Other Parts Discussed in Thread: TPS65910, TPS65217
We have a issue when change pmic from tps65910 to tps65217.The board hand up at uboot after reboot.
But,if we use cold boot board,it succ.
So,Where do we need to modify?
Below arelog and dts:
U-Boot SPL 2023.04 (Feb 21 2025 - 14:00:19 +0800)
env:
SDK:09_01_00_001
Uboot:2023-04
kernel:6.1
dts:
cpus {
cpu@0 {
cpu0-supply = <&dcdc2_reg>;
memory@80000000 {
device_type = "memory";
reg = <0x80000000 0x20000000>; /* 256 MB */
chosen {
stdout-path = &uart0;
vbat: fixedregulator@0 {
compatible = "regulator-fixed";
regulator-name = "vbat";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
regulator-always-on;
vdd_3v3b: fixedregulator@1 {
regulator-name = "vdd_3v3b";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vin-supply = <&vbat>;
regulator-boot-on;
wlreg_on: fixedregulator@2 {
regulator-name = "wlreg_on";
regulator-boot-on;
vmmcsd_fixed: fixedregulator@3 {
regulator-name = "vmmcsd_fixed";
&i2c0 {
pinctrl-names = "default";
pinctrl-0 = <&i2c0_pins>;
status = "okay";
clock-frequency = <400000>;
tps: tps@24 {
reg = <0x24>;
#include "tps65217.dtsi"
&tps {
interrupts = <7>; /* NMI */
interrupt-parent = <&intc>;
ti,pmic-shutdown-controller;
charger {
interrupts = <0>, <1>;
interrupt-names = "USB", "AC";
status = "okay";
pwrbutton {
interrupts = <2>;
interrupt-names = "PB";
status = "okay";
regulators {
dcdc1_reg: regulator@0 {
regulator-name = "vdds_dpr";
dcdc2_reg: regulator@1 {
/* VDD_MPU voltage limits 0.95V - 1.325V with +/-4% tolerance */
regulator-name = "vdd_mpu";
regulator-min-microvolt = <925000>;
regulator-max-microvolt = <1378000>;
regulator-boot-on;
dcdc3_reg: regulator@2 {
/* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */
regulator-name = "vdd_core";
regulator-max-microvolt = <1150000>;
regulator-boot-on;
ldo1_reg: regulator@3 {
regulator-name = "vio,vrtc,vdds";
ldo2_reg: regulator@4 {
regulator-name = "vdd_3v3aux";
ldo3_reg: regulator@5 {
regulator-name = "vdd_1v8";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
ldo4_reg: regulator@6 {
regulator-name = "vdd_3v3a";
