Part Number: DRA821U-Q1
Other Parts Discussed in Thread: TEST2
Hi, TI
HW: customer board
SDK: ti-processor-sdk-rtos-j7200-evm-10_00_00_03
Linux Kernel: ti-linux-kernel-6.6.58
Now I am try boot linux with SBL from emmc, before try it SBL form SD card is successful and linux is run.
Here is my emmc partition: /dev/mmcblk0p1 is boot, /dev/mmcblk0p2 is rootfs, I am sure there are OK as I can use it in U-boot.
Bellow is my compile command:
cd $pdk_path/packages/ti/build
make sbl_lib_emmc BOARD=j7200_evm
make sbl_emmc_uda_img BOARD=j7200_evm
cd $mcusw_path/build
make -s -j can_boot_app_mcu_rtos BOARD=j7200_evm SOC=j7200 BUILD_PROFILE=release CORE=mcu1_0 BUILD_OS_TYPE=freertos BOOTMODE=emmc HLOSBOOT=linux BISTFUNC=disabled
cd $mcusw_path/mcuss_demos/boot_app_mcu_rtos/main_domain_apps/scripts/hlos
./constructappimageshlos.sh j7200_evm
And copy these files in boot partition in emmc:
NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty NOTICE: BL31: Built : 16:09:05, Feb 9 2024 I/TC: I/TC: OP-TEE version: 4.2.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Apr 12 09:51:21 UTC 2024 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: GIC redistributor base address not provided I/TC: Assuming default GIC group status and modifier I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Fixing SA2UL firewall owner for GP device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 6.6.58 (root@4e56a679f58b) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #3 SMP PREEMPT Wed Mar 12 14:00:23 CST 2025 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments J7200 EVM [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! [ 0.000000] OF: reserved mem: OVERLAP DETECTED! [ 0.000000] optee@9e800000 (0x000000009e800000--0x00000000a0000000) overlaps with sharememory_for_dv@9ffff000 (0x000000009ffff000--0x00000000a0000000) [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] OF: reserved mem: 0x000000009ffff000..0x000000009fffffff (4 KiB) nomap non-reusable sharememory_for_dv@9ffff000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000 [ 0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a47fffff (8192 KiB) nomap non-reusable ipc-memories@a4000000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a47fffff] [ 0.000000] node 0: [mem 0x00000000a4800000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] cma: Reserved 32 MiB at 0x00000000fe000000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s43176 r8192 d30552 u81920 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Spectre-v3a [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 2. [ 0.000000] software IO TLB: mapped [mem 0x00000000fa000000-0x00000000fe000000] (64MB) [ 0.000000] Memory: 3896068K/4194304K available (12096K kernel code, 1276K rwdata, 4044K rodata, 2496K init, 457K bss, 265468K reserved, 32768K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008356] Console: colour dummy device 80x25 [ 0.012921] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023593] pid_max: default: 32768 minimum: 301 [ 0.028347] LSM: initializing lsm=capability,selinux,integrity [ 0.034320] SELinux: Initializing. [ 0.037950] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.045529] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.054436] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1. [ 0.061704] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1. [ 0.069568] rcu: Hierarchical SRCU implementation. [ 0.074467] rcu: Max phase no-delay instances is 1000. [ 0.079989] Platform MSI: msi-controller@1820000 domain created [ 0.086164] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.095545] EFI services will not be available. [ 0.100291] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.113449] Detected PIPT I-cache on CPU1 [ 0.113497] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.113512] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000 [ 0.113544] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.113602] smp: Brought up 1 node, 2 CPUs [ 0.142955] SMP: Total of 2 processors activated. [ 0.147760] CPU features: detected: 32-bit EL0 Support [ 0.153014] CPU features: detected: CRC32 instructions [ 0.158291] CPU: All CPU(s) started at EL2 [ 0.162473] alternatives: applying system-wide alternatives [ 0.169002] devtmpfs: initialized [ 0.177685] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.187667] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.195211] pinctrl core: initialized pinctrl subsystem [ 0.200814] DMI not present or invalid. [ 0.205270] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.211770] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.219087] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.227127] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.235248] audit: initializing netlink subsys (disabled) [ 0.240873] audit: type=2000 audit(0.152:1): state=initialized audit_enabled=0 res=1 [ 0.241106] thermal_sys: Registered thermal governor 'step_wise' [ 0.248798] thermal_sys: Registered thermal governor 'power_allocator' [ 0.254954] cpuidle: using governor menu [ 0.265702] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.272663] ASID allocator initialised with 65536 entries [ 0.281120] /bus@100000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@100000/interrupt-controller@1800000 [ 0.297897] /bus@100000/pinctrl@a40000: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts [ 0.309546] Modules: 27632 pages in range for non-PLT usage [ 0.309551] Modules: 519152 pages in range for PLT usage [ 0.315750] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.328123] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.334525] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.341459] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.347861] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.354794] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.361195] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.368129] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.375388] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR2.0 JTAGID[0x1bb6d02f] Detected [ 0.384389] iommu: Default domain type: Translated [ 0.389303] iommu: DMA domain TLB invalidation policy: strict mode [ 0.395757] SCSI subsystem initialized [ 0.399777] usbcore: registered new interface driver usbfs [ 0.405400] usbcore: registered new interface driver hub [ 0.410849] usbcore: registered new device driver usb [ 0.416243] pps_core: LinuxPPS API ver. 1 registered [ 0.421317] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.430658] PTP clock support registered [ 0.434782] EDAC MC: Ver: 3.0.0 [ 0.438249] scmi_core: SCMI protocol bus registered [ 0.443387] FPGA manager framework [ 0.446901] Advanced Linux Sound Architecture Driver Initialized. [ 0.453642] clocksource: Switched to clocksource arch_sys_counter [ 0.460019] VFS: Disk quotas dquot_6.6.0 [ 0.464049] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.474616] NET: Registered PF_INET protocol family [ 0.479855] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.488921] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.497704] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.505627] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.513830] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear) [ 0.522529] TCP: Hash tables configured (established 32768 bind 32768) [ 0.529359] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.536282] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.543717] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.549851] RPC: Registered named UNIX socket transport module. [ 0.555910] RPC: Registered udp transport module. [ 0.560714] RPC: Registered tcp transport module. [ 0.565517] RPC: Registered tcp-with-tls transport module. [ 0.571119] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.577702] NET: Registered PF_XDP protocol family [ 0.582606] PCI: CLS 0 bytes, default 64 [ 0.587291] Initialise system trusted keyrings [ 0.591954] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.598715] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.604827] NFS: Registering the id_resolver key type [ 0.610012] Key type id_resolver registered [ 0.614286] Key type id_legacy registered [ 0.618390] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.625239] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.646695] Key type asymmetric registered [ 0.650886] Asymmetric key parser 'x509' registered [ 0.655904] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.663581] io scheduler mq-deadline registered [ 0.668217] io scheduler kyber registered [ 0.672329] io scheduler bfq registered [ 0.678127] pinctrl-single 4301c000.pinctrl: 13 pins, size 52 [ 0.684122] pinctrl-single 4301c038.pinctrl: 2 pins, size 8 [ 0.689918] pinctrl-single 4301c068.pinctrl: 59 pins, size 236 [ 0.695984] pinctrl-single 4301c174.pinctrl: 8 pins, size 32 [ 0.701872] pinctrl-single 104200.pinctrl: 20 pins, size 80 [ 0.707631] pinctrl-single 104280.pinctrl: 8 pins, size 32 [ 0.713323] pinctrl-single 11c000.pinctrl: 67 pins, size 268 [ 0.719440] pinctrl-single 11c110.pinctrl: 1 pins, size 4 [ 0.725019] pinctrl-single 11c11c.pinctrl: 3 pins, size 12 [ 0.730713] pinctrl-single 11c164.pinctrl: 2 pins, size 8 [ 0.736588] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.746239] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.758376] loop: module loaded [ 0.762201] megasas: 07.725.01.00-rc1 [ 0.767719] tun: Universal TUN/TAP device driver, 1.6 [ 0.773463] VFIO - User Level meta-driver version: 0.3 [ 0.779347] usbcore: registered new interface driver usb-storage [ 0.785661] gadgetfs: USB Gadget filesystem, version 24 Aug 2004 [ 0.791805] file system registered [ 0.795606] i2c_dev: i2c /dev entries driver [ 0.800641] sdhci: Secure Digital Host Controller Interface driver [ 0.806964] sdhci: Copyright(c) Pierre Ossman [ 0.811532] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.817647] ledtrig-cpu: registered to indicate activity on CPUs [ 0.823950] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.830966] usbcore: registered new interface driver usbhid [ 0.836661] usbhid: USB HID core driver [ 0.841305] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.849939] optee: probing for conduit method. I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.854502] optee: revision 4.2 (12d7c4ee) [ 0.870961] optee: dynamic shared memory is enabled [ 0.880569] random: crng init done [ 0.884110] optee: initialized driver [ 0.889093] Initializing XFRM netlink socket [ 0.893490] NET: Registered PF_PACKET protocol family [ 0.898694] Key type dns_resolver registered [ 0.906911] registered taskstats version 1 [ 0.911171] Loading compiled-in X.509 certificates [ 0.920851] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') [ 0.997423] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created [ 1.005972] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created [ 1.015309] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created [ 1.023902] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created [ 1.035071] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235 [ 1.044969] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.051733] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 1.062299] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211 [ 1.072470] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.079230] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 1.087234] printk: console [ttyS2] disabled [ 1.091796] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 265, base_baud = 3000000) is a 8250 [ 1.100745] printk: console [ttyS2] enabled [ 1.100745] printk: console [ttyS2] enabled [ 1.109194] printk: bootconsole [ns16550a0] disabled [ 1.109194] printk: bootconsole [ns16550a0] disabled [ 1.122313] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 266, base_baud = 3000000) is a 8250 [ 1.132118] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.177648] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.185643] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing. [ 1.192352] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 1.205205] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.212415] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.218635] pps pps0: new PPS source ptp0 [ 1.222809] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1 [ 1.233135] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0 [ 1.242131] mmc0: CQHCI version 5.10 [ 1.245944] mmc1: CQHCI version 5.10 [ 1.251032] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 1.261465] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8) [ 1.273451] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.294215] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 1.317647] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.325643] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing. [ 1.332351] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 1.345218] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.352508] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.358714] pps pps0: new PPS source ptp1 [ 1.362879] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1 [ 1.378826] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 1.391189] clk: Disabling unused clocks [ 1.407363] ALSA device list: [ 1.410376] No soundcards found. [ 1.413838] mmc0: Command Queue Engine enabled [ 1.418293] mmc0: new HS400 MMC card at address 0001 [ 1.423660] mmcblk0: mmc0:0001 G1M15L 29.6 GiB [ 1.429103] mmcblk0: p1 p2 [ 1.432253] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB [ 1.437887] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB [ 1.443434] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (238:0) [ 2.768093] sdhci-am654 4fb0000.mmc: Power on failed [ 2.803687] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 2.894816] EXT4-fs (mmcblk0p2): recovery complete [ 2.900051] EXT4-fs (mmcblk0p2): mounted filesystem 77d86fda-475b-45f5-9d0d-7515a2b934e5 r/w with ordered data mode. Quota mode: none. [ 2.912164] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 2.918384] devtmpfs: mounted [ 2.922734] Freeing unused kernel memory: 2496K [ 2.927374] Run /sbin/init as init process [ 2.933574] mmc0: running CQE recovery [ 2.937696] I/O error, dev mmcblk0, sector 42207488 op 0x0:(READ) flags 0x3000 phys_seg 1 prio class 2 [ 2.946998] Unable to handle kernel paging request at virtual address 0042c56000000038 [ 2.954898] Mem abort info: [ 2.957680] ESR = 0x0000000096000004 [ 2.961416] EC = 0x25: DABT (current EL), IL = 32 bits [ 2.966714] SET = 0, FnV = 0 [ 2.969757] EA = 0, S1PTW = 0 [ 2.972884] FSC = 0x04: level 0 translation fault [ 2.977751] Data abort info: [ 2.980617] ISV = 0, ISS = 0x00000004, ISS2 = 0x00000000 [ 2.986089] CM = 0, WnR = 0, TnD = 0, TagAccess = 0 [ 2.991126] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0 [ 2.996424] [0042c56000000038] address between user and kernel address ranges [ 3.003543] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP [ 3.009792] Modules linked in: [ 3.012837] CPU: 0 PID: 43 Comm: kworker/0:1H Not tainted 6.6.58 #3 [ 3.019087] Hardware name: Texas Instruments J7200 EVM (DT) [ 3.024642] Workqueue: kblockd blk_mq_requeue_work [ 3.029428] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 3.036370] pc : percpu_ref_put_many.constprop.0+0x18/0xe4 [ 3.041846] lr : percpu_ref_put_many.constprop.0+0x18/0xe4 [ 3.047316] sp : ffff800081933a50 [ 3.050618] x29: ffff800081933a50 x28: ffff800081933c28 x27: ffff000801ae7d00 [ 3.057737] x26: ffff000801ae7d48 x25: 0000000000000000 x24: 000000000000000a [ 3.064855] x23: 00000000ffffffff x22: 0000000000000001 x21: ffff8000805240c4 [ 3.071973] x20: 0000000000000000 x19: b542c56000000038 x18: 0000000000000006 [ 3.079091] x17: 3033783020736761 x16: 6c66202944414552 x15: 283a30783020706f [ 3.086209] x14: 2038383437303232 x13: ffff8000812ef178 x12: 000000000000038a [ 3.093327] x11: 000000000000012e x10: ffff800081347178 x9 : ffff8000812ef178 [ 3.100445] x8 : 00000000ffffefff x7 : ffff800081347178 x6 : 80000000fffff000 [ 3.107563] x5 : ffff8007fe685000 x4 : 00000000000015aa x3 : 0000000000000000 [ 3.114681] x2 : 00000000000015aa x1 : ffff000800244740 x0 : 0000000000000001 [ 3.121799] Call trace: [ 3.124234] percpu_ref_put_many.constprop.0+0x18/0xe4 [ 3.129358] bio_endio+0x154/0x198 [ 3.132748] blk_update_request+0x218/0x3c4 [ 3.136918] blk_mq_end_request+0x24/0x138 [ 3.141001] blk_mq_dispatch_rq_list+0x3bc/0x7b4 [ 3.145603] __blk_mq_sched_dispatch_requests+0xb8/0x578 [ 3.150902] blk_mq_sched_dispatch_requests+0x38/0x74 [ 3.155939] blk_mq_run_hw_queue+0xf4/0x190 [ 3.160106] blk_mq_run_hw_queues+0x6c/0x10c [ 3.164362] blk_mq_requeue_work+0x190/0x1c8 [ 3.168617] process_one_work+0x138/0x248 [ 3.172617] worker_thread+0x320/0x438 [ 3.176355] kthread+0x110/0x114 [ 3.179571] ret_from_fork+0x10/0x20 [ 3.183137] Code: 910003fd f9000bf3 aa0003f3 97f08cf2 (f9400260) [ 3.189212] ---[ end trace 0000000000000000 ]---
