Part Number: TDA4VH-Q1
We want to optimize IPC latency between C7x cores. We measured around 30 μs for a RPMessage, which is way too much for our application, and 2 μs for a Mailbox message, which is still too much.
Could you provide us with the following information?
- Your measurements for RPMessage and Mailbox latency
- The path of an interrupt sent by a mailbox to a C7x core (software and hardware)
- Your measurements for the time it takes for an interrupt to reach a C7x core
Also, do you have some advice on this subject? Is triggering an interruption from the CLEC an option?
Note: in the IPC section of the SDK RTOS developer’s notes, there is a Latency section: https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-j784s4/latest/exports/docs/psdk_rtos/docs/user_guide/developer_notes_ipc.html#latency. It links to https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-j784s4/latest/exports/docs/pdk_j784s4_10_01_00_25/docs/datasheet/j784s4/datasheet_j784s4.html#ipc for IPC performance measurements, but there is nothing about IPCs on this page.
Lucas
