IND-COMMS-SDK: AM243x-LP
Part Number: IND-COMMS-SDK
Hi there,
I wish to come back the questions about EtherCAT related libraries. HERE is the previous post.
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1404683/ind-comms-sdk-am243x-lp?tisearch=e2e-sitesearch&keymatch=ethercat_slave.am243x_lp.r5f.ti-arm-clang.release.lib#
about this library: ./ind_comms_sdk/source/industrial_comms/ethercat_slave/stack/lib/ethercat_slave.am243x_lp.r5f.ti-arm-clang.release.lib
I cannot find makefile in motor control sdk 9.2.0.9.  Is it possible for the customers to build the library freshly, and both debug and release variants.
In addition, am243x_lp: what does it mean that it can only be used with launchpad?
Jinlong
  • Hello Jinlong Shen,
    It is not possible for customers to rebuild the libs ethercat_slave.am243x_lp.r5f.ti-arm-clang.release.lib and ethercat_slave.am243x_evm.r5f.ti-arm-clang.release.lib
    Customers can build the EtherCAT SubDevice application in both debug and release variants.
    The lib ethercat_slave.am243x_lp.r5f.ti-arm-clang.release.lib should be able use with AM243x LP, AM243x EVM and custom boards based on AM243x processors. We are working on this to provide one lib for these targets in the upcoming SDK releases.
    "I cannot find makefile in motor control sdk 9.2.0.9" - Could you please provide us more information on this?
    Kind Regards,
  • I mean I could NOT  find the relevant makefile for the aforementioned library. As you have already explained at the beginning of your last post, TI does NOT support rebuild of that library by customers as of now.
    Looking forward to new releases. Thank you.
