Hi exerts,
Is it possible to use tivxImgMosaicNode with input images of different resolution?
Thanks!
Gang
Hi exerts,
Thanks!
Gang
Hi Gang,
Well, in this case, if array of input image array is used with each image array of different frame size, it can be supported. But we have not really tested it.
Brijesh
Thanks Brijesh!
That looks like the intention of "input_arr[ ]" for mosaic node input.
I was confused by the type naming of "vx_object_array" which is actually an array of arrays rather than an array of objects.
I can get around by using MSC and 2 display pipes directly (simpler than using the mosaic node for me).
