We have created a test project in which we have included our own linker/command file. our own linker file contains the memory sections alone and original memory range is defined in auto generated linker/command file.
Since we were using some TI DSP api to create task, so we were getting some linking error. To remove the linking error we have added "test.cfg" file.
test.cfg file contains
var Task = xdc.useModule('ti.sysbios.knl.Task');
Now after compiling we are getting
placement fails for object ".cinit", size 0x17f34 (page 0). Available ranges: L2SRAM size: 0x100000 unused: 0x34 max hole: 0xc Test C/C++ Problem
placement fails for object ".const", size 0x2c306 (page 0). Available ranges: L2SRAM size: 0x100000 unused: 0x4b max hole: 0xc Test C/C++ Problem
placement fails for object ".switch", size 0x7a7 (page 0). Available ranges: L2SRAM size: 0x100000 unused: 0x4b max hole: 0xc Test C/C++ Problem
placement fails for object ".text", size 0xbb0d0 (page 0). Available ranges: L2SRAM size: 0x100000 unused: 0x4b max hole: 0xc Test C/C++ Problem
placement fails for object ".vecs", size 0x5ff (page 0). Available ranges: L2SRAM size: 0x100000 unused: 0x4b max hole: 0xc Test C/C++ Problem
run placement fails for object Test C/C++ Problem
run placement fails for object ".cio", size 0x123 (page 0). Available ranges: L2SRAM size: 0x100000 unused: 0x4b max hole: 0xc Test C/C++ Problem
run placement fails for object ".far", size 0x2c634a (page 0). Available ranges: L2SRAM size: 0x100000 unused: 0x6950b max hole: 0x694cc Test C/C++ Problem
run placement fails for object ".fardata", size 0xb23b1 (page 0). Available ranges: L2SRAM size: 0x100000 unused: 0x4b max hole: 0xc Test C/C++ Problem
run placement fails for object ".stack", size 0x1000 (page 0). Available ranges: L2SRAM size: 0x100000 unused: 0x4b max hole: 0xc Test C/C++ Problem
run placement fails for object "GROUP_1", size 0x1cf (page 0). Available ranges: L2SRAM size: 0x100000 unused: 0x4b max hole: 0xc Test C/C++ Problem
Rohit
