AM5728: UBOOT porting
Part Number: AM5728
I am porting my uboot from the SDK(5.03) to SDK(8.02), I have made the necessary changes same as that of 5.03 in 8.03 uboot files. namely board.c and mux.h and am57xx_hs_evm_defconfig.
The problem here is my old SDK MLO and uboot.img in the first partition boots fine but the one i made in 8.03 does not boot at all.
Could you help me port the u-boot and get it ready?
Roshan Rajagopal
  • Hi Roshan,
    Our AM57 engineer is currently out of office. Please expect a delay in response by 1 day.
    Takuma
  • Hi
    Thank you for the reply.Please do let us know the reply once he/she is available.
    Roshan Rajagopal
  • Hi Roshan,
    Understood and apologies in advance. It looks like our engineer had some delays in travel. Please expect a response around Friday or Monday timeframe.
    Takuma
    Is there any update on this issue??
    Roshan Rajagopal
  • Hello Roshan,
    The SDK versions are very far apart. So are you saying that you get zero prints whatsoever?
    This mostly indicates that you're images are not signed or not signed correctly. have you made the ports to a GP device first?
    -Josue
    Sorry we do not have a gp-evm device currently , could you guide us on how to sign the images correctly?
    Also is there a updated guide on uboot porting for am57xx? i found for am335x.
    Roshan Rajagopal
  • Roshan,
    High Security (HS) support for AM57 is under NDA only. Please work with your local TI office to gain access to the AM57 HS documentation and Security forum.
    Can you confirm the following question:
    Essentially no UART prints. Is this a production device? Do you have a product on the market with AM572x with Secure boot?
    Or is this the first time attempting secure boot?
    I do not believe we have a u-boot porting guide. It sounds like you are doing most of the right steps. I suspect that you are using a HS device and don't have the signed SW for it.
    -Josue
    No we do not attempt secure boot, we have tried it to use it in 5.03 without secure boot , we had made changes to the gp evm files and then it had worked there. The same changes when done in 8.03 SDK does not work.
    Roshan Rajagopal
    Is the below part needed for the latest SDK, we had used the same for booting with 4GB emif as mentioned in the emif tool PDF.
    board/ti/am57xx/board.c
    int dram_init_banksize(void)
    	u64 ram_size;
    	ram_size = 0x100000000;
    	gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE;
    	gd->bd->bi_dram[0].size = get_effective_memsize();
    	if (ram_size > CONFIG_MAX_MEM_MAPPED) {
    	gd->bd->bi_dram[1].start = 0x200000000;
    	gd->bd->bi_dram[1].size = ram_size - CONFIG_MAX_MEM_MAPPED;
    	return 0;
    include/configs/am57xx_evm.h
    #define CONFIG_VERY_BIG_RAM
    #define CONFIG_MAX_MEM_MAPPED 0x80000000
    #define CONFIG_PHYS_64BIT
    the above was used in SDK 5.03 , but should the same be used in sdk 8.03 as i had noticed that
    #define CONFIG_NR_DRAM_BANKS        2
    the above line in am57xx_evm.h was moved into kconfig and not present in the am57xx_evm.h of sdk 8.03 so similarly is the other lines also moved or depreciated?
    Roshan Rajagopal
  • Roshan,
    Your responses and original questions are confusing. The following inputs from your side made me think that you are using High Security devices:
    am57xx_hs_evm_defconfig: This is the High security configuration for Linux.
    What was meant by "we do not have a gp-evm"? Did you mean that you do not have a TI EVM? specifically the AM572x GP EVM?
    The part number would also be a different part number than the GP device, the number would have a n (S) on the end as explained in the datasheet:
    In terms of bringing up Uboot, you are taking the right steps in reviewing the code that boots our EVMs on the SDK that coincides with the U-boot release that you need. Please see the following guide that can be of help (Of course you would have to replace the naming for AM57):
    https://software-dl.ti.com/processor-sdk-linux/esd/AM437X/08_02_00_24/exports/docs/linux/How_to_Guides/Board_Port/U-Boot.html
    .In general you would want to first, create a minimal configuration that can be used for the initial board bring up attempt. Once the basics are working, the minimal configuration is a good base to incrementally build on. Add features one by one, until the configuration fully supports all the desired features of the custom board.
    Please see the following disclaimer: https://software-dl.ti.com/processor-sdk-linux/esd/AM57X/08_02_01_00/exports/docs/linux/Overview_Technical_Support.html#open-source-software-support-disclaimer
    -Josue
    Sorry for the confusion so we did use the am57xx_hs_evm_defconfig, but later on we removed the secure device sections from the same and had used it in our am57xx custom board boot up using SDK 5.03.
    Also yes i meant that we do not have a ti evm device at the moment specifically AM572x gp evm.
    Also since most our features in the custom board is matching with the am572x gp evm except the emif configuration. If i just use those changes it should work right?
    Also could also just let me know if the emif 4GB support which we had put in the board.c file according to my previous reply.
    I am also providing the defconfig file i am using for clarity.
    CONFIG_ARM=y
    CONFIG_ARCH_OMAP2PLUS=y
    CONFIG_TI_SECURE_DEVICE=n
    CONFIG_TI_COMMON_CMD_OPTIONS=y
    CONFIG_SYS_MALLOC_F_LEN=0x2000
    CONFIG_ARCH_DRA7XX=y
    CONFIG_TI_EDMA3=y
    CONFIG_NR_DRAM_BANKS=2
    CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000
    CONFIG_DM_GPIO=y
    CONFIG_SPL_DM_SPI=y
    CONFIG_OMAP54XX=y
    CONFIG_TARGET_AM57XX_EVM=y
    CONFIG_DRA7_DSPEVE_OPP_HIGH=y
    CONFIG_DRA7_IVA_OPP_HIGH=y
    CONFIG_DRA7_GPU_OPP_HIGH=y
    CONFIG_SPL=y
    CONFIG_ENV_OFFSET_REDUND=0x280000
    CONFIG_SPL_SPI_FLASH_SUPPORT=y
    CONFIG_SPL_SPI_SUPPORT=y
    CONFIG_ARMV7_LPAE=y
    CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15"
    CONFIG_AHCI=y
    CONFIG_DISTRO_DEFAULTS=y
    CONFIG_FIT_IMAGE_POST_PROCESS=y
    CONFIG_SPL_LOAD_FIT=y
    CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y
    # CONFIG_USE_SPL_FIT_GENERATOR is not set
    CONFIG_OF_BOARD_SETUP=y
    CONFIG_USE_BOOTARGS=y
    CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS2,115200 androidboot.console=ttyS2 androidboot.hardware=beagle_x15board"
    # CONFIG_USE_BOOTCOMMAND is not set
    CONFIG_SYS_CONSOLE_INFO_QUIET=y
    CONFIG_BOARD_EARLY_INIT_F=y
    # CONFIG_MISC_INIT_R is not set
    CONFIG_AVB_VERIFY=y
    CONFIG_ANDROID_AB=y
    CONFIG_SPL_SYS_MALLOC_SIMPLE=y
    CONFIG_SPL_SEPARATE_BSS=y
    CONFIG_SPL_DMA=y
    # CONFIG_SPL_NAND_SUPPORT is not set
    CONFIG_SPL_DM_SPI_FLASH=y
    CONFIG_SPL_SPI_LOAD=y
    CONFIG_CMD_ADTIMG=y
    CONFIG_CMD_ABOOTIMG=y
    CONFIG_CMD_BCB=y
    # CONFIG_CMD_FLASH is not set
    # CONFIG_CMD_SETEXPR is not set
    CONFIG_CMD_AB_SELECT=y
    CONFIG_BOOTP_DNS2=y
    # CONFIG_CMD_PMIC is not set
    CONFIG_CMD_AVB=y
    CONFIG_OF_CONTROL=y
    CONFIG_SPL_OF_CONTROL=y
    CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk"
    CONFIG_ENV_OVERWRITE=y
    CONFIG_ENV_IS_IN_MMC=y
    CONFIG_SYS_REDUNDAND_ENVIRONMENT=y
    CONFIG_SYS_RELOC_GD_ENV_ADDR=y
    CONFIG_SYS_MMC_ENV_DEV=1
    CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y
    CONFIG_VERSION_VARIABLE=y
    CONFIG_BOOTP_SEND_HOSTNAME=y
    CONFIG_DM=y
    CONFIG_SPL_DM=y
    CONFIG_SPL_DM_SEQ_ALIAS=y
    CONFIG_DWC_AHCI=y
    CONFIG_DFU_MMC=y
    CONFIG_DFU_RAM=y
    CONFIG_USB_FUNCTION_FASTBOOT=y
    CONFIG_FASTBOOT_BUF_ADDR=0x82000000
    CONFIG_FASTBOOT_BUF_SIZE=0x2F000000
    CONFIG_FASTBOOT_USB_DEV=1
    CONFIG_FASTBOOT_FLASH=y
    CONFIG_FASTBOOT_FLASH_MMC_DEV=1
    CONFIG_FASTBOOT_CMD_OEM_FORMAT=y
    CONFIG_FASTBOOT_GPT_NAME="gpt"
    CONFIG_FASTBOOT_MBR_NAME="mbr"
    CONFIG_DM_I2C=y
    CONFIG_MISC=y
    CONFIG_DM_MMC=y
    CONFIG_SUPPORT_EMMC_BOOT=y
    CONFIG_MMC_OMAP_HS=y
    CONFIG_MTD=y
    CONFIG_DM_SPI_FLASH=y
    CONFIG_SF_DEFAULT_MODE=0
    CONFIG_SF_DEFAULT_SPEED=76800000
    CONFIG_SPI_FLASH_SPANSION=y
    CONFIG_PHY_MICREL=y
    CONFIG_PHY_MICREL_KSZ90X1=y
    CONFIG_DM_ETH=y
    CONFIG_MII=y
    CONFIG_DRIVER_TI_CPSW=y
    CONFIG_PIPE3_PHY=y
    CONFIG_OMAP_USB2_PHY=y
    CONFIG_DM_PMIC=y
    CONFIG_PMIC_PALMAS=y
    CONFIG_DM_REGULATOR=y
    CONFIG_DM_REGULATOR_PALMAS=y
    CONFIG_DM_SCSI=y
    CONFIG_DM_SERIAL=y
    CONFIG_SPI=y
    CONFIG_DM_SPI=y
    CONFIG_TI_QSPI=y
    CONFIG_USB=y
    CONFIG_DM_USB=y
    CONFIG_DM_USB_GADGET=y
    CONFIG_SPL_DM_USB_GADGET=y
    CONFIG_USB_XHCI_HCD=y
    CONFIG_USB_XHCI_DWC3=y
    CONFIG_USB_DWC3=y
    CONFIG_USB_DWC3_GENERIC=y
    CONFIG_USB_GADGET=y
    CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments"
    CONFIG_USB_GADGET_VENDOR_NUM=0x0451
    CONFIG_USB_GADGET_PRODUCT_NUM=0xd022
    CONFIG_LIBAVB=y
    below is the .config that was working in 5.03 sdk
    # Automatically generated file; DO NOT EDIT.
    # U-Boot 2018.01 Configuration
    CONFIG_CREATE_ARCH_SYMLINK=y
    # CONFIG_ARC is not set
    CONFIG_ARM=y
    # CONFIG_M68K is not set
    # CONFIG_MICROBLAZE is not set
    # CONFIG_MIPS is not set
    # CONFIG_NDS32 is not set
    # CONFIG_NIOS2 is not set
    # CONFIG_PPC is not set
    # CONFIG_SANDBOX is not set
    # CONFIG_SH is not set
    # CONFIG_X86 is not set
    # CONFIG_XTENSA is not set
    CONFIG_SYS_ARCH="arm"
    CONFIG_SYS_CPU="armv7"
    CONFIG_SYS_SOC="omap5"
    CONFIG_SYS_VENDOR="ti"
    CONFIG_SYS_BOARD="am57xx"
    CONFIG_SYS_CONFIG_NAME="am57xx_evm"
    # ARM architecture
    CONFIG_HAS_VBAR=y
    CONFIG_HAS_THUMB2=y
    CONFIG_ARM_ASM_UNIFIED=y
    CONFIG_SYS_ARM_CACHE_CP15=y
    CONFIG_SYS_ARM_MMU=y
    # CONFIG_SYS_ARM_MPU is not set
    CONFIG_ARM_ERRATA_798870=y
    CONFIG_ARM_CORTEX_A15_CVE_2017_5715=y
    CONFIG_CPU_V7A=y
    CONFIG_SYS_ARM_ARCH=7
    CONFIG_SYS_CACHE_SHIFT_6=y
    CONFIG_SYS_CACHELINE_SIZE=64
    # CONFIG_ARM_SMCCC is not set
    # CONFIG_SEMIHOSTING is not set
    CONFIG_SYS_THUMB_BUILD=y
    CONFIG_SPL_SYS_THUMB_BUILD=y
    # CONFIG_SYS_L2CACHE_OFF is not set
    # CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set
    # CONFIG_ARM_CORTEX_CPU_IS_UP is not set
    CONFIG_USE_ARCH_MEMCPY=y
    CONFIG_SPL_USE_ARCH_MEMCPY=y
    CONFIG_USE_ARCH_MEMSET=y
    CONFIG_SPL_USE_ARCH_MEMSET=y
    # CONFIG_ARM64_SUPPORT_AARCH32 is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_TARGET_EDB93XX is not set
    # CONFIG_TARGET_ASPENITE is not set
    # CONFIG_TARGET_GPLUGD is not set
    # CONFIG_ARCH_DAVINCI is not set
    # CONFIG_KIRKWOOD is not set
    # CONFIG_ARCH_MVEBU is not set
    # CONFIG_TARGET_DEVKIT3250 is not set
    # CONFIG_TARGET_WORK_92105 is not set
    # CONFIG_TARGET_APF27 is not set
    # CONFIG_TARGET_APX4DEVKIT is not set
    # CONFIG_TARGET_XFI3 is not set
    # CONFIG_TARGET_M28EVK is not set
    # CONFIG_TARGET_MX23EVK is not set
    # CONFIG_TARGET_MX28EVK is not set
    # CONFIG_TARGET_MX23_OLINUXINO is not set
    # CONFIG_TARGET_BG0900 is not set
    # CONFIG_TARGET_SANSA_FUZE_PLUS is not set
    # CONFIG_TARGET_SC_SPS_1 is not set
    # CONFIG_ORION5X is not set
    # CONFIG_TARGET_SPEAR300 is not set
    # CONFIG_TARGET_SPEAR310 is not set
    # CONFIG_TARGET_SPEAR320 is not set
    # CONFIG_TARGET_SPEAR600 is not set
    # CONFIG_TARGET_STV0991 is not set
    # CONFIG_TARGET_X600 is not set
    # CONFIG_TARGET_IMX31_PHYCORE is not set
    # CONFIG_TARGET_IMX31_PHYCORE_EET is not set
    # CONFIG_TARGET_MX31ADS is not set
    # CONFIG_TARGET_MX31PDK is not set
    # CONFIG_TARGET_WOODBURN is not set
    # CONFIG_TARGET_WOODBURN_SD is not set
    # CONFIG_TARGET_FLEA3 is not set
    # CONFIG_TARGET_MX35PDK is not set
    # CONFIG_ARCH_BCM283X is not set
    # CONFIG_TARGET_VEXPRESS_CA15_TC2 is not set
    # CONFIG_TARGET_VEXPRESS_CA5X2 is not set
    # CONFIG_TARGET_VEXPRESS_CA9X4 is not set
    # CONFIG_TARGET_BCM23550_W1D is not set
    # CONFIG_TARGET_BCM28155_AP is not set
    # CONFIG_TARGET_BCMCYGNUS is not set
    # CONFIG_TARGET_BCMNSP is not set
    # CONFIG_TARGET_BCMNS2 is not set
    # CONFIG_ARCH_EXYNOS is not set
    # CONFIG_ARCH_S5PC1XX is not set
    # CONFIG_ARCH_HIGHBANK is not set
    # CONFIG_ARCH_INTEGRATOR is not set
    # CONFIG_ARCH_KEYSTONE is not set
    # CONFIG_ARCH_K3 is not set
    # CONFIG_ARCH_MESON is not set
    # CONFIG_ARCH_MX25 is not set
    # CONFIG_ARCH_MX7ULP is not set
    # CONFIG_ARCH_MX7 is not set
    # CONFIG_ARCH_MX6 is not set
    CONFIG_SPL_LDSCRIPT="arch/arm/mach-omap2/u-boot-spl.lds"
    # CONFIG_ARCH_MX5 is not set
    # CONFIG_ARCH_QEMU is not set
    # CONFIG_ARCH_RMOBILE is not set
    # CONFIG_TARGET_S32V234EVB is not set
    # CONFIG_ARCH_SNAPDRAGON is not set
    # CONFIG_ARCH_SOCFPGA is not set
    # CONFIG_ARCH_SUNXI is not set
    # CONFIG_TARGET_TS4600 is not set
    # CONFIG_ARCH_VF610 is not set
    # CONFIG_ARCH_ZYNQ is not set
    # CONFIG_ARCH_ZYNQMP is not set
    # CONFIG_TEGRA is not set
    # CONFIG_TARGET_VEXPRESS64_AEMV8A is not set
    # CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set
    # CONFIG_TARGET_VEXPRESS64_BASE_FVP_DRAM is not set
    # CONFIG_TARGET_VEXPRESS64_JUNO is not set
    # CONFIG_TARGET_LS2080A_EMU is not set
    # CONFIG_TARGET_LS2080A_SIMU is not set
    # CONFIG_TARGET_LS1088AQDS is not set
    # CONFIG_TARGET_LS2080AQDS is not set
    # CONFIG_TARGET_LS2080ARDB is not set
    # CONFIG_TARGET_LS2081ARDB is not set
    # CONFIG_TARGET_HIKEY is not set
    # CONFIG_TARGET_POPLAR is not set
    # CONFIG_TARGET_LS1012AQDS is not set
    # CONFIG_TARGET_LS1012ARDB is not set
    # CONFIG_TARGET_LS1012AFRDM is not set
    # CONFIG_TARGET_LS1088ARDB is not set
    # CONFIG_TARGET_LS1021AQDS is not set
    # CONFIG_TARGET_LS1021ATWR is not set
    # CONFIG_TARGET_LS1021AIOT is not set
    # CONFIG_TARGET_LS1043AQDS is not set
    # CONFIG_TARGET_LS1043ARDB is not set
    # CONFIG_TARGET_LS1046AQDS is not set
    # CONFIG_TARGET_LS1046ARDB is not set
    # CONFIG_TARGET_H2200 is not set
    # CONFIG_TARGET_ZIPITZ2 is not set
    # CONFIG_TARGET_COLIBRI_PXA270 is not set
    # CONFIG_ARCH_UNIPHIER is not set
    # CONFIG_STM32 is not set
    # CONFIG_ARCH_STI is not set
    # CONFIG_ARCH_ROCKCHIP is not set
    # CONFIG_TARGET_THUNDERX_88XX is not set
    # CONFIG_ARCH_ASPEED is not set
    # CONFIG_TI_SECURE_DEVICE is not set
    CONFIG_SYS_TEXT_BASE=0x80800000
    CONFIG_TI_I2C_BOARD_DETECT=y
    CONFIG_EEPROM_BUS_ADDRESS=0
    CONFIG_EEPROM_CHIP_ADDRESS=0x50
    CONFIG_SPL_GPIO_SUPPORT=y
    CONFIG_SPL_LIBCOMMON_SUPPORT=y
    CONFIG_SPL_LIBGENERIC_SUPPORT=y
    # CONFIG_OMAP34XX is not set
    # CONFIG_OMAP44XX is not set
    CONFIG_OMAP54XX=y
    # CONFIG_TI814X is not set
    # CONFIG_TI816X is not set
    # CONFIG_AM43XX is not set
    # CONFIG_AM33XX is not set
    CONFIG_SYS_MPUCLK=500
    CONFIG_DRA7XX=y
    # CONFIG_TARGET_CL_SOM_AM57X is not set
    # CONFIG_TARGET_CM_T54 is not set
    # CONFIG_TARGET_OMAP5_UEVM is not set
    # CONFIG_TARGET_DRA7XX_EVM is not set
    CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC=31219
    # Voltage Domain OPP selections
    CONFIG_DRA7_MPU_OPP_NOM=y
    # CONFIG_DRA7_DSPEVE_OPP_NOM is not set
    # CONFIG_DRA7_DSPEVE_OPP_OD is not set
    # CONFIG_DRA7_IVA_OPP_NOM is not set
    # CONFIG_DRA7_IVA_OPP_OD is not set
    # CONFIG_DRA7_GPU_OPP_NOM is not set
    # CONFIG_DRA7_GPU_OPP_OD is not set
    CONFIG_CONS_INDEX=3
    CONFIG_SPL_MMC_SUPPORT=y
    CONFIG_SPL_SERIAL_SUPPORT=y
    # CONFIG_SPL_DRIVERS_MISC_SUPPORT is not set
    CONFIG_SPL_LIBDISK_SUPPORT=y
    # CONFIG_SPL_WATCHDOG_SUPPORT is not set
    CONFIG_IDENT_STRING=""
    CONFIG_SPL_STACK_R_ADDR=0x82000000
    CONFIG_SPL_FAT_SUPPORT=y
    CONFIG_ARMV7_LPAE=y
    # CONFIG_CMD_DEKBLOB is not set
    # CONFIG_CMD_HDMIDETECT is not set
    # ARM debug
    # CONFIG_DEBUG_LL is not set
    CONFIG_SMBIOS_PRODUCT_NAME="am57xx"
    # CONFIG_DEBUG_UART is not set
    # CONFIG_AHCI is not set
    # General setup
    CONFIG_LOCALVERSION=""
    CONFIG_LOCALVERSION_AUTO=y
    CONFIG_CC_OPTIMIZE_FOR_SIZE=y
    # CONFIG_DISTRO_DEFAULTS is not set
    CONFIG_SYS_MALLOC_F=y
    CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000
    CONFIG_TPL_SYS_MALLOC_F_LEN=0x2000
    CONFIG_EXPERT=y
    CONFIG_SYS_MALLOC_CLEAR_ON_INIT=y
    # CONFIG_TOOLS_DEBUG is not set
    # CONFIG_PHYS_64BIT is not set
    # Boot images
    CONFIG_ANDROID_BOOT_IMAGE=y
    CONFIG_FIT=y
    CONFIG_FIT_ENABLE_SHA256_SUPPORT=y
    # CONFIG_FIT_SIGNATURE is not set
    # CONFIG_FIT_VERBOSE is not set
    # CONFIG_FIT_BEST_MATCH is not set
    CONFIG_SPL_FIT=y
    # CONFIG_SPL_FIT_SIGNATURE is not set
    # CONFIG_SPL_FIT_IMAGE_POST_PROCESS is not set
    CONFIG_SPL_FIT_SOURCE=""
    CONFIG_SPL_FIT_GENERATOR=""
    # CONFIG_OF_SYSTEM_SETUP is not set
    # CONFIG_OF_STDOUT_VIA_ALIAS is not set
    CONFIG_SYS_EXTRA_OPTIONS=""
    CONFIG_ARCH_FIXUP_FDT_MEMORY=y
    # API
    # CONFIG_API is not set
    # Boot timing
    # CONFIG_BOOTSTAGE is not set
    CONFIG_BOOTSTAGE_RECORD_COUNT=30
    CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=5
    CONFIG_BOOTSTAGE_STASH_ADDR=0
    CONFIG_BOOTSTAGE_STASH_SIZE=0x1000
    # Boot media
    # CONFIG_NAND_BOOT is not set
    # CONFIG_ONENAND_BOOT is not set
    # CONFIG_QSPI_BOOT is not set
    # CONFIG_SATA_BOOT is not set
    # CONFIG_SD_BOOT is not set
    # CONFIG_SPI_BOOT is not set
    CONFIG_BOOTDELAY=2
    CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS2,115200 androidboot.console=ttyS2 androidboot.hardware=am57xevmboard"
    # Console
    # CONFIG_CONSOLE_RECORD is not set
    CONFIG_LOGLEVEL=4
    CONFIG_SPL_LOGLEVEL=4
    # CONFIG_SILENT_CONSOLE is not set
    # CONFIG_PRE_CONSOLE_BUFFER is not set
    # CONFIG_CONSOLE_MUX is not set
    # CONFIG_SYS_CONSOLE_IS_IN_ENV is not set
    # CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE is not set
    # CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set
    # CONFIG_SYS_STDIO_DEREGISTER is not set
    # Logging
    # CONFIG_LOG is not set
    # CONFIG_SPL_LOG is not set
    CONFIG_DEFAULT_FDT_FILE="am57xx-beagle-x15.dtb"
    CONFIG_BOARD_LATE_INIT=y
    CONFIG_DISPLAY_CPUINFO=y
    CONFIG_DISPLAY_BOARDINFO=y
    # Start-up hooks
    # CONFIG_ARCH_EARLY_INIT_R is not set
    # CONFIG_ARCH_MISC_INIT is not set
    # Security support
    CONFIG_HASH=y
    # SPL / TPL
    CONFIG_SUPPORT_SPL=y
    CONFIG_SPL=y
    CONFIG_SPL_BOARD_INIT=y
    # CONFIG_SPL_BOOTROM_SUPPORT is not set
    CONFIG_SPL_RAW_IMAGE_SUPPORT=y
    CONFIG_SPL_LEGACY_IMAGE_SUPPORT=y
    # CONFIG_TPL_SYS_MALLOC_SIMPLE is not set
    CONFIG_SPL_STACK_R=y
    CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x100000
    # CONFIG_SPL_SKIP_CLEAR_BSS is not set
    CONFIG_SPL_DISPLAY_PRINT=y
    CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y
    CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300
    # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION is not set
    # CONFIG_SPL_CRC32_SUPPORT is not set
    # CONFIG_SPL_MD5_SUPPORT is not set
    # CONFIG_SPL_SHA1_SUPPORT is not set
    # CONFIG_SPL_SHA256_SUPPORT is not set
    # CONFIG_SPL_FIT_IMAGE_TINY is not set
    # CONFIG_SPL_CPU_SUPPORT is not set
    # CONFIG_SPL_CRYPTO_SUPPORT is not set
    # CONFIG_SPL_HASH_SUPPORT is not set
    CONFIG_SPL_DMA_SUPPORT=y
    CONFIG_SPL_ENV_SUPPORT=y
    # CONFIG_SPL_SAVEENV is not set
    # CONFIG_SPL_ETH_SUPPORT is not set
    CONFIG_SPL_EXT_SUPPORT=y
    # CONFIG_SPL_FPGA_SUPPORT is not set
    CONFIG_SPL_I2C_SUPPORT=y
    # CONFIG_SPL_MAILBOX_SUPPORT is not set
    # CONFIG_SPL_MMC_WRITE is not set
    # CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT is not set
    # CONFIG_SPL_MTD_SUPPORT is not set
    # CONFIG_SPL_MUSB_NEW_SUPPORT is not set
    # CONFIG_SPL_NET_SUPPORT is not set
    # CONFIG_SPL_NO_CPU_SUPPORT is not set
    # CONFIG_SPL_NOR_SUPPORT is not set
    # CONFIG_SPL_XIP_SUPPORT is not set
    # CONFIG_SPL_ONENAND_SUPPORT is not set
    CONFIG_SPL_OS_BOOT=y
    # CONFIG_SPL_PCI_SUPPORT is not set
    # CONFIG_SPL_PCH_SUPPORT is not set
    # CONFIG_SPL_POST_MEM_SUPPORT is not set
    CONFIG_SPL_POWER_SUPPORT=y
    # CONFIG_SPL_RAM_SUPPORT is not set
    # CONFIG_SPL_REMOTEPROC_SUPPORT is not set
    # CONFIG_SPL_RTC_SUPPORT is not set
    # CONFIG_SPL_SATA_SUPPORT is not set
    CONFIG_SPL_THERMAL=y
    # CONFIG_SPL_USB_HOST_SUPPORT is not set
    # CONFIG_SPL_USB_GADGET_SUPPORT is not set
    # CONFIG_SPL_YMODEM_SUPPORT is not set
    # Command line interface
    CONFIG_CMDLINE=y
    CONFIG_HUSH_PARSER=y
    CONFIG_SYS_PROMPT="=> "
    # Autoboot options
    CONFIG_AUTOBOOT=y
    # CONFIG_AUTOBOOT_KEYED is not set
    # FASTBOOT
    CONFIG_FASTBOOT=y
    CONFIG_CMD_FASTBOOT=y
    CONFIG_FASTBOOT_FLASH_MMC=y
    # Commands
    # Info commands
    CONFIG_CMD_BDI=y
    # CONFIG_CMD_CONFIG is not set
    CONFIG_CMD_CONSOLE=y
    # CONFIG_CMD_CPU is not set
    # CONFIG_CMD_LICENSE is not set
    # Boot commands
    CONFIG_CMD_BOOTD=y
    CONFIG_CMD_BOOTM=y
    CONFIG_CMD_BOOTZ=y
    CONFIG_CMD_BOOTEFI=y
    CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y
    # CONFIG_CMD_BOOTEFI_HELLO is not set
    # CONFIG_CMD_BOOTEFI_SELFTEST is not set
    # CONFIG_CMD_BOOTMENU is not set
    CONFIG_CMD_ELF=y
    CONFIG_CMD_FDT=y
    CONFIG_CMD_GO=y
    CONFIG_CMD_RUN=y
    CONFIG_CMD_IMI=y
    # CONFIG_CMD_IMLS is not set
    CONFIG_CMD_XIMG=y
    # CONFIG_CMD_POWEROFF is not set
    CONFIG_CMD_SPL=y
    CONFIG_CMD_SPL_NAND_OFS=0
    CONFIG_CMD_SPL_WRITE_SIZE=0x2000
    # CONFIG_CMD_THOR_DOWNLOAD is not set
    # CONFIG_CMD_ZBOOT is not set
    # Environment commands
    CONFIG_CMD_ASKENV=y
    CONFIG_CMD_EXPORTENV=y
    CONFIG_CMD_IMPORTENV=y
    CONFIG_CMD_EDITENV=y
    # CONFIG_CMD_GREPENV is not set
    CONFIG_CMD_SAVEENV=y
    CONFIG_CMD_ENV_EXISTS=y
    # CONFIG_CMD_ENV_CALLBACK is not set
    # CONFIG_CMD_ENV_FLAGS is not set
    # Memory commands
    CONFIG_CMD_CRC32=y
    # CONFIG_CRC32_VERIFY is not set
    CONFIG_CMD_EEPROM=y
    # CONFIG_CMD_EEPROM_LAYOUT is not set
    # CONFIG_LOOPW is not set
    # CONFIG_CMD_MD5SUM is not set
    # CONFIG_CMD_MEMINFO is not set
    CONFIG_CMD_MEMORY=y
    # CONFIG_CMD_MEMTEST is not set
    # CONFIG_CMD_MX_CYCLIC is not set
    # CONFIG_CMD_SHA1SUM is not set
    # CONFIG_CMD_STRINGS is not set
    # Compression commands
    # CONFIG_CMD_LZMADEC is not set
    # CONFIG_CMD_UNZIP is not set
    # CONFIG_CMD_ZIP is not set
    # Device access commands
    # CONFIG_CMD_ARMFLASH is not set
    # CONFIG_CMD_CLK is not set
    # CONFIG_CMD_DEMO is not set
    CONFIG_CMD_DFU=y
    CONFIG_CMD_DM=y
    # CONFIG_CMD_FDC is not set
    CONFIG_CMD_FPGA=y
    # CONFIG_CMD_FPGA_LOADBP is not set
    # CONFIG_CMD_FPGA_LOADFS is not set
    # CONFIG_CMD_FPGA_LOADMK is not set
    # CONFIG_CMD_FPGA_LOADP is not set
    # CONFIG_CMD_FPGAD is not set
    # CONFIG_CMD_FUSE is not set
    CONFIG_CMD_GPIO=y
    CONFIG_CMD_GPT=y
    CONFIG_RANDOM_UUID=y
    # CONFIG_CMD_GPT_RENAME is not set
    # CONFIG_CMD_IDE is not set
    # CONFIG_CMD_IO is not set
    # CONFIG_CMD_IOTRACE is not set
    CONFIG_CMD_I2C=y
    CONFIG_CMD_LOADB=y
    CONFIG_CMD_LOADS=y
    CONFIG_CMD_MMC=y
    # CONFIG_CMD_NAND is not set
    # CONFIG_CMD_MMC_SPI is not set
    # CONFIG_CMD_ONENAND is not set
    CONFIG_CMD_PART=y
    # CONFIG_CMD_PCI is not set
    # CONFIG_CMD_PCMCIA is not set
    # CONFIG_CMD_READ is not set
    # CONFIG_CMD_SATA is not set
    # CONFIG_CMD_SAVES is not set
    # CONFIG_CMD_SDRAM is not set
    CONFIG_CMD_SF=y
    # CONFIG_CMD_SF_TEST is not set
    CONFIG_CMD_SPI=y
    # CONFIG_CMD_TSI148 is not set
    # CONFIG_CMD_UNIVERSE is not set
    CONFIG_CMD_USB=y
    # CONFIG_CMD_USB_SDP is not set
    # CONFIG_CMD_USB_MASS_STORAGE is not set
    # Shell scripting commands
    CONFIG_CMD_ECHO=y
    CONFIG_CMD_ITEST=y
    CONFIG_CMD_SOURCE=y
    # Network commands
    CONFIG_CMD_NET=y
    # CONFIG_CMD_TFTPPUT is not set
    # CONFIG_CMD_TFTPSRV is not set
    # CONFIG_CMD_RARP is not set
    CONFIG_CMD_DHCP=y
    # CONFIG_CMD_PXE is not set
    CONFIG_CMD_NFS=y
    CONFIG_CMD_MII=y
    CONFIG_CMD_PING=y
    # CONFIG_CMD_CDP is not set
    # CONFIG_CMD_SNTP is not set
    # CONFIG_CMD_DNS is not set
    # CONFIG_CMD_LINK_LOCAL is not set
    # CONFIG_CMD_ETHSW is not set
    # Misc commands
    # CONFIG_CMD_BSP is not set
    # CONFIG_CMD_BKOPS_ENABLE is not set
    # CONFIG_CMD_CACHE is not set
    # CONFIG_CMD_DISPLAY is not set
    # CONFIG_CMD_LED is not set
    # CONFIG_CMD_DATE is not set
    CONFIG_CMD_TIME=y
    # CONFIG_CMD_GETTIME is not set
    CONFIG_CMD_MISC=y
    # CONFIG_CMD_TIMER is not set
    # CONFIG_CMD_QFW is not set
    # CONFIG_CMD_TERMINAL is not set
    # CONFIG_CMD_UUID is not set
    # TI specific command line interface
    CONFIG_CMD_DDR3=y
    # Power commands
    CONFIG_CMD_REGULATOR=y
    # Security commands
    # CONFIG_CMD_AES is not set
    # CONFIG_CMD_BLOB is not set
    # CONFIG_CMD_HASH is not set
    # Firmware commands
    # Filesystem commands
    # CONFIG_CMD_BTRFS is not set
    CONFIG_CMD_EXT2=y
    CONFIG_CMD_EXT4=y
    CONFIG_CMD_EXT4_WRITE=y
    CONFIG_CMD_FAT=y
    CONFIG_CMD_FS_GENERIC=y
    # CONFIG_CMD_FS_UUID is not set
    # CONFIG_CMD_JFFS2 is not set
    # CONFIG_CMD_MTDPARTS is not set
    # CONFIG_CMD_REISER is not set
    CONFIG_CMD_SCSI=y
    # CONFIG_CMD_ZFS is not set
    # Debug commands
    # CONFIG_CMD_BEDBUG is not set
    # CONFIG_CMD_DIAG is not set
    # CONFIG_CMD_KGDB is not set
    # CONFIG_CMD_LOG is not set
    # CONFIG_CMD_TRACE is not set
    # CONFIG_CMD_UBI is not set
    # Partition Types
    CONFIG_PARTITIONS=y
    # CONFIG_MAC_PARTITION is not set
    # CONFIG_SPL_MAC_PARTITION is not set
    CONFIG_DOS_PARTITION=y
    CONFIG_SPL_DOS_PARTITION=y
    CONFIG_ISO_PARTITION=y
    CONFIG_SPL_ISO_PARTITION=y
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_SPL_AMIGA_PARTITION is not set
    CONFIG_EFI_PARTITION=y
    CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=128
    CONFIG_EFI_PARTITION_ENTRIES_OFF=0
    CONFIG_SPL_EFI_PARTITION=y
    CONFIG_PARTITION_UUIDS=y
    CONFIG_SPL_PARTITION_UUIDS=y
    # CONFIG_PARTITION_TYPE_GUID is not set
    CONFIG_SUPPORT_OF_CONTROL=y
    CONFIG_DTC=y
    # Device Tree Control
    CONFIG_OF_CONTROL=y
    # CONFIG_OF_BOARD_FIXUP is not set
    # CONFIG_OF_LIVE is not set
    CONFIG_OF_SEPARATE=y
    # CONFIG_OF_EMBED is not set
    # CONFIG_OF_BOARD is not set
    # CONFIG_MULTI_DTB_FIT is not set
    # CONFIG_SPL_MULTI_DTB_FIT is not set
    CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent"
    # CONFIG_SPL_OF_PLATDATA is not set
    CONFIG_MKIMAGE_DTC_PATH="dtc"
    # Environment
    # CONFIG_ENV_IS_NOWHERE is not set
    # CONFIG_ENV_IS_IN_EEPROM is not set
    # CONFIG_ENV_IS_IN_FAT is not set
    # CONFIG_ENV_IS_IN_FLASH is not set
    # CONFIG_ENV_IS_IN_NAND is not set
    # CONFIG_ENV_IS_IN_NVRAM is not set
    # CONFIG_ENV_IS_IN_ONENAND is not set
    # CONFIG_ENV_IS_IN_REMOTE is not set
    # CONFIG_ENV_IS_IN_SPI_FLASH is not set
    # CONFIG_ENV_IS_IN_UBI is not set
    CONFIG_NET=y
    # CONFIG_NET_RANDOM_ETHADDR is not set
    # CONFIG_NETCONSOLE is not set
    CONFIG_NET_TFTP_VARS=y
    CONFIG_BOOTP_PXE_CLIENTARCH=0x15
    CONFIG_BOOTP_VCI_STRING="U-Boot.armv7"
    # Device Drivers
    # Generic Driver Options
    CONFIG_DM=y
    CONFIG_SPL_DM=y
    CONFIG_DM_WARN=y
    # CONFIG_DM_DEBUG is not set
    CONFIG_DM_DEVICE_REMOVE=y
    CONFIG_DM_STDIO=y
    CONFIG_DM_SEQ_ALIAS=y
    # CONFIG_SPL_DM_SEQ_ALIAS is not set
    CONFIG_REGMAP=y
    # CONFIG_SPL_REGMAP is not set
    CONFIG_SYSCON=y
    # CONFIG_DEVRES is not set
    CONFIG_SIMPLE_BUS=y
    CONFIG_SPL_SIMPLE_BUS=y
    CONFIG_OF_TRANSLATE=y
    # CONFIG_SPL_OF_TRANSLATE is not set
    CONFIG_DM_DEV_READ_INLINE=y
    # CONFIG_ADC is not set
    # CONFIG_ADC_EXYNOS is not set
    # CONFIG_ADC_SANDBOX is not set
    # CONFIG_SARADC_ROCKCHIP is not set
    # CONFIG_SATA is not set
    CONFIG_LIBATA=y
    CONFIG_SCSI_AHCI=y
    # SATA/SCSI device support
    # CONFIG_DWC_AHSATA is not set
    # CONFIG_FSL_SATA is not set
    # CONFIG_MVSATA_IDE is not set
    # CONFIG_SATA_MV is not set
    # CONFIG_SATA_SIL is not set
    # CONFIG_SATA_SIL3114 is not set
    # CONFIG_BLK is not set
    # CONFIG_IDE is not set
    # Boot count support
    CONFIG_BOOTCOUNT=y
    CONFIG_BOOTCOUNT_EXT=y
    CONFIG_SYS_BOOTCOUNT_EXT_INTERFACE="mmc"
    CONFIG_SYS_BOOTCOUNT_EXT_DEVPART="1:3"
    CONFIG_SYS_BOOTCOUNT_EXT_NAME="/boot/failures"
    CONFIG_SYS_BOOTCOUNT_ADDR=0x8200A000
    # Clock
    # CONFIG_CLK is not set
    # CONFIG_CPU is not set
    # Hardware crypto devices
    # CONFIG_FSL_CAAM is not set
    # CONFIG_SYS_FSL_SEC_BE is not set
    # CONFIG_SYS_FSL_SEC_LE is not set
    # Demo for driver model
    # CONFIG_DM_DEMO is not set
    # DFU support
    CONFIG_USB_FUNCTION_DFU=y
    # CONFIG_DFU_TFTP is not set
    CONFIG_DFU_MMC=y
    # CONFIG_DFU_NAND is not set
    CONFIG_DFU_RAM=y
    # CONFIG_DFU_SF is not set
    # DMA Support
    # CONFIG_DMA is not set
    # CONFIG_TI_EDMA3 is not set
    # FPGA support
    # CONFIG_FPGA_ALTERA is not set
    # CONFIG_FPGA_SOCFPGA is not set
    # CONFIG_FPGA_XILINX is not set
    # GPIO Support
    CONFIG_DM_GPIO=y
    # CONFIG_ALTERA_PIO is not set
    # CONFIG_DWAPB_GPIO is not set
    # CONFIG_AT91_GPIO is not set
    # CONFIG_ATMEL_PIO4 is not set
    # CONFIG_DA8XX_GPIO is not set
    # CONFIG_INTEL_BROADWELL_GPIO is not set
    # CONFIG_INTEL_ICH6_GPIO is not set
    # CONFIG_IMX_RGPIO2P is not set
    # CONFIG_HSDK_CREG_GPIO is not set
    # CONFIG_LPC32XX_GPIO is not set
    # CONFIG_MSM_GPIO is not set
    CONFIG_OMAP_GPIO=y
    # CONFIG_CMD_PCA953X is not set
    # CONFIG_PCF8575_GPIO is not set
    # CONFIG_ROCKCHIP_GPIO is not set
    # CONFIG_CMD_TCA642X is not set
    # CONFIG_TEGRA_GPIO is not set
    # CONFIG_TEGRA186_GPIO is not set
    # CONFIG_VYBRID_GPIO is not set
    # CONFIG_DM_74X164 is not set
    # CONFIG_DM_PCA953X is not set
    # CONFIG_MPC85XX_GPIO is not set
    # I2C support
    CONFIG_DM_I2C=y
    # CONFIG_DM_I2C_COMPAT is not set
    # CONFIG_I2C_SET_DEFAULT_BUS_NUM is not set
    # CONFIG_DM_I2C_GPIO is not set
    # CONFIG_SYS_I2C_FSL is not set
    # CONFIG_SYS_I2C_DW is not set
    # CONFIG_SYS_I2C_INTEL is not set
    # CONFIG_SYS_I2C_IMX_LPI2C is not set
    CONFIG_SYS_I2C_OMAP24XX=y
    # CONFIG_SYS_I2C_ROCKCHIP is not set
    # CONFIG_SYS_I2C_MVTWSI is not set
    CONFIG_SYS_I2C_BUS_MAX=5
    # CONFIG_I2C_MUX is not set
    # CONFIG_DM_KEYBOARD is not set
    # CONFIG_CROS_EC_KEYB is not set
    # LED Support
    # CONFIG_LED is not set
    # CONFIG_SPL_LED is not set
    # CONFIG_LED_STATUS is not set
    # Mailbox Controller Support
    # CONFIG_DM_MAILBOX is not set
    # Memory Controller drivers
    # Multifunction device drivers
    CONFIG_MISC=y
    # CONFIG_ALTERA_SYSID is not set
    # CONFIG_ATSHA204A is not set
    # CONFIG_ROCKCHIP_EFUSE is not set
    # CONFIG_CROS_EC is not set
    # CONFIG_DS4510 is not set
    # CONFIG_FSL_SEC_MON is not set
    # CONFIG_MXC_OCOTP is not set
    # CONFIG_NUVOTON_NCT6102D is not set
    # CONFIG_PWRSEQ is not set
    # CONFIG_PCA9551_LED is not set
    # CONFIG_WINBOND_W83627 is not set
    # CONFIG_I2C_EEPROM is not set
    # CONFIG_SPL_I2C_EEPROM is not set
    # MMC Host controller Support
    CONFIG_MMC=y
    CONFIG_MMC_WRITE=y
    # CONFIG_MMC_BROKEN_CD is not set
    CONFIG_DM_MMC=y
    CONFIG_SPL_DM_MMC=y
    # CONFIG_ARM_PL180_MMCI is not set
    CONFIG_MMC_QUIRKS=y
    CONFIG_MMC_HW_PARTITIONING=y
    CONFIG_MMC_IO_VOLTAGE=y
    # CONFIG_SPL_MMC_IO_VOLTAGE is not set
    CONFIG_MMC_UHS_SUPPORT=y
    # CONFIG_MMC_HS400_SUPPORT is not set
    # CONFIG_SPL_MMC_HS400_SUPPORT is not set
    # CONFIG_MMC_HS200_SUPPORT is not set
    # CONFIG_SPL_MMC_HS200_SUPPORT is not set
    CONFIG_MMC_VERBOSE=y
    # CONFIG_SPL_MMC_TINY is not set
    # CONFIG_MMC_DW is not set
    # CONFIG_MMC_MXC is not set
    # CONFIG_MMC_MXS is not set
    # CONFIG_MMC_PCI is not set
    # CONFIG_MMC_SDHCI is not set
    # CONFIG_FTSDC010 is not set
    # MTD Support
    # CONFIG_MTD is not set
    # CONFIG_MTD_NOR_FLASH is not set
    # CONFIG_NAND is not set
    # SPI Flash Support
    CONFIG_SPI_FLASH=y
    CONFIG_SPI_FLASH_BAR=y
    # CONFIG_SF_DUAL_FLASH is not set
    # CONFIG_SPI_FLASH_ATMEL is not set
    # CONFIG_SPI_FLASH_EON is not set
    # CONFIG_SPI_FLASH_GIGADEVICE is not set
    # CONFIG_SPI_FLASH_MACRONIX is not set
    # CONFIG_SPI_FLASH_STMICRO is not set
    # CONFIG_SPI_FLASH_SST is not set
    # CONFIG_SPI_FLASH_WINBOND is not set
    CONFIG_SPI_FLASH_USE_4K_SECTORS=y
    # CONFIG_SPI_FLASH_DATAFLASH is not set
    # CONFIG_SPI_FLASH_MTD is not set
    # UBI support
    # CONFIG_MTD_UBI is not set
    # CONFIG_BITBANGMII is not set
    # CONFIG_MV88E6352_SWITCH is not set
    CONFIG_PHYLIB=y
    # CONFIG_MV88E61XX_SWITCH is not set
    # CONFIG_PHYLIB_10G is not set
    # CONFIG_PHY_AQUANTIA is not set
    # CONFIG_PHY_ATHEROS is not set
    # CONFIG_PHY_BROADCOM is not set
    # CONFIG_PHY_CORTINA is not set
    # CONFIG_PHY_DAVICOM is not set
    # CONFIG_PHY_ET1011C is not set
    # CONFIG_PHY_LXT is not set
    # CONFIG_PHY_MARVELL is not set
    # CONFIG_PHY_MESON_GXL is not set
    CONFIG_PHY_MICREL=y
    # CONFIG_PHY_MICREL_KSZ8XXX is not set
    # CONFIG_PHY_MSCC is not set
    # CONFIG_PHY_NATSEMI is not set
    # CONFIG_PHY_REALTEK is not set
    # CONFIG_PHY_SMSC is not set
    # CONFIG_PHY_TERANETICS is not set
    # CONFIG_PHY_TI is not set
    # CONFIG_PHY_VITESSE is not set
    # CONFIG_PHY_XILINX is not set
    # CONFIG_PHY_FIXED is not set
    CONFIG_DM_ETH=y
    CONFIG_NETDEVICES=y
    CONFIG_PHY_GIGE=y
    # CONFIG_ALTERA_TSE is not set
    # CONFIG_BCM_SF2_ETH is not set
    # CONFIG_DWC_ETH_QOS is not set
    # CONFIG_E1000 is not set
    # CONFIG_ETH_DESIGNWARE is not set
    # CONFIG_ETHOC is not set
    # CONFIG_FTMAC100 is not set
    # CONFIG_MACB is not set
    # CONFIG_RGMII is not set
    # CONFIG_RTL8139 is not set
    # CONFIG_RTL8169 is not set
    # CONFIG_SMC911X is not set
    # CONFIG_SUN7I_GMAC is not set
    # CONFIG_SUN4I_EMAC is not set
    # CONFIG_SUN8I_EMAC is not set
    # CONFIG_PCI is not set
    # PHY Subsystem
    CONFIG_PHY=y
    # CONFIG_SPL_PHY is not set
    # CONFIG_NOP_PHY is not set
    CONFIG_PIPE3_PHY=y
    # CONFIG_AM654_MMC_PHY is not set
    # CONFIG_MVEBU_COMPHY_SUPPORT is not set
    # Pin controllers
    # CONFIG_PINCTRL is not set
    # CONFIG_SPL_PINCTRL is not set
    # Power
    # Power Domain Support
    # CONFIG_POWER_DOMAIN is not set
    CONFIG_DM_PMIC=y
    CONFIG_PMIC_CHILDREN=y
    CONFIG_SPL_PMIC_CHILDREN=y
    # CONFIG_PMIC_ACT8846 is not set
    # CONFIG_PMIC_AS3722 is not set
    # CONFIG_DM_PMIC_PFUZE100 is not set
    # CONFIG_DM_PMIC_MAX77686 is not set
    # CONFIG_DM_PMIC_MAX8998 is not set
    # CONFIG_PMIC_MAX8997 is not set
    # CONFIG_PMIC_PM8916 is not set
    # CONFIG_PMIC_RK8XX is not set
    # CONFIG_PMIC_S2MPS11 is not set
    # CONFIG_DM_PMIC_SANDBOX is not set
    # CONFIG_PMIC_S5M8767 is not set
    # CONFIG_PMIC_RN5T567 is not set
    # CONFIG_PMIC_TPS65090 is not set
    # CONFIG_PMIC_LP873X is not set
    # CONFIG_PMIC_LP87565 is not set
    # CONFIG_POWER_MC34VR500 is not set
    # CONFIG_DM_PMIC_TPS65910 is not set
    # CONFIG_SPL_DM_REGULATOR is not set
    # CONFIG_REGULATOR_PWM is not set
    # CONFIG_DM_REGULATOR_FIXED is not set
    # CONFIG_DM_REGULATOR_GPIO is not set
    CONFIG_DM_REGULATOR_PBIAS=y
    # CONFIG_DM_PWM is not set
    # CONFIG_PWM_SANDBOX is not set
    # CONFIG_RAM is not set
    # Remote Processor drivers
    # Reset Controller Support
    # CONFIG_DM_RESET is not set
    # Real Time Clock
    # CONFIG_DM_RTC is not set
    # CONFIG_RTC_S35392A is not set
    CONFIG_SCSI=y
    # Serial drivers
    CONFIG_BAUDRATE=115200
    CONFIG_REQUIRE_SERIAL_CONSOLE=y
    CONFIG_SERIAL_PRESENT=y
    CONFIG_SPL_SERIAL_PRESENT=y
    CONFIG_DM_SERIAL=y
    # CONFIG_SERIAL_RX_BUFFER is not set
    CONFIG_SPL_DM_SERIAL=y
    # CONFIG_TPL_DM_SERIAL is not set
    # CONFIG_DEBUG_UART_SKIP_INIT is not set
    # CONFIG_ALTERA_JTAG_UART is not set
    # CONFIG_ALTERA_UART is not set
    # CONFIG_ATMEL_USART is not set
    # CONFIG_FSL_LPUART is not set
    # CONFIG_MVEBU_A3700_UART is not set
    # CONFIG_NULLDEV_SERIAL is not set
    CONFIG_SYS_NS16550=y
    # CONFIG_MSM_SERIAL is not set
    # CONFIG_PXA_SERIAL is not set
    # Sound support
    # CONFIG_SOUND is not set
    # SOC (System On Chip) specific Drivers
    # CONFIG_SOC_TI is not set
    # SPI Support
    CONFIG_DM_SPI=y
    # CONFIG_ALTERA_SPI is not set
    # CONFIG_CADENCE_QSPI is not set
    # CONFIG_DESIGNWARE_SPI is not set
    # CONFIG_EXYNOS_SPI is not set
    # CONFIG_FSL_DSPI is not set
    # CONFIG_ICH_SPI is not set
    # CONFIG_MVEBU_A3700_SPI is not set
    # CONFIG_ROCKCHIP_SPI is not set
    # CONFIG_TEGRA114_SPI is not set
    # CONFIG_TEGRA20_SFLASH is not set
    # CONFIG_TEGRA20_SLINK is not set
    # CONFIG_TEGRA210_QSPI is not set
    # CONFIG_XILINX_SPI is not set
    # CONFIG_SOFT_SPI is not set
    # CONFIG_FSL_ESPI is not set
    # CONFIG_FSL_QSPI is not set
    # CONFIG_ATCSPI200_SPI is not set
    CONFIG_TI_QSPI=y
    # CONFIG_OMAP3_SPI is not set
    # SPMI support
    # CONFIG_SPMI is not set
    # System reset device drivers
    # CONFIG_SYSRESET is not set
    # CONFIG_SYSRESET_SYSCON is not set
    # CONFIG_SYSRESET_WATCHDOG is not set
    CONFIG_DM_THERMAL=y
    CONFIG_TI_DRA7_THERMAL=y
    # Timer Support
    # CONFIG_TIMER is not set
    # TPM support
    CONFIG_USB=y
    CONFIG_DM_USB=y
    # USB Host Controller Drivers
    CONFIG_USB_HOST=y
    # CONFIG_USB_XHCI_PCI is not set
    CONFIG_USB_XHCI_DRA7XX_INDEX=0
    CONFIG_USB_DM_XHCI_OMAP=y
    # CONFIG_USB_XHCI_FSL is not set
    # CONFIG_USB_EHCI_HCD is not set
    # CONFIG_USB_OHCI_HCD is not set
    # CONFIG_USB_UHCI_HCD is not set
    # CONFIG_USB_DWC2 is not set
    CONFIG_USB_DWC3=y
    # CONFIG_USB_DWC3_HOST is not set
    CONFIG_USB_DWC3_GADGET=y
    # Platform Glue Driver Support
    CONFIG_USB_DWC3_OMAP=y
    # PHY Subsystem
    CONFIG_USB_DWC3_PHY_OMAP=y
    # CONFIG_USB_DWC3_PHY_SAMSUNG is not set
    # MUSB Controller Driver
    # CONFIG_USB_MUSB_HOST is not set
    # CONFIG_USB_MUSB_GADGET is not set
    # CONFIG_USB_MUSB_TI is not set
    # ULPI drivers
    # USB peripherals
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_KEYBOARD is not set
    CONFIG_USB_GADGET=y
    # CONFIG_USB_GADGET_ATMEL_USBA is not set
    # CONFIG_USB_GADGET_BCM_UDC_OTG_PHY is not set
    # CONFIG_USB_GADGET_DWC2_OTG is not set
    # CONFIG_CI_UDC is not set
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_DUALSPEED=y
    CONFIG_USB_GADGET_DOWNLOAD=y
    # CONFIG_USB_FUNCTION_SDP is not set
    # CONFIG_USB_ETHER is not set
    # CONFIG_USB_HOST_ETHER is not set
    # Graphics support
    # CONFIG_DM_VIDEO is not set
    # CONFIG_SYS_WHITE_ON_BLACK is not set
    # CONFIG_NO_FB_CLEAR is not set
    # TrueType Fonts
    # CONFIG_VIDEO_VESA is not set
    # CONFIG_VIDEO_LCD_ANX9804 is not set
    # CONFIG_VIDEO_LCD_SSD2828 is not set
    # CONFIG_VIDEO_MVEBU is not set
    # CONFIG_I2C_EDID is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_VIDEO_TEGRA20 is not set
    # CONFIG_VIDEO_BRIDGE is not set
    # CONFIG_VIDEO is not set
    # CONFIG_LCD is not set
    # CONFIG_VIDEO_SIMPLE is not set
    # CONFIG_VIDEO_DT_SIMPLEFB is not set
    # Watchdog Timer Support
    # CONFIG_BCM2835_WDT is not set
    # CONFIG_OMAP_WATCHDOG is not set
    # CONFIG_ULP_WATCHDOG is not set
    # CONFIG_WDT is not set
    # CONFIG_PHYS_TO_BUS is not set
    # File systems
    # CONFIG_FS_BTRFS is not set
    # CONFIG_FS_CBFS is not set
    CONFIG_FS_FAT=y
    CONFIG_FAT_WRITE=y
    CONFIG_FS_FAT_MAX_CLUSTSIZE=65536
    # CONFIG_FS_JFFS2 is not set
    # CONFIG_FS_CRAMFS is not set
    # CONFIG_YAFFS2 is not set
    # Library routines
    # CONFIG_BCH is not set
    # CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set
    # CONFIG_DYNAMIC_CRC_TABLE is not set
    CONFIG_HAVE_PRIVATE_LIBGCC=y
    CONFIG_USE_PRIVATE_LIBGCC=y
    CONFIG_SYS_HZ=1000
    # CONFIG_USE_TINY_PRINTF is not set
    # CONFIG_PANIC_HANG is not set
    CONFIG_REGEX=y
    # CONFIG_LIB_RAND is not set
    # CONFIG_SPL_TINY_MEMSET is not set
    # CONFIG_TPL_TINY_MEMSET is not set
    # CONFIG_BITREVERSE is not set
    # CONFIG_CMD_DHRYSTONE is not set
    # Security support
    # CONFIG_AES is not set
    # CONFIG_RSA is not set
    # CONFIG_TPM is not set
    # Hashing Support
    CONFIG_SHA1=y
    CONFIG_SHA256=y
    # CONFIG_SHA_HW_ACCEL is not set
    CONFIG_MD5=y
    # Compression Support
    # CONFIG_LZ4 is not set
    # CONFIG_LZMA is not set
    # CONFIG_LZO is not set
    # CONFIG_SPL_LZO is not set
    # CONFIG_SPL_GZIP is not set
    # CONFIG_ERRNO_STR is not set
    CONFIG_OF_LIBFDT=y
    CONFIG_OF_LIBFDT_OVERLAY=y
    CONFIG_SPL_OF_LIBFDT=y
    # CONFIG_FDT_FIXUP_PARTITIONS is not set
    # System tables
    CONFIG_GENERATE_SMBIOS_TABLE=y
    CONFIG_SMBIOS_MANUFACTURER="ti"
    CONFIG_EFI_LOADER=y
    # CONFIG_UNIT_TEST is not set
    Roshan Rajagopal
  • Roshan,
    For GP boards, am57xx_evm_defconfig is the proper config. And yes, my suggestion is to follow the conventions on the newer u-boot release.
    I believe other customers are using this still on newer versions: see https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1458019/am5726-how-to-support-4gb-ddr
    As well as the following App note: https://www.ti.com/lit/an/sprac36e/sprac36e.pdf?ts=1735896379982
    Josue
    I finally got the board to boot atleast little bit and print on the serial console.
    but now i am getting another error , could you help me out.
    I am getting it like below
    U-Boot SPL 2021.01-00003-g16d964ac27-dirty (Mar 21 2025 - 12:41:32 +0530)
    DRA752-GP ES2.0
    Trying to boot from MMC1
    no pinctrl state for default mode
    spl: could not find mmc device 0. error: -19
    SPL: failed to boot from all boot devices
    ### ERROR ### Please RESET the board ###
    So i enabled #DEBUG in evm.h and i got the below prints
    U-Boot SPL 2021.01-00003-g16d964ac27-dirty (Mar 21 2025 - 15:50:21 +0530)
    DRA752-GP ES2.0
    0 0
       - -1 -1 'mmc@4809c000'
       - -1 -1 'mmc@480b4000'
       - not found
    1 0
       - not found
    size=x, ptr=68, limit=90: 81f00028
    size=x, ptr=4, limit=94: 81f00090
    DEBUG: devfdt_get_addr_index() called for device: mmc@4809c000
    DEBUG: gd->fdt_blob = 4031cc40
    fdtdec_get_addr_size_auto_parent: na=1, ns=1, fdtdec_get_addr_size_fixed: reg: addr=00000000x
    DEBUG: fdtdec_get_addr_size_auto_parent() returned = 4809c000
    ofnode_read_u32_index: bus-width: x (4)
    ofnode_read_u32_index: max-frequency: x (192000000)
    ofnode_read_bool: cap-sd-highspeed: false
    ofnode_read_bool: cap-mmc-highspeed: false
    ofnode_read_bool: sd-uhs-sdr12: false
    ofnode_read_bool: sd-uhs-sdr25: false
    ofnode_read_bool: sd-uhs-sdr50: false
    ofnode_read_bool: sd-uhs-sdr104: false
    ofnode_read_bool: sd-uhs-ddr50: false
    ofnode_read_bool: mmc-ddr-1_8v: false
    ofnode_read_bool: mmc-ddr-1_2v: false
    ofnode_read_bool: mmc-hs200-1_8v: false
    ofnode_read_bool: mmc-hs200-1_2v: false
    ofnode_read_bool: mmc-hs400-1_8v: false
    ofnode_read_bool: mmc-hs400-1_2v: false
    ofnode_read_bool: mmc-hs400-enhanced-strobe: false
    ofnode_read_bool: non-removable: false
    ofnode_read_bool: cd-inverted: false
    ofnode_read_bool: broken-cd: false
    ofnode_read_bool: no-1-8-v: true
    fdtdec_get_bool: ti,dual-volt
    fdtdec_get_bool: no-1-8-v
    0 -1
    0 0
       - not found
    size=x, ptr=178, limit=20c: 81f00094
    fdtdec_get_int: #gpio-cells: x (2)
    size=x, ptr=6, limit=212: 81f0020c
    gpio_request_tail: Node 'mmc@4809c000', property 'wp-gpios', failed to request GPIO index 0: -2
    size=x, ptr=10, limit=224: 81f00214
    fail to find default mode FDT_ERR_NOTFOUND
    with some of the debug mesages i printed in fdtaddr.c
    but if i boot ith my older SDK 5.03 i get prints like this and it boots
    U-Boot SPL 2018.01-00569-gfd38f5afef-dirty (Mar 21 2025 - 14:13:50)
    DRA752-GP ES2.0
    omap24_i2c_findpsc: speed [kHz]: 100 psc: 0x17 sscl: 0xd ssch: 0xf
    uclass_find_device_by_seq: 0 0
       - not found
    uclass_find_device_by_seq: 1 0
       - not found
    malloc_simple: size=6c, ptr=94, limit=100000: 81f00028
    malloc_simple: size=4, ptr=98, limit=100000: 81f00094
    uclass_find_device_by_seq: 0 -1
       - not found
    fdtdec_get_addr_size_auto_parent: na=1, ns=1, fdtdec_get_addr_size_fixed: reg: addr=4809c000
    ofnode_read_u32: bus-width: 0x4 (4)
    ofnode_read_u32: max-frequency: 0xb71b000 (192000000)
    fdtdec_get_bool: cd-inverted
    malloc_simple: size=170, ptr=208, limit=100000: 81f00098
    fdtdec_get_int: #gpio-cells: 0x2 (2)
    malloc_simple: size=16, ptr=21e, limit=100000: 81f00208
    malloc_simple: size=10, ptr=230, limit=100000: 81f00220
    malloc_simple: size=6c, ptr=29c, limit=100000: 81f00230
    malloc_simple: size=4, ptr=2a0, limit=100000: 81f0029c
       - -1 0 'mmc@4809c000'
       - found
    uclass_find_device_by_seq: 0 1
       - not found
    fdtdec_get_addr_size_auto_parent: na=1, ns=1, fdtdec_get_addr_size_fixed: reg: addr=480b4000
    ofnode_read_u32: bus-width: 0x8 (8)
    ofnode_read_bool: sd-uhs-sdr12: true
    ofnode_read_bool: sd-uhs-sdr25: true
    ofnode_read_bool: mmc-ddr-1_8v: true
    malloc_simple: size=170, ptr=410, limit=100000: 81f002a0
    gpio_request_tail: Node 'mmc@480b4000', property 'cd-gpios', failed to request GPIO index 0: -2
    gpio_request_tail: Node 'mmc@480b4000', property 'wp-gpios', failed to request GPIO index 0: -2
    malloc_simple: size=10, ptr=420, limit=100000: 81f00410
    81f00440
    81f00480
    81f004c0
    81f00500
    part_init: try 'EFI': ret=-1
    81f00540
    part_init: try 'DOS': ret=0
    spl: mmc boot mode: fs
    81f00580
    malloc_simple: size=200, ptr=788, limit=100000: 81f00588
    81f007c0
    81f00800
    81f00840
    81f00880
    part_init: try 'DOS': ret=-1
    81f008c0
    part_init: try 'ISO': ret=-1
    fdtdec_get_config_string: u-boot,mmc-env-partition
    fdtdec_get_config_int: u-boot,mmc-env-offset
    fdtdec_get_config_int: u-boot,mmc-env-offset-redundant
    81f00900
    81f00940
    *** Warning - bad CRC, using default environment
    malloc_simple: size=1d0d, ptr=2665, limit=100000: 81f00958
    Destroy Hash Table: 4031dfec table = 00000000
    Create Hash Table: N=512
    malloc_simple: size=28c8, ptr=4f30, limit=100000: 81f02668
    malloc_simple: size=9, ptr=4f39, limit=100000: 81f04f30
    malloc_simple: size=72, ptr=4fae, limit=100000: 81f04f3c
    malloc_simple: size=16, ptr=4fc6, limit=100000: 81f04fb0
    malloc_simple: size=e, ptr=4fd6, limit=100000: 81f04fc8
    malloc_simple: size=12, ptr=4fea, limit=100000: 81f04fd8
    malloc_simple: size=12, ptr=4ffe, limit=100000: 81f04fec
    malloc_simple: size=e, ptr=500e, limit=100000: 81f05000
    malloc_simple: size=14, ptr=5024, limit=100000: 81f05010
    malloc_simple: size=10, ptr=5034, limit=100000: 81f05024
    malloc_simple: size=12, ptr=5046, limit=100000: 81f05034
    malloc_simple: size=c, ptr=5054, limit=100000: 81f05048
    malloc_simple: size=a, ptr=505e, limit=100000: 81f05054
    malloc_simple: size=13, ptr=5073, limit=100000: 81f05060
    malloc_simple: size=12, ptr=5086, limit=100000: 81f05074
    malloc_simple: size=e, ptr=5096, limit=100000: 81f05088
    malloc_simple: size=f, ptr=50a7, limit=100000: 81f05098
    malloc_simple: size=f, ptr=50b7, limit=100000: 81f050a8
    malloc_simple: size=11, ptr=50c9, limit=100000: 81f050b8
    malloc_simple: size=e, ptr=50da, limit=100000: 81f050cc
    malloc_simple: size=9, ptr=50e5, limit=100000: 81f050dc
    malloc_simple: size=c, ptr=50f4, limit=100000: 81f050e8
    malloc_simple: size=a, ptr=50fe, limit=100000: 81f050f4
    malloc_simple: size=b, ptr=510b, limit=100000: 81f05100
    malloc_simple: size=8, ptr=5114, limit=100000: 81f0510c
    malloc_simple: size=7, ptr=511b, limit=100000: 81f05114
    malloc_simple: size=8, ptr=5124, limit=100000: 81f0511c
    INSERT: table 4031dfec, filled 1/521 rv 81f04e94 ==> name="bootargs" value="androidboot.serialno=${serial#} console=t"
    malloc_simple: size=8, ptr=512c, limit=100000: 81f05124
    malloc_simple: size=12d, ptr=5259, limit=100000: 81f0512c
    malloc_simple: size=16, ptr=5272, limit=100000: 81f0525c
    malloc_simple: size=e, ptr=5282, limit=100000: 81f05274
    malloc_simple: size=12, ptr=5296, limit=100000: 81f05284
    malloc_simple: size=12, ptr=52aa, limit=100000: 81f05298
    malloc_simple: size=e, ptr=52ba, limit=100000: 81f052ac
    malloc_simple: size=14, ptr=52d0, limit=100000: 81f052bc
    malloc_simple: size=10, ptr=52e0, limit=100000: 81f052d0
    malloc_simple: size=12, ptr=52f2, limit=100000: 81f052e0
    malloc_simple: size=c, ptr=5300, limit=100000: 81f052f4
    malloc_simple: size=a, ptr=530a, limit=100000: 81f05300
    malloc_simple: size=13, ptr=531f, limit=100000: 81f0530c
    malloc_simple: size=12, ptr=5332, limit=100000: 81f05320
    malloc_simple: size=e, ptr=5342, limit=100000: 81f05334
    malloc_simple: size=f, ptr=5353, limit=100000: 81f05344
    malloc_simple: size=f, ptr=5363, limit=100000: 81f05354
    malloc_simple: size=11, ptr=5375, limit=100000: 81f05364
    malloc_simple: size=e, ptr=5386, limit=100000: 81f05378
    malloc_simple: size=9, ptr=5391, limit=100000: 81f05388
    malloc_simple: size=c, ptr=53a0, limit=100000: 81f05394
    malloc_simple: size=a, ptr=53aa, limit=100000: 81f053a0
    malloc_simple: size=b, ptr=53b7, limit=100000: 81f053ac
    malloc_simple: size=8, ptr=53c0, limit=100000: 81f053b8
    malloc_simple: size=7, ptr=53c7, limit=100000: 81f053c0
    malloc_simple: size=8, ptr=53d0, limit=100000: 81f053c8
    INSERT: table 4031dfec, filled 2/521 rv 81f03724 ==> name="bootcmd" value="if test ${dofastboot} -eq 1; then echo Boo"
    malloc_simple: size=a, ptr=53da, limit=100000: 81f053d0
    malloc_simple: size=2, ptr=53de, limit=100000: 81f053dc
    malloc_simple: size=16, ptr=53f6, limit=100000: 81f053e0
    malloc_simple: size=e, ptr=5406, limit=100000: 81f053f8
    malloc_simple: size=12, ptr=541a, limit=100000: 81f05408
    malloc_simple: size=12, ptr=542e, limit=100000: 81f0541c
    malloc_simple: size=e, ptr=543e, limit=100000: 81f05430
    malloc_simple: size=14, ptr=5454, limit=100000: 81f05440
    malloc_simple: size=10, ptr=5464, limit=100000: 81f05454
    malloc_simple: size=12, ptr=5476, limit=100000: 81f05464
    malloc_simple: size=c, ptr=5484, limit=100000: 81f05478
    malloc_simple: size=a, ptr=548e, limit=100000: 81f05484
    malloc_simple: size=13, ptr=54a3, limit=100000: 81f05490
    malloc_simple: size=12, ptr=54b6, limit=100000: 81f054a4
    malloc_simple: size=e, ptr=54c6, limit=100000: 81f054b8
    malloc_simple: size=f, ptr=54d7, limit=100000: 81f054c8
    malloc_simple: size=f, ptr=54e7, limit=100000: 81f054d8
    malloc_simple: size=11, ptr=54f9, limit=100000: 81f054e8
    malloc_simple: size=e, ptr=550a, limit=100000: 81f054fc
    malloc_simple: size=9, ptr=5515, limit=100000: 81f0550c
    malloc_simple: size=c, ptr=5524, limit=100000: 81f05518
    malloc_simple: size=a, ptr=552e, limit=100000: 81f05524
    malloc_simple: size=b, ptr=553b, limit=100000: 81f05530
    malloc_simple: size=8, ptr=5544, limit=100000: 81f0553c
    malloc_simple: size=7, ptr=554b, limit=100000: 81f05544
    malloc_simple: size=8, ptr=5554, limit=100000: 81f0554c
    INSERT: table 4031dfec, filled 3/521 rv 81f03f80 ==> name="bootdelay" value="2"
    malloc_simple: size=9, ptr=555d, limit=100000: 81f05554
    malloc_simple: size=7, ptr=5567, limit=100000: 81f05560
    malloc_simple: size=16, ptr=557e, limit=100000: 81f05568
    malloc_simple: size=e, ptr=558e, limit=100000: 81f05580
    malloc_simple: size=12, ptr=55a2, limit=100000: 81f05590
    malloc_simple: size=b, ptr=55af, limit=100000: 81f055a4
    malloc_simple: size=9, ptr=55b9, limit=100000: 81f055b0
    malloc_simple: size=12, ptr=55ce, limit=100000: 81f055bc
    malloc_simple: size=e, ptr=55de, limit=100000: 81f055d0
    malloc_simple: size=14, ptr=55f4, limit=100000: 81f055e0
    malloc_simple: size=10, ptr=5604, limit=100000: 81f055f4
    malloc_simple: size=12, ptr=5616, limit=100000: 81f05604
    malloc_simple: size=c, ptr=5624, limit=100000: 81f05618
    malloc_simple: size=a, ptr=562e, limit=100000: 81f05624
    malloc_simple: size=13, ptr=5643, limit=100000: 81f05630
    malloc_simple: size=12, ptr=5656, limit=100000: 81f05644
    malloc_simple: size=e, ptr=5666, limit=100000: 81f05658
    malloc_simple: size=f, ptr=5677, limit=100000: 81f05668
    malloc_simple: size=f, ptr=5687, limit=100000: 81f05678
    malloc_simple: size=11, ptr=5699, limit=100000: 81f05688
    malloc_simple: size=e, ptr=56aa, limit=100000: 81f0569c
    malloc_simple: size=9, ptr=56b5, limit=100000: 81f056ac
    malloc_simple: size=c, ptr=56c4, limit=100000: 81f056b8
    malloc_simple: size=a, ptr=56ce, limit=100000: 81f056c4
    malloc_simple: size=b, ptr=56db, limit=100000: 81f056d0
    malloc_simple: size=8, ptr=56e4, limit=100000: 81f056dc
    malloc_simple: size=7, ptr=56eb, limit=100000: 81f056e4
    malloc_simple: size=8, ptr=56f4, limit=100000: 81f056ec
    INSERT: table 4031dfec, filled 4/521 rv 81f03300 ==> name="baudrate" value="115200"
    malloc_simple: size=5, ptr=56f9, limit=100000: 81f056f4
    malloc_simple: size=4, ptr=5700, limit=100000: 81f056fc
    malloc_simple: size=16, ptr=5716, limit=100000: 81f05700
    malloc_simple: size=e, ptr=5726, limit=100000: 81f05718
    malloc_simple: size=12, ptr=573a, limit=100000: 81f05728
    malloc_simple: size=12, ptr=574e, limit=100000: 81f0573c
    malloc_simple: size=e, ptr=575e, limit=100000: 81f05750
    malloc_simple: size=14, ptr=5774, limit=100000: 81f05760
    malloc_simple: size=10, ptr=5784, limit=100000: 81f05774
    malloc_simple: size=12, ptr=5796, limit=100000: 81f05784
    malloc_simple: size=c, ptr=57a4, limit=100000: 81f05798
    malloc_simple: size=a, ptr=57ae, limit=100000: 81f057a4
    malloc_simple: size=13, ptr=57c3, limit=100000: 81f057b0
    malloc_simple: size=12, ptr=57d6, limit=100000: 81f057c4
    malloc_simple: size=e, ptr=57e6, limit=100000: 81f057d8
    malloc_simple: size=f, ptr=57f7, limit=100000: 81f057e8
    malloc_simple: size=f, ptr=5807, limit=100000: 81f057f8
    malloc_simple: size=11, ptr=5819, limit=100000: 81f05808
    malloc_simple: size=e, ptr=582a, limit=100000: 81f0581c
    malloc_simple: size=9, ptr=5835, limit=100000: 81f0582c
    malloc_simple: size=c, ptr=5844, limit=100000: 81f05838
    malloc_simple: size=a, ptr=584e, limit=100000: 81f05844
    malloc_simple: size=b, ptr=585b, limit=100000: 81f05850
    malloc_simple: size=8, ptr=5864, limit=100000: 81f0585c
    malloc_simple: size=7, ptr=586b, limit=100000: 81f05864
    malloc_simple: size=8, ptr=5874, limit=100000: 81f0586c
    INSERT: table 4031dfec, filled 5/521 rv 81f02b1c ==> name="arch" value="arm"
    malloc_simple: size=4, ptr=5878, limit=100000: 81f05874
    malloc_simple: size=6, ptr=587e, limit=100000: 81f05878
    malloc_simple: size=16, ptr=5896, limit=100000: 81f05880
    malloc_simple: size=e, ptr=58a6, limit=100000: 81f05898
    malloc_simple: size=12, ptr=58ba, limit=100000: 81f058a8
    malloc_simple: size=12, ptr=58ce, limit=100000: 81f058bc
    malloc_simple: size=e, ptr=58de, limit=100000: 81f058d0
    malloc_simple: size=14, ptr=58f4, limit=100000: 81f058e0
    malloc_simple: size=10, ptr=5904, limit=100000: 81f058f4
    malloc_simple: size=12, ptr=5916, limit=100000: 81f05904
    malloc_simple: size=c, ptr=5924, limit=100000: 81f05918
    malloc_simple: size=a, ptr=592e, limit=100000: 81f05924
    malloc_simple: size=13, ptr=5943, limit=100000: 81f05930
    malloc_simple: size=12, ptr=5956, limit=100000: 81f05944
    malloc_simple: size=e, ptr=5966, limit=100000: 81f05958
    malloc_simple: size=f, ptr=5977, limit=100000: 81f05968
    malloc_simple: size=f, ptr=5987, limit=100000: 81f05978
    malloc_simple: size=11, ptr=5999, limit=100000: 81f05988
    malloc_simple: size=e, ptr=59aa, limit=100000: 81f0599c
    malloc_simple: size=9, ptr=59b5, limit=100000: 81f059ac
    malloc_simple: size=c, ptr=59c4, limit=100000: 81f059b8
    malloc_simple: size=a, ptr=59ce, limit=100000: 81f059c4
    malloc_simple: size=b, ptr=59db, limit=100000: 81f059d0
    malloc_simple: size=8, ptr=59e4, limit=100000: 81f059dc
    malloc_simple: size=7, ptr=59eb, limit=100000: 81f059e4
    malloc_simple: size=8, ptr=59f4, limit=100000: 81f059ec
    INSERT: table 4031dfec, filled 6/521 rv 81f04318 ==> name="cpu" value="armv7"
    malloc_simple: size=6, ptr=59fa, limit=100000: 81f059f4
    malloc_simple: size=7, ptr=5a03, limit=100000: 81f059fc
    malloc_simple: size=16, ptr=5a1a, limit=100000: 81f05a04
    malloc_simple: size=e, ptr=5a2a, limit=100000: 81f05a1c
    malloc_simple: size=12, ptr=5a3e, limit=100000: 81f05a2c
    malloc_simple: size=12, ptr=5a52, limit=100000: 81f05a40
    malloc_simple: size=e, ptr=5a62, limit=100000: 81f05a54
    malloc_simple: size=14, ptr=5a78, limit=100000: 81f05a64
    malloc_simple: size=10, ptr=5a88, limit=100000: 81f05a78
    malloc_simple: size=12, ptr=5a9a, limit=100000: 81f05a88
    malloc_simple: size=c, ptr=5aa8, limit=100000: 81f05a9c
    malloc_simple: size=a, ptr=5ab2, limit=100000: 81f05aa8
    malloc_simple: size=13, ptr=5ac7, limit=100000: 81f05ab4
    malloc_simple: size=12, ptr=5ada, limit=100000: 81f05ac8
    malloc_simple: size=e, ptr=5aea, limit=100000: 81f05adc
    malloc_simple: size=f, ptr=5afb, limit=100000: 81f05aec
    malloc_simple: size=f, ptr=5b0b, limit=100000: 81f05afc
    malloc_simple: size=11, ptr=5b1d, limit=100000: 81f05b0c
    malloc_simple: size=e, ptr=5b2e, limit=100000: 81f05b20
    malloc_simple: size=9, ptr=5b39, limit=100000: 81f05b30
    malloc_simple: size=c, ptr=5b48, limit=100000: 81f05b3c
    malloc_simple: size=a, ptr=5b52, limit=100000: 81f05b48
    malloc_simple: size=b, ptr=5b5f, limit=100000: 81f05b54
    malloc_simple: size=8, ptr=5b68, limit=100000: 81f05b60
    malloc_simple: size=7, ptr=5b6f, limit=100000: 81f05b68
    malloc_simple: size=8, ptr=5b78, limit=100000: 81f05b70
    INSERT: table 4031dfec, filled 7/521 rv 81f03ad0 ==> name="board" value="am57xx"
    malloc_simple: size=b, ptr=5b83, limit=100000: 81f05b78
    malloc_simple: size=7, ptr=5b8b, limit=100000: 81f05b84
    malloc_simple: size=16, ptr=5ba2, limit=100000: 81f05b8c
    malloc_simple: size=e, ptr=5bb2, limit=100000: 81f05ba4
    malloc_simple: size=12, ptr=5bc6, limit=100000: 81f05bb4
    malloc_simple: size=12, ptr=5bda, limit=100000: 81f05bc8
    malloc_simple: size=e, ptr=5bea, limit=100000: 81f05bdc
    malloc_simple: size=14, ptr=5c00, limit=100000: 81f05bec
    malloc_simple: size=10, ptr=5c10, limit=100000: 81f05c00
    malloc_simple: size=12, ptr=5c22, limit=100000: 81f05c10
    malloc_simple: size=c, ptr=5c30, limit=100000: 81f05c24
    malloc_simple: size=a, ptr=5c3a, limit=100000: 81f05c30
    malloc_simple: size=13, ptr=5c4f, limit=100000: 81f05c3c
    malloc_simple: size=12, ptr=5c62, limit=100000: 81f05c50
    malloc_simple: size=e, ptr=5c72, limit=100000: 81f05c64
    malloc_simple: size=f, ptr=5c83, limit=100000: 81f05c74
    malloc_simple: size=f, ptr=5c93, limit=100000: 81f05c84
    malloc_simple: size=11, ptr=5ca5, limit=100000: 81f05c94
    malloc_simple: size=e, ptr=5cb6, limit=100000: 81f05ca8
    malloc_simple: size=9, ptr=5cc1, limit=100000: 81f05cb8
    malloc_simple: size=c, ptr=5cd0, limit=100000: 81f05cc4
    malloc_simple: size=a, ptr=5cda, limit=100000: 81f05cd0
    malloc_simple: size=b, ptr=5ce7, limit=100000: 81f05cdc
    malloc_simple: size=8, ptr=5cf0, limit=100000: 81f05ce8
    malloc_simple: size=7, ptr=5cf7, limit=100000: 81f05cf0
    malloc_simple: size=8, ptr=5d00, limit=100000: 81f05cf8
    INSERT: table 4031dfec, filled 8/521 rv 81f02dd8 ==> name="board_name" value="am57xx"
    malloc_simple: size=7, ptr=5d07, limit=100000: 81f05d00
    malloc_simple: size=3, ptr=5d0b, limit=100000: 81f05d08
    malloc_simple: size=16, ptr=5d22, limit=100000: 81f05d0c
    malloc_simple: size=e, ptr=5d32, limit=100000: 81f05d24
    malloc_simple: size=12, ptr=5d46, limit=100000: 81f05d34
    malloc_simple: size=12, ptr=5d5a, limit=100000: 81f05d48
    malloc_simple: size=e, ptr=5d6a, limit=100000: 81f05d5c
    malloc_simple: size=14, ptr=5d80, limit=100000: 81f05d6c
    malloc_simple: size=10, ptr=5d90, limit=100000: 81f05d80
    malloc_simple: size=12, ptr=5da2, limit=100000: 81f05d90
    malloc_simple: size=c, ptr=5db0, limit=100000: 81f05da4
    malloc_simple: size=a, ptr=5dba, limit=100000: 81f05db0
    malloc_simple: size=13, ptr=5dcf, limit=100000: 81f05dbc
    malloc_simple: size=12, ptr=5de2, limit=100000: 81f05dd0
    malloc_simple: size=e, ptr=5df2, limit=100000: 81f05de4
    malloc_simple: size=f, ptr=5e03, limit=100000: 81f05df4
    malloc_simple: size=f, ptr=5e13, limit=100000: 81f05e04
    malloc_simple: size=11, ptr=5e25, limit=100000: 81f05e14
    malloc_simple: size=e, ptr=5e36, limit=100000: 81f05e28
    malloc_simple: size=9, ptr=5e41, limit=100000: 81f05e38
    malloc_simple: size=c, ptr=5e50, limit=100000: 81f05e44
    malloc_simple: size=a, ptr=5e5a, limit=100000: 81f05e50
    malloc_simple: size=b, ptr=5e67, limit=100000: 81f05e5c
    malloc_simple: size=8, ptr=5e70, limit=100000: 81f05e68
    malloc_simple: size=7, ptr=5e77, limit=100000: 81f05e70
    malloc_simple: size=8, ptr=5e80, limit=100000: 81f05e78
    INSERT: table 4031dfec, filled 9/521 rv 81f043a4 ==> name="vendor" value="ti"
    malloc_simple: size=4, ptr=5e84, limit=100000: 81f05e80
    malloc_simple: size=6, ptr=5e8a, limit=100000: 81f05e84
    malloc_simple: size=16, ptr=5ea2, limit=100000: 81f05e8c
    malloc_simple: size=e, ptr=5eb2, limit=100000: 81f05ea4
    malloc_simple: size=12, ptr=5ec6, limit=100000: 81f05eb4
    malloc_simple: size=12, ptr=5eda, limit=100000: 81f05ec8
    malloc_simple: size=e, ptr=5eea, limit=100000: 81f05edc
    malloc_simple: size=14, ptr=5f00, limit=100000: 81f05eec
    malloc_simple: size=10, ptr=5f10, limit=100000: 81f05f00
    malloc_simple: size=12, ptr=5f22, limit=100000: 81f05f10
    malloc_simple: size=c, ptr=5f30, limit=100000: 81f05f24
    malloc_simple: size=a, ptr=5f3a, limit=100000: 81f05f30
    malloc_simple: size=13, ptr=5f4f, limit=100000: 81f05f3c
    malloc_simple: size=12, ptr=5f62, limit=100000: 81f05f50
    malloc_simple: size=e, ptr=5f72, limit=100000: 81f05f64
    malloc_simple: size=f, ptr=5f83, limit=100000: 81f05f74
    malloc_simple: size=f, ptr=5f93, limit=100000: 81f05f84
    malloc_simple: size=11, ptr=5fa5, limit=100000: 81f05f94
    malloc_simple: size=e, ptr=5fb6, limit=100000: 81f05fa8
    malloc_simple: size=9, ptr=5fc1, limit=100000: 81f05fb8
    malloc_simple: size=c, ptr=5fd0, limit=100000: 81f05fc4
    malloc_simple: size=a, ptr=5fda, limit=100000: 81f05fd0
    malloc_simple: size=b, ptr=5fe7, limit=100000: 81f05fdc
    malloc_simple: size=8, ptr=5ff0, limit=100000: 81f05fe8
    malloc_simple: size=7, ptr=5ff7, limit=100000: 81f05ff0
    malloc_simple: size=8, ptr=6000, limit=100000: 81f05ff8
    INSERT: table 4031dfec, filled 10/521 rv 81f0496c ==> name="soc" value="omap5"
    malloc_simple: size=9, ptr=6009, limit=100000: 81f06000
    malloc_simple: size=b, ptr=6017, limit=100000: 81f0600c
    malloc_simple: size=16, ptr=602e, limit=100000: 81f06018
    malloc_simple: size=e, ptr=603e, limit=100000: 81f06030
    malloc_simple: size=12, ptr=6052, limit=100000: 81f06040
    malloc_simple: size=12, ptr=6066, limit=100000: 81f06054
    malloc_simple: size=e, ptr=6076, limit=100000: 81f06068
    malloc_simple: size=14, ptr=608c, limit=100000: 81f06078
    malloc_simple: size=10, ptr=609c, limit=100000: 81f0608c
    malloc_simple: size=12, ptr=60ae, limit=100000: 81f0609c
    malloc_simple: size=c, ptr=60bc, limit=100000: 81f060b0
    malloc_simple: size=a, ptr=60c6, limit=100000: 81f060bc
    malloc_simple: size=13, ptr=60db, limit=100000: 81f060c8
    malloc_simple: size=12, ptr=60ee, limit=100000: 81f060dc
    malloc_simple: size=b, ptr=60fb, limit=100000: 81f060f0
    malloc_simple: size=9, ptr=6105, limit=100000: 81f060fc
    malloc_simple: size=e, ptr=6116, limit=100000: 81f06108
    malloc_simple: size=f, ptr=6127, limit=100000: 81f06118
    malloc_simple: size=f, ptr=6137, limit=100000: 81f06128
    malloc_simple: size=11, ptr=6149, limit=100000: 81f06138
    malloc_simple: size=e, ptr=615a, limit=100000: 81f0614c
    malloc_simple: size=9, ptr=6165, limit=100000: 81f0615c
    malloc_simple: size=c, ptr=6174, limit=100000: 81f06168
    malloc_simple: size=a, ptr=617e, limit=100000: 81f06174
    malloc_simple: size=b, ptr=618b, limit=100000: 81f06180
    malloc_simple: size=8, ptr=6194, limit=100000: 81f0618c
    malloc_simple: size=7, ptr=619b, limit=100000: 81f06194
    malloc_simple: size=8, ptr=61a4, limit=100000: 81f0619c
    INSERT: table 4031dfec, filled 11/521 rv 81f03e04 ==> name="loadaddr" value="0x82000000"
    malloc_simple: size=e, ptr=61b2, limit=100000: 81f061a4
    malloc_simple: size=b, ptr=61bf, limit=100000: 81f061b4
    malloc_simple: size=16, ptr=61d6, limit=100000: 81f061c0
    malloc_simple: size=e, ptr=61e6, limit=100000: 81f061d8
    malloc_simple: size=12, ptr=61fa, limit=100000: 81f061e8
    malloc_simple: size=12, ptr=620e, limit=100000: 81f061fc
    malloc_simple: size=e, ptr=621e, limit=100000: 81f06210
    malloc_simple: size=14, ptr=6234, limit=100000: 81f06220
    malloc_simple: size=10, ptr=6244, limit=100000: 81f06234
    malloc_simple: size=12, ptr=6256, limit=100000: 81f06244
    malloc_simple: size=c, ptr=6264, limit=100000: 81f06258
    malloc_simple: size=a, ptr=626e, limit=100000: 81f06264
    malloc_simple: size=13, ptr=6283, limit=100000: 81f06270
    malloc_simple: size=12, ptr=6296, limit=100000: 81f06284
    malloc_simple: size=e, ptr=62a6, limit=100000: 81f06298
    malloc_simple: size=f, ptr=62b7, limit=100000: 81f062a8
    malloc_simple: size=f, ptr=62c7, limit=100000: 81f062b8
    malloc_simple: size=11, ptr=62d9, limit=100000: 81f062c8
    malloc_simple: size=e, ptr=62ea, limit=100000: 81f062dc
    malloc_simple: size=9, ptr=62f5, limit=100000: 81f062ec
    malloc_simple: size=c, ptr=6304, limit=100000: 81f062f8
    malloc_simple: size=a, ptr=630e, limit=100000: 81f06304
    malloc_simple: size=b, ptr=631b, limit=100000: 81f06310
    malloc_simple: size=8, ptr=6324, limit=100000: 81f0631c
    malloc_simple: size=7, ptr=632b, limit=100000: 81f06324
    malloc_simple: size=8, ptr=6334, limit=100000: 81f0632c
    INSERT: table 4031dfec, filled 12/521 rv 81f03788 ==> name="kernel_addr_r" value="0x82000000"
    malloc_simple: size=8, ptr=633c, limit=100000: 81f06334
    malloc_simple: size=b, ptr=6347, limit=100000: 81f0633c
    malloc_simple: size=16, ptr=635e, limit=100000: 81f06348
    malloc_simple: size=e, ptr=636e, limit=100000: 81f06360
    malloc_simple: size=12, ptr=6382, limit=100000: 81f06370
    malloc_simple: size=12, ptr=6396, limit=100000: 81f06384
    malloc_simple: size=e, ptr=63a6, limit=100000: 81f06398
    malloc_simple: size=14, ptr=63bc, limit=100000: 81f063a8
    malloc_simple: size=10, ptr=63cc, limit=100000: 81f063bc
    malloc_simple: size=12, ptr=63de, limit=100000: 81f063cc
    malloc_simple: size=c, ptr=63ec, limit=100000: 81f063e0
    malloc_simple: size=a, ptr=63f6, limit=100000: 81f063ec
    malloc_simple: size=13, ptr=640b, limit=100000: 81f063f8
    malloc_simple: size=12, ptr=641e, limit=100000: 81f0640c
    malloc_simple: size=e, ptr=642e, limit=100000: 81f06420
    malloc_simple: size=f, ptr=643f, limit=100000: 81f06430
    malloc_simple: size=f, ptr=644f, limit=100000: 81f06440
    malloc_simple: size=11, ptr=6461, limit=100000: 81f06450
    malloc_simple: size=e, ptr=6472, limit=100000: 81f06464
    malloc_simple: size=9, ptr=647d, limit=100000: 81f06474
    malloc_simple: size=c, ptr=648c, limit=100000: 81f06480
    malloc_simple: size=a, ptr=6496, limit=100000: 81f0648c
    malloc_simple: size=b, ptr=64a3, limit=100000: 81f06498
    malloc_simple: size=8, ptr=64ac, limit=100000: 81f064a4
    malloc_simple: size=7, ptr=64b3, limit=100000: 81f064ac
    malloc_simple: size=8, ptr=64bc, limit=100000: 81f064b4
    INSERT: table 4031dfec, filled 13/521 rv 81f04124 ==> name="fdtaddr" value="0x88000000"
    malloc_simple: size=b, ptr=64c7, limit=100000: 81f064bc
    malloc_simple: size=b, ptr=64d3, limit=100000: 81f064c8
    malloc_simple: size=16, ptr=64ea, limit=100000: 81f064d4
    malloc_simple: size=e, ptr=64fa, limit=100000: 81f064ec
    malloc_simple: size=12, ptr=650e, limit=100000: 81f064fc
    malloc_simple: size=12, ptr=6522, limit=100000: 81f06510
    malloc_simple: size=e, ptr=6532, limit=100000: 81f06524
    malloc_simple: size=14, ptr=6548, limit=100000: 81f06534
    malloc_simple: size=10, ptr=6558, limit=100000: 81f06548
    malloc_simple: size=12, ptr=656a, limit=100000: 81f06558
    malloc_simple: size=c, ptr=6578, limit=100000: 81f0656c
    malloc_simple: size=a, ptr=6582, limit=100000: 81f06578
    malloc_simple: size=13, ptr=6597, limit=100000: 81f06584
    malloc_simple: size=12, ptr=65aa, limit=100000: 81f06598
    malloc_simple: size=e, ptr=65ba, limit=100000: 81f065ac
    malloc_simple: size=f, ptr=65cb, limit=100000: 81f065bc
    malloc_simple: size=f, ptr=65db, limit=100000: 81f065cc
    malloc_simple: size=11, ptr=65ed, limit=100000: 81f065dc
    malloc_simple: size=e, ptr=65fe, limit=100000: 81f065f0
    malloc_simple: size=9, ptr=6609, limit=100000: 81f06600
    malloc_simple: size=c, ptr=6618, limit=100000: 81f0660c
    malloc_simple: size=a, ptr=6622, limit=100000: 81f06618
    malloc_simple: size=b, ptr=662f, limit=100000: 81f06624
    malloc_simple: size=8, ptr=6638, limit=100000: 81f06630
    malloc_simple: size=7, ptr=663f, limit=100000: 81f06638
    malloc_simple: size=8, ptr=6648, limit=100000: 81f06640
    INSERT: table 4031dfec, filled 14/521 rv 81f030e4 ==> name="fdt_addr_r" value="0x88000000"
    malloc_simple: size=7, ptr=664f, limit=100000: 81f06648
    malloc_simple: size=b, ptr=665b, limit=100000: 81f06650
    malloc_simple: size=16, ptr=6672, limit=100000: 81f0665c
    malloc_simple: size=e, ptr=6682, limit=100000: 81f06674
    malloc_simple: size=12, ptr=6696, limit=100000: 81f06684
    malloc_simple: size=12, ptr=66aa, limit=100000: 81f06698
    malloc_simple: size=e, ptr=66ba, limit=100000: 81f066ac
    malloc_simple: size=14, ptr=66d0, limit=100000: 81f066bc
    malloc_simple: size=10, ptr=66e0, limit=100000: 81f066d0
    malloc_simple: size=12, ptr=66f2, limit=100000: 81f066e0
    malloc_simple: size=c, ptr=6700, limit=100000: 81f066f4
    malloc_simple: size=a, ptr=670a, limit=100000: 81f06700
    malloc_simple: size=13, ptr=671f, limit=100000: 81f0670c
    malloc_simple: size=12, ptr=6732, limit=100000: 81f06720
    malloc_simple: size=e, ptr=6742, limit=100000: 81f06734
    malloc_simple: size=f, ptr=6753, limit=100000: 81f06744
    malloc_simple: size=f, ptr=6763, limit=100000: 81f06754
    malloc_simple: size=11, ptr=6775, limit=100000: 81f06764
    malloc_simple: size=e, ptr=6786, limit=100000: 81f06778
    malloc_simple: size=9, ptr=6791, limit=100000: 81f06788
    malloc_simple: size=c, ptr=67a0, limit=100000: 81f06794
    malloc_simple: size=a, ptr=67aa, limit=100000: 81f067a0
    malloc_simple: size=b, ptr=67b7, limit=100000: 81f067ac
    malloc_simple: size=8, ptr=67c0, limit=100000: 81f067b8
    malloc_simple: size=7, ptr=67c7, limit=100000: 81f067c0
    malloc_simple: size=8, ptr=67d0, limit=100000: 81f067c8
    INSERT: table 4031dfec, filled 15/521 rv 81f03f6c ==> name="rdaddr" value="0x88080000"
    malloc_simple: size=f, ptr=67df, limit=100000: 81f067d0
    malloc_simple: size=b, ptr=67eb, limit=100000: 81f067e0
    malloc_simple: size=16, ptr=6802, limit=100000: 81f067ec
    malloc_simple: size=e, ptr=6812, limit=100000: 81f06804
    malloc_simple: size=12, ptr=6826, limit=100000: 81f06814
    malloc_simple: size=12, ptr=683a, limit=100000: 81f06828
    malloc_simple: size=e, ptr=684a, limit=100000: 81f0683c
    malloc_simple: size=14, ptr=6860, limit=100000: 81f0684c
    malloc_simple: size=10, ptr=6870, limit=100000: 81f06860
    malloc_simple: size=12, ptr=6882, limit=100000: 81f06870
    malloc_simple: size=c, ptr=6890, limit=100000: 81f06884
    malloc_simple: size=a, ptr=689a, limit=100000: 81f06890
    malloc_simple: size=13, ptr=68af, limit=100000: 81f0689c
    malloc_simple: size=12, ptr=68c2, limit=100000: 81f068b0
    malloc_simple: size=e, ptr=68d2, limit=100000: 81f068c4
    malloc_simple: size=f, ptr=68e3, limit=100000: 81f068d4
    malloc_simple: size=f, ptr=68f3, limit=100000: 81f068e4
    malloc_simple: size=11, ptr=6905, limit=100000: 81f068f4
    malloc_simple: size=e, ptr=6916, limit=100000: 81f06908
    malloc_simple: size=9, ptr=6921, limit=100000: 81f06918
    malloc_simple: size=c, ptr=6930, limit=100000: 81f06924
    malloc_simple: size=a, ptr=693a, limit=100000: 81f06930
    malloc_simple: size=b, ptr=6947, limit=100000: 81f0693c
    malloc_simple: size=8, ptr=6950, limit=100000: 81f06948
    malloc_simple: size=7, ptr=6957, limit=100000: 81f06950
    malloc_simple: size=8, ptr=6960, limit=100000: 81f06958
    INSERT: table 4031dfec, filled 16/521 rv 81f044a8 ==> name="ramdisk_addr_r" value="0x88080000"
    malloc_simple: size=b, ptr=696b, limit=100000: 81f06960
    malloc_simple: size=b, ptr=6977, limit=100000: 81f0696c
    malloc_simple: size=16, ptr=698e, limit=100000: 81f06978
    malloc_simple: size=e, ptr=699e, limit=100000: 81f06990
    malloc_simple: size=12, ptr=69b2, limit=100000: 81f069a0
    malloc_simple: size=12, ptr=69c6, limit=100000: 81f069b4
    malloc_simple: size=e, ptr=69d6, limit=100000: 81f069c8
    malloc_simple: size=14, ptr=69ec, limit=100000: 81f069d8
    malloc_simple: size=10, ptr=69fc, limit=100000: 81f069ec
    malloc_simple: size=12, ptr=6a0e, limit=100000: 81f069fc
    malloc_simple: size=c, ptr=6a1c, limit=100000: 81f06a10
    malloc_simple: size=a, ptr=6a26, limit=100000: 81f06a1c
    malloc_simple: size=13, ptr=6a3b, limit=100000: 81f06a28
    malloc_simple: size=12, ptr=6a4e, limit=100000: 81f06a3c
    malloc_simple: size=e, ptr=6a5e, limit=100000: 81f06a50
    malloc_simple: size=f, ptr=6a6f, limit=100000: 81f06a60
    malloc_simple: size=f, ptr=6a7f, limit=100000: 81f06a70
    malloc_simple: size=11, ptr=6a91, limit=100000: 81f06a80
    malloc_simple: size=e, ptr=6aa2, limit=100000: 81f06a94
    malloc_simple: size=9, ptr=6aad, limit=100000: 81f06aa4
    malloc_simple: size=c, ptr=6abc, limit=100000: 81f06ab0
    malloc_simple: size=a, ptr=6ac6, limit=100000: 81f06abc
    malloc_simple: size=b, ptr=6ad3, limit=100000: 81f06ac8
    malloc_simple: size=8, ptr=6adc, limit=100000: 81f06ad4
    malloc_simple: size=7, ptr=6ae3, limit=100000: 81f06adc
    malloc_simple: size=8, ptr=6aec, limit=100000: 81f06ae4
    INSERT: table 4031dfec, filled 17/521 rv 81f02f7c ==> name="scriptaddr" value="0x80000000"
    malloc_simple: size=f, ptr=6afb, limit=100000: 81f06aec
    malloc_simple: size=b, ptr=6b07, limit=100000: 81f06afc
    malloc_simple: size=16, ptr=6b1e, limit=100000: 81f06b08
    malloc_simple: size=e, ptr=6b2e, limit=100000: 81f06b20
    malloc_simple: size=12, ptr=6b42, limit=100000: 81f06b30
    malloc_simple: size=12, ptr=6b56, limit=100000: 81f06b44
    malloc_simple: size=e, ptr=6b66, limit=100000: 81f06b58
    malloc_simple: size=14, ptr=6b7c, limit=100000: 81f06b68
    malloc_simple: size=10, ptr=6b8c, limit=100000: 81f06b7c
    malloc_simple: size=12, ptr=6b9e, limit=100000: 81f06b8c
    malloc_simple: size=c, ptr=6bac, limit=100000: 81f06ba0
    malloc_simple: size=a, ptr=6bb6, limit=100000: 81f06bac
    malloc_simple: size=13, ptr=6bcb, limit=100000: 81f06bb8
    malloc_simple: size=12, ptr=6bde, limit=100000: 81f06bcc
    malloc_simple: size=e, ptr=6bee, limit=100000: 81f06be0
    malloc_simple: size=f, ptr=6bff, limit=100000: 81f06bf0
    malloc_simple: size=f, ptr=6c0f, limit=100000: 81f06c00
    malloc_simple: size=11, ptr=6c21, limit=100000: 81f06c10
    malloc_simple: size=e, ptr=6c32, limit=100000: 81f06c24
    malloc_simple: size=9, ptr=6c3d, limit=100000: 81f06c34
    malloc_simple: size=c, ptr=6c4c, limit=100000: 81f06c40
    malloc_simple: size=a, ptr=6c56, limit=100000: 81f06c4c
    malloc_simple: size=b, ptr=6c63, limit=100000: 81f06c58
    malloc_simple: size=8, ptr=6c6c, limit=100000: 81f06c64
    malloc_simple: size=7, ptr=6c73, limit=100000: 81f06c6c
    malloc_simple: size=8, ptr=6c7c, limit=100000: 81f06c74
    INSERT: table 4031dfec, filled 18/521 rv 81f02dec ==> name="pxefile_addr_r" value="0x80100000"
    malloc_simple: size=b, ptr=6c87, limit=100000: 81f06c7c
    malloc_simple: size=b, ptr=6c93, limit=100000: 81f06c88
    malloc_simple: size=16, ptr=6caa, limit=100000: 81f06c94
    malloc_simple: size=e, ptr=6cba, limit=100000: 81f06cac
    malloc_simple: size=12, ptr=6cce, limit=100000: 81f06cbc
    malloc_simple: size=12, ptr=6ce2, limit=100000: 81f06cd0
    malloc_simple: size=e, ptr=6cf2, limit=100000: 81f06ce4
    malloc_simple: size=14, ptr=6d08, limit=100000: 81f06cf4
    malloc_simple: size=10, ptr=6d18, limit=100000: 81f06d08
    malloc_simple: size=12, ptr=6d2a, limit=100000: 81f06d18
    malloc_simple: size=c, ptr=6d38, limit=100000: 81f06d2c
    malloc_simple: size=a, ptr=6d42, limit=100000: 81f06d38
    malloc_simple: size=13, ptr=6d57, limit=100000: 81f06d44
    malloc_simple: size=12, ptr=6d6a, limit=100000: 81f06d58
    malloc_simple: size=e, ptr=6d7a, limit=100000: 81f06d6c
    malloc_simple: size=f, ptr=6d8b, limit=100000: 81f06d7c
    malloc_simple: size=f, ptr=6d9b, limit=100000: 81f06d8c
    malloc_simple: size=11, ptr=6dad, limit=100000: 81f06d9c
    malloc_simple: size=e, ptr=6dbe, limit=100000: 81f06db0
    malloc_simple: size=9, ptr=6dc9, limit=100000: 81f06dc0
    malloc_simple: size=c, ptr=6dd8, limit=100000: 81f06dcc
    malloc_simple: size=a, ptr=6de2, limit=100000: 81f06dd8
    malloc_simple: size=b, ptr=6def, limit=100000: 81f06de4
    malloc_simple: size=8, ptr=6df8, limit=100000: 81f06df0
    malloc_simple: size=7, ptr=6dff, limit=100000: 81f06df8
    malloc_simple: size=8, ptr=6e08, limit=100000: 81f06e00
    INSERT: table 4031dfec, filled 19/521 rv 81f0275c ==> name="bootm_size" value="0x10000000"
    malloc_simple: size=9, ptr=6e11, limit=100000: 81f06e08
    malloc_simple: size=4, ptr=6e18, limit=100000: 81f06e14
    malloc_simple: size=16, ptr=6e2e, limit=100000: 81f06e18
    malloc_simple: size=e, ptr=6e3e, limit=100000: 81f06e30
    malloc_simple: size=12, ptr=6e52, limit=100000: 81f06e40
    malloc_simple: size=12, ptr=6e66, limit=100000: 81f06e54
    malloc_simple: size=e, ptr=6e76, limit=100000: 81f06e68
    malloc_simple: size=14, ptr=6e8c, limit=100000: 81f06e78
    malloc_simple: size=10, ptr=6e9c, limit=100000: 81f06e8c
    malloc_simple: size=12, ptr=6eae, limit=100000: 81f06e9c
    malloc_simple: size=c, ptr=6ebc, limit=100000: 81f06eb0
    malloc_simple: size=a, ptr=6ec6, limit=100000: 81f06ebc
    malloc_simple: size=13, ptr=6edb, limit=100000: 81f06ec8
    malloc_simple: size=12, ptr=6eee, limit=100000: 81f06edc
    malloc_simple: size=e, ptr=6efe, limit=100000: 81f06ef0
    malloc_simple: size=f, ptr=6f0f, limit=100000: 81f06f00
    malloc_simple: size=f, ptr=6f1f, limit=100000: 81f06f10
    malloc_simple: size=11, ptr=6f31, limit=100000: 81f06f20
    malloc_simple: size=e, ptr=6f42, limit=100000: 81f06f34
    malloc_simple: size=9, ptr=6f4d, limit=100000: 81f06f44
    malloc_simple: size=c, ptr=6f5c, limit=100000: 81f06f50
    malloc_simple: size=a, ptr=6f66, limit=100000: 81f06f5c
    malloc_simple: size=b, ptr=6f73, limit=100000: 81f06f68
    malloc_simple: size=8, ptr=6f7c, limit=100000: 81f06f74
    malloc_simple: size=7, ptr=6f83, limit=100000: 81f06f7c
    malloc_simple: size=8, ptr=6f8c, limit=100000: 81f06f84
    INSERT: table 4031dfec, filled 20/521 rv 81f03288 ==> name="boot_fdt" value="try"
    malloc_simple: size=7, ptr=6f93, limit=100000: 81f06f8c
    malloc_simple: size=2, ptr=6f96, limit=100000: 81f06f94
    malloc_simple: size=16, ptr=6fae, limit=100000: 81f06f98
    malloc_simple: size=e, ptr=6fbe, limit=100000: 81f06fb0
    malloc_simple: size=12, ptr=6fd2, limit=100000: 81f06fc0
    malloc_simple: size=12, ptr=6fe6, limit=100000: 81f06fd4
    malloc_simple: size=e, ptr=6ff6, limit=100000: 81f06fe8
    malloc_simple: size=14, ptr=700c, limit=100000: 81f06ff8
    malloc_simple: size=10, ptr=701c, limit=100000: 81f0700c
    malloc_simple: size=12, ptr=702e, limit=100000: 81f0701c
    malloc_simple: size=c, ptr=703c, limit=100000: 81f07030
    malloc_simple: size=a, ptr=7046, limit=100000: 81f0703c
    malloc_simple: size=13, ptr=705b, limit=100000: 81f07048
    malloc_simple: size=12, ptr=706e, limit=100000: 81f0705c
    malloc_simple: size=e, ptr=707e, limit=100000: 81f07070
    malloc_simple: size=f, ptr=708f, limit=100000: 81f07080
    malloc_simple: size=f, ptr=709f, limit=100000: 81f07090
    malloc_simple: size=11, ptr=70b1, limit=100000: 81f070a0
    malloc_simple: size=e, ptr=70c2, limit=100000: 81f070b4
    malloc_simple: size=9, ptr=70cd, limit=100000: 81f070c4
    malloc_simple: size=c, ptr=70dc, limit=100000: 81f070d0
    malloc_simple: size=a, ptr=70e6, limit=100000: 81f070dc
    malloc_simple: size=b, ptr=70f3, limit=100000: 81f070e8
    could you help me solve this.
    Roshan Rajagopal
  • Roshan,
    Have you doble checked pinmuxing is right and not used elsewhere? See https://e2e.ti.com/support/processors-group/processors/f/processors-forum/786189/am4378-u-boot-unable-to-read-mmc/2907337#2907337
    "gpio_request_tail: Node 'mmc@4809c000', property 'wp-gpios', failed to request GPIO index 0: -2"
    Have you checked the default DT for the later release and see if it has similar properties?
    -Josue
    i dont think
    the above causes an issue because if u see the boot log of the earlier sdk also which i proivded that statement is present,
    also i tried using broken-cd in the DTS but all i am getting is
    gpio_request_tail: Node 'mmc@4809c000', property 'cd-gpios', failed to request GPIO index 0: -2
    i added one printf in spl-mmc.c to print the boot device and it is returning it as
    DEBUG: spl_mmc_find_device() called for boot_device=5
    Is the above correct for SD card booting.
    Could you help me add some more printf statements in the code so that we can track where is the issue correctly and solve it at the earliest?
    like is the mmc issue itself or the SDRAM initialisation.
    i feel if we add some printf at some places we can track this issue better.
    i also understood it is some issue in my MLO , as i used the MLO of the previous SDK and u-boot.img of the new sdk and it worked, whereas when i tried the vice versa it did not work.
    If you could help me debug this issue it would be helpful
    Roshan Rajagopal
  • Roshan,
    Please see the working DTS for the closest board your custom board resembles in our source for pointers. I do not recommend mixing and matching, this does not really show any progress.
    My recommendation is to start from scratch and bring up the essentials.  For simplicity, the only peripherals initially supported by a minimal configuration are the SD card reader and UART. Then move on to follow up with more features from there.
    The gap in SDKs that you are trying to bridge is too far and you would be better off starting anew.
    Our support in this effort will be very limited.
    Please see the following SDK disclaimer: https://software-dl.ti.com/processor-sdk-linux/esd/AM57X/09_03_06_05/exports/docs/linux/Overview_Technical_Support.html#open-source-software-support-disclaimer
    I share this because both the SDKs you are working on are no longer supported by TI and U-boot is an open source SW that you can get much help from the FOSS community.
    Josue
