SK-AM62B-P1: AM62 CPU Freq to over 1.4Ghz?
Part Number: SK-AM62B-P1
Hi Champs:
How to let the AM62 CPU Speed over 1.4Ghz?
Is any side effect if running with 1.6Ghz?
BR Rio
  • Hi Rio
    1,6GHz is outside datasheet specification. So while you can try to test this  and it may work for nominal process/temp, it is not something we can propose for a production solution and if it does not work on your nominal bench setup, it is also not something we can support /debug as you would be running it outside the datasheet specfication.
  • Hi Muku:
    I understand the side effect concern, but my customer is just to try this.
    Any SW setting with 1.6Ghz for letting them try this?
    Need the Voltage from PMIC higher?
    plz have a detail info for this.
    Thanks.
    BR Rio
