Part Number: PROCESSOR-SDK-AM437X
Other Parts Discussed in Thread: BQ25890, TPS51632, TAS2764, TPS65090, DP83869, TPS65912, TPA6130A2, TPS65910, ADS7950, ADS7846, LP8727, TMP006, DAC124S085, LMP91000, PCM1681, BQ24735, DA8XX, LM3639, TLC4541, TAS5805M, ADS8688, DAC5571, BQ24190, TAS2552, SN65DSI83, TPS65219, TPD12S015, SN65DSI86, DAC7612, TPS65217, ADS131E08, DRV2665, DRV2667, DAC082S085, TWL6030, PCM3168A, TUSB1210, DRA752, TPS65010, LP3972, LP3971, TMP117, ADC128S052, LM3642, CDCE706, ADS1015, TAS2562, TCA6507, PCM5102A, TAS6424, TPS62360, TPS65218, TPS65086, DP83TC811, TAS2770, TPS65023, LP3943, LP3944, TFP410, DAC7311, TSC2004, TSC2005, OPT3001, TS3A227E, LM3630A, HDC2010, ADS8344, TAS2780, PCF8574, PCM3060, TSC2046, LMK04832, LM3532, LM3533, LM3530, TSC2007, BQ24257, DLPC3433, TWL6040, TAS5086, AFE4403, AFE4404, PCM1789, ADS124S08, ADC084S021, ADC161S626, TPIC2810, BQ25980, TPS65132, CDCE925, ADC108S102
SDK Version:ti-processor-sdk-linux-an437x-evm-09.03.05.02
Hi:
I am making a recovery system. The recovery system is made of kernel and initramfs file system. However, there is a problem that the system cannot be displayed after startup, and the DSS display is abnormal.
The error message is:
[ 14.579543] platform 4832a000.dss: deferred probe pending
[ 14.585265] platform backlight: deferred probe pending
[ 14.590595] platform display: deferred probe pending
I just want to display it on fb devices, but /dev/fb0 doesn't exist on the system.
here is dmesg:
Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 6.1.119-130752-ge74dec0cd797-dirty (root@wuyunxiang) (arm-none-linux-gnueabihf-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #2 PREEMPT Wed Feb 12 14:34:52 CST 2025 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: EDAN MPM AM43xx [ 0.000000] Memory policy: Data cache writeback [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 64 MiB at 0x9c000000 [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000080000000-0x000000009fffffff] [ 0.000000] HighMem empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff] [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM437x ES1.2 (sgx neon) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130048 [ 0.000000] Kernel command line: console=ttyS3,115200n8 board_name=RespArray DomainControl=fda Screen= root=PARTUUID=61999ea2-03 rw rootfstype=ext4 rootwait [ 0.000000] Unknown kernel command line parameters "board_name=RespArray DomainControl=fda Screen=", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 426532K/524288K available (10240K kernel code, 1351K rwdata, 2664K rodata, 12288K init, 284K bss, 32220K reserved, 65536K cma-reserved, 0K highmem) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] trace event string verifier disabled [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C-310 erratum 769419 enabled [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] OMAP L2C310: ROM does not support power control setting [ 0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled [ 0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] TI gptimer clocksource: always-on /ocp@44000000/interconnect@44c00000/segment@200000/target-module@31000 [ 0.000001] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000023] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000149] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000157] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000438] TI gptimer clockevent: 24000000 Hz at /ocp@44000000/interconnect@48000000/segment@0/target-module@40000 [ 0.001884] Console: colour dummy device 80x30 [ 0.001962] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664) [ 0.057887] CPU: Testing write buffer coherency: ok [ 0.057977] CPU0: Spectre v2: using BPIALL workaround [ 0.057987] pid_max: default: 32768 minimum: 301 [ 0.058190] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.058218] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.060412] cblist_init_generic: Setting adjustable number of callback queues. [ 0.060436] cblist_init_generic: Setting shift to 0 and lim to 1. [ 0.060689] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.060905] rcu: Hierarchical SRCU implementation. [ 0.060913] rcu: Max phase no-delay instances is 1000. [ 0.061090] EFI services will not be available. [ 0.061659] devtmpfs: initialized [ 0.078181] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.078566] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.078603] futex hash table entries: 256 (order: -1, 3072 bytes, linear) [ 0.084700] pinctrl core: initialized pinctrl subsystem [ 0.086177] DMI not present or invalid. [ 0.087041] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.090436] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.091674] thermal_sys: Registered thermal governor 'step_wise' [ 0.091809] cpuidle: using governor menu [ 0.109243] platform display: Fixed dependency cycle(s) with /ocp@44000000/interconnect@48000000/segment@300000/target-module@2a000/dss@0 [ 0.109524] No ATAGs? [ 0.109576] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.109587] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.130832] SCSI subsystem initialized [ 0.131168] usbcore: registered new interface driver usbfs [ 0.131222] usbcore: registered new interface driver hub [ 0.131292] usbcore: registered new device driver usb [ 0.131667] pps_core: LinuxPPS API ver. 1 registered [ 0.131676] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.131701] PTP clock support registered [ 0.131754] EDAC MC: Ver: 3.0.0 [ 0.138426] Advanced Linux Sound Architecture Driver Initialized. [ 0.140156] clocksource: Switched to clocksource dmtimer [ 0.162100] NET: Registered PF_INET protocol family [ 0.162614] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.164188] tcp_listen_portaddr_hash hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.164241] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.164256] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear) [ 0.164321] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.164461] TCP: Hash tables configured (established 4096 bind 4096) [ 0.164684] UDP hash table entries: 256 (order: 0, 4096 bytes, linear) [ 0.164716] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear) [ 0.164916] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.165648] RPC: Registered named UNIX socket transport module. [ 0.165663] RPC: Registered udp transport module. [ 0.165667] RPC: Registered tcp transport module. [ 0.165671] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.167298] Initialise system trusted keyrings [ 0.167714] workingset: timestamp_bits=30 max_order=17 bucket_order=0 [ 0.183316] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.190834] NFS: Registering the id_resolver key type [ 0.190915] Key type id_resolver registered [ 0.190922] Key type id_legacy registered [ 0.191035] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.191045] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.191094] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.191770] Key type asymmetric registered [ 0.191787] Asymmetric key parser 'x509' registered [ 0.191998] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.192011] io scheduler mq-deadline registered [ 0.192018] io scheduler kyber registered [ 0.212054] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled [ 0.221778] STMicroelectronics ASC driver initialized [ 0.255818] brd: module loaded [ 0.282300] loop: module loaded [ 0.285693] usbcore: registered new interface driver usb-storage [ 0.285771] i2c_dev: i2c /dev entries driver [ 0.287054] cpuidle: enable-method property 'ti,am4372' found operations [ 0.287680] sdhci: Secure Digital Host Controller Interface driver [ 0.287689] sdhci: Copyright(c) Pierre Ossman [ 0.287847] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.288674] usbcore: registered new interface driver usbhid [ 0.288685] usbhid: USB HID core driver [ 0.288693] SPI driver spi_ims has no spi_device_id for spi,spi1052 [ 0.300343] v8kbd_init(line 666): [ 0.300384] succeed [ 0.312435] NET: Registered PF_INET6 protocol family [ 0.314303] Segment Routing with IPv6 [ 0.314372] In-situ OAM (IOAM) with IPv6 [ 0.314485] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 0.315371] NET: Registered PF_PACKET protocol family [ 0.315666] Key type dns_resolver registered [ 0.315833] ThumbEE CPU extension supported. [ 0.315850] Registering SWP/SWPB emulation handler [ 0.315862] omap_voltage_late_init: Voltage driver support not added [ 0.320466] Loading compiled-in X.509 certificates [ 0.401459] omap_l3_noc 44000000.l3-noc: L3 debug error: target 8 mod:0 (unclearable) [ 0.401642] omap_l3_noc 44000000.l3-noc: L3 application error: target 8 mod:0 (unclearable) [ 0.425073] gpio gpiochip0: (gpio-0-31): not an immutable chip, please consider fixing it! [ 0.430601] OMAP GPIO hardware version 0.1 [ 0.443994] pinctrl-single 44e10800.pinmux: 199 pins, size 796 [ 0.471157] ti-sysc: probe of 44e31000.target-module failed with error -16 [ 0.479949] omap8250 48022000.serial: No clock speed specified: using default: 48000000 [ 0.500783] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 54, base_baud = 3000000) is a 8250 [ 0.532396] rtc-pcf8563 1-0051: registered as rtc0 [ 0.532792] rtc-pcf8563 1-0051: setting system clock to 2025-02-12T17:48:20 UTC (1739382500) [ 0.540399] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz [ 0.548386] ti-sysc: probe of 48040000.target-module failed with error -16 [ 0.572051] ti-sysc 4804c000.target-module: dts flag should be at module level for ti,no-reset-on-init [ 0.573142] gpio-32 (rstb0): hogged as output/low [ 0.573170] gpio-33 (pwd0): hogged as output/low [ 0.573217] gpio gpiochip1: (gpio-32-63): not an immutable chip, please consider fixing it! [ 0.604851] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 400 kHz [ 0.612083] omap8250 481a6000.serial: No clock speed specified: using default: 48000000 [ 0.630996] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 60, base_baud = 3000000) is a 8250 [ 3.142755] printk: console [ttyS3] enabled [ 3.149998] omap8250 481a8000.serial: No clock speed specified: using default: 48000000 [ 3.158801] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 61, base_baud = 3000000) is a 8250 [ 3.170802] gpio gpiochip2: (gpio-64-95): not an immutable chip, please consider fixing it! [ 3.181486] gpio gpiochip3: (gpio-96-127): not an immutable chip, please consider fixing it! [ 3.203212] omap_rng 48310000.rng: Random Number Generator ver. 20 [ 3.210082] ti-sysc 48320000.target-module: dts flag should be at module level for ti,no-reset-on-init [ 3.219591] random: crng init done [ 3.224335] gpio-128 (ctrl1v35): hogged as output/low [ 3.229441] gpio gpiochip4: (gpio-128-159): not an immutable chip, please consider fixing it! [ 3.239035] ti-sysc 48322000.target-module: dts flag should be at module level for ti,no-reset-on-init [ 3.249504] gpio-161 (lcden): hogged as output/high [ 3.254494] gpio gpiochip5: (gpio-160-191): not an immutable chip, please consider fixing it! [ 3.265817] platform display: Fixed dependency cycle(s) with /ocp@44000000/interconnect@48000000/segment@300000/target-module@2a000/dss@0 [ 3.278474] platform 4832a000.dss: Fixed dependency cycle(s) with /display [ 3.286500] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator [ 3.370227] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 3.389726] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720 [ 3.399321] cpsw-switch 4a100000.switch: /ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/ethernet-ports/port@1 Missing dual_emac_res_vlan in DT. [ 3.414897] cpsw-switch 4a100000.switch: /ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/ethernet-ports/port@1 Using 1 as Reserved VLAN [ 3.429584] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4 [ 3.436400] cpsw-switch 4a100000.switch: ALE Table size 1024 [ 3.442215] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies) [ 3.449782] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec [ 3.460809] cpsw-switch 4a100000.switch: Detected MACID = a8:e7:7d:38:ec:08 [ 3.469131] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010F 1.15 (0) [ 3.487715] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present! [ 3.495794] edma 49000000.dma: TI EDMA DMA engine driver [ 3.506627] omap_gpio 4804c000.gpio: Could not set line 3 debounce to 200000 microseconds (-22) [ 3.523039] sdhci-omap 47810000.mmc: Got CD GPIO [ 3.527879] sdhci-omap 47810000.mmc: supply pbias not found, using dummy regulator [ 3.543710] omap8250 44e09000.serial: No clock speed specified: using default: 48000000 [ 3.552337] sdhci-omap 47810000.mmc: supply vqmmc not found, using dummy regulator [ 3.561012] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 75, base_baud = 3000000) is a 8250 [ 3.597327] mmc0: SDHCI controller on 47810000.mmc [47810000.mmc] using External DMA [ 3.607071] tps65218-pwrbutton: Failed to locate of_node [id: -2] [ 3.613554] tps65218-gpio: Failed to locate of_node [id: -2] [ 3.630798] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz [ 3.637520] tlv320aic31xx-codec 1-0018: supply SPRVDD not found, using dummy regulator [ 3.645703] tlv320aic31xx-codec 1-0018: supply SPLVDD not found, using dummy regulator [ 3.658554] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator [ 3.667053] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator [ 3.675063] sdhci-omap 48060000.mmc: using old ti,non-removable property [ 3.691117] sii9022x 2-003b: Sii902x: init [ 3.698409] spi_ims spi1.0: start talking to iMx.RT1052 [ 3.705054] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator [ 3.713308] mmc1: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA [ 3.725384] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 3.731262] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1 [ 3.739872] xhci-hcd xhci-hcd.3.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000008002010010 [ 3.749673] xhci-hcd xhci-hcd.3.auto: irq 83, io mem 0x48390000 [ 3.756156] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 3.761918] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2 [ 3.769747] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed [ 3.777631] hub 1-0:1.0: USB hub found [ 3.781567] hub 1-0:1.0: 1 port detected [ 3.786089] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.794976] index=1,h=14,l=d2 [ 3.798467] hub 2-0:1.0: USB hub found [ 3.802482] hub 2-0:1.0: 1 port detected [ 3.809793] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller [ 3.815653] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 3 [ 3.826362] xhci-hcd xhci-hcd.4.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000008002010010 [ 3.836029] xhci-hcd xhci-hcd.4.auto: irq 84, io mem 0x483d0000 [ 3.842397] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller [ 3.847959] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 4 [ 3.855795] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed [ 3.863706] hub 3-0:1.0: USB hub found [ 3.867588] hub 3-0:1.0: 1 port detected [ 3.872287] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.881563] mmc1: new high speed MMC card at address 0001 [ 3.887868] hub 4-0:1.0: USB hub found [ 3.892829] mmcblk1: mmc1:0001 Q2J54A 3.59 GiB [ 3.899196] hub 4-0:1.0: 1 port detected [ 3.910791] mmcblk1: p1 p2 p3 p4 [ 3.919480] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator [ 3.929180] mmcblk1boot0: mmc1:0001 Q2J54A 16.0 MiB [ 3.937749] mmcblk1boot1: mmc1:0001 Q2J54A 16.0 MiB [ 3.945245] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator [ 3.956171] mmcblk1rpmb: mmc1:0001 Q2J54A 512 KiB, chardev (242:0) [ 3.965717] clk: Disabling unused clocks [ 3.970369] ALSA device list: [ 3.973356] #0: MPM Am43xx Audio [ 3.976838] Warning: unable to open an initial console. [ 3.983226] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator [ 4.040878] Freeing unused kernel image (initmem) memory: 12288K [ 4.047191] Run /init as init process [ 4.140386] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 4.170516] usb 3-1: new high-speed USB device number 2 using xhci-hcd [ 4.180933] cpsw-switch 4a100000.switch: starting ndev. mode: dual_mac [ 4.271009] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL) [ 4.376997] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator [ 4.407068] hub 3-1:1.0: USB hub found [ 4.419350] hub 3-1:1.0: 4 ports detected [ 4.472595] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator [ 4.485322] v8kbd_connect [ 4.488448] lcd res_x = 1920, res_y = 1080 [ 4.488727] serio: Serial port ttyS1 [ 4.497028] connect succeed [ 4.501630] input: EDAN V8 Serial Touchscreen as /devices/virtual/input/input1 [ 4.509196] register touch device succeed [ 4.513714] input: EDAN V8 Serial Keyboard as /devices/virtual/input/input0 [ 4.521055] register keyboard device succeed [ 4.526092] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator [ 5.558286] agree connect [ 6.400892] cpsw-switch 4a100000.switch eth0: Link is Up - 100Mbps/Full - flow control off [ 6.411884] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Welcome to Buildroot buildroot login: [ 14.561026] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator [ 14.570860] pwm-backlight backlight: supply power not found, using dummy regulator [ 14.579543] platform 4832a000.dss: deferred probe pending [ 14.585265] platform backlight: deferred probe pending [ 14.590595] platform display: deferred probe pending Welcome to Buildroot buildroot login: Welcome to Buildroot buildroot login: Welcome to Buildroot buildroot login: root Password: login[112]: root login on 'ttyS3' # [ 602.164240] usb 1-1: USB disconnect, device number 2 [ 602.172388] xhci-hcd xhci-hcd.3.auto: xHCI xhci_drop_endpoint called with disabled ep 538cdfe9 [ 602.680179] usb 1-1: new high-speed USB device number 3 using xhci-hcd [ 602.897220] omapdss_dss 4832a000.dss: supply vdda_video not found, using dummy regulator [ 602.907008] pwm-backlight backlight: supply power not found, using dummy regulator # # #
This is the kernel configuration file:
# # Automatically generated file; DO NOT EDIT. # Linux/arm 6.1.119 Kernel Configuration # CONFIG_CC_VERSION_TEXT="arm-none-linux-gnueabihf-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712" CONFIG_CC_IS_GCC=y CONFIG_GCC_VERSION=110301 CONFIG_CLANG_VERSION=0 CONFIG_AS_IS_GNU=y CONFIG_AS_VERSION=20244508 CONFIG_LD_IS_BFD=y CONFIG_LD_VERSION=20244508 CONFIG_LLD_VERSION=0 CONFIG_CC_CAN_LINK=y CONFIG_CC_CAN_LINK_STATIC=y CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y CONFIG_GCC_ASM_GOTO_OUTPUT_WORKAROUND=y CONFIG_CC_HAS_ASM_INLINE=y CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y CONFIG_PAHOLE_VERSION=0 CONFIG_IRQ_WORK=y CONFIG_BUILDTIME_TABLE_SORT=y CONFIG_THREAD_INFO_IN_TASK=y # # General setup # CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 # CONFIG_COMPILE_TEST is not set # CONFIG_WERROR is not set CONFIG_LOCALVERSION="" CONFIG_LOCALVERSION_AUTO=y CONFIG_BUILD_SALT="" CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_XZ=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_HAVE_KERNEL_LZ4=y CONFIG_KERNEL_GZIP=y # CONFIG_KERNEL_LZMA is not set # CONFIG_KERNEL_XZ is not set # CONFIG_KERNEL_LZO is not set # CONFIG_KERNEL_LZ4 is not set CONFIG_DEFAULT_INIT="" CONFIG_DEFAULT_HOSTNAME="(none)" CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y # CONFIG_POSIX_MQUEUE is not set # CONFIG_WATCH_QUEUE is not set CONFIG_CROSS_MEMORY_ATTACH=y # CONFIG_USELIB is not set # CONFIG_AUDIT is not set CONFIG_HAVE_ARCH_AUDITSYSCALL=y # # IRQ subsystem # CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_GENERIC_IRQ_SHOW_LEVEL=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_CHIP=y CONFIG_IRQ_DOMAIN=y CONFIG_IRQ_DOMAIN_HIERARCHY=y CONFIG_IRQ_FORCED_THREADING=y CONFIG_SPARSE_IRQ=y # CONFIG_GENERIC_IRQ_DEBUGFS is not set # end of IRQ subsystem CONFIG_GENERIC_IRQ_MULTI_HANDLER=y CONFIG_GENERIC_TIME_VSYSCALL=y CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_ARCH_HAS_TICK_BROADCAST=y CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y CONFIG_CONTEXT_TRACKING=y CONFIG_CONTEXT_TRACKING_IDLE=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ_COMMON=y # CONFIG_HZ_PERIODIC is not set CONFIG_NO_HZ_IDLE=y # CONFIG_NO_HZ is not set CONFIG_HIGH_RES_TIMERS=y # end of Timers subsystem CONFIG_BPF=y CONFIG_HAVE_EBPF_JIT=y # # BPF subsystem # # CONFIG_BPF_SYSCALL is not set # CONFIG_BPF_JIT is not set # end of BPF subsystem CONFIG_PREEMPT_BUILD=y # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_PREEMPT_COUNT=y CONFIG_PREEMPTION=y # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set # CONFIG_IRQ_TIME_ACCOUNTING is not set # CONFIG_BSD_PROCESS_ACCT is not set # CONFIG_TASKSTATS is not set # CONFIG_PSI is not set # end of CPU/Task time and stats accounting # # RCU Subsystem # CONFIG_TREE_RCU=y CONFIG_PREEMPT_RCU=y # CONFIG_RCU_EXPERT is not set CONFIG_SRCU=y CONFIG_TREE_SRCU=y CONFIG_TASKS_RCU_GENERIC=y CONFIG_TASKS_RCU=y CONFIG_RCU_STALL_COMMON=y CONFIG_RCU_NEED_SEGCBLIST=y # end of RCU Subsystem CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y # CONFIG_IKHEADERS is not set CONFIG_LOG_BUF_SHIFT=17 CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13 # CONFIG_PRINTK_INDEX is not set CONFIG_GENERIC_SCHED_CLOCK=y # # Scheduler features # # end of Scheduler features CONFIG_CC_IMPLICIT_FALLTHROUGH="-Wimplicit-fallthrough=5" CONFIG_GCC10_NO_ARRAY_BOUNDS=y CONFIG_CC_NO_ARRAY_BOUNDS=y CONFIG_CGROUPS=y # CONFIG_CGROUP_FAVOR_DYNMODS is not set # CONFIG_MEMCG is not set # CONFIG_BLK_CGROUP is not set # CONFIG_CGROUP_SCHED is not set # CONFIG_CGROUP_PIDS is not set # CONFIG_CGROUP_RDMA is not set # CONFIG_CGROUP_FREEZER is not set # CONFIG_CGROUP_DEVICE is not set # CONFIG_CGROUP_CPUACCT is not set # CONFIG_CGROUP_PERF is not set # CONFIG_CGROUP_MISC is not set # CONFIG_CGROUP_DEBUG is not set # CONFIG_NAMESPACES is not set # CONFIG_CHECKPOINT_RESTORE is not set # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="../export/initramfs" CONFIG_INITRAMFS_ROOT_UID=0 CONFIG_INITRAMFS_ROOT_GID=0 CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_XZ=y CONFIG_RD_LZO=y CONFIG_RD_LZ4=y CONFIG_RD_ZSTD=y CONFIG_INITRAMFS_COMPRESSION_GZIP=y # CONFIG_INITRAMFS_COMPRESSION_BZIP2 is not set # CONFIG_INITRAMFS_COMPRESSION_LZMA is not set # CONFIG_INITRAMFS_COMPRESSION_XZ is not set # CONFIG_INITRAMFS_COMPRESSION_LZO is not set # CONFIG_INITRAMFS_COMPRESSION_LZ4 is not set # CONFIG_INITRAMFS_COMPRESSION_ZSTD is not set # CONFIG_INITRAMFS_COMPRESSION_NONE is not set # CONFIG_BOOT_CONFIG is not set CONFIG_INITRAMFS_PRESERVE_MTIME=y CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_LD_ORPHAN_WARN=y CONFIG_SYSCTL=y CONFIG_HAVE_UID16=y CONFIG_EXPERT=y CONFIG_UID16=y CONFIG_MULTIUSER=y # CONFIG_SGETMASK_SYSCALL is not set CONFIG_SYSFS_SYSCALL=y CONFIG_FHANDLE=y CONFIG_POSIX_TIMERS=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_FUTEX_PI=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_IO_URING=y CONFIG_ADVISE_SYSCALLS=y CONFIG_MEMBARRIER=y CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_ALL is not set CONFIG_KALLSYMS_BASE_RELATIVE=y CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y CONFIG_KCMP=y CONFIG_RSEQ=y # CONFIG_DEBUG_RSEQ is not set CONFIG_EMBEDDED=y CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # CONFIG_PC104 is not set # # Kernel Performance Events And Counters # CONFIG_PERF_EVENTS=y # CONFIG_DEBUG_PERF_USE_VMALLOC is not set # end of Kernel Performance Events And Counters CONFIG_SYSTEM_DATA_VERIFICATION=y # CONFIG_PROFILING is not set CONFIG_TRACEPOINTS=y # end of General setup CONFIG_ARM=y CONFIG_ARM_HAS_GROUP_RELOCS=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_HAVE_PROC_CPU=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_ARCH_HAS_BANDGAP=y CONFIG_FIX_EARLYCON_MEM=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_ARCH_SUPPORTS_UPROBES=y CONFIG_ARM_PATCH_PHYS_VIRT=y CONFIG_GENERIC_BUG=y CONFIG_PGTABLE_LEVELS=2 # # System Type # CONFIG_MMU=y CONFIG_ARCH_MMAP_RND_BITS_MIN=8 CONFIG_ARCH_MMAP_RND_BITS_MAX=16 CONFIG_ARCH_MULTIPLATFORM=y # # Platform selection # # # CPU Core family selection # # CONFIG_ARCH_MULTI_V6 is not set CONFIG_ARCH_MULTI_V7=y CONFIG_ARCH_MULTI_V6_V7=y # end of Platform selection # CONFIG_ARCH_VIRT is not set # CONFIG_ARCH_AIROHA is not set # CONFIG_ARCH_ACTIONS is not set # CONFIG_ARCH_ALPINE is not set # CONFIG_ARCH_ARTPEC is not set # CONFIG_ARCH_ASPEED is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_BCM is not set # CONFIG_ARCH_BERLIN is not set # CONFIG_ARCH_DIGICOLOR is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_HISI is not set # CONFIG_ARCH_HPE is not set # CONFIG_ARCH_MXC is not set CONFIG_ARCH_KEYSTONE=y # CONFIG_ARCH_MEDIATEK is not set # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MILBEAUT is not set # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_MSTARV7 is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_ARCH_NPCM is not set CONFIG_ARCH_OMAP=y CONFIG_MACH_OMAP_GENERIC=y # # TI OMAP/AM/DM/DRA Family # CONFIG_OMAP_HWMOD=y CONFIG_ARCH_OMAP3=y CONFIG_ARCH_OMAP4=y CONFIG_SOC_OMAP5=y CONFIG_SOC_AM33XX=y CONFIG_SOC_AM43XX=y CONFIG_SOC_DRA7XX=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP_INTERCONNECT_BARRIER=y # # TI OMAP2/3/4 Specific Features # CONFIG_ARCH_OMAP2PLUS_TYPICAL=y CONFIG_SOC_HAS_OMAP2_SDRC=y CONFIG_SOC_HAS_REALTIME_COUNTER=y # CONFIG_POWER_AVS_OMAP is not set # CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set CONFIG_SOC_OMAP3430=y CONFIG_SOC_TI81XX=y # # OMAP Legacy Platform Data Board Type # # CONFIG_OMAP3_SDRC_AC_TIMING is not set # end of TI OMAP2/3/4 Specific Features # CONFIG_OMAP5_ERRATA_801819 is not set # end of TI OMAP/AM/DM/DRA Family # CONFIG_ARCH_QCOM is not set # CONFIG_ARCH_RDA is not set # CONFIG_ARCH_REALTEK is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_S5PV210 is not set # CONFIG_ARCH_RENESAS is not set # CONFIG_ARCH_INTEL_SOCFPGA is not set # CONFIG_PLAT_SPEAR is not set # CONFIG_ARCH_STI is not set # CONFIG_ARCH_STM32 is not set # CONFIG_ARCH_SUNPLUS is not set # CONFIG_ARCH_SUNXI is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_WM8850 is not set # CONFIG_ARCH_ZYNQ is not set # # Processor Type # CONFIG_CPU_V7=y CONFIG_CPU_THUMB_CAPABLE=y CONFIG_CPU_32v6K=y CONFIG_CPU_32v7=y CONFIG_CPU_ABRT_EV7=y CONFIG_CPU_PABRT_V7=y CONFIG_CPU_CACHE_V7=y CONFIG_CPU_CACHE_VIPT=y CONFIG_CPU_COPY_V6=y CONFIG_CPU_TLB_V7=y CONFIG_CPU_HAS_ASID=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y # # Processor Features # # CONFIG_ARM_LPAE is not set CONFIG_ARM_THUMB=y CONFIG_ARM_THUMBEE=y CONFIG_ARM_VIRT_EXT=y CONFIG_SWP_EMULATE=y CONFIG_CPU_LITTLE_ENDIAN=y # CONFIG_CPU_BIG_ENDIAN is not set # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_DCACHE_DISABLE is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_CPU_SPECTRE=y CONFIG_HARDEN_BRANCH_PREDICTOR=y CONFIG_HARDEN_BRANCH_HISTORY=y CONFIG_KUSER_HELPERS=y CONFIG_VDSO=y CONFIG_OUTER_CACHE=y CONFIG_OUTER_CACHE_SYNC=y CONFIG_MIGHT_HAVE_CACHE_L2X0=y CONFIG_CACHE_L2X0=y # CONFIG_CACHE_L2X0_PMU is not set CONFIG_PL310_ERRATA_588369=y CONFIG_PL310_ERRATA_727915=y CONFIG_PL310_ERRATA_753970=y CONFIG_PL310_ERRATA_769419=y CONFIG_ARM_L1_CACHE_SHIFT_6=y CONFIG_ARM_L1_CACHE_SHIFT=6 CONFIG_ARM_DMA_MEM_BUFFERABLE=y CONFIG_ARM_HEAVY_MB=y CONFIG_DEBUG_ALIGN_RODATA=y CONFIG_ARM_ERRATA_430973=y CONFIG_ARM_ERRATA_720789=y CONFIG_ARM_ERRATA_754322=y # CONFIG_ARM_ERRATA_764319 is not set CONFIG_ARM_ERRATA_775420=y # CONFIG_ARM_ERRATA_773022 is not set # CONFIG_ARM_ERRATA_818325_852422 is not set # CONFIG_ARM_ERRATA_821420 is not set # CONFIG_ARM_ERRATA_825619 is not set # CONFIG_ARM_ERRATA_857271 is not set # CONFIG_ARM_ERRATA_852421 is not set # CONFIG_ARM_ERRATA_852423 is not set # CONFIG_ARM_ERRATA_857272 is not set # end of System Type # # Bus support # CONFIG_ARM_ERRATA_814220=y # end of Bus support # # Kernel Features # CONFIG_HAVE_SMP=y # CONFIG_SMP is not set CONFIG_CURRENT_POINTER_IN_TPIDRURO=y CONFIG_IRQSTACKS=y CONFIG_HAVE_ARM_SCU=y CONFIG_HAVE_ARM_ARCH_TIMER=y CONFIG_HAVE_ARM_TWD=y CONFIG_VMSPLIT_3G=y # CONFIG_VMSPLIT_3G_OPT is not set # CONFIG_VMSPLIT_2G is not set # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0xC0000000 CONFIG_ARM_PSCI=y CONFIG_ARCH_NR_GPIO=2048 CONFIG_HZ_FIXED=0 CONFIG_HZ_100=y # CONFIG_HZ_200 is not set # CONFIG_HZ_250 is not set # CONFIG_HZ_300 is not set # CONFIG_HZ_500 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=100 CONFIG_SCHED_HRTICK=y # CONFIG_THUMB2_KERNEL is not set CONFIG_ARM_PATCH_IDIV=y CONFIG_AEABI=y # CONFIG_OABI_COMPAT is not set CONFIG_ARCH_SELECT_MEMORY_MODEL=y CONFIG_ARCH_FLATMEM_ENABLE=y CONFIG_ARCH_SPARSEMEM_ENABLE=y CONFIG_HIGHMEM=y CONFIG_HIGHPTE=y CONFIG_CPU_SW_DOMAIN_PAN=y CONFIG_HW_PERF_EVENTS=y CONFIG_ARM_MODULE_PLTS=y CONFIG_ARCH_FORCE_MAX_ORDER=12 CONFIG_ALIGNMENT_TRAP=y # CONFIG_UACCESS_WITH_MEMCPY is not set # CONFIG_PARAVIRT is not set # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set # CONFIG_XEN is not set CONFIG_STACKPROTECTOR_PER_TASK=y # end of Kernel Features # # Boot options # CONFIG_USE_OF=y CONFIG_ATAGS=y # CONFIG_UNUSED_BOARD_FILES is not set # CONFIG_DEPRECATED_PARAM_STRUCT is not set CONFIG_ZBOOT_ROM_TEXT=0x0 CONFIG_ZBOOT_ROM_BSS=0x0 CONFIG_ARM_APPENDED_DTB=y CONFIG_ARM_ATAG_DTB_COMPAT=y CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y # CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set CONFIG_CMDLINE="" CONFIG_KEXEC=y CONFIG_ATAGS_PROC=y # CONFIG_CRASH_DUMP is not set CONFIG_AUTO_ZRELADDR=y CONFIG_EFI_STUB=y CONFIG_EFI=y CONFIG_DMI=y # end of Boot options # # CPU Power Management # # # CPU Frequency scaling # CONFIG_CPU_FREQ=y CONFIG_CPU_FREQ_STAT=y CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set CONFIG_CPU_FREQ_GOV_PERFORMANCE=y # CONFIG_CPU_FREQ_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_GOV_USERSPACE is not set # CONFIG_CPU_FREQ_GOV_ONDEMAND is not set # CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set # # CPU frequency scaling drivers # CONFIG_CPUFREQ_DT=y CONFIG_CPUFREQ_DT_PLATDEV=y CONFIG_ARM_OMAP2PLUS_CPUFREQ=y CONFIG_ARM_SCMI_CPUFREQ=y CONFIG_ARM_TI_CPUFREQ=y # end of CPU Frequency scaling # # CPU Idle # CONFIG_CPU_IDLE=y CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y # CONFIG_CPU_IDLE_GOV_LADDER is not set CONFIG_CPU_IDLE_GOV_MENU=y # CONFIG_CPU_IDLE_GOV_TEO is not set CONFIG_DT_IDLE_STATES=y CONFIG_DT_IDLE_GENPD=y # # ARM CPU Idle Drivers # CONFIG_ARM_CPUIDLE=y CONFIG_ARM_PSCI_CPUIDLE=y CONFIG_ARM_PSCI_CPUIDLE_DOMAIN=y # CONFIG_ARM_HIGHBANK_CPUIDLE is not set # end of ARM CPU Idle Drivers # end of CPU Idle # end of CPU Power Management # # Floating point emulation # # # At least one emulation must be selected # CONFIG_VFP=y CONFIG_VFPv3=y CONFIG_NEON=y CONFIG_KERNEL_MODE_NEON=y # end of Floating point emulation # # Power management options # CONFIG_SUSPEND=y CONFIG_SUSPEND_FREEZER=y # CONFIG_SUSPEND_SKIP_SYNC is not set # CONFIG_HIBERNATION is not set CONFIG_PM_SLEEP=y # CONFIG_PM_AUTOSLEEP is not set # CONFIG_PM_USERSPACE_AUTOSLEEP is not set # CONFIG_PM_WAKELOCKS is not set CONFIG_PM=y # CONFIG_PM_DEBUG is not set # CONFIG_APM_EMULATION is not set CONFIG_PM_CLK=y CONFIG_PM_GENERIC_DOMAINS=y # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set CONFIG_PM_GENERIC_DOMAINS_SLEEP=y CONFIG_PM_GENERIC_DOMAINS_OF=y CONFIG_CPU_PM=y CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_ARM_CPU_SUSPEND=y CONFIG_ARCH_HIBERNATION_POSSIBLE=y # end of Power management options CONFIG_AS_VFP_VMRS_FPINST=y CONFIG_CPU_MITIGATIONS=y # # General architecture-dependent options # CONFIG_CRASH_CORE=y CONFIG_KEXEC_CORE=y # CONFIG_KPROBES is not set # CONFIG_JUMP_LABEL is not set CONFIG_UPROBES=y CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y CONFIG_ARCH_USE_BUILTIN_BSWAP=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_OPTPROBES=y CONFIG_HAVE_NMI=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_GENERIC_IDLE_POLL_SETUP=y CONFIG_ARCH_HAS_FORTIFY_SOURCE=y CONFIG_ARCH_HAS_KEEPINITRD=y CONFIG_ARCH_HAS_SET_MEMORY=y CONFIG_ARCH_HAS_CPU_FINALIZE_INIT=y CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y CONFIG_ARCH_32BIT_OFF_T=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_RSEQ=y CONFIG_HAVE_HW_BREAKPOINT=y CONFIG_HAVE_PERF_REGS=y CONFIG_HAVE_PERF_USER_STACK_DUMP=y CONFIG_HAVE_ARCH_JUMP_LABEL=y CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG=y CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y CONFIG_HAVE_ARCH_SECCOMP=y CONFIG_HAVE_ARCH_SECCOMP_FILTER=y CONFIG_SECCOMP=y CONFIG_SECCOMP_FILTER=y # CONFIG_SECCOMP_CACHE_DEBUG is not set CONFIG_HAVE_STACKPROTECTOR=y CONFIG_STACKPROTECTOR=y CONFIG_STACKPROTECTOR_STRONG=y CONFIG_LTO_NONE=y CONFIG_HAVE_CONTEXT_TRACKING_USER=y CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_MOD_ARCH_SPECIFIC=y CONFIG_MODULES_USE_ELF_REL=y CONFIG_HAVE_IRQ_EXIT_ON_IRQ_STACK=y CONFIG_HAVE_SOFTIRQ_ON_OWN_STACK=y CONFIG_SOFTIRQ_ON_OWN_STACK=y CONFIG_ARCH_HAS_ELF_RANDOMIZE=y CONFIG_HAVE_ARCH_MMAP_RND_BITS=y CONFIG_HAVE_EXIT_THREAD=y CONFIG_ARCH_MMAP_RND_BITS=8 CONFIG_PAGE_SIZE_LESS_THAN_64KB=y CONFIG_PAGE_SIZE_LESS_THAN_256KB=y CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y CONFIG_CLONE_BACKWARDS=y CONFIG_OLD_SIGSUSPEND3=y CONFIG_OLD_SIGACTION=y CONFIG_COMPAT_32BIT_TIME=y CONFIG_HAVE_ARCH_VMAP_STACK=y CONFIG_VMAP_STACK=y CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y CONFIG_STRICT_KERNEL_RWX=y CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y CONFIG_STRICT_MODULE_RWX=y # CONFIG_LOCK_EVENT_COUNTS is not set CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y CONFIG_HAVE_ARCH_PFN_VALID=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y # end of GCOV-based kernel profiling CONFIG_HAVE_GCC_PLUGINS=y CONFIG_GCC_PLUGINS=y # CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set CONFIG_GCC_PLUGIN_ARM_SSP_PER_TASK=y # end of General architecture-dependent options CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y CONFIG_MODULE_FORCE_LOAD=y CONFIG_MODULE_UNLOAD=y CONFIG_MODULE_FORCE_UNLOAD=y # CONFIG_MODULE_UNLOAD_TAINT_TRACKING is not set CONFIG_MODVERSIONS=y CONFIG_MODULE_SRCVERSION_ALL=y # CONFIG_MODULE_SIG is not set CONFIG_MODULE_COMPRESS_NONE=y # CONFIG_MODULE_COMPRESS_GZIP is not set # CONFIG_MODULE_COMPRESS_XZ is not set # CONFIG_MODULE_COMPRESS_ZSTD is not set # CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set CONFIG_MODPROBE_PATH="/sbin/modprobe" # CONFIG_TRIM_UNUSED_KSYMS is not set CONFIG_MODULES_TREE_LOOKUP=y CONFIG_BLOCK=y CONFIG_BLOCK_LEGACY_AUTOLOAD=y CONFIG_BLK_DEV_BSG_COMMON=y CONFIG_BLK_DEV_BSGLIB=y # CONFIG_BLK_DEV_INTEGRITY is not set # CONFIG_BLK_DEV_ZONED is not set # CONFIG_BLK_WBT is not set CONFIG_BLK_DEBUG_FS=y # CONFIG_BLK_SED_OPAL is not set # CONFIG_BLK_INLINE_ENCRYPTION is not set # # Partition Types # CONFIG_PARTITION_ADVANCED=y # CONFIG_ACORN_PARTITION is not set # CONFIG_AIX_PARTITION is not set # CONFIG_OSF_PARTITION is not set # CONFIG_AMIGA_PARTITION is not set # CONFIG_ATARI_PARTITION is not set # CONFIG_MAC_PARTITION is not set CONFIG_MSDOS_PARTITION=y # CONFIG_BSD_DISKLABEL is not set # CONFIG_MINIX_SUBPARTITION is not set # CONFIG_SOLARIS_X86_PARTITION is not set # CONFIG_UNIXWARE_DISKLABEL is not set # CONFIG_LDM_PARTITION is not set # CONFIG_SGI_PARTITION is not set # CONFIG_ULTRIX_PARTITION is not set # CONFIG_SUN_PARTITION is not set # CONFIG_KARMA_PARTITION is not set CONFIG_EFI_PARTITION=y # CONFIG_SYSV68_PARTITION is not set CONFIG_CMDLINE_PARTITION=y # end of Partition Types CONFIG_BLK_MQ_VIRTIO=y CONFIG_BLK_PM=y # # IO Schedulers # CONFIG_MQ_IOSCHED_DEADLINE=y CONFIG_MQ_IOSCHED_KYBER=y # CONFIG_IOSCHED_BFQ is not set # end of IO Schedulers CONFIG_ASN1=y CONFIG_UNINLINE_SPIN_UNLOCK=y CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y CONFIG_FREEZER=y # # Executable file formats # CONFIG_BINFMT_ELF=y # CONFIG_BINFMT_ELF_FDPIC is not set CONFIG_ELFCORE=y CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y CONFIG_BINFMT_SCRIPT=y CONFIG_ARCH_HAS_BINFMT_FLAT=y # CONFIG_BINFMT_FLAT is not set CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y # CONFIG_BINFMT_MISC is not set CONFIG_COREDUMP=y # end of Executable file formats # # Memory Management options # CONFIG_SWAP=y # CONFIG_ZSWAP is not set # # SLAB allocator options # # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_SLOB is not set CONFIG_SLAB_MERGE_DEFAULT=y # CONFIG_SLAB_FREELIST_RANDOM is not set # CONFIG_SLAB_FREELIST_HARDENED is not set # CONFIG_SLUB_STATS is not set # end of SLAB allocator options # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set CONFIG_COMPAT_BRK=y CONFIG_SELECT_MEMORY_MODEL=y CONFIG_FLATMEM_MANUAL=y # CONFIG_SPARSEMEM_MANUAL is not set CONFIG_FLATMEM=y CONFIG_ARCH_KEEP_MEMBLOCK=y CONFIG_MEMORY_ISOLATION=y CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_COMPACTION=y CONFIG_COMPACT_UNEVICTABLE_DEFAULT=1 # CONFIG_PAGE_REPORTING is not set CONFIG_MIGRATION=y CONFIG_CONTIG_ALLOC=y CONFIG_PCP_BATCH_SCALE_MAX=5 CONFIG_BOUNCE=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_ARCH_WANT_GENERAL_HUGETLB=y CONFIG_NEED_PER_CPU_KM=y CONFIG_CMA=y # CONFIG_CMA_DEBUG is not set # CONFIG_CMA_DEBUGFS is not set # CONFIG_CMA_SYSFS is not set CONFIG_CMA_AREAS=7 CONFIG_GENERIC_EARLY_IOREMAP=y # CONFIG_IDLE_PAGE_TRACKING is not set CONFIG_ARCH_HAS_CURRENT_STACK_POINTER=y CONFIG_VM_EVENT_COUNTERS=y # CONFIG_PERCPU_STATS is not set # CONFIG_GUP_TEST is not set CONFIG_KMAP_LOCAL=y CONFIG_KMAP_LOCAL_NON_LINEAR_PTE_ARRAY=y # CONFIG_ANON_VMA_NAME is not set # CONFIG_USERFAULTFD is not set # CONFIG_LRU_GEN is not set CONFIG_LOCK_MM_AND_FIND_VMA=y # # Data Access Monitoring # # CONFIG_DAMON is not set # end of Data Access Monitoring # end of Memory Management options CONFIG_NET=y CONFIG_SKB_EXTENSIONS=y # # Networking options # CONFIG_PACKET=y # CONFIG_PACKET_DIAG is not set CONFIG_UNIX=y CONFIG_UNIX_SCM=y CONFIG_AF_UNIX_OOB=y # CONFIG_UNIX_DIAG is not set # CONFIG_TLS is not set CONFIG_XFRM=y CONFIG_XFRM_ALGO=m # CONFIG_XFRM_USER is not set # CONFIG_XFRM_INTERFACE is not set # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set # CONFIG_XFRM_STATISTICS is not set CONFIG_XFRM_AH=m CONFIG_XFRM_ESP=m CONFIG_XFRM_IPCOMP=m # CONFIG_NET_KEY is not set CONFIG_INET=y # CONFIG_IP_MULTICAST is not set # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y CONFIG_IP_PNP_RARP=y # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set CONFIG_NET_IP_TUNNEL=y # CONFIG_SYN_COOKIES is not set # CONFIG_NET_IPVTI is not set # CONFIG_NET_FOU is not set # CONFIG_NET_FOU_IP_TUNNELS is not set # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set CONFIG_INET_TABLE_PERTURB_ORDER=16 CONFIG_INET_TUNNEL=y CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_INET_UDP_DIAG is not set # CONFIG_INET_RAW_DIAG is not set # CONFIG_INET_DIAG_DESTROY is not set # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set CONFIG_IPV6=y CONFIG_IPV6_ROUTER_PREF=y # CONFIG_IPV6_ROUTE_INFO is not set CONFIG_IPV6_OPTIMISTIC_DAD=y CONFIG_INET6_AH=m CONFIG_INET6_ESP=m # CONFIG_INET6_ESP_OFFLOAD is not set # CONFIG_INET6_ESPINTCP is not set CONFIG_INET6_IPCOMP=m CONFIG_IPV6_MIP6=m CONFIG_INET6_XFRM_TUNNEL=m CONFIG_INET6_TUNNEL=m # CONFIG_IPV6_VTI is not set CONFIG_IPV6_SIT=y # CONFIG_IPV6_SIT_6RD is not set CONFIG_IPV6_NDISC_NODETYPE=y CONFIG_IPV6_TUNNEL=m CONFIG_IPV6_MULTIPLE_TABLES=y # CONFIG_IPV6_SUBTREES is not set # CONFIG_IPV6_MROUTE is not set # CONFIG_IPV6_SEG6_LWTUNNEL is not set # CONFIG_IPV6_SEG6_HMAC is not set # CONFIG_IPV6_RPL_LWTUNNEL is not set # CONFIG_IPV6_IOAM6_LWTUNNEL is not set # CONFIG_MPTCP is not set # CONFIG_NETWORK_SECMARK is not set CONFIG_NET_PTP_CLASSIFY=y # CONFIG_NETWORK_PHY_TIMESTAMPING is not set # CONFIG_NETFILTER is not set # CONFIG_BPFILTER is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set # CONFIG_BRIDGE is not set CONFIG_NET_DSA=m # CONFIG_NET_DSA_TAG_AR9331 is not set CONFIG_NET_DSA_TAG_BRCM_COMMON=m CONFIG_NET_DSA_TAG_BRCM=m CONFIG_NET_DSA_TAG_BRCM_LEGACY=m CONFIG_NET_DSA_TAG_BRCM_PREPEND=m # CONFIG_NET_DSA_TAG_HELLCREEK is not set # CONFIG_NET_DSA_TAG_GSWIP is not set # CONFIG_NET_DSA_TAG_DSA is not set # CONFIG_NET_DSA_TAG_EDSA is not set # CONFIG_NET_DSA_TAG_MTK is not set # CONFIG_NET_DSA_TAG_KSZ is not set # CONFIG_NET_DSA_TAG_OCELOT is not set # CONFIG_NET_DSA_TAG_OCELOT_8021Q is not set # CONFIG_NET_DSA_TAG_QCA is not set # CONFIG_NET_DSA_TAG_RTL4_A is not set # CONFIG_NET_DSA_TAG_RTL8_4 is not set # CONFIG_NET_DSA_TAG_RZN1_A5PSW is not set # CONFIG_NET_DSA_TAG_LAN9303 is not set # CONFIG_NET_DSA_TAG_SJA1105 is not set # CONFIG_NET_DSA_TAG_TRAILER is not set # CONFIG_NET_DSA_TAG_XRS700X is not set # CONFIG_VLAN_8021Q is not set # CONFIG_LLC2 is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set # CONFIG_6LOWPAN is not set # CONFIG_IEEE802154 is not set # CONFIG_NET_SCHED is not set # CONFIG_DCB is not set CONFIG_DNS_RESOLVER=y # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set # CONFIG_VSOCKETS is not set # CONFIG_NETLINK_DIAG is not set # CONFIG_MPLS is not set # CONFIG_NET_NSH is not set # CONFIG_HSR is not set CONFIG_NET_SWITCHDEV=y # CONFIG_NET_L3_MASTER_DEV is not set CONFIG_QRTR=m CONFIG_QRTR_SMD=m # CONFIG_QRTR_TUN is not set # CONFIG_NET_NCSI is not set # CONFIG_CGROUP_NET_PRIO is not set # CONFIG_CGROUP_NET_CLASSID is not set CONFIG_NET_RX_BUSY_POLL=y CONFIG_BQL=y # # Network testing # # CONFIG_NET_PKTGEN is not set # CONFIG_NET_DROP_MONITOR is not set # end of Network testing # end of Networking options # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set # CONFIG_BT is not set # CONFIG_AF_RXRPC is not set # CONFIG_AF_KCM is not set # CONFIG_MCTP is not set CONFIG_FIB_RULES=y CONFIG_WIRELESS=y CONFIG_WIRELESS_EXT=y CONFIG_WEXT_CORE=y CONFIG_WEXT_PROC=y CONFIG_WEXT_SPY=y CONFIG_WEXT_PRIV=y CONFIG_CFG80211=m # CONFIG_NL80211_TESTMODE is not set # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set # CONFIG_CFG80211_CERTIFICATION_ONUS is not set CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y CONFIG_CFG80211_DEFAULT_PS=y # CONFIG_CFG80211_DEBUGFS is not set CONFIG_CFG80211_CRDA_SUPPORT=y # CONFIG_CFG80211_WEXT is not set CONFIG_MAC80211=m CONFIG_MAC80211_HAS_RC=y CONFIG_MAC80211_RC_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT="minstrel_ht" # CONFIG_MAC80211_MESH is not set # CONFIG_MAC80211_LEDS is not set # CONFIG_MAC80211_DEBUGFS is not set # CONFIG_MAC80211_MESSAGE_TRACING is not set # CONFIG_MAC80211_DEBUG_MENU is not set CONFIG_MAC80211_STA_HASH_MAX_SIZE=0 CONFIG_RFKILL=y CONFIG_RFKILL_INPUT=y CONFIG_RFKILL_GPIO=y # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # CONFIG_NFC is not set # CONFIG_PSAMPLE is not set # CONFIG_NET_IFE is not set # CONFIG_LWTUNNEL is not set CONFIG_DST_CACHE=y CONFIG_GRO_CELLS=y CONFIG_NET_SELFTESTS=y CONFIG_NET_DEVLINK=y CONFIG_PAGE_POOL=y CONFIG_PAGE_POOL_STATS=y CONFIG_FAILOVER=y CONFIG_ETHTOOL_NETLINK=y # # Device Drivers # CONFIG_HAVE_PCI=y # CONFIG_PCI is not set # CONFIG_PCCARD is not set # # Generic Driver Options # # CONFIG_UEVENT_HELPER is not set CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y # CONFIG_DEVTMPFS_SAFE is not set CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y # # Firmware loader # CONFIG_FW_LOADER=y CONFIG_EXTRA_FIRMWARE="" # CONFIG_FW_LOADER_USER_HELPER is not set # CONFIG_FW_LOADER_COMPRESS is not set CONFIG_FW_CACHE=y # CONFIG_FW_UPLOAD is not set # end of Firmware loader CONFIG_WANT_DEV_COREDUMP=y CONFIG_ALLOW_DEV_COREDUMP=y CONFIG_DEV_COREDUMP=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set CONFIG_GENERIC_CPU_AUTOPROBE=y CONFIG_GENERIC_CPU_VULNERABILITIES=y CONFIG_SOC_BUS=y CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_SPI=y CONFIG_REGMAP_MMIO=y CONFIG_REGMAP_IRQ=y CONFIG_DMA_SHARED_BUFFER=y # CONFIG_DMA_FENCE_TRACE is not set # end of Generic Driver Options # # Bus devices # CONFIG_BRCMSTB_GISB_ARB=y # CONFIG_MOXTET is not set CONFIG_OMAP_INTERCONNECT=y CONFIG_OMAP_OCP2SCP=y CONFIG_TI_PWMSS=y CONFIG_TI_SYSC=y CONFIG_VEXPRESS_CONFIG=y # CONFIG_MHI_BUS is not set # CONFIG_MHI_BUS_EP is not set # end of Bus devices # CONFIG_CONNECTOR is not set # # Firmware Drivers # # # ARM System Control and Management Interface Protocol # CONFIG_ARM_SCMI_PROTOCOL=y CONFIG_ARM_SCMI_HAVE_TRANSPORT=y CONFIG_ARM_SCMI_HAVE_SHMEM=y CONFIG_ARM_SCMI_TRANSPORT_MAILBOX=y CONFIG_ARM_SCMI_TRANSPORT_SMC=y # CONFIG_ARM_SCMI_TRANSPORT_SMC_ATOMIC_ENABLE is not set # CONFIG_ARM_SCMI_TRANSPORT_VIRTIO is not set CONFIG_ARM_SCMI_POWER_DOMAIN=y # CONFIG_ARM_SCMI_POWER_CONTROL is not set # end of ARM System Control and Management Interface Protocol # CONFIG_ARM_SCPI_PROTOCOL is not set # CONFIG_FIRMWARE_MEMMAP is not set CONFIG_DMIID=y # CONFIG_DMI_SYSFS is not set # CONFIG_FW_CFG_SYSFS is not set # CONFIG_SYSFB_SIMPLEFB is not set CONFIG_TRUSTED_FOUNDATIONS=y # CONFIG_GOOGLE_FIRMWARE is not set # # EFI (Extensible Firmware Interface) Support # CONFIG_EFI_ESRT=y CONFIG_EFI_VARS_PSTORE=y # CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE is not set CONFIG_EFI_PARAMS_FROM_FDT=y CONFIG_EFI_RUNTIME_WRAPPERS=y CONFIG_EFI_GENERIC_STUB=y CONFIG_EFI_ARMSTUB_DTB_LOADER=y # CONFIG_EFI_GENERIC_STUB_INITRD_CMDLINE_LOADER is not set # CONFIG_EFI_BOOTLOADER_CONTROL is not set CONFIG_EFI_CAPSULE_LOADER=m # CONFIG_EFI_TEST is not set # CONFIG_RESET_ATTACK_MITIGATION is not set # CONFIG_EFI_DISABLE_PCI_DMA is not set # CONFIG_EFI_DISABLE_RUNTIME is not set # CONFIG_EFI_COCO_SECRET is not set # end of EFI (Extensible Firmware Interface) Support CONFIG_ARM_PSCI_FW=y CONFIG_HAVE_ARM_SMCCC=y CONFIG_HAVE_ARM_SMCCC_DISCOVERY=y CONFIG_ARM_SMCCC_SOC_ID=y # # Tegra firmware driver # # end of Tegra firmware driver # end of Firmware Drivers # CONFIG_GNSS is not set CONFIG_MTD=y # CONFIG_MTD_TESTS is not set # # Partition parsers # CONFIG_MTD_AR7_PARTS=m CONFIG_MTD_CMDLINE_PARTS=y CONFIG_MTD_OF_PARTS=y # CONFIG_MTD_AFS_PARTS is not set # CONFIG_MTD_REDBOOT_PARTS is not set # end of Partition parsers # # User Modules And Translation Layers # CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # # Note that in some cases UBI block is preferred. See MTD_UBI_BLOCK. # # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set # CONFIG_MTD_OOPS is not set # CONFIG_MTD_SWAP is not set # CONFIG_MTD_PARTITIONED_MASTER is not set # # RAM/ROM/Flash chip drivers # CONFIG_MTD_CFI=y # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_GEN_PROBE=y # CONFIG_MTD_CFI_ADV_OPTIONS is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y CONFIG_MTD_CFI_INTELEXT=y # CONFIG_MTD_CFI_AMDSTD is not set # CONFIG_MTD_CFI_STAA is not set CONFIG_MTD_CFI_UTIL=y # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # end of RAM/ROM/Flash chip drivers # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set CONFIG_MTD_PHYSMAP=y # CONFIG_MTD_PHYSMAP_COMPAT is not set CONFIG_MTD_PHYSMAP_OF=y # CONFIG_MTD_PHYSMAP_VERSATILE is not set # CONFIG_MTD_PHYSMAP_GEMINI is not set # CONFIG_MTD_PHYSMAP_IXP4XX is not set # CONFIG_MTD_PLATRAM is not set # end of Mapping drivers for chip access # # Self-contained MTD device drivers # # CONFIG_MTD_DATAFLASH is not set # CONFIG_MTD_MCHP23K256 is not set # CONFIG_MTD_MCHP48L640 is not set # CONFIG_MTD_SST25L is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOCG3 is not set # end of Self-contained MTD device drivers # # NAND # # CONFIG_MTD_ONENAND is not set # CONFIG_MTD_RAW_NAND is not set # CONFIG_MTD_SPI_NAND is not set # # ECC engine support # # CONFIG_MTD_NAND_ECC_SW_HAMMING is not set # CONFIG_MTD_NAND_ECC_SW_BCH is not set # CONFIG_MTD_NAND_ECC_MXIC is not set # end of ECC engine support # end of NAND # # LPDDR & LPDDR2 PCM memory drivers # # CONFIG_MTD_LPDDR is not set # CONFIG_MTD_LPDDR2_NVM is not set # end of LPDDR & LPDDR2 PCM memory drivers # CONFIG_MTD_SPI_NOR is not set # CONFIG_MTD_UBI is not set # CONFIG_MTD_HYPERBUS is not set CONFIG_DTC=y CONFIG_OF=y # CONFIG_OF_UNITTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_KOBJ=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_RESERVED_MEM=y # CONFIG_OF_OVERLAY is not set CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_NULL_BLK is not set CONFIG_CDROM=y # CONFIG_ZRAM is not set CONFIG_BLK_DEV_LOOP=y CONFIG_BLK_DEV_LOOP_MIN_COUNT=8 # CONFIG_BLK_DEV_DRBD is not set # CONFIG_BLK_DEV_NBD is not set CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_COUNT=8 CONFIG_BLK_DEV_RAM_SIZE=65536 # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set # CONFIG_VIRTIO_BLK is not set # CONFIG_BLK_DEV_RBD is not set # CONFIG_BLK_DEV_UBLK is not set # # NVME Support # # CONFIG_NVME_FC is not set # CONFIG_NVME_TCP is not set # CONFIG_NVME_TARGET is not set # end of NVME Support # # Misc devices # # CONFIG_AD525X_DPOT is not set # CONFIG_DUMMY_IRQ is not set # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_APDS9802ALS is not set # CONFIG_ISL29003 is not set # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_LATTICE_ECP3_CONFIG is not set # CONFIG_SRAM is not set # CONFIG_XILINX_SDFEC is not set # CONFIG_HISI_HIKEY_USB is not set # CONFIG_OPEN_DICE is not set # CONFIG_VCPU_STALL_DETECTOR is not set # CONFIG_DMA_BUF_PHYS is not set # CONFIG_C2PORT is not set # # EEPROM support # # CONFIG_EEPROM_AT24 is not set # CONFIG_EEPROM_AT25 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set # CONFIG_EEPROM_93CX6 is not set # CONFIG_EEPROM_93XX46 is not set # CONFIG_EEPROM_IDT_89HPESX is not set # CONFIG_EEPROM_EE1004 is not set # end of EEPROM support # # Texas Instruments shared transport line discipline # # CONFIG_TI_ST is not set # end of Texas Instruments shared transport line discipline # CONFIG_SENSORS_LIS3_SPI is not set # CONFIG_SENSORS_LIS3_I2C is not set # CONFIG_ALTERA_STAPL is not set # CONFIG_ECHO is not set # CONFIG_MISC_RTSX_USB is not set # CONFIG_PVPANIC is not set # end of Misc devices # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_RAID_ATTRS is not set CONFIG_SCSI_COMMON=y CONFIG_SCSI=y CONFIG_SCSI_DMA=y CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set CONFIG_BLK_DEV_SR=y # CONFIG_CHR_DEV_SG is not set CONFIG_BLK_DEV_BSG=y # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_ATTRS is not set # CONFIG_SCSI_SAS_LIBSAS is not set # CONFIG_SCSI_SRP_ATTRS is not set # end of SCSI Transports CONFIG_SCSI_LOWLEVEL=y # CONFIG_ISCSI_TCP is not set # CONFIG_ISCSI_BOOT_SYSFS is not set # CONFIG_SCSI_DEBUG is not set # CONFIG_SCSI_VIRTIO is not set # CONFIG_SCSI_DH is not set # end of SCSI device support # CONFIG_ATA is not set # CONFIG_MD is not set # CONFIG_TARGET_CORE is not set CONFIG_NETDEVICES=y CONFIG_NET_CORE=y # CONFIG_BONDING is not set # CONFIG_DUMMY is not set # CONFIG_WIREGUARD is not set # CONFIG_EQUALIZER is not set # CONFIG_NET_TEAM is not set # CONFIG_MACVLAN is not set # CONFIG_IPVLAN is not set # CONFIG_VXLAN is not set # CONFIG_GENEVE is not set # CONFIG_BAREUDP is not set # CONFIG_GTP is not set # CONFIG_MACSEC is not set # CONFIG_NETCONSOLE is not set # CONFIG_TUN is not set # CONFIG_TUN_VNET_CROSS_LE is not set # CONFIG_VETH is not set # CONFIG_VIRTIO_NET is not set # CONFIG_NLMON is not set # # Distributed Switch Architecture drivers # # CONFIG_B53 is not set # CONFIG_NET_DSA_BCM_SF2 is not set # CONFIG_NET_DSA_LOOP is not set # CONFIG_NET_DSA_LANTIQ_GSWIP is not set # CONFIG_NET_DSA_MT7530 is not set # CONFIG_NET_DSA_MV88E6060 is not set # CONFIG_NET_DSA_MICROCHIP_KSZ_COMMON is not set # CONFIG_NET_DSA_MV88E6XXX is not set # CONFIG_NET_DSA_AR9331 is not set # CONFIG_NET_DSA_QCA8K is not set # CONFIG_NET_DSA_SJA1105 is not set # CONFIG_NET_DSA_XRS700X_I2C is not set # CONFIG_NET_DSA_XRS700X_MDIO is not set # CONFIG_NET_DSA_REALTEK is not set # CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set # CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set # CONFIG_NET_DSA_VITESSE_VSC73XX_SPI is not set # CONFIG_NET_DSA_VITESSE_VSC73XX_PLATFORM is not set # end of Distributed Switch Architecture drivers CONFIG_ETHERNET=y # CONFIG_NET_VENDOR_ALACRITECH is not set # CONFIG_ALTERA_TSE is not set # CONFIG_NET_VENDOR_AMAZON is not set # CONFIG_NET_VENDOR_AQUANTIA is not set # CONFIG_NET_VENDOR_ARC is not set # CONFIG_NET_VENDOR_ASIX is not set # CONFIG_NET_VENDOR_BROADCOM is not set # CONFIG_NET_VENDOR_CADENCE is not set # CONFIG_NET_VENDOR_CAVIUM is not set # CONFIG_NET_VENDOR_CIRRUS is not set # CONFIG_NET_VENDOR_CORTINA is not set # CONFIG_NET_VENDOR_DAVICOM is not set # CONFIG_DNET is not set # CONFIG_NET_VENDOR_ENGLEDER is not set # CONFIG_NET_VENDOR_EZCHIP is not set # CONFIG_NET_VENDOR_FARADAY is not set # CONFIG_NET_VENDOR_FUNGIBLE is not set # CONFIG_NET_VENDOR_GOOGLE is not set # CONFIG_NET_VENDOR_HISILICON is not set # CONFIG_NET_VENDOR_HUAWEI is not set # CONFIG_NET_VENDOR_INTEL is not set # CONFIG_NET_VENDOR_ADI is not set # CONFIG_NET_VENDOR_LITEX is not set # CONFIG_NET_VENDOR_MARVELL is not set # CONFIG_NET_VENDOR_MELLANOX is not set # CONFIG_NET_VENDOR_MICREL is not set # CONFIG_NET_VENDOR_MICROCHIP is not set # CONFIG_NET_VENDOR_MICROSEMI is not set # CONFIG_NET_VENDOR_MICROSOFT is not set # CONFIG_NET_VENDOR_NI is not set # CONFIG_NET_VENDOR_NATSEMI is not set # CONFIG_NET_VENDOR_NETRONOME is not set # CONFIG_ETHOC is not set # CONFIG_NET_VENDOR_PENSANDO is not set # CONFIG_NET_VENDOR_QUALCOMM is not set # CONFIG_NET_VENDOR_RENESAS is not set # CONFIG_NET_VENDOR_ROCKER is not set # CONFIG_NET_VENDOR_SAMSUNG is not set # CONFIG_NET_VENDOR_SEEQ is not set # CONFIG_NET_VENDOR_SOLARFLARE is not set # CONFIG_NET_VENDOR_SMSC is not set # CONFIG_NET_VENDOR_SOCIONEXT is not set # CONFIG_NET_VENDOR_STMICRO is not set # CONFIG_NET_VENDOR_SYNOPSYS is not set CONFIG_NET_VENDOR_TI=y # CONFIG_TI_DAVINCI_EMAC is not set CONFIG_TI_DAVINCI_MDIO=y # CONFIG_TI_CPSW_PHY_SEL is not set CONFIG_TI_CPSW=y CONFIG_TI_CPSW_SWITCHDEV=y CONFIG_TI_CPTS=y # CONFIG_TI_PRUETH is not set CONFIG_TI_ICSS_IEP=m # CONFIG_NET_VENDOR_VERTEXCOM is not set # CONFIG_NET_VENDOR_VIA is not set # CONFIG_NET_VENDOR_WANGXUN is not set # CONFIG_NET_VENDOR_WIZNET is not set # CONFIG_NET_VENDOR_XILINX is not set CONFIG_PHYLINK=m CONFIG_PHYLIB=y CONFIG_SWPHY=y CONFIG_FIXED_PHY=y # CONFIG_SFP is not set # # MII PHY device drivers # # CONFIG_AMD_PHY is not set # CONFIG_ADIN_PHY is not set # CONFIG_ADIN1100_PHY is not set # CONFIG_AQUANTIA_PHY is not set # CONFIG_AX88796B_PHY is not set # CONFIG_BROADCOM_PHY is not set # CONFIG_BCM54140_PHY is not set # CONFIG_BCM7XXX_PHY is not set # CONFIG_BCM84881_PHY is not set # CONFIG_BCM87XX_PHY is not set # CONFIG_CICADA_PHY is not set # CONFIG_CORTINA_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_ICPLUS_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_INTEL_XWAY_PHY is not set # CONFIG_LSI_ET1011C_PHY is not set # CONFIG_MARVELL_PHY is not set # CONFIG_MARVELL_10G_PHY is not set # CONFIG_MARVELL_88X2222_PHY is not set # CONFIG_MAXLINEAR_GPHY is not set # CONFIG_MEDIATEK_GE_PHY is not set # CONFIG_MICREL_PHY is not set # CONFIG_MICROCHIP_PHY is not set # CONFIG_MICROCHIP_T1_PHY is not set # CONFIG_MICROSEMI_PHY is not set # CONFIG_MOTORCOMM_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_NXP_C45_TJA11XX_PHY is not set # CONFIG_AT803X_PHY is not set # CONFIG_QSEMI_PHY is not set # CONFIG_REALTEK_PHY is not set # CONFIG_RENESAS_PHY is not set # CONFIG_ROCKCHIP_PHY is not set CONFIG_SMSC_PHY=y # CONFIG_STE10XP is not set # CONFIG_TERANETICS_PHY is not set # CONFIG_DP83822_PHY is not set # CONFIG_DP83TC811_PHY is not set # CONFIG_DP83848_PHY is not set # CONFIG_DP83867_PHY is not set # CONFIG_DP83869_PHY is not set # CONFIG_DP83TD510_PHY is not set # CONFIG_VITESSE_PHY is not set # CONFIG_XILINX_GMII2RGMII is not set # CONFIG_MICREL_KS8995MA is not set # CONFIG_PSE_CONTROLLER is not set CONFIG_MDIO_DEVICE=y CONFIG_MDIO_BUS=y CONFIG_FWNODE_MDIO=y CONFIG_OF_MDIO=y CONFIG_MDIO_DEVRES=y CONFIG_MDIO_BITBANG=y # CONFIG_MDIO_BCM_UNIMAC is not set # CONFIG_MDIO_GPIO is not set # CONFIG_MDIO_HISI_FEMAC is not set # CONFIG_MDIO_MVUSB is not set # CONFIG_MDIO_MSCC_MIIM is not set # CONFIG_MDIO_IPQ4019 is not set # CONFIG_MDIO_IPQ8064 is not set # # MDIO Multiplexers # # CONFIG_MDIO_BUS_MUX_GPIO is not set # CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set # CONFIG_MDIO_BUS_MUX_MMIOREG is not set # # PCS device drivers # # end of PCS device drivers # CONFIG_PPP is not set # CONFIG_SLIP is not set CONFIG_USB_NET_DRIVERS=y # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set # CONFIG_USB_PEGASUS is not set # CONFIG_USB_RTL8150 is not set # CONFIG_USB_RTL8152 is not set # CONFIG_USB_LAN78XX is not set # CONFIG_USB_USBNET is not set # CONFIG_USB_HSO is not set # CONFIG_USB_IPHETH is not set CONFIG_WLAN=y # CONFIG_WLAN_VENDOR_ADMTEK is not set # CONFIG_WLAN_VENDOR_ATH is not set # CONFIG_WLAN_VENDOR_ATMEL is not set # CONFIG_WLAN_VENDOR_BROADCOM is not set # CONFIG_WLAN_VENDOR_CISCO is not set # CONFIG_WLAN_VENDOR_INTEL is not set # CONFIG_WLAN_VENDOR_INTERSIL is not set # CONFIG_WLAN_VENDOR_MARVELL is not set # CONFIG_WLAN_VENDOR_MEDIATEK is not set # CONFIG_WLAN_VENDOR_MICROCHIP is not set # CONFIG_WLAN_VENDOR_PURELIFI is not set # CONFIG_WLAN_VENDOR_RALINK is not set # CONFIG_WLAN_VENDOR_REALTEK is not set # CONFIG_WLAN_VENDOR_RSI is not set # CONFIG_WLAN_VENDOR_SILABS is not set # CONFIG_WLAN_VENDOR_ST is not set # CONFIG_WLAN_VENDOR_TI is not set # CONFIG_WLAN_VENDOR_ZYDAS is not set # CONFIG_WLAN_VENDOR_QUANTENNA is not set # CONFIG_MAC80211_HWSIM is not set # CONFIG_USB_NET_RNDIS_WLAN is not set # CONFIG_VIRT_WIFI is not set CONFIG_REDPINE_WLAN_MODULE_NEEDED=y # CONFIG_WAN is not set # # Wireless WAN # # CONFIG_WWAN is not set # end of Wireless WAN # CONFIG_NETDEVSIM is not set CONFIG_NET_FAILOVER=y # CONFIG_ISDN is not set # # Input device support # CONFIG_INPUT=y CONFIG_INPUT_LEDS=y # CONFIG_INPUT_FF_MEMLESS is not set # CONFIG_INPUT_SPARSEKMAP is not set # CONFIG_INPUT_MATRIXKMAP is not set # # Userland interfaces # # CONFIG_INPUT_MOUSEDEV is not set # CONFIG_INPUT_JOYDEV is not set CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # # CONFIG_INPUT_KEYBOARD is not set # CONFIG_INPUT_MOUSE is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set CONFIG_INPUT_TOUCHSCREEN=y # CONFIG_TOUCHSCREEN_ADS7846 is not set # CONFIG_TOUCHSCREEN_AD7877 is not set # CONFIG_TOUCHSCREEN_AD7879 is not set # CONFIG_TOUCHSCREEN_ADC is not set # CONFIG_TOUCHSCREEN_AR1021_I2C is not set # CONFIG_TOUCHSCREEN_ATMEL_MXT is not set # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set # CONFIG_TOUCHSCREEN_BU21013 is not set # CONFIG_TOUCHSCREEN_BU21029 is not set # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set # CONFIG_TOUCHSCREEN_CY8CTMA140 is not set # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set # CONFIG_TOUCHSCREEN_DYNAPRO is not set # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set # CONFIG_TOUCHSCREEN_EETI is not set # CONFIG_TOUCHSCREEN_EGALAX is not set # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set # CONFIG_TOUCHSCREEN_EXC3000 is not set # CONFIG_TOUCHSCREEN_FUJITSU is not set # CONFIG_TOUCHSCREEN_GOODIX is not set # CONFIG_TOUCHSCREEN_HIDEEP is not set # CONFIG_TOUCHSCREEN_HYCON_HY46XX is not set # CONFIG_TOUCHSCREEN_ILI210X is not set # CONFIG_TOUCHSCREEN_ILITEK is not set # CONFIG_TOUCHSCREEN_S6SY761 is not set # CONFIG_TOUCHSCREEN_GUNZE is not set # CONFIG_TOUCHSCREEN_EKTF2127 is not set # CONFIG_TOUCHSCREEN_ELAN is not set # CONFIG_TOUCHSCREEN_ELO is not set # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set # CONFIG_TOUCHSCREEN_WACOM_I2C is not set # CONFIG_TOUCHSCREEN_MAX11801 is not set # CONFIG_TOUCHSCREEN_MCS5000 is not set # CONFIG_TOUCHSCREEN_MMS114 is not set # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set # CONFIG_TOUCHSCREEN_MSG2638 is not set # CONFIG_TOUCHSCREEN_MTOUCH is not set # CONFIG_TOUCHSCREEN_IMAGIS is not set # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set # CONFIG_TOUCHSCREEN_INEXIO is not set # CONFIG_TOUCHSCREEN_MK712 is not set # CONFIG_TOUCHSCREEN_PENMOUNT is not set # CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set # CONFIG_TOUCHSCREEN_TOUCHWIN is not set # CONFIG_TOUCHSCREEN_PIXCIR is not set # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set # CONFIG_TOUCHSCREEN_TSC_SERIO is not set # CONFIG_TOUCHSCREEN_TSC2004 is not set # CONFIG_TOUCHSCREEN_TSC2005 is not set # CONFIG_TOUCHSCREEN_TSC2007 is not set # CONFIG_TOUCHSCREEN_RM_TS is not set # CONFIG_TOUCHSCREEN_SILEAD is not set # CONFIG_TOUCHSCREEN_SIS_I2C is not set # CONFIG_TOUCHSCREEN_ST1232 is not set # CONFIG_TOUCHSCREEN_STMFTS is not set # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set # CONFIG_TOUCHSCREEN_SX8654 is not set # CONFIG_TOUCHSCREEN_TPS6507X is not set # CONFIG_TOUCHSCREEN_ZET6223 is not set # CONFIG_TOUCHSCREEN_ZFORCE is not set # CONFIG_TOUCHSCREEN_COLIBRI_VF50 is not set # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set # CONFIG_TOUCHSCREEN_IQS5XX is not set # CONFIG_TOUCHSCREEN_ZINITIX is not set CONFIG_INPUT_MISC=y # CONFIG_INPUT_AD714X is not set # CONFIG_INPUT_ATMEL_CAPTOUCH is not set # CONFIG_INPUT_BMA150 is not set # CONFIG_INPUT_E3X0_BUTTON is not set # CONFIG_INPUT_MMA8450 is not set # CONFIG_INPUT_GPIO_BEEPER is not set # CONFIG_INPUT_GPIO_DECODER is not set # CONFIG_INPUT_GPIO_VIBRA is not set # CONFIG_INPUT_ATI_REMOTE2 is not set # CONFIG_INPUT_KEYSPAN_REMOTE is not set # CONFIG_INPUT_KXTJ9 is not set # CONFIG_INPUT_POWERMATE is not set # CONFIG_INPUT_YEALINK is not set # CONFIG_INPUT_CM109 is not set # CONFIG_INPUT_REGULATOR_HAPTIC is not set # CONFIG_INPUT_TPS65218_PWRBUTTON is not set # CONFIG_INPUT_TWL4030_PWRBUTTON is not set # CONFIG_INPUT_TWL4030_VIBRA is not set # CONFIG_INPUT_UINPUT is not set # CONFIG_INPUT_PCF8574 is not set # CONFIG_INPUT_PWM_BEEPER is not set # CONFIG_INPUT_PWM_VIBRA is not set # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set # CONFIG_INPUT_DA7280_HAPTICS is not set # CONFIG_INPUT_ADXL34X is not set # CONFIG_INPUT_IBM_PANEL is not set # CONFIG_INPUT_IMS_PCU is not set # CONFIG_INPUT_IQS269A is not set # CONFIG_INPUT_IQS626A is not set # CONFIG_INPUT_IQS7222 is not set # CONFIG_INPUT_CMA3000 is not set # CONFIG_INPUT_DRV260X_HAPTICS is not set # CONFIG_INPUT_DRV2665_HAPTICS is not set # CONFIG_INPUT_DRV2667_HAPTICS is not set # CONFIG_RMI4_CORE is not set # # Hardware I/O ports # CONFIG_SERIO=y CONFIG_SERIO_SERPORT=y # CONFIG_SERIO_LIBPS2 is not set # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_SERIO_ARC_PS2 is not set # CONFIG_SERIO_APBPS2 is not set # CONFIG_SERIO_GPIO_PS2 is not set # CONFIG_USERIO is not set # CONFIG_GAMEPORT is not set # end of Hardware I/O ports # end of Input device support # # Character devices # CONFIG_TTY=y CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_VT_CONSOLE_SLEEP=y CONFIG_HW_CONSOLE=y CONFIG_VT_HW_CONSOLE_BINDING=y CONFIG_UNIX98_PTYS=y CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=8 CONFIG_LDISC_AUTOLOAD=y # # Serial drivers # CONFIG_SERIAL_EARLYCON=y CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y CONFIG_SERIAL_8250_16550A_VARIANTS=y # CONFIG_SERIAL_8250_FINTEK is not set CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_DMA=y CONFIG_SERIAL_8250_NR_UARTS=5 CONFIG_SERIAL_8250_RUNTIME_UARTS=5 CONFIG_SERIAL_8250_EXTENDED=y CONFIG_SERIAL_8250_MANY_PORTS=y CONFIG_SERIAL_8250_SHARE_IRQ=y # CONFIG_SERIAL_8250_DETECT_IRQ is not set # CONFIG_SERIAL_8250_RSA is not set CONFIG_SERIAL_8250_DWLIB=y CONFIG_SERIAL_8250_FSL=y CONFIG_SERIAL_8250_DW=y # CONFIG_SERIAL_8250_RT288X is not set CONFIG_SERIAL_8250_OMAP=y CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y CONFIG_SERIAL_8250_PRUSS=m CONFIG_SERIAL_OF_PLATFORM=y # # Non-8250 serial port support # # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX310X is not set # CONFIG_SERIAL_UARTLITE is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_SIFIVE is not set # CONFIG_SERIAL_SCCNXP is not set # CONFIG_SERIAL_SC16IS7XX is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set CONFIG_SERIAL_XILINX_PS_UART=y CONFIG_SERIAL_XILINX_PS_UART_CONSOLE=y # CONFIG_SERIAL_ARC is not set CONFIG_SERIAL_FSL_LPUART=y CONFIG_SERIAL_FSL_LPUART_CONSOLE=y # CONFIG_SERIAL_FSL_LINFLEXUART is not set CONFIG_SERIAL_CONEXANT_DIGICOLOR=y CONFIG_SERIAL_CONEXANT_DIGICOLOR_CONSOLE=y CONFIG_SERIAL_ST_ASC=y CONFIG_SERIAL_ST_ASC_CONSOLE=y # CONFIG_SERIAL_SPRD is not set # end of Serial drivers CONFIG_SERIAL_MCTRL_GPIO=y # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_N_GSM is not set # CONFIG_NULL_TTY is not set CONFIG_HVC_DRIVER=y # CONFIG_HVC_DCC is not set # CONFIG_RPMSG_TTY is not set CONFIG_SERIAL_DEV_BUS=y CONFIG_SERIAL_DEV_CTRL_TTYPORT=y # CONFIG_TTY_PRINTK is not set CONFIG_VIRTIO_CONSOLE=y # CONFIG_IPMI_HANDLER is not set # CONFIG_IPMB_DEVICE_INTERFACE is not set CONFIG_HW_RANDOM=y # CONFIG_HW_RANDOM_TIMERIOMEM is not set # CONFIG_HW_RANDOM_BA431 is not set CONFIG_HW_RANDOM_OMAP=y CONFIG_HW_RANDOM_OMAP3_ROM=y # CONFIG_HW_RANDOM_VIRTIO is not set CONFIG_HW_RANDOM_KEYSTONE=y # CONFIG_HW_RANDOM_CCTRNG is not set # CONFIG_HW_RANDOM_XIPHERA is not set CONFIG_HW_RANDOM_ARM_SMCCC_TRNG=y CONFIG_DEVMEM=y CONFIG_TCG_TPM=m CONFIG_HW_RANDOM_TPM=y # CONFIG_TCG_TIS is not set # CONFIG_TCG_TIS_SPI is not set # CONFIG_TCG_TIS_I2C is not set # CONFIG_TCG_TIS_I2C_CR50 is not set # CONFIG_TCG_TIS_I2C_ATMEL is not set # CONFIG_TCG_TIS_I2C_INFINEON is not set # CONFIG_TCG_TIS_I2C_NUVOTON is not set # CONFIG_TCG_ATMEL is not set # CONFIG_TCG_VTPM_PROXY is not set # CONFIG_TCG_TIS_ST33ZP24_I2C is not set # CONFIG_TCG_TIS_ST33ZP24_SPI is not set # CONFIG_XILLYBUS is not set # CONFIG_XILLYUSB is not set CONFIG_RANDOM_TRUST_CPU=y CONFIG_RANDOM_TRUST_BOOTLOADER=y # end of Character devices # # I2C support # CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y CONFIG_I2C_MUX=y # # Multiplexer I2C Chip support # CONFIG_I2C_ARB_GPIO_CHALLENGE=m CONFIG_I2C_MUX_GPIO=y # CONFIG_I2C_MUX_GPMUX is not set # CONFIG_I2C_MUX_LTC4306 is not set # CONFIG_I2C_MUX_PCA9541 is not set # CONFIG_I2C_MUX_PCA954x is not set CONFIG_I2C_MUX_PINCTRL=y # CONFIG_I2C_MUX_REG is not set # CONFIG_I2C_DEMUX_PINCTRL is not set # CONFIG_I2C_MUX_MLXCPLD is not set # end of Multiplexer I2C Chip support # CONFIG_I2C_ATR is not set CONFIG_I2C_HELPER_AUTO=y CONFIG_I2C_ALGOBIT=y # # I2C Hardware Bus support # # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_CBUS_GPIO is not set # CONFIG_I2C_DAVINCI is not set # CONFIG_I2C_DESIGNWARE_PLATFORM is not set # CONFIG_I2C_EMEV2 is not set # CONFIG_I2C_GPIO is not set # CONFIG_I2C_OCORES is not set CONFIG_I2C_OMAP=y # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_RK3X is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_DIOLAN_U2C is not set # CONFIG_I2C_CP2615 is not set # CONFIG_I2C_ROBOTFUZZ_OSIF is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_VIRTIO is not set # end of I2C Hardware Bus support # CONFIG_I2C_STUB is not set CONFIG_I2C_SLAVE=y CONFIG_I2C_SLAVE_EEPROM=y # CONFIG_I2C_SLAVE_TESTUNIT is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set # end of I2C support # CONFIG_I3C is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y CONFIG_SPI_MEM=y # # SPI Master Controller Drivers # # CONFIG_SPI_ALTERA is not set # CONFIG_SPI_AXI_SPI_ENGINE is not set CONFIG_SPI_BITBANG=y # CONFIG_SPI_CADENCE is not set # CONFIG_SPI_CADENCE_QUADSPI is not set # CONFIG_SPI_CADENCE_XSPI is not set # CONFIG_SPI_DAVINCI is not set # CONFIG_SPI_DESIGNWARE is not set # CONFIG_SPI_NXP_FLEXSPI is not set # CONFIG_SPI_GPIO is not set # CONFIG_SPI_FSL_SPI is not set # CONFIG_SPI_MICROCHIP_CORE is not set # CONFIG_SPI_MICROCHIP_CORE_QSPI is not set # CONFIG_SPI_OC_TINY is not set CONFIG_SPI_OMAP24XX=y # CONFIG_SPI_TI_QSPI is not set # CONFIG_SPI_ROCKCHIP is not set # CONFIG_SPI_SC18IS602 is not set # CONFIG_SPI_SIFIVE is not set # CONFIG_SPI_MXIC is not set # CONFIG_SPI_XCOMM is not set # CONFIG_SPI_XILINX is not set # CONFIG_SPI_ZYNQMP_GQSPI is not set # CONFIG_SPI_AMD is not set # # SPI Multiplexer support # # CONFIG_SPI_MUX is not set # # SPI Protocol Masters # CONFIG_SPI_SPIDEV=y # CONFIG_SPI_LOOPBACK_TEST is not set # CONFIG_SPI_TLE62X0 is not set # CONFIG_SPI_SLAVE is not set # CONFIG_SPMI is not set # CONFIG_HSI is not set CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # # PPS clients support # # CONFIG_PPS_CLIENT_KTIMER is not set # CONFIG_PPS_CLIENT_LDISC is not set # CONFIG_PPS_CLIENT_GPIO is not set # # PPS generators support # # # PTP clock support # CONFIG_PTP_1588_CLOCK=y CONFIG_PTP_1588_CLOCK_OPTIONAL=y # # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks. # # CONFIG_PTP_1588_CLOCK_KVM is not set # CONFIG_PTP_1588_CLOCK_IDT82P33 is not set # CONFIG_PTP_1588_CLOCK_IDTCM is not set # end of PTP clock support CONFIG_PINCTRL=y CONFIG_GENERIC_PINCTRL_GROUPS=y CONFIG_PINMUX=y CONFIG_GENERIC_PINMUX_FUNCTIONS=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y # CONFIG_DEBUG_PINCTRL is not set # CONFIG_PINCTRL_CY8C95X0 is not set # CONFIG_PINCTRL_MCP23S08 is not set # CONFIG_PINCTRL_MICROCHIP_SGPIO is not set # CONFIG_PINCTRL_OCELOT is not set CONFIG_PINCTRL_SINGLE=y # CONFIG_PINCTRL_STMFX is not set # CONFIG_PINCTRL_SX150X is not set # # Renesas pinctrl drivers # # end of Renesas pinctrl drivers CONFIG_PINCTRL_TI_IODELAY=y CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y CONFIG_GPIOLIB=y CONFIG_GPIOLIB_FASTPATH_LIMIT=512 CONFIG_OF_GPIO=y CONFIG_GPIOLIB_IRQCHIP=y # CONFIG_DEBUG_GPIO is not set # CONFIG_GPIO_SYSFS is not set CONFIG_GPIO_CDEV=y CONFIG_GPIO_CDEV_V1=y CONFIG_GPIO_GENERIC=y # # Memory mapped GPIO drivers # # CONFIG_GPIO_74XX_MMIO is not set # CONFIG_GPIO_ALTERA is not set # CONFIG_GPIO_CADENCE is not set # CONFIG_GPIO_DAVINCI is not set # CONFIG_GPIO_DWAPB is not set # CONFIG_GPIO_FTGPIO010 is not set CONFIG_GPIO_GENERIC_PLATFORM=y # CONFIG_GPIO_GRGPIO is not set # CONFIG_GPIO_HLWD is not set # CONFIG_GPIO_LOGICVC is not set # CONFIG_GPIO_MB86S7X is not set # CONFIG_GPIO_MPC8XXX is not set CONFIG_GPIO_OMAP=y # CONFIG_GPIO_SIFIVE is not set # CONFIG_GPIO_SYSCON is not set # CONFIG_GPIO_XILINX is not set # CONFIG_GPIO_ZEVIO is not set # CONFIG_GPIO_AMD_FCH is not set # end of Memory mapped GPIO drivers # # I2C GPIO expanders # # CONFIG_GPIO_ADNP is not set # CONFIG_GPIO_GW_PLD is not set # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set # CONFIG_GPIO_PCA953X is not set # CONFIG_GPIO_PCA9570 is not set # CONFIG_GPIO_PCF857X is not set # CONFIG_GPIO_TPIC2810 is not set # end of I2C GPIO expanders # # MFD GPIO expanders # # CONFIG_HTC_EGPIO is not set # CONFIG_GPIO_TPS65218 is not set # CONFIG_GPIO_TWL4030 is not set # end of MFD GPIO expanders # # SPI GPIO expanders # # CONFIG_GPIO_74X164 is not set # CONFIG_GPIO_MAX3191X is not set # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MC33880 is not set # CONFIG_GPIO_PISOSR is not set # CONFIG_GPIO_XRA1403 is not set # end of SPI GPIO expanders # # USB GPIO expanders # # end of USB GPIO expanders # # Virtual GPIO drivers # # CONFIG_GPIO_AGGREGATOR is not set # CONFIG_GPIO_MOCKUP is not set # CONFIG_GPIO_VIRTIO is not set # CONFIG_GPIO_SIM is not set # end of Virtual GPIO drivers # CONFIG_W1 is not set CONFIG_POWER_RESET=y # CONFIG_POWER_RESET_BRCMKONA is not set # CONFIG_POWER_RESET_BRCMSTB is not set # CONFIG_POWER_RESET_GPIO is not set # CONFIG_POWER_RESET_GPIO_RESTART is not set # CONFIG_POWER_RESET_LTC2952 is not set # CONFIG_POWER_RESET_REGULATOR is not set # CONFIG_POWER_RESET_RESTART is not set # CONFIG_POWER_RESET_VERSATILE is not set CONFIG_POWER_RESET_VEXPRESS=y # CONFIG_POWER_RESET_KEYSTONE is not set # CONFIG_POWER_RESET_SYSCON is not set # CONFIG_POWER_RESET_SYSCON_POWEROFF is not set # CONFIG_SYSCON_REBOOT_MODE is not set # CONFIG_NVMEM_REBOOT_MODE is not set CONFIG_POWER_SUPPLY=y # CONFIG_POWER_SUPPLY_DEBUG is not set # CONFIG_PDA_POWER is not set # CONFIG_GENERIC_ADC_BATTERY is not set # CONFIG_IP5XXX_POWER is not set # CONFIG_TEST_POWER is not set # CONFIG_CHARGER_ADP5061 is not set # CONFIG_BATTERY_CW2015 is not set # CONFIG_BATTERY_DS2780 is not set # CONFIG_BATTERY_DS2781 is not set # CONFIG_BATTERY_DS2782 is not set # CONFIG_BATTERY_SAMSUNG_SDI is not set # CONFIG_BATTERY_SBS is not set # CONFIG_CHARGER_SBS is not set # CONFIG_MANAGER_SBS is not set # CONFIG_BATTERY_BQ27XXX is not set # CONFIG_BATTERY_MAX17040 is not set # CONFIG_BATTERY_MAX17042 is not set # CONFIG_CHARGER_ISP1704 is not set # CONFIG_CHARGER_MAX8903 is not set # CONFIG_CHARGER_TWL4030 is not set # CONFIG_CHARGER_LP8727 is not set # CONFIG_CHARGER_GPIO is not set # CONFIG_CHARGER_MANAGER is not set # CONFIG_CHARGER_LT3651 is not set # CONFIG_CHARGER_LTC4162L is not set # CONFIG_CHARGER_DETECTOR_MAX14656 is not set # CONFIG_CHARGER_MAX77976 is not set # CONFIG_CHARGER_BQ2415X is not set # CONFIG_CHARGER_BQ24190 is not set # CONFIG_CHARGER_BQ24257 is not set # CONFIG_CHARGER_BQ24735 is not set # CONFIG_CHARGER_BQ2515X is not set # CONFIG_CHARGER_BQ25890 is not set # CONFIG_CHARGER_BQ25980 is not set # CONFIG_CHARGER_BQ256XX is not set # CONFIG_CHARGER_SMB347 is not set # CONFIG_BATTERY_GAUGE_LTC2941 is not set # CONFIG_BATTERY_GOLDFISH is not set # CONFIG_BATTERY_RT5033 is not set # CONFIG_CHARGER_RT9455 is not set # CONFIG_CHARGER_UCS1002 is not set # CONFIG_CHARGER_BD99954 is not set # CONFIG_BATTERY_UG3105 is not set # CONFIG_HWMON is not set CONFIG_THERMAL=y # CONFIG_THERMAL_NETLINK is not set # CONFIG_THERMAL_STATISTICS is not set CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0 CONFIG_THERMAL_OF=y # CONFIG_THERMAL_WRITABLE_TRIPS is not set CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set # CONFIG_THERMAL_GOV_FAIR_SHARE is not set CONFIG_THERMAL_GOV_STEP_WISE=y # CONFIG_THERMAL_GOV_BANG_BANG is not set # CONFIG_THERMAL_GOV_USER_SPACE is not set CONFIG_CPU_THERMAL=y CONFIG_CPU_FREQ_THERMAL=y CONFIG_DEVFREQ_THERMAL=y # CONFIG_THERMAL_EMULATION is not set # CONFIG_THERMAL_MMIO is not set # # Texas Instruments thermal drivers # CONFIG_TI_SOC_THERMAL=y # CONFIG_TI_THERMAL is not set # CONFIG_OMAP3_THERMAL is not set # CONFIG_OMAP4_THERMAL is not set # CONFIG_OMAP5_THERMAL is not set # CONFIG_DRA752_THERMAL is not set # end of Texas Instruments thermal drivers # CONFIG_GENERIC_ADC_THERMAL is not set CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y # CONFIG_WATCHDOG_NOWAYOUT is not set CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y CONFIG_WATCHDOG_OPEN_TIMEOUT=0 # CONFIG_WATCHDOG_SYSFS is not set # CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set # # Watchdog Pretimeout Governors # # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set # CONFIG_GPIO_WATCHDOG is not set # CONFIG_XILINX_WATCHDOG is not set # CONFIG_ZIIRAVE_WATCHDOG is not set # CONFIG_CADENCE_WATCHDOG is not set # CONFIG_FTWDT010_WATCHDOG is not set # CONFIG_DW_WATCHDOG is not set CONFIG_OMAP_WATCHDOG=m # CONFIG_DAVINCI_WATCHDOG is not set # CONFIG_TWL4030_WATCHDOG is not set # CONFIG_MAX63XX_WATCHDOG is not set # CONFIG_ARM_SMC_WATCHDOG is not set # CONFIG_MEN_A21_WDT is not set # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set CONFIG_SSB_POSSIBLE=y # CONFIG_SSB is not set CONFIG_BCMA_POSSIBLE=y # CONFIG_BCMA is not set # # Multifunction device drivers # CONFIG_MFD_CORE=y # CONFIG_MFD_ACT8945A is not set # CONFIG_MFD_AS3711 is not set # CONFIG_MFD_AS3722 is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_ATMEL_FLEXCOM is not set # CONFIG_MFD_ATMEL_HLCDC is not set # CONFIG_MFD_BCM590XX is not set # CONFIG_MFD_BD9571MWV is not set # CONFIG_MFD_AXP20X_I2C is not set # CONFIG_MFD_MADERA is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_SPI is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_MFD_DA9055 is not set # CONFIG_MFD_DA9062 is not set # CONFIG_MFD_DA9063 is not set # CONFIG_MFD_DA9150 is not set # CONFIG_MFD_DLN2 is not set # CONFIG_MFD_GATEWORKS_GSC is not set # CONFIG_MFD_MC13XXX_SPI is not set # CONFIG_MFD_MC13XXX_I2C is not set # CONFIG_MFD_MP2629 is not set # CONFIG_MFD_HI6421_PMIC is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_MFD_IQS62X is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_88PM800 is not set # CONFIG_MFD_88PM805 is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_MAX14577 is not set # CONFIG_MFD_MAX77620 is not set # CONFIG_MFD_MAX77650 is not set # CONFIG_MFD_MAX77686 is not set # CONFIG_MFD_MAX77693 is not set # CONFIG_MFD_MAX77714 is not set # CONFIG_MFD_MAX77843 is not set # CONFIG_MFD_MAX8907 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set # CONFIG_MFD_MT6360 is not set # CONFIG_MFD_MT6370 is not set # CONFIG_MFD_MT6397 is not set # CONFIG_MFD_MENF21BMC is not set # CONFIG_MFD_OCELOT is not set # CONFIG_EZX_PCAP is not set # CONFIG_MFD_CPCAP is not set # CONFIG_MFD_VIPERBOARD is not set # CONFIG_MFD_NTXEC is not set # CONFIG_MFD_RETU is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_PM8XXX is not set # CONFIG_MFD_SY7636A is not set # CONFIG_MFD_RT4831 is not set # CONFIG_MFD_RT5033 is not set # CONFIG_MFD_RT5120 is not set # CONFIG_MFD_RC5T583 is not set # CONFIG_MFD_RK808 is not set # CONFIG_MFD_RN5T618 is not set # CONFIG_MFD_SEC_CORE is not set # CONFIG_MFD_SI476X_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_SKY81452 is not set # CONFIG_MFD_STMPE is not set CONFIG_MFD_SYSCON=y # CONFIG_MFD_TI_AM335X_TSCADC is not set # CONFIG_MFD_LP3943 is not set # CONFIG_MFD_LP8788 is not set # CONFIG_MFD_TI_LMU is not set CONFIG_MFD_OMAP_USB_HOST=y # CONFIG_MFD_PALMAS is not set # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65086 is not set # CONFIG_MFD_TPS65090 is not set # CONFIG_MFD_TPS65217 is not set # CONFIG_MFD_TI_LP873X is not set # CONFIG_MFD_TI_LP87565 is not set CONFIG_MFD_TPS65218=y # CONFIG_MFD_TPS65219 is not set # CONFIG_MFD_TPS6586X is not set # CONFIG_MFD_TPS65910 is not set # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS65912_SPI is not set # CONFIG_MFD_TPS6594_I2C is not set # CONFIG_MFD_TPS6594_SPI is not set CONFIG_TWL4030_CORE=y CONFIG_TWL4030_POWER=y # CONFIG_MFD_TWL4030_AUDIO is not set # CONFIG_TWL6040_CORE is not set # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_LM3533 is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_MFD_TQMX86 is not set # CONFIG_MFD_LOCHNAGAR is not set # CONFIG_MFD_ARIZONA_I2C is not set # CONFIG_MFD_ARIZONA_SPI is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set # CONFIG_MFD_ROHM_BD718XX is not set # CONFIG_MFD_ROHM_BD71828 is not set # CONFIG_MFD_ROHM_BD957XMUF is not set # CONFIG_MFD_STPMIC1 is not set # CONFIG_MFD_STMFX is not set # CONFIG_MFD_ATC260X_I2C is not set # CONFIG_MFD_QCOM_PM8008 is not set # CONFIG_MFD_VEXPRESS_SYSREG is not set # CONFIG_RAVE_SP_CORE is not set # CONFIG_MFD_INTEL_M10_BMC is not set # CONFIG_MFD_RSMU_I2C is not set # CONFIG_MFD_RSMU_SPI is not set # end of Multifunction device drivers CONFIG_REGULATOR=y # CONFIG_REGULATOR_DEBUG is not set CONFIG_REGULATOR_FIXED_VOLTAGE=y # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_88PG86X is not set # CONFIG_REGULATOR_ACT8865 is not set # CONFIG_REGULATOR_AD5398 is not set # CONFIG_REGULATOR_ARM_SCMI is not set # CONFIG_REGULATOR_DA9121 is not set # CONFIG_REGULATOR_DA9210 is not set # CONFIG_REGULATOR_DA9211 is not set # CONFIG_REGULATOR_FAN53555 is not set # CONFIG_REGULATOR_FAN53880 is not set # CONFIG_REGULATOR_GPIO is not set # CONFIG_REGULATOR_ISL9305 is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_LP872X is not set # CONFIG_REGULATOR_LP8755 is not set # CONFIG_REGULATOR_LTC3589 is not set # CONFIG_REGULATOR_LTC3676 is not set # CONFIG_REGULATOR_MAX1586 is not set # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8893 is not set # CONFIG_REGULATOR_MAX8952 is not set # CONFIG_REGULATOR_MAX8973 is not set # CONFIG_REGULATOR_MAX20086 is not set # CONFIG_REGULATOR_MAX77826 is not set # CONFIG_REGULATOR_MCP16502 is not set # CONFIG_REGULATOR_MP5416 is not set # CONFIG_REGULATOR_MP8859 is not set # CONFIG_REGULATOR_MP886X is not set # CONFIG_REGULATOR_MPQ7920 is not set # CONFIG_REGULATOR_MT6311 is not set # CONFIG_REGULATOR_PBIAS is not set # CONFIG_REGULATOR_PCA9450 is not set # CONFIG_REGULATOR_PF8X00 is not set # CONFIG_REGULATOR_PFUZE100 is not set # CONFIG_REGULATOR_PV88060 is not set # CONFIG_REGULATOR_PV88080 is not set # CONFIG_REGULATOR_PV88090 is not set # CONFIG_REGULATOR_PWM is not set # CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY is not set # CONFIG_REGULATOR_RT4801 is not set # CONFIG_REGULATOR_RT5190A is not set # CONFIG_REGULATOR_RT5759 is not set # CONFIG_REGULATOR_RT6160 is not set # CONFIG_REGULATOR_RT6245 is not set # CONFIG_REGULATOR_RTQ2134 is not set # CONFIG_REGULATOR_RTMV20 is not set # CONFIG_REGULATOR_RTQ6752 is not set # CONFIG_REGULATOR_SLG51000 is not set CONFIG_REGULATOR_TI_ABB=y # CONFIG_REGULATOR_SY8106A is not set # CONFIG_REGULATOR_SY8824X is not set # CONFIG_REGULATOR_SY8827N is not set # CONFIG_REGULATOR_TPS51632 is not set CONFIG_REGULATOR_TPS62360=y # CONFIG_REGULATOR_TPS6286X is not set # CONFIG_REGULATOR_TPS65023 is not set # CONFIG_REGULATOR_TPS6507X is not set # CONFIG_REGULATOR_TPS65132 is not set CONFIG_REGULATOR_TPS65218=y # CONFIG_REGULATOR_TPS6524X is not set # CONFIG_REGULATOR_TWL4030 is not set # CONFIG_REGULATOR_VCTRL is not set # CONFIG_REGULATOR_VEXPRESS is not set # CONFIG_RC_CORE is not set CONFIG_CEC_CORE=y # # CEC support # CONFIG_MEDIA_CEC_SUPPORT=y # CONFIG_CEC_CH7322 is not set # CONFIG_CEC_GPIO is not set # CONFIG_USB_PULSE8_CEC is not set # CONFIG_USB_RAINSHADOW_CEC is not set # end of CEC support # CONFIG_MEDIA_SUPPORT is not set # # Graphics support # # CONFIG_IMX_IPUV3_CORE is not set CONFIG_DRM=y # CONFIG_DRM_DEBUG_MM is not set CONFIG_DRM_KMS_HELPER=y # CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set # CONFIG_DRM_DEBUG_MODESET_LOCK is not set CONFIG_DRM_FBDEV_EMULATION=y CONFIG_DRM_FBDEV_OVERALLOC=100 # CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set CONFIG_DRM_DP_AUX_BUS=y CONFIG_DRM_DISPLAY_HELPER=y CONFIG_DRM_DISPLAY_DP_HELPER=y # CONFIG_DRM_DP_AUX_CHARDEV is not set # CONFIG_DRM_DP_CEC is not set CONFIG_DRM_GEM_DMA_HELPER=y # # I2C encoder or helper chips # # CONFIG_DRM_I2C_CH7006 is not set # CONFIG_DRM_I2C_SIL164 is not set # CONFIG_DRM_I2C_NXP_TDA998X is not set # CONFIG_DRM_I2C_NXP_TDA9950 is not set # end of I2C encoder or helper chips # # ARM devices # # CONFIG_DRM_HDLCD is not set # CONFIG_DRM_MALI_DISPLAY is not set # CONFIG_DRM_KOMEDA is not set # end of ARM devices # CONFIG_DRM_VGEM is not set # CONFIG_DRM_VKMS is not set # CONFIG_DRM_EXYNOS is not set # CONFIG_DRM_UDL is not set # CONFIG_DRM_ARMADA is not set # CONFIG_DRM_RCAR_DW_HDMI is not set # CONFIG_DRM_RCAR_USE_LVDS is not set # CONFIG_DRM_RCAR_USE_MIPI_DSI is not set CONFIG_DRM_OMAP=y # CONFIG_OMAP2_DSS_DEBUG is not set CONFIG_OMAP2_DSS_DEBUGFS=y # CONFIG_OMAP2_DSS_COLLECT_IRQ_STATS is not set CONFIG_OMAP2_DSS_DPI=y CONFIG_OMAP2_DSS_VENC=y CONFIG_OMAP2_DSS_HDMI_COMMON=y CONFIG_OMAP4_DSS_HDMI=y CONFIG_OMAP4_DSS_HDMI_CEC=y CONFIG_OMAP5_DSS_HDMI=y # CONFIG_OMAP2_DSS_SDI is not set # CONFIG_OMAP2_DSS_DSI is not set CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0 CONFIG_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y CONFIG_DRM_TILCDC=y # CONFIG_DRM_VIRTIO_GPU is not set # CONFIG_DRM_FSL_DCU is not set # CONFIG_DRM_STM is not set CONFIG_DRM_PANEL=y # # Display Panels # # CONFIG_DRM_PANEL_ABT_Y030XX067A is not set # CONFIG_DRM_PANEL_ARM_VERSATILE is not set CONFIG_DRM_PANEL_LVDS=m CONFIG_DRM_PANEL_SIMPLE=y CONFIG_DRM_PANEL_EDP=y # CONFIG_DRM_PANEL_ILITEK_IL9322 is not set # CONFIG_DRM_PANEL_ILITEK_ILI9341 is not set # CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set # CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set # CONFIG_DRM_PANEL_LG_LB035Q02 is not set # CONFIG_DRM_PANEL_LG_LG4573 is not set # CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set # CONFIG_DRM_PANEL_NEWVISION_NV3052C is not set # CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set # CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set # CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set # CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6D27A1 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set # CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set # CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set # CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set # CONFIG_DRM_PANEL_SONY_ACX565AKM is not set # CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set # CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set # CONFIG_DRM_PANEL_TPO_TPG110 is not set # CONFIG_DRM_PANEL_WIDECHIPS_WS2401 is not set # end of Display Panels CONFIG_DRM_BRIDGE=y CONFIG_DRM_PANEL_BRIDGE=y # # Display Interface Bridges # # CONFIG_DRM_CHIPONE_ICN6211 is not set # CONFIG_DRM_CHRONTEL_CH7033 is not set CONFIG_DRM_DISPLAY_CONNECTOR=m # CONFIG_DRM_ITE_IT6505 is not set # CONFIG_DRM_LONTIUM_LT8912B is not set # CONFIG_DRM_LONTIUM_LT9211 is not set # CONFIG_DRM_LONTIUM_LT9611 is not set # CONFIG_DRM_LONTIUM_LT9611UXC is not set # CONFIG_DRM_ITE_IT66121 is not set CONFIG_DRM_LVDS_CODEC=m # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set # CONFIG_DRM_NWL_MIPI_DSI is not set # CONFIG_DRM_NXP_PTN3460 is not set # CONFIG_DRM_PARADE_PS8622 is not set # CONFIG_DRM_PARADE_PS8640 is not set # CONFIG_DRM_SIL_SII8620 is not set CONFIG_DRM_SII902X=m # CONFIG_DRM_SII9234 is not set CONFIG_DRM_SIMPLE_BRIDGE=m # CONFIG_DRM_THINE_THC63LVD1024 is not set # CONFIG_DRM_TOSHIBA_TC358762 is not set # CONFIG_DRM_TOSHIBA_TC358764 is not set # CONFIG_DRM_TOSHIBA_TC358767 is not set # CONFIG_DRM_TOSHIBA_TC358768 is not set # CONFIG_DRM_TOSHIBA_TC358775 is not set # CONFIG_DRM_TI_DLPC3433 is not set # CONFIG_DRM_TI_TFP410 is not set # CONFIG_DRM_TI_SN65DSI83 is not set # CONFIG_DRM_TI_SN65DSI86 is not set # CONFIG_DRM_TI_TPD12S015 is not set # CONFIG_DRM_ANALOGIX_ANX6345 is not set # CONFIG_DRM_ANALOGIX_ANX78XX is not set # CONFIG_DRM_ANALOGIX_ANX7625 is not set # CONFIG_DRM_I2C_ADV7511 is not set # CONFIG_DRM_CDNS_DSI is not set # CONFIG_DRM_CDNS_MHDP8546 is not set # end of Display Interface Bridges # CONFIG_DRM_STI is not set # CONFIG_DRM_ETNAVIV is not set # CONFIG_DRM_LOGICVC is not set # CONFIG_DRM_ARCPGU is not set # CONFIG_DRM_GM12U320 is not set # CONFIG_DRM_PANEL_MIPI_DBI is not set # CONFIG_DRM_SIMPLEDRM is not set # CONFIG_TINYDRM_HX8357D is not set # CONFIG_TINYDRM_ILI9163 is not set # CONFIG_TINYDRM_ILI9225 is not set # CONFIG_TINYDRM_ILI9341 is not set # CONFIG_TINYDRM_ILI9486 is not set # CONFIG_TINYDRM_MI0283QT is not set # CONFIG_TINYDRM_REPAPER is not set # CONFIG_TINYDRM_ST7586 is not set # CONFIG_TINYDRM_ST7735R is not set # CONFIG_DRM_PL111 is not set # CONFIG_DRM_TVE200 is not set # CONFIG_DRM_LIMA is not set # CONFIG_DRM_PANFROST is not set # CONFIG_DRM_MCDE is not set # CONFIG_DRM_TIDSS is not set # CONFIG_DRM_GUD is not set # CONFIG_DRM_SSD130X is not set CONFIG_DRM_LEGACY=y CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y CONFIG_DRM_NOMODESET=y # # Frame buffer Devices # CONFIG_FB_CMDLINE=y CONFIG_FB_NOTIFY=y CONFIG_FB=y # CONFIG_FIRMWARE_EDID is not set CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y CONFIG_FB_SYS_FILLRECT=y CONFIG_FB_SYS_COPYAREA=y CONFIG_FB_SYS_IMAGEBLIT=y # CONFIG_FB_FOREIGN_ENDIAN is not set CONFIG_FB_SYS_FOPS=y CONFIG_FB_DEFERRED_IO=y CONFIG_FB_MODE_HELPERS=y # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_EFI is not set # CONFIG_FB_OPENCORES is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_SMSCUFX is not set # CONFIG_FB_UDL is not set # CONFIG_FB_IBM_GXT4500 is not set # CONFIG_FB_DA8XX is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_SIMPLE is not set # CONFIG_FB_SSD1307 is not set # end of Frame buffer Devices # # Backlight & LCD device support # # CONFIG_LCD_CLASS_DEVICE is not set CONFIG_BACKLIGHT_CLASS_DEVICE=y # CONFIG_BACKLIGHT_KTD253 is not set CONFIG_BACKLIGHT_PWM=y # CONFIG_BACKLIGHT_QCOM_WLED is not set # CONFIG_BACKLIGHT_ADP8860 is not set # CONFIG_BACKLIGHT_ADP8870 is not set # CONFIG_BACKLIGHT_LM3630A is not set # CONFIG_BACKLIGHT_LM3639 is not set # CONFIG_BACKLIGHT_LP855X is not set # CONFIG_BACKLIGHT_PANDORA is not set CONFIG_BACKLIGHT_GPIO=y # CONFIG_BACKLIGHT_LV5207LP is not set # CONFIG_BACKLIGHT_BD6107 is not set # CONFIG_BACKLIGHT_ARCXCNN is not set CONFIG_BACKLIGHT_LED=y # end of Backlight & LCD device support CONFIG_VIDEOMODE_HELPERS=y CONFIG_HDMI=y # # Console display driver support # CONFIG_DUMMY_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE=y # CONFIG_FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION is not set CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set # CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set # end of Console display driver support # CONFIG_LOGO is not set # end of Graphics support CONFIG_SOUND=y CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_PCM_ELD=y CONFIG_SND_PCM_IEC958=y CONFIG_SND_DMAENGINE_PCM=y CONFIG_SND_JACK=y CONFIG_SND_JACK_INPUT_DEV=y # CONFIG_SND_OSSEMUL is not set CONFIG_SND_PCM_TIMER=y # CONFIG_SND_HRTIMER is not set CONFIG_SND_DYNAMIC_MINORS=y CONFIG_SND_MAX_CARDS=32 CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_PROC_FS=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set CONFIG_SND_CTL_FAST_LOOKUP=y # CONFIG_SND_DEBUG is not set # CONFIG_SND_CTL_INPUT_VALIDATION is not set # CONFIG_SND_SEQUENCER is not set # CONFIG_SND_DRIVERS is not set # # HD-Audio # # end of HD-Audio CONFIG_SND_HDA_PREALLOC_SIZE=64 # CONFIG_SND_ARM is not set # CONFIG_SND_SPI is not set # CONFIG_SND_USB is not set CONFIG_SND_SOC=y CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y # CONFIG_SND_SOC_ADI is not set # CONFIG_SND_SOC_AMD_ACP is not set # CONFIG_SND_AMD_ACP_CONFIG is not set # CONFIG_SND_ATMEL_SOC is not set # CONFIG_SND_BCM63XX_I2S_WHISTLER is not set # CONFIG_SND_DESIGNWARE_I2S is not set # # SoC Audio for Freescale CPUs # # # Common SoC Audio options for Freescale CPUs: # # CONFIG_SND_SOC_FSL_ASRC is not set # CONFIG_SND_SOC_FSL_SAI is not set # CONFIG_SND_SOC_FSL_AUDMIX is not set # CONFIG_SND_SOC_FSL_SSI is not set # CONFIG_SND_SOC_FSL_SPDIF is not set # CONFIG_SND_SOC_FSL_ESAI is not set # CONFIG_SND_SOC_FSL_MICFIL is not set # CONFIG_SND_SOC_FSL_XCVR is not set # CONFIG_SND_SOC_FSL_RPMSG is not set # CONFIG_SND_SOC_IMX_AUDMUX is not set # end of SoC Audio for Freescale CPUs # CONFIG_SND_I2S_HI6210_I2S is not set # CONFIG_SND_SOC_IMG is not set # CONFIG_SND_SOC_MTK_BTCVSD is not set # CONFIG_SND_SOC_SOF_TOPLEVEL is not set # # STMicroelectronics STM32 SOC audio support # # end of STMicroelectronics STM32 SOC audio support # # Audio support for Texas Instruments SoCs # CONFIG_SND_SOC_TI_EDMA_PCM=y CONFIG_SND_SOC_TI_SDMA_PCM=y CONFIG_SND_SOC_TI_UDMA_PCM=y # # Texas Instruments DAI support for: # CONFIG_SND_SOC_DAVINCI_MCASP=y # CONFIG_SND_SOC_OMAP_DMIC is not set # CONFIG_SND_SOC_OMAP_MCBSP is not set # CONFIG_SND_SOC_OMAP_MCPDM is not set # # Audio support for boards with Texas Instruments SoCs # # CONFIG_SND_SOC_NOKIA_RX51 is not set # CONFIG_SND_SOC_OMAP3_PANDORA is not set # CONFIG_SND_SOC_OMAP3_TWL4030 is not set # CONFIG_SND_SOC_OMAP_HDMI is not set # end of Audio support for Texas Instruments SoCs # CONFIG_SND_SOC_XILINX_I2S is not set # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set # CONFIG_SND_SOC_XILINX_SPDIF is not set # CONFIG_SND_SOC_XTFPGA_I2S is not set CONFIG_SND_SOC_I2C_AND_SPI=y # # CODEC drivers # # CONFIG_SND_SOC_AC97_CODEC is not set # CONFIG_SND_SOC_ADAU1372_I2C is not set # CONFIG_SND_SOC_ADAU1372_SPI is not set # CONFIG_SND_SOC_ADAU1701 is not set # CONFIG_SND_SOC_ADAU1761_I2C is not set # CONFIG_SND_SOC_ADAU1761_SPI is not set # CONFIG_SND_SOC_ADAU7002 is not set # CONFIG_SND_SOC_ADAU7118_HW is not set # CONFIG_SND_SOC_ADAU7118_I2C is not set # CONFIG_SND_SOC_AK4104 is not set # CONFIG_SND_SOC_AK4118 is not set # CONFIG_SND_SOC_AK4375 is not set # CONFIG_SND_SOC_AK4458 is not set # CONFIG_SND_SOC_AK4554 is not set # CONFIG_SND_SOC_AK4613 is not set # CONFIG_SND_SOC_AK4642 is not set # CONFIG_SND_SOC_AK5386 is not set # CONFIG_SND_SOC_AK5558 is not set # CONFIG_SND_SOC_ALC5623 is not set # CONFIG_SND_SOC_AW8738 is not set # CONFIG_SND_SOC_BD28623 is not set # CONFIG_SND_SOC_BT_SCO is not set # CONFIG_SND_SOC_CS35L32 is not set # CONFIG_SND_SOC_CS35L33 is not set # CONFIG_SND_SOC_CS35L34 is not set # CONFIG_SND_SOC_CS35L35 is not set # CONFIG_SND_SOC_CS35L36 is not set # CONFIG_SND_SOC_CS35L41_SPI is not set # CONFIG_SND_SOC_CS35L41_I2C is not set # CONFIG_SND_SOC_CS35L45_SPI is not set # CONFIG_SND_SOC_CS35L45_I2C is not set # CONFIG_SND_SOC_CS42L42 is not set # CONFIG_SND_SOC_CS42L51_I2C is not set # CONFIG_SND_SOC_CS42L52 is not set # CONFIG_SND_SOC_CS42L56 is not set # CONFIG_SND_SOC_CS42L73 is not set # CONFIG_SND_SOC_CS42L83 is not set # CONFIG_SND_SOC_CS4234 is not set # CONFIG_SND_SOC_CS4265 is not set # CONFIG_SND_SOC_CS4270 is not set # CONFIG_SND_SOC_CS4271_I2C is not set # CONFIG_SND_SOC_CS4271_SPI is not set # CONFIG_SND_SOC_CS42XX8_I2C is not set # CONFIG_SND_SOC_CS43130 is not set # CONFIG_SND_SOC_CS4341 is not set # CONFIG_SND_SOC_CS4349 is not set # CONFIG_SND_SOC_CS53L30 is not set # CONFIG_SND_SOC_CX2072X is not set # CONFIG_SND_SOC_DA7213 is not set # CONFIG_SND_SOC_DMIC is not set CONFIG_SND_SOC_HDMI_CODEC=m # CONFIG_SND_SOC_ES7134 is not set # CONFIG_SND_SOC_ES7241 is not set # CONFIG_SND_SOC_ES8316 is not set # CONFIG_SND_SOC_ES8326 is not set # CONFIG_SND_SOC_ES8328_I2C is not set # CONFIG_SND_SOC_ES8328_SPI is not set # CONFIG_SND_SOC_GTM601 is not set # CONFIG_SND_SOC_HDA is not set # CONFIG_SND_SOC_ICS43432 is not set # CONFIG_SND_SOC_INNO_RK3036 is not set # CONFIG_SND_SOC_MAX98088 is not set # CONFIG_SND_SOC_MAX98357A is not set # CONFIG_SND_SOC_MAX98504 is not set # CONFIG_SND_SOC_MAX9867 is not set # CONFIG_SND_SOC_MAX98927 is not set # CONFIG_SND_SOC_MAX98520 is not set # CONFIG_SND_SOC_MAX98373_I2C is not set # CONFIG_SND_SOC_MAX98390 is not set # CONFIG_SND_SOC_MAX98396 is not set # CONFIG_SND_SOC_MAX9860 is not set # CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set # CONFIG_SND_SOC_PCM1681 is not set # CONFIG_SND_SOC_PCM1789_I2C is not set # CONFIG_SND_SOC_PCM179X_I2C is not set # CONFIG_SND_SOC_PCM179X_SPI is not set # CONFIG_SND_SOC_PCM186X_I2C is not set # CONFIG_SND_SOC_PCM186X_SPI is not set # CONFIG_SND_SOC_PCM3060_I2C is not set # CONFIG_SND_SOC_PCM3060_SPI is not set # CONFIG_SND_SOC_PCM3168A_I2C is not set # CONFIG_SND_SOC_PCM3168A_SPI is not set # CONFIG_SND_SOC_PCM5102A is not set # CONFIG_SND_SOC_PCM512x_I2C is not set # CONFIG_SND_SOC_PCM512x_SPI is not set # CONFIG_SND_SOC_RK3328 is not set # CONFIG_SND_SOC_RT5616 is not set # CONFIG_SND_SOC_RT5631 is not set # CONFIG_SND_SOC_RT5640 is not set # CONFIG_SND_SOC_RT5659 is not set # CONFIG_SND_SOC_RT9120 is not set # CONFIG_SND_SOC_SGTL5000 is not set # CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set # CONFIG_SND_SOC_SIMPLE_MUX is not set # CONFIG_SND_SOC_SPDIF is not set # CONFIG_SND_SOC_SRC4XXX_I2C is not set # CONFIG_SND_SOC_SSM2305 is not set # CONFIG_SND_SOC_SSM2518 is not set # CONFIG_SND_SOC_SSM2602_SPI is not set # CONFIG_SND_SOC_SSM2602_I2C is not set # CONFIG_SND_SOC_SSM4567 is not set # CONFIG_SND_SOC_STA32X is not set # CONFIG_SND_SOC_STA350 is not set # CONFIG_SND_SOC_STI_SAS is not set # CONFIG_SND_SOC_TAS2552 is not set # CONFIG_SND_SOC_TAS2562 is not set # CONFIG_SND_SOC_TAS2764 is not set # CONFIG_SND_SOC_TAS2770 is not set # CONFIG_SND_SOC_TAS2780 is not set # CONFIG_SND_SOC_TAS5086 is not set # CONFIG_SND_SOC_TAS571X is not set # CONFIG_SND_SOC_TAS5720 is not set # CONFIG_SND_SOC_TAS5805M is not set # CONFIG_SND_SOC_TAS6424 is not set # CONFIG_SND_SOC_TDA7419 is not set # CONFIG_SND_SOC_TFA9879 is not set # CONFIG_SND_SOC_TFA989X is not set # CONFIG_SND_SOC_TLV320ADC3XXX is not set # CONFIG_SND_SOC_TLV320AIC23_I2C is not set # CONFIG_SND_SOC_TLV320AIC23_SPI is not set CONFIG_SND_SOC_TLV320AIC31XX=y # CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set # CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set # CONFIG_SND_SOC_TLV320AIC3X_I2C is not set # CONFIG_SND_SOC_TLV320AIC3X_SPI is not set # CONFIG_SND_SOC_TLV320ADCX140 is not set # CONFIG_SND_SOC_TS3A227E is not set # CONFIG_SND_SOC_TSCS42XX is not set # CONFIG_SND_SOC_TSCS454 is not set # CONFIG_SND_SOC_UDA1334 is not set # CONFIG_SND_SOC_WM8510 is not set # CONFIG_SND_SOC_WM8523 is not set # CONFIG_SND_SOC_WM8524 is not set # CONFIG_SND_SOC_WM8580 is not set # CONFIG_SND_SOC_WM8711 is not set # CONFIG_SND_SOC_WM8728 is not set # CONFIG_SND_SOC_WM8731_I2C is not set # CONFIG_SND_SOC_WM8731_SPI is not set # CONFIG_SND_SOC_WM8737 is not set # CONFIG_SND_SOC_WM8741 is not set # CONFIG_SND_SOC_WM8750 is not set # CONFIG_SND_SOC_WM8753 is not set # CONFIG_SND_SOC_WM8770 is not set # CONFIG_SND_SOC_WM8776 is not set # CONFIG_SND_SOC_WM8782 is not set # CONFIG_SND_SOC_WM8804_I2C is not set # CONFIG_SND_SOC_WM8804_SPI is not set # CONFIG_SND_SOC_WM8903 is not set # CONFIG_SND_SOC_WM8904 is not set # CONFIG_SND_SOC_WM8940 is not set # CONFIG_SND_SOC_WM8960 is not set # CONFIG_SND_SOC_WM8962 is not set # CONFIG_SND_SOC_WM8974 is not set # CONFIG_SND_SOC_WM8978 is not set # CONFIG_SND_SOC_WM8985 is not set # CONFIG_SND_SOC_ZL38060 is not set # CONFIG_SND_SOC_MAX9759 is not set # CONFIG_SND_SOC_MT6351 is not set # CONFIG_SND_SOC_MT6358 is not set # CONFIG_SND_SOC_MT6660 is not set # CONFIG_SND_SOC_NAU8315 is not set # CONFIG_SND_SOC_NAU8540 is not set # CONFIG_SND_SOC_NAU8810 is not set # CONFIG_SND_SOC_NAU8821 is not set # CONFIG_SND_SOC_NAU8822 is not set # CONFIG_SND_SOC_NAU8824 is not set # CONFIG_SND_SOC_TPA6130A2 is not set # CONFIG_SND_SOC_LPASS_WSA_MACRO is not set # CONFIG_SND_SOC_LPASS_VA_MACRO is not set # CONFIG_SND_SOC_LPASS_RX_MACRO is not set # CONFIG_SND_SOC_LPASS_TX_MACRO is not set # end of CODEC drivers CONFIG_SND_SIMPLE_CARD_UTILS=y CONFIG_SND_SIMPLE_CARD=y CONFIG_SND_AUDIO_GRAPH_CARD=m # CONFIG_SND_AUDIO_GRAPH_CARD2 is not set # CONFIG_SND_TEST_COMPONENT is not set # CONFIG_SND_VIRTIO is not set # # HID support # CONFIG_HID=y # CONFIG_HID_BATTERY_STRENGTH is not set # CONFIG_HIDRAW is not set # CONFIG_UHID is not set CONFIG_HID_GENERIC=y # # Special HID drivers # # CONFIG_HID_A4TECH is not set # CONFIG_HID_ACCUTOUCH is not set # CONFIG_HID_ACRUX is not set # CONFIG_HID_APPLE is not set # CONFIG_HID_APPLEIR is not set # CONFIG_HID_ASUS is not set # CONFIG_HID_AUREAL is not set # CONFIG_HID_BELKIN is not set # CONFIG_HID_BETOP_FF is not set # CONFIG_HID_BIGBEN_FF is not set # CONFIG_HID_CHERRY is not set # CONFIG_HID_CHICONY is not set # CONFIG_HID_CORSAIR is not set # CONFIG_HID_COUGAR is not set # CONFIG_HID_MACALLY is not set # CONFIG_HID_PRODIKEYS is not set # CONFIG_HID_CMEDIA is not set # CONFIG_HID_CREATIVE_SB0540 is not set # CONFIG_HID_CYPRESS is not set # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EMS_FF is not set # CONFIG_HID_ELAN is not set # CONFIG_HID_ELECOM is not set # CONFIG_HID_ELO is not set # CONFIG_HID_EZKEY is not set # CONFIG_HID_GEMBIRD is not set # CONFIG_HID_GFRM is not set # CONFIG_HID_GLORIOUS is not set # CONFIG_HID_HOLTEK is not set # CONFIG_HID_VIVALDI is not set # CONFIG_HID_GT683R is not set # CONFIG_HID_KEYTOUCH is not set # CONFIG_HID_KYE is not set # CONFIG_HID_UCLOGIC is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_VIEWSONIC is not set # CONFIG_HID_VRC2 is not set # CONFIG_HID_XIAOMI is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_ICADE is not set # CONFIG_HID_ITE is not set # CONFIG_HID_JABRA is not set # CONFIG_HID_TWINHAN is not set # CONFIG_HID_KENSINGTON is not set # CONFIG_HID_LCPOWER is not set # CONFIG_HID_LED is not set # CONFIG_HID_LENOVO is not set # CONFIG_HID_LETSKETCH is not set # CONFIG_HID_LOGITECH is not set # CONFIG_HID_MAGICMOUSE is not set # CONFIG_HID_MALTRON is not set # CONFIG_HID_MAYFLASH is not set # CONFIG_HID_MEGAWORLD_FF is not set # CONFIG_HID_REDRAGON is not set # CONFIG_HID_MICROSOFT is not set # CONFIG_HID_MONTEREY is not set CONFIG_HID_MULTITOUCH=m # CONFIG_HID_NINTENDO is not set # CONFIG_HID_NTI is not set # CONFIG_HID_NTRIG is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PENMOUNT is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_PLANTRONICS is not set # CONFIG_HID_PXRC is not set # CONFIG_HID_RAZER is not set # CONFIG_HID_PRIMAX is not set # CONFIG_HID_RETRODE is not set # CONFIG_HID_ROCCAT is not set # CONFIG_HID_SAITEK is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SEMITEK is not set # CONFIG_HID_SIGMAMICRO is not set # CONFIG_HID_SONY is not set # CONFIG_HID_SPEEDLINK is not set # CONFIG_HID_STEAM is not set # CONFIG_HID_STEELSERIES is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_RMI is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TIVO is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_TOPRE is not set # CONFIG_HID_THINGM is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_UDRAW_PS3 is not set # CONFIG_HID_U2FZERO is not set # CONFIG_HID_WACOM is not set # CONFIG_HID_WIIMOTE is not set # CONFIG_HID_XINMO is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set # CONFIG_HID_SENSOR_HUB is not set # CONFIG_HID_ALPS is not set # CONFIG_HID_MCP2221 is not set # end of Special HID drivers # # USB HID support # CONFIG_USB_HID=y # CONFIG_HID_PID is not set # CONFIG_USB_HIDDEV is not set # end of USB HID support # # I2C HID support # # CONFIG_I2C_HID_OF is not set # CONFIG_I2C_HID_OF_ELAN is not set # CONFIG_I2C_HID_OF_GOODIX is not set # end of I2C HID support # end of HID support CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_SUPPORT=y CONFIG_USB_COMMON=y CONFIG_USB_ULPI_BUS=y CONFIG_USB_CONN_GPIO=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB=y # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set # # Miscellaneous USB options # CONFIG_USB_DEFAULT_PERSIST=y # CONFIG_USB_FEW_INIT_RETRIES is not set # CONFIG_USB_DYNAMIC_MINORS is not set # CONFIG_USB_OTG is not set # CONFIG_USB_OTG_PRODUCTLIST is not set # CONFIG_USB_OTG_DISABLE_EXTERNAL_HUB is not set CONFIG_USB_AUTOSUSPEND_DELAY=2 # CONFIG_USB_MON is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set CONFIG_USB_XHCI_HCD=y # CONFIG_USB_XHCI_DBGCAP is not set # CONFIG_USB_XHCI_PCI_RENESAS is not set CONFIG_USB_XHCI_PLATFORM=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_ROOT_HUB_TT=y CONFIG_USB_EHCI_TT_NEWSCHED=y # CONFIG_USB_EHCI_FSL is not set CONFIG_USB_EHCI_HCD_OMAP=y CONFIG_USB_EHCI_HCD_PLATFORM=y # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_FOTG210_HCD is not set # CONFIG_USB_MAX3421_HCD is not set CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_HCD_OMAP3=y CONFIG_USB_OHCI_HCD_PLATFORM=y # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_HCD_TEST_MODE is not set # # USB Device Class drivers # CONFIG_USB_ACM=m # CONFIG_USB_PRINTER is not set # CONFIG_USB_WDM is not set # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=y # CONFIG_USB_STORAGE_DEBUG is not set # CONFIG_USB_STORAGE_REALTEK is not set # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set # CONFIG_USB_STORAGE_ENE_UB6250 is not set # CONFIG_USB_UAS is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # CONFIG_USBIP_CORE is not set # CONFIG_USB_CDNS_SUPPORT is not set CONFIG_USB_MUSB_HDRC=m CONFIG_USB_MUSB_HOST=y # # Platform Glue Layer # # CONFIG_USB_MUSB_TUSB6010 is not set CONFIG_USB_MUSB_OMAP2PLUS=m CONFIG_USB_MUSB_AM35X=m # CONFIG_USB_MUSB_DSPS is not set # # MUSB DMA mode # # CONFIG_MUSB_PIO_ONLY is not set CONFIG_USB_INVENTRA_DMA=y CONFIG_USB_TI_CPPI41_DMA=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_ULPI is not set CONFIG_USB_DWC3_HOST=y # # Platform Glue Driver Support # CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_KEYSTONE=y CONFIG_USB_DWC3_OF_SIMPLE=y # CONFIG_USB_DWC2 is not set # CONFIG_USB_CHIPIDEA is not set # CONFIG_USB_ISP1760 is not set # # USB port drivers # CONFIG_USB_SERIAL=m # CONFIG_USB_SERIAL_GENERIC is not set # CONFIG_USB_SERIAL_SIMPLE is not set # CONFIG_USB_SERIAL_AIRCABLE is not set # CONFIG_USB_SERIAL_ARK3116 is not set # CONFIG_USB_SERIAL_BELKIN is not set CONFIG_USB_SERIAL_CH341=m # CONFIG_USB_SERIAL_WHITEHEAT is not set # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set # CONFIG_USB_SERIAL_CP210X is not set # CONFIG_USB_SERIAL_CYPRESS_M8 is not set # CONFIG_USB_SERIAL_EMPEG is not set # CONFIG_USB_SERIAL_FTDI_SIO is not set # CONFIG_USB_SERIAL_VISOR is not set # CONFIG_USB_SERIAL_IPAQ is not set # CONFIG_USB_SERIAL_IR is not set # CONFIG_USB_SERIAL_EDGEPORT is not set # CONFIG_USB_SERIAL_EDGEPORT_TI is not set # CONFIG_USB_SERIAL_F81232 is not set # CONFIG_USB_SERIAL_F8153X is not set # CONFIG_USB_SERIAL_GARMIN is not set # CONFIG_USB_SERIAL_IPW is not set # CONFIG_USB_SERIAL_IUU is not set # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set # CONFIG_USB_SERIAL_KEYSPAN is not set # CONFIG_USB_SERIAL_KLSI is not set # CONFIG_USB_SERIAL_KOBIL_SCT is not set # CONFIG_USB_SERIAL_MCT_U232 is not set # CONFIG_USB_SERIAL_METRO is not set # CONFIG_USB_SERIAL_MOS7720 is not set # CONFIG_USB_SERIAL_MOS7840 is not set # CONFIG_USB_SERIAL_MXUPORT is not set # CONFIG_USB_SERIAL_NAVMAN is not set # CONFIG_USB_SERIAL_PL2303 is not set # CONFIG_USB_SERIAL_OTI6858 is not set # CONFIG_USB_SERIAL_QCAUX is not set # CONFIG_USB_SERIAL_QUALCOMM is not set # CONFIG_USB_SERIAL_SPCP8X5 is not set # CONFIG_USB_SERIAL_SAFE is not set # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set # CONFIG_USB_SERIAL_SYMBOL is not set # CONFIG_USB_SERIAL_TI is not set # CONFIG_USB_SERIAL_CYBERJACK is not set # CONFIG_USB_SERIAL_OPTION is not set # CONFIG_USB_SERIAL_OMNINET is not set # CONFIG_USB_SERIAL_OPTICON is not set # CONFIG_USB_SERIAL_XSENS_MT is not set # CONFIG_USB_SERIAL_WISHBONE is not set # CONFIG_USB_SERIAL_SSU100 is not set # CONFIG_USB_SERIAL_QT2 is not set # CONFIG_USB_SERIAL_UPD78F0730 is not set # CONFIG_USB_SERIAL_XR is not set # CONFIG_USB_SERIAL_DEBUG is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_APPLE_MFI_FASTCHARGE is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_EHSET_TEST_FIXTURE is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_EZUSB_FX2 is not set CONFIG_USB_HUB_USB251XB=m # CONFIG_USB_HSIC_USB3503 is not set # CONFIG_USB_HSIC_USB4604 is not set # CONFIG_USB_LINK_LAYER_TEST is not set # CONFIG_USB_CHAOSKEY is not set CONFIG_USB_ONBOARD_HUB=m # # USB Physical Layer drivers # CONFIG_USB_PHY=y CONFIG_KEYSTONE_USB_PHY=m CONFIG_NOP_USB_XCEIV=y CONFIG_AM335X_CONTROL_USB=m CONFIG_AM335X_PHY_USB=m # CONFIG_TWL6030_USB is not set CONFIG_USB_GPIO_VBUS=y # CONFIG_USB_ISP1301 is not set CONFIG_USB_ULPI=y CONFIG_USB_ULPI_VIEWPORT=y # end of USB Physical Layer drivers # CONFIG_USB_GADGET is not set # CONFIG_TYPEC is not set CONFIG_USB_ROLE_SWITCH=y CONFIG_MMC=y CONFIG_PWRSEQ_EMMC=y CONFIG_PWRSEQ_SIMPLE=y CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=16 # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_DEBUG is not set CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_PLTFM=y CONFIG_MMC_SDHCI_OF_ARASAN=y CONFIG_MMC_SDHCI_OF_AT91=y # CONFIG_MMC_SDHCI_OF_DWCMSHC is not set # CONFIG_MMC_SDHCI_CADENCE is not set # CONFIG_MMC_SDHCI_F_SDH30 is not set # CONFIG_MMC_SDHCI_MILBEAUT is not set CONFIG_MMC_OMAP=y CONFIG_MMC_OMAP_HS=y # CONFIG_MMC_SPI is not set # CONFIG_MMC_DW is not set # CONFIG_MMC_VUB300 is not set # CONFIG_MMC_USHC is not set # CONFIG_MMC_USDHI6ROL0 is not set CONFIG_MMC_CQHCI=y # CONFIG_MMC_HSQ is not set # CONFIG_MMC_MTK is not set # CONFIG_MMC_SDHCI_XENON is not set CONFIG_MMC_SDHCI_OMAP=y CONFIG_MMC_SDHCI_EXTERNAL_DMA=y # CONFIG_SCSI_UFSHCD is not set # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y # CONFIG_LEDS_CLASS_FLASH is not set # CONFIG_LEDS_CLASS_MULTICOLOR is not set # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set # # LED drivers # # CONFIG_LEDS_AN30259A is not set # CONFIG_LEDS_AW2013 is not set # CONFIG_LEDS_BCM6328 is not set # CONFIG_LEDS_BCM6358 is not set # CONFIG_LEDS_CR0014114 is not set # CONFIG_LEDS_EL15203000 is not set # CONFIG_LEDS_LM3530 is not set # CONFIG_LEDS_LM3532 is not set # CONFIG_LEDS_LM3642 is not set # CONFIG_LEDS_LM3692X is not set # CONFIG_LEDS_PCA9532 is not set CONFIG_LEDS_GPIO=y # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_LP3952 is not set # CONFIG_LEDS_LP50XX is not set # CONFIG_LEDS_LP55XX_COMMON is not set # CONFIG_LEDS_LP8860 is not set # CONFIG_LEDS_PCA955X is not set # CONFIG_LEDS_PCA963X is not set # CONFIG_LEDS_DAC124S085 is not set CONFIG_LEDS_PWM=y # CONFIG_LEDS_REGULATOR is not set # CONFIG_LEDS_BD2802 is not set # CONFIG_LEDS_LT3593 is not set # CONFIG_LEDS_TCA6507 is not set # CONFIG_LEDS_TLC591XX is not set # CONFIG_LEDS_LM355x is not set # CONFIG_LEDS_IS31FL319X is not set # CONFIG_LEDS_IS31FL32XX is not set # # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM) # # CONFIG_LEDS_BLINKM is not set # CONFIG_LEDS_SYSCON is not set # CONFIG_LEDS_MLXREG is not set # CONFIG_LEDS_USER is not set # CONFIG_LEDS_SPI_BYTE is not set # CONFIG_LEDS_TI_LMU_COMMON is not set # # Flash and Torch LED drivers # # # RGB LED drivers # # # LED Triggers # # CONFIG_LEDS_TRIGGERS is not set # # Simple LED drivers # # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_EDAC_ATOMIC_SCRUB=y CONFIG_EDAC_SUPPORT=y CONFIG_EDAC=y CONFIG_EDAC_LEGACY_SYSFS=y # CONFIG_EDAC_DEBUG is not set # CONFIG_EDAC_TI is not set CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" CONFIG_RTC_SYSTOHC=y CONFIG_RTC_SYSTOHC_DEVICE="rtc0" # CONFIG_RTC_DEBUG is not set CONFIG_RTC_NVMEM=y # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_ABB5ZES3 is not set # CONFIG_RTC_DRV_ABEOZ9 is not set # CONFIG_RTC_DRV_ABX80X is not set # CONFIG_RTC_DRV_DS1307 is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_HYM8563 is not set # CONFIG_RTC_DRV_MAX6900 is not set # CONFIG_RTC_DRV_NCT3018Y is not set # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_ISL12026 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8523 is not set # CONFIG_RTC_DRV_PCF85063 is not set # CONFIG_RTC_DRV_PCF85363 is not set CONFIG_RTC_DRV_PCF8563=y # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BQ32K is not set # CONFIG_RTC_DRV_TWL4030 is not set # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8010 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set # CONFIG_RTC_DRV_RV3028 is not set # CONFIG_RTC_DRV_RV3032 is not set # CONFIG_RTC_DRV_RV8803 is not set # CONFIG_RTC_DRV_SD3078 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T93 is not set # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1302 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1343 is not set # CONFIG_RTC_DRV_DS1347 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6916 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RX4581 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_PCF2123 is not set # CONFIG_RTC_DRV_MCP795 is not set CONFIG_RTC_I2C_AND_SPI=y # # SPI and I2C RTC drivers # # CONFIG_RTC_DRV_DS3232 is not set # CONFIG_RTC_DRV_PCF2127 is not set # CONFIG_RTC_DRV_RV3029C2 is not set # CONFIG_RTC_DRV_RX6110 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1685_FAMILY is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_DS2404 is not set # CONFIG_RTC_DRV_EFI is not set # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # CONFIG_RTC_DRV_ZYNQMP is not set # # on-CPU RTC drivers # # CONFIG_RTC_DRV_OMAP is not set # CONFIG_RTC_DRV_CADENCE is not set # CONFIG_RTC_DRV_FTRTC010 is not set # CONFIG_RTC_DRV_R7301 is not set # # HID Sensor RTC drivers # # CONFIG_RTC_DRV_GOLDFISH is not set CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y CONFIG_DMA_OF=y # CONFIG_ALTERA_MSGDMA is not set # CONFIG_DW_AXI_DMAC is not set # CONFIG_FSL_EDMA is not set # CONFIG_FSL_QDMA is not set # CONFIG_INTEL_IDMA64 is not set # CONFIG_NBPFAXI_DMA is not set # CONFIG_XILINX_ZYNQMP_DPDMA is not set # CONFIG_QCOM_HIDMA_MGMT is not set # CONFIG_QCOM_HIDMA is not set # CONFIG_DW_DMAC is not set # CONFIG_SF_PDMA is not set CONFIG_TI_CPPI41=m CONFIG_TI_EDMA=y CONFIG_DMA_OMAP=y CONFIG_TI_DMA_CROSSBAR=y # # DMA Clients # # CONFIG_ASYNC_TX_DMA is not set # CONFIG_DMATEST is not set # # DMABUF options # CONFIG_SYNC_FILE=y # CONFIG_SW_SYNC is not set # CONFIG_UDMABUF is not set # CONFIG_DMABUF_MOVE_NOTIFY is not set # CONFIG_DMABUF_DEBUG is not set # CONFIG_DMABUF_SELFTESTS is not set CONFIG_DMABUF_HEAPS=y # CONFIG_DMABUF_SYSFS_STATS is not set CONFIG_DMABUF_HEAPS_SYSTEM=y CONFIG_DMABUF_HEAPS_CMA=y CONFIG_DMABUF_HEAPS_CARVEOUT=y # end of DMABUF options # CONFIG_AUXDISPLAY is not set # CONFIG_UIO is not set # CONFIG_VFIO is not set # CONFIG_VIRT_DRIVERS is not set CONFIG_VIRTIO_ANCHOR=y CONFIG_VIRTIO=y CONFIG_VIRTIO_MENU=y # CONFIG_VIRTIO_BALLOON is not set # CONFIG_VIRTIO_INPUT is not set CONFIG_VIRTIO_MMIO=y # CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set # CONFIG_VDPA is not set CONFIG_VHOST_MENU=y # CONFIG_VHOST_NET is not set # CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set # # Microsoft Hyper-V guest support # # end of Microsoft Hyper-V guest support # CONFIG_GREYBUS is not set # CONFIG_COMEDI is not set CONFIG_STAGING=y # CONFIG_PRISM2_USB is not set # CONFIG_RTLLIB is not set # CONFIG_RTL8723BS is not set # CONFIG_R8712U is not set # CONFIG_R8188EU is not set # CONFIG_VT6656 is not set # # IIO staging drivers # # # Accelerometers # # CONFIG_ADIS16203 is not set # CONFIG_ADIS16240 is not set # end of Accelerometers # # Analog to digital converters # # CONFIG_AD7816 is not set # end of Analog to digital converters # # Analog digital bi-direction converters # # CONFIG_ADT7316 is not set # end of Analog digital bi-direction converters # # Direct Digital Synthesis # # CONFIG_AD9832 is not set # CONFIG_AD9834 is not set # end of Direct Digital Synthesis # # Network Analyzer, Impedance Converters # # CONFIG_AD5933 is not set # end of Network Analyzer, Impedance Converters # # Active energy metering IC # # CONFIG_ADE7854 is not set # end of Active energy metering IC # # Resolver to digital converters # # CONFIG_AD2S1210 is not set # end of Resolver to digital converters # end of IIO staging drivers # CONFIG_STAGING_MEDIA is not set # CONFIG_STAGING_BOARD is not set # CONFIG_LTE_GDM724X is not set # CONFIG_FB_TFT is not set # CONFIG_KS7010 is not set # CONFIG_PI433 is not set # CONFIG_XIL_AXIS_FIFO is not set # CONFIG_FIELDBUS_DEV is not set CONFIG_EDAN=y # CONFIG_NX_DEVSWITCH is not set # CONFIG_LED_TRIGGER_ALARM is not set CONFIG_EDAN_V8KBD=y CONFIG_EDAN_KEYPAD=y CONFIG_EDAN_TOUCH_SCREEN=y CONFIG_SPI_NX=y CONFIG_SPI_NX_MODULE_POWER=y CONFIG_SPI_NX_MODULE_UART=y # CONFIG_SPI_NX_MODULE_MAINBOARD_KEYPAD is not set # CONFIG_NX_ATTACH is not set # CONFIG_EDAN_MISC_BOARD is not set CONFIG_MXS_SII902X=y # CONFIG_EDAN_VIRTUAL_INPUT is not set CONFIG_LT9211=y CONFIG_EDAN_PANEL_MANAGEMENT=y CONFIG_EDAN_PANEL=y CONFIG_NCS8805_LCD=y # CONFIG_EDAN_KSZ8895_SPI is not set # CONFIG_GOLDFISH is not set # CONFIG_CHROME_PLATFORMS is not set # CONFIG_MELLANOX_PLATFORM is not set CONFIG_HAVE_CLK=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Clock driver for ARM Reference designs # CONFIG_CLK_ICST=y CONFIG_CLK_SP810=y CONFIG_CLK_VEXPRESS_OSC=y # end of Clock driver for ARM Reference designs # CONFIG_LMK04832 is not set # CONFIG_COMMON_CLK_MAX9485 is not set CONFIG_COMMON_CLK_SCMI=y # CONFIG_COMMON_CLK_SI5341 is not set # CONFIG_COMMON_CLK_SI5351 is not set # CONFIG_COMMON_CLK_SI514 is not set # CONFIG_COMMON_CLK_SI544 is not set # CONFIG_COMMON_CLK_SI570 is not set # CONFIG_COMMON_CLK_CDCE706 is not set # CONFIG_COMMON_CLK_CDCE925 is not set # CONFIG_COMMON_CLK_CS2000_CP is not set # CONFIG_COMMON_CLK_AXI_CLKGEN is not set # CONFIG_COMMON_CLK_PWM is not set # CONFIG_COMMON_CLK_RS9_PCIE is not set # CONFIG_COMMON_CLK_VC5 is not set # CONFIG_COMMON_CLK_VC7 is not set # CONFIG_COMMON_CLK_FIXED_MMIO is not set CONFIG_COMMON_CLK_KEYSTONE=y CONFIG_TI_SYSCON_CLK=y CONFIG_COMMON_CLK_TI_ADPLL=y # CONFIG_XILINX_VCU is not set # CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set CONFIG_HWSPINLOCK=y # CONFIG_HWSPINLOCK_OMAP is not set # # Clock Source drivers # CONFIG_TIMER_OF=y CONFIG_TIMER_PROBE=y CONFIG_OMAP_DM_SYSTIMER=y CONFIG_CLKSRC_MMIO=y CONFIG_OMAP_DM_TIMER=y CONFIG_KEYSTONE_TIMER=y CONFIG_CLKSRC_TI_32K=y CONFIG_ARM_ARCH_TIMER=y CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y # CONFIG_MICROCHIP_PIT64B is not set # end of Clock Source drivers CONFIG_MAILBOX=y # CONFIG_PLATFORM_MHU is not set # CONFIG_OMAP2PLUS_MBOX is not set # CONFIG_ALTERA_MBOX is not set # CONFIG_TI_MESSAGE_MANAGER is not set # CONFIG_MAILBOX_TEST is not set CONFIG_IOMMU_SUPPORT=y # # Generic IOMMU Pagetable Support # CONFIG_IOMMU_IO_PGTABLE=y CONFIG_IOMMU_IO_PGTABLE_LPAE=y # CONFIG_IOMMU_IO_PGTABLE_LPAE_SELFTEST is not set # CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set # end of Generic IOMMU Pagetable Support # CONFIG_IOMMU_DEBUGFS is not set # CONFIG_OMAP_IOMMU is not set # CONFIG_ARM_SMMU is not set # # Remoteproc drivers # CONFIG_REMOTEPROC=y # CONFIG_REMOTEPROC_CDEV is not set # CONFIG_WKUP_M3_RPROC is not set # CONFIG_KEYSTONE_REMOTEPROC is not set CONFIG_PRU_REMOTEPROC=m # end of Remoteproc drivers # # Rpmsg drivers # CONFIG_RPMSG=m # CONFIG_RPMSG_CHAR is not set # CONFIG_RPMSG_CTRL is not set CONFIG_RPMSG_NS=m # CONFIG_RPMSG_QCOM_GLINK_RPM is not set CONFIG_RPMSG_VIRTIO=m # CONFIG_RPMSG_PRU is not set # end of Rpmsg drivers # # Rpmsg virtual device drivers # CONFIG_RPMSG_KDRV=m # CONFIG_RPMSG_KDRV_DEMO is not set # CONFIG_RPMSG_KDRV_DISPLAY is not set CONFIG_RPMSG_KDRV_ETH_SWITCH=m # end of Rpmsg virtual device drivers # CONFIG_SOUNDWIRE is not set # # SOC (System On Chip) specific Drivers # # # Amlogic SoC drivers # # end of Amlogic SoC drivers # # Broadcom SoC drivers # # CONFIG_SOC_BRCMSTB is not set # end of Broadcom SoC drivers # # NXP/Freescale QorIQ SoC drivers # # CONFIG_QUICC_ENGINE is not set # CONFIG_FSL_RCPM is not set # end of NXP/Freescale QorIQ SoC drivers # # fujitsu SoC drivers # # end of fujitsu SoC drivers # # i.MX SoC drivers # # end of i.MX SoC drivers # # Enable LiteX SoC Builder specific drivers # # CONFIG_LITEX_SOC_CONTROLLER is not set # end of Enable LiteX SoC Builder specific drivers # # Qualcomm SoC drivers # # end of Qualcomm SoC drivers CONFIG_SOC_TI=y # CONFIG_KEYSTONE_NAVIGATOR_QMSS is not set # CONFIG_KEYSTONE_NAVIGATOR_DMA is not set CONFIG_TI_PRUSS=m # # Xilinx SoC drivers # # end of Xilinx SoC drivers # end of SOC (System On Chip) specific Drivers CONFIG_PM_DEVFREQ=y # # DEVFREQ Governors # CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y # CONFIG_DEVFREQ_GOV_PERFORMANCE is not set # CONFIG_DEVFREQ_GOV_POWERSAVE is not set # CONFIG_DEVFREQ_GOV_USERSPACE is not set CONFIG_DEVFREQ_GOV_PASSIVE=m # # DEVFREQ Drivers # CONFIG_PM_DEVFREQ_EVENT=y CONFIG_EXTCON=y # # Extcon Device Drivers # # CONFIG_EXTCON_ADC_JACK is not set # CONFIG_EXTCON_FSA9480 is not set # CONFIG_EXTCON_GPIO is not set # CONFIG_EXTCON_MAX3355 is not set # CONFIG_EXTCON_PTN5150 is not set # CONFIG_EXTCON_RT8973A is not set # CONFIG_EXTCON_SM5502 is not set CONFIG_EXTCON_USB_GPIO=y CONFIG_MEMORY=y CONFIG_TI_AEMIF=y # CONFIG_TI_EMIF is not set CONFIG_OMAP_GPMC=y # CONFIG_OMAP_GPMC_DEBUG is not set CONFIG_IIO=y CONFIG_IIO_BUFFER=y CONFIG_IIO_BUFFER_CB=m # CONFIG_IIO_BUFFER_DMA is not set # CONFIG_IIO_BUFFER_DMAENGINE is not set CONFIG_IIO_BUFFER_HW_CONSUMER=m CONFIG_IIO_KFIFO_BUF=y CONFIG_IIO_TRIGGERED_BUFFER=y CONFIG_IIO_CONFIGFS=y CONFIG_IIO_TRIGGER=y CONFIG_IIO_CONSUMERS_PER_TRIGGER=2 # CONFIG_IIO_SW_DEVICE is not set CONFIG_IIO_SW_TRIGGER=y # CONFIG_IIO_TRIGGERED_EVENT is not set # # Accelerometers # # CONFIG_ADIS16201 is not set # CONFIG_ADIS16209 is not set # CONFIG_ADXL313_I2C is not set # CONFIG_ADXL313_SPI is not set # CONFIG_ADXL345_I2C is not set # CONFIG_ADXL345_SPI is not set # CONFIG_ADXL355_I2C is not set # CONFIG_ADXL355_SPI is not set # CONFIG_ADXL367_SPI is not set # CONFIG_ADXL367_I2C is not set # CONFIG_ADXL372_SPI is not set # CONFIG_ADXL372_I2C is not set # CONFIG_BMA180 is not set # CONFIG_BMA220 is not set # CONFIG_BMA400 is not set # CONFIG_BMC150_ACCEL is not set # CONFIG_BMI088_ACCEL is not set # CONFIG_DA280 is not set # CONFIG_DA311 is not set # CONFIG_DMARD06 is not set # CONFIG_DMARD09 is not set # CONFIG_DMARD10 is not set # CONFIG_FXLS8962AF_I2C is not set # CONFIG_FXLS8962AF_SPI is not set # CONFIG_IIO_ST_ACCEL_3AXIS is not set # CONFIG_KXSD9 is not set # CONFIG_KXCJK1013 is not set # CONFIG_MC3230 is not set # CONFIG_MMA7455_I2C is not set # CONFIG_MMA7455_SPI is not set # CONFIG_MMA7660 is not set # CONFIG_MMA8452 is not set # CONFIG_MMA9551 is not set # CONFIG_MMA9553 is not set # CONFIG_MSA311 is not set # CONFIG_MXC4005 is not set # CONFIG_MXC6255 is not set # CONFIG_SCA3000 is not set # CONFIG_SCA3300 is not set # CONFIG_STK8312 is not set # CONFIG_STK8BA50 is not set # end of Accelerometers # # Analog to digital converters # # CONFIG_AD7091R5 is not set # CONFIG_AD7124 is not set # CONFIG_AD7192 is not set # CONFIG_AD7266 is not set # CONFIG_AD7280 is not set # CONFIG_AD7291 is not set # CONFIG_AD7292 is not set # CONFIG_AD7298 is not set # CONFIG_AD7476 is not set # CONFIG_AD7606_IFACE_PARALLEL is not set # CONFIG_AD7606_IFACE_SPI is not set # CONFIG_AD7766 is not set # CONFIG_AD7768_1 is not set # CONFIG_AD7780 is not set # CONFIG_AD7791 is not set # CONFIG_AD7793 is not set # CONFIG_AD7887 is not set # CONFIG_AD7923 is not set # CONFIG_AD7949 is not set # CONFIG_AD799X is not set # CONFIG_ADI_AXI_ADC is not set # CONFIG_CC10001_ADC is not set # CONFIG_ENVELOPE_DETECTOR is not set # CONFIG_HI8435 is not set # CONFIG_HX711 is not set # CONFIG_INA2XX_ADC is not set # CONFIG_LTC2471 is not set # CONFIG_LTC2485 is not set # CONFIG_LTC2496 is not set # CONFIG_LTC2497 is not set # CONFIG_MAX1027 is not set # CONFIG_MAX11100 is not set # CONFIG_MAX1118 is not set # CONFIG_MAX11205 is not set # CONFIG_MAX1241 is not set # CONFIG_MAX1363 is not set # CONFIG_MAX9611 is not set # CONFIG_MCP320X is not set # CONFIG_MCP3422 is not set # CONFIG_MCP3911 is not set # CONFIG_NAU7802 is not set # CONFIG_RICHTEK_RTQ6056 is not set # CONFIG_SD_ADC_MODULATOR is not set # CONFIG_TI_ADC081C is not set # CONFIG_TI_ADC0832 is not set # CONFIG_TI_ADC084S021 is not set # CONFIG_TI_ADC12138 is not set # CONFIG_TI_ADC108S102 is not set # CONFIG_TI_ADC128S052 is not set # CONFIG_TI_ADC161S626 is not set # CONFIG_TI_ADS1015 is not set # CONFIG_TI_ADS7950 is not set # CONFIG_TI_ADS8344 is not set # CONFIG_TI_ADS8688 is not set # CONFIG_TI_ADS124S08 is not set # CONFIG_TI_ADS131E08 is not set # CONFIG_TI_TLC4541 is not set # CONFIG_TI_TSC2046 is not set # CONFIG_TWL4030_MADC is not set # CONFIG_TWL6030_GPADC is not set # CONFIG_VF610_ADC is not set # CONFIG_XILINX_XADC is not set # end of Analog to digital converters # # Analog to digital and digital to analog converters # # CONFIG_AD74413R is not set # end of Analog to digital and digital to analog converters # # Analog Front Ends # # CONFIG_IIO_RESCALE is not set # end of Analog Front Ends # # Amplifiers # # CONFIG_AD8366 is not set # CONFIG_ADA4250 is not set # CONFIG_HMC425 is not set # end of Amplifiers # # Capacitance to digital converters # # CONFIG_AD7150 is not set # CONFIG_AD7746 is not set # end of Capacitance to digital converters # # Chemical Sensors # # CONFIG_ATLAS_PH_SENSOR is not set # CONFIG_ATLAS_EZO_SENSOR is not set # CONFIG_BME680 is not set # CONFIG_CCS811 is not set # CONFIG_IAQCORE is not set # CONFIG_PMS7003 is not set # CONFIG_SCD30_CORE is not set # CONFIG_SCD4X is not set # CONFIG_SENSIRION_SGP30 is not set # CONFIG_SENSIRION_SGP40 is not set # CONFIG_SPS30_I2C is not set # CONFIG_SPS30_SERIAL is not set # CONFIG_SENSEAIR_SUNRISE_CO2 is not set # CONFIG_VZ89X is not set # end of Chemical Sensors # # Hid Sensor IIO Common # # end of Hid Sensor IIO Common # # IIO SCMI Sensors # # CONFIG_IIO_SCMI is not set # end of IIO SCMI Sensors # # SSP Sensor Common # # CONFIG_IIO_SSP_SENSORHUB is not set # end of SSP Sensor Common # # Digital to analog converters # # CONFIG_AD3552R is not set # CONFIG_AD5064 is not set # CONFIG_AD5360 is not set # CONFIG_AD5380 is not set # CONFIG_AD5421 is not set # CONFIG_AD5446 is not set # CONFIG_AD5449 is not set # CONFIG_AD5592R is not set # CONFIG_AD5593R is not set # CONFIG_AD5504 is not set # CONFIG_AD5624R_SPI is not set # CONFIG_LTC2688 is not set # CONFIG_AD5686_SPI is not set # CONFIG_AD5696_I2C is not set # CONFIG_AD5755 is not set # CONFIG_AD5758 is not set # CONFIG_AD5761 is not set # CONFIG_AD5764 is not set # CONFIG_AD5766 is not set # CONFIG_AD5770R is not set # CONFIG_AD5791 is not set # CONFIG_AD7293 is not set # CONFIG_AD7303 is not set # CONFIG_AD8801 is not set # CONFIG_DPOT_DAC is not set # CONFIG_DS4424 is not set # CONFIG_LTC1660 is not set # CONFIG_LTC2632 is not set # CONFIG_M62332 is not set # CONFIG_MAX517 is not set # CONFIG_MAX5821 is not set # CONFIG_MCP4725 is not set # CONFIG_MCP4922 is not set # CONFIG_TI_DAC082S085 is not set # CONFIG_TI_DAC5571 is not set # CONFIG_TI_DAC7311 is not set # CONFIG_TI_DAC7612 is not set # CONFIG_VF610_DAC is not set # end of Digital to analog converters # # IIO dummy driver # # end of IIO dummy driver # # Filters # # end of Filters # # Frequency Synthesizers DDS/PLL # # # Clock Generator/Distribution # # CONFIG_AD9523 is not set # end of Clock Generator/Distribution # # Phase-Locked Loop (PLL) frequency synthesizers # # CONFIG_ADF4350 is not set # CONFIG_ADF4371 is not set # CONFIG_ADMV1013 is not set # CONFIG_ADMV4420 is not set # CONFIG_ADRF6780 is not set # end of Phase-Locked Loop (PLL) frequency synthesizers # end of Frequency Synthesizers DDS/PLL # # Digital gyroscope sensors # # CONFIG_ADIS16080 is not set # CONFIG_ADIS16130 is not set # CONFIG_ADIS16136 is not set # CONFIG_ADIS16260 is not set # CONFIG_ADXRS290 is not set # CONFIG_ADXRS450 is not set # CONFIG_BMG160 is not set # CONFIG_FXAS21002C is not set # CONFIG_MPU3050_I2C is not set # CONFIG_IIO_ST_GYRO_3AXIS is not set # CONFIG_ITG3200 is not set # end of Digital gyroscope sensors # # Health Sensors # # # Heart Rate Monitors # # CONFIG_AFE4403 is not set # CONFIG_AFE4404 is not set # CONFIG_MAX30100 is not set # CONFIG_MAX30102 is not set # end of Heart Rate Monitors # end of Health Sensors # # Humidity sensors # # CONFIG_AM2315 is not set # CONFIG_DHT11 is not set # CONFIG_HDC100X is not set # CONFIG_HDC2010 is not set # CONFIG_HTS221 is not set # CONFIG_HTU21 is not set # CONFIG_SI7005 is not set # CONFIG_SI7020 is not set # end of Humidity sensors # # Inertial measurement units # # CONFIG_ADIS16400 is not set # CONFIG_ADIS16460 is not set # CONFIG_ADIS16475 is not set # CONFIG_ADIS16480 is not set # CONFIG_BMI160_I2C is not set # CONFIG_BMI160_SPI is not set # CONFIG_BOSCH_BNO055_SERIAL is not set # CONFIG_BOSCH_BNO055_I2C is not set # CONFIG_FXOS8700_I2C is not set # CONFIG_FXOS8700_SPI is not set # CONFIG_KMX61 is not set # CONFIG_INV_ICM42600_I2C is not set # CONFIG_INV_ICM42600_SPI is not set # CONFIG_INV_MPU6050_I2C is not set # CONFIG_INV_MPU6050_SPI is not set # CONFIG_IIO_ST_LSM6DSX is not set # CONFIG_IIO_ST_LSM9DS0 is not set # end of Inertial measurement units # # Light sensors # # CONFIG_ADJD_S311 is not set # CONFIG_ADUX1020 is not set # CONFIG_AL3010 is not set # CONFIG_AL3320A is not set # CONFIG_APDS9300 is not set # CONFIG_APDS9960 is not set # CONFIG_AS73211 is not set # CONFIG_BH1750 is not set # CONFIG_BH1780 is not set # CONFIG_CM32181 is not set # CONFIG_CM3232 is not set # CONFIG_CM3323 is not set # CONFIG_CM3605 is not set # CONFIG_CM36651 is not set # CONFIG_GP2AP002 is not set # CONFIG_GP2AP020A00F is not set # CONFIG_SENSORS_ISL29018 is not set # CONFIG_SENSORS_ISL29028 is not set # CONFIG_ISL29125 is not set # CONFIG_JSA1212 is not set # CONFIG_RPR0521 is not set # CONFIG_LTR501 is not set # CONFIG_LTRF216A is not set # CONFIG_LV0104CS is not set # CONFIG_MAX44000 is not set # CONFIG_MAX44009 is not set # CONFIG_NOA1305 is not set # CONFIG_OPT3001 is not set # CONFIG_PA12203001 is not set # CONFIG_SI1133 is not set # CONFIG_SI1145 is not set # CONFIG_STK3310 is not set # CONFIG_ST_UVIS25 is not set # CONFIG_TCS3414 is not set # CONFIG_TCS3472 is not set # CONFIG_SENSORS_TSL2563 is not set # CONFIG_TSL2583 is not set # CONFIG_TSL2591 is not set # CONFIG_TSL2772 is not set # CONFIG_TSL4531 is not set # CONFIG_US5182D is not set # CONFIG_VCNL4000 is not set # CONFIG_VCNL4035 is not set # CONFIG_VEML6030 is not set # CONFIG_VEML6070 is not set # CONFIG_VL6180 is not set # CONFIG_ZOPT2201 is not set # end of Light sensors # # Magnetometer sensors # # CONFIG_AK8974 is not set # CONFIG_AK8975 is not set # CONFIG_AK09911 is not set # CONFIG_BMC150_MAGN_I2C is not set # CONFIG_BMC150_MAGN_SPI is not set # CONFIG_MAG3110 is not set # CONFIG_MMC35240 is not set # CONFIG_IIO_ST_MAGN_3AXIS is not set # CONFIG_SENSORS_HMC5843_I2C is not set # CONFIG_SENSORS_HMC5843_SPI is not set # CONFIG_SENSORS_RM3100_I2C is not set # CONFIG_SENSORS_RM3100_SPI is not set # CONFIG_YAMAHA_YAS530 is not set # end of Magnetometer sensors # # Multiplexers # # CONFIG_IIO_MUX is not set # end of Multiplexers # # Inclinometer sensors # # end of Inclinometer sensors # # Triggers - standalone # # CONFIG_IIO_HRTIMER_TRIGGER is not set # CONFIG_IIO_INTERRUPT_TRIGGER is not set # CONFIG_IIO_TIGHTLOOP_TRIGGER is not set # CONFIG_IIO_SYSFS_TRIGGER is not set # end of Triggers - standalone # # Linear and angular position sensors # # end of Linear and angular position sensors # # Digital potentiometers # # CONFIG_AD5110 is not set # CONFIG_AD5272 is not set # CONFIG_DS1803 is not set # CONFIG_MAX5432 is not set # CONFIG_MAX5481 is not set # CONFIG_MAX5487 is not set # CONFIG_MCP4018 is not set # CONFIG_MCP4131 is not set # CONFIG_MCP4531 is not set # CONFIG_MCP41010 is not set # CONFIG_TPL0102 is not set # end of Digital potentiometers # # Digital potentiostats # # CONFIG_LMP91000 is not set # end of Digital potentiostats # # Pressure sensors # # CONFIG_ABP060MG is not set # CONFIG_BMP280 is not set # CONFIG_DLHL60D is not set # CONFIG_DPS310 is not set # CONFIG_HP03 is not set # CONFIG_ICP10100 is not set # CONFIG_MPL115_I2C is not set # CONFIG_MPL115_SPI is not set # CONFIG_MPL3115 is not set # CONFIG_MS5611 is not set # CONFIG_MS5637 is not set # CONFIG_IIO_ST_PRESS is not set # CONFIG_T5403 is not set # CONFIG_HP206C is not set # CONFIG_ZPA2326 is not set # end of Pressure sensors # # Lightning sensors # # CONFIG_AS3935 is not set # end of Lightning sensors # # Proximity and distance sensors # # CONFIG_ISL29501 is not set # CONFIG_LIDAR_LITE_V2 is not set # CONFIG_MB1232 is not set # CONFIG_PING is not set # CONFIG_RFD77402 is not set # CONFIG_SRF04 is not set # CONFIG_SX9310 is not set # CONFIG_SX9324 is not set # CONFIG_SX9360 is not set # CONFIG_SX9500 is not set # CONFIG_SRF08 is not set # CONFIG_VCNL3020 is not set # CONFIG_VL53L0X_I2C is not set # end of Proximity and distance sensors # # Resolver to digital converters # # CONFIG_AD2S90 is not set # CONFIG_AD2S1200 is not set # end of Resolver to digital converters # # Temperature sensors # # CONFIG_LTC2983 is not set # CONFIG_MAXIM_THERMOCOUPLE is not set # CONFIG_MLX90614 is not set # CONFIG_MLX90632 is not set # CONFIG_TMP006 is not set # CONFIG_TMP007 is not set # CONFIG_TMP117 is not set # CONFIG_TSYS01 is not set # CONFIG_TSYS02D is not set # CONFIG_MAX31856 is not set # CONFIG_MAX31865 is not set # end of Temperature sensors CONFIG_PWM=y CONFIG_PWM_SYSFS=y # CONFIG_PWM_DEBUG is not set # CONFIG_PWM_ATMEL_TCB is not set # CONFIG_PWM_CLK is not set # CONFIG_PWM_FSL_FTM is not set # CONFIG_PWM_OMAP_DMTIMER is not set # CONFIG_PWM_PCA9685 is not set CONFIG_PWM_TIECAP=m CONFIG_PWM_TIEHRPWM=m # CONFIG_PWM_TWL is not set # CONFIG_PWM_TWL_LED is not set # CONFIG_PWM_XILINX is not set # # IRQ chip support # CONFIG_IRQCHIP=y CONFIG_ARM_GIC=y CONFIG_ARM_GIC_MAX_NR=1 # CONFIG_AL_FIC is not set CONFIG_OMAP_IRQCHIP=y # CONFIG_XILINX_INTC is not set CONFIG_IRQ_CROSSBAR=y CONFIG_KEYSTONE_IRQ=y CONFIG_TI_PRUSS_INTC=m # end of IRQ chip support # CONFIG_IPACK_BUS is not set CONFIG_ARCH_HAS_RESET_CONTROLLER=y CONFIG_RESET_CONTROLLER=y CONFIG_RESET_SCMI=y CONFIG_RESET_SIMPLE=y # CONFIG_RESET_TI_SYSCON is not set # CONFIG_RESET_TI_TPS380X is not set # # PHY Subsystem # CONFIG_GENERIC_PHY=y # CONFIG_PHY_CAN_TRANSCEIVER is not set # # PHY drivers for Broadcom platforms # # CONFIG_BCM_KONA_USB2_PHY is not set # end of PHY drivers for Broadcom platforms # CONFIG_PHY_CADENCE_TORRENT is not set # CONFIG_PHY_CADENCE_DPHY is not set # CONFIG_PHY_CADENCE_DPHY_RX is not set # CONFIG_PHY_CADENCE_SIERRA is not set # CONFIG_PHY_CADENCE_SALVO is not set # CONFIG_PHY_PXA_28NM_HSIC is not set # CONFIG_PHY_PXA_28NM_USB2 is not set # CONFIG_PHY_LAN966X_SERDES is not set CONFIG_PHY_CPCAP_USB=m # CONFIG_PHY_MAPPHONE_MDM6600 is not set # CONFIG_PHY_OCELOT_SERDES is not set CONFIG_PHY_QCOM_USB_HS=y # CONFIG_PHY_QCOM_USB_HSIC is not set # CONFIG_PHY_DM816X_USB is not set CONFIG_OMAP_CONTROL_PHY=y CONFIG_OMAP_USB2=y CONFIG_TI_PIPE3=y # CONFIG_PHY_TUSB1210 is not set CONFIG_PHY_TI_GMII_SEL=y # end of PHY Subsystem # CONFIG_POWERCAP is not set # CONFIG_MCB is not set # # Performance monitor support # # CONFIG_ARM_CCI_PMU is not set # CONFIG_ARM_CCN is not set CONFIG_ARM_PMU=y # end of Performance monitor support CONFIG_RAS=y # # Android # # CONFIG_ANDROID_BINDER_IPC is not set # end of Android # CONFIG_DAX is not set CONFIG_NVMEM=y CONFIG_NVMEM_SYSFS=y # CONFIG_NVMEM_RMEM is not set # CONFIG_NVMEM_U_BOOT_ENV is not set # # HW tracing support # # CONFIG_STM is not set # CONFIG_INTEL_TH is not set # end of HW tracing support # CONFIG_FPGA is not set # CONFIG_FSI is not set # CONFIG_TEE is not set CONFIG_PM_OPP=y # CONFIG_SIOX is not set # CONFIG_SLIMBUS is not set CONFIG_INTERCONNECT=y CONFIG_COUNTER=m # CONFIG_INTERRUPT_CNT is not set # CONFIG_TI_EQEP is not set # CONFIG_FTM_QUADDEC is not set # CONFIG_MICROCHIP_TCB_CAPTURE is not set # CONFIG_TI_ECAP_CAPTURE is not set # CONFIG_MOST is not set # CONFIG_PECI is not set # CONFIG_HTE is not set # end of Device Drivers # # File systems # CONFIG_DCACHE_WORD_ACCESS=y # CONFIG_VALIDATE_FS_PARSER is not set CONFIG_FS_IOMAP=y # CONFIG_EXT2_FS is not set # CONFIG_EXT3_FS is not set CONFIG_EXT4_FS=y CONFIG_EXT4_USE_FOR_EXT2=y # CONFIG_EXT4_FS_POSIX_ACL is not set # CONFIG_EXT4_FS_SECURITY is not set # CONFIG_EXT4_DEBUG is not set CONFIG_JBD2=y # CONFIG_JBD2_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_XFS_FS is not set # CONFIG_GFS2_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set # CONFIG_F2FS_FS is not set CONFIG_FS_POSIX_ACL=y CONFIG_EXPORTFS=y # CONFIG_EXPORTFS_BLOCK_OPS is not set CONFIG_FILE_LOCKING=y # CONFIG_FS_ENCRYPTION is not set # CONFIG_FS_VERITY is not set CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_FANOTIFY is not set # CONFIG_QUOTA is not set CONFIG_AUTOFS4_FS=y CONFIG_AUTOFS_FS=y # CONFIG_FUSE_FS is not set # CONFIG_OVERLAY_FS is not set # # Caches # # CONFIG_FSCACHE is not set # end of Caches # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # end of CD-ROM/DVD Filesystems # # DOS/FAT/EXFAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_FAT_DEFAULT_UTF8 is not set CONFIG_EXFAT_FS=y CONFIG_EXFAT_DEFAULT_IOCHARSET="utf8" CONFIG_NTFS_FS=y # CONFIG_NTFS_DEBUG is not set # CONFIG_NTFS_RW is not set # CONFIG_NTFS3_FS is not set # end of DOS/FAT/EXFAT/NT Filesystems # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y # CONFIG_PROC_CHILDREN is not set CONFIG_KERNFS=y CONFIG_SYSFS=y CONFIG_TMPFS=y CONFIG_TMPFS_POSIX_ACL=y CONFIG_TMPFS_XATTR=y CONFIG_MEMFD_CREATE=y CONFIG_CONFIGFS_FS=y CONFIG_EFIVAR_FS=m # end of Pseudo filesystems CONFIG_MISC_FILESYSTEMS=y # CONFIG_ORANGEFS_FS is not set # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set # CONFIG_JFFS2_FS is not set # CONFIG_CRAMFS is not set CONFIG_SQUASHFS=y CONFIG_SQUASHFS_FILE_CACHE=y # CONFIG_SQUASHFS_FILE_DIRECT is not set CONFIG_SQUASHFS_DECOMP_SINGLE=y # CONFIG_SQUASHFS_DECOMP_MULTI is not set # CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set # CONFIG_SQUASHFS_XATTR is not set CONFIG_SQUASHFS_ZLIB=y # CONFIG_SQUASHFS_LZ4 is not set CONFIG_SQUASHFS_LZO=y CONFIG_SQUASHFS_XZ=y # CONFIG_SQUASHFS_ZSTD is not set # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set # CONFIG_SQUASHFS_EMBEDDED is not set CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3 # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_QNX6FS_FS is not set # CONFIG_ROMFS_FS is not set CONFIG_PSTORE=y CONFIG_PSTORE_DEFAULT_KMSG_BYTES=10240 CONFIG_PSTORE_DEFLATE_COMPRESS=y # CONFIG_PSTORE_LZO_COMPRESS is not set # CONFIG_PSTORE_LZ4_COMPRESS is not set # CONFIG_PSTORE_LZ4HC_COMPRESS is not set # CONFIG_PSTORE_842_COMPRESS is not set # CONFIG_PSTORE_ZSTD_COMPRESS is not set CONFIG_PSTORE_COMPRESS=y CONFIG_PSTORE_DEFLATE_COMPRESS_DEFAULT=y CONFIG_PSTORE_COMPRESS_DEFAULT="deflate" CONFIG_PSTORE_CONSOLE=y CONFIG_PSTORE_PMSG=y CONFIG_PSTORE_RAM=y # CONFIG_PSTORE_BLK is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set # CONFIG_EROFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V2=y CONFIG_NFS_V3=y CONFIG_NFS_V3_ACL=y CONFIG_NFS_V4=y # CONFIG_NFS_SWAP is not set CONFIG_NFS_V4_1=y CONFIG_NFS_V4_2=y CONFIG_PNFS_FILE_LAYOUT=y CONFIG_PNFS_FLEXFILE_LAYOUT=y CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org" # CONFIG_NFS_V4_1_MIGRATION is not set CONFIG_ROOT_NFS=y # CONFIG_NFS_USE_LEGACY_DNS is not set CONFIG_NFS_USE_KERNEL_DNS=y CONFIG_NFS_DISABLE_UDP_SUPPORT=y # CONFIG_NFS_V4_2_READ_PLUS is not set # CONFIG_NFSD is not set CONFIG_GRACE_PERIOD=y CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_NFS_ACL_SUPPORT=y CONFIG_NFS_COMMON=y CONFIG_NFS_V4_2_SSC_HELPER=y CONFIG_SUNRPC=y CONFIG_SUNRPC_GSS=y CONFIG_SUNRPC_BACKCHANNEL=y # CONFIG_SUNRPC_DEBUG is not set # CONFIG_CEPH_FS is not set # CONFIG_CIFS is not set # CONFIG_SMB_SERVER is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_MAC_ROMAN is not set # CONFIG_NLS_MAC_CELTIC is not set # CONFIG_NLS_MAC_CENTEURO is not set # CONFIG_NLS_MAC_CROATIAN is not set # CONFIG_NLS_MAC_CYRILLIC is not set # CONFIG_NLS_MAC_GAELIC is not set # CONFIG_NLS_MAC_GREEK is not set # CONFIG_NLS_MAC_ICELAND is not set # CONFIG_NLS_MAC_INUIT is not set # CONFIG_NLS_MAC_ROMANIAN is not set # CONFIG_NLS_MAC_TURKISH is not set CONFIG_NLS_UTF8=y # CONFIG_DLM is not set # CONFIG_UNICODE is not set CONFIG_IO_WQ=y # end of File systems # # Security options # CONFIG_KEYS=y # CONFIG_KEYS_REQUEST_CACHE is not set # CONFIG_PERSISTENT_KEYRINGS is not set # CONFIG_TRUSTED_KEYS is not set # CONFIG_ENCRYPTED_KEYS is not set # CONFIG_KEY_DH_OPERATIONS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set CONFIG_PROC_MEM_ALWAYS_FORCE=y # CONFIG_PROC_MEM_FORCE_PTRACE is not set # CONFIG_PROC_MEM_NO_FORCE is not set # CONFIG_SECURITY is not set CONFIG_SECURITYFS=y CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y # CONFIG_HARDENED_USERCOPY is not set # CONFIG_FORTIFY_SOURCE is not set # CONFIG_STATIC_USERMODEHELPER is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity,bpf" # # Kernel hardening options # # # Memory initialization # CONFIG_INIT_STACK_NONE=y # CONFIG_GCC_PLUGIN_STRUCTLEAK_USER is not set # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF is not set # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF_ALL is not set # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set CONFIG_CC_HAS_ZERO_CALL_USED_REGS=y # CONFIG_ZERO_CALL_USED_REGS is not set # end of Memory initialization CONFIG_RANDSTRUCT_NONE=y # CONFIG_RANDSTRUCT_FULL is not set # CONFIG_RANDSTRUCT_PERFORMANCE is not set # end of Kernel hardening options # end of Security options CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=m CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_SKCIPHER=m CONFIG_CRYPTO_SKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=m CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_RNG_DEFAULT=m CONFIG_CRYPTO_AKCIPHER2=y CONFIG_CRYPTO_AKCIPHER=y CONFIG_CRYPTO_KPP2=y CONFIG_CRYPTO_KPP=m CONFIG_CRYPTO_ACOMP2=y CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y CONFIG_CRYPTO_USER=m CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y CONFIG_CRYPTO_GF128MUL=m CONFIG_CRYPTO_NULL=m CONFIG_CRYPTO_NULL2=y CONFIG_CRYPTO_CRYPTD=m CONFIG_CRYPTO_AUTHENC=m # CONFIG_CRYPTO_TEST is not set CONFIG_CRYPTO_SIMD=m CONFIG_CRYPTO_ENGINE=m # end of Crypto core or helper # # Public-key cryptography # CONFIG_CRYPTO_RSA=y # CONFIG_CRYPTO_DH is not set CONFIG_CRYPTO_ECC=m CONFIG_CRYPTO_ECDH=m # CONFIG_CRYPTO_ECDSA is not set # CONFIG_CRYPTO_ECRDSA is not set # CONFIG_CRYPTO_SM2 is not set # CONFIG_CRYPTO_CURVE25519 is not set # end of Public-key cryptography # # Block ciphers # CONFIG_CRYPTO_AES=m # CONFIG_CRYPTO_AES_TI is not set # CONFIG_CRYPTO_ANUBIS is not set # CONFIG_CRYPTO_ARIA is not set # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set CONFIG_CRYPTO_DES=m # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_SM4_GENERIC is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # end of Block ciphers # # Length-preserving ciphers and modes # # CONFIG_CRYPTO_ADIANTUM is not set # CONFIG_CRYPTO_ARC4 is not set # CONFIG_CRYPTO_CHACHA20 is not set CONFIG_CRYPTO_CBC=m # CONFIG_CRYPTO_CFB is not set CONFIG_CRYPTO_CTR=m # CONFIG_CRYPTO_CTS is not set CONFIG_CRYPTO_ECB=m # CONFIG_CRYPTO_HCTR2 is not set # CONFIG_CRYPTO_KEYWRAP is not set # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_OFB is not set # CONFIG_CRYPTO_PCBC is not set CONFIG_CRYPTO_XTS=m # end of Length-preserving ciphers and modes # # AEAD (authenticated encryption with associated data) ciphers # # CONFIG_CRYPTO_AEGIS128 is not set # CONFIG_CRYPTO_CHACHA20POLY1305 is not set CONFIG_CRYPTO_CCM=m CONFIG_CRYPTO_GCM=m CONFIG_CRYPTO_SEQIV=m CONFIG_CRYPTO_ECHAINIV=m # CONFIG_CRYPTO_ESSIV is not set # end of AEAD (authenticated encryption with associated data) ciphers # # Hashes, digests, and MACs # # CONFIG_CRYPTO_BLAKE2B is not set CONFIG_CRYPTO_CMAC=m CONFIG_CRYPTO_GHASH=m CONFIG_CRYPTO_HMAC=m # CONFIG_CRYPTO_MD4 is not set CONFIG_CRYPTO_MD5=m # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_POLY1305 is not set # CONFIG_CRYPTO_RMD160 is not set CONFIG_CRYPTO_SHA1=m CONFIG_CRYPTO_SHA256=m CONFIG_CRYPTO_SHA512=m # CONFIG_CRYPTO_SHA3 is not set # CONFIG_CRYPTO_SM3_GENERIC is not set # CONFIG_CRYPTO_STREEBOG is not set # CONFIG_CRYPTO_VMAC is not set # CONFIG_CRYPTO_WP512 is not set # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_XXHASH is not set # end of Hashes, digests, and MACs # # CRCs (cyclic redundancy checks) # CONFIG_CRYPTO_CRC32C=y # CONFIG_CRYPTO_CRC32 is not set # CONFIG_CRYPTO_CRCT10DIF is not set # end of CRCs (cyclic redundancy checks) # # Compression # CONFIG_CRYPTO_DEFLATE=y CONFIG_CRYPTO_LZO=y # CONFIG_CRYPTO_842 is not set # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set CONFIG_CRYPTO_ZSTD=y # end of Compression # # Random number generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set CONFIG_CRYPTO_DRBG_MENU=m CONFIG_CRYPTO_DRBG_HMAC=y # CONFIG_CRYPTO_DRBG_HASH is not set # CONFIG_CRYPTO_DRBG_CTR is not set CONFIG_CRYPTO_DRBG=m CONFIG_CRYPTO_JITTERENTROPY=m # end of Random number generation # # Userspace interface # CONFIG_CRYPTO_USER_API=m CONFIG_CRYPTO_USER_API_HASH=m CONFIG_CRYPTO_USER_API_SKCIPHER=m CONFIG_CRYPTO_USER_API_RNG=m # CONFIG_CRYPTO_USER_API_RNG_CAVP is not set CONFIG_CRYPTO_USER_API_AEAD=m CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE=y # CONFIG_CRYPTO_STATS is not set # end of Userspace interface CONFIG_CRYPTO_HASH_INFO=y # # Accelerated Cryptographic Algorithms for CPU (arm) # # CONFIG_CRYPTO_CURVE25519_NEON is not set CONFIG_CRYPTO_GHASH_ARM_CE=m # CONFIG_CRYPTO_NHPOLY1305_NEON is not set # CONFIG_CRYPTO_POLY1305_ARM is not set # CONFIG_CRYPTO_BLAKE2S_ARM is not set # CONFIG_CRYPTO_BLAKE2B_NEON is not set CONFIG_CRYPTO_SHA1_ARM=m CONFIG_CRYPTO_SHA1_ARM_NEON=m CONFIG_CRYPTO_SHA1_ARM_CE=m CONFIG_CRYPTO_SHA2_ARM_CE=m CONFIG_CRYPTO_SHA256_ARM=m CONFIG_CRYPTO_SHA512_ARM=m CONFIG_CRYPTO_AES_ARM=m CONFIG_CRYPTO_AES_ARM_BS=m CONFIG_CRYPTO_AES_ARM_CE=m CONFIG_CRYPTO_CHACHA20_NEON=m CONFIG_CRYPTO_CRC32_ARM_CE=m # end of Accelerated Cryptographic Algorithms for CPU (arm) CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_OMAP is not set # CONFIG_CRYPTO_DEV_ATMEL_ECC is not set # CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set # CONFIG_CRYPTO_DEV_VIRTIO is not set # CONFIG_CRYPTO_DEV_SAFEXCEL is not set # CONFIG_CRYPTO_DEV_CCREE is not set CONFIG_CRYPTO_DEV_AMLOGIC_GXL=m # CONFIG_CRYPTO_DEV_AMLOGIC_GXL_DEBUG is not set CONFIG_ASYMMETRIC_KEY_TYPE=y CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y CONFIG_X509_CERTIFICATE_PARSER=y # CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set CONFIG_PKCS7_MESSAGE_PARSER=y # CONFIG_PKCS7_TEST_KEY is not set # CONFIG_SIGNED_PE_FILE_VERIFICATION is not set # CONFIG_FIPS_SIGNATURE_SELFTEST is not set # # Certificates for signature checking # CONFIG_SYSTEM_TRUSTED_KEYRING=y CONFIG_SYSTEM_TRUSTED_KEYS="" # CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set # CONFIG_SECONDARY_TRUSTED_KEYRING is not set # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set # end of Certificates for signature checking CONFIG_BINARY_PRINTF=y # # Library routines # CONFIG_LINEAR_RANGES=y CONFIG_PACKING=y CONFIG_BITREVERSE=y CONFIG_HAVE_ARCH_BITREVERSE=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y # CONFIG_CORDIC is not set # CONFIG_PRIME_NUMBERS is not set CONFIG_RATIONAL=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y # # Crypto library routines # CONFIG_CRYPTO_LIB_UTILS=y CONFIG_CRYPTO_LIB_AES=m CONFIG_CRYPTO_LIB_ARC4=m CONFIG_CRYPTO_LIB_BLAKE2S_GENERIC=y CONFIG_CRYPTO_ARCH_HAVE_LIB_CHACHA=m # CONFIG_CRYPTO_LIB_CHACHA is not set # CONFIG_CRYPTO_LIB_CURVE25519 is not set CONFIG_CRYPTO_LIB_DES=m CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9 # CONFIG_CRYPTO_LIB_POLY1305 is not set # CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set CONFIG_CRYPTO_LIB_SHA1=y CONFIG_CRYPTO_LIB_SHA256=m # end of Crypto library routines CONFIG_CRC_CCITT=m CONFIG_CRC16=y # CONFIG_CRC_T10DIF is not set # CONFIG_CRC64_ROCKSOFT is not set CONFIG_CRC_ITU_T=m CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set # CONFIG_CRC64 is not set CONFIG_CRC4=m # CONFIG_CRC7 is not set # CONFIG_LIBCRC32C is not set # CONFIG_CRC8 is not set CONFIG_XXHASH=y # CONFIG_RANDOM32_SELFTEST is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y CONFIG_LZ4_DECOMPRESS=y CONFIG_ZSTD_COMMON=y CONFIG_ZSTD_COMPRESS=y CONFIG_ZSTD_DECOMPRESS=y CONFIG_XZ_DEC=y # CONFIG_XZ_DEC_X86 is not set # CONFIG_XZ_DEC_POWERPC is not set # CONFIG_XZ_DEC_IA64 is not set CONFIG_XZ_DEC_ARM=y CONFIG_XZ_DEC_ARMTHUMB=y # CONFIG_XZ_DEC_SPARC is not set # CONFIG_XZ_DEC_MICROLZMA is not set CONFIG_XZ_DEC_BCJ=y # CONFIG_XZ_DEC_TEST is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_DECOMPRESS_XZ=y CONFIG_DECOMPRESS_LZO=y CONFIG_DECOMPRESS_LZ4=y CONFIG_DECOMPRESS_ZSTD=y CONFIG_GENERIC_ALLOCATOR=y CONFIG_REED_SOLOMON=y CONFIG_REED_SOLOMON_ENC8=y CONFIG_REED_SOLOMON_DEC8=y CONFIG_XARRAY_MULTI=y CONFIG_ASSOCIATIVE_ARRAY=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT_MAP=y CONFIG_HAS_DMA=y CONFIG_DMA_OPS=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_DMA_DECLARE_COHERENT=y CONFIG_ARCH_HAS_SETUP_DMA_OPS=y CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y CONFIG_ARCH_HAS_SYNC_DMA_FOR_DEVICE=y CONFIG_ARCH_HAS_SYNC_DMA_FOR_CPU=y CONFIG_DMA_NONCOHERENT_MMAP=y CONFIG_DMA_CMA=y # CONFIG_DMA_PERNUMA_CMA is not set # # Default contiguous memory area size: # CONFIG_CMA_SIZE_MBYTES=64 CONFIG_CMA_SIZE_SEL_MBYTES=y # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set # CONFIG_CMA_SIZE_SEL_MIN is not set # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_ALIGNMENT=8 # CONFIG_DMA_API_DEBUG is not set # CONFIG_DMA_MAP_BENCHMARK is not set CONFIG_SGL_ALLOC=y CONFIG_DQL=y CONFIG_GLOB=y # CONFIG_GLOB_SELFTEST is not set CONFIG_NLATTR=y CONFIG_CLZ_TAB=y # CONFIG_IRQ_POLL is not set CONFIG_MPILIB=y CONFIG_LIBFDT=y CONFIG_OID_REGISTRY=y CONFIG_UCS2_STRING=y CONFIG_HAVE_GENERIC_VDSO=y CONFIG_GENERIC_GETTIMEOFDAY=y CONFIG_GENERIC_VDSO_32=y CONFIG_FONT_SUPPORT=y # CONFIG_FONTS is not set CONFIG_FONT_8x8=y CONFIG_FONT_8x16=y CONFIG_SG_SPLIT=y CONFIG_SG_POOL=y CONFIG_STACKDEPOT=y CONFIG_SBITMAP=y # end of Library routines CONFIG_GENERIC_LIB_DEVMEM_IS_ALLOWED=y # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y # CONFIG_PRINTK_CALLER is not set # CONFIG_STACKTRACE_BUILD_ID is not set CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7 CONFIG_CONSOLE_LOGLEVEL_QUIET=4 CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_DYNAMIC_DEBUG is not set # CONFIG_DYNAMIC_DEBUG_CORE is not set CONFIG_SYMBOLIC_ERRNAME=y CONFIG_DEBUG_BUGVERBOSE=y # end of printk and dmesg options CONFIG_DEBUG_KERNEL=y CONFIG_DEBUG_MISC=y # # Compile-time checks and compiler options # CONFIG_AS_HAS_NON_CONST_LEB128=y CONFIG_DEBUG_INFO_NONE=y # CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT is not set # CONFIG_DEBUG_INFO_DWARF4 is not set # CONFIG_DEBUG_INFO_DWARF5 is not set CONFIG_FRAME_WARN=1024 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set # CONFIG_HEADERS_INSTALL is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_SECTION_MISMATCH_WARN_ONLY=y # CONFIG_VMLINUX_MAP is not set # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # end of Compile-time checks and compiler options # # Generic Kernel Debugging Instruments # CONFIG_MAGIC_SYSRQ=y CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1 CONFIG_MAGIC_SYSRQ_SERIAL=y CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE="" CONFIG_DEBUG_FS=y CONFIG_DEBUG_FS_ALLOW_ALL=y # CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set # CONFIG_DEBUG_FS_ALLOW_NONE is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set # CONFIG_UBSAN is not set CONFIG_HAVE_KCSAN_COMPILER=y # end of Generic Kernel Debugging Instruments # # Networking Debugging # # CONFIG_NET_DEV_REFCNT_TRACKER is not set # CONFIG_NET_NS_REFCNT_TRACKER is not set # CONFIG_DEBUG_NET is not set # end of Networking Debugging # # Memory Debugging # # CONFIG_PAGE_EXTENSION is not set # CONFIG_DEBUG_PAGEALLOC is not set CONFIG_SLUB_DEBUG=y # CONFIG_SLUB_DEBUG_ON is not set # CONFIG_PAGE_OWNER is not set # CONFIG_PAGE_POISONING is not set # CONFIG_DEBUG_PAGE_REF is not set # CONFIG_DEBUG_RODATA_TEST is not set # CONFIG_DEBUG_WX is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SHRINKER_DEBUG is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_SCHED_STACK_END_CHECK is not set # CONFIG_DEBUG_VM is not set CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y # CONFIG_DEBUG_VIRTUAL is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_KMAP_LOCAL is not set # CONFIG_DEBUG_HIGHMEM is not set CONFIG_HAVE_ARCH_KASAN=y CONFIG_HAVE_ARCH_KASAN_VMALLOC=y CONFIG_CC_HAS_KASAN_GENERIC=y CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y # CONFIG_KASAN is not set CONFIG_HAVE_ARCH_KFENCE=y # CONFIG_KFENCE is not set # end of Memory Debugging # CONFIG_DEBUG_SHIRQ is not set # # Debug Oops, Lockups and Hangs # # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 CONFIG_PANIC_TIMEOUT=0 # CONFIG_SOFTLOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_WQ_WATCHDOG is not set # CONFIG_TEST_LOCKUP is not set # end of Debug Oops, Lockups and Hangs # # Scheduler Debugging # CONFIG_SCHED_DEBUG=y # CONFIG_SCHEDSTATS is not set # end of Scheduler Debugging # CONFIG_DEBUG_TIMEKEEPING is not set CONFIG_DEBUG_PREEMPT=y # # Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_LOCK_DEBUGGING_SUPPORT=y # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set # CONFIG_DEBUG_RWSEMS is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_LOCK_TORTURE_TEST is not set # CONFIG_WW_MUTEX_SELFTEST is not set # CONFIG_SCF_TORTURE_TEST is not set # end of Lock Debugging (spinlocks, mutexes, etc...) # CONFIG_DEBUG_IRQFLAGS is not set CONFIG_STACKTRACE=y # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set # CONFIG_DEBUG_KOBJECT is not set # # Debug kernel data structures # # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_PLIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_BUG_ON_DATA_CORRUPTION is not set # CONFIG_DEBUG_MAPLE_TREE is not set # end of Debug kernel data structures # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_RCU_SCALE_TEST is not set # CONFIG_RCU_TORTURE_TEST is not set # CONFIG_RCU_REF_SCALE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=21 CONFIG_RCU_EXP_CPU_STALL_TIMEOUT=0 CONFIG_RCU_TRACE=y # CONFIG_RCU_EQS_DEBUG is not set # end of RCU Debugging # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set # CONFIG_LATENCYTOP is not set CONFIG_NOP_TRACER=y CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_HAVE_C_RECORDMCOUNT=y CONFIG_HAVE_BUILDTIME_MCOUNT_SORT=y CONFIG_TRACE_CLOCK=y CONFIG_RING_BUFFER=y CONFIG_EVENT_TRACING=y CONFIG_CONTEXT_SWITCH_TRACER=y CONFIG_TRACING=y CONFIG_TRACING_SUPPORT=y CONFIG_FTRACE=y # CONFIG_BOOTTIME_TRACING is not set # CONFIG_FUNCTION_TRACER is not set # CONFIG_STACK_TRACER is not set # CONFIG_IRQSOFF_TRACER is not set # CONFIG_PREEMPT_TRACER is not set # CONFIG_SCHED_TRACER is not set # CONFIG_HWLAT_TRACER is not set # CONFIG_OSNOISE_TRACER is not set # CONFIG_TIMERLAT_TRACER is not set # CONFIG_ENABLE_DEFAULT_TRACERS is not set # CONFIG_FTRACE_SYSCALLS is not set # CONFIG_TRACER_SNAPSHOT is not set CONFIG_BRANCH_PROFILE_NONE=y # CONFIG_PROFILE_ANNOTATED_BRANCHES is not set # CONFIG_PROFILE_ALL_BRANCHES is not set # CONFIG_BLK_DEV_IO_TRACE is not set CONFIG_UPROBE_EVENTS=y CONFIG_DYNAMIC_EVENTS=y CONFIG_PROBE_EVENTS=y # CONFIG_SYNTH_EVENTS is not set # CONFIG_HIST_TRIGGERS is not set # CONFIG_TRACE_EVENT_INJECT is not set # CONFIG_TRACEPOINT_BENCHMARK is not set # CONFIG_RING_BUFFER_BENCHMARK is not set # CONFIG_TRACE_EVAL_MAP_FILE is not set # CONFIG_RING_BUFFER_STARTUP_TEST is not set # CONFIG_RING_BUFFER_VALIDATE_TIME_DELTAS is not set # CONFIG_PREEMPTIRQ_DELAY_TEST is not set # CONFIG_RV is not set # CONFIG_SAMPLES is not set # CONFIG_STRICT_DEVMEM is not set # # arm Debugging # # CONFIG_ARM_PTDUMP_DEBUGFS is not set # CONFIG_UNWINDER_FRAME_POINTER is not set CONFIG_UNWINDER_ARM=y CONFIG_ARM_UNWIND=y # CONFIG_BACKTRACE_VERBOSE is not set # CONFIG_DEBUG_USER is not set # CONFIG_DEBUG_LL is not set CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S" CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h" # CONFIG_PID_IN_CONTEXTIDR is not set # CONFIG_CORESIGHT is not set # end of arm Debugging # # Kernel Testing and Coverage # # CONFIG_KUNIT is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set CONFIG_ARCH_HAS_KCOV=y CONFIG_CC_HAS_SANCOV_TRACE_PC=y # CONFIG_KCOV is not set CONFIG_RUNTIME_TESTING_MENU=y # CONFIG_LKDTM is not set # CONFIG_TEST_MIN_HEAP is not set # CONFIG_TEST_DIV64 is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_TEST_REF_TRACKER is not set # CONFIG_RBTREE_TEST is not set # CONFIG_REED_SOLOMON_TEST is not set # CONFIG_INTERVAL_TREE_TEST is not set # CONFIG_PERCPU_TEST is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_TEST_HEXDUMP is not set # CONFIG_STRING_SELFTEST is not set # CONFIG_TEST_STRING_HELPERS is not set # CONFIG_TEST_STRSCPY is not set # CONFIG_TEST_KSTRTOX is not set # CONFIG_TEST_PRINTF is not set # CONFIG_TEST_SCANF is not set # CONFIG_TEST_BITMAP is not set # CONFIG_TEST_UUID is not set # CONFIG_TEST_XARRAY is not set # CONFIG_TEST_MAPLE_TREE is not set # CONFIG_TEST_RHASHTABLE is not set # CONFIG_TEST_SIPHASH is not set # CONFIG_TEST_IDA is not set # CONFIG_TEST_LKM is not set # CONFIG_TEST_BITOPS is not set # CONFIG_TEST_VMALLOC is not set # CONFIG_TEST_USER_COPY is not set # CONFIG_TEST_BPF is not set # CONFIG_TEST_BLACKHOLE_DEV is not set # CONFIG_FIND_BIT_BENCHMARK is not set # CONFIG_TEST_FIRMWARE is not set # CONFIG_TEST_SYSCTL is not set # CONFIG_TEST_UDELAY is not set # CONFIG_TEST_STATIC_KEYS is not set # CONFIG_TEST_KMOD is not set # CONFIG_TEST_MEMCAT_P is not set # CONFIG_TEST_MEMINIT is not set # CONFIG_TEST_FREE_PAGES is not set CONFIG_ARCH_USE_MEMTEST=y # CONFIG_MEMTEST is not set # end of Kernel Testing and Coverage # # Rust hacking # # end of Rust hacking # end of Kernel hacking
But I do not have this problem in the official system, the official system kernel configuration does not have the initramfs file system, and all other kernel configuration items are the same except the initramfs file system configuration item.The dtb file in the official system and the dtb file in the recovery system use the same file.
Does the problem have anything to do with the file system? The initramfs file system in the recovery system is built on buildroot, while the official system uses the file system in SDK 09.03.05.02.
Please give me a hint, thank you!
