TDA4VM-Q1: CPSW9g virtual port issue
Part Number: TDA4VM-Q1
Dear Sudheer,
RTOS SDK Version:10.01
As we discussed in other thread earlier,Our current requirement is to use ethfw on MCU20 and then implement inter ping within the local area network on Linux through virtual mapping.
The current problem is that Linux does not map a virtual network card, so we cannot ping external network devices through the network card in Linux.
Can you help me see what the problem is?
root@j721e-evm:~#
root@j721e-evm:~#
root@j721e-evm:~# /opt/vx_app_arm_remote_log.out
[MCU2_0]     10.279336 s: CIO: Init ... Done !!!
[MCU2_0]     10.279412 s: ### CPU Frequency = 1000000000 Hz
[MCU2_0]     10.279448 s: CPU is running FreeRTOS
[MCU2_0]     10.279471 s: APP: Init ... !!!
[MCU2_0]     10.279490 s: SCICLIENT: Init ... !!!
[MCU2_0]     10.279697 s: SCICLIENT: DMSC FW version [10.1.6--v10.01.06 (Fiery Fox)]
[MCU2_0]     10.279741 s: SCICLIENT: DMSC FW revision 0xa
[MCU2_0]     10.279768 s: SCICLIENT: DMSC FW ABI revision 4.0
[MCU2_0]     10.279794 s: SCICLIENT: Init ... Done !!!
[MCU2_0]     10.279818 s: UDMA: Init ... !!!
[MCU2_0]     10.280916 s: UDMA: Init ... Done !!!
[MCU2_0]     10.280981 s: MEM: Init ... !!!
[MCU2_0]     10.281021 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ f1200000 of size 2097152 bytes !!!
[MCU2_0]     10.281082 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
[MCU2_0]     10.281142 s: MEM: Created heap (DDR_CACHE_WT_MEM, id=7, flags=0x00000000) @ f1400000 of size 1048576 bytes !!!
[MCU2_0]     10.281192 s: MEM: Init ... Done !!!
[MCU2_0]     10.281213 s: ETHFW: Init ... !!!
[MCU2_0]     10.282201 s: ETHFW: Warning: Using 6 random MAC address(es)
[MCU2_0]     10.282471 s: EnetMcm: CPSW_9G on MAIN NAVSS
[MCU2_0]     10.291426 s: Mdio_open: MDIO manual mode enabled
[MCU2_0]     10.291492 s:
[MCU2_0]     10.293648 s: PHY 0 is alive
[MCU2_0]     10.294345 s: PHY 4 is alive
[MCU2_0]     10.299173 s: EnetPhy_bindDriver: PHY 4: OUI:006037 Model:10 Ver:02 <-> 'tja1101' : OK
[MCU2_0]     10.299228 s:
[MCU2_0]     10.299469 s: ETHFW: Shared multicasts:
[MCU2_0]     10.299536 s: ETHFW:   01:00:5e:00:00:01
[MCU2_0]     10.299572 s: ETHFW:   01:00:5e:00:00:fb
[MCU2_0]     10.299604 s: ETHFW:   01:00:5e:00:00:fc
[MCU2_0]     10.299634 s: ETHFW:   33:33:00:00:00:01
[MCU2_0]     10.299664 s: ETHFW:   33:33:ff:1d:92:c2
[MCU2_0]     10.299694 s: ETHFW:   01:80:c2:00:00:00
[MCU2_0]     10.299723 s: ETHFW:   01:80:c2:00:00:03
[MCU2_0]     10.299748 s: ETHFW: Reserved multicasts:
[MCU2_0]     10.299779 s: ETHFW:   01:80:c2:00:00:0e
[MCU2_0]     10.299808 s: ETHFW:   01:1b:19:00:00:00
[MCU2_0]     10.299856 s: ETHFW: CPSW recovery is not enabled
[MCU2_0]     10.301406 s: ETHFW: VLAN 1024 member=0x1ed virtMember=0x7 regMcastFlood=0x1ed unregMcastFlood=0x1ed untag=0x0
[MCU2_0]     10.301975 s: ETHFW: 1 VLAN entries added in ALE table
[MCU2_0]     10.302224 s:
[MCU2_0] ETHFW Version   : 0.05.00
[MCU2_0]     10.302282 s: ETHFW Build Date: Mar  4, 2025
[MCU2_0]     10.302311 s: ETHFW Build Time: 10:24:25
[MCU2_0]     10.302334 s: ETHFW Commit SHA: 303d812f
[MCU2_0]     10.302399 s: ETHFW: Init ... DONE !!!
[MCU2_0]     10.302430 s: IPC: Init ... !!!
[MCU2_0]     10.302481 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_0]     10.302524 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_0]     26.033661 s: IPC: HLOS is ready !!!
[MCU2_0]     26.038264 s: IPC: Init ... Done !!!
[MCU2_0]     26.038337 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_0]     26.071530 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_0]     26.071585 s: REMOTE_SERVICE: Init ... !!!
[MCU2_0]     26.072031 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_0]     26.072104 s: FVID2: Init ... !!!
[MCU2_0]     26.072239 s: FVID2: Init ... Done !!!
[MCU2_0]     26.072287 s: DSS: Init ... !!!
[MCU2_0]     26.072309 s: DSS: Display type is eDP !!!
[MCU2_0]     26.072333 s: DSS: M2M Path is enabled !!!
[MCU2_0]     26.072357 s: DSS: SoC init ... !!!
[MCU2_0]     26.072378 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
[MCU2_0]     26.072579 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.072615 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2
[MCU2_0]     26.072804 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.072841 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2
[MCU2_0]     26.073021 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.073059 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11
[MCU2_0]     26.073307 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0]     26.073345 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18
[MCU2_0]     26.073549 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0]     26.073580 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2
[MCU2_0]     26.073748 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0]     26.073799 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000
[MCU2_0]     26.075064 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
[MCU2_0]     26.075096 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0
[MCU2_0]     26.075632 s: SCICLIENT: Sciclient_pmModuleClkRequest success
[MCU2_0]     26.075667 s: DSS: SoC init ... Done !!!
[MCU2_0]     26.075692 s: DSS: Board init ... !!!
[MCU2_0]     26.075713 s: DSS: Board init ... Done !!!
[MCU2_0]     26.093673 s: DSS: Init ... Done !!!
[MCU2_0]     26.093743 s: VHWA: VPAC Init ... !!!
[MCU2_0]     26.093774 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2
[MCU2_0]     26.093975 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.094011 s: VHWA: LDC Init ... !!!
[MCU2_0]     26.097009 s: VHWA: LDC Init ... Done !!!
[MCU2_0]     26.097070 s: VHWA: MSC Init ... !!!
[MCU2_0]     26.106818 s: VHWA: MSC Init ... Done !!!
[MCU2_0]     26.106883 s: VHWA: NF Init ... !!!
[MCU2_0]     26.108430 s: VHWA: NF Init ... Done !!!
[MCU2_0]     26.108488 s: VHWA: VISS Init ... !!!
[MCU2_0]     26.118107 s: VHWA: VISS Init ... Done !!!
[MCU2_0]     26.118179 s: VHWA: VPAC Init ... Done !!!
[MCU2_0]     26.118227 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR
[MCU2_0]     26.118268 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING
[MCU2_0]     26.118300 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO
[MCU2_0]     26.119578 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_sink on target MCU2-0
[MCU2_0]     26.119690 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_source on target MCU2-0
[MCU2_0]     26.119768 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_sink2 on target MCU2-0
[MCU2_0]     26.119843 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_source2 on target MCU2-0
[MCU2_0]     26.119917 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_intermediate on target MCU2-0
[MCU2_0]     26.119989 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_intermediate_2 on target MCU2-0
[MCU2_0]     26.120060 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_source_error on target MCU2-0
[MCU2_0]     26.120147 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_source_obj_array on target MCU2-0
[MCU2_0]     26.120224 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_sink_obj_array on target MCU2-0
[MCU2_0]     26.120295 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_intermediate on target MCU2-0
[MCU2_0]     26.120367 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_source on target MCU2-0
[MCU2_0]     26.120438 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_sink on target MCU2-0
[MCU2_0]     26.120510 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.test_target on target MCU2-0
[MCU2_0]     26.120581 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.image_intermediate on target MCU2-0
[MCU2_0]     26.120655 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.cmd_timeout_test on target MCU2-0
[MCU2_0]     26.120724 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.tiovx_overhead on target MCU2-0
[MCU2_0]     26.120932 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target MCU2-0
[MCU2_0]     26.121099 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target VPAC_NF
[MCU2_0]     26.121278 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target VPAC_LDC1
[MCU2_0]     26.121433 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target VPAC_MSC1
[MCU2_0]     26.121583 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target VPAC_MSC2
[MCU2_0]     26.121817 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target VPAC_VISS1
[MCU2_0]     26.122024 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target CAPTURE1
[MCU2_0]     26.122230 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target CAPTURE2
[MCU2_0]     26.122430 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target CAPTURE3
[MCU2_0]     26.122634 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target CAPTURE4
[MCU2_0]     26.122831 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target CAPTURE5
[MCU2_0]     26.123031 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target CAPTURE6
[MCU2_0]     26.123251 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target CAPTURE7
[MCU2_0]     26.123453 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target CAPTURE8
[MCU2_0]     26.123656 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DISPLAY1
[MCU2_0]     26.123857 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DISPLAY2
[MCU2_0]     26.124031 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target CSITX
[MCU2_0]     26.124217 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSS_M2M1
[MCU2_0]     26.124392 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSS_M2M2
[MCU2_0]     26.124557 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSS_M2M3
[MCU2_0]     26.124715 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSS_M2M4
[MCU2_0]     26.124764 s:  VX_ZONE_INFO: [tivxInitLocal:126] Initialization Done !!!
[MCU2_0]     26.124802 s:  VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO
[MCU2_0]     26.124829 s: APP: OpenVX Target kernel init ... !!!
[MCU2_0]     26.140871 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_0]     26.140928 s: CSI2RX: Init ... !!!
[MCU2_0]     26.140955 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
[MCU2_0]     26.141070 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.141105 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2
[MCU2_0]     26.141247 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.141279 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2
[MCU2_0]     26.141397 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.141426 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2
[MCU2_0]     26.141516 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.141544 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2
[MCU2_0]     26.141626 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.141833 s: CSI2RX: Init ... Done !!!
[MCU2_0]     26.141873 s: CSI2TX: Init ... !!!
[MCU2_0]     26.141898 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
[MCU2_0]     26.141980 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.142010 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2
[MCU2_0]     26.142128 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.142158 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2
[MCU2_0]     26.142258 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]     26.142338 s: CSI2TX: Init ... Done !!!
[MCU2_0]     26.142367 s: ISS: Init ... !!!
[MCU2_0]     26.142404 s: IssSensor_Init ... Done !!!
[MCU2_0]     26.142476 s: IttRemoteServer_Init ... Done !!!
[MCU2_0]     26.142502 s: ISS: Init ... Done !!!
[MCU2_0]     26.142527 s: VISS REMOTE SERVICE: Init ... !!!
[MCU2_0]     26.142585 s: VISS REMOTE SERVICE: Init ... Done !!!
[MCU2_0]     26.142614 s: UDMA Copy: Init ... !!!
[MCU2_0]     26.144275 s: UDMA Copy: Init ... Done !!!
[MCU2_0]     26.144343 s: APP: Init ... Done !!!
[MCU2_0]     26.144373 s: APP: Run ... !!!
[MCU2_0]     26.144397 s: IPC: Starting echo test ...
[MCU2_0]     26.144686 s: APP: Run ... Done !!!
[MCU2_0]     26.144721 s: appMAX9295Config I2C Instance = 1
[MCU2_0]     26.144916 s: @0x42 write 0x0001 for value 0x14, readback: 0x05, status = 0
[MCU2_0]     26.149288 s: @0x42 read 0x0001 -> 0x14, status = 0
[MCU2_0]     26.149468 s: @0x42 write 0x0331 for value 0x33, readback: 0x14, status = 0
[MCU2_0]     26.154283 s: @0x42 read 0x0331 -> 0x33, status = 0
[MCU2_0]     26.154460 s: @0x42 write 0x0318 for value 0x64, readback: 0x33, status = 0
[MCU2_0]     26.170284 s: @0x42 read 0x0318 -> 0x64, status = 0
[MCU2_0]     26.170350 s: max9295 init status is [0]
[MCU2_0]     26.173246 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[.] C66X_2[P] C7X_1[.]
[MCU2_0]     26.173348 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_0]     26.173428 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_0]     26.173499 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_0]     26.174327 s: Starting lwIP, local interface IP is dhcp-enabled
[MCU2_0]     26.181267 s: ETHFW: Host MAC address: 70:5a:95:d9:f8:c2
[MCU2_0]     26.184505 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully
[MCU2_0]     26.191395 s: [LWIPIF_LWIP_IC] Interface started successfully
[MCU2_0]     26.191469 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS
[MCU2_0]     26.198101 s: [LWIPIF_LWIP_IC] Interface started successfully
[MCU2_0]     26.198270 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS
[MCU2_0]     26.198366 s: Added interface 'br3', IP is 0.0.0.0
[MCU2_1]     10.366217 s: CIO: Init ... Done !!!
[MCU2_1]     10.366292 s: ### CPU Frequency = 1000000000 Hz
[MCU2_1]     10.366330 s: CPU is running FreeRTOS
[MCU2_1]     10.366351 s: APP: Init ... !!!
[MCU2_1]     10.366370 s: SCICLIENT: Init ... !!!
[MCU2_1]     10.366574 s: SCICLIENT: DMSC FW version [10.1.6--v10.01.06 (Fiery Fox)]
[MCU2_1]     10.366616 s: SCICLIENT: DMSC FW revision 0xa
[MCU2_1]     10.366645 s: SCICLIENT: DMSC FW ABI revision 4.0
[MCU2_1]     10.366670 s: SCICLIENT: Init ... Done !!!
[MCU2_1]     10.366692 s: UDMA: Init ... !!!
[MCU2_1]     10.367904 s: UDMA: Init ... Done !!!
[MCU2_1]     10.367970 s: MEM: Init ... !!!
[MCU2_1]     10.368008 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!!
[MCU2_1]     10.368080 s: MEM: Init ... Done !!!
[MCU2_1]     10.368103 s: IPC: Init ... !!!
[MCU2_1]     10.368149 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_1]     10.368190 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_1]     26.066830 s: IPC: HLOS is ready !!!
[MCU2_1]     26.071415 s: IPC: Init ... Done !!!
[MCU2_1]     26.071483 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_1]     26.071529 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_1]     26.071562 s: REMOTE_SERVICE: Init ... !!!
[MCU2_1]     26.072037 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_1]     26.072122 s: FVID2: Init ... !!!
[MCU2_1]     26.072234 s: FVID2: Init ... Done !!!
[MCU2_1]     26.072273 s: VHWA: DMPAC: Init ... !!!
[MCU2_1]     26.072298 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2
[MCU2_1]     26.072476 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1]     26.072517 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2
[MCU2_1]     26.072645 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1]     26.072678 s: VHWA: DOF Init ... !!!
[MCU2_1]     26.082140 s: VHWA: DOF Init ... Done !!!
[MCU2_1]     26.082207 s: VHWA: SDE Init ... !!!
[MCU2_1]     26.084494 s: VHWA: SDE Init ... Done !!!
[MCU2_1]     26.084552 s: VHWA: DMPAC: Init ... Done !!!
[MCU2_1]     26.084598 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR
[MCU2_1]     26.084636 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING
[MCU2_1]     26.084666 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO
[MCU2_1]     26.085973 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_sink on target MCU2-1
[MCU2_1]     26.086110 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_source on target MCU2-1
[MCU2_1]     26.086193 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_sink2 on target MCU2-1
[MCU2_1]     26.086267 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_source2 on target MCU2-1
[MCU2_1]     26.086340 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_intermediate on target MCU2-1
[MCU2_1]     26.086414 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_intermediate_2 on target MCU2-1
[MCU2_1]     26.086492 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_source_error on target MCU2-1
[MCU2_1]     26.086569 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_source_obj_array on target MCU2-1
[MCU2_1]     26.086644 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_sink_obj_array on target MCU2-1
[MCU2_1]     26.086719 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_intermediate on target MCU2-1
[MCU2_1]     26.086792 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_source on target MCU2-1
[MCU2_1]     26.086864 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_sink on target MCU2-1
[MCU2_1]     26.086939 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.test_target on target MCU2-1
[MCU2_1]     26.087007 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.image_intermediate on target MCU2-1
[MCU2_1]     26.087098 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.cmd_timeout_test on target MCU2-1
[MCU2_1]     26.087175 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.tiovx_overhead on target MCU2-1
[MCU2_1]     26.087391 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target MCU2-1
[MCU2_1]     26.087558 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DMPAC_SDE
[MCU2_1]     26.087719 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DMPAC_DOF
[MCU2_1]     26.087770 s:  VX_ZONE_INFO: [tivxInitLocal:126] Initialization Done !!!
[MCU2_1]     26.087807 s:  VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO
[MCU2_1]     26.087835 s: APP: OpenVX Target kernel init ... !!!
[MCU2_1]     26.088137 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_1]     26.088181 s: UDMA Copy: Init ... !!!
[MCU2_1]     26.089743 s: UDMA Copy: Init ... Done !!!
[MCU2_1]     26.089808 s: APP: Init ... Done !!!
[MCU2_1]     26.089834 s: APP: Run ... !!!
[MCU2_1]     26.089855 s: IPC: Starting echo test ...
[MCU2_1]     26.090109 s: APP: Run ... Done !!!
[MCU2_1]     26.091142 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_1]     26.091232 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_1]     26.091309 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_1]     26.173072 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
[C6x_1 ]     10.626961 s: CIO: Init ... Done !!!
[C6x_1 ]     10.626987 s: ### CPU Frequency = 1350000000 Hz
[C6x_1 ]     10.626997 s: CPU is running FreeRTOS
[C6x_1 ]     10.627006 s: APP: Init ... !!!
[C6x_1 ]     10.627014 s: SCICLIENT: Init ... !!!
[C6x_1 ]     10.627193 s: SCICLIENT: DMSC FW version [10.1.6--v10.01.06 (Fiery Fox)]
[C6x_1 ]     10.627205 s: SCICLIENT: DMSC FW revision 0xa
[C6x_1 ]     10.627215 s: SCICLIENT: DMSC FW ABI revision 4.0
[C6x_1 ]     10.627225 s: SCICLIENT: Init ... Done !!!
[C6x_1 ]     10.627234 s: UDMA: Init ... !!!
[C6x_1 ]     10.628524 s: UDMA: Init ... Done !!!
[C6x_1 ]     10.628543 s: MEM: Init ... !!!
[C6x_1 ]     10.628557 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!!
[C6x_1 ]     10.628576 s: MEM: Init ... Done !!!
[C6x_1 ]     10.628585 s: IPC: Init ... !!!
[C6x_1 ]     10.628606 s: IPC: 6 CPUs participating in IPC !!!
[C6x_1 ]     10.628622 s: IPC: Waiting for HLOS to be ready ... !!!
[C6x_1 ]     25.449762 s: IPC: HLOS is ready !!!
[C6x_1 ]     25.453432 s: IPC: Init ... Done !!!
[C6x_1 ]     25.453465 s: APP: Syncing with 5 CPUs ... !!!
[C6x_1 ]     26.071528 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_1 ]     26.071541 s: REMOTE_SERVICE: Init ... !!!
[C6x_1 ]     26.071976 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_1 ]     26.072016 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR
[C6x_1 ]     26.072033 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING
[C6x_1 ]     26.072046 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO
[C6x_1 ]     26.072669 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel vx_tutorial_graph.phase_rgb on target DSP-1
[C6x_1 ]     26.072707 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_sink on target DSP-1
[C6x_1 ]     26.072738 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_source on target DSP-1
[C6x_1 ]     26.072774 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_sink2 on target DSP-1
[C6x_1 ]     26.072806 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_source2 on target DSP-1
[C6x_1 ]     26.072852 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_intermediate on target DSP-1
[C6x_1 ]     26.072886 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_intermediate_2 on target DSP-1
[C6x_1 ]     26.072924 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_source_error on target DSP-1
[C6x_1 ]     26.072958 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_source_obj_array on target DSP-1
[C6x_1 ]     26.072995 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_sink_obj_array on target DSP-1
[C6x_1 ]     26.073027 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_intermediate on target DSP-1
[C6x_1 ]     26.073064 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_source on target DSP-1
[C6x_1 ]     26.073096 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_sink on target DSP-1
[C6x_1 ]     26.073131 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.test_target on target DSP-1
[C6x_1 ]     26.073163 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.image_intermediate on target DSP-1
[C6x_1 ]     26.073195 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.test_target on target DSP-1
[C6x_1 ]     26.073228 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.tiovx_overhead on target DSP-1
[C6x_1 ]     26.073480 s:  VX_ZONE_INFO: [tivxInitLocal:126] Initialization Done !!!
[C6x_1 ]     26.073501 s:  VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO
[C6x_1 ]     26.073515 s: APP: OpenVX Target kernel init ... !!!
[C6x_1 ]     26.073917 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_1 ]     26.073942 s: UDMA Copy: Init ... !!!
[C6x_1 ]     26.078374 s: UDMA Copy: Init ... Done !!!
[C6x_1 ]     26.078393 s: APP: Init ... Done !!!
[C6x_1 ]     26.078402 s: APP: Run ... !!!
[C6x_1 ]     26.078411 s: IPC: Starting echo test ...
[C6x_1 ]     26.078935 s: APP: Run ... Done !!!
[C6x_1 ]     26.079337 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[.] C7X_1[P]
[C6x_1 ]     26.079514 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_1 ]     26.090895 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_1 ]     26.172931 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_2 ]     10.817313 s: CIO: Init ... Done !!!
[C6x_2 ]     10.817341 s: ### CPU Frequency = 1350000000 Hz
[C6x_2 ]     10.817352 s: CPU is running FreeRTOS
[C6x_2 ]     10.817361 s: APP: Init ... !!!
[C6x_2 ]     10.817370 s: SCICLIENT: Init ... !!!
[C6x_2 ]     10.817543 s: SCICLIENT: DMSC FW version [10.1.6--v10.01.06 (Fiery Fox)]
[C6x_2 ]     10.817557 s: SCICLIENT: DMSC FW revision 0xa
[C6x_2 ]     10.817567 s: SCICLIENT: DMSC FW ABI revision 4.0
[C6x_2 ]     10.817578 s: SCICLIENT: Init ... Done !!!
[C6x_2 ]     10.817588 s: UDMA: Init ... !!!
[C6x_2 ]     10.818887 s: UDMA: Init ... Done !!!
[C6x_2 ]     10.818908 s: MEM: Init ... !!!
[C6x_2 ]     10.818922 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!!
[C6x_2 ]     10.818942 s: MEM: Init ... Done !!!
[C6x_2 ]     10.818952 s: IPC: Init ... !!!
[C6x_2 ]     10.818975 s: IPC: 6 CPUs participating in IPC !!!
[C6x_2 ]     10.818992 s: IPC: Waiting for HLOS to be ready ... !!!
[C6x_2 ]     25.552195 s: IPC: HLOS is ready !!!
[C6x_2 ]     25.555637 s: IPC: Init ... Done !!!
[C6x_2 ]     25.555666 s: APP: Syncing with 5 CPUs ... !!!
[C6x_2 ]     26.071528 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_2 ]     26.071542 s: REMOTE_SERVICE: Init ... !!!
[C6x_2 ]     26.071994 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_2 ]     26.072033 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR
[C6x_2 ]     26.072048 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING
[C6x_2 ]     26.072061 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO
[C6x_2 ]     26.072693 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel vx_tutorial_graph.phase_rgb on target DSP-2
[C6x_2 ]     26.072733 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_sink on target DSP-2
[C6x_2 ]     26.072770 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_source on target DSP-2
[C6x_2 ]     26.072802 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_sink2 on target DSP-2
[C6x_2 ]     26.072837 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_source2 on target DSP-2
[C6x_2 ]     26.072869 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_intermediate on target DSP-2
[C6x_2 ]     26.072901 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_intermediate_2 on target DSP-2
[C6x_2 ]     26.072936 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_source_error on target DSP-2
[C6x_2 ]     26.072968 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_source_obj_array on target DSP-2
[C6x_2 ]     26.073004 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_sink_obj_array on target DSP-2
[C6x_2 ]     26.073038 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_intermediate on target DSP-2
[C6x_2 ]     26.073074 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_source on target DSP-2
[C6x_2 ]     26.073106 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_sink on target DSP-2
[C6x_2 ]     26.073141 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.test_target on target DSP-2
[C6x_2 ]     26.073172 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.image_intermediate on target DSP-2
[C6x_2 ]     26.073210 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.test_target on target DSP-2
[C6x_2 ]     26.073243 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.tiovx_overhead on target DSP-2
[C6x_2 ]     26.073501 s:  VX_ZONE_INFO: [tivxInitLocal:126] Initialization Done !!!
[C6x_2 ]     26.073522 s:  VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO
[C6x_2 ]     26.073534 s: APP: OpenVX Target kernel init ... !!!
[C6x_2 ]     26.073926 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_2 ]     26.073951 s: UDMA Copy: Init ... !!!
[C6x_2 ]     26.078497 s: UDMA Copy: Init ... Done !!!
[C6x_2 ]     26.078516 s: APP: Init ... Done !!!
[C6x_2 ]     26.078525 s: APP: Run ... !!!
[C6x_2 ]     26.078535 s: IPC: Starting echo test ...
[C6x_2 ]     26.079137 s: APP: Run ... Done !!!
[C6x_2 ]     26.079513 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[.] C66X_2[s] C7X_1[P]
[C6x_2 ]     26.079550 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P]
[C6x_2 ]     26.090921 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
[C6x_2 ]     26.172949 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
[C7x_1 ]     11.496742 s: CIO: Init ... Done !!!
[C7x_1 ]     11.496757 s: ### CPU Frequency = 1000000000 Hz
[C7x_1 ]     11.496768 s: CPU is running FreeRTOS
[C7x_1 ]     11.496777 s: APP: Init ... !!!
[C7x_1 ]     11.496785 s: SCICLIENT: Init ... !!!
[C7x_1 ]     11.496966 s: SCICLIENT: DMSC FW version [10.1.6--v10.01.06 (Fiery Fox)]
[C7x_1 ]     11.496981 s: SCICLIENT: DMSC FW revision 0xa
[C7x_1 ]     11.496992 s: SCICLIENT: DMSC FW ABI revision 4.0
[C7x_1 ]     11.497003 s: SCICLIENT: Init ... Done !!!
[C7x_1 ]     11.497012 s: UDMA: Init ... !!!
[C7x_1 ]     11.498016 s: UDMA: Init ... Done !!!
[C7x_1 ]     11.498029 s: MEM: Init ... !!!
[C7x_1 ]     11.498041 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!!
[C7x_1 ]     11.498063 s: MEM: Init ... Done !!!
[C7x_1 ]     11.498073 s: IPC: Init ... !!!
[C7x_1 ]     11.498088 s: IPC: 6 CPUs participating in IPC !!!
[C7x_1 ]     11.498102 s: IPC: Waiting for HLOS to be ready ... !!!
[C7x_1 ]     25.675681 s: IPC: HLOS is ready !!!
[C7x_1 ]     25.677559 s: IPC: Init ... Done !!!
[C7x_1 ]     25.677574 s: APP: Syncing with 5 CPUs ... !!!
[C7x_1 ]     26.071530 s: APP: Syncing with 5 CPUs ... Done !!!
[C7x_1 ]     26.071548 s: REMOTE_SERVICE: Init ... !!!
[C7x_1 ]     26.071703 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_1 ]     26.071725 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_ERROR
[C7x_1 ]     26.071741 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_WARNING
[C7x_1 ]     26.071756 s:  VX_ZONE_INFO: Globally Enabled VX_ZONE_INFO
[C7x_1 ]     26.071946 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_sink on target DSP_C7-1
[C7x_1 ]     26.072005 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_source on target DSP_C7-1
[C7x_1 ]     26.072043 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_sink2 on target DSP_C7-1
[C7x_1 ]     26.072080 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_source2 on target DSP_C7-1
[C7x_1 ]     26.072118 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.scalar_intermediate on target DSP_C7-1
[C7x_1 ]     26.072158 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_intermediate_2 on target DSP_C7-1
[C7x_1 ]     26.072198 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_source_error on target DSP_C7-1
[C7x_1 ]     26.072237 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_source_obj_array on target DSP_C7-1
[C7x_1 ]     26.072275 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.scalar_sink_obj_array on target DSP_C7-1
[C7x_1 ]     26.072313 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_intermediate on target DSP_C7-1
[C7x_1 ]     26.072350 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_source on target DSP_C7-1
[C7x_1 ]     26.072387 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.pyramid_sink on target DSP_C7-1
[C7x_1 ]     26.072423 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.test_target on target DSP_C7-1
[C7x_1 ]     26.072459 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.capture.image_intermediate on target DSP_C7-1
[C7x_1 ]     26.072496 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.test_target on target DSP_C7-1
[C7x_1 ]     26.072533 s:  VX_ZONE_INFO: [ownAddTargetKernelInternal:162] registered kernel com.ti.test_kernels.tiovx_overhead on target DSP_C7-1
[C7x_1 ]     26.072621 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSP_C7-1
[C7x_1 ]     26.072700 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSP_C7-1_PRI_2
[C7x_1 ]     26.072777 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSP_C7-1_PRI_3
[C7x_1 ]     26.072854 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSP_C7-1_PRI_4
[C7x_1 ]     26.072930 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSP_C7-1_PRI_5
[C7x_1 ]     26.073006 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSP_C7-1_PRI_6
[C7x_1 ]     26.073082 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSP_C7-1_PRI_7
[C7x_1 ]     26.073156 s:  VX_ZONE_INFO: [tivxPlatformCreateTargetId:134] Added target DSP_C7-1_PRI_8
[C7x_1 ]     26.073180 s:  VX_ZONE_INFO: [tivxInitLocal:126] Initialization Done !!!
[C7x_1 ]     26.073198 s:  VX_ZONE_INFO: Globally Disabled VX_ZONE_INFO
[C7x_1 ]     26.073211 s: APP: OpenVX Target kernel init ... !!!
[C7x_1 ]     26.073388 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_1 ]     26.073402 s: APP: Init ... Done !!!
[C7x_1 ]     26.073412 s: APP: Run ... !!!
[C7x_1 ]     26.073421 s: IPC: Starting echo test ...
[C7x_1 ]     26.073528 s: APP: Run ... Done !!!
[C7x_1 ]     26.079313 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[.] C7X_1[s]
[C7x_1 ]     26.079506 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ]     26.090948 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ]     26.172967 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
4477.linux_log.txt
Regards.
  • HI,
    Can you please check CONFIG_TI_CPSW_PROXY_CLIENT is enabled from configs?
    Also, check whether "
    appEthFwRemoteServerInit
    " is ivoked from your application after ethfw_init in vision application.
    Refer to TI SDK for reference.
    Sudheer
  • Hi Sudheer,
    Yes,I checked that CONFIG_TI_CPSW_PROXY_CLIENT is enabled in defconfig.
    Also, check whether "appEthFwRemoteServerInit" is ivoked from your application after ethfw_init in vision application.
    This is the root cause of the problem. Due to some debugging reasons, appEthFwRemoteServerInit is blocked in app_init. When I call this API again, I can now find the "eth1" network card on Linux.
    Thank you for your patient and professional support.You can close this thread now.
    Regards.
    Thanks for the confirmation as it is working with above.
    Sudheer
