Part Number: AM69A
I have a model with a custom layer that is already supported by TIDL.
I added my file for the custom layer in the SDK RTOS, and now I want to test my model.
However, when compiling, the layer is not recognized as CUSTOM_LAYER but as POOLING_LAYER:
tidl_tools_path = /home/developer/edgeai/edgeai-tidl-tools/tidl_tools
artifacts_folder = artefacts/artefacts_custom_layer_v0
tidl_tensor_bits = 8
debug_level = 9
num_tidl_subgraphs = 16
tidl_denylist =
tidl_denylist_layer_name =
tidl_denylist_layer_type =
tidl_allowlist_layer_name =
model_type =
tidl_calibration_accuracy_level = 7
tidl_calibration_options:num_frames_calibration = 4
tidl_calibration_options:bias_calibration_iterations = 3
mixed_precision_factor = -1.000000
model_group_id = 0
power_of_2_quantization = 2
ONNX QDQ Enabled = 0
enable_high_resolution_optimization = 0
pre_batchnorm_fold = 1
add_data_convert_ops = 0
output_feature_16bit_names_list =
m_params_16bit_names_list =
m_single_core_layers_names_list =
Inference mode = 0
Number of cores = 1
reserved_compile_constraints_flag = 1601
partial_init_during_compile = 0
ti_internal_reserved_1 =
[35;1m========================= [Model Compilation Started] =========================
[0mModel compilation will perform the following stages:
1. Parsing
2. Graph Optimization
3. Quantization & Calibration
4. Memory Planning
[35;1m============================== [Version Summary] ==============================
[0m-------------------------------------------------------------------------------
| TIDL Tools Version | [32;1m10_00_08_00[0m |
| C7x Firmware Version | [32;1m10_00_02_00[0m |
[35;1m============================== [Parsing Started] ==============================
[0m[33m[TIDL Import] [PARSER] WARNING: Network not identified as Object Detection network : (1) Ignore if network is not Object Detection network (2) If network is Object Detection network, please specify "model_type":"OD" as part of OSRT compilation options[0m
[TIDL Import] [PARSER] SUPPORTED: Supported TIDL layer type --- 1 Tflite layer type --- 3 layer output name--- sequential_2/conv2d_3/Relu;sequential_2/conv2d_3/BiasAdd;sequential_2/conv2d_3/Conv2D;conv2d_3/bias -- [tidl_tfLiteRtImport_core.cpp, 3090]
[TIDL Import] [PARSER] SUPPORTED: Supported TIDL layer type --- 2 Tflite layer type --- 17 layer output name--- sequential_2/max_pooling2d_3/MaxPool -- [tidl_tfLiteRtImport_core.cpp, 3090]
[TIDL Import] [PARSER] SUPPORTED: Supported TIDL layer type --- 38 Tflite layer type --- 22 layer output name--- sequential_2/flatten_1/Reshape -- [tidl_tfLiteRtImport_core.cpp, 3090]
[TIDL Import] [PARSER] SUPPORTED: Supported TIDL layer type --- 6 Tflite layer type --- 9 layer output name--- sequential_2/dense_3/MatMul;sequential_2/dense_3/BiasAdd -- [tidl_tfLiteRtImport_core.cpp, 3090]
[TIDL Import] [PARSER] SUPPORTED: Supported TIDL layer type --- 7 Tflite layer type --- 25 layer output name--- StatefulPartitionedCall:0 -- [tidl_tfLiteRtImport_core.cpp, 3090]
Total Nodes = 5
| Core | No. of Nodes | Number of Subgraphs |
| C7x | 5 | 1 |
| CPU | 0 | x |
[35;1m============================= [Parsing Completed] =============================
[0mIn TIDL_tfliteRtImportInit subgraph_id=10
Layer 0, subgraph id 10, name=StatefulPartitionedCall:0
Layer 1, subgraph id 10, name=serving_default_conv2d_3_input:0
In TIDL_tfliteRtImportNode, TIDL Layer type - 1, Tflite builtin code type - 3
In TIDL_tfliteRtImportNode, TIDL Layer type - 2, Tflite builtin code type - 17
In TIDL_tfliteRtImportNode, TIDL Layer type - 38, Tflite builtin code type - 22
In TIDL_tfliteRtImportNode, TIDL Layer type - 6, Tflite builtin code type - 9
In TIDL_tfliteRtImportNode, TIDL Layer type - 7, Tflite builtin code type - 25
[35;1m==================== [Optimization for subgraph_10 started] ====================
[0mIn TIDL_runtimesOptimizeNet: LayerIndex = 7, dataIndex = 6
----------------------------- Optimization Summary -----------------------------
| Layer | Nodes before optimization | Nodes after optimization |
| TIDL_SoftMaxLayer | 1 | 1 |
| TIDL_InnerProductLayer | 1 | 1 |
| TIDL_CropLayer | 0 | 1 |
| TIDL_ConvolutionLayer | 1 | 1 |
| TIDL_PoolingLayer | 1 | 1 |
[35;1m=================== [Optimization for subgraph_10 completed] ===================
[0mIn TIDL_runtimesPostProcessNet
************ in TIDL_subgraphRtCreate ************
TIDL_initDebugTraceParams Done
TIDL Memory size requiement (record wise):
MemRecNum , Space , Attribute , Alignment , Size(KBytes), BasePtr
0 , DDR Cacheable , Persistent , 12 0%| | 0/4 [00:00<?, ?it/s]8, 19.67 , 0x00000000
1 , DDR Cacheable , Persistent , 128, 0.65 , 0x00000000
2 , DDR Cacheable , Scratch , 128, 16.00 , 0x00000000
3 , DDR Cacheable , Scratch , 128, 4.00 , 0x00000000
4 , DDR Cacheable , Scratch , 128, 56.00 , 0x00000000
5 , DDR Cacheable , Persistent , 128, 258.53 , 0x00000000
6 , DDR Cacheable , Scratch , 128, 178.79 , 0x00000000
7 , DDR Cacheable , Scratch , 128, 0.12 , 0x00000000
8 , DDR Cacheable , Scratch , 128, 96.12 , 0x00000000
9 , DDR Cacheable , Scratch , 128, 131.00 , 0x00000000
10 , DDR Cacheable , Persistent , 128, 321.81 , 0x00000000
11 , DDR Cacheable , Scratch , 128, 512.25 , 0x00000000
12 , DDR Cacheable , Persistent , 128, 0.12 , 0x00000000
13 , DDR Cacheable , Persistent , 128, 22613.75, 0x00000000
14 , DDR Cacheable , Persistent , 128, 0.00 , 0x00000000
15 , DDR Cacheable , Persistent , 128, 0.12 , 0x00000000
Total memory size requirement (space wise):
Mem Space , Size(KBytes)
DDR Cacheable, 24208.95
NOTE: Memory requirement in host emulation can be different from the same on EVM
To get the actual TIDL memory requirement make sure to run on EVM with
debugTraceLevel = 2
TIDL init call from ivision API
0 , DDR Cacheable , Persistent , 128, 19.67 , 0x2dcab000
1 , DDR Cacheable , Persistent , 128, 0.65 , 0x70cf3000
2 , DDR Cacheable , Scratch , 128, 16.00 , 0x6d601000
3 , DDR Cacheable , Scratch , 128, 4.00 , 0x70cf2000
4 , DDR Cacheable , Scratch , 128, 56.00 , 0x11a1a000
5 , DDR Cacheable , Persistent , 128, 258.53 , 0xecc85000
6 , DDR Cacheable , Scratch , 128, 178.79 , 0x0e208000
7 , DDR Cacheable , Scratch , 128, 0.12 , 0x70cf1000
8 , DDR Cacheable , Scratch , 128, 96.12 , 0x0dc85000
9 , DDR Cacheable , Scratch , 128, 131.00 , 0x0c7df000
10 , DDR Cacheable , Persistent , 128, 321.81 , 0xe9f5c000
11 , DDR Cacheable , Scratch , 128, 512.25 , 0xe9edb000
12 , DDR Cacheable , Persistent , 128, 0.12 , 0x6fe03000
13 , DDR Cacheable , Persistent , 128, 22613.75, 0xe578d000
14 , DDR Cacheable , Persistent , 128, 0.00 , 0x6fe02000
15 , DDR Cacheable , Persistent , 128, 0.12 , 0x6f401000
debugTraceLevel = 2
Alg Init for Layer # - 1
Alg Init for Layer # - 2
Alg Init for Layer # - 3
Alg Init for Layer # - 4
Alg Init for Layer # - 5
Alg Init for Layer # - 6
Alg Init for Layer # - 7
Alg Init for Layer # - 8
PREEMPTION: Adding a new priority object for targetPriority = 0, handle = 0x7c562dcab000
PREEMPTION: Now total number of priority objects = 6 at priorityId = 0, with new memRec of base = 0x7c566fe03000 and size = 128
PREEMPTION: Requesting context memory addr for handle 0x7c562dcab000, return Addr = 0x7c55eec314b8
************ TIDL_subgraphRtCreate done ************
tidl_tfLiteRtImport_delegate.cpp Invoke 526
******* In TIDL_subgraphRtInvoke ********
TIDL_process is started with handle : 0x7c562dcab000
TIDL_deactivate is called with handle : 0x7c5640731000 - Copying handle of size 20144 from 0x7c5610f97080 to 0x7c5640731000
TIDL_activate is called with handle : 0x7c562dcab000 - Copying handle of size 20144 from 0x7c562dcab000 to 0x7c5611a1a080
Coreid 0 Layerid to execute = 0
Core 0 Alg Process for Layer # - 0, layer type 0
Coreid 0 Layerid to execute = 1
Core 0 Alg Process for Layer # - 1, layer type 1
Processing Layer # - 1
Core 0 End of Layer # - 1 with outPtrs[0] = 0x7c560e208000
Coreid 0 Layerid to execute = 2
Core 0 Alg Process for Layer # - 2, layer type 15
Processing Layer # - 2
Core 0 End of Layer # - 2 with outPtrs[0] = 0x7c560e218080
Coreid 0 Layerid to execute = 3
Core 0 Alg Process for Layer # - 3, layer type 2
Processing Layer # - 3
Core 0 End of Layer # - 3 with outPtrs[0] = 0x7c560e226200
Coreid 0 Layerid to execute = 4
Core 0 Alg Process for Layer # - 4, layer type 29
Processing Layer # - 4
Core 0 End of Layer # - 4 with outPtrs[0] = 0x7c560e229b00
Coreid 0 Layerid to execute = 5
Core 0 Alg Process for Layer # - 5, layer type 38
Processing Layer # - 5
Core 0 End of Layer # - 5 with outPtrs[0] = 0x7c560e22d400
Coreid 0 Layerid to execute = 6
Core 0 Alg Process for Layer # - 6, layer type 29
Processing Layer # - 6
Core 0 End of Layer # - 6 with outPtrs[0] = 0x7c560e230d00
Coreid 0 Layerid to execute = 7
Core 0 Alg Process for Layer # - 7, layer type 6
Processing Layer # - 7
Executing reference flow for inner product layer
Core 0 End of Layer # - 7 with outPtrs[0] = 0x7c560e234600
Coreid 0 Layerid to execute = 8
Core 0 Alg Process for Layer # - 8, layer type 7
Processing Layer # - 8
Core 0 End of Layer # - 8 with outPtrs[0] = 0x7c5670d46000
Coreid 0 Layerid to execute = 9
Core 0 Alg Process for Layer # - 9, layer type 0
Coreid 0 Layerid to execute = -1
TIDL_process is completed with handle : 0x7c562dcab000
Layer, Layer Cycles,kernelOnlyCycles, coreLoopCycles,LayerSetupCycles,dmaPipeupCycles, dmaPipeDownCycles, PrefetchCycles,copyKerCoeffCycles,LayerDeinitCycles,LastBlockCycles, paddingTrigger, paddingWait,LayerWithoutPad,LayerHandleCopy, BackupCycles, RestoreCycles,Multic7xContextCopyCycles,
1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
6, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
8, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
Sum of Layer Cycles 0
Sub Graph Stats 24.000000 1411.000000 280.000000
******* TIDL_subgraphRtInvoke done ********
************ Frame index 1 : Running float inference ****************
tidl_tfLiteRtImport_delegate.cpp Invoke 647
Sub Graph Stats 7.000000 997.000000 221.000000
************ Frame index 2 : Running float inference ****************
Sub Graph Stats 4.000000 956.000000 8802.000000
************ Frame index 3 : Running float inference ****************
Sub Graph Stats 32.000000 1008.000000 247.000000
************ Frame index 4 : Running fixed point mode for calibration ****************
-------- Running Calibration in Float Mode to Collect Tensor Statistics --------
[=============================================================================] 100 %
------------------ Fixed-point Calibration Iteration [1 / 3]: ------------------
------------------ Fixed-point Calibration Iteration [2 / 3]: ------------------
------------------ Fixed-point Calibration Iteration [3 / 3]: ------------------
[35;1m==================== [Quantization & Calibration Completed] ====================
[0m[35;1m========================== [Memory Planning Started] ==========================
[0m
------------------------- Network Compiler Traces ------------------------------
Successful Memory Allocation
Successful Workload Creation
[35;1m========================= [Memory Planning Completed] =========================
[0mRerunning network compiler...
[0m
100%|██████████| 4/4 [00:01<00:00, 3.78it/s]Successful Workload Creation
[0m[32;1m======================== Subgraph Compiled Successfully ========================
[0m
Final number of subgraphs:1 , 5 nodes delegated to accelerator
Running Runtimes GraphViz - /home/developer/edgeai/edgeai-tidl-tools/tidl_tools/tidl_graphVisualiser_runtimes.out artefacts/artefacts_custom_layer_v0/allowedNode.txt artefacts/artefacts_custom_layer_v0/tempDir/graphvizInfo.txt artefacts/artefacts_custom_layer_v0/tempDir/runtimes_visualization.svg
To enable the custom layer, I set the following variable in the import config file: enableCustomLayers = 1
Then I compiled the custom project with `{TIDL_BASE_PATH}/make tidl`.
After that, I set up SDK RTOS with:
make vision_apps -jN
make tidl_rt -jN
I also set up edgeai_tidl_tools again.
However, the CUSTOM_LAYER is still not recognized, and the TIDL layer is chosen over my custom layer.
Could you help me enable the custom layer so it can be recognized?
Azer
