ERROR: More than one source file is specified.......... CCSv5.0.23........C6678
Hi all,
I'm trying to make a new project in CCS v5.0.23... After making all the corrections and got over all the error this is the last error am getting...
Linking failed. Check the Console window for details.
I'm pasting the console window details herewith....
**** Build of configuration Debug for project TI_Project ****
C:\Program Files\Texas Instruments\ccsv5\utils\gmake\gmake -k all
'Building file: ../source/ti_main.c'
'Invoking: C6000 Compiler'
"C:/Program Files/Texas Instruments/ccsv5/tools/compiler/c6000/bin/cl6x" -mv6600 -g --define=xdc_target_types__=C:\Program Files\Texas Instruments\xdctools_3_20_08_88\packages\ti\targets\std.h --include_path="C:\Program Files\Texas Instruments\ccsv5\tools\compiler\c6000\include" --include_path="E:\Projects\TI Project\Task\server_workspace\test1\inc" --include_path="C:\Program Files\Texas Instruments\bios_6_31_04_27\packages" --include_path="C:\Program Files\Texas Instruments\imglib_c66x_3_0_1_0" --include_path="C:\Program Files\Texas Instruments\ipc_1_22_05_27\packages" --include_path="C:\Program Files\Texas Instruments\mcsdk_2_00_00_beta2" --include_path="C:\Program Files\Texas Instruments\ndk_2_20_03_24\packages" --include_path="C:\Program Files\Texas Instruments\pdk_C6678_1_0_0_9_beta2\packages" --diag_warning=225 --abi=eabi --preproc_with_compile --preproc_dependency="source/ti_main.pp" --obj_directory="source"  "../source/ti_main.c"
[Texas.]
>> WARNING: more than one source file is specified; preprocessor output will be generated for last file only
Fatal error: could not open source file "Files\Texas"
1 fatal error detected in the compilation of "Files\Texas".
Compilation terminated.
>> Compilation failure
gmake: *** [source/ti_main.obj] Error 1
'Building file: ../source/webpage_access.c'
"C:/Program Files/Texas Instruments/ccsv5/tools/compiler/c6000/bin/cl6x" -mv6600 -g --define=xdc_target_types__=C:\Program Files\Texas Instruments\xdctools_3_20_08_88\packages\ti\targets\std.h --include_path="C:\Program Files\Texas Instruments\ccsv5\tools\compiler\c6000\include" --include_path="E:\Projects\TI Project\Task\server_workspace\test1\inc" --include_path="C:\Program Files\Texas Instruments\bios_6_31_04_27\packages" --include_path="C:\Program Files\Texas Instruments\imglib_c66x_3_0_1_0" --include_path="C:\Program Files\Texas Instruments\ipc_1_22_05_27\packages" --include_path="C:\Program Files\Texas Instruments\mcsdk_2_00_00_beta2" --include_path="C:\Program Files\Texas Instruments\ndk_2_20_03_24\packages" --include_path="C:\Program Files\Texas Instruments\pdk_C6678_1_0_0_9_beta2\packages" --diag_warning=225 --abi=eabi --preproc_with_compile --preproc_dependency="source/webpage_access.pp" --obj_directory="source"  "../source/webpage_access.c"
[Texas.]
>> Compilation failure
gmake: *** [source/webpage_access.obj] Error 1
'Building file: ../common/src/image_processing.c'
"C:/Program Files/Texas Instruments/ccsv5/tools/compiler/c6000/bin/cl6x" -mv6600 -g --define=xdc_target_types__=C:\Program Files\Texas Instruments\xdctools_3_20_08_88\packages\ti\targets\std.h --include_path="C:\Program Files\Texas Instruments\ccsv5\tools\compiler\c6000\include" --include_path="E:\Projects\TI Project\Task\server_workspace\test1\inc" --include_path="C:\Program Files\Texas Instruments\bios_6_31_04_27\packages" --include_path="C:\Program Files\Texas Instruments\imglib_c66x_3_0_1_0" --include_path="C:\Program Files\Texas Instruments\ipc_1_22_05_27\packages" --include_path="C:\Program Files\Texas Instruments\mcsdk_2_00_00_beta2" --include_path="C:\Program Files\Texas Instruments\ndk_2_20_03_24\packages" --include_path="C:\Program Files\Texas Instruments\pdk_C6678_1_0_0_9_beta2\packages" --diag_warning=225 --abi=eabi --preproc_with_compile --preproc_dependency="common/src/image_processing.pp" --obj_directory="common/src"  "../common/src/image_processing.c"
[Texas.]
>> Compilation failure
gmake: *** [common/src/image_processing.obj] Error 1
'Building file: ../common/src/image_processing_task.c'
"C:/Program Files/Texas Instruments/ccsv5/tools/compiler/c6000/bin/cl6x" -mv6600 -g --define=xdc_target_types__=C:\Program Files\Texas Instruments\xdctools_3_20_08_88\packages\ti\targets\std.h --include_path="C:\Program Files\Texas Instruments\ccsv5\tools\compiler\c6000\include" --include_path="E:\Projects\TI Project\Task\server_workspace\test1\inc" --include_path="C:\Program Files\Texas Instruments\bios_6_31_04_27\packages" --include_path="C:\Program Files\Texas Instruments\imglib_c66x_3_0_1_0" --include_path="C:\Program Files\Texas Instruments\ipc_1_22_05_27\packages" --include_path="C:\Program Files\Texas Instruments\mcsdk_2_00_00_beta2" --include_path="C:\Program Files\Texas Instruments\ndk_2_20_03_24\packages" --include_path="C:\Program Files\Texas Instruments\pdk_C6678_1_0_0_9_beta2\packages" --diag_warning=225 --abi=eabi --preproc_with_compile --preproc_dependency="common/src/image_processing_task.pp" --obj_directory="common/src"  "../common/src/image_processing_task.c"
[Texas.]
>> Compilation failure
gmake: *** [common/src/image_processing_task.obj] Error 1
gmake: Target `all' not remade because of errors.
    What does this error message make you think of?
    What do you find in your compile command that matches this error message?
    How did you create your compile command, within CCS or as a separate makefile?
    Look for the string "Files\Texas" in your command list and see what may be wrong. Keep in mind that almost all of the filenames and paths in the command list correctly place "" around complex paths, especially when they include embedded spaces in the pathname.
    RandyP
    If you need more help, please reply back. If this answers the question, please click  Verify Answer  , below.
