Part Number: AM625
I tested IGH ethercat with kernel 6.6 with native driver, but got an error during ethercat stop(/etc/init.d/ethercat stop)
removing the module(ec_ti_am65_cpsw_nuss) will cause an error
It seems that phylink_stop, phylink_disconnect_phy, and k3_knav_desc_pool are not able to properly release memory (Only happens on ethercat port)
hope there is a way to solve it
Incidentally, In FAQ "ti-am65-cpsw-nuss" may be wrong and needs to be changed to "ti_am65_cpsw_nuss"
thanks,
reference:
dmesg:
[ 1039.685425] ec_master: loading out-of-tree module taints kernel.
[ 1039.689599] EtherCAT: Master driver 1.6.1 unknown
[ 1039.690227] EtherCAT: 1 master waiting for devices.
[ 1039.773014] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 1040.124104] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down
[ 1040.332118] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1040.371825] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1040.400071] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver Qualcomm Atheros AR8035
[ 1040.400176] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver Qualcomm Atheros AR8035
[ 1040.400314] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000002
[ 1040.400727] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1040.400739] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1040.401750] pps pps0: new PPS source ptp0
[ 1040.402961] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[ 1040.940032] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1040.942354] EtherCAT: Accepting AA:BB:CC:DD:EE:FF as main device for master 0.
[ 1041.012943] am65-cpsw-nuss 8000000.ethernet ecm0 (uninitialized): PHY [8000f00.mdio:01] driver [Qualcomm Atheros AR8035] (irq=POLL)
[ 1041.013007] am65-cpsw-nuss 8000000.ethernet ecm0 (uninitialized): configuring for phy/rgmii-rxid link mode
[ 1041.013144] EtherCAT 0: Starting EtherCAT-IDLE thread.
[ 1041.152978] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [Qualcomm Atheros AR8035] (irq=POLL)
[ 1041.153050] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ 1043.052440] EtherCAT 0: Link state of ecm0 changed to UP.
[ 1043.052508] am65-cpsw-nuss 8000000.ethernet ecm0 (uninitialized): Link is Up - 100Mbps/Full - flow control off
[ 1043.063834] EtherCAT WARNING 0: 1 datagram TIMED OUT!
[ 1043.071858] EtherCAT 0: 3 slave(s) responding on main device.
[ 1043.071909] EtherCAT 0: Slave states on main device: PREOP.
[ 1043.072020] EtherCAT 0: Scanning bus.
[ 1043.182536] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 1043.939957] EtherCAT 0: Bus scanning completed in 868 ms.
[ 1043.940012] EtherCAT 0: Using slave 0 as DC reference clock.
[ 1088.797081] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
[ 1089.167931] EtherCAT 0: Master thread exited.
[ 1089.169460] ------------[ cut here ]------------
[ 1089.169496] RTNL: assertion failed at drivers/net/phy/phylink.c (2138)
[ 1089.169773] WARNING: CPU: 2 PID: 1132 at drivers/net/phy/phylink.c:2138 phylink_stop+0xfc/0x104 [phylink]
[ 1089.169823] Modules linked in: ec_ti_am65_cpsw_nuss(O-) ec_master(O) cdc_ether usbnet r8152 rpmsg_ctrl rpmsg_char virtio_rpmsg_bus xhci_plat_hcd rpmsg_ns dwc3 snd_soc_simple_card crct10dif_ce snd_soc_simple_card_utils dwc3_am62 ti_k3_r5_remoteproc rtc_ti_k3 ti_k3_m4_remoteproc phy_gmii_sel tidss k3_cppi_desc_pool phylink drm_dma_helper sa2ul drm_kms_helper mcrc64 tps6598x snd_soc_tlv320aic3x_i2c typec snd_soc_davinci_mcasp snd_soc_ti_udma snd_soc_tlv320aic3x snd_soc_ti_edma snd_soc_ti_sdma panel_simple dm_mod ipmi_devintf ipmi_msghandler fuse drm ip_tables x_tables ipv6 [last unloaded: ti_am65_cpsw_nuss]
[ 1089.169942] CPU: 2 PID: 1132 Comm: rmmod Tainted: G W O 6.6.58-rt45 #4
[ 1089.169951] Hardware name: Texas Instruments AM625 SK (DT)
[ 1089.169956] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1089.169964] pc : phylink_stop+0xfc/0x104 [phylink]
[ 1089.169985] lr : phylink_stop+0xfc/0x104 [phylink]
[ 1089.170004] sp : ffff800083a0bb50
[ 1089.170008] x29: ffff800083a0bb50 x28: ffff00000e5b8000 x27: 0000000000000000
[ 1089.170018] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1089.170027] x23: ffff0000003bbc90 x22: 0000000000000480 x21: ffff00000e58e500
[ 1089.170038] x20: ffff00000e79c000 x19: ffff00000bb5d600 x18: 0000038afa1b18fb
[ 1089.170047] x17: 0000000000000002 x16: 000003851accc284 x15: 000e2dc2f62b3c4c
[ 1089.170057] x14: ffff800080fec398 x13: 0000000000000002 x12: 0000000000000000
[ 1089.170067] x11: 0000000000000289 x10: 0000000000000a10 x9 : ffff800083a0b9e0
[ 1089.170076] x8 : ffff00000e5b8a70 x7 : 0000000000000001 x6 : 000000fd696bd000
[ 1089.170086] x5 : 00000000410fd030 x4 : 0000000000f0000f x3 : 0000000000000004
[ 1089.170095] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff00000e5b8000
[ 1089.170105] Call trace:
[ 1089.170110] phylink_stop+0xfc/0x104 [phylink]
[ 1089.170131] am65_cpsw_nuss_ndo_slave_stop+0x28/0x300 [ec_ti_am65_cpsw_nuss]
[ 1089.170161] ec_device_close+0x30/0x8c [ec_master]
[ 1089.170266] ecdev_close+0x2c/0x6c [ec_master]
[ 1089.170318] am65_cpsw_nuss_cleanup_ndev+0x6c/0xac [ec_ti_am65_cpsw_nuss]
[ 1089.170337] am65_cpsw_nuss_remove+0x38/0x1c0 [ec_ti_am65_cpsw_nuss]
[ 1089.170354] platform_remove+0x2c/0x6c
[ 1089.170371] device_remove+0x4c/0x80
[ 1089.170381] device_release_driver_internal+0x1cc/0x228
[ 1089.170390] driver_detach+0x50/0x98
[ 1089.170398] bus_remove_driver+0x6c/0xbc
[ 1089.170405] driver_unregister+0x30/0x60
[ 1089.170414] platform_driver_unregister+0x14/0x20
[ 1089.170423] am65_cpsw_nuss_driver_exit+0x18/0x1358 [ec_ti_am65_cpsw_nuss]
[ 1089.170440] __arm64_sys_delete_module+0x178/0x260
[ 1089.170450] invoke_syscall+0x48/0x118
[ 1089.170462] el0_svc_common.constprop.0+0x40/0xe8
[ 1089.170471] do_el0_svc+0x20/0x2c
[ 1089.170479] el0_svc+0x40/0xf4
[ 1089.170489] el0t_64_sync_handler+0x13c/0x158
[ 1089.170497] el0t_64_sync+0x190/0x194
[ 1089.170505] ---[ end trace 0000000000000000 ]---
[ 1089.171399] EtherCAT 0: Link state of ecm0 changed to DOWN.
[ 1089.171852] am65-cpsw-nuss 8000000.ethernet ecm0 (uninitialized): Link is Down
[ 1089.172158] ------------[ cut here ]------------
[ 1089.172168] RTNL: assertion failed at drivers/net/phy/phylink.c (1991)
[ 1089.172289] WARNING: CPU: 0 PID: 1132 at drivers/net/phy/phylink.c:1991 phylink_disconnect_phy+0xa8/0xb0 [phylink]
[ 1089.172337] Modules linked in: ec_ti_am65_cpsw_nuss(O-) ec_master(O) cdc_ether usbnet r8152 rpmsg_ctrl rpmsg_char virtio_rpmsg_bus xhci_plat_hcd rpmsg_ns dwc3 snd_soc_simple_card crct10dif_ce snd_soc_simple_card_utils dwc3_am62 ti_k3_r5_remoteproc rtc_ti_k3 ti_k3_m4_remoteproc phy_gmii_sel tidss k3_cppi_desc_pool phylink drm_dma_helper sa2ul drm_kms_helper mcrc64 tps6598x snd_soc_tlv320aic3x_i2c typec snd_soc_davinci_mcasp snd_soc_ti_udma snd_soc_tlv320aic3x snd_soc_ti_edma snd_soc_ti_sdma panel_simple dm_mod ipmi_devintf ipmi_msghandler fuse drm ip_tables x_tables ipv6 [last unloaded: ti_am65_cpsw_nuss]
[ 1089.172453] CPU: 0 PID: 1132 Comm: rmmod Tainted: G W O 6.6.58-rt45 #4
[ 1089.172462] Hardware name: Texas Instruments AM625 SK (DT)
[ 1089.172467] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1089.172475] pc : phylink_disconnect_phy+0xa8/0xb0 [phylink]
[ 1089.172495] lr : phylink_disconnect_phy+0xa8/0xb0 [phylink]
[ 1089.172514] sp : ffff800083a0bb40
[ 1089.172518] x29: ffff800083a0bb40 x28: ffff00000e5b8000 x27: 0000000000000000
[ 1089.172528] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1089.172538] x23: ffff0000003bbc90 x22: 0000000000000480 x21: ffff00000e58e500
[ 1089.172548] x20: ffff00000e79c000 x19: ffff00000bb5d600 x18: ffffffffffffffff
[ 1089.172558] x17: 0000000000000001 x16: 00000029199b57c4 x15: ffff800082553424
[ 1089.172568] x14: 0000000000000001 x13: ffff80008255341d x12: 6166206e6f697472
[ 1089.172577] x11: fffffffffffe0000 x10: 000000000000000a x9 : ffff8000821a2168
[ 1089.172587] x8 : 00000000ffffefff x7 : ffff8000821fa168 x6 : 0000000000000878
[ 1089.172597] x5 : ffff00007729fd48 x4 : 0000000000000000 x3 : 0000000000000027
[ 1089.172606] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff00000e5b8000
[ 1089.172618] Call trace:
[ 1089.172625] phylink_disconnect_phy+0xa8/0xb0 [phylink]
[ 1089.172645] am65_cpsw_nuss_ndo_slave_stop+0x38/0x300 [ec_ti_am65_cpsw_nuss]
[ 1089.172675] ec_device_close+0x30/0x8c [ec_master]
[ 1089.172771] ecdev_close+0x2c/0x6c [ec_master]
[ 1089.172824] am65_cpsw_nuss_cleanup_ndev+0x6c/0xac [ec_ti_am65_cpsw_nuss]
[ 1089.172844] am65_cpsw_nuss_remove+0x38/0x1c0 [ec_ti_am65_cpsw_nuss]
[ 1089.172861] platform_remove+0x2c/0x6c
[ 1089.172877] device_remove+0x4c/0x80
[ 1089.172887] device_release_driver_internal+0x1cc/0x228
[ 1089.172897] driver_detach+0x50/0x98
[ 1089.172904] bus_remove_driver+0x6c/0xbc
[ 1089.172912] driver_unregister+0x30/0x60
[ 1089.172921] platform_driver_unregister+0x14/0x20
[ 1089.172930] am65_cpsw_nuss_driver_exit+0x18/0x1358 [ec_ti_am65_cpsw_nuss]
[ 1089.172947] __arm64_sys_delete_module+0x178/0x260
[ 1089.172957] invoke_syscall+0x48/0x118
[ 1089.172968] el0_svc_common.constprop.0+0x40/0xe8
[ 1089.172976] do_el0_svc+0x20/0x2c
[ 1089.172984] el0_svc+0x40/0xf4
[ 1089.172995] el0t_64_sync_handler+0x13c/0x158
[ 1089.173002] el0t_64_sync+0x190/0x194
[ 1089.173011] ---[ end trace 0000000000000000 ]---
[ 1090.187766] am65-cpsw-nuss 8000000.ethernet: rx teardown timeout
[ 1090.188846] EtherCAT 0: Releasing main device AA:BB:CC:DD:EE:FF.
[ 1090.192338] ------------[ cut here ]------------
[ 1090.192357] k3_knav_desc_pool size 64000 != avail 63872
[ 1090.192465] WARNING: CPU: 0 PID: 1132 at drivers/net/ethernet/ti/k3-cppi-desc-pool.c:33 k3_cppi_desc_pool_destroy+0xa0/0xa8 [k3_cppi_desc_pool]
[ 1090.192498] Modules linked in: ec_ti_am65_cpsw_nuss(O-) ec_master(O) cdc_ether usbnet r8152 rpmsg_ctrl rpmsg_char virtio_rpmsg_bus xhci_plat_hcd rpmsg_ns dwc3 snd_soc_simple_card crct10dif_ce snd_soc_simple_card_utils dwc3_am62 ti_k3_r5_remoteproc rtc_ti_k3 ti_k3_m4_remoteproc phy_gmii_sel tidss k3_cppi_desc_pool phylink drm_dma_helper sa2ul drm_kms_helper mcrc64 tps6598x snd_soc_tlv320aic3x_i2c typec snd_soc_davinci_mcasp snd_soc_ti_udma snd_soc_tlv320aic3x snd_soc_ti_edma snd_soc_ti_sdma panel_simple dm_mod ipmi_devintf ipmi_msghandler fuse drm ip_tables x_tables ipv6 [last unloaded: ti_am65_cpsw_nuss]
[ 1090.192613] CPU: 0 PID: 1132 Comm: rmmod Tainted: G W O 6.6.58-rt45 #4
[ 1090.192621] Hardware name: Texas Instruments AM625 SK (DT)
[ 1090.192626] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1090.192634] pc : k3_cppi_desc_pool_destroy+0xa0/0xa8 [k3_cppi_desc_pool]
[ 1090.192647] lr : k3_cppi_desc_pool_destroy+0xa0/0xa8 [k3_cppi_desc_pool]
[ 1090.192659] sp : ffff800083a0bbe0
[ 1090.192663] x29: ffff800083a0bbe0 x28: ffff00000e5b8000 x27: 0000000000000000
[ 1090.192673] x26: 0000000000000000 x25: 0000000000000000 x24: 0000000000000000
[ 1090.192682] x23: 000000000000002a x22: ffff800083a0bc78 x21: ffff0000003dfc10
[ 1090.192692] x20: 000000000000fa00 x19: ffff00000700a400 x18: ffffffffffffffff
[ 1090.192702] x17: 00000148389e2c80 x16: 0000000000000001 x15: ffff8000825540e4
[ 1090.192711] x14: ffffffffffffffff x13: ffff8000825540de x12: 6f705f637365645f
[ 1090.192721] x11: fffffffffffe0000 x10: 2d2d2d2d2d2d2d2d x9 : 000000000000f980
[ 1090.192731] x8 : ffff800083a0bbe0 x7 : ffff8000821a2110 x6 : 00000000000008f1
[ 1090.192740] x5 : ffff00007729fd48 x4 : 0000000000000000 x3 : 0000000000000027
[ 1090.192750] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff00000e5b8000
[ 1090.192760] Call trace:
[ 1090.192764] k3_cppi_desc_pool_destroy+0xa0/0xa8 [k3_cppi_desc_pool]
[ 1090.192778] am65_cpsw_nuss_free_rx_chns+0x2c/0x54 [ec_ti_am65_cpsw_nuss]
[ 1090.192805] devm_action_release+0x14/0x20
[ 1090.192819] devres_release_all+0x98/0xf8
[ 1090.192827] device_unbind_cleanup+0x18/0x68
[ 1090.192836] device_release_driver_internal+0x1ec/0x228
[ 1090.192845] driver_detach+0x50/0x98
[ 1090.192852] bus_remove_driver+0x6c/0xbc
[ 1090.192860] driver_unregister+0x30/0x60
[ 1090.192868] platform_driver_unregister+0x14/0x20
[ 1090.192877] am65_cpsw_nuss_driver_exit+0x18/0x1358 [ec_ti_am65_cpsw_nuss]
[ 1090.192894] __arm64_sys_delete_module+0x178/0x260
[ 1090.192904] invoke_syscall+0x48/0x118
[ 1090.192916] el0_svc_common.constprop.0+0x40/0xe8
[ 1090.192924] do_el0_svc+0x20/0x2c
[ 1090.192932] el0_svc+0x40/0xf4
[ 1090.192942] el0t_64_sync_handler+0x13c/0x158
[ 1090.192949] el0t_64_sync+0x190/0x194
[ 1090.192957] ---[ end trace 0000000000000000 ]---
[ 1090.193017] ------------[ cut here ]------------
[ 1090.193020] kernel BUG at lib/genalloc.c:255!
[ 1090.193028] Internal error: Oops - BUG: 00000000f2000800 [#1] PREEMPT_RT SMP
[ 1090.193034] Modules linked in: ec_ti_am65_cpsw_nuss(O-) ec_master(O) cdc_ether usbnet r8152 rpmsg_ctrl rpmsg_char virtio_rpmsg_bus xhci_plat_hcd rpmsg_ns dwc3 snd_soc_simple_card crct10dif_ce snd_soc_simple_card_utils dwc3_am62 ti_k3_r5_remoteproc rtc_ti_k3 ti_k3_m4_remoteproc phy_gmii_sel tidss k3_cppi_desc_pool phylink drm_dma_helper sa2ul drm_kms_helper mcrc64 tps6598x snd_soc_tlv320aic3x_i2c typec snd_soc_davinci_mcasp snd_soc_ti_udma snd_soc_tlv320aic3x snd_soc_ti_edma snd_soc_ti_sdma panel_simple dm_mod ipmi_devintf ipmi_msghandler fuse drm ip_tables x_tables ipv6 [last unloaded: ti_am65_cpsw_nuss]
[ 1090.193122] CPU: 0 PID: 1132 Comm: rmmod Tainted: G W O 6.6.58-rt45 #4
[ 1090.193128] Hardware name: Texas Instruments AM625 SK (DT)
[ 1090.193131] pstate: 20000005 (nzCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1090.193138] pc : gen_pool_destroy+0x98/0xc8
[ 1090.193149] lr : gen_pool_destroy+0x90/0xc8
[ 1090.193157] sp : ffff800083a0bb90
[ 1090.193160] x29: ffff800083a0bb90 x28: ffff00000e5b8000 x27: 0000000000000000
[ 1090.193170] x26: ffff0000048c5500 x25: ffff0000048c54e0 x24: dead000000000100
[ 1090.193180] x23: dead000000000122 x22: 0000000000000007 x21: ffff0000048c5500
[ 1090.193189] x20: 00000000000001f4 x19: ffff800082a59000 x18: ffffffffffffffff
[ 1090.193199] x17: 00000148389e2c80 x16: 0000000000000001 x15: ffff8000825540e4
[ 1090.193208] x14: ffffffffffffffff x13: ffff8000825540de x12: 6f705f637365645f
[ 1090.193218] x11: fffffffffffe0000 x10: ffff0000772acd50 x9 : ffff0000772acd80
[ 1090.193228] x8 : fffffc0001ddb788 x7 : 0000000000000010 x6 : 00000000ffffffe0
[ 1090.193237] x5 : ffff0000772ab9b8 x4 : 000000000000016c x3 : 0000000000000140
[ 1090.193246] x2 : ffff800082a59068 x1 : 00000000000001f4 x0 : 000000000000016c
[ 1090.193256] Call trace:
[ 1090.193258] gen_pool_destroy+0x98/0xc8
[ 1090.193266] k3_cppi_desc_pool_destroy+0x5c/0xa8 [k3_cppi_desc_pool]
[ 1090.193279] am65_cpsw_nuss_free_rx_chns+0x2c/0x54 [ec_ti_am65_cpsw_nuss]
[ 1090.193296] devm_action_release+0x14/0x20
[ 1090.193303] devres_release_all+0x98/0xf8
[ 1090.193309] device_unbind_cleanup+0x18/0x68
[ 1090.193317] device_release_driver_internal+0x1ec/0x228
[ 1090.193325] driver_detach+0x50/0x98
[ 1090.193333] bus_remove_driver+0x6c/0xbc
[ 1090.193340] driver_unregister+0x30/0x60
[ 1090.193347] platform_driver_unregister+0x14/0x20
[ 1090.193356] am65_cpsw_nuss_driver_exit+0x18/0x1358 [ec_ti_am65_cpsw_nuss]
[ 1090.193373] __arm64_sys_delete_module+0x178/0x260
[ 1090.193380] invoke_syscall+0x48/0x118
[ 1090.193388] el0_svc_common.constprop.0+0x40/0xe8
[ 1090.193396] do_el0_svc+0x20/0x2c
[ 1090.193404] el0_svc+0x40/0xf4
[ 1090.193411] el0t_64_sync_handler+0x13c/0x158
[ 1090.193418] el0t_64_sync+0x190/0x194
[ 1090.193428] Code: aa1403e1 97ff945e eb00029f 54fffdc9 (d4210000)
[ 1090.193434] ---[ end trace 0000000000000000 ]---
[ 1090.193438] note: rmmod[1132] exited with irqs disabled
[ 1090.193442] note: rmmod[1132] exited with preempt_count 1
[ 1090.235484] ------------[ cut here ]------------
[ 1090.235506] WARNING: CPU: 0 PID: 0 at kernel/context_tracking.c:128 ct_kernel_exit.constprop.0+0x98/0xa0
[ 1090.235541] Modules linked in: ec_ti_am65_cpsw_nuss(O-) ec_master(O) cdc_ether usbnet r8152 rpmsg_ctrl rpmsg_char virtio_rpmsg_bus xhci_plat_hcd rpmsg_ns dwc3 snd_soc_simple_card crct10dif_ce snd_soc_simple_card_utils dwc3_am62 ti_k3_r5_remoteproc rtc_ti_k3 ti_k3_m4_remoteproc phy_gmii_sel tidss k3_cppi_desc_pool phylink drm_dma_helper sa2ul drm_kms_helper mcrc64 tps6598x snd_soc_tlv320aic3x_i2c typec snd_soc_davinci_mcasp snd_soc_ti_udma snd_soc_tlv320aic3x snd_soc_ti_edma snd_soc_ti_sdma panel_simple dm_mod ipmi_devintf ipmi_msghandler fuse drm ip_tables x_tables ipv6 [last unloaded: ti_am65_cpsw_nuss]
[ 1090.235666] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D W O 6.6.58-rt45 #4
[ 1090.235675] Hardware name: Texas Instruments AM625 SK (DT)
[ 1090.235679] pstate: 200000c5 (nzCv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 1090.235688] pc : ct_kernel_exit.constprop.0+0x98/0xa0
[ 1090.235696] lr : ct_idle_enter+0x10/0x1c
[ 1090.235704] sp : ffff800082183d80
[ 1090.235707] x29: ffff800082183d80 x28: 000000008395b0ac x27: 00000000ff61d80c
[ 1090.235718] x26: ffff8000817cb320 x25: ffff0000772f9000 x24: 0000000000000000
[ 1090.235728] x23: ffff80008253b000 x22: ffff800082194ec0 x21: ffff80008218cb44
[ 1090.235737] x20: ffff80008218ca40 x19: ffff0000772a4f08 x18: 0000000000000000
[ 1090.235747] x17: 0000000000000001 x16: 00003cf549e631de x15: 00f1d786699187fc
[ 1090.235757] x14: ffff800080fec398 x13: 00000000007719d9 x12: 0000000000000000
[ 1090.235766] x11: ffff0000772d3fc0 x10: 0000000000000a10 x9 : ffff800082183d00
[ 1090.235776] x8 : ffff800082195930 x7 : 0000000000000000 x6 : 0000218786b6f138
[ 1090.235785] x5 : 4000000000000002 x4 : ffff7ffff578a000 x3 : ffff800082183d80
[ 1090.235795] x2 : 4000000000000000 x1 : ffff800081b1af08 x0 : ffff800081b1af08
[ 1090.235806] Call trace:
[ 1090.235810] ct_kernel_exit.constprop.0+0x98/0xa0
[ 1090.235818] ct_idle_enter+0x10/0x1c
[ 1090.235826] default_idle_call+0x1c/0x3c
[ 1090.235833] do_idle+0xa8/0xfc
[ 1090.235845] cpu_startup_entry+0x38/0x3c
[ 1090.235853] kernel_init+0x0/0x1dc
[ 1090.235860] arch_post_acpi_subsys_init+0x0/0x8
[ 1090.235871] start_kernel+0x50c/0x610
[ 1090.235876] __primary_switched+0xbc/0xc4
[ 1090.235888] ---[ end trace 0000000000000000 ]---
