PROCESSOR-SDK-J784S4: How to control the volume using amixer command
Part Number: PROCESSOR-SDK-J784S4
Hi Team,
We are trying to use audio for our custom board. we are using dummy codec.
Both aplay and arecord are working fine for us.
root@j784s4-evm:~# aplay -Dplughw:0,0 c304-2.wav
Playing WAVE 'c304-2.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
^CAborted by signal Interrupt...
root@j784s4-evm:~# arecord -Dplughw:0,0 -c 2 -r 48000 -f S16_LE test.wav
Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
root@j784s4-evm:~#
But when we try to use amixer command to set the volume, we are getting below error.
root@j784s4-evm:~# amixer -Dplughw:0,0 sset J784S4-TEST 50%
ALSA lib /usr/src/debug/alsa-lib/1.2.11/src/control/control.c:1570:(snd_ctl_open_noupdate) Invalid CTL plughw:0,0
amixer: Mixer attach plughw:0,0 error: No such file or directory
How to use amixer command to set volume
root@j784s4-evm:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: J784S4TEST [J784S4-TEST], device 0: 2b00000.mcasp-snd-soc-dummy-dai snd-soc-dummy-dai-0 [2b00000.mcasp-snd-soc-dummy-dai snd-soc-dummy-dai-0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: J784S4TEST_1 [J784S4-TEST], device 0: 2b10000.mcasp-snd-soc-dummy-dai snd-soc-dummy-dai-0 [2b10000.mcasp-snd-soc-dummy-dai snd-soc-dummy-dai-0]
  Subdevices: 1/1
card 2: J784S4TEST_2 [J784S4-TEST], device 0: 2b30000.mcasp-snd-soc-dummy-dai snd-soc-dummy-dai-0 [2b30000.mcasp-snd-soc-dummy-dai snd-soc-dummy-dai-0]
  Subdevices: 1/1
Ajins
  • Hi Ajins,
    You're referencing the wrong device name with amixer. You should either reference the card, or the device as `hw:N` where N is the specified card number (amixer man page).
    You can set the volume to 70% with either of the following two commands:
    $ amixer -c0 sset 'codec-1 DAC1' 70%
    $ amixer -Dhw:0 sset 'codec-1 DAC1' 70%
    You can view the controllable settings with the following command:
    $ amixer -c0
    Tested with:
    $ aplay -Dplughw:0,0 /dev/random
    Jared
  • Hi Jared,
     amixer -c0 is not listing anything.
    We are using dummy codec. How to find out controls for that?
    Ajins
  • Hi Ajins,
    Can you send your device tree?
    Jared
  • Hi Jared,
    Please find the device tree.
    // SPDX-License-Identifier: GPL-2.0-only OR MIT
     * Copyright (C) 2022-2024 Texas Instruments Incorporated - https://www.ti.com/
     * EVM Board Schematics: https://www.ti.com/lit/zip/sprr458
    /dts-v1/;
    #include <dt-bindings/net/ti-dp83867.h>
    #include <dt-bindings/gpio/gpio.h>
    #include "k3-j784s4.dtsi"
    	compatible = "ti,j784s4-evm", "ti,j784s4";
    	model = "CAT-DC CV Board";
    	chosen {
    		stdout-path = "serial5:115200n8";
    	aliases {
    		serial0 = &main_uart3;	/* RS485 based 5Pin UART */
    		serial1 = &main_uart4;	/* RS232 Based 5Pin UART */
    		serial2 = &main_uart5;	/* RS232 Based 3Pin UART */
    		serial3 = &main_uart7;	/* RS232 Based 3Pin UART */
    		serial5 = &wkup_uart0;	/* 3Pin Debug UART */
    		i2c0 = &main_i2c0;	/* Connected with MAX96789 - 0x40 Serializer */
    		i2c1 = &main_i2c2;	/* Connected with A2B transiver - 0x68 and 0x69 */
    		i2c2 = &main_i2c3;	/* Connected with MAX96745 - 0x42 Serializer */
    		i2c3 = &wkup_i2c0;	/* PMIC's and Voltage Monitor Chip - 0x48, 0x40, 0x43, 0x30 */
    		i2c4 = &mcu_i2c0;	/* RTC Chip - 0x53 */
    		i2c5 = &mcu_i2c1;	/* Connected to TCAL9539 Based GPIO Expanders - 0x74 and 0x77 */
    	memory@80000000 {
    		device_type = "memory";
    		/* 16G RAM */
    		reg = <0x00 0x80000000 0x00 0x80000000>,
    		      <0x08 0x80000000 0x03 0x80000000>;
    	reserved_memory: reserved-memory {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		 /* global cma region */
    		linux,cma {
    			compatible = "shared-dma-pool";
    			reusable;
    			size = <0x00 0x38000000>; //16GB CMA
    			linux,cma-default;
    		secure_ddr: optee@9e800000 {
    			reg = <0x00 0x9e800000 0x00 0x01800000>;
    			no-map;
    		mcu_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 {
    			reg = <0x00 0xa0000000 0x00 0x100000>;
    			no-map;
    		mcu_r5fss0_core0_memory_region: r5f-memory@a0100000 {
    			reg = <0x00 0xa0100000 0x00 0xf00000>;
    			no-map;
    		mcu_r5fss0_core1_dma_memory_region: r5f-dma-memory@a1000000 {
    			reg = <0x00 0xa1000000 0x00 0x100000>;
    			no-map;
    		mcu_r5fss0_core1_memory_region: r5f-memory@a1100000 {
    			reg = <0x00 0xa1100000 0x00 0xf00000>;
    			no-map;
    		main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a2000000 {
    			reg = <0x00 0xa2000000 0x00 0x100000>;
    			no-map;
    		main_r5fss0_core0_memory_region: r5f-memory@a2100000 {
    			reg = <0x00 0xa2100000 0x00 0xf00000>;
    			no-map;
    		main_r5fss0_core1_dma_memory_region: r5f-dma-memory@a3000000 {
    			reg = <0x00 0xa3000000 0x00 0x100000>;
    			no-map;
    		main_r5fss0_core1_memory_region: r5f-memory@a3100000 {
    			reg = <0x00 0xa3100000 0x00 0xf00000>;
    			no-map;
    		main_r5fss1_core0_dma_memory_region: r5f-dma-memory@a4000000 {
    			reg = <0x00 0xa4000000 0x00 0x100000>;
    			no-map;
    		main_r5fss1_core0_memory_region: r5f-memory@a4100000 {
    			reg = <0x00 0xa4100000 0x00 0xf00000>;
    			no-map;
    		main_r5fss1_core1_dma_memory_region: r5f-dma-memory@a5000000 {
    			reg = <0x00 0xa5000000 0x00 0x100000>;
    			no-map;
    		main_r5fss1_core1_memory_region: r5f-memory@a5100000 {
    			reg = <0x00 0xa5100000 0x00 0xf00000>;
    			no-map;
    		main_r5fss2_core0_dma_memory_region: r5f-dma-memory@a6000000 {
    			reg = <0x00 0xa6000000 0x00 0x100000>;
    			no-map;
    		main_r5fss2_core0_memory_region: r5f-memory@a6100000 {
    			reg = <0x00 0xa6100000 0x00 0xf00000>;
    			no-map;
    		main_r5fss2_core1_dma_memory_region: r5f-dma-memory@a7000000 {
    			reg = <0x00 0xa7000000 0x00 0x100000>;
    			no-map;
    		main_r5fss2_core1_memory_region: r5f-memory@a7100000 {
    			reg = <0x00 0xa7100000 0x00 0xf00000>;
    			no-map;
    		c71_0_dma_memory_region: c71-dma-memory@a8000000 {
    			reg = <0x00 0xa8000000 0x00 0x100000>;
    			no-map;
    		c71_0_memory_region: c71-memory@a8100000 {
    			reg = <0x00 0xa8100000 0x00 0xf00000>;
    			no-map;
    		c71_1_dma_memory_region: c71-dma-memory@a9000000 {
    			reg = <0x00 0xa9000000 0x00 0x100000>;
    			no-map;
    		c71_1_memory_region: c71-memory@a9100000 {
    			reg = <0x00 0xa9100000 0x00 0xf00000>;
    			no-map;
    		c71_2_dma_memory_region: c71-dma-memory@aa000000 {
    			reg = <0x00 0xaa000000 0x00 0x100000>;
    			no-map;
    		c71_2_memory_region: c71-memory@aa100000 {
    			reg = <0x00 0xaa100000 0x00 0xf00000>;
    			no-map;
    		c71_3_dma_memory_region: c71-dma-memory@ab000000 {
    			reg = <0x00 0xab000000 0x00 0x100000>;
    			no-map;
    		c71_3_memory_region: c71-memory@ab100000 {
    			reg = <0x00 0xab100000 0x00 0xf00000>;
    			no-map;
    	evm_12v0: regulator-evm12v0 {
    		/* main supply */
    		compatible = "regulator-fixed";
    		regulator-name = "evm_12v0";
    		regulator-min-microvolt = <12000000>;
    		regulator-max-microvolt = <12000000>;
    		regulator-always-on;
    		regulator-boot-on;
    	vsys_3v3: regulator-vsys3v3 {
    		/* Output of LM5140 */
    		regulator-name = "vsys_3v3";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    		vin-supply = <&evm_12v0>;
    		regulator-boot-on;
    	vsys_5v0: regulator-vsys5v0 {
    		regulator-name = "vsys_5v0";
    		regulator-min-microvolt = <5000000>;
    		regulator-max-microvolt = <5000000>;
    		regulator-boot-on;
    	/* This node need to be removed while adding entry for display */
    	dp0_pwr_3v3: regulator-dp0-prw {
    		regulator-name = "dp0-pwr";
    //		gpio = <&exp4 0 GPIO_ACTIVE_HIGH>;
    //		enable-active-high;
    	dp0: dp0-connector {
    		compatible = "dp-connector";
    		label = "DP0";
    		type = "full-size";
    		//dp-pwr-supply = <&dp0_pwr_3v3>;
    		port {
    			dp0_connector_in: endpoint {
    				remote-endpoint = <&dp0_out>;
    	vsys_io_1v8: regulator-vsys-io-1v8 {
    		regulator-name = "vsys_io_1v8";
    		regulator-min-microvolt = <1800000>;
    		regulator-max-microvolt = <1800000>;
    		regulator-boot-on;
    	vsys_io_1v2: regulator-vsys-io-1v2 {
    		regulator-name = "vsys_io_1v2";
    		regulator-min-microvolt = <1200000>;
    		regulator-max-microvolt = <1200000>;
    		regulator-boot-on;
    	edp1_refclk: clock-edp1-refclk {
    		#clock-cells = <0>;
    		compatible = "fixed-clock";
    		clock-frequency = <19200000>;
    	/* This node need to be removed while doing clean up for display */
    	dp1_pwr_3v3: regulator-dp1-prw {
    		regulator-name = "dp1-pwr";
    //		gpio = <&exp4 1 GPIO_ACTIVE_HIGH>; /* P1 - DP1_PWR_SW_EN */
    //		regulator-always-on;
    	transceiver1: can-phy0 {
    		compatible = "ti,tcan1043";
    		#phy-cells = <0>;
    		max-bitrate = <5000000>;
    //		standby-gpios = <&exp1 7 GPIO_ACTIVE_HIGH>;
    //		enable-gpios = <&exp1 5 GPIO_ACTIVE_HIGH>;
    	dsi0_display_panel: panel {
    		reg = <0>;
    		compatible = "max96789-simple-panel0";
    		label = "dsi-gmsl";
    		power-supply = <&vsys_3v3>;
    		/* reg = <0x42>;*/
    		/* The color signals mapping order */
    		data-mapping = "rgb888-1x24";		/* bus format MEDIA_BUS_FMT_RGB888_1X24 */
    		width-mm = <293>;
    		height-mm = <165>;
    		port {
    			max96789_in_0: endpoint {
    				remote-endpoint = <&panel0_bridge_out>;
    	dsi1_display_panel: panel {
    		reg = <0>;
    		compatible = "max96789-simple-panel1";
    		label = "dsi-gmsl";
    		/* reg = <0x42>;*/
    		width-mm = <293>;
    		height-mm = <165>;
    		port {
    			max96789_in_1: endpoint {
    				remote-endpoint = <&panel1_bridge_out>;
    	codec_test: codec_test {
    		compatible = "linux,snd-soc-dummy";
    		#sound-dai-cells = <0>;
    		status="okay";
    	codec_audio0: sound0 {
    		compatible = "simple-audio-card";
    		simple-audio-card,name = "J784S4-TEST";
    		simple-audio-card,format = "i2s";
    		simple-audio-card,bitclock-master = <&sound_master0>;
    		simple-audio-card,frame-master = <&sound_master0>;
    		sound_master0: simple-audio-card,cpu {
    		sound-dai = <&mcasp0>;
    		system-clock-direction-out;
    		simple-audio-card,codec {
    			sound-dai = <&codec_test>;
    	codec_audio1: sound1 {
    		simple-audio-card,bitclock-master = <&sound_master1>;
    		simple-audio-card,frame-master = <&sound_master1>;
    		sound_master1: simple-audio-card,cpu {
    		sound-dai = <&mcasp1>;
    	codec_audio3: sound3 {
    		simple-audio-card,bitclock-master = <&sound_master3>;
    		simple-audio-card,frame-master = <&sound_master3>;
    		sound_master3: simple-audio-card,cpu {
    		sound-dai = <&mcasp3>;
    &wkup_pmx0 {
    	bootph-all;
    	mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-default-pins {
    		bootph-all;
    		pinctrl-single,pins = <
    			J784S4_WKUP_IOPAD(0x000, PIN_OUTPUT, 0) /* (E32) MCU_OSPI0_CLK */
    			J784S4_WKUP_IOPAD(0x02c, PIN_OUTPUT, 0) /* (A32) MCU_OSPI0_CSn0 */
    			J784S4_WKUP_IOPAD(0x00c, PIN_INPUT, 0) /* (B33) MCU_OSPI0_D0 */
    			J784S4_WKUP_IOPAD(0x010, PIN_INPUT, 0) /* (B32) MCU_OSPI0_D1 */
    			J784S4_WKUP_IOPAD(0x014, PIN_INPUT, 0) /* (C33) MCU_OSPI0_D2 */
    			J784S4_WKUP_IOPAD(0x018, PIN_INPUT, 0) /* (C35) MCU_OSPI0_D3 */
    			J784S4_WKUP_IOPAD(0x01c, PIN_INPUT, 0) /* (D33) MCU_OSPI0_D4 */
    			J784S4_WKUP_IOPAD(0x020, PIN_INPUT, 0) /* (D34) MCU_OSPI0_D5 */
    			J784S4_WKUP_IOPAD(0x024, PIN_INPUT, 0) /* (E34) MCU_OSPI0_D6 */
    			J784S4_WKUP_IOPAD(0x028, PIN_INPUT, 0) /* (E33) MCU_OSPI0_D7 */
    			J784S4_WKUP_IOPAD(0x008, PIN_INPUT, 0) /* (C34) MCU_OSPI0_DQS */
    	wkup_gpio_mcu1_pins_default_pmux0: wkup-gpio-mcu1-pins-default-pmux0 {
    			// Sync Input from BCM
    			J784S4_WKUP_IOPAD(0x004, PIN_INPUT, 7) /* (D32) MCU_OSPI0_LBCLKO.WKUP_GPIO0_17 */
    			// PMIC IRQ
    			J784S4_WKUP_IOPAD(0x030, PIN_INPUT, 7) /* (A33) MCU_OSPI0_CSn1.WKUP_GPIO0_28 */
    &wkup_pmx1 {
    	bootph-all;
    	wkup_gpio_mcu1_pins_default_pmux1: wkup-gpio-mcu1-pins-default-pmux1 {
    			// BCM Reset In
    			J784S4_WKUP_IOPAD(0x004, PIN_INPUT, 7) /* (C32) MCU_OSPI0_CSn3.WKUP_GPIO0_30 */
    			// SCORPIO IRQ In
    			J784S4_WKUP_IOPAD(0x000, PIN_INPUT, 7) /* (B34) MCU_OSPI0_CSn2.WKUP_GPIO0_29 */
    			// SCORPIO Sync Out
    			J784S4_WKUP_IOPAD(0x014, PIN_OUTPUT, 7) /* (E35) MCU_OSPI1_D0.WKUP_GPIO0_34 */
    			// EN_1V8_USB_VBUS
    			J784S4_WKUP_IOPAD(0x028, PIN_OUTPUT, 7) /* (G33) MCU_OSPI1_CSn1.WKUP_GPIO0_39 */
    			// HSD Status
    			J784S4_WKUP_IOPAD(0x024, PIN_INPUT, 7) /* (G32) MCU_OSPI1_CSn0.WKUP_GPIO0_38 */
    			// EN_1V8_A2B_PHANTOM
    			J784S4_WKUP_IOPAD(0x018, PIN_OUTPUT, 7) /* (D31) MCU_OSPI1_D1.WKUP_GPIO0_35 */
    			// EN 1V8 HSD
    			J784S4_WKUP_IOPAD(0x01c, PIN_OUTPUT, 7) /* (G31) MCU_OSPI1_D2.WKUP_GPIO0_36 */
    			// Reset SCORPIO
    			J784S4_WKUP_IOPAD(0x008, PIN_OUTPUT, 7) /* (F32) MCU_OSPI1_CLK.WKUP_GPIO0_31 */
    			// SCORPIO IRQ
    			J784S4_WKUP_IOPAD(0x020, PIN_INPUT, 7) /* (F33) MCU_OSPI1_D3.WKUP_GPIO0_37 */
    			// Watchdog trigger
    			J784S4_WKUP_IOPAD(0x010, PIN_OUTPUT, 7) /* (F31) MCU_OSPI1_DQS.WKUP_GPIO0_33 */
    			// 3V3 Peripheral IRQ
    			J784S4_WKUP_IOPAD(0x00c, PIN_INPUT, 7) /* (C31) MCU_OSPI1_LBCLKO.WKUP_GPIO0_32 */
    &wkup_pmx2 {
    	bootph-all;
    	status = "okay";
    	mcu_adc0_pins_default: mcu-adc0-pins-default {
    			J784S4_WKUP_IOPAD(0x0cc, PIN_INPUT, 0) /* (P36) MCU_ADC0_AIN0 */
    			J784S4_WKUP_IOPAD(0x0d0, PIN_INPUT, 0) /* (V36) MCU_ADC0_AIN1 */
    			J784S4_WKUP_IOPAD(0x0d4, PIN_INPUT, 0) /* (T34) MCU_ADC0_AIN2 */
    			J784S4_WKUP_IOPAD(0x0d8, PIN_INPUT, 0) /* (T36) MCU_ADC0_AIN3 */
    			J784S4_WKUP_IOPAD(0x0dc, PIN_INPUT, 0) /* (P34) MCU_ADC0_AIN4 */
    			J784S4_WKUP_IOPAD(0x0e0, PIN_INPUT, 0) /* (R37) MCU_ADC0_AIN5 */
    			J784S4_WKUP_IOPAD(0x0e4, PIN_INPUT, 0) /* (R33) MCU_ADC0_AIN6 */
    			J784S4_WKUP_IOPAD(0x0e8, PIN_INPUT, 0) /* (V38) MCU_ADC0_AIN7 */
    	/* PMIC's and Voltage Monitor Chip */
    	wkup_i2c0_pins_default: wkup-i2c0-pins-default {
    			J784S4_WKUP_IOPAD(0x098, PIN_INPUT, 0) /* (N33) WKUP_I2C0_SCL */
    			J784S4_WKUP_IOPAD(0x09C, PIN_INPUT, 0) /* (N35) WKUP_I2C0_SDA */
    	/* RTC Chip */
    	mcu_i2c0_pins_default: mcu-i2c0-default-pins {
    			J784S4_WKUP_IOPAD(0x0a0, PIN_INPUT, 0) /* (M35) MCU_I2C0_SCL */
    			J784S4_WKUP_IOPAD(0x0a4, PIN_INPUT, 0) /* (G34) MCU_I2C0_SDA */
    	/* Connected to TCAL9539 Based GPIO Expanders */
    	mcu_i2c1_pins_default: mcu-i2c1-default-pins {
    			J784S4_WKUP_IOPAD(0x078, PIN_INPUT, 0) /* (L35) WKUP_GPIO0_8.MCU_I2C1_SCL */
    			J784S4_WKUP_IOPAD(0x07c, PIN_INPUT, 0) /* (L34) WKUP_GPIO0_9.MCU_I2C1_SDA */
    	wkup_uart0_pins_default: wkup-uart0-pins-default {
    			J784S4_WKUP_IOPAD(0x048, PIN_INPUT, 0) /* (K35) WKUP_UART0_RXD */
    			J784S4_WKUP_IOPAD(0x04c, PIN_OUTPUT, 0) /* (K34) WKUP_UART0_TXD */
    	/* SPI line to scorpio chip */
    	mcu_spi0_pins_default: mcu_spi0-default-pins {
    			J784S4_WKUP_IOPAD(0x038, PIN_OUTPUT, 0) /* (G38) MCU_SPI0_CLK */
    			J784S4_WKUP_IOPAD(0x044, PIN_OUTPUT, 0) /* (F37) MCU_SPI0_CS0 */
    			J784S4_WKUP_IOPAD(0x03c, PIN_OUTPUT, 0) /* (H36) MCU_SPI0_D0 */
    			J784S4_WKUP_IOPAD(0x040, PIN_INPUT, 0) /* (J38) MCU_SPI0_D1 */
    	/* SPI line to HSD and LSD */
    	mcu_spi1_pins_default: mcu_spi1-default-pins {
    			J784S4_WKUP_IOPAD(0x058, PIN_OUTPUT, 0) /* (H38) WKUP_GPIO0_0.MCU_SPI1_CLK */
    			J784S4_WKUP_IOPAD(0x064, PIN_OUTPUT, 0) /* (J36) WKUP_GPIO0_3.MCU_SPI1_CS0 */
    			J784S4_WKUP_IOPAD(0x05c, PIN_OUTPUT, 0) /* (J34) WKUP_GPIO0_1.MCU_SPI1_D0 */
    			J784S4_WKUP_IOPAD(0x060, PIN_INPUT, 0) /* (J35) WKUP_GPIO0_2.MCU_SPI1_D1 */
    	mcu_mcan0_pins_default: mcu-mcan0-default-pins {
    			J784S4_WKUP_IOPAD(0x054, PIN_INPUT, 0) /* (F38) MCU_MCAN0_RX */
    			J784S4_WKUP_IOPAD(0x050, PIN_OUTPUT, 0) /* (K33) MCU_MCAN0_TX */
    	wkup_gpio_mcu1_pins_default_pmux2: wkup-gpio-mcu1-pins-default-pmux2 {
    			// RTC Clock In
    			J784S4_WKUP_IOPAD(0x11c, PIN_INPUT, 7) /* (M34) WKUP_GPIO0_67 */
    			// Test PIN
    			J784S4_WKUP_IOPAD(0x080, PIN_OUTPUT, 7) /* (L33) WKUP_GPIO0_10 */
    			// NOR Reset Out
    			J784S4_WKUP_IOPAD(0x0b4, PIN_OUTPUT, 0) /* (F36) MCU_RESETSTATz */
    			// Ser1 Touch D1
    			J784S4_WKUP_IOPAD(0x06c, PIN_INPUT, 7) /* (K36) WKUP_GPIO0_5 */
    			// Ser1 Touch D2
    			J784S4_WKUP_IOPAD(0x070, PIN_INPUT, 7) /* (L37) WKUP_GPIO0_6 */
    			// FSync clock to regulator
    			J784S4_WKUP_IOPAD(0x084, PIN_OUTPUT, 7) /* (M38) WKUP_GPIO0_11 */
    			// System Sleep Control
    			J784S4_WKUP_IOPAD(0x074, PIN_OUTPUT, 7) /* (L36) WKUP_GPIO0_7 */
    			// Short to GND 3
    			J784S4_WKUP_IOPAD(0x00c, PIN_INPUT, 7) /* (E37) MCU_RGMII1_TD2.WKUP_GPIO0_43 */
    			// Short to GND 2
    			J784S4_WKUP_IOPAD(0x010, PIN_INPUT, 7) /* (D38) MCU_RGMII1_TD1.WKUP_GPIO0_44 */
    			// Short to GND 1
    			J784S4_WKUP_IOPAD(0x014, PIN_INPUT, 7) /* (D37) MCU_RGMII1_TD0.WKUP_GPIO0_45 */
    			// STB1
    			J784S4_WKUP_IOPAD(0x02c, PIN_INPUT, 7) /* (A35) MCU_RGMII1_RD0.WKUP_GPIO0_51 */
    			// STB2
    			J784S4_WKUP_IOPAD(0x028, PIN_INPUT, 7) /* (B36) MCU_RGMII1_RD1.WKUP_GPIO0_50 */
    			// Control 12V Supply for Camera
    			J784S4_WKUP_IOPAD(0x0b8, PIN_OUTPUT, 7) /* (M37) WKUP_GPIO0_56 */
    			// Control 12V Supply Diagnostics
    			J784S4_WKUP_IOPAD(0x114, PIN_OUTPUT, 7) /* (M36) WKUP_GPIO0_57 */
    			// EN_P1V4_EFUSE
    			J784S4_WKUP_IOPAD(0x068, PIN_OUTPUT, 7) /* (H35) WKUP_GPIO0_4 */
    			// LSD_IN65
    			J784S4_WKUP_IOPAD(0x088, PIN_OUTPUT, 7) /* (J37) WKUP_GPIO0_12 */
    			// LSD_IN87
    			J784S4_WKUP_IOPAD(0x08c, PIN_OUTPUT, 7) /* (K38) WKUP_GPIO0_13 */
    			// LSD_IN21
    			J784S4_WKUP_IOPAD(0x090, PIN_OUTPUT, 7) /* (H37) WKUP_GPIO0_14 */
    			// LSD_IN43
    			J784S4_WKUP_IOPAD(0x094, PIN_OUTPUT, 7) /* (K37) WKUP_GPIO0_15 */
    			// PWRGD_P0V8
    			J784S4_WKUP_IOPAD(0x0ec, PIN_INPUT, 7) /* (Y38) MCU_ADC1_AIN0.WKUP_GPIO0_79 */
    			// PWRGD_P1V0
    			J784S4_WKUP_IOPAD(0x0f0, PIN_INPUT, 7) /* (Y34) MCU_ADC1_AIN1.WKUP_GPIO0_80 */
    			// PWRGD_P1V8
    			J784S4_WKUP_IOPAD(0x0f4, PIN_INPUT, 7) /* (V34) MCU_ADC1_AIN2.WKUP_GPIO0_81 */
    			// PWRGD_P5V0
    			J784S4_WKUP_IOPAD(0x0f8, PIN_INPUT, 7) /* (W37) MCU_ADC1_AIN3.WKUP_GPIO0_82 */
    			// PWRGD_P9V6
    			J784S4_WKUP_IOPAD(0x0fc, PIN_INPUT, 7) /* (AA37) MCU_ADC1_AIN4.WKUP_GPIO0_83 */
    			// PWRGD_P12V6
    			J784S4_WKUP_IOPAD(0x100, PIN_INPUT, 7) /* (W33) MCU_ADC1_AIN5.WKUP_GPIO0_84 */
    			// USB_VBUS Fault
    			J784S4_WKUP_IOPAD(0x104, PIN_INPUT, 7) /* (U33) MCU_ADC1_AIN6.WKUP_GPIO0_85 */
    			// P3V3 Ser Fault
    			J784S4_WKUP_IOPAD(0x108, PIN_INPUT, 7) /* (Y36) MCU_ADC1_AIN7.WKUP_GPIO0_86 */
    			// EN_P0V8
    			J784S4_WKUP_IOPAD(0x034, PIN_OUTPUT, 7) /* (A36) MCU_MDIO0_MDC.WKUP_GPIO0_53 */
    			// EN_P1V0
    			J784S4_WKUP_IOPAD(0x024, PIN_OUTPUT, 7) /* (C36) MCU_RGMII1_RD2.WKUP_GPIO0_62 */
    			// EN_P1V8
    			J784S4_WKUP_IOPAD(0x020, PIN_OUTPUT, 7) /* (D36) MCU_RGMII1_RD3.WKUP_GPIO0_48 */
    			// EN_P3V3_SER
    			J784S4_WKUP_IOPAD(0x01c, PIN_OUTPUT, 7) /* (B37) MCU_RGMII1_RXC.WKUP_GPIO0_47 */
    			// EN_P5V0
    			J784S4_WKUP_IOPAD(0x018, PIN_OUTPUT, 7) /* (E36) MCU_RGMII1_TXC.WKUP_GPIO0_46 */
    &wkup_pmx3 {
    	wkup_gpio_mcu1_pins_default_pmux3: wkup-gpio-mcu1-pins-default-pmux3 {
    			/* Wake-up PMIC */
    			J784S4_WKUP_IOPAD(0x000, PIN_OUTPUT, 0) /* (M33) WKUP_GPIO0_49 */
    &wkup_gpio0 {
    	status = "okay";
    	pinctrl-names = "default";
    	pinctrl-0 = <&wkup_gpio_mcu1_pins_default_pmux0 &wkup_gpio_mcu1_pins_default_pmux1 &wkup_gpio_mcu1_pins_default_pmux2 &wkup_gpio_mcu1_pins_default_pmux3>;
    &wkup_gpio_intr {
    	status = "okay";
    &tscadc0 {
    	pinctrl-0 = <&mcu_adc0_pins_default>;
    	status = "okay";
    	adc {
    		ti,adc-channels = <0 1 2 3 4 5 6 7>;
    &wkup_uart0 {
    	status = "okay";
    	pinctrl-0 = <&wkup_uart0_pins_default>;
    &mcu_spi0 {
    	status = "okay";
    	pinctrl-0 = <&mcu_spi0_pins_default>;
    	ti,spi-num-cs = <4>;
    	ti,pindir-d0-out-d1-in;
            spidev@0{
                    compatible = "rohm,dh2228fv";
                    reg = <0>;
                    spi-max-frequency = <10000000>;
    &mcu_spi1 {
    	status = "okay";
    	pinctrl-0 = <&mcu_spi1_pins_default>;
    	spidev@0{
                    reg = <0>;
    &wkup_i2c0 {
    	bootph-all;
    	status = "okay";
    	pinctrl-0 = <&wkup_i2c0_pins_default>;
    	clock-frequency = <400000>;
    	tps659413: pmic@48 {
    		compatible = "ti,tps6594-q1";
    		reg = <0x48>;
    		system-power-controller;
    //		pinctrl-0 = <&pmic_irq_pins_default>;
    		interrupt-parent = <&wkup_gpio0>;
    		interrupts = <39 IRQ_TYPE_EDGE_FALLING>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		ti,primary-pmic;
    		buck12-supply = <&vsys_3v3>;
    		buck3-supply = <&vsys_3v3>;
    		buck4-supply = <&vsys_3v3>;
    		buck5-supply = <&vsys_3v3>;
    		ldo1-supply = <&vsys_3v3>;
    		ldo2-supply = <&vsys_3v3>;
    		ldo3-supply = <&vsys_3v3>;
    		ldo4-supply = <&vsys_3v3>;
    		regulators {
    			bucka12: buck12 {
    				regulator-name = "vdd_ddr_1v1";
    				regulator-min-microvolt = <1100000>;
    				regulator-max-microvolt = <1100000>;
    				regulator-boot-on;
    			bucka3: buck3 {
    				regulator-name = "vdd_ram_0v85";
    				regulator-min-microvolt = <850000>;
    				regulator-max-microvolt = <850000>;
    				regulator-boot-on;
    			bucka4: buck4 {
    				regulator-name = "vdd_io_1v8";
    				regulator-boot-on;
    			bucka5: buck5 {
    				regulator-name = "vdd_mcu_0v85";
    				regulator-boot-on;
    			ldoa1: ldo1 {
    				regulator-name = "vdd_mcuio_1v8";
    				regulator-boot-on;
    			ldoa2: ldo2 {
    				regulator-name = "vdd_mcuio_3v3";
    				regulator-boot-on;
    			ldoa3: ldo3 {
    				regulator-name = "vds_dll_0v8";
    				regulator-min-microvolt = <800000>;
    				regulator-max-microvolt = <800000>;
    				regulator-boot-on;
    			ldoa4: ldo4 {
    				regulator-name = "vda_mcu_1v8";
    				regulator-boot-on;
    /* RTC Chip */
    &mcu_i2c0 {
    	status = "okay";
    	pinctrl-0 = <&mcu_i2c0_pins_default>;
    &mcu_i2c1 {
    	status = "okay";
    	pinctrl-0 = <&mcu_i2c1_pins_default>;
    	exp1: gpio@74 {
    		compatible = "ti,tca9539";
    		reg = <0x74>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		gpio-line-names = "RSR_SER2_PWDN", "DI_SER2_LOCK", "IRQ_SER2_ERR",
                                      "RST_SER1_PWDN", "FM_LSD_IDLE", "CAN_MAIN1_EN",
    				  "CAN_MAIN1_FLT", "CAN_MAIN1_STBY", "EN_RS485_TX",
    				  "EN_HSD_DIAG", "FM_SCORPIO3_SWFDL",
    				  "FM_SCORPIO3_GPIO7", "FM_SCORPIO3_GPIO4",
    				  "DI_SER1_LOCK", "IRQ_SER1_LOCK", "EN_USB_VBUS_DIAG";
    		p00-hog {
    			/* RSR_SER2_PWDN */
    			gpio-hog;
    			gpios = <0 GPIO_ACTIVE_HIGH>;
    			output-high;
    		p03-hog {
    			/* RST_SER1_PWDN */
    			gpio-hog;
    			gpios = <3 GPIO_ACTIVE_HIGH>;
    			output-high;
    		p04-hog {
    			/* FM_LSD_IDLE */
    			gpio-hog;
    			gpios = <4 GPIO_ACTIVE_HIGH>;
    			output-high;
    		p05-hog {
    			/* CAN_MAIN1_EN */
    			gpio-hog;
    			gpios = <5 GPIO_ACTIVE_HIGH>;
    			output-high;
    		p07-hog {
    			/* CAN_MAIN1_STBY */
    			gpio-hog;
    			gpios = <7 GPIO_ACTIVE_HIGH>;
    			output-high;
    		p10-hog {
    			/* EN_RS485_TX */
    			gpio-hog;
    			gpios = <8 GPIO_ACTIVE_HIGH>;
    			output-high;
    		p11-hog {
    			/* EN_HSD_DIAG */
    			gpio-hog;
    			gpios = <9 GPIO_ACTIVE_HIGH>;
    			output-high;
    		p12-hog {
    			/* FM_SCORPIO3_SWFDL */
    			gpio-hog;
    			gpios = <10 GPIO_ACTIVE_HIGH>;
    			output-low;
    		p13-hog {
    			/* FM_SCORPIO3_GPIO7 */
    			gpio-hog;
    			gpios = <11 GPIO_ACTIVE_HIGH>;
    			output-low;
    		p14-hog {
    			/* FM_SCORPIO3_GPIO4 */
    			gpio-hog;
    			gpios = <12 GPIO_ACTIVE_HIGH>;
    			output-high;
    		p17-hog {
    			/* EN_USB_VBUS_DIAG */
    			gpio-hog;
    			gpios = <15 GPIO_ACTIVE_HIGH>;
    			output-high;
    	exp2: gpio@77 {
    		reg = <0x77>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		gpio-line-names = "WU_CAN_MAIN1", "WU_RS232_1_DCD", "WU_STG", "WU_STB",
                                      "WU_RTC", "WU_KEYSW", "WU_ETHSW", "WU_P3V3AON", "GND", "GND",
                                      "GND", "GND", "GND", "GND", "GND", "EN_WU_MASK";
    		p17-hog {
    			/* EN_WU_MASK */
    			gpio-hog;
    			output-high;
    &ufs_wrapper {
    	status = "okay";
    &fss {
    	bootph-all;
    	status = "okay";
    &serdes0 {
    	status = "okay";
    	serdes0_pcie_link1: phy@0 {
    		reg = <0>;
    		cdns,num-lanes = <1>;
    		#phy-cells = <0>;
    		cdns,phy-type = <PHY_TYPE_PCIE>;
    		resets = <&serdes_wiz0 1>;
    	serdes0_pcie_link2: phy@2 {
    		reg = <2>;
    		#phy-cells = <0>;
    		resets = <&serdes_wiz0 3>;
    &serdes0 {
    	status = "okay";
    	serdes0_usb_link: phy@3 {
    		reg = <3>;
    		#phy-cells = <0>;
    		cdns,phy-type = <PHY_TYPE_USB3>;
    		resets = <&serdes_wiz0 4>;
    &serdes_wiz0 {
    	status = "okay";
    &usb_serdes_mux {
    	idle-states = <0>; /* USB0 to SERDES lane 3 */
    &usbss0 {
    	status = "okay";
    //	pinctrl-0 = <&main_usbss0_pins_default>;
    //	pinctrl-names = "default";
    	ti,vbus-divider;
    	ti,usb2-only;
    &usb0 {
    	dr_mode = "host";
    	maximum-speed = "high-speed";
    	phys = <&serdes0_usb_link>;
    	phy-names = "cdns3,usb3-phy";
    	phy-names = "cdns3,usb2-phy";
    &serdes1 {
    	status = "okay";
    	serdes1_pcie2_link: phy@2 {
    		reg = <2>;
    		#phy-cells = <0>;
    		resets = <&serdes_wiz1 3>;
    &serdes_wiz1 {
    	status = "okay";
    &pcie2_rc {
    	status = "okay";
    	num-lanes = <1>;
    //	reset-gpios = <&wkup_gpio0 25 GPIO_ACTIVE_HIGH>;
    	phys = <&serdes1_pcie2_link>;
    	ti,syscon-acspcie-proxy-ctrl = <&acspcie0_proxy_ctrl 0x2>;
    	/delete-property/ clocks;
    	/delete-property/ clock-names;
    	clocks = <&k3_clks 334 0>, <&serdes1 CDNS_TORRENT_REFCLK_DRIVER>;
    	clock-names = "fck", "pcie_refclk";
    	phy-names = "pcie-phy";
    &pcie1_rc {
    	status="disabled";
    	/delete-property/ ti,syscon-acspcie-proxy-ctrl;
    	ti,syscon-acspcie-proxy-ctrl = <&acspcie0_proxy_ctrl 0x3>;
    &serdes_ln_ctrl {
    	idle-states = <J784S4_SERDES0_LANE0_PCIE1_LANE0>, <J784S4_SERDES0_LANE1_IP1_UNUSED>,
    <J784S4_SERDES0_LANE2_PCIE3_LANE0>, <J784S4_SERDES0_LANE3_USB>,
    <J784S4_SERDES1_LANE0_PCIE0_LANE0>, <J784S4_SERDES1_LANE1_PCIE0_LANE1>,
    <J784S4_SERDES1_LANE2_PCIE0_LANE2>, <J784S4_SERDES1_LANE3_PCIE0_LANE3>,
    <J784S4_SERDES2_LANE2_QSGMII_LANE1>, <J784S4_SERDES2_LANE3_QSGMII_LANE2>;
    &serdes_refclk {
    	status = "okay";
    	clock-frequency = <100000000>;
    &ospi0 {
    	bootph-all;
    	status = "okay";
    	pinctrl-0 = <&mcu_fss0_ospi0_pins_default>;
    	ospi0_nor: flash@0 {
    		compatible = "jedec,spi-nor";
    		reg = <0x0>;
    		spi-tx-bus-width = <8>;
    		spi-rx-bus-width = <8>;
    		spi-max-frequency = <20000000>;
    		cdns,tshsl-ns = <10>;
    		cdns,tsd2d-ns = <30>;
    		cdns,tchsh-ns = <2>;
    		cdns,tslch-ns = <2>;
    		cdns,read-delay = <4>;
                    cdns,phy-mode;
    		partitions {
    			compatible = "fixed-partitions";
    			#address-cells = <1>;
    			#size-cells = <1>;
    			partition@0 {
    				label = "ospi.tiboot3";
    				reg = <0x0 0x80000>;
    			partition@80000 {
    				label = "ospi.tispl";
    				reg = <0x80000 0x200000>;
    			partition@280000 {
    				label = "ospi.u-boot";
    				reg = <0x280000 0x400000>;
    			partition@680000 {
    				label = "ospi.env";
    				reg = <0x680000 0x40000>;
    			partition@6c0000 {
    				label = "ospi.env.backup";
    				reg = <0x6c0000 0x40000>;
    			partition@800000 {
    				label = "ospi.rootfs";
    				reg = <0x800000 0x7c0000>;
    			partition@fc0000 {
    				bootph-all;
    				label = "ospi.phypattern";
    				reg = <0xfc0000 0x40000>;
    			partition@1000000 {
    				label = "ospi.full";
    				reg = <0x0 0x1000000>;
    &main_pmx0 {
    	bootph-all;
    	/* RS485 5pin UART */
    	main_uart3_pins_default: main-uart3-default-pins {
    			J784S4_IOPAD(0x074, PIN_INPUT, 11) /* (AC33) MCAN2_TX.UART3_RXD */
    			J784S4_IOPAD(0x078, PIN_INPUT, 11) /* (AH37) MCAN2_RX.UART3_TXD */
    	main_uart4_pins_default: main-uart4-default-pins {
    			J784S4_IOPAD(0x094, PIN_INPUT, 7) /* (AG35) MCASP0_AXR9.GPIO0_37 */	// Configured as GPIO
    			J784S4_IOPAD(0x098, PIN_INPUT, 7) /* (AH36) MCASP0_AXR10.GPIO0_38 */	// Configured as GPIO
    			J784S4_IOPAD(0x08c, PIN_INPUT, 11) /* (AE35) MCASP0_AXR7.UART4_RXD */
    			J784S4_IOPAD(0x090, PIN_INPUT, 11) /* (AC35) MCASP0_AXR8.UART4_TXD */
    	main_uart5_pins_default: main-uart5-default-pins {
    			J784S4_IOPAD(0x09c, PIN_INPUT, 11) /* (AF35) MCASP0_AXR11.UART5_RXD */
    			J784S4_IOPAD(0x0a0, PIN_INPUT, 11) /* (AD34) MCASP0_AXR12.UART5_TXD */
    	main_uart7_pins_default: main-uart7-default-pins {
    			J784S4_IOPAD(0x0a4, PIN_INPUT, 13) /* (AJ36) MCASP0_AXR13.UART7_RXD */
    			J784S4_IOPAD(0x0a8, PIN_OUTPUT, 13) /* (AF34) MCASP0_AXR14.UART7_TXD */
    	/* Connected with MAX96789 Serializer */
    	main_i2c0_pins_default: main-i2c0-pins-default {
    			J784S4_IOPAD(0x0e0, PIN_INPUT_PULLUP, 0) /* (AN36) I2C0_SCL */
    			J784S4_IOPAD(0x0e4, PIN_INPUT_PULLUP, 0) /* (AP37) I2C0_SDA */
    	/* Connected with A2B transiver */
    	main_i2c2_pins_default: main-i2c2-default-pins {
    			J784S4_IOPAD(0x04c, PIN_OUTPUT, 13) /* (AC32) MCASP1_AXR1.I2C2_SCL */
    			J784S4_IOPAD(0x050, PIN_INPUT, 13) /* (AC37) MCASP1_AXR2.I2C2_SDA */
    	/* Connected with MAX96745 Serializer */
    	main_i2c3_pins_default: main-i2c3-default-pins {
    			J784S4_IOPAD(0x0f0, PIN_INPUT, 10) /* (AC38) MMC1_DAT3.I2C3_SCL */
    			J784S4_IOPAD(0x0f4, PIN_INPUT, 10) /* (AA32) MMC1_DAT2.I2C3_SDA */
    	mcasp0_pins_default: mcasp0-default-pins {
    			J784S4_IOPAD(0x038, PIN_OUTPUT, 1) /* (AK35) MCASP0_ACLKX */
    			J784S4_IOPAD(0x03c, PIN_OUTPUT, 1) /* (AK38) MCASP0_AFSX */
    			J784S4_IOPAD(0x044, PIN_INPUT, 1) /* (AG37) MCASP0_AXR1 */
    			J784S4_IOPAD(0x048, PIN_OUTPUT, 1) /* (AK33) MCASP0_AXR2 */
    			J784S4_IOPAD(0x084, PIN_INPUT, 1) /* (AG38) MCASP0_AXR5 */
    			J784S4_IOPAD(0x088, PIN_OUTPUT, 1) /* (AF36) MCASP0_AXR6 */
    	mcasp1_pins_default: mcasp1-default-pins {
    			J784S4_IOPAD(0x0b8, PIN_OUTPUT, 1) /* (AC34) MCASP1_ACLKX */
    			J784S4_IOPAD(0x0bc, PIN_OUTPUT, 1) /* (AD33) MCASP1_AFSX */
    			J784S4_IOPAD(0x0c0, PIN_OUTPUT, 1) /* (AD38) MCASP1_AXR0 */
    			J784S4_IOPAD(0x0b4, PIN_OUTPUT, 1) /* (AL34) MCASP1_AXR4 */
    	mcasp3_pins_default: mcasp3-default-pins {
    			J784S4_IOPAD(0x0cc, PIN_OUTPUT, 3) /* (AM37) SPI0_CS0.MCASP3_ACLKX */
    			J784S4_IOPAD(0x0d0, PIN_OUTPUT, 3) /* (AP38) SPI0_CS1.MCASP3_AFSX */
    			J784S4_IOPAD(0x0d4, PIN_OUTPUT, 3) /* (AN38) SPI0_CLK.MCASP3_AXR0 */
    			J784S4_IOPAD(0x0d8, PIN_OUTPUT, 3) /* (AM35) SPI0_D0.MCASP3_AXR1 */
    	dp0_pins_default: dp0-pins-default {
                            J784S4_IOPAD(0x014, PIN_INPUT, 13) /* (AG33) MCAN14_TX.DP0_HPD */
    	main_mcan12_pins_default: mcan12-default-pins {
    			J784S4_IOPAD(0x008, PIN_INPUT, 0) /* (AJ33) MCAN12_RX */
    			J784S4_IOPAD(0x004, PIN_INPUT, 0) /* (AG36) MCAN12_TX */
    	main_mcan13_pins_default: main-mcan13-default-pins {
    			J784S4_IOPAD(0x010, PIN_INPUT, 0) /* (AH33) MCAN13_RX */
    			J784S4_IOPAD(0x00c, PIN_INPUT, 0) /* (AF33) MCAN13_TX */
    	main_mcan3_pins_default: main-mcan3-default-pins {
    			J784S4_IOPAD(0x080, PIN_INPUT, 0) /* (AK34) MCASP0_AXR4.MCAN3_RX */
    			J784S4_IOPAD(0x07c, PIN_OUTPUT, 0) /* (AJ38) MCASP0_AXR3.MCAN3_TX */
    	main_mcan15_pins_default: main-mcan15-default-pins {
    			J784S4_IOPAD(0x020, PIN_INPUT, 0) /* (AJ35) MCAN15_RX */
    			J784S4_IOPAD(0x01c, PIN_INPUT, 0) /* (AG34) MCAN15_TX */
    	main_mcan16_pins_default: main-mcan16-default-pins {
    			J784S4_IOPAD(0x028, PIN_INPUT, 0) /* (AE33) MCAN16_RX */
    			J784S4_IOPAD(0x024, PIN_INPUT, 0) /* (AH34) MCAN16_TX */
    	main_mcan1_pins_default: main-mcan1-default-pins {
    			J784S4_IOPAD(0x070, PIN_INPUT, 0) /* (AH38) MCAN1_RX */
    			J784S4_IOPAD(0x06c, PIN_OUTPUT, 0) /* (AJ37) MCAN1_TX */
    	main_gpio_default_pins: main-gpio-default-pins {
    			// Ser1 Touch D1
    			J784S4_IOPAD(0x054, PIN_INPUT, 7) /* (AD37) MCASP2_ACLKX.GPIO0_21 */
    			// Ser1 Touch D2
    			J784S4_IOPAD(0x058, PIN_INPUT, 7) /* (AE37) MCASP2_AFSX.GPIO0_22 */
    			// Wake-up Scorpio
    			J784S4_IOPAD(0x02c, PIN_OUTPUT, 7) /* (AL32) GPIO0_11 */
    			// EN_9V6
    			J784S4_IOPAD(0x05c, PIN_OUTPUT, 7) /* (AC36) MCASP2_AXR0.GPIO0_23 */
    			// Reset PE3 SCORPIO
    			J784S4_IOPAD(0x064, PIN_OUTPUT, 7) /* (AF38) MCAN0_TX.GPIO0_25 */
    			// PCIE IRQ In
    			J784S4_IOPAD(0x0b0, PIN_INPUT, 7) /* (AL33) MCASP1_AXR3.GPIO_44 */
    			// EN_12V6
    			J784S4_IOPAD(0x000, PIN_OUTPUT, 7) /* (AN35) EXTINTn.GPIO0_0 */
    &main_gpio0 {
    	status = "okay";
    	pinctrl-0 = <&main_gpio_default_pins>;
    &main_uart3 {
    	status = "okay";
    	pinctrl-0 = <&main_uart3_pins_default>;
    	/* Uart Enable pin need to be configured from gpio expander*/
    &main_uart4 {
    	status = "okay";
    	pinctrl-0 = <&main_uart4_pins_default>;
    &main_uart5 {
    	status = "okay";
    	pinctrl-0 = <&main_uart5_pins_default>;
    &main_uart7 {
    	status = "okay";
    	pinctrl-0 = <&main_uart7_pins_default>;
    &main_i2c0 {
    	status = "okay";
    	pinctrl-0 = <&main_i2c0_pins_default>;
    /* Connected with A2B transiver and USB HUB */
    &main_i2c2 {
    	status = "okay";
    	pinctrl-0 = <&main_i2c2_pins_default>;
    &main_i2c3 {
    	status = "okay";
    	pinctrl-0 = <&main_i2c3_pins_default>;
    &main_mcan12 {
    	status = "okay";
    	pinctrl-0 = <&main_mcan12_pins_default>;
    	phys = <&transceiver1>;
    &mcu_mcan0 {
    	status = "okay";
    	pinctrl-0 = <&mcu_mcan0_pins_default>;
    &main_mcan13 {
    	status = "okay";
    	pinctrl-0 = <&main_mcan13_pins_default>;
    &main_mcan3 {
    	status = "okay";
    	pinctrl-0 = <&main_mcan3_pins_default>;
    &main_mcan15 {
    	status = "okay";
    	pinctrl-0 = <&main_mcan15_pins_default>;
    &main_mcan16 {
    	status = "okay";
    	pinctrl-0 = <&main_mcan16_pins_default>;
    &main_mcan1 {
    	status = "okay";
    	pinctrl-0 = <&main_mcan1_pins_default>;
    &mailbox0_cluster0 {
    	status = "okay";
    	interrupts = <436>;
    	mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 {
    		ti,mbox-rx = <0 0 0>;
    		ti,mbox-tx = <1 0 0>;
    	mbox_mcu_r5fss0_core1: mbox-mcu-r5fss0-core1 {
    		ti,mbox-rx = <2 0 0>;
    		ti,mbox-tx = <3 0 0>;
    &mailbox0_cluster1 {
    	status = "okay";
    	interrupts = <432>;
    	mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 {
    	mbox_main_r5fss0_core1: mbox-main-r5fss0-core1 {
    &mailbox0_cluster2 {
    	status = "okay";
    	interrupts = <428>;
    	mbox_main_r5fss1_core0: mbox-main-r5fss1-core0 {
    	mbox_main_r5fss1_core1: mbox-main-r5fss1-core1 {
    &mailbox0_cluster3 {
    	status = "okay";
    	interrupts = <424>;
    	mbox_main_r5fss2_core0: mbox-main-r5fss2-core0 {
    	mbox_main_r5fss2_core1: mbox-main-r5fss2-core1 {
    &mailbox0_cluster4 {
    	status = "okay";
    	interrupts = <420>;
    	mbox_c71_0: mbox-c71-0 {
    	mbox_c71_1: mbox-c71-1 {
    &mailbox0_cluster5 {
    	status = "okay";
    	interrupts = <416>;
    	mbox_c71_2: mbox-c71-2 {
    	mbox_c71_3: mbox-c71-3 {
    &mcu_r5fss0_core0 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>;
    	memory-region = <&mcu_r5fss0_core0_dma_memory_region>,
    			<&mcu_r5fss0_core0_memory_region>;
    &mcu_r5fss0_core1 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core1>;
    	memory-region = <&mcu_r5fss0_core1_dma_memory_region>,
    			<&mcu_r5fss0_core1_memory_region>;
    &main_r5fss0_core0 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core0>;
    	memory-region = <&main_r5fss0_core0_dma_memory_region>,
    			<&main_r5fss0_core0_memory_region>;
    &main_r5fss0_core1 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core1>;
    	memory-region = <&main_r5fss0_core1_dma_memory_region>,
    			<&main_r5fss0_core1_memory_region>;
    &main_r5fss1_core0 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core0>;
    	memory-region = <&main_r5fss1_core0_dma_memory_region>,
    			<&main_r5fss1_core0_memory_region>;
    &main_r5fss1_core1 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster2 &mbox_main_r5fss1_core1>;
    	memory-region = <&main_r5fss1_core1_dma_memory_region>,
    			<&main_r5fss1_core1_memory_region>;
    &main_r5fss2_core0 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster3 &mbox_main_r5fss2_core0>;
    	memory-region = <&main_r5fss2_core0_dma_memory_region>,
    			<&main_r5fss2_core0_memory_region>;
    &main_r5fss2_core1 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster3 &mbox_main_r5fss2_core1>;
    	memory-region = <&main_r5fss2_core1_dma_memory_region>,
    			<&main_r5fss2_core1_memory_region>;
    &c71_0 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster4 &mbox_c71_0>;
    	memory-region = <&c71_0_dma_memory_region>,
    			<&c71_0_memory_region>;
    &c71_1 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster4 &mbox_c71_1>;
    	memory-region = <&c71_1_dma_memory_region>,
    			<&c71_1_memory_region>;
    &c71_2 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster5 &mbox_c71_2>;
    	memory-region = <&c71_2_dma_memory_region>,
    			<&c71_2_memory_region>;
    &c71_3 {
    	status = "okay";
    	mboxes = <&mailbox0_cluster5 &mbox_c71_3>;
    	memory-region = <&c71_3_dma_memory_region>,
    			<&c71_3_memory_region>;
    &dss {
    	status = "okay";
    	assigned-clocks = <&k3_clks 218 2>,
    			  <&k3_clks 218 5>,
    			  <&k3_clks 218 14>,
    			  <&k3_clks 218 18>;
    	assigned-clock-parents = <&k3_clks 218 3>,
    				 <&k3_clks 218 7>,
    				 <&k3_clks 218 16>,
    				 <&k3_clks 218 22>;
    &dss_ports {
    	#size-cells = <0>;
    	 /* DP */
    	port@0 {
    		reg = <0>;
    		dpi0_out: endpoint {
    			remote-endpoint = <&dp0_in>;
    	port@2 {
    		reg = <2>;
    		dpi2_out: endpoint {
    			remote-endpoint = <&dsi0_in>;
    	port@3 {
    		reg = <3>;
    		dpi3_out: endpoint {
    			remote-endpoint = <&dsi1_in>;
    &dphy_tx0 {
    	status = "okay";
    &dsi0_ports {
    	#size-cells = <0>;
    	port@0 {
    		reg = <0>;
    		dsi0_out: endpoint {
    			remote-endpoint = <&panel0_bridge_in>;
    	port@1 {
    		reg = <1>;
    		dsi0_in: endpoint {
    			remote-endpoint = <&dpi2_out>;
    &dphy_tx1 {
    	status = "okay";
    &dsi1_ports {
    	#size-cells = <0>;
    	port@0 {
    		reg = <0>;
    		dsi1_out: endpoint {
    			remote-endpoint = <&panel1_bridge_in>;
    	port@1 {
    		reg = <1>;
    		dsi1_in: endpoint {
    			remote-endpoint = <&dpi3_out>; // TODO not sure !!!
    &dsi0 {
    	status = "okay";
    	#size-cells = <0>;
    	dsi_bridge_0: bridge@0 {
    		compatible = "toshiba,tc358762";
    		reg = <0>;
    		ports {
    		#size-cells = <0>;
    			port@0 {
    				reg = <0>;
    				panel0_bridge_in: endpoint {
    					remote-endpoint = <&dsi0_out>;
    			port@1 {
    				reg = <1>;
    				panel0_bridge_out: endpoint {
    					remote-endpoint = <&max96789_in_0>;
    &dsi1 {
    	status = "okay";
    	#size-cells = <0>;
    	dsi_bridge_1: bridge@0 {
    		reg = <0>;
    		ports {
    		#size-cells = <0>;
    			port@0 {
    				reg = <0>;
    				panel1_bridge_in: endpoint {
    					remote-endpoint = <&dsi1_out>;
    			port@1 {
    				reg = <1>;
    				panel1_bridge_out: endpoint {
    					remote-endpoint = <&max96789_in_1>;
    &serdes_wiz4 {
    	status = "okay";
    &serdes4 {
    	status = "okay";
    	serdes4_dp_link: phy@0 {
    		reg = <0>;
    		cdns,num-lanes = <4>;
    		#phy-cells = <0>;
    		cdns,max-bit-rate = <2700>;
    		cdns,phy-type = <PHY_TYPE_DP>;
    		resets = <&serdes_wiz4 1>, <&serdes_wiz4 2>,
    			 <&serdes_wiz4 3>, <&serdes_wiz4 4>;
    &dp0_ports {
    	#size-cells = <0>;
    	port@0 {
    		reg = <0>;
    		dp0_in: endpoint {
    			remote-endpoint = <&dpi0_out>;
    	port@4 {
    		reg = <4>;
    		dp0_out: endpoint {
    			remote-endpoint = <&dp0_connector_in>;
    &mhdp {
    	status = "okay";
    	pinctrl-0 = <&dp0_pins_default>;
    	phys = <&serdes4_dp_link>;
    	phy-names = "dpphy";
    &k3_clks {
    	/* Confiure AUDIO_EXT_REFCLK2 pin as output */
    //	pinctrl-0 = <&audio_ext_refclk1_pins_default>;
    &mcasp0 {
    	status = "okay";
    	pinctrl-0 = <&mcasp0_pins_default>;
    	op-mode = <0>;          /* MCASP_IIS_MODE */
    	tdm-slots = <2>;
    	auxclk-fs-ratio = <256>;
    	serial-dir = <	/* 0: INACTIVE, 1: TX, 2: RX */   // first row 0 0 1 0
    		0 2 1 0
    		0 2 1 0
    		0 0 0 0
    		0 0 0 0
    	tx-num-evt = <0>;
    	rx-num-evt = <0>;
    &mcasp1 {
    	status = "okay";
    	pinctrl-0 = <&mcasp1_pins_default>;
    	tdm-slots = <2>;
    		1 0 0 0
    		1 0 0 0
    		0 0 0 0
    		0 0 0 0
    	tx-num-evt = <0>;
    	rx-num-evt = <0>;
    &mcasp3 {
    	status = "okay";
    	pinctrl-0 = <&mcasp3_pins_default>;
    	tdm-slots = <2>;
    		1 1 0 0
    		0 0 0 0
    		0 0 0 0
    		0 0 0 0
    	tx-num-evt = <0>;
    	rx-num-evt = <0>;
    Ajins
  • Hi Ajins,
    The scontrols for amixer come from the codec driver. For example, if you look within the pcm3168a driver (codec used in the k3-j784s4-evm.dts), you will see all of the settings that amixer lists:
    root@j784s4-evm:~# amixer -c0
    Simple mixer control 'codec-1 ADC Overflow Flag Polarity',0
      Capabilities: enum
      Items: 'Active High' 'Active Low'
      Item0: 'Active High'
    Simple mixer control 'codec-1 ADC Volume Control Type',0
      Capabilities: enum
      Items: 'Individual' 'Master + Individual'
      Item0: 'Individual'
    Simple mixer control 'codec-1 ADC Volume Rate Multiplier',0
      Capabilities: enum
      Items: '2048' '4096'
      Item0: '2048'
    Simple mixer control 'codec-1 ADC1',0
      Capabilities: cvolume
      Capture channels: Front Left - Front Right
      Limits: Capture 0 - 241
      Front Left: Capture 197 [82%] [-2.00dB]
      Front Right: Capture 197 [82%] [-2.00dB]
    Simple mixer control 'codec-1 ADC1 Connection Type',0
      Capabilities: enum
      Items: 'Differential' 'Single-Ended'
      Item0: 'Differential'
      Item1: 'Differential'
    Simple mixer control 'codec-1 ADC1 High-Pass Filter',0
      Capabilities: pswitch pswitch-joined
      Playback channels: Mono
      Mono: Playback [on]
    Simple mixer control 'codec-1 ADC1 Invert',0
      Playback channels: Front Left - Front Right
      Mono:
      Front Left: Playback [off]
      Front Right: Playback [off]
    Simple mixer control 'codec-1 ADC1 Mute',0
      Mono:
    Simple mixer control 'codec-1 ADC2',0
    Simple mixer control 'codec-1 ADC2 Connection Type',0
      Capabilities: enum
    Simple mixer control 'codec-1 ADC2 High-Pass Filter',0
      Mono: Playback [on]
    Simple mixer control 'codec-1 ADC2 Invert',0
      Mono:
    Simple mixer control 'codec-1 ADC2 Mute',0
      Mono:
    Simple mixer control 'codec-1 ADC3',0
    Simple mixer control 'codec-1 ADC3 Connection Type',0
      Capabilities: enum
    Simple mixer control 'codec-1 ADC3 High-Pass Filter',0
      Mono: Playback [on]
    Simple mixer control 'codec-1 ADC3 Invert',0
      Mono:
    Simple mixer control 'codec-1 ADC3 Mute',0
      Mono:
    Simple mixer control 'codec-1 DAC De-Emphasis',0
      Capabilities: enum
      Items: 'Disabled' '48khz' '44.1khz' '32khz'
      Item0: 'Disabled'
    Simple mixer control 'codec-1 DAC Power-Save',0
      Mono: Playback [on]
    Simple mixer control 'codec-1 DAC Volume Control Type',0
      Capabilities: enum
      Item0: 'Individual'
    Simple mixer control 'codec-1 DAC Volume Rate Multiplier',0
      Capabilities: enum
      Item0: '2048'
    Simple mixer control 'codec-1 DAC Zero Flag Function',0
      Capabilities: enum
      Items: 'DAC 1/2/3/4 AND' 'DAC 1/2/3/4 OR' 'DAC 1/2/3 AND' 'DAC 1/2/3 OR' 'DAC 4 AND' 'DAC 4 OR'
      Item0: 'DAC 1/2/3/4 AND'
    Simple mixer control 'codec-1 DAC Zero Flag Polarity',0
      Capabilities: enum
    Simple mixer control 'codec-1 DAC1',0
      Capabilities: pvolume
      Limits: Playback 0 - 201
      Mono:
      Front Left: Playback 201 [100%] [0.00dB]
      Front Right: Playback 201 [100%] [0.00dB]
    Simple mixer control 'codec-1 DAC1 Digital Filter roll-off',0
      Capabilities: enum
      Items: 'Sharp' 'Slow'
      Item0: 'Sharp'
    Simple mixer control 'codec-1 DAC1 Invert',0
      Mono:
    Simple mixer control 'codec-1 DAC2',0
      Mono:
    Simple mixer control 'codec-1 DAC2 Digital Filter roll-off',0
      Capabilities: enum
      Item0: 'Sharp'
    Simple mixer control 'codec-1 DAC2 Invert',0
      Mono:
    Simple mixer control 'codec-1 DAC3',0
      Mono:
    Simple mixer control 'codec-1 DAC3 Digital Filter roll-off',0
      Capabilities: enum
      Item0: 'Sharp'
    Simple mixer control 'codec-1 DAC3 Invert',0
      Mono:
    Simple mixer control 'codec-1 DAC4',0
      Mono:
    Simple mixer control 'codec-1 DAC4 Digital Filter roll-off',0
      Capabilities: enum
      Item0: 'Sharp'
    Simple mixer control 'codec-1 DAC4 Invert',0
      Mono:
    Simple mixer control 'codec-1 Master',0
      Capabilities: pvolume pvolume-joined cvolume cvolume-joined
      Capture channels: Mono
      Limits: Playback 0 - 201 Capture 0 - 241
      Mono: Playback 201 [100%] [0.00dB] Capture 197 [82%] [-2.00dB]
    The snd-soc-dummy codec isn't a real codec, and doesn't have any controls. Because of this, you can't set the volume in amixer.
    Jared
