Other Parts Discussed in Thread: AM62L
Hi Support,
While specifically evaluating the AM62L - we figure the AM623 docs are our best bet for determining DFS performance.
After 2 hours of pouring over the AM62 TRM / Datasheet and forum posts, I cannot figure out what TI-CPUFREQ actually changes.
I suspect the LPDDR4 speed will change?, and that the CPU clocks will change when the Linux Governor asks the cpufreq driver for a different CPU Speed.
For the CPU, from the TRM AM62 figure 6-40, I am assuming a new frequency will be called for then there will be a latency for PLL lock then some margin added. Is there other factors at play?
Can you walk me through the steps for cpufreq to make the change to a new processor operating speed?
The assigned focus customer is trying to ascertain risk of changing processor speeds.
They ask:
Let’s say we change the CPU frequency from ‘2X’ to ‘1X’. Is there some recalibration of the clocks that is automatically done in Linux for the different peripherals (AHB, APB, DDR ctlr, SPI, timers, etc.)? I am trying to assess any unintended consequences that may be seen on different modules and/or peripherals when we change the CPU frequency.
We confirmed with Mukul that all cores will operate at the same frequency, but I am assuming you can manually gate a core off if you want its power consumption to be at the lowest level?
Thanks!
Blake
