[FAQ] AM62A7: power rails decay note in Latest Datasheet
Guru 10085 points
Part Number: AM62A7
Hi Support Team,
In the latest AM62A datasheet: 10 Revision History, there is the following description,
is it correct that this is a typo for “Power-Down Sequence”?
https://www.ti.com/lit/ds/symlink/am62a7.pdf
Kanae
  • I'm not sure what you are asking. TI has always expected all power rails to decay below 300mV before initiating a new power-up sequence. A new note was added to clarify the requirement.
    Paul
  • Hi Paul,
    Thank you for your reply.
    I understood that the same notes are listed in both the power-up sequence and power-down sequence section.
    Appreciate your help.
    Kanae
  • Yes, I placed the note in both sections because it applies to both power-up and power-down. The power-up sequence should not begin until all power rails are below 300mV, and the power-down sequence is not complete until all power rails are below 300mV.
    Paul
