Hi team,
I'm working on SDK 08_02_00_05(Linux+RTOS).
When testing a application, I'm facing the below error log.
root@j7-evm:/opt/vision_apps# ./btc_tpa_dl.out --cfg btc_tpa_dl.cfg APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=4) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 61.952107 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 61.958635 s: VX_ZONE_INIT:Enabled 61.958652 s: VX_ZONE_ERROR:Enabled 61.958666 s: VX_ZONE_WARNING:Enabled 61.962714 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! 61.962886 s: VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!! Default param set! Parsed user params! Updated user params! end app_init_res_resize, vx_status:0 inside mesh img creation resolution resize init Done! app_init_color_conv_RGB_NV12() : ENTERING app_init_color_conv_RGB_NV12() : EXITING color_conv_RGB_NV12 Done! [LDC-MODULE] configure_dcc_params() : ENTERING [LDC-MODULE] configure_dcc_params() : Setting DCC config object to NULL! [LDC-MODULE] configure_dcc_params() : EXITING LDC init done! Scaler Init Done! Computing checksum at 0x0000FFFFA1DB2F00, size = 785072 TIDL Init Done! Pre Proc Update Done! Pre Proc Init Done! APP_INIT Number of Input Tensors in draw detections 1 rci postproc Update Done! rci postproc Init Done! App Init Done! I am inside app_create_graph_reso_res Before tivxResoResizeNode ! tivxResoResizeNode after! Tensor releasing Start Done! Tensor releasing Done! app_create_graph_res_resize graph done! app_create_graph_color_conv_RGB_NV12() : ENTERING Color convert RGB_NV12 node create started Color convert node RGB_NV12 create done app_create_graph_color_conv_RGB_NV12() : EXITING app_create_graph_color_conv_RGB_NV12 graph done! [LDC-MODULE] app_create_graph_ldc() : ENTERING [LDC-MODULE] app_create_graph_ldc() : DCC config object is NULL output image is NULL in ldc 62.038711 s: VX_ZONE_ERROR:[vxSetParameterByIndex:228] Supplied value was not actually a reference 62.038721 s: VX_ZONE_ERROR:[vxSetParameterByIndex:305] Specified: parameter[7] type:00000000 => (nil) 62.038728 s: VX_ZONE_ERROR:[vxSetParameterByIndex:307] Required: parameter[7] dir:1 type:0000080f 62.038739 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference 62.038746 s: VX_ZONE_ERROR:[vxGetStatus:713] Reference is NULL status:-7 [LDC-MODULE] Unable to create LDC node without DCC config! [LDC-MODULE] app_create_graph_ldc() : EXITING LDC graph done! App Create Graph Done! App Run Graph Done! res resize delete done! Color_conv_RGB_NV12 delete done! LDC delete done! App Delete Graph Done! Input image release Done! 62.038841 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:307] Invalid reference res resize deinit done! rgb to nv12 done! LDC deinit done! Scaler deinit Done! Pre-Proc deinit Done! TIDL deinit Done! Post_proc deinit Done! TIDL unload Done! ImgProc unload Done! RCIPostProc unload Done! Resolution Resize unload Done! HWA unload Done! 62.039379 s: VX_ZONE_WARNING:[vxReleaseContext:1050] Found a reference 0xffffad795c28 of type 00000813 at external count 1, internal count 0, releasing it 62.039387 s: VX_ZONE_WARNING:[vxReleaseContext:1052] Releasing reference (name=object_array_104) now as a part of garbage collection 62.039397 s: VX_ZONE_WARNING:[vxReleaseContext:1050] Found a reference 0xffffad72e9a8 of type 0000080f at external count 1, internal count 0, releasing it 62.039403 s: VX_ZONE_WARNING:[vxReleaseContext:1052] Releasing reference (name=image_105) now as a part of garbage collection 62.039428 s: VX_ZONE_WARNING:[vxReleaseContext:1050] Found a reference 0xffffad6fc080 of type 00000816 at external count 1, internal count 0, releasing it 62.039436 s: VX_ZONE_WARNING:[vxReleaseContext:1052] Releasing reference (name=user_data_object_106) now as a part of garbage collection 62.039457 s: VX_ZONE_WARNING:[vxReleaseContext:1050] Found a reference 0xffffad72ec60 of type 0000080f at external count 1, internal count 0, releasing it 62.039464 s: VX_ZONE_WARNING:[vxReleaseContext:1052] Releasing reference (name=image_108) now as a part of garbage collection 62.039485 s: VX_ZONE_WARNING:[vxReleaseContext:1050] Found a reference 0xffffad790740 of type 0000080d at external count 1, internal count 0, releasing it 62.039493 s: VX_ZONE_WARNING:[vxReleaseContext:1052] Releasing reference (name=scalar_132) now as a part of garbage collection Context released! App De-init Done! 62.039525 s: VX_ZONE_INIT:[tivxHostDeInitLocal:100] De-Initialization Done for HOST !!! 62.043893 s: VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!! APP: Deinit ... !!! REMOTE_SERVICE: Deinit ... !!! REMOTE_SERVICE: Deinit ... Done !!! IPC: Deinit ... !!! IPC: DeInit ... Done !!! MEM: Deinit ... !!! MEM: Alloc's: 18 alloc's of 2513008 bytes MEM: Free's : 18 free's of 2513008 bytes MEM: Open's : 0 allocs of 0 bytes MEM: Deinit ... Done !!! APP: Deinit ... Done !!! root@j7-evm:/opt/vision_apps#
Attaching my app_create_graph function.
static vx_status app_create_graph(AppObj *obj) { vx_status status = VX_SUCCESS; vx_char output_file_name[APP_MAX_FILE_PATH]; //vx_graph_parameter_queue_params_t graph_parameters_queue_params_list[2]; //vx_int32 graph_parameter_index; obj->graph = vxCreateGraph(obj->context); status = vxGetStatus((vx_reference)obj->graph); if(status == VX_SUCCESS) { status = vxSetReferenceName((vx_reference)obj->graph, "OpenVxGraph"); } if(status == VX_SUCCESS) { status = app_create_graph_res_resize(obj->graph, &obj->resResizeObj, obj->input.arr[0]); APP_PRINTF(" app_create_graph_res_resize graph done!\n"); } if(status == VX_SUCCESS) { status = app_create_graph_color_conv_RGB_NV12(obj->graph, &obj->colorConvRGBNV12Obj, obj->resResizeObj.output_image_arr); APP_PRINTF(" app_create_graph_color_conv_RGB_NV12 graph done!\n"); } vx_image src_image1 = (vx_image)vxGetObjectArrayItem(obj->colorConvRGBNV12Obj.dst_image_arr, 0); snprintf(output_file_name, APP_MAX_FILE_PATH, "%s/cc_output.bmp", obj->output_file_path); tivx_utils_save_vximage_to_bmpfile(output_file_name, src_image1); if(status == VX_SUCCESS) { status = app_create_graph_ldc(obj->graph, &obj->ldcObj, obj->colorConvRGBNV12Obj.dst_image_arr); APP_PRINTF("LDC graph done!\n"); } if(status == VX_SUCCESS) { status = app_create_graph_scaler(obj->context, obj->graph, &obj->scalerObj, obj->ldcObj.output_arr); } if(status == VX_SUCCESS) { status = app_create_graph_pre_proc(obj->graph, &obj->preProcObj, obj->scalerObj.output[0].arr); } if(status == VX_SUCCESS) { status = app_create_graph_tidl(obj->context, obj->graph, &obj->tidlObj, obj->preProcObj.output_tensor_arr); APP_PRINTF("TIDL Create Done! \n"); } if(status == VX_SUCCESS) { status = app_rci_create_graph_postproc(obj->graph, &obj->rcipostprocObj, obj->tidlObj.output_tensor_arr); APP_PRINTF("RCI Create Postproc Done!\n"); } return status; }
When I dumped obj->colorConvRGBNV12Obj.dst_image_arr the output is not expected but it's not NULL. Attaching the dump below.
But when the same is passed to app_create_graph_ldc function which is the next node, I'm facing the error.
What could be the reason for this behaviour? How to resolve this?
Chaitanya Prakash Uppala
