plus_sdk/am62dx/tools/boot/sbl_prebuilt/am62dx-evm/default_sbl_ospi_hs_fs.cfg
Parsing config file ...
Parsing config file ... SUCCESS. Found 8 command(s) !!!
Executing command 1 of 8 ...
Found flash writer ... sending sbl_prebuilt/am62dx-evm/sbl_uart_uniflash_stage1.release.hs_fs.tiimage
Sending sbl_prebuilt/am62dx-evm/sbl_uart_uniflash_stage1.release.hs_fs.tiimage: Sending sbl_prebuilt/am62dx-evm/sbl_uart_uniflash_stage1.release.hs_fs.tiimage: Sending sbl_prebuilt/am62dx-evm/sbl_uart_uniflash_stage1.release.hs_fs.tiimage: Sending sbl_prebuilt/am62dx-evm/sbl_uart_uniflash_stage1.release.hs_fs.tiimage: Sending sbl_prebuilt/am62dx-evm/sbl_uart_uniflash_stage1.release.hs_fs.tiimage: Sent flashwriter sbl_prebuilt/am62dx-evm/sbl_uart_uniflash_stage1.release.hs_fs.tiimage of size 259144 bytes in 24.61s.
Executing command 2 of 8 ...
Command arguments : --file=../../examples/drivers/boot/sbl_uart_uniflash_multistage/sbl_uart_uniflash_stage2/am62dx-evm/r5fss0-0_nortos/ti-arm-clang/sbl_uart_uniflash_stage2.release.appimage.hs_fs --operation=flash --flash-offset=0x0
Sending ../../examples/drivers/boot/sbl_uart_uniflash_multistage/sbl_uart_uniflash_stage2/am62dx-evm/r5fss0-0_nortos/ti-arm-clang/sbl_uart_uniflash_stage2.releaSending ../../examples/drivers/boot/sbl_uart_uniflash_multistage/sbl_uart_uniflash_stage2/am62dx-evm/r5fss0-0_nortos/ti-arm-clang/sbl_uart_uniflash_stage2.releaSending ../../examples/drivers/boot/sbl_uart_uniflash_multistage/sbl_uart_uniflash_stage2/am62dx-evm/r5fss0-0_nortos/ti-arm-clang/sbl_uart_uniflash_stage2.releaSending ../../examples/drivers/boot/sbl_uart_uniflash_multistage/sbl_uart_uniflash_stage2/am62dx-evm/r5fss0-0_nortos/ti-arm-clang/sbl_uart_uniflash_stage2.releaSending ../../examples/drivers/boot/sbl_uart_uniflash_multistage/sbl_uart_uniflash_stage2/am62dx-evm/r5fss0-0_nortos/ti-arm-clang/sbl_uart_uniflash_stage2.releaSending ../../examples/drivers/boot/sbl_uart_uniflash_multistage/sbl_uart_uniflash_stage2/am62dx-evm/r5fss0-0_nortos/ti-arm-clang/sbl_uart_uniflash_stage2.releaSending ../../examples/drivers/boot/sbl_uart_uniflash_multistage/sbl_uart_uniflash_stage2/am62dx-evm/r5fss0-0_nortos/ti-arm-clang/sbl_uart_uniflash_stage2.relea Sent ../../examples/drivers/boot/sbl_uart_uniflash_multistage/sbl_uart_uniflash_stage2/am62dx-evm/r5fss0-0_nortos/ti-arm-clang/sbl_uart_uniflash_stage2.release.appimage.hs_fs of size 133179 bytes in 14.09s.
[STATUS] SUCCESS !!!
Executing command 3 of 8 ...
Command arguments : --operation=flash-phy-tuning-data
Sent flash phy tuning data in 3.13s.
Executing command 4 of 8 ...
Command arguments : --file=sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage --operation=flash --flash-offset=0x0
Sending sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage: 299439bytSending sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage: 299439bytSending sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage: 300468bytSending sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage: 301497bytSending sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage: 301497bytSending sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage: 301498bytSending sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage: 301499bytSending sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage: 301500bytSending sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage: 301501byt Sent sbl_prebuilt/am62dx-evm/sbl_ospi_stage1.release.hs_fs.tiimage of size 299336 bytes in 31.13s.
Executing command 5 of 8 ...
Command arguments : --file=../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs --operation=flash --flash-offset=0x80000
Sending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 206829bytes [00:20, 10720.50bSending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 206829bytes [00:20, 10720.50bSending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 207858bytes [00:20, 10720.50bSending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 207859bytes [00:20, 10720.50bSending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 207860bytes [00:22, 10720.50bSending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 207861bytes [00:23, 10720.50bSending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 207862bytes [00:23, 10720.50b Sent ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs of size 205847 bytes in 22.4s.
Executing command 6 of 8 ...
Command arguments : --file=../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/mcu-r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs --operation=flash --flash-offset=0x800000
Sending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/mcu-r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 42189bytes [00:05, 10699.Sending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/mcu-r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 42189bytes [00:05, 10699.Sending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/mcu-r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 42190bytes [00:05, 10699.Sending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/mcu-r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 42191bytes [00:06, 10699.Sending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/mcu-r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 42192bytes [00:07, 10699.Sending ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/mcu-r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs: 42193bytes [00:07, 10699. Sent ../../examples/drivers/ipc/ipc_rpmsg_echo/am62dx-evm/mcu-r5fss0-0_freertos/ti-arm-clang/ipc_rpmsg_echo.release.appimage.hs_fs of size 41587 bytes in 6.94s.
Executing command 7 of 8 ...
Command arguments : --file=../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/c75ss0-0_freertos/ti-c7000/mcasp_stereo_playback.release.appimage.hs_fs --operation=flash --flash-offset=0xA00000
Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/c75ss0-0_freertos/ti-c7000/mcasp_stereo_playback.release.appimage.hs_fs: 259308bytes [00:2Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/c75ss0-0_freertos/ti-c7000/mcasp_stereo_playback.release.appimage.hs_fs: 260337bytes [00:2Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/c75ss0-0_freertos/ti-c7000/mcasp_stereo_playback.release.appimage.hs_fs: 260337bytes [00:2Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/c75ss0-0_freertos/ti-c7000/mcasp_stereo_playback.release.appimage.hs_fs: 260338bytes [00:2Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/c75ss0-0_freertos/ti-c7000/mcasp_stereo_playback.release.appimage.hs_fs: 260339bytes [00:2Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/c75ss0-0_freertos/ti-c7000/mcasp_stereo_playback.release.appimage.hs_fs: 260340bytes [00:2Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/c75ss0-0_freertos/ti-c7000/mcasp_stereo_playback.release.appimage.hs_fs: 260341bytes [00:2 Sent ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/c75ss0-0_freertos/ti-c7000/mcasp_stereo_playback.release.appimage.hs_fs of size 258415 bytes in 27.28s.
Executing command 8 of 8 ...
Command arguments : --file=../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/a53ss0-0_freertos/gcc-aarch64/mcasp_stereo_playback.release.appimage.hs_fs --operation=flash --flash-offset=0x1200000
Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/a53ss0-0_freertos/gcc-aarch64/mcasp_stereo_playback.release.appimage.hs_fs: 215061bytes [0Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/a53ss0-0_freertos/gcc-aarch64/mcasp_stereo_playback.release.appimage.hs_fs: 215061bytes [0Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/a53ss0-0_freertos/gcc-aarch64/mcasp_stereo_playback.release.appimage.hs_fs: 216090bytes [0Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/a53ss0-0_freertos/gcc-aarch64/mcasp_stereo_playback.release.appimage.hs_fs: 216091bytes [0Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/a53ss0-0_freertos/gcc-aarch64/mcasp_stereo_playback.release.appimage.hs_fs: 216092bytes [0Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/a53ss0-0_freertos/gcc-aarch64/mcasp_stereo_playback.release.appimage.hs_fs: 216093bytes [0Sending ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/a53ss0-0_freertos/gcc-aarch64/mcasp_stereo_playback.release.appimage.hs_fs: 216094bytes [0 Sent ../../examples/drivers/mcasp/mcasp_stereo_playback/am62dx-evm/a53ss0-0_freertos/gcc-aarch64/mcasp_stereo_playback.release.appimage.hs_fs of size 214855 bytes in 23.16s.
All commands from config file are executed !!!
BR,
Roy
Hi Roy,
Can you send the boot logs? The logs you sent are the uart_uniflash logs.
Ritapravo
Ritapravo,
[10:02:39:818] SYSFW Firmware Version 10.0.8--v10.00.08 (Fiery Fox)␍␊ [10:02:39:818] SYSFW Firmware revision 0xa␍␊ [10:02:39:818] SYSFW ABI revision 4.0␍␊ [10:02:39:818] ␍␊ [10:02:40:170] [BOOTLOADER_PROFILE] Boot Media : SD Card ␍␊ [10:02:40:185] [BOOTLOADER_PROFILE] Boot Image Size : 659 KB ␍␊ [10:02:40:185] [BOOTLOADER_PROFILE] Cores present : ␍␊ [10:02:40:185] mcu-r5f0-0␍␊ [10:02:40:185] r5f0-0␍␊ [10:02:40:185] c75ss0␍␊ [10:02:40:185] [BOOTLOADER PROFILE] System_init : 23395us ␍␊ [10:02:40:201] [BOOTLOADER PROFILE] Board_init : 0us ␍␊ [10:02:40:201] [BOOTLOADER PROFILE] Drivers_open : 2875us ␍␊ [10:02:40:201] [BOOTLOADER PROFILE] Board_driversOpen : 0us ␍␊ [10:02:40:217] [BOOTLOADER PROFILE] File read from SD card : 10083us ␍␊ [10:02:40:217] [BOOTLOADER PROFILE] App_loadImages(CSL_CORE_ID_MCU_R5FSS0_0) : 90495us ␍␊ [10:02:40:233] [BOOTLOADER PROFILE] App_loadImages(CSL_CORE_ID_R5FSS0_0) : 79754us ␍␊ [10:02:40:233] [BOOTLOADER PROFILE] App_loadImages(CSL_CORE_ID_C75SS0_0) : 181614us ␍␊ [10:02:40:249] [BOOTLOADER PROFILE] SBL End : 143us ␍␊ [10:02:40:249] [BOOTLOADER_PROFILE] SBL Total Time Taken : 388361us ␍␊ [10:02:40:249] ␍␊ [10:02:40:249] Image loading done, switching to application ...␍␊ [10:02:40:281] mcu/r5f tuning server : Configuring Codec...␍␊ [10:02:40:281] ASSERT: 0.8573s: ../../common/src/am62d_board_codec.c:Board_clockgenConfig:431: status == SystemP_SUCCESS failed !!!␍␊
Hi Roy,
For the uniflash logs, I can see that you have flashed mcasp_stereo_playback example to both a53 and c7x cores. Both these examples use the same MCASP instance by default. This might cause a resource conflict. I recommend you to flash one at a time or change the mcasp instance in one of the examples using sysConfig. Please try this and let us know.
Ritapravo
Hi Ritapravo,
I only use C7x example,these is no sound.
ttyUSB1 [14:49:26:136] SYSFW Firmware Version 10.0.8--v10.00.08 (Fiery Fox) [14:49:26:136] SYSFW Firmware revision 0xa [14:49:26:136] SYSFW ABI revision 4.0 [14:49:26:136] [14:49:26:152] [BOOTLOADER_PROFILE] Boot Media : FLASH [14:49:26:152] [BOOTLOADER_PROFILE] Boot Media Clock : 166.667 MHz [14:49:26:152] [BOOTLOADER_PROFILE] Boot Image Size : 199 KB [14:49:26:152] [BOOTLOADER_PROFILE] Cores present : [14:49:26:168] r5f0-0 [14:49:26:168] [BOOTLOADER PROFILE] System_init : 23530us [14:49:26:168] [BOOTLOADER PROFILE] Board_init : 0us [14:49:26:184] [BOOTLOADER PROFILE] Drivers_open : 1us [14:49:26:184] [BOOTLOADER PROFILE] SBL Drivers_open : 194us [14:49:26:184] [BOOTLOADER PROFILE] Board_driversOpen : 8us [14:49:26:200] [BOOTLOADER PROFILE] SBL Board_driversOpen : 1323us [14:49:26:200] [BOOTLOADER PROFILE] Sciclient Get Version : 10169us [14:49:26:216] [BOOTLOADER PROFILE] App_loadSelfcoreImage : 5434us [14:49:26:216] [BOOTLOADER_PROFILE] SBL Total Time Taken : 40662us [14:49:26:216] Image loading done, switching to application ... [14:49:26:232] Starting 2nd stage bootloader ttyUSB2 [15:00:56:374] <0xe0><0xe0>Sciserver Testapp Built On: Feb 6 2025 14:51:19 [15:01:18:894] Sciserver Version: v2024.09.0.0-REL.MCUSDK.K3.10.00.00.18+ [15:01:18:894] RM_PM_HAL Version: v10.00.08a [15:01:18:894] Starting Sciserver..... PASSED
BR,
Roy
1. copy tisdk/bin/am62dx/sd_card/app; app_dsp; dm; tiboot3.bin to sdcard/boot
Hi Roy,
Initially you sent the uart_uniflash logs for default_sbl_ospi_hs_fs.cfg
If you are using OSPI boot, no need to copy anything to SD_card. Just flash the c7x example, change the boot switch to OSPI boot mode and then power-cycle the evm.
Use the instructions in this image to listen to audio from the EVM.
If you are still facing problems, then use default_sbl_null_hs_fs.cfg. Just add the image for c7x/a53 in the config file and then flash.
Ritapravo
ttyUSB1 [09:46:56:861] Starting NULL Bootloader ... ␍␊ [09:46:56:861] ␍␊ [09:46:56:861] SYSFW Firmware Version 10.0.8--v10.00.08 (Fiery Fox)␍␊ [09:46:56:861] SYSFW Firmware revision 0xa␍␊ [09:46:56:861] SYSFW ABI revision 4.0␍␊ [09:46:56:876] ␍␊ [09:46:56:876] INFO: Bootloader_runCpu:176: CPU mcu-r5f is initialized to 800000000 Hz !!!␍␊ [09:46:56:876] INFO: Bootloader_runCpu:176: CPU a530-0 is initialized to 1400000000 Hz !!!␍␊ [09:46:56:876] INFO: Bootloader_runCpu:176: CPU a530-1 is initialized to 1400000000 Hz !!!␍␊ [09:46:56:892] INFO: Bootloader_runCpu:176: CPU a531-0 is initialized to 1400000000 Hz !!!␍␊ [09:46:56:892] INFO: Bootloader_runCpu:176: CPU a531-1 is initialized to 1400000000 Hz !!!␍␊ [09:46:56:909] INFO: Bootloader_runCpu:176: CPU c7x0-0 is initialized to 1000000000 Hz !!!␍␊ [09:46:56:925] INFO: Bootloader_loadSelfCpu:229: CPU r5f0-0 is initialized to 800000000 Hz !!!␍␊ [09:46:56:925] INFO: Bootloader_JumpSelfCpu:248: All done, jumping self ...␍␊ [09:46:56:941] ␊ ttyUSB2 [09:47:19:198] <0xc0>Sciserver Testapp Built On: Feb 6 2025 14:51:19␍␊ [09:47:19:390] Sciserver Version: v2024.09.0.0-REL.MCUSDK.K3.10.00.00.18+␍␊ [09:47:19:406] RM_PM_HAL Version: v10.00.08a␍␊ [09:47:19:406] Starting Sciserver..... PASSED␍␊ [09:47:19:406] SYSFW Firmware Version 10.0.8--v10.00.08 (Fiery Fox)␍␊ [09:47:19:406] Firmware revision 0xa␍␊ [09:47:19:406] ABI revision 4.0␍␊ [09:47:19:406] [SCICLIENT] CPU clock frequency = 800000000 Hz ␍␊ [09:47:19:422] All tests have passed!!␍␊ [09:47:32:157] <0xc0>Sciserver Testapp Built On: Feb 6 2025 14:51:19␍␊ [09:47:32:350] Sciserver Version: v2024.09.0.0-REL.MCUSDK.K3.10.00.00.18+␍␊ [09:47:32:350] RM_PM_HAL Version: v10.00.08a␍␊ [09:47:32:365] Starting Sciserver..... PASSED␍␊ [09:47:32:365] SYSFW Firmware Version 10.0.8--v10.00.08 (Fiery Fox)␍␊ [09:47:32:365] Firmware revision 0xa␍␊ [09:47:32:365] ABI revision 4.0␍␊ [09:47:32:365] [SCICLIENT] CPU clock frequency = 800000000 Hz ␍␊ [09:47:32:381] All tests have passed!!
Hi Roy,
ut still there is no sound.
From the image you have sent, I can see that you have not inputted any audio in J2 top. Please connect an input 3.5mm jack to J2 top and you will be able to hear it in J3 top via earphones ( in mcasp_stereo_playback example ).
Ritapravo
Hi Ritapravo,
I don't understand why I need to insert a 3.5mm plug into J2. Isn't this a recording interfaces? Shouldn't I just need to insert an output plug? Or do I need a special cable? Or I need to insert two 3.5mm headphone together?
BR,
Roy
Hi Ritapravo,
There is no sound.
ttyUSB2(3rd USB) log:
Hi Roy,
You will have to plug in a 3.5mm aux cable and connect the other end of the aux cable to a laptop/phone and play audio on the laptop/phone. In this example, you cannot directly take input via the microphone.
Ritapravo
Hi Roy,
Are you able to listen to audio out of the EVM after connecting it via aux cable to your PC?
Ritapravo
Hi Ritapravo,
There is still no sound. Are there any special for requirements the audio format?
BR,
Roy
Hi Roy,
Your setup looks right to me. Can you test the following and let me know.
1. Flash default_sbl_null_hs_fs.cfg to am62d evm
2. Import the mcasp_stereo_playback example in CSS
3. Run the example
Let us know, if you are able to see any different results after these steps.
Ritapravo
Hi Ritapravo,
By following these three steps,I can hear the sound played by the PC. Please provide me with WAV files for 16ch、8ch、2ch based on the following characteristics, I need to conduct more tests.
Audio SDK 10.1
•AWE core 16 channel processing, (same as 10.0)
•ADC/DAC I/O: Stereo in/out, 8ch in/out
•Ethernet AVB single stream
•Dolby DCX 5.1.2 on A53
•Ethernet/UART tuning
•Single core C7x
•VLOP optimization
AM62D - Demos
•Ethernet AVB 8ch PCM in DAC 8 ch out (16 ch processing)
•Dolby 5.1.2 (8 channels)
Documentation
•Release notes
•SRAS approval and manifest
•Update Getting started guide
•Users guide
•Installer and OneRelease updates
BR,
Roy
Hi Roy,
There are some sample wav files in asdk-10.00.00/ti-asdk-bsp/packages/dspc/a53/AWECore/Audio/ folder.
You can try these for now.
Ritapravo
