Dear TI Forum,
we found a bug in the library rpmsg library.
Here is a patch with a possible fix:
# * TI RPMsg Char Utility Library
# * Utility Library for accessing rpmsg devices through rpmsg-char driver
# * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/
# * Redistribution and use in source and binary forms, with or without
# * modification, are permitted provided that the following conditions
# * are met:
# * Redistributions of source code must retain the above copyright
# * notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright
# * notice, this list of conditions and the following disclaimer in the
# * documentation and/or other materials provided with the distribution.
# * Neither the name of Texas Instruments Incorporated nor the names of
# * its contributors may be used to endorse or promote products derived
# * from this software without specific prior written permission.
# * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
# * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
# * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
# * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
# * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
# * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
# * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
# * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
# * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
diff --git a/src/rpmsg_char.c b/src/rpmsg_char.c
index afb4fec..b2886b7 100644
--- a/src/rpmsg_char.c
+++ b/src/rpmsg_char.c
@@ -274,34 +274,29 @@ static int _rpmsg_char_find_ctrldev(struct rpmsg_char_endpt *ept,
* virtio device number and the rpmsg device number.
sprintf(ctrl_path, "virtio%u.rpmsg_ctrl.0.0", ept->virtio_id);
- dir = opendir(rpath);
- if (dir) {
- * find a directory that matches the rpmsg_ctrl
- * form virtio%d.rpmsg_ctrl.0.0
- while ((iter = readdir(dir))) {
- if (iter->d_type == DT_DIR) {
- if (!strcmp(iter->d_name, ctrl_path))
- break;
+ rewinddir(dir);
+ * find a directory that matches the rpmsg_ctrl
+ * form virtio%d.rpmsg_ctrl.0.0
+ while ((iter = readdir(dir))) {
+ if (iter->d_type == DT_DIR) {
+ if (!strcmp(iter->d_name, ctrl_path))
+ break;
- if (iter) {
- memset(&fpath, 0, sizeof(fpath));
- sprintf(fpath, "%s/%s/rpmsg", rpath, iter->d_name);
- if (check_dir(fpath)) {
- fprintf(stderr, "%s: rpmsg directory doesn't exist under %s\n",
- __func__, ept->rpmsg_dev_name);
- ret = -ENOENT;
- } else {
- ret = get_child_dir_suffix(fpath, "rpmsg_ctrl%u", &ctrl_id);
- } else {
+ if (iter) {
+ memset(&fpath, 0, sizeof(fpath));
+ sprintf(fpath, "%s/%s/rpmsg", rpath, iter->d_name);
+ if (check_dir(fpath)) {
+ fprintf(stderr, "%s: rpmsg directory doesn't exist under %s\n",
+ __func__, ept->rpmsg_dev_name);
ret = -ENOENT;
+ } else {
+ ret = get_child_dir_suffix(fpath, "rpmsg_ctrl%u", &ctrl_id);
- else {
- ret = -errno;
+ } else {
+ ret = -ENOENT;
/* check for backward compatibility if failed */
igmogo_ku
