Part Number: AM6422
i have a custom board with own yocto linux build. Right now i booting from sdcard. Looks good so far.
I trying porting pru1_0 code from am43 to am64. I can load and start different binary without any problem. /sys/class/remoteproc/remoteproc6/state print it is "running".
What i am observing is that the binary .out (elf-file) is more then double the size of am43 for the same code. Why? The final size of my binary is ~168KB. If i try to load and start the binary i am getting:
If i remove some code and the final binary i a lil bit smaller ~164K, i have not problem.
The map file looks ok:
PRU Linker Unix v2.3.3
>> Linked Wed Feb 12 16:56:59 2025
OUTPUT FILE NAME: <gen/PRU1/PRU_Display_1.out>
ENTRY POINT SYMBOL: "_c_int00_noinit_noargs" address: 00000000
MEMORY CONFIGURATION
name origin length used unused attr fill
PAGE 0:
PRU_IMEM 00000000 00003000 00000834 000027cc RWIX
PAGE 1:
PRU1_DMEM_1 00000000 00001000 00000277 00000d89 RWIX
RTU1_DMEM_1 00001000 00000800 00000000 00000800 RWIX
TX_PRU1_DMEM_1 00001800 00000800 00000000 00000800 RWIX
PRU1_DMEM_0 00002000 00001000 00000000 00001000 RWIX
RTU1_DMEM_0 00003000 00000800 00000000 00000800 RWIX
TX_PRU1_DMEM_0 00003800 00000800 00000000 00000800 RWIX
PAGE 2:
PRU_RTU_RAT1 00009000 00000854 00000000 00000854 RWIX
PRU_SHAREDMEM 00010000 00010000 00000000 00010000 RWIX
PRU_INTC 00020000 00001504 00001504 00000000 RWIX
PRU1_CTRL 00024000 00000030 00000000 00000030 RWIX
RSVD14 00024800 00000100 00000000 00000100 RWIX
PRU_CFG 00026000 00000100 00000000 00000100 RWIX
PRU_CFG_0x100 00026100 00000098 00000000 00000098 RWIX
PA_STATS_QRAM 00027000 00001000 00000000 00001000 RWIX
PRU_UART 00028000 00000038 00000000 00000038 RWIX
TM_CFG_PRU1 0002a200 0000004c 00000000 0000004c RWIX
PA_STATS_CRAM 0002c000 00001000 00000000 00001000 RWIX
PRU_IEP0 0002e000 00000100 00000000 00000100 RWIX
PRU_IEP0_0x100 0002e100 0000021c 00000000 0000021c RWIX
PRU_IEP1 0002f000 00000100 00000000 00000100 RWIX
PRU_IEP1_0x100 0002f100 0000021c 00000000 0000021c RWIX
PRU_ECAP 00030000 00000060 00000000 00000060 RWIX
MII_RT 00032000 00000070 00000000 00000070 RWIX
MII_MDIO 00032400 00000088 00000000 00000088 RWIX
MII_G_RT 00033000 00000f44 00000000 00000f44 RWIX
RSVD15 60000000 00000100 00000000 00000100 RWIX
RSVD16 70000000 00000100 00000000 00000100 RWIX
RSVD17 80000000 00000100 00000000 00000100 RWIX
RSVD18 90000000 00000100 00000000 00000100 RWIX
RSVD19 a0000000 00000100 00000000 00000100 RWIX
RSVD20 b0000000 00000100 00000000 00000100 RWIX
RSVD23 c0000000 00000100 00000000 00000100 RWIX
RSVD29 d0000000 00010000 00000000 00010000 RWIX
RSVD30 e0000000 00010000 00000000 00010000 RWIX
RSVD31 f0000000 00010000 00000000 00010000 RWIX
SECTION ALLOCATION MAP
output attributes/
section page origin length input sections
.text:_c_int00*
* 0 00000000 0000001c
00000000 0000001c rtspruv3_le.lib : boot.c.obj (.text:_c_int00_noinit_noargs)
.text 0 0000001c 00000818
0000001c 0000036c main.object (.text:DisplayLoop)
00000388 000000f0 spi.object (.text:SpiTxRx)
00000478 000000a8 spi.object (.text:SpiSetup)
00000520 000000a0 main.object (.text:SignalEvent)
000005c0 00000064 main.object (.text:CheckForRunStopTelegram)
00000624 0000005c main.object (.text:SetDefaultTeleV2)
00000680 0000005c main.object (.text:SetTextTeleV2)
000006dc 00000054 spi.object (.text:SpiReset)
00000730 00000048 main.object (.text:CheckForDefaultTelegram)
00000778 00000048 main.object (.text:main)
000007c0 00000034 rtspruv3_le.lib : memcpy.asm.obj (.text)
000007f4 00000030 crcfcts.object (.text:UtilCRC8)
00000824 00000008 rtspruv3_le.lib : exit.c.obj (.text:abort)
0000082c 00000008 : exit.c.obj (.text:loader_exit)
.stack 1 00000108 00000100 UNINITIALIZED
00000108 00000004 rtspruv3_le.lib : boot.c.obj (.stack)
0000010c 000000fc --HOLE--
.data 1 00000208 0000006f
00000208 00000058 main.object (.data:sReadBuf)
00000260 00000017 main.object (.data)
.cinit 1 00000000 00000000 UNINITIALIZED
.rodata 1 00000000 00000108
00000000 00000100 crcfcts.object (.rodata:.string:abyCRC8Tab)
00000100 00000008 main.object (.rodata:.string)
.creg.PRU_INTC.noload.near
* 2 00020000 00000000 NOLOAD SECTION
.creg.PRU_INTC.near
* 2 00020000 00000000 UNINITIALIZED
.creg.PRU_INTC.noload.far
* 2 00020000 00001504 NOLOAD SECTION
00020000 00001504 main.object (.creg.PRU_INTC.noload.far)
.creg.PRU_INTC.far
* 2 00021504 00000000 UNINITIALIZED
MODULE SUMMARY
Module code ro data rw data
gen/PRU1/
main.object 1464 8 5491
spi.object 492 0 0
crcfcts.object 48 256 0
Total: 2004 264 5491
/home/chris/ti/ti-processor-sdk-linux-rt-am64xx-evm-10.00.07.04/linux-devkit/sysroots/x86_64-arago-linux/usr/share/ti/cgt-pru//lib/rtspruv3_le.lib
memcpy.asm.obj 52 0 0
boot.c.obj 28 0 0
exit.c.obj 16 0 0
Total: 96 0 0
Stack: 0 0 256
Grand Total: 2100 264 5747
SEGMENT ATTRIBUTES
id tag seg value
0 PHA_PAGE 1 1
1 PHA_PAGE 2 1
2 PHA_PAGE 3 1
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
page address name
0 0000082c C$$EXIT
2 00020000 CT_INTC
0 000006dc SpiReset
0 00000478 SpiSetup
0 00000388 SpiTxRx
0 000007f4 UtilCRC8
abs 00033000 __PRU_CREG_BASE_MII_G_RT
abs 00032400 __PRU_CREG_BASE_MII_MDIO
abs 00032000 __PRU_CREG_BASE_MII_RT
abs 0002c000 __PRU_CREG_BASE_PA_STATS_CRAM
abs 00027000 __PRU_CREG_BASE_PA_STATS_QRAM
abs 00024000 __PRU_CREG_BASE_PRU1_CTRL
abs 00002000 __PRU_CREG_BASE_PRU1_DMEM_0
abs 00000000 __PRU_CREG_BASE_PRU1_DMEM_1
abs 00026000 __PRU_CREG_BASE_PRU_CFG
abs 00026100 __PRU_CREG_BASE_PRU_CFG_0x100
abs 00030000 __PRU_CREG_BASE_PRU_ECAP
abs 0002e000 __PRU_CREG_BASE_PRU_IEP0
abs 0002e100 __PRU_CREG_BASE_PRU_IEP0_0x100
abs 0002f000 __PRU_CREG_BASE_PRU_IEP1
abs 0002f100 __PRU_CREG_BASE_PRU_IEP1_0x100
abs 00020000 __PRU_CREG_BASE_PRU_INTC
abs 00009000 __PRU_CREG_BASE_PRU_RTU_RAT1
abs 00010000 __PRU_CREG_BASE_PRU_SHAREDMEM
abs 00028000 __PRU_CREG_BASE_PRU_UART
abs 00024800 __PRU_CREG_BASE_RSVD14
abs 60000000 __PRU_CREG_BASE_RSVD15
abs 70000000 __PRU_CREG_BASE_RSVD16
abs 80000000 __PRU_CREG_BASE_RSVD17
abs 90000000 __PRU_CREG_BASE_RSVD18
abs a0000000 __PRU_CREG_BASE_RSVD19
abs b0000000 __PRU_CREG_BASE_RSVD20
abs c0000000 __PRU_CREG_BASE_RSVD23
abs d0000000 __PRU_CREG_BASE_RSVD29
abs e0000000 __PRU_CREG_BASE_RSVD30
abs f0000000 __PRU_CREG_BASE_RSVD31
abs 0002a200 __PRU_CREG_BASE_TM_CFG_PRU1
abs 00000009 __PRU_CREG_MII_G_RT
abs 00000015 __PRU_CREG_MII_MDIO
abs 0000001b __PRU_CREG_MII_RT
abs 0000000d __PRU_CREG_PA_STATS_CRAM
abs 0000000c __PRU_CREG_PA_STATS_QRAM
abs 0000000b __PRU_CREG_PRU1_CTRL
abs 00000019 __PRU_CREG_PRU1_DMEM_0
abs 00000018 __PRU_CREG_PRU1_DMEM_1
abs 00000004 __PRU_CREG_PRU_CFG
abs 00000005 __PRU_CREG_PRU_CFG_0x100
abs 00000003 __PRU_CREG_PRU_ECAP
abs 0000001a __PRU_CREG_PRU_IEP0
abs 00000008 __PRU_CREG_PRU_IEP0_0x100
abs 00000001 __PRU_CREG_PRU_IEP1
abs 00000002 __PRU_CREG_PRU_IEP1_0x100
abs 00000000 __PRU_CREG_PRU_INTC
abs 00000016 __PRU_CREG_PRU_RTU_RAT1
abs 0000001c __PRU_CREG_PRU_SHAREDMEM
abs 00000007 __PRU_CREG_PRU_UART
abs 0000000e __PRU_CREG_RSVD14
abs 0000000f __PRU_CREG_RSVD15
abs 00000010 __PRU_CREG_RSVD16
abs 00000011 __PRU_CREG_RSVD17
abs 00000012 __PRU_CREG_RSVD18
abs 00000013 __PRU_CREG_RSVD19
abs 00000014 __PRU_CREG_RSVD20
abs 00000017 __PRU_CREG_RSVD23
abs 0000001d __PRU_CREG_RSVD29
abs 0000001e __PRU_CREG_RSVD30
abs 0000001f __PRU_CREG_RSVD31
abs 0000000a __PRU_CREG_TM_CFG_PRU1
1 00000208 __TI_STACK_END
abs 00000100 __TI_STACK_SIZE
abs ffffffff __c_args__
0 00000000 _c_int00_noinit_noargs
1 00000108 _stack
0 00000824 abort
0 00000778 main
0 000007c0 memcpy
GLOBAL SYMBOLS: SORTED BY Symbol Address
page address name
0 00000388 SpiTxRx
0 00000478 SpiSetup
0 000006dc SpiReset
0 00000778 main
0 000007c0 memcpy
0 000007f4 UtilCRC8
0 00000824 abort
0 0000082c C$$EXIT
1 00000108 _stack
2 00020000 CT_INTC
[76 symbols]
Could you please help me to analyze?
Thanks a lot
Chris
