during debugging with ccs5 system analyzer I receive following assertion errors on the target:
[C66xx_6] ti.uia.runtime.ServiceMgr: line 87: assertion failure: A_invalidProcessCallbackFxn: Callback cannot be NULL
[C66xx_6] xdc.runtime.Error.raise: terminating execution
[C66xx_7] ti.uia.runtime.ServiceMgr: line 87: assertion failure: A_invalidProcessCallbackFxn: Callback cannot be NULL
[C66xx_7] xdc.runtime.Error.raise: terminating execution
[C66xx_0] ti.uia.runtime.ServiceMgr: line 87: assertion failure: A_invalidProcessCallbackFxn: Callback cannot be NULL
[C66xx_0] xdc.runtime.Error.raise: terminating execution
I run the MCSK image processing example on an EVM6678 Evaluation Board, with XDS560v2 STM jtag emulator.
I have selected UploadMode_JTAGRUNMODE.
The assertion failure does not happen immediately, it appear about 3 minutes or even later after starting System Analyzer.
The problem is not linked to a specific core, instead it happens in some random fashion on some of the cores, including core 0. Looks like some kind of buffer overflow.
Just another observation: It does no make a differenc if the SA Log is updating or is in pause mode.
Any suggestions ?
regards
Alois
Here is the XDC .cfg file of the master module:
* Specify all needed RTSC Moudles and configure them. *
var Memory = xdc.useModule('xdc.runtime.Memory');
var Log = xdc.useModule('xdc.runtime.Log');
var Error = xdc.useModule('xdc.runtime.Error');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Timestamp = xdc.useModule('xdc.runtime.Timestamp');
var Startup = xdc.useModule('xdc.runtime.Startup');
var System = xdc.useModule('xdc.runtime.System');
var SysStd = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
/* Load and configure SYSBIOS packages */
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Sem = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
var Ecm = xdc.useModule('ti.sysbios.family.c64p.EventCombiner');
var BiosCache = xdc.useModule('ti.sysbios.hal.Cache');
var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var Exc = xdc.useModule('ti.sysbios.family.c64p.Exception');
var Cache = xdc.useModule('ti.sysbios.family.c66.Cache');
BIOS.taskEnabled = true;
Task.common$.namedInstance = true;
* Enable Event Groups here and registering of ISR for specific GEM INTC is done
* using EventCombiner_dispatchPlug() and Hwi_eventMap() APIs
Ecm.eventGroupHwiNum[0] = 7;
Ecm.eventGroupHwiNum[1] = 8;
Ecm.eventGroupHwiNum[2] = 9;
Ecm.eventGroupHwiNum[3] = 10;
/* Create a Heap. */
var heapMemParams = new HeapMem.Params();
heapMemParams.size = 0x8000000;
heapMemParams.sectionName = "systemHeapMaster";
Program.global.heap0 = HeapMem.create(heapMemParams);
Memory.defaultHeapInstance = Program.global.heap0;
/* Load and configure NDK */
var Global = xdc.useModule('ti.ndk.config.Global');
** This allows the heart beat (poll function) to be created but does not generate the stack threads
** Look in the cdoc (help files) to see what CfgAddEntry items can be configured. We tell it NOT
** to create any stack threads (services) as we configure those ourselves in our Main Task
** thread.
Global.enableCodeGeneration = false;
/* Load the PDK packages */
var Csl = xdc.useModule('ti.csl.Settings');
var Pa = xdc.useModule('ti.drv.pa.Settings');
var Cppi = xdc.loadPackage('ti.drv.cppi');
var Qmss = xdc.loadPackage('ti.drv.qmss');
/* Load the Platform/NDK Transport packages */
var PlatformLib = xdc.loadPackage('ti.platform.evmc6678l');
var NdkTransport = xdc.loadPackage('ti.transport.ndk');
/* Load and configure the IPC packages */
var MessageQ = xdc.useModule('ti.sdo.ipc.MessageQ');
var Ipc = xdc.useModule('ti.sdo.ipc.Ipc');
var HeapBufMP = xdc.useModule('ti.sdo.ipc.heaps.HeapBufMP');
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
MultiProc.setConfig(null, ["CORE0", "CORE1", "CORE2", "CORE3", "CORE4", "CORE5", "CORE6", "CORE7"]);
/* Synchronize all processors (this will be done in Ipc_start) */
Ipc.procSync = Ipc.ProcSync_ALL;
/* Shared Memory base address and length */
var SHAREDMEM = 0x0c200000;
var SHAREDMEMSIZE = 0x00200000;
SharedRegion.setEntryMeta(0,
{ base: SHAREDMEM,
len: SHAREDMEMSIZE,
ownerProcId: 0,
isValid: true,
/* ================ Logger configuration ================ */
var LoggerCircBuf = xdc.useModule('ti.uia.runtime.LoggerCircBuf');
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Main = xdc.useModule('xdc.runtime.Main');
var Load = xdc.useModule('ti.sysbios.utils.Load');
Load.windowInMs = 50;
CpuTimestamp = xdc.useModule('ti.uia.family.c66.TimestampC66XLocal');
GlobalTimestamp = xdc.useModule('ti.uia.family.c66.TimestampC66XGlobal');
LogSync = xdc.useModule('ti.uia.runtime.LogSync');
LogSync.GlobalTimestampProxy = GlobalTimestamp;
LogSync.CpuTimestampProxy = CpuTimestamp;
CpuTimestamp.maxTimerClockFreq = {lo:1000000000,hi:0};
CpuTimestamp.maxBusClockFreq = {lo:1000000000,hi:0};
GlobalTimestamp.maxTimerClockFreq = {lo:250000000,hi:0};
GlobalTimestamp.maxBusClockFreq = {lo:1000000000,hi:0};
GlobalTimestamp.cpuCyclesPerTick = 4;
Exc.common$.logger = Main.common$.logger;
Exc.enablePrint = true;
var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
/* Increase the sysbios logger and turn Hwi and Swi logging off */
LoggingSetup.sysbiosLoggerSize = 32768;
LoggingSetup.mainLoggerSize = 8*1024;
LoggingSetup.loadLoggerSize = 32768;
LoggingSetup.loadLogging = true;
LoggingSetup.sysbiosTaskLogging = true;
LoggingSetup.sysbiosSwiLogging = false;
LoggingSetup.sysbiosHwiLogging = false;
//LoggingSetup.eventUploadMode = LoggingSetup.UploadMode_NONJTAGTRANSPORT;
LoggingSetup.eventUploadMode = LoggingSetup.UploadMode_JTAGRUNMODE; // C66xx JTAG
/* ================ UIA configuration ================ */
* This example is a multi-core example, so UIA's ServiceMgr
* must be configured to collect events from multiple cores.
var ServiceMgr = xdc.useModule('ti.uia.runtime.ServiceMgr');
ServiceMgr.topology = ServiceMgr.Topology_MULTICORE;
ServiceMgr.masterProcId = 0;
/* The application is using the UIA benchmark events. */
var UIABenchmark = xdc.useModule('ti.uia.events.UIABenchmark');
** Create a Heap.
Memory.defaultHeapSize = 0x10000;
Program.heap = 0x10000;
Program.sectMap[".vecs"] = {loadSegment: "MSMCSRAM_MASTER", loadAlign:1024};
Program.sectMap[".switch"] = {loadSegment: "MSMCSRAM_MASTER", loadAlign:8};
Program.sectMap[".cio"] = {loadSegment: "L2SRAM", loadAlign:8};
Program.sectMap[".args"] = {loadSegment: "L2SRAM", loadAlign:8};
Program.sectMap[".cppi"] = {loadSegment: "L2SRAM", loadAlign:16};
Program.sectMap[".qmss"] = {loadSegment: "L2SRAM", loadAlign:16};
Program.sectMap[".nimu_eth_ll2"] = {loadSegment: "L2SRAM", loadAlign:16};
Program.sectMap[".far:NDK_PACKETMEM"]= {loadSegment: "MSMCSRAM_MASTER", loadAlign: 128};
Program.sectMap[".far:NDK_OBJMEM"] = {loadSegment: "MSMCSRAM_MASTER", loadAlign: 16};
Program.sectMap[".far:WEBDATA"] = {loadSegment: "DDR3", loadAlign: 8};
Program.sectMap[".resmgr_memregion"] = {loadSegment: "L2SRAM", loadAlign:128};
Program.sectMap[".resmgr_handles"] = {loadSegment: "L2SRAM", loadAlign:16};
Program.sectMap[".resmgr_pa"] = {loadSegment: "L2SRAM", loadAlign:8};
Program.sectMap["systemHeapMaster"] = "DDR3";
Program.sectMap[".cinit"] = "MSMCSRAM_MASTER";
Program.sectMap[".const"] = "MSMCSRAM_MASTER";
Program.sectMap[".text"] = "MSMCSRAM_MASTER";
Program.sectMap[".far"] = "L2SRAM";
Program.sectMap[".bss"] = "L2SRAM";
Program.sectMap[".rodata"] = "L2SRAM";
Program.sectMap[".neardata"] = "L2SRAM";
Program.sectMap[".code"] = "L2SRAM";
Program.sectMap[".data"] = "L2SRAM";
Program.sectMap[".sysmem"] = "L2SRAM";
Program.sectMap[".defaultStackSection"] = "L2SRAM";
Program.sectMap[".stack"] = "L2SRAM";
Program.sectMap[".plt"] = "L2SRAM";
Program.sectMap["platform_lib"] = "L2SRAM";
/* Add init function */
Startup.firstFxns.$add('&EVM_init');
/* Create the stack Thread Task for our application. */
var tskMainThread = Task.create("&master_main");
tskMainThread.stackSize = 0x2000;
tskMainThread.priority = 0x5;
tskMainThread.instance.name = "master_main";
var tskSlaveThread = Task.create("&slave_main");
tskSlaveThread.stackSize = 0x2000;
tskSlaveThread.priority = 0x5;
tskSlaveThread.instance.name = "slave_main";
Load.hwiEnabled = false;
Load.swiEnabled = false;
Defaults.common$.diags_ENTRY = Diags.ALWAYS_ON;
Defaults.common$.diags_EXIT = Diags.ALWAYS_ON;
Defaults.common$.namedInstance = true;
