TDA4VM: Ipc between Llinx and Mcu1_0 error.
Part Number: TDA4VM
Hi,Ti expert
SDK : 0902
Board: Ti tda4_evm
Now I want to IPC between linux and mcu1_0 by rpmsg_char_simple, but error:
This is my linux log:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.162-g76b3e88d56 (jietingdu@sz-dl-420.autox.sz) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.15
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000008a7000000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node linux-cma-buffers@8a7000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
[    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
[    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] On node 0 totalpages: 1048576
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524288 pages, LIFO batch:63
[    0.000000]   Normal zone: 8192 pages used for memmap
[    0.000000]   Normal zone: 524288 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
[    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),t
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 1696364K/4194304K available (11200K kernel code, 1160K rwdata, 4300K rodata, 1856K init, 433K bss, 1973652K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c7800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008c7030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c7040000
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008450] Console: colour dummy device 80x25
[    0.013014] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023683] pid_max: default: 32768 minimum: 301
[    0.028442] LSM: Security Framework initializing
[    0.033199] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.040777] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.049636] rcu: Hierarchical SRCU implementation.
[    0.054712] Platform MSI: msi-controller@1820000 domain created
[    0.060978] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070294] EFI services will not be available.
[    0.075020] smp: Bringing up secondary CPUs ...
[    0.088336] Detected PIPT I-cache on CPU1
[    0.088360] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.088372] GICv3: CPU1: using allocated LPI pending table @0x00000008c7050000
[    0.088406] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.088456] smp: Brought up 1 node, 2 CPUs
[    0.117802] SMP: Total of 2 processors activated.
[    0.122607] CPU features: detected: 32-bit EL0 Support
[    0.127862] CPU features: detected: CRC32 instructions
[    0.142100] CPU: All CPU(s) started at EL2
[    0.146295] alternatives: patching kernel code
[    0.151347] devtmpfs: initialized
[    0.160707] KASLR disabled due to lack of seed
[    0.165356] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.175320] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.189408] pinctrl core: initialized pinctrl subsystem
[    0.195078] DMI not present or invalid.
[    0.199331] NET: Registered protocol family 16
[    0.204735] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.212052] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.220069] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.228385] thermal_sys: Registered thermal governor 'step_wise'
[    0.228388] thermal_sys: Registered thermal governor 'power_allocator'
[    0.234977] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.248614] ASID allocator initialised with 65536 entries
[    0.270685] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.277541] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.284391] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.291238] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.298722] cryptd: max_cpu_qlen set to 1000
[    0.304759] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[    0.313580] vsys_3v3: supplied by evm_12v0
[    0.317977] vsys_5v0: supplied by evm_12v0
[    0.322733] iommu: Default domain type: Translated
[    0.327855] SCSI subsystem initialized
[    0.331964] mc: Linux media interface: v0.10
[    0.336386] videodev: Linux video capture interface: v2.00
[    0.342016] pps_core: LinuxPPS API ver. 1 registered
[    0.347089] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.356426] PTP clock support registered
[    0.360444] EDAC MC: Ver: 3.0.0
[    0.364238] FPGA manager framework
[    0.367755] Advanced Linux Sound Architecture Driver Initialized.
[    0.374356] clocksource: Switched to clocksource arch_sys_counter
[    0.380685] VFS: Disk quotas dquot_6.6.0
[    0.384731] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.394397] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[    0.400689] NET: Registered protocol family 2
[    0.405439] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.414049] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.422805] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.431009] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.438827] TCP: Hash tables configured (established 32768 bind 32768)
[    0.445624] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.452517] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.459919] NET: Registered protocol family 1
[    0.464646] RPC: Registered named UNIX socket transport module.
[    0.470705] RPC: Registered udp transport module.
[    0.475521] RPC: Registered tcp transport module.
[    0.480325] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.486907] NET: Registered protocol family 44
[    0.491454] PCI: CLS 0 bytes, default 64
[    0.495863] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.506269] Initialise system trusted keyrings
[    0.510891] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.519082] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.525323] NFS: Registering the id_resolver key type
[    0.530508] Key type id_resolver registered
[    0.534781] Key type id_legacy registered
[    0.538902] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.545751] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.553393] 9p: Installing v9fs 9p2000 file system support
[    0.578565] Key type asymmetric registered
[    0.582752] Asymmetric key parser 'x509' registered
[    0.587748] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.595307] io scheduler mq-deadline registered
[    0.599933] io scheduler kyber registered
[    0.605605] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.611805] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.620691] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.627140] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[    0.635132] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.641551] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[    0.649497] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[    0.655916] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[    0.663841] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.670167] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[    0.678118] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[    0.684443] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[    0.694097] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.702287] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.710545] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.717698] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.726327] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.739625] brd: module loaded
[    0.746178] loop: module loaded
[    0.749970] megasas: 07.714.04.00-rc1
[    0.755657] tun: Universal TUN/TAP device driver, 1.6
[    0.761133] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.767540] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.773614] sky2: driver version 1.30
[    0.777879] VFIO - User Level meta-driver version: 0.3
[    0.783651] i2c /dev entries driver
[    0.788082] sdhci: Secure Digital Host Controller Interface driver
[    0.794400] sdhci: Copyright(c) Pierre Ossman
[    0.799046] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.805395] ledtrig-cpu: registered to indicate activity on CPUs
[    0.811717] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.819070] optee: probing for conduit method.
[    0.823627] optee: revision 3.20 (8e74d476)
[    0.840036] optee: dynamic shared memory is enabled
[    0.849499] optee: initialized driver
[    0.854581] NET: Registered protocol family 17
[    0.859194] 9pnet: Installing 9P2000 support
[    0.863591] Key type dns_resolver registered
[    0.868063] Loading compiled-in X.509 certificates
[    0.882108] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
[    1.112980] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    1.119345] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    1.126538] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    1.133669] i2c i2c-3: Failed to register i2c client tca6408 at 0x20 (-16)
[    1.140708] i2c i2c-3: of_i2c: Failure registering /bus@100000/i2c@2010000/gpio@20
[    1.148446] i2c i2c-3: Failed to create I2C device for /bus@100000/i2c@2010000/gpio@20
[    1.156544] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz
[    1.166660] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz
[    1.173668] pca953x 5-0020: supply vcc not found, using dummy regulator
[    1.180492] pca953x 5-0020: using no AI
[    1.207063] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[    1.213437] omap_i2c 2050000.i2c: bus 6 rev0.12 at 100 kHz
[    1.220129] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.230190] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.239113] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    1.249215] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.261813] cdns-sierra-phy: probe of 5000000.serdes failed with error -22
[    1.288371] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    1.296070] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    1.304347] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    1.312624] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.322256] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.329931] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.338210] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.346489] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.356190] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    1.363862] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    1.372138] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    1.380414] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.390390] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    1.400269] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.407031] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.416567] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    1.426720] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.433478] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.441506] printk: console [ttyS2] disabled
[    1.445901] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 26, base_baud = 3000000) is a 8250
[    1.454645] printk: console [ttyS2] enabled
[    1.463082] printk: bootconsole [ns16550a0] disabled
[    1.474317] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 27, base_baud = 3000000) is a 8250
[    1.483353] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 28, base_baud = 3000000) is a 8250
[    1.493826] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    1.504337] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    1.514497] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    1.524736] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    1.537454] scsi host0: ufshcd
[    1.552473] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.559195] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[    1.596736] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[    1.608389] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[    1.619653] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    1.628448] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[    1.637151] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[    1.677292] mmc0: CQHCI version 5.10
[    1.703090] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    1.710697] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    1.718282] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    1.722165] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.732324] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    1.739264] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    1.751273] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    1.758771] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    1.766852] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    1.774932] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.784289] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.791783] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.799865] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.807944] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.817267] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    1.824766] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    1.832846] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    1.840924] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.849516] mmc0: Command Queue Engine enabled
[    1.853965] mmc0: new HS200 MMC card at address 0001
[    1.859259] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[    1.863913] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[    1.869961] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[    1.870156] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.875964] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[    1.896073]  mmcblk0: p1
[    1.896282] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    1.911786] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    1.911998] mmc1: CQHCI version 5.10
[    1.919283] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    1.930926] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    1.939010] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.948279] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.955771] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.963850] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.971934] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.981268] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    1.988755] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    1.996837] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.004916] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.015267] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.022758] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.030838] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.038919] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.048271] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.055765] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.063843] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.071923] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.081287] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.088782] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.096862] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.104943] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.113432] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    2.120729] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    2.129132] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    2.136467] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    2.143783] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    2.151090] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    2.159445] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.167356] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.174859] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.182946] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.191036] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.201176] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.208676] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.216761] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.224847] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.235099] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.242596] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.250680] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.258766] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.326172] ALSA device list:
[    2.329143]   No soundcards found.
[    2.975209] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    2.984297] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.991803] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.999894] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.008010] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.016428] Waiting for root device PARTUUID=9b3b485d-06...
[    3.017353] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.029535] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.037675] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.045767] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.055275] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.062780] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.070869] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.078984] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.111601] mmc1: new high speed SDHC card at address aaaa
[    3.117456] mmcblk1: mmc1:aaaa SD32G 29.7 GiB
[    3.128543]  mmcblk1: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 > p4
[    3.137284] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.144794] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.152876] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.160959] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.170288] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.177806] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.185886] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.193970] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.203284] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.210781] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.218860] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.226941] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.274832] EXT4-fs (mmcblk1p6): recovery complete
[    3.280600] EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: (null)
[    3.288708] VFS: Mounted root (ext4 filesystem) on device 179:102.
[    3.295625] devtmpfs: mounted
[    3.299479] Freeing unused kernel memory: 1856K
[    3.304105] Run /sbin/init as init process
[    3.308191]   with arguments:
[    3.308193]     /sbin/init
[    3.308195]   with environment:
[    3.308197]     HOME=/
[    3.308199]     TERM=linux
[    3.606312] systemd[1]: System time before build time, advancing clock.
[    3.679065] NET: Registered protocol family 10
[    3.683954] Segment Routing with IPv6
[    3.733229] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLK)
[    3.754959] systemd[1]: Detected architecture arm64.
[    3.790986] systemd[1]: Set hostname to <j7-evm>.
[    4.040714] systemd[1]: /lib/systemd/system/irqbalanced.service:6: Unknown key name 'ConditionCPUs' in section 'Unit', ignoring.
[    4.065043] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock \xe2\x86\x92 /run/docker.
[    4.137086] random: systemd: uninitialized urandom read (16 bytes read)
[    4.145442] systemd[1]: Created slice system-getty.slice.
[    4.166492] random: systemd: uninitialized urandom read (16 bytes read)
[    4.173885] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.194435] random: systemd: uninitialized urandom read (16 bytes read)
[    4.201691] systemd[1]: Created slice User and Session Slice.
[    4.222569] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.246486] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.270528] systemd[1]: Reached target Paths.
[    4.286426] systemd[1]: Reached target Remote File Systems.
[    4.306412] systemd[1]: Reached target Slices.
[    4.322416] systemd[1]: Reached target Swap.
[    4.354810] systemd[1]: Listening on RPCbind Server Activation Socket.
[    4.378509] systemd[1]: Reached target RPC Port Mapper.
[    4.400872] systemd[1]: Listening on Process Core Dump Socket.
[    4.422583] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    4.448097] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    4.456465] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.478682] systemd[1]: Listening on Journal Socket.
[    4.494734] systemd[1]: Listening on Network Service Netlink Socket.
[    4.518643] systemd[1]: Listening on udev Control Socket.
[    4.538557] systemd[1]: Listening on udev Kernel Socket.
[    4.560768] systemd[1]: Mounting Huge Pages File System...
[    4.580733] systemd[1]: Mounting POSIX Message Queue File System...
[    4.604742] systemd[1]: Mounting Kernel Debug File System...
[    4.625326] systemd[1]: Mounting Temporary Directory (/tmp)...
[    4.644953] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    4.680776] systemd[1]: Starting Start psplash boot splash screen...
[    4.709482] systemd[1]: Starting RPC Bind...
[    4.722598] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    4.734955] systemd[1]: Starting Journal Service...
[    4.762225] systemd[1]: Starting Load Kernel Modules...
[    4.776982] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.794556] cryptodev: loading out-of-tree module taints kernel.
[    4.797529] EXT4-fs (mmcblk1p6): re-mounted. Opts: (null)
[    4.808739] systemd[1]: Starting udev Coldplug all Devices...
[    4.815609] cryptodev: driver 1.10 loaded.
[    4.837525] systemd[1]: Started RPC Bind.
[    4.854762] systemd[1]: Started Journal Service.
[    5.076756] systemd-journald[170]: Received client request to flush runtime journal.
[    5.175389] random: systemd: uninitialized urandom read (16 bytes read)
[    5.187055] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    5.238839] random: systemd: uninitialized urandom read (16 bytes read)
[    5.654506] random: crng init done
[    5.658883] random: 60 urandom warning(s) missed due to ratelimiting
[    5.665541] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    5.674532] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    5.685168] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    5.699236] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.711342] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    5.721764] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    5.730477] ina2xx 4-0040: error configuring the device: -121
[    5.730985] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    5.744501] ina2xx 4-0041: error configuring the device: -121
[    5.745016] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.758581] ina2xx 4-0042: error configuring the device: -121
[    5.764564] ina2xx 4-0043: error configuring the device: -121
[    5.770460] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    5.778064] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    5.786198] ina2xx 4-0044: error configuring the device: -121
[    5.792000] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    5.800145] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.809414] ina2xx 4-0045: error configuring the device: -121
[    5.815331] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    5.823056] ina2xx 4-0046: error configuring the device: -121
[    5.828847] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    5.836975] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    5.845084] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.853560] ina2xx 4-0047: error configuring the device: -121
[    5.859902] ina2xx 4-0048: error configuring the device: -121
[    5.865813] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    5.873540] ina2xx 4-0049: error configuring the device: -121
[    5.879334] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    5.887492] ina2xx 4-004a: error configuring the device: -121
[    5.887516] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    5.901357] ina2xx 4-004b: error configuring the device: -121
[    5.902293] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.915417] ina2xx 4-004c: error configuring the device: -121
[    5.916339] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    5.928708] ina2xx 4-004d: error configuring the device: -121
[    5.928749] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    5.942596] ina2xx 4-004e: error configuring the device: -121
[    5.942653] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    5.956469] ina2xx 4-004f: error configuring the device: -121
[    5.956483] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.010228] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    6.017805] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    6.026879] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    6.038619] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.050875] CAN device driver interface
[    6.056341] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    6.065193] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    6.075520] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    6.084562] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.097192] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    6.105937] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    6.118961] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    6.130763] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.146314] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    6.155523] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    6.164377] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    6.173005] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.183259] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    6.190869] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    6.199966] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    6.208683] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.218438] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    6.226013] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    6.235486] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    6.244262] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.259792] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[    6.283426] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    6.288170] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
[    6.291309] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    6.309922] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    6.318937] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.323679] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    6.343694] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[    6.350691] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    6.353123] remoteproc remoteproc0: 4d80800000.dsp is available
[    6.362405] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    6.365466] remoteproc remoteproc0: attaching to 4d80800000.dsp
[    6.372330] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    6.379355] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[    6.386327] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.395311] PVR_K:  192: Read BVNC 22.104.208.318 from HW device registers
[    6.402285]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[    6.409557] platform 41000000.r5f: configured R5F for IPC-only mode
[    6.417708] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    6.433017] virtio_rpmsg_bus virtio0: rpmsg host is online
[    6.435432] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[    6.438634] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    6.448214] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[    6.454810] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    6.470057] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.479180] PVR_K:  192: RGX Device registered with BVNC 22.104.208.318
[    6.479479]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[    6.486695] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[    6.501311] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
[    6.509318] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    6.516856] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    6.524995] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    6.527577] img_enc 4200000.video-encoder: encoder registered as /dev/video0
[    6.533110] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.548967] remoteproc remoteproc1: 41000000.r5f is available
[    6.552283] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
[    6.556690] remoteproc remoteproc1: attaching to 41000000.r5f
[    6.568336] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    6.574552] platform 41000000.r5f: R5F core initialized in IPC-only mode
[    6.575852] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    6.584402]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[    6.590610] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    6.600790] virtio_rpmsg_bus virtio1: rpmsg host is online
[    6.613641] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.615125]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[    6.628277] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    6.631079] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
[    6.636547] img_dec 4300000.video-decoder: decoder registered as /dev/video1
[    6.647354] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[    6.650419] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    6.669155] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[    6.671223] platform 5c00000.r5f: configured R5F for IPC-only mode
[    6.676012] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    6.682743] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    6.698402] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.699320] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    6.710627] remoteproc remoteproc2: 4d81800000.dsp is available
[    6.724060] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    6.734075] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    6.749339] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    6.762766] remoteproc remoteproc3: 5c00000.r5f is available
[    6.768538] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.783229] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    6.796491] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    6.812403] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    6.825720] remoteproc remoteproc2: attaching to 4d81800000.dsp
[    6.831800] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.844268] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    6.858437] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    6.874190] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    6.890697] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.915526] remoteproc remoteproc3: attaching to 5c00000.r5f
[    6.918536] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[    6.936867]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[    6.938592] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[    6.953737] virtio_rpmsg_bus virtio2: rpmsg host is online
[    6.967501]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[    6.969087] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
[    6.976173] remoteproc remoteproc2: remote processor 4d81800000.dsp is now attached
[    6.988530] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    6.996308] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    7.004473] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    7.019030]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    7.028486] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.038433] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    7.050478] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[    7.060010] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    7.068253] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    7.080287] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.092990] virtio_rpmsg_bus virtio3: rpmsg host is online
[    7.100258] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    7.113185] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    7.117235] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[    7.125118]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[    7.134556] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    7.137170] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
[    7.142770] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.151147] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[    7.165825] remoteproc remoteproc4: 64800000.dsp is available
[    7.172567] platform 5d00000.r5f: configured R5F for IPC-only mode
[    7.178990] remoteproc remoteproc4: attaching to 64800000.dsp
[    7.185435] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    7.187987] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    7.195315] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    7.213118] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    7.213725] remoteproc remoteproc4: unsupported resource 65538
[    7.226409] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.237288] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    7.245617] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    7.254165] remoteproc remoteproc5: 5d00000.r5f is available
[    7.259955] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    7.268158] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.277291] remoteproc remoteproc5: attaching to 5d00000.r5f
[    7.283135] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    7.290731] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    7.291112] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[    7.298866] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    7.298877] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.320836] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[    7.383029]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[    7.412255]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[    7.426624] virtio_rpmsg_bus virtio4: rpmsg host is online
[    7.433326] virtio_rpmsg_bus virtio5: rpmsg host is online
[    7.434657] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[    7.441786]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[    7.452984] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached
[    7.453025]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[    7.460544] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    7.466568] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[    7.474847] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    7.484546] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[    7.490901] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    7.506337] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.512533] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[    7.515402] remoteproc remoteproc4: remote processor 64800000.dsp is now attached
[    7.530525] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[    7.537809] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[    7.537824] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    7.553497] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    7.558511] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
[    7.561848] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    7.577055] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.578742] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
[    7.597353] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    7.604278] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x20
[    7.610399] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    7.618478] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x21
[    7.620118] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    7.634549] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[    7.635390] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.645648] platform 5e00000.r5f: configured R5F for remoteproc mode
[    7.657103] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[    7.664970] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    7.672276] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    7.678476] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[    7.682399] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    7.695419] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    7.702513] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xa
[    7.703606] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.717710] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[    7.726513] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    7.736265] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[    7.738457] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    7.753577] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    7.761728] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.764757] remoteproc remoteproc6: 5e00000.r5f is available
[    7.798406] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[    7.811553] remoteproc remoteproc6: powering up 5e00000.r5f
[    7.821024] platform 5f00000.r5f: configured R5F for remoteproc mode
[    7.827472] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[    7.838417] remoteproc remoteproc6: request_firmware failed: -2
[    7.847426] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[    7.887198] remoteproc remoteproc7: 5f00000.r5f is available
[    7.936238] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[    7.950437] remoteproc remoteproc7: powering up 5f00000.r5f
[    7.965136] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[    7.981257] remoteproc remoteproc7: request_firmware failed: -2
[    7.994465] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    8.004430] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    8.020192] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    8.036026] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.056378] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    8.067776] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    8.080861] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.092919] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.108281] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.121096] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    8.134512] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    8.147924] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.403322] EXT4-fs (mmcblk1p11): recovery complete
[    8.408405] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: (null)
[    8.420216] EXT4-fs (mmcblk1p12): recovery complete
[    8.425521] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: (null)
[    9.174283] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.184866] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.196844] remoteproc remoteproc8: b034000.pru is available
[    9.202554] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.213919] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.234310] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.242400] FAT-fs (mmcblk1p4): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    9.252402] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.260546] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.278895] usbcore: registered new interface driver usbfs
[    9.287283] remoteproc remoteproc9: b004000.rtu is available
[    9.290100] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.311562] usbcore: registered new interface driver hub
[    9.314516] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.323628] remoteproc remoteproc10: b00a000.txpru is available
[    9.337799] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.339161] remoteproc remoteproc11: b038000.pru is available
[    9.347813] usbcore: registered new device driver usb
[    9.352539] remoteproc remoteproc12: b006000.rtu is available
[    9.357287] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.363153] remoteproc remoteproc13: b00c000.txpru is available
[    9.377359] remoteproc remoteproc14: b134000.pru is available
[    9.381004] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.383479] remoteproc remoteproc15: b104000.rtu is available
[    9.397601] remoteproc remoteproc16: b10a000.txpru is available
[    9.403953] remoteproc remoteproc17: b138000.pru is available
[    9.409875] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.410077] remoteproc remoteproc18: b106000.rtu is available
[    9.422534] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.423522] remoteproc remoteproc19: b10c000.txpru is available
[    9.437328] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.450430] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.473430] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    9.486541] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.498911] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.507858] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.517889] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.531237] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.538835] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.548294] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.556956] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.570104] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.577697] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.579825] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[    9.590392] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.602520] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.619265] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.626969] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.640438] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.652313] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.672582] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.682008] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.692197] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.700991] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.714582] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.725391] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.738062] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.750675] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.767386] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.775213] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.783358] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.791473] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.010189] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: (null)
[   10.018389] ext4 filesystem being mounted at /run/media/mmcblk1p10 supports timestamps until 2038 (0x7fffffff)
[   10.401189] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.412846] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.421737] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.430204] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.441166] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.449147] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.457599] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.465747] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.478865] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.488800] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.502316] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.511658] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.526507] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.534072] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.542216] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.550548] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.568549] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   10.574095] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   10.581933] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[   10.591448] xhci-hcd xhci-hcd.2.auto: irq 643, io mem 0x06410000
[   10.597714] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   10.606095] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.613321] usb usb1: Product: xHCI Host Controller
[   10.618195] usb usb1: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
[   10.624812] usb usb1: SerialNumber: xhci-hcd.2.auto
[   10.630446] hub 1-0:1.0: USB hub found
[   10.634213] hub 1-0:1.0: 1 port detected
[   10.638685] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   10.644320] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.646377] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[   10.651834] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.660127] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   10.668756] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.674346] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   10.682625] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.690356] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   10.703333] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.706767] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.714850] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.721515] usb usb2: Product: xHCI Host Controller
[   10.729904] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.734408] usb usb2: Manufacturer: Linux 5.10.162-g76b3e88d56 xhci-hcd
[   10.734410] usb usb2: SerialNumber: xhci-hcd.2.auto
[   10.735719] hub 2-0:1.0: USB hub found
[   10.742784] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.749933] hub 2-0:1.0: 1 port detected
[   10.755346] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.777599] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.785797] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.793941] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.803812] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.811380] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.820301] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.828833] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.838684] EXT4-fs (mmcblk1p7): mounted filesystem with ordered data mode. Opts: (null)
[   10.842343] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.854529] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.868171] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.878479] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.889148] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.899683] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.910749] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.914399] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[   10.924153] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.066457] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: (null)
[   11.094666] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[   11.102999] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[   11.110191] usb 1-1: SerialNumber: 39010849A119
[   11.115354] hub 1-1:1.0: USB hub found
[   11.119183] hub 1-1:1.0: 4 ports detected
[   11.131452] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   11.141617] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   11.156293] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   11.165374] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.177834] EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: (null)
[   11.190763] ext4 filesystem being mounted at /run/media/mmcblk1p5 supports timestamps until 2038 (0x7fffffff)
[   11.205945] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.219151] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.227476] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.235672] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.245372] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.252929] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.259826] EXT4-fs (mmcblk1p8): mounted filesystem with ordered data mode. Opts: (null)
[   11.266410] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.269244] ext4 filesystem being mounted at /run/media/mmcblk1p8 supports timestamps until 2038 (0x7fffffff)
[   11.277741] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.308166] Bluetooth: Core ver 2.22
[   12.313705] NET: Registered protocol family 31
[   12.318278] Bluetooth: HCI device and connection manager initialized
[   12.328091] Bluetooth: HCI socket layer initialized
[   12.334809] Bluetooth: L2CAP socket layer initialized
[   12.339890] Bluetooth: SCO socket layer initialized
[   13.388968] PVR_K:  1097: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[   13.433575] PVR_K:  1097: Shader binary image 'rgx.sh.22.104.208.318' loaded
[   13.661385] EXT4-fs (mmcblk1p6): re-mounted. Opts: (null)
[   30.847029] ========== chunshuang: synaptics_rmi4_i2c_probe(): >>>
[   30.854431] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   30.855164] ========== chunshuang: synaptics_rmi4_probe(): >>>
[   30.865134] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   30.876002] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   30.876485] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_set_page: I2C retry 1
[   30.884140] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   30.904266] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   30.911850] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   30.919975] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   30.928196] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_set_page: I2C retry 2
[   30.931119] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   30.950580] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   30.962427] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   30.970604] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   30.978763] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   30.978766] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_set_page: I2C retry 3
[   31.006517] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_set_page: I2C retry 4
[   31.038458] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_set_page: I2C retry 5
[   31.070525] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_set_page: I2C retry 6
[   31.102431] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_set_page: I2C retry 7
[   31.134417] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_set_page: I2C retry 8
[   31.166407] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_set_page: I2C retry 9
[   31.198416] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_set_page: I2C retry 10
[   31.230407] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C retry 1
[   31.262406] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C retry 2
[   31.294420] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C retry 3
[   31.326405] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C retry 4
[   31.358405] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C retry 5
[   31.390409] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C retry 6
[   31.434362] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C retry 7
[   31.478362] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C retry 8
[   31.522361] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C retry 9
[   31.566361] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C retry 10
[   31.598359] synaptics_dsx_i2c 3-0020: synaptics_rmi4_i2c_read: I2C read over retry limit
[   31.606439] synaptics_dsx_i2c 3-0020: synaptics_rmi4_set_input_dev: Failed to query device
[   31.614697] synaptics_dsx synaptics_dsx.0: synaptics_rmi4_probe: Failed to set up input device
[   31.623315] synaptics_dsx: probe of synaptics_dsx.0 failed with error -5
[  132.836759] Initializing XFRM netlink socket
This is mem dts:
// SPDX-License-Identifier: GPL-2.0
 * Vision-apps: device-tree overlay
 * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/
#include <dt-bindings/soc/ti,sci_pm_domain.h>
	dma_buf_phys {
		compatible = "ti,dma-buf-phys";
&mcu_r5fss0_core0_memory_region {
	status = "disabled";
&mcu_r5fss0_core0_dma_memory_region {
&mcu_r5fss0_core1_dma_memory_region {
&mcu_r5fss0_core1_memory_region {
&main_r5fss0_core0_dma_memory_region {
&main_r5fss0_core0_memory_region {
&main_r5fss0_core1_dma_memory_region {
&main_r5fss0_core1_memory_region {
&main_r5fss1_core0_dma_memory_region {
&main_r5fss1_core0_memory_region {
&main_r5fss1_core1_dma_memory_region {
&main_r5fss1_core1_memory_region {
&c66_0_dma_memory_region {
&c66_0_memory_region {
&c66_1_dma_memory_region {
&c66_1_memory_region {
&c71_0_dma_memory_region {
&c71_0_memory_region {
&rtos_ipc_memory_region {
&reserved_memory {
	#address-cells = <2>;
	#size-cells = <2>;
	vision_apps_mcu_r5fss0_core0_dma_memory_region: vision-apps-r5f-dma-memory@a0000000 {
		compatible = "shared-dma-pool";
		reg = <0x00 0xa0000000 0x00 0x00100000>;
		no-map;
	vision_apps_mcu_r5fss0_core0_memory_region: vision-apps-r5f-memory@a0100000 {
		reg = <0x00 0xa0100000 0x00 0x00f00000>;
		no-map;
	vision_apps_mcu_r5fss0_core1_dma_memory_region: vision-apps-r5f-dma-memory@a1000000 {
		reg = <0x00 0xa1000000 0x00 0x00100000>;
		no-map;
	vision_apps_mcu_r5fss0_core1_memory_region: vision-apps-r5f-memory@a1100000 {
		reg = <0x00 0xa1100000 0x00 0x00f00000>;
		no-map;
	vision_apps_main_r5fss0_core0_dma_memory_region: vision-apps-r5f-dma-memory@a2000000 {
		reg = <0x00 0xa2000000 0x00 0x00100000>;
		no-map;
	vision_apps_main_r5fss0_core0_memory_region: vision-apps-r5f-memory@a2100000 {
		reg = <0x00 0xa2100000 0x00 0x01f00000>;
		no-map;
	vision_apps_main_r5fss0_core1_dma_memory_region: vision-apps-r5f-dma-memory@a4000000 {
		reg = <0x00 0xa4000000 0x00 0x00100000>;
		no-map;
	vision_apps_main_r5fss0_core1_memory_region: vision-apps-r5f-memory@a4100000 {
		reg = <0x00 0xa4100000 0x00 0x01f00000>;
		no-map;
	vision_apps_main_r5fss1_core0_dma_memory_region: vision-apps-r5f-dma-memory@a6000000 {
		reg = <0x00 0xa6000000 0x00 0x00100000>;
		no-map;
	vision_apps_main_r5fss1_core0_memory_region: vision-apps-r5f-memory@a6100000 {
		reg = <0x00 0xa6100000 0x00 0x00f00000>;
		no-map;
	vision_apps_main_r5fss1_core1_dma_memory_region: vision-apps-r5f-dma-memory@a7000000 {
		reg = <0x00 0xa7000000 0x00 0x00100000>;
		no-map;
	vision_apps_main_r5fss1_core1_memory_region: vision-apps-r5f-memory@a7100000 {
		reg = <0x00 0xa7100000 0x00 0x00f00000>;
		no-map;
	vision_apps_c66_1_dma_memory_region: vision-apps-c66-dma-memory@a8000000 {
		reg = <0x00 0xa8000000 0x00 0x00100000>;
		no-map;
	vision_apps_c66_0_memory_region: vision-apps-c66-memory@a8100000 {
		reg = <0x00 0xa8100000 0x00 0x00f00000>;
		no-map;
	vision_apps_c66_0_dma_memory_region: vision-apps-c66-dma-memory@a9000000 {
		reg = <0x00 0xa9000000 0x00 0x00100000>;
		no-map;
	vision_apps_c66_1_memory_region: vision-apps-c66-memory@a9100000 {
		reg = <0x00 0xa9100000 0x00 0x00f00000>;
		no-map;
	vision_apps_rtos_ipc_memory_region: vision-apps-rtos-ipc-memory-region {
		reg = <0x00 0xaa000000 0x00 0x02000000>;
		alignment = <0x1000>;
		no-map;
	vision_apps_memory_region: vision-apps-dma-memory@ac000000 {
		reg = <0x00 0xac000000 0x00 0x06000000>;
		no-map;
	vision_apps_c71_0_dma_memory_region: vision-apps-c71-dma-memory@b2000000 {
		reg = <0x00 0xb2000000 0x00 0x00100000>;
		no-map;
	vision_apps_c71_0_memory_region: vision-apps-c71-memory@b2100000 {
		reg = <0x00 0xb2100000 0x00 0x05f00000>;
		no-map;
	vision_apps_shared_region: vision_apps_shared-memories {
		compatible = "dma-heap-carveout";
		reg = <0x00 0xb8000000 0x00 0x20000000>;
	vision_apps_core_heaps_lo: vision-apps-core-heap-memory-lo@d8000000 {
		reg = <0x00 0xd8000000 0x00 0x0c000000>;
		no-map;
	vision_apps_main_r5fss0_core0_shared_memory_queue_region: vision-apps-r5f-virtual-eth-queues@e4000000 {
		reg = <0x00 0xe4000000 0x00 0x00800000>;
		no-map;
	vision_apps_main_r5fss0_core0_shared_memory_bufpool_region: vision-apps-r5f-virtual-eth-buffers@e4800000 {
		reg = <0x00 0xe4800000 0x00 0x01800000>;
		no-map;
	vision_apps_core_heaps_hi: vision-apps-core-heap-memory-hi@880000000 {
		reg = <0x08 0x80000000 0x00 0x27000000>;
		no-map;
&mcu_r5fss0_core0 {
	memory-region = <&vision_apps_mcu_r5fss0_core0_dma_memory_region>,
			<&vision_apps_mcu_r5fss0_core0_memory_region>;
&mcu_r5fss0_core1 {
	memory-region = <&vision_apps_mcu_r5fss0_core1_dma_memory_region>,
			<&vision_apps_mcu_r5fss0_core1_memory_region>;
&main_r5fss0_core0 {
	memory-region = <&vision_apps_main_r5fss0_core0_dma_memory_region>,
			<&vision_apps_main_r5fss0_core0_memory_region>,
			<&vision_apps_main_r5fss0_core0_shared_memory_queue_region>,
			<&vision_apps_main_r5fss0_core0_shared_memory_bufpool_region>;
&main_r5fss0_core1 {
	memory-region = <&vision_apps_main_r5fss0_core1_dma_memory_region>,
			<&vision_apps_main_r5fss0_core1_memory_region>;
&main_r5fss1_core0 {
	memory-region = <&vision_apps_main_r5fss1_core0_dma_memory_region>,
			<&vision_apps_main_r5fss1_core0_memory_region>;
&main_r5fss1_core1 {
	memory-region = <&vision_apps_main_r5fss1_core1_dma_memory_region>,
			<&vision_apps_main_r5fss1_core1_memory_region>;
&c66_0 {
	memory-region = <&vision_apps_c66_0_dma_memory_region>,
			<&vision_apps_c66_0_memory_region>;
&c66_1 {
	memory-region = <&vision_apps_c66_1_dma_memory_region>,
			<&vision_apps_c66_1_memory_region>;
&c71_0 {
	memory-region = <&vision_apps_c71_0_dma_memory_region>,
			<&vision_apps_c71_0_memory_region>;
This k3-j721e-wkup.dts:
 * Device Tree Source for J721E SoC Family MCU/WAKEUP Domain peripherals
 * Copyright (C) 2016-2020 Texas Instruments Incorporated - https://www.ti.com/
&cbass_mcu_wakeup {
	dmsc: system-controller@44083000 {
		compatible = "ti,k2g-sci";
		ti,host-id = <12>;
		mbox-names = "rx", "tx";
		mboxes = <&secure_proxy_main 11>,
			 <&secure_proxy_main 13>;
		reg-names = "debug_messages";
		reg = <0x00 0x44083000 0x0 0x1000>;
		k3_pds: power-controller {
			compatible = "ti,sci-pm-domain";
			#power-domain-cells = <2>;
		k3_clks: clock-controller {
			compatible = "ti,k2g-sci-clk";
			#clock-cells = <2>;
		k3_reset: reset-controller {
			compatible = "ti,sci-reset";
			#reset-cells = <2>;
	mcu_conf: syscon@40f00000 {
		compatible = "syscon", "simple-mfd";
		reg = <0x0 0x40f00000 0x0 0x20000>;
		#address-cells = <1>;
		#size-cells = <1>;
		ranges = <0x0 0x0 0x40f00000 0x20000>;
		phy_gmii_sel: phy@4040 {
			compatible = "ti,am654-phy-gmii-sel";
			reg = <0x4040 0x4>;
			#phy-cells = <1>;
	chipid@43000014 {
		compatible = "ti,am654-chipid";
		reg = <0x0 0x43000014 0x0 0x4>;
	wkup_pmx0: pinctrl@4301c000 {
		compatible = "pinctrl-single";
		/* Proxy 0 addressing */
		reg = <0x00 0x4301c000 0x00 0x178>;
		#pinctrl-cells = <1>;
		pinctrl-single,register-width = <32>;
		pinctrl-single,function-mask = <0xffffffff>;
	mcu_ram: sram@41c00000 {
		compatible = "mmio-sram";
		reg = <0x00 0x41c00000 0x00 0x100000>;
		ranges = <0x0 0x00 0x41c00000 0x100000>;
		#size-cells = <1>;
	wkup_uart0: serial@42300000 {
		compatible = "ti,j721e-uart", "ti,am654-uart";
		reg = <0x00 0x42300000 0x00 0x100>;
		interrupts = <GIC_SPI 897 IRQ_TYPE_LEVEL_HIGH>;
		clock-frequency = <48000000>;
		current-speed = <115200>;
		power-domains = <&k3_pds 287 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 287 0>;
		clock-names = "fclk";
	mcu_uart0: serial@40a00000 {
		reg = <0x00 0x40a00000 0x00 0x100>;
		interrupts = <GIC_SPI 846 IRQ_TYPE_LEVEL_HIGH>;
		clock-frequency = <96000000>;
		power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 149 0>;
	wkup_gpio_intr: interrupt-controller@42200000 {
		compatible = "ti,sci-intr";
		reg = <0x00 0x42200000 0x00 0x400>;
		ti,intr-trigger-type = <1>;
		interrupt-controller;
		interrupt-parent = <&gic500>;
		#interrupt-cells = <1>;
		ti,sci = <&dmsc>;
		ti,sci-dev-id = <137>;
		ti,interrupt-ranges = <16 960 16>;
	wkup_gpio0: gpio@42110000 {
		compatible = "ti,j721e-gpio", "ti,keystone-gpio";
		reg = <0x0 0x42110000 0x0 0x100>;
		gpio-controller;
		#gpio-cells = <2>;
		interrupt-parent = <&wkup_gpio_intr>;
		interrupts = <103>, <104>, <105>, <106>, <107>, <108>;
		#interrupt-cells = <2>;
		ti,ngpio = <84>;
		ti,davinci-gpio-unbanked = <0>;
		power-domains = <&k3_pds 113 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 113 0>;
		clock-names = "gpio";
	wkup_gpio1: gpio@42100000 {
		reg = <0x0 0x42100000 0x0 0x100>;
		gpio-controller;
		#gpio-cells = <2>;
		interrupts = <112>, <113>, <114>, <115>, <116>, <117>;
		ti,ngpio = <84>;
		power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 114 0>;
	mcu_i2c0: i2c@40b00000 {
		compatible = "ti,j721e-i2c", "ti,omap4-i2c";
		reg = <0x0 0x40b00000 0x0 0x100>;
		interrupts = <GIC_SPI 852 IRQ_TYPE_LEVEL_HIGH>;
		#size-cells = <0>;
		clock-names = "fck";
		clocks = <&k3_clks 194 0>;
		power-domains = <&k3_pds 194 TI_SCI_PD_EXCLUSIVE>;
	mcu_i2c1: i2c@40b10000 {
		reg = <0x0 0x40b10000 0x0 0x100>;
		interrupts = <GIC_SPI 853 IRQ_TYPE_LEVEL_HIGH>;
		#size-cells = <0>;
		clocks = <&k3_clks 195 0>;
		power-domains = <&k3_pds 195 TI_SCI_PD_EXCLUSIVE>;
	wkup_i2c0: i2c@42120000 {
		reg = <0x0 0x42120000 0x0 0x100>;
		interrupts = <GIC_SPI 896 IRQ_TYPE_LEVEL_HIGH>;
		#size-cells = <0>;
		clocks = <&k3_clks 197 0>;
		power-domains = <&k3_pds 197 TI_SCI_PD_SHARED>;
	fss: fss@47000000 {
		compatible = "ti,j721e-system-controller", "syscon", "simple-mfd";
		reg = <0x0 0x47000000 0x0 0x100>;
		#size-cells = <2>;
		ranges;
		hbmc_mux: mux-controller@47000004 {
			compatible = "mmio-mux";
			#mux-control-cells = <1>;
			mux-reg-masks = <0x4 0x2>; /* HBMC select */
		hbmc: hyperbus@47034000 {
			compatible = "ti,am654-hbmc";
			reg = <0x00 0x47034000 0x00 0x100>,
				<0x05 0x00000000 0x01 0x0000000>;
			power-domains = <&k3_pds 102 TI_SCI_PD_EXCLUSIVE>;
			clocks = <&k3_clks 102 0>;
			assigned-clocks = <&k3_clks 102 5>;
			assigned-clock-rates = <333333333>;
			#size-cells = <1>;
			mux-controls = <&hbmc_mux 0>;
		ospi0: spi@47040000 {
			compatible = "ti,am654-ospi", "cdns,qspi-nor";
			reg = <0x0 0x47040000 0x0 0x100>,
				<0x5 0x00000000 0x1 0x0000000>;
			interrupts = <GIC_SPI 840 IRQ_TYPE_LEVEL_HIGH>;
			cdns,fifo-depth = <256>;
			cdns,fifo-width = <4>;
			cdns,trigger-address = <0x0>;
			clocks = <&k3_clks 103 0>;
			assigned-clocks = <&k3_clks 103 0>;
			assigned-clock-parents = <&k3_clks 103 2>;
			assigned-clock-rates = <166666666>;
			power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>;
			#size-cells = <0>;
		ospi1: spi@47050000 {
			reg = <0x0 0x47050000 0x0 0x100>,
				<0x7 0x00000000 0x1 0x00000000>;
			interrupts = <GIC_SPI 841 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&k3_clks 104 0>;
			power-domains = <&k3_pds 104 TI_SCI_PD_EXCLUSIVE>;
			#size-cells = <0>;
	tscadc0: tscadc@40200000 {
		compatible = "ti,am3359-tscadc";
		reg = <0x0 0x40200000 0x0 0x1000>;
		interrupts = <GIC_SPI 860 IRQ_TYPE_LEVEL_HIGH>;
		power-domains = <&k3_pds 0 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 0 1>;
		assigned-clocks = <&k3_clks 0 3>;
		assigned-clock-rates = <60000000>;
		clock-names = "adc_tsc_fck";
		dmas = <&main_udmap 0x7400>,
			<&main_udmap 0x7401>;
		dma-names = "fifo0", "fifo1";
		adc {
			#io-channel-cells = <1>;
			compatible = "ti,am3359-adc";
	tscadc1: tscadc@40210000 {
		reg = <0x0 0x40210000 0x0 0x1000>;
		interrupts = <GIC_SPI 861 IRQ_TYPE_LEVEL_HIGH>;
		power-domains = <&k3_pds 1 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 1 1>;
		assigned-clocks = <&k3_clks 1 3>;
		dmas = <&main_udmap 0x7402>,
			<&main_udmap 0x7403>;
		adc {
	mcu_navss: bus@28380000 {
		compatible = "simple-mfd";
		#size-cells = <2>;
		ranges = <0x00 0x28380000 0x00 0x28380000 0x00 0x03880000>;
		dma-coherent;
		dma-ranges;
		ti,sci-dev-id = <232>;
		mcu_ringacc: ringacc@2b800000 {
			compatible = "ti,am654-navss-ringacc";
			reg =	<0x0 0x2b800000 0x0 0x400000>,
				<0x0 0x2b000000 0x0 0x400000>,
				<0x0 0x28590000 0x0 0x100>,
				<0x0 0x2a500000 0x0 0x40000>;
			reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target";
			ti,num-rings = <286>;
			ti,sci-rm-range-gp-rings = <0x1>; /* GP ring range */
			ti,sci = <&dmsc>;
			ti,sci-dev-id = <235>;
			msi-parent = <&main_udmass_inta>;
		mcu_udmap: dma-controller@285c0000 {
			compatible = "ti,j721e-navss-mcu-udmap";
			reg =	<0x0 0x285c0000 0x0 0x100>,
				<0x0 0x2a800000 0x0 0x40000>,
				<0x0 0x2aa00000 0x0 0x40000>;
			reg-names = "gcfg", "rchanrt", "tchanrt";
			#dma-cells = <1>;
			ti,sci = <&dmsc>;
			ti,sci-dev-id = <236>;
			ti,ringacc = <&mcu_ringacc>;
			ti,sci-rm-range-tchan = <0x0d>, /* TX_CHAN */
						<0x0f>; /* TX_HCHAN */
			ti,sci-rm-range-rchan = <0x0a>, /* RX_CHAN */
						<0x0b>; /* RX_HCHAN */
			ti,sci-rm-range-rflow = <0x00>; /* GP RFLOW */
	mcu_cpsw: ethernet@46000000 {
		compatible = "ti,j721e-cpsw-nuss";
		#size-cells = <2>;
		reg = <0x0 0x46000000 0x0 0x200000>;
		reg-names = "cpsw_nuss";
		ranges = <0x0 0x0 0x0 0x46000000 0x0 0x200000>;
		dma-coherent;
		clocks = <&k3_clks 18 22>;
		power-domains = <&k3_pds 18 TI_SCI_PD_EXCLUSIVE>;
		dmas = <&mcu_udmap 0xf000>,
		       <&mcu_udmap 0xf001>,
		       <&mcu_udmap 0xf002>,
		       <&mcu_udmap 0xf003>,
		       <&mcu_udmap 0xf004>,
		       <&mcu_udmap 0xf005>,
		       <&mcu_udmap 0xf006>,
		       <&mcu_udmap 0xf007>,
		       <&mcu_udmap 0x7000>;
		dma-names = "tx0", "tx1", "tx2", "tx3",
			    "tx4", "tx5", "tx6", "tx7",
			    "rx";
		ethernet-ports {
			#size-cells = <0>;
			cpsw_port1: port@1 {
				reg = <1>;
				ti,mac-only;
				label = "port1";
				ti,syscon-efuse = <&mcu_conf 0x200>;
				phys = <&phy_gmii_sel 1>;
		davinci_mdio: mdio@f00 {
			compatible = "ti,cpsw-mdio","ti,davinci_mdio";
			reg = <0x0 0xf00 0x0 0x100>;
			#size-cells = <0>;
			bus_freq = <1000000>;
		cpts@3d000 {
			compatible = "ti,am65-cpts";
			reg = <0x0 0x3d000 0x0 0x400>;
			clocks = <&k3_clks 18 2>;
			clock-names = "cpts";
			interrupts-extended = <&gic500 GIC_SPI 858 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "cpts";
			ti,cpts-ext-ts-inputs = <4>;
			ti,cpts-periodic-outputs = <2>;
	mcu_r5fss0: r5fss@41000000 {
		compatible = "ti,j721e-r5fss";
		ti,cluster-mode = <0>;
		#size-cells = <1>;
		ranges = <0x41000000 0x00 0x41000000 0x20000>,
			 <0x41400000 0x00 0x41400000 0x20000>;
		power-domains = <&k3_pds 249 TI_SCI_PD_EXCLUSIVE>;
		mcu_r5fss0_core0: r5f@41000000 {
			compatible = "ti,j721e-r5f";
			reg = <0x41000000 0x00008000>,
			      <0x41010000 0x00008000>;
			reg-names = "atcm", "btcm";
			ti,sci = <&dmsc>;
			ti,sci-dev-id = <250>;
			ti,sci-proc-ids = <0x01 0xff>;
			resets = <&k3_reset 250 1>;
			firmware-name = "j7-mcu-r5f0_0-fw";
			ti,atcm-enable = <1>;
			ti,btcm-enable = <1>;
			ti,loczrama = <1>;
		mcu_r5fss0_core1: r5f@41400000 {
			reg = <0x41400000 0x00008000>,
			      <0x41410000 0x00008000>;
			ti,sci = <&dmsc>;
			ti,sci-dev-id = <251>;
			ti,sci-proc-ids = <0x02 0xff>;
			resets = <&k3_reset 251 1>;
			firmware-name = "j7-mcu-r5f0_1-fw";
			ti,loczrama = <1>;
	mcu_mcan0: can@40528000 {
		compatible = "bosch,m_can";
		reg = <0x00 0x40528000 0x00 0x200>,
		      <0x00 0x40500000 0x00 0x8000>;
		reg-names = "m_can", "message_ram";
		power-domains = <&k3_pds 172 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 172 0>, <&k3_clks 172 1>;
		clock-names = "hclk", "cclk";
		interrupts = <GIC_SPI 832 IRQ_TYPE_LEVEL_HIGH>,
			     <GIC_SPI 833 IRQ_TYPE_LEVEL_HIGH>;
		interrupt-names = "int0", "int1";
		bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>;
	mcu_mcan1: can@40568000 {
		reg = <0x00 0x40568000 0x00 0x200>,
		      <0x00 0x40540000 0x00 0x8000>;
		power-domains = <&k3_pds 173 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 173 0>, <&k3_clks 173 1>;
		interrupts = <GIC_SPI 835 IRQ_TYPE_LEVEL_HIGH>,
			     <GIC_SPI 836 IRQ_TYPE_LEVEL_HIGH>;
	mcu_spi0: spi@40300000 {
		compatible = "ti,am654-mcspi", "ti,omap4-mcspi";
		reg = <0x00 0x040300000 0x00 0x400>;
		interrupts = <GIC_SPI 848 IRQ_TYPE_LEVEL_HIGH>;
		#size-cells = <0>;
		power-domains = <&k3_pds 274 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 274 0>;
	mcu_spi1: spi@40310000 {
		reg = <0x00 0x040310000 0x00 0x400>;
		interrupts = <GIC_SPI 849 IRQ_TYPE_LEVEL_HIGH>;
		#size-cells = <0>;
		power-domains = <&k3_pds 275 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 275 0>;
	mcu_spi2: spi@40320000 {
		reg = <0x00 0x040320000 0x00 0x400>;
		interrupts = <GIC_SPI 850 IRQ_TYPE_LEVEL_HIGH>;
		#size-cells = <0>;
		power-domains = <&k3_pds 276 TI_SCI_PD_EXCLUSIVE>;
		clocks = <&k3_clks 276 0>;
	wkup_vtm0: temperature-sensor@42040000 {
		compatible = "ti,j721e-vtm";
		reg = <0x00 0x42040000 0x00 0x350>,
			<0x00 0x42050000 0x00 0x350>,
			<0x00 0x43000300 0x00 0x10>;
		power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>;
		#thermal-sensor-cells = <1>;
Pls help me to check this~
Best Regards
Eason
  • Sorry I need to update a latest log:
    Linux kernel log:
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 6.1.80-ti-g2e423244f8c0 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Mon Nov 27 16:11:04 UTC 2023
    [    0.000000] Machine model: Texas Instruments J721e EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000008e0000000, size 512 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
    [    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
    [    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
    [    0.000000] pcpu-alloc: s41064 r8192 d32664 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: Spectre-v3a
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=33423791-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] Memory: 1695676K/4194304K available (11712K kernel code, 1258K rwdata, 3816K rodata, 1984K init, 438K bss, 1974340K reserved, 524288K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008a7030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.010526] Console: colour dummy device 80x25
    [    0.016238] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.029577] pid_max: default: 32768 minimum: 301
    [    0.035497] LSM: Security Framework initializing
    [    0.041466] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.050935] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.061933] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.071183] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.079013] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.088245] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.096132] rcu: Hierarchical SRCU implementation.
    [    0.102254] rcu:     Max phase no-delay instances is 1000.
    [    0.109152] Platform MSI: msi-controller@1820000 domain created
    [    0.116990] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.128782] EFI services will not be available.
    [    0.134707] smp: Bringing up secondary CPUs ...
    [    0.151290] Detected PIPT I-cache on CPU1
    [    0.151367] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.151384] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000
    [    0.151423] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.151484] smp: Brought up 1 node, 2 CPUs
    [    0.188166] SMP: Total of 2 processors activated.
    [    0.194172] CPU features: detected: 32-bit EL0 Support
    [    0.200739] CPU features: detected: CRC32 instructions
    [    0.207335] CPU: All CPU(s) started at EL2
    [    0.212561] alternatives: applying system-wide alternatives
    [    0.220786] devtmpfs: initialized
    [    0.233706] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.246177] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.265641] pinctrl core: initialized pinctrl subsystem
    [    0.272722] DMI not present or invalid.
    [    0.278029] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.286330] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.295472] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.305479] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.315636] audit: initializing netlink subsys (disabled)
    [    0.322671] audit: type=2000 audit(0.172:1): state=initialized audit_enabled=0 res=1
    [    0.322952] thermal_sys: Registered thermal governor 'step_wise'
    [    0.332569] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.340325] cpuidle: using governor menu
    [    0.353765] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.362466] ASID allocator initialised with 65536 entries
    [    0.379987] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
    [    0.394446] KASLR disabled due to lack of seed
    [    0.403655] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.412336] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.420339] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.429006] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.437008] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.445675] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.453680] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.462347] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.471242] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
    [    0.482905] iommu: Default domain type: Translated
    [    0.489134] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.497286] SCSI subsystem initialized
    [    0.502159] libata version 3.00 loaded.
    [    0.502271] usbcore: registered new interface driver usbfs
    [    0.509295] usbcore: registered new interface driver hub
    [    0.516092] usbcore: registered new device driver usb
    [    0.522804] pps_core: LinuxPPS API ver. 1 registered
    [    0.529144] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.540815] PTP clock support registered
    [    0.545914] EDAC MC: Ver: 3.0.0
    [    0.550556] FPGA manager framework
    [    0.554945] Advanced Linux Sound Architecture Driver Initialized.
    [    0.563202] clocksource: Switched to clocksource arch_sys_counter
    [    0.571138] VFS: Disk quotas dquot_6.6.0
    [    0.576171] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.588595] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.596461] NET: Registered PF_INET protocol family
    [    0.602923] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.614195] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.625160] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.635061] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.645316] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [    0.656110] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.664596] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.673229] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.682537] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.690143] RPC: Registered named UNIX socket transport module.
    [    0.697712] RPC: Registered udp transport module.
    [    0.703716] RPC: Registered tcp transport module.
    [    0.709718] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.717949] NET: Registered PF_XDP protocol family
    [    0.724074] PCI: CLS 0 bytes, default 64
    [    0.729499] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.740873] Initialise system trusted keyrings
    [    0.746691] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.757358] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.765161] NFS: Registering the id_resolver key type
    [    0.771636] Key type id_resolver registered
    [    0.776976] Key type id_legacy registered
    [    0.782122] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.790683] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.825218] Key type asymmetric registered
    [    0.830449] Asymmetric key parser 'x509' registered
    [    0.836706] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.846264] io scheduler mq-deadline registered
    [    0.852056] io scheduler kyber registered
    [    0.860021] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.867970] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.876193] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.887942] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.898327] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.908611] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.917542] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.927508] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.941192] loop: module loaded
    [    0.946110] megasas: 07.719.03.00-rc1
    [    0.952688] tun: Universal TUN/TAP device driver, 1.6
    [    0.959688] VFIO - User Level meta-driver version: 0.3
    [    0.966760] usbcore: registered new interface driver usb-storage
    [    0.974837] i2c_dev: i2c /dev entries driver
    [    0.980980] sdhci: Secure Digital Host Controller Interface driver
    [    0.988879] sdhci: Copyright(c) Pierre Ossman
    [    0.994684] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.002325] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.010112] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.018524] usbcore: registered new interface driver usbhid
    [    1.025644] usbhid: USB HID core driver
    [    1.031155] optee: probing for conduit method.
    [    1.036851] optee: revision 4.1 (012cdca4)
    [    1.057401] optee: dynamic shared memory is enabled
    [    1.069126] optee: initialized driver
    [    1.075341] Initializing XFRM netlink socket
    [    1.080817] NET: Registered PF_PACKET protocol family
    [    1.087320] Key type dns_resolver registered
    [    1.092990] registered taskstats version 1
    [    1.098238] Loading compiled-in X.509 certificates
    [    1.111570] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.4--v09.02.04 (Kool Koala)')
    [    1.211327] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.219243] pca953x 1-0020: supply vcc not found, using dummy regulator
    [    1.227759] pca953x 1-0020: using no AI
    [    1.256047] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.264558] pca953x 1-0022: using AI
    [    1.269887] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
    [    1.277355] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
    [    1.285156] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
    [    1.293282] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.301708] omap_i2c 2020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.309400] pca953x 3-0020: supply vcc not found, using dummy regulator
    [    1.317936] pca953x 3-0020: using no AI
    [    1.343777] omap_i2c 2030000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.351159] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
    [    1.361848] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
    [    1.373529] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
    [    1.384314] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.402767] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    1.415136] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.423586] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.434893] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    1.447592] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.456040] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    1.465937] printk: console [ttyS2] disabled
    [    1.471434] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 192, base_baud = 3000000) is a 8250
    [    1.482491] printk: console [ttyS2] enabled
    [    1.493046] printk: bootconsole [ns16550a0] disabled
    [    1.506142] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 193, base_baud = 3000000) is a 8250
    [    1.517381] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 194, base_baud = 3000000) is a 8250
    [    1.528776] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.575209] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.585959] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.596299] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.612315] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.621323] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.629130] pps pps0: new PPS source ptp0
    [    1.634313] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
    [    1.647491] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:250000000, add_val:3 pps:0
    [    1.658863] mmc0: CQHCI version 5.10
    [    1.701788] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.801005] mmc0: Command Queue Engine enabled
    [    1.806564] mmc0: new HS200 MMC card at address 0001
    [    1.813202] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.822059]  mmcblk0: p1
    [    1.825624] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    1.832671] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    1.839582] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
    [    1.993389] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
    [    2.000838] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock
    [    2.308127] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    2.316681] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    2.325213] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    2.333736] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    2.342233] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    2.352049] cdns-sierra-phy: probe of 5000000.serdes failed with error -22
    [    2.368328] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    2.382006] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    2.396295] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    2.443227] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.454013] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    2.464354] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    2.480364] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.489372] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.497125] pps pps0: new PPS source ptp1
    [    2.502281] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1
    [    2.515524] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.526355] mmc1: CQHCI version 5.10
    [    2.530730] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    2.558028] ALSA device list:
    [    2.561741]   No soundcards found.
    [    2.571854] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    2.581403] Waiting for root device PARTUUID=33423791-02...
    [    2.641312] sdhci-am654 4fb0000.mmc: No passing ITAPDLY, return 0
    [    2.648945] mmc1: new ultra high speed DDR50 SDHC card at address 0001
    [    2.657566] mmcblk1: mmc1:0001 SD32G 28.8 GiB
    [    2.664858]  mmcblk1: p1 p2
    [    3.059797] EXT4-fs (mmcblk1p2): recovery complete
    [    3.067109] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    3.077796] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    3.091484] devtmpfs: mounted
    [    3.096368] Freeing unused kernel memory: 1984K
    [    3.102138] Run /sbin/init as init process
    [    3.107261]   with arguments:
    [    3.107264]     /sbin/init
    [    3.107266]   with environment:
    [    3.107267]     HOME=/
    [    3.107270]     TERM=linux
    [    3.396746] systemd[1]: System time before build time, advancing clock.
    [    3.465173] NET: Registered PF_INET6 protocol family
    [    3.472022] Segment Routing with IPv6
    [    3.476616] In-situ OAM (IOAM) with IPv6
    [    3.512251] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    3.551508] systemd[1]: Detected architecture arm64.
    [    3.608196] systemd[1]: Hostname set to <j721e-evm>.
    [    3.702304] systemd-sysv-generator[148]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    3.921931] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.978354] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    4.045120] systemd[1]: Queued start job for default target Graphical Interface.
    [    4.096755] systemd[1]: Created slice Slice /system/getty.
    [    4.120953] systemd[1]: Created slice Slice /system/modprobe.
    [    4.148867] systemd[1]: Created slice Slice /system/serial-getty.
    [    4.176484] systemd[1]: Created slice User and Session Slice.
    [    4.199464] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    4.227360] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    4.255454] systemd[1]: Reached target Path Units.
    [    4.271280] systemd[1]: Reached target Remote File Systems.
    [    4.295268] systemd[1]: Reached target Slice Units.
    [    4.311291] systemd[1]: Reached target Swaps.
    [    4.359123] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    4.387369] systemd[1]: Reached target RPC Port Mapper.
    [    4.415053] systemd[1]: Listening on Process Core Dump Socket.
    [    4.439490] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    4.463677] systemd[1]: Listening on Journal Audit Socket.
    [    4.487581] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.511586] systemd[1]: Listening on Journal Socket.
    [    4.527692] systemd[1]: Listening on Network Service Netlink Socket.
    [    4.551679] systemd[1]: Listening on udev Control Socket.
    [    4.575538] systemd[1]: Listening on udev Kernel Socket.
    [    4.599524] systemd[1]: Listening on User Database Manager Socket.
    [    4.643568] systemd[1]: Mounting Huge Pages File System...
    [    4.662261] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.690371] systemd[1]: Mounting Kernel Debug File System...
    [    4.707571] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    4.724339] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
    [    4.755542] systemd[1]: Mounting Temporary Directory /tmp...
    [    4.775011] systemd[1]: Starting Create List of Static Device Nodes...
    [    4.802426] systemd[1]: Starting Load Kernel Module configfs...
    [    4.847761] systemd[1]: Starting Load Kernel Module drm...
    [    4.874522] systemd[1]: Starting Load Kernel Module fuse...
    [    4.893247] fuse: init (API version 7.37)
    [    4.910216] systemd[1]: Starting Start psplash boot splash screen...
    [    4.959864] systemd[1]: Starting RPC Bind...
    [    4.979524] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    5.011825] systemd[1]: Starting Journal Service...
    [    5.033320] systemd[1]: Starting Load Kernel Modules...
    [    5.059276] systemd[1]: Starting Generate network units from Kernel command line...
    [    5.069015] cryptodev: loading out-of-tree module taints kernel.
    [    5.078212] cryptodev: driver 1.12 loaded.
    [    5.112249] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.143155] systemd[1]: Starting Coldplug All udev Devices...
    [    5.148963] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [    5.181225] systemd[1]: Started RPC Bind.
    [    5.195807] systemd[1]: Started Journal Service.
    [    5.564749] systemd-journald[163]: Received client request to flush runtime journal.
    [    5.794254] audit: type=1334 audit(1651167747.396:2): prog-id=5 op=LOAD
    [    5.802992] audit: type=1334 audit(1651167747.408:3): prog-id=6 op=LOAD
    [    6.316632] random: crng init done
    [    6.367818] ina2xx 2-0040: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.378134] ina2xx 2-0041: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.393514] ina2xx 2-0042: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.402970] ina2xx 2-0043: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.415568] ina2xx 2-0044: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.428411] ina2xx 2-0045: power monitor ina226 (Rshunt = 5000 uOhm)
    [    6.440033] ina2xx 2-0046: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.449050] ina2xx 2-0047: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.458798] ina2xx 2-0048: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.474654] ina2xx 2-0049: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.484859] ina2xx 2-004a: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.494687] ina2xx 2-004b: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.504092] ina2xx 2-004c: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.518859] ina2xx 2-004d: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.527944] ina2xx 2-004e: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.542670] ina2xx 2-004f: power monitor ina226 (Rshunt = 10000 uOhm)
    [    6.596071] CAN device driver interface
    [    6.611944] j721e-pcie-host 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    6.622214] j721e-pcie-host 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    6.633095] j721e-pcie-host 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    6.643865] j721e-pcie-host 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    6.675943] mc: Linux media interface: v0.10
    [    6.705662] videodev: Linux video capture interface: v2.00
    [    6.775538] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    6.800477] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [    6.809405] remoteproc remoteproc0: 4d80800000.dsp is available
    [    6.824047] PVR_K:  203: Device: 4e20000000.gpu
    [    6.829548] ZZX-rproc_boot: name = 4d80800000.dsp, firmware = j7-c66_0-fw. rproc = 6.
    [    6.838371] PVR_K:  203: Read BVNC 22.104.208.318 from HW device registers
    [    6.854380] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [    6.863538] ZZX-name = 4d80800000.dsp, firmare = j7-c66_0-fw, set_rcs_table.
    [    6.874646] ZZX: mame = 4d80800000.dsp, friware = j7-c66_0-fw, table_ptr = 00000000e032272f, table_sz = 256.
    [    6.892247] ZZX: Need = j7-mcu-r5f0_0-fw, but = j7-c66_0-fw.
    [    6.899740] ZZX-name = 4d80800000.dsp, firmware = j7-c66_0-fw ver = 1, num = 2.
    [    6.909186] ZZX-rproc: name = j7-c66_0-fw, type 3.
    [    6.917603] ZZX-rproc: name = j7-c66_0-fw, type 2.
    [    6.924094] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [    6.940580] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    6.978076] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.980096] PVR_K:  203: RGX Device registered with BVNC 22.104.208.318
    [    6.985114] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    7.004739] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    7.027438] rproc-virtio rproc-virtio.12.auto: registered virtio0 (type 7)
    [    7.037051] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [    7.049181] [drm] Initialized pvr 23.3.6512818 20170530 for 4e20000000.gpu on minor 0
    [    7.051732] k3-dsp-rproc 4d80800000.dsp: register pm nitifiers in remoteproc mode
    [    7.158350] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    7.180695] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [    7.254198] audit: type=1334 audit(1651167748.856:4): prog-id=7 op=LOAD
    [    7.257081] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [    7.273154] remoteproc remoteproc1: 4d81800000.dsp is available
    [    7.278895] audit: type=1334 audit(1651167748.876:5): prog-id=8 op=LOAD
    [    7.283789] ZZX-rproc_boot: name = 4d81800000.dsp, firmware = j7-c66_1-fw. rproc = 6.
    [    7.301516] remoteproc remoteproc1: attaching to 4d81800000.dsp
    [    7.302555] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    7.315572] ZZX-name = 4d81800000.dsp, firmare = j7-c66_1-fw, set_rcs_table.
    [    7.340565] ZZX: mame = 4d81800000.dsp, friware = j7-c66_1-fw, table_ptr = 0000000026e8309b, table_sz = 256.
    [    7.353373] ZZX: Need = j7-c66_0-fw, but = j7-c66_1-fw.
    [    7.363956] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    7.369536] ZZX: Need = j7-mcu-r5f0_0-fw, but = j7-c66_1-fw.
    [    7.395671] ZZX-name = 4d81800000.dsp, firmware = j7-c66_1-fw ver = 1, num = 2.
    [    7.408680] ZZX-rproc: name = j7-c66_1-fw, type 3.
    [    7.421809] ZZX-rproc: name = j7-c66_1-fw, type 2.
    [    7.428391] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [    7.437271] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    7.450650] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    7.455241] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    7.457650] rproc-virtio rproc-virtio.13.auto: registered virtio1 (type 7)
    [    7.474986] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
    [    7.484764] k3-dsp-rproc 4d81800000.dsp: register pm nitifiers in remoteproc mode
    [    7.562216] audit: type=1334 audit(1651167749.164:6): prog-id=9 op=LOAD
    [    7.576694] audit: type=1334 audit(1651167749.176:7): prog-id=10 op=LOAD
    [    7.602755] audit: type=1334 audit(1651167749.176:8): prog-id=7 op=UNLOAD
    [    7.623285] audit: type=1334 audit(1651167749.176:9): prog-id=8 op=UNLOAD
    [    7.650243] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [    7.667737] platform 41000000.r5f: configured R5F for IPC-only mode
    [    7.679002] audit: type=1334 audit(1651167749.248:10): prog-id=11 op=LOAD
    [    7.694652] audit: type=1334 audit(1651167749.284:11): prog-id=12 op=LOAD
    [    7.697699] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    7.736339] remoteproc remoteproc2: 41000000.r5f is available
    [    7.749646] j721e-pcie-host 2910000.pcie: PCI host bridge to bus 0000:00
    [    7.764552] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    7.778351] ZZX-rproc_boot: name = 41000000.r5f, firmware = j7-mcu-r5f0_0-fw. rproc = 6.
    [    7.781992] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
    [    7.826905] remoteproc remoteproc2: attaching to 41000000.r5f
    [    7.835294] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    7.841803] ZZX-name = 41000000.r5f, firmare = j7-mcu-r5f0_0-fw, set_rcs_table.
    [    7.854119] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    7.863994] ZZX: mame = 41000000.r5f, friware = j7-mcu-r5f0_0-fw, table_ptr = 00000000ca6aaa3e, table_sz = 256.
    [    7.910583] ZZX: Need = j7-c66_0-fw, but = j7-mcu-r5f0_0-fw.
    [    7.910671] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    7.925896] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    7.945984] pci 0000:00:00.0: supports D1
    [    7.956800] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    7.961664] ZZX-name = 41000000.r5f, firmware = j7-mcu-r5f0_0-fw ver = 1, num = 2.
    [    7.979096] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    8.006641] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    8.013163] m_can_platform 40528000.can: m_can device registered (irq=811, version=32)
    [    8.019583] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    8.065054] m_can_platform 40568000.can: m_can device registered (irq=812, version=32)
    [    8.084039] ZZX-rproc: name = j7-mcu-r5f0_0-fw, type 3.
    [    8.094411] remoteproc remoteproc3: 64800000.dsp is available
    [    8.095713] pcieport 0000:00:00.0: PME: Signaling with IRQ 815
    [    8.125100] m_can_platform 2701000.can: m_can device registered (irq=813, version=32)
    [    8.126568] ZZX-rproc_boot: name = 64800000.dsp, firmware = j7-c71_0-fw. rproc = 6.
    [    8.142738] pcieport 0000:00:00.0: AER: enabled with IRQ 815
    [    8.155646] remoteproc remoteproc3: attaching to 64800000.dsp
    [    8.170335] m_can_platform 2721000.can: m_can device registered (irq=816, version=32)
    [    8.175843] ZZX-name = 64800000.dsp, firmare = j7-c71_0-fw, set_rcs_table.
    [    8.198555] ZZX: mame = 64800000.dsp, friware = j7-c71_0-fw, table_ptr = 0000000052fa10c8, table_sz = 256.
    [    8.204467] ZZX-rproc: name = j7-mcu-r5f0_0-fw, type 2.
    [    8.215553] ZZX: Need = j7-c66_0-fw, but = j7-c71_0-fw.
    [    8.228862] ZZX: Need = j7-mcu-r5f0_0-fw, but = j7-c71_0-fw.
    [    8.236125] ZZX-name = 64800000.dsp, firmware = j7-c71_0-fw ver = 1, num = 2.
    [    8.245613] ZZX-rproc: name = j7-c71_0-fw, type 3.
    [    8.255739] ZZX-rproc: name = j7-c71_0-fw, type 65538.
    [    8.269672] remoteproc remoteproc3: unsupported resource 65538
    [    8.277489] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    8.286267] rproc-virtio rproc-virtio.15.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [    8.301650] j721e-pcie-host 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
    [    8.309567] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    8.312103] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    8.318508] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    8.326879] j721e-pcie-host 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
    [    8.346631] rproc-virtio rproc-virtio.14.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    8.359012] rproc-virtio rproc-virtio.15.auto: registered virtio2 (type 7)
    [    8.359589] j721e-pcie-host 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
    [    8.380667] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    8.387814] rproc-virtio rproc-virtio.14.auto: registered virtio3 (type 7)
    [    8.396829] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
    [    8.402057] j721e-pcie-host 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.406390] remoteproc remoteproc3: remote processor 64800000.dsp is now attached
    [    8.419358] platform 41400000.r5f: configured R5F for remoteproc mode
    [    8.426511] k3-dsp-rproc 64800000.dsp: register pm nitifiers in remoteproc mode
    [    8.436803] platform 41400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
    [    8.458792] remoteproc remoteproc4: 41400000.r5f is available
    [    8.526478] remoteproc remoteproc4: loading /lib/firmware/j7-mcu-r5f0_1-fw failed with error -22
    [    8.542947] remoteproc remoteproc4: Direct firmware load for j7-mcu-r5f0_1-fw failed with error -22
    [    8.560673] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.561085] ZZX-rproc_boot: name = 41400000.r5f, firmware = j7-mcu-r5f0_1-fw. rproc = 0.
    [    8.590408] remoteproc remoteproc4: powering up 41400000.r5f
    [    8.599328] remoteproc remoteproc4: loading /lib/firmware/j7-mcu-r5f0_1-fw failed with error -22
    [    8.616132] remoteproc remoteproc4: Direct firmware load for j7-mcu-r5f0_1-fw failed with error -22
    [    8.628474] remoteproc remoteproc4: request_firmware failed: -22
    [    8.722034] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.730624] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    9.035106] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    9.068223] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    9.428079] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [    9.449783] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    9.463599] j721e-pcie-host 2920000.pcie: PCI host bridge to bus 0001:00
    [    9.465222] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    9.475124] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    9.487041] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    9.506250] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    9.527381] scsi host0: ufshcd
    [    9.530544] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x1000-0x10fff])
    [    9.544456] pci_bus 0001:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
    [    9.559372] remoteproc remoteproc5: b034000.pru is available
    [    9.559696] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    9.572399] remoteproc remoteproc6: b004000.rtu is available
    [    9.581860] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    9.588745] remoteproc remoteproc7: b00a000.txpru is available
    [    9.602674] pci 0001:00:00.0: supports D1
    [    9.607477] remoteproc remoteproc8: b038000.pru is available
    [    9.614322] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    9.620342] remoteproc remoteproc9: b006000.rtu is available
    [    9.632213] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    9.634751] remoteproc remoteproc10: b00c000.txpru is available
    [    9.646697] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    9.651300] remoteproc remoteproc11: b134000.pru is available
    [    9.661851] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    9.667028] remoteproc remoteproc12: b104000.rtu is available
    [    9.675719] pcieport 0001:00:00.0: PME: Signaling with IRQ 841
    [    9.680199] remoteproc remoteproc13: b10a000.txpru is available
    [    9.690662] pcieport 0001:00:00.0: AER: enabled with IRQ 841
    [    9.695380] remoteproc remoteproc14: b138000.pru is available
    [    9.709262] remoteproc remoteproc15: b106000.rtu is available
    [    9.717969] remoteproc remoteproc16: b10c000.txpru is available
    [    9.730239] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    9.744282] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [    9.756948] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [    9.841156] m_can_platform 40528000.can mcu_mcan0: renamed from can0
    [    9.964494] m_can_platform 40568000.can mcu_mcan1: renamed from can1
    [   10.018715] m_can_platform 2701000.can main_mcan0: renamed from can2
    [   10.073018] m_can_platform 2721000.can main_mcan2: renamed from can3
    [   10.410370] xhci-hcd xhci-hcd.16.auto: xHCI Host Controller
    [   10.417460] xhci-hcd xhci-hcd.16.auto: new USB bus registered, assigned bus number 1
    [   10.427977] xhci-hcd xhci-hcd.16.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000018010
    [   10.440009] xhci-hcd xhci-hcd.16.auto: irq 846, io mem 0x06410000
    [   10.447891] xhci-hcd xhci-hcd.16.auto: xHCI Host Controller
    [   10.454888] xhci-hcd xhci-hcd.16.auto: new USB bus registered, assigned bus number 2
    [   10.464944] xhci-hcd xhci-hcd.16.auto: Host supports USB 3.0 SuperSpeed
    [   10.473798] hub 1-0:1.0: USB hub found
    [   10.478619] hub 1-0:1.0: 1 port detected
    [   10.483924] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   10.494776] hub 2-0:1.0: USB hub found
    [   10.499572] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: Timed out waiting for 41400000.r5f core to power up!
    [   10.500388] hub 2-0:1.0: 1 port detected
    [   10.526676] platform 5c00000.r5f: configured R5F for IPC-only mode
    [   10.540898] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [   10.554231] remoteproc remoteproc17: 5c00000.r5f is available
    [   10.562062] ZZX-rproc_boot: name = 5c00000.r5f, firmware = j7-main-r5f0_0-fw. rproc = 6.
    [   10.572318] remoteproc remoteproc17: attaching to 5c00000.r5f
    [   10.579501] ZZX-name = 5c00000.r5f, firmare = j7-main-r5f0_0-fw, set_rcs_table.
    [   10.588750] ZZX: mame = 5c00000.r5f, friware = j7-main-r5f0_0-fw, table_ptr = 00000000d2c72f23, table_sz = 256.
    [   10.601506] ZZX: Need = j7-c66_0-fw, but = j7-main-r5f0_0-fw.
    [   10.608824] ZZX: Need = j7-mcu-r5f0_0-fw, but = j7-main-r5f0_0-fw.
    [   10.618394] ZZX-name = 5c00000.r5f, firmware = j7-main-r5f0_0-fw ver = 1, num = 2.
    [   10.636174] ZZX-rproc: name = j7-main-r5f0_0-fw, type 3.
    [   10.644829] ZZX-rproc: name = j7-main-r5f0_0-fw, type 2.
    [   10.652314] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [   10.661178] rproc-virtio rproc-virtio.17.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [   10.674826] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   10.681834] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [   10.683907] rproc-virtio rproc-virtio.17.auto: registered virtio4 (type 7)
    [   10.699417] remoteproc remoteproc17: remote processor 5c00000.r5f is now attached
    [   10.709793] platform 5d00000.r5f: configured R5F for IPC-only mode
    [   10.722087] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [   10.738104] remoteproc remoteproc18: 5d00000.r5f is available
    [   10.745419] ZZX-rproc_boot: name = 5d00000.r5f, firmware = j7-main-r5f0_1-fw. rproc = 6.
    [   10.755808] remoteproc remoteproc18: attaching to 5d00000.r5f
    [   10.763033] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [   10.763987] ZZX-name = 5d00000.r5f, firmare = j7-main-r5f0_1-fw, set_rcs_table.
    [   10.782219] ZZX: mame = 5d00000.r5f, friware = j7-main-r5f0_1-fw, table_ptr = 0000000026b54034, table_sz = 256.
    [   10.795673] ZZX: Need = j7-c66_0-fw, but = j7-main-r5f0_1-fw.
    [   10.804625] ZZX: Need = j7-mcu-r5f0_0-fw, but = j7-main-r5f0_1-fw.
    [   10.813894] ZZX-name = 5d00000.r5f, firmware = j7-main-r5f0_1-fw ver = 1, num = 2.
    [   10.829587] ZZX-rproc: name = j7-main-r5f0_1-fw, type 3.
    [   10.838731] ZZX-rproc: name = j7-main-r5f0_1-fw, type 2.
    [   10.846079] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [   10.854789] rproc-virtio rproc-virtio.18.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [   10.877788] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   10.884787] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [   10.887544] rproc-virtio rproc-virtio.18.auto: registered virtio5 (type 7)
    [   10.897394] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [   10.909017] remoteproc remoteproc18: remote processor 5d00000.r5f is now attached
    [   10.912856] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [   10.931966] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [   10.941927] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [   10.942088] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   10.952495] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [   10.968457] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [   10.977883] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [   10.981064] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [   10.988892] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [   11.003390] remoteproc remoteproc19: 5e00000.r5f is available
    [   11.009394] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [   11.024281] hub 1-1:1.0: USB hub found
    [   11.029221] hub 1-1:1.0: 4 ports detected
    [   11.079314] remoteproc remoteproc19: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
    [   11.090660] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
    [   11.102246] ZZX-rproc_boot: name = 5e00000.r5f, firmware = j7-main-r5f1_0-fw. rproc = 0.
    [   11.112497] remoteproc remoteproc19: powering up 5e00000.r5f
    [   11.120469] remoteproc remoteproc19: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
    [   11.131769] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
    [   11.144657] remoteproc remoteproc19: request_firmware failed: -22
    [   11.412673] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
    [   13.023288] k3_r5_rproc bus@100000:r5fss@5e00000: Timed out waiting for 5e00000.r5f core to power up!
    [   13.188172] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   13.199079] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   23.232153] platform 2900000.pcie: deferred probe pending
    [   23.238909] platform regulator-dp-pwr: deferred probe pending
    [   23.246082] platform main-r5fss-cpsw9g-virt-mac1: deferred probe pending
    [   23.254446] platform main-r5fss-cpsw9g-virt-mac0: deferred probe pending
    [   23.262811] platform connector: deferred probe pending
    mem dts and wkup dts no change.
    Boot mode: SBL
    Best Regards
    Eason
  • Hello ,
    Now I want to IPC between linux and mcu1_0 by rpmsg_char_simple, but error:
    For MCU1_0 and A72 , the command is rpmsg_char_simple -r 0 -n 10
    Tarun Mukesh
