Other Parts Discussed in Thread: TDA4VM
We ported the TP2855 driver to the TDA4VM on SDK 10.0, but only the first camera was working.
We expected four sinks to be mapped from pad1 to pad4 on ticsi2rx.
To address this, we modified j721e-ticsi2rx.c and cdns-csi2rx.c by adjusting the routing and increasing the number of routes from 1 to 4, mapping each accordingly.
Although this approach worked, we believe it is not the correct solution. How can we enable virtual channel support without modifying these source files?
root@j721e-iec:~# media-ctl -p
Media controller API version 6.6.32
Media device information
driver j721e-csi2rx
model TI-CSI2RX
serial
bus info platform:4500000.ticsi2rx
hw revision 0x1
driver version 6.6.32
Device topology
- entity 1: 4500000.ticsi2rx (17 pads, 17 links, 1 route)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
[stream:0 fmt:UYVY8_1X16/1280x720 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
<- "cdns_csi2rx.4504000.csi-bridge":1 [ENABLED,IMMUTABLE]
pad1: Source
-> "4500000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
pad2: Source
-> "4500000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
pad3: Source
-> "4500000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
pad4: Source
-> "4500000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
pad5: Source
-> "4500000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE]
pad6: Source
-> "4500000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE]
pad7: Source
-> "4500000.ticsi2rx context 6":0 [ENABLED,IMMUTABLE]
pad8: Source
-> "4500000.ticsi2rx context 7":0 [ENABLED,IMMUTABLE]
pad9: Source
-> "4500000.ticsi2rx context 8":0 [ENABLED,IMMUTABLE]
pad10: Source
-> "4500000.ticsi2rx context 9":0 [ENABLED,IMMUTABLE]
pad11: Source
-> "4500000.ticsi2rx context 10":0 [ENABLED,IMMUTABLE]
pad12: Source
-> "4500000.ticsi2rx context 11":0 [ENABLED,IMMUTABLE]
pad13: Source
-> "4500000.ticsi2rx context 12":0 [ENABLED,IMMUTABLE]
pad14: Source
-> "4500000.ticsi2rx context 13":0 [ENABLED,IMMUTABLE]
pad15: Source
-> "4500000.ticsi2rx context 14":0 [ENABLED,IMMUTABLE]
pad16: Source
-> "4500000.ticsi2rx context 15":0 [ENABLED,IMMUTABLE]
- entity 19: cdns_csi2rx.4504000.csi-bridge (5 pads, 2 links, 1 route)
device node name /dev/v4l-subdev1
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
<- "tp2855_des 1-0044":4 [ENABLED,IMMUTABLE]
pad1: Source
-> "4500000.ticsi2rx":0 [ENABLED,IMMUTABLE]
pad2: Source
pad3: Source
pad4: Source
- entity 25: tp2855_des 1-0044 (5 pads, 5 links, 1 route)
device node name /dev/v4l-subdev2
routes:
0/0 -> 4/0 [ACTIVE]
pad0: Sink
<- "tp2855_ser 1-0045":1 [ENABLED,IMMUTABLE]
pad1: Sink
<- "tp2855_ser 1-0046":1 [ENABLED,IMMUTABLE]
pad2: Sink
<- "tp2855_ser 1-0047":1 [ENABLED,IMMUTABLE]
pad3: Sink
<- "tp2855_ser 1-0048":1 [ENABLED,IMMUTABLE]
pad4: Source
-> "cdns_csi2rx.4504000.csi-bridge":0 [ENABLED,IMMUTABLE]
- entity 33: tp2855_ser 1-0048 (2 pads, 2 links, 1 route)
device node name /dev/v4l-subdev3
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
<- "tp2855_sensor 9-0021":0 [ENABLED,IMMUTABLE]
pad1: Source
-> "tp2855_des 1-0044":3 [ENABLED,IMMUTABLE]
- entity 38: tp2855_sensor 9-0021 (1 pad, 1 link, 2 routes)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev4
routes:
0/0 -> 0/0 [ACTIVE]
0/0 -> 0/1 [ACTIVE]
pad0: Source
[stream:0 fmt:UYVY8_1X16/1280x720@1/30 field:none]
[stream:1 fmt:UYVY8_1X16/1280x720@1/30 field:none]
-> "tp2855_ser 1-0048":0 [ENABLED,IMMUTABLE]
- entity 42: tp2855_ser 1-0047 (2 pads, 2 links, 1 route)
device node name /dev/v4l-subdev5
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
<- "tp2855_sensor 8-0021":0 [ENABLED,IMMUTABLE]
pad1: Source
-> "tp2855_des 1-0044":2 [ENABLED,IMMUTABLE]
- entity 47: tp2855_sensor 8-0021 (1 pad, 1 link, 2 routes)
device node name /dev/v4l-subdev6
routes:
0/0 -> 0/0 [ACTIVE]
0/0 -> 0/1 [ACTIVE]
pad0: Source
-> "tp2855_ser 1-0047":0 [ENABLED,IMMUTABLE]
- entity 51: tp2855_ser 1-0046 (2 pads, 2 links, 1 route)
device node name /dev/v4l-subdev7
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
<- "tp2855_sensor 7-0021":0 [ENABLED,IMMUTABLE]
pad1: Source
-> "tp2855_des 1-0044":1 [ENABLED,IMMUTABLE]
- entity 56: tp2855_sensor 7-0021 (1 pad, 1 link, 2 routes)
device node name /dev/v4l-subdev8
routes:
0/0 -> 0/0 [ACTIVE]
0/0 -> 0/1 [ACTIVE]
pad0: Source
-> "tp2855_ser 1-0046":0 [ENABLED,IMMUTABLE]
- entity 60: tp2855_ser 1-0045 (2 pads, 2 links, 1 route)
device node name /dev/v4l-subdev9
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
<- "tp2855_sensor 6-0021":0 [ENABLED,IMMUTABLE]
pad1: Source
-> "tp2855_des 1-0044":0 [ENABLED,IMMUTABLE]
- entity 65: tp2855_sensor 6-0021 (1 pad, 1 link, 2 routes)
device node name /dev/v4l-subdev10
routes:
0/0 -> 0/0 [ACTIVE]
0/0 -> 0/1 [ACTIVE]
pad0: Source
-> "tp2855_ser 1-0045":0 [ENABLED,IMMUTABLE]
- entity 71: 4500000.ticsi2rx context 0 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video2
pad0: Sink
<- "4500000.ticsi2rx":1 [ENABLED,IMMUTABLE]
- entity 77: 4500000.ticsi2rx context 1 (1 pad, 1 link)
device node name /dev/video3
pad0: Sink
<- "4500000.ticsi2rx":2 [ENABLED,IMMUTABLE]
- entity 83: 4500000.ticsi2rx context 2 (1 pad, 1 link)
device node name /dev/video4
pad0: Sink
<- "4500000.ticsi2rx":3 [ENABLED,IMMUTABLE]
- entity 89: 4500000.ticsi2rx context 3 (1 pad, 1 link)
device node name /dev/video5
pad0: Sink
<- "4500000.ticsi2rx":4 [ENABLED,IMMUTABLE]
- entity 95: 4500000.ticsi2rx context 4 (1 pad, 1 link)
device node name /dev/video6
pad0: Sink
<- "4500000.ticsi2rx":5 [ENABLED,IMMUTABLE]
- entity 101: 4500000.ticsi2rx context 5 (1 pad, 1 link)
device node name /dev/video7
pad0: Sink
<- "4500000.ticsi2rx":6 [ENABLED,IMMUTABLE]
- entity 107: 4500000.ticsi2rx context 6 (1 pad, 1 link)
device node name /dev/video8
pad0: Sink
<- "4500000.ticsi2rx":7 [ENABLED,IMMUTABLE]
- entity 113: 4500000.ticsi2rx context 7 (1 pad, 1 link)
device node name /dev/video9
pad0: Sink
<- "4500000.ticsi2rx":8 [ENABLED,IMMUTABLE]
- entity 119: 4500000.ticsi2rx context 8 (1 pad, 1 link)
device node name /dev/video10
pad0: Sink
<- "4500000.ticsi2rx":9 [ENABLED,IMMUTABLE]
- entity 125: 4500000.ticsi2rx context 9 (1 pad, 1 link)
device node name /dev/video11
pad0: Sink
<- "4500000.ticsi2rx":10 [ENABLED,IMMUTABLE]
- entity 131: 4500000.ticsi2rx context 10 (1 pad, 1 link)
device node name /dev/video12
pad0: Sink
<- "4500000.ticsi2rx":11 [ENABLED,IMMUTABLE]
- entity 137: 4500000.ticsi2rx context 11 (1 pad, 1 link)
device node name /dev/video13
pad0: Sink
<- "4500000.ticsi2rx":12 [ENABLED,IMMUTABLE]
- entity 143: 4500000.ticsi2rx context 12 (1 pad, 1 link)
device node name /dev/video14
pad0: Sink
<- "4500000.ticsi2rx":13 [ENABLED,IMMUTABLE]
- entity 149: 4500000.ticsi2rx context 13 (1 pad, 1 link)
device node name /dev/video15
pad0: Sink
<- "4500000.ticsi2rx":14 [ENABLED,IMMUTABLE]
- entity 155: 4500000.ticsi2rx context 14 (1 pad, 1 link)
device node name /dev/video16
pad0: Sink
<- "4500000.ticsi2rx":15 [ENABLED,IMMUTABLE]
- entity 161: 4500000.ticsi2rx context 15 (1 pad, 1 link)
device node name /dev/video17
pad0: Sink
<- "4500000.ticsi2rx":16 [ENABLED,IMMUTABLE]
