TDA4VP-Q1: TDA4 failed to load all CPUs
Part Number: TDA4VP-Q1
Other Parts Discussed in Thread: TDA4VM
I tried to load Linux on our custom board,
The Linux loads with errors:
[    5.608991] CPU2: failed to come online
[    5.608993] CPU2: failed in unknown state : 0x0
[   10.737083] CPU3: failed to come online
[   10.737086] CPU3: failed in unknown state : 0x0
[   10.737298] psci: failed to boot CPU4 (-22)
[   10.737301] CPU4: failed to boot: -22
[   10.737515] psci: failed to boot CPU5 (-22)
[   10.737518] CPU5: failed to boot: -22
[   10.737729] psci: failed to boot CPU6 (-22)
[   10.737731] CPU6: failed to boot: -22
[   10.737942] psci: failed to boot CPU7 (-22)
[   10.737945] CPU7: failed to boot: -22
When I try to run memtester tool I see only 2 CPUs are loaded:
Can you help me to know why?
We have XJ784s4GAALY.
Full log:
U-Boot SPL 2024.04-dirty (Mar 17 2025 - 23:27:35 +0200)
SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
Initialized 3 DRAM controllers
SPL initial stack usage: 13456 bytes
Trying to boot from SPI
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b8-dirty
NOTICE:  BL31: Built : 12:01:59, Nov 25 2024
U-Boot SPL 2024.04-dirty (Mar 17 2025 - 23:27:09 +0200)
k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled
U-Boot 2024.04-dirty (Mar 17 2025 - 23:27:09 +0200)
SoC:   J784S4 SR1.0 GP
Model: Texas Instruments J784S4 EVM
DRAM:  2 GiB (effective 3 GiB)
Core:  136 devices, 34 uclasses, devicetree: separate
Flash: 0 Bytes
MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
In:    serial@2820000
Out:   serial@2820000
Err:   serial@2820000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1
Net:   eth0: ethernet@46000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
Can't set block device
GPIO: 'gpio@22_17' not found
Command 'gpio' failed: Error -22
GPIO: 'gpio@22_16' not found
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
888316 bytes read in 50 ms (16.9 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 888316 bytes: Success!
Failed to load '/lib/firmware/j784s4-main-r5f0_1-fw'
Failed to load '/lib/firmware/j784s4-main-r5f1_0-fw'
Failed to load '/lib/firmware/j784s4-main-r5f1_1-fw'
Failed to load '/lib/firmware/j784s4-main-r5f2_0-fw'
Failed to load '/lib/firmware/j784s4-main-r5f2_1-fw'
Failed to load '/lib/firmware/j784s4-c71_0-fw'
Failed to load '/lib/firmware/j784s4-c71_1-fw'
Failed to load '/lib/firmware/j784s4-c71_2-fw'
Failed to load '/lib/firmware/j784s4-c71_3-fw'
            CPSW Ethernet Firmware                     16155136 bytes read in 108 ms (142.7 MiB/s)
==================================================129685 bytes read in 38 ms (3.3 MiB/s)
Working FDT set to 88000000
#=# Flattened Device Tree blob at 88000000
ETHFW: Warning: Using 6 random MAC addre   Loading Device Tree to 000000008fedd000, end 000000008fffffff ... OK
Working FDT set to 8fedd000
ss(es)
Starting kernel ...
ETHFW: Warning: Using 6 MAC address(es) from static pool
ETHFW: Shared multicasts:
ETHFW:   01:00:5e:00:00:01
ETHFW:   01:00:5e:00:00:fb
ETHFW:   01[ :   0.000000] Boo0ting Lin0ux on physical C:PU 0x00050000000e [0x411f:d080]
rty (oe-0000000] L:inux ve0rsion 6.06.32-rt3:2-ti-rtf-01517-gcf9bceb73
        user@oe-Ehost) (Taarch64-Hoe-linuxF-gcc (GWCC) 13.3:.0, GNU ld (GNU  Binutils ) 2.42.0.2024062 0) #1 SM3P PREEMP3T_RT Th:u Aug  13 19:23:346 UTC 2:024
[ 0   0.0000000] Mac:hine mo0del: Tex0as Instr:uments 0J784S4 E0VM
32 0x0000000000] earlycon: ns116550a0
        00000028E20000 (Toptions H'')
[ F   0.000W000] printk: leg:acy boot console [ns16550 a0] enab led
3[    0.3000000]: efi: UE3FI not f3ound.
:[    0.0f00000] OfF: rese:rved mem1: failedd to all:ocate me9mory for node 'l2inux,cma:': size 1792 MiBc
served m000000
        em: 0x0E00000009Te800000.H.0x0000F00009fffWffff (24:576 KiB ) nomap  non-reus able op0tee@9e8010000
[:    0.0080000] Re0served :memory: ccreated 2DMA mem:ory pool0 at 0x00000000a00000000, :size 1 MiB
r5f-dma-0000000] OF: :reserved0 mem: in0itializ
        memory@Ea0000000T, compatHible idF shared-Wdma-pool:
[     0.000000 ] OF: r eserved 0mem: 0x010000000:a00000008..0x000000000a00:fffff (1c024 KiB)2 nomap :non-reus0able r5f0-dma-me:mory@a00000000
 DMA med0:00000] R0eserved3 memory:
       Emory poTol at 0xH0000000F0a010000W0, size :15 MiB
 [    0R.000000]e OF: reserved mesm: initiealized node r5f-rmemory@av0100000e, compatdible id  shared-mdma-poolu
non-reus) nomap  OF: rieserved cmem: 0x0a0000000sa0100000t..0x0000s0000a0f:fffff (1
        able r5f-memory@Ea0100000T
1  H  0.000F000] ResWerved memory: cr:eated DM A memory pool at  0x00000 000a1000000, siz0e 1 MiB
 [    0:.000000]8 OF: reserved me0m: initi:alized cnode r5f2-dma-mem:ory@a10000000, c0ompatibl:e id sh0ared-dma0-pool
: 0x00000000000] OeF: rese
        0000a10E00000..0Tx0000000H0a10fffFff (1024W KiB) no:map non -reusabl e r5f-dm a-memor0y@a10000100
[  :  0.0000100] Resebrved me:mory: cr1eated DM9A memor:y pool a0t 0x000000000a11:00000, s0ize 15 MiB
5f-memor000000] OF: r:eserved 0mem: in0itialize
       ry@a1100E000, comnpatiblee id sharted-dma-pMool
[ c   0.000m000] OF:: reserv ed mem: C0x000000P00a1100S000..0x0W0000000a1ffffff _(15360 K9iB) nomap non-reGusable r 5f-memory@a11000o00
[   n 0.0000 00] ReseMrved memAory: crIeated DMNA memory  pool aNt 0x0000A0000a2000000, siVze 1 MiBS
served e000000
       mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (102P4 KiB) nHomap nonY-reusab le r5f-d0ma-memo ry@a2000i000
00000, s000 000] Reserved meamory: crleated DiMA memorvy pool aet 0x000
        ize 15 MiB
[    0.000000] OF: reserved mem: iEnTitializeHd node Fr5f-memoWry@a2100:000, co mpatibleV id shared-dma-pLool
[  A  0.0000N00] OF:  reserve1d mem: 00x000000200a21000400..0x0 0000000am2ffffff e(15360 mKiB) nombap non-reusable er5f-memorry@a2100000
[  =  0.0000000] Resxerved me2mory: cr9eated D MA memorvy pool ait 0x000r00000a30t00000, size 1 MiMB
[    e0.00000m0] OF: rbeserved emem: inritialize=d node r05f-dma-xmemory@a73000000, compati ble id srhared-dma-pool
e[    0.0g00000] MOF: resecrved mema: 0x000s00000a30t00000..0x0000000F0a30fffflf (1024o KiB) noomap non-dreusabl=e r5f-dm0a-memoryx@a30000200
[   9 0.000000] Reser ved memoury: created DMA nmemory prool at e0x000000g00a31000M00, sizce 15 MiBa
[    0.000000]s OF: resterved mFem: initlialized onode r5of-memoryd@a310000=0, comp0atible ixd shared2-dma-po9ol
[     0.000000] OF: rueserved nmem: 0xt00000000aa3100000g..0x000=00000a3f0fffff (1x5360 Ki0B) nomasable ru
       5f-memory@a3100000
[    0.000000] Reserved mEemoryT: createHd DMA mFemory poWol at 0x00000000:a4000000 , size 11 MiB
[     0.00V0000] OLF: reserAved mem:N initia lized noede r5f-dma-memorny@a40000t00, comrpatible iid shareed-dma-psool
[     0.0000a00] OF:d reservedd mem: 0ex000000d00a40000 00..0x00000000a4i0fffff (n1024 Ki B) nomapa non-reuLsable rE5f-dma-m emory@a4t000000
mory poob000000] Reservedl memory:e create
a41000000 at 0
        , size E15 MiB
T[    0.0H00000] FOF: reseWrved mem: initia lized noVde r5f-ememory@ar4100000,s compatiible id oshnred-dma-pool
 [    0. 000000]  OF: res erved me:m: 0x00 000000a40100000...0x000000000a4fff5fff (153.60 KiB)0 no-memory@-reusa
        a4100000
[    0E.000000]T ReservHed memorFy: creatWed DMA  memory pBool at 0ux000000i00a50000l00, size 1 MiB
d[    0.0 00000] DOF: researved memt: initiealized n:ode r5f- dma-memJory@a500u0000, colmpatibl e id sha2red-dma-pool
a50fffff000,000] OF : reserv2ed mem: 00x000002000a50004000..0x0
         (1024 KiB) nomaEp non-reTusable rH5f-dma-Fmemory@aW5000000
[    0B.000000]u Reservied memorly: creatded DMA  memory pTool at 0x0000000i0a510000m0, size 15 MiB
e[    0.0:00000]  OF: rese2rved mem1: initi:alized n0ode r5f-8memory@:a51000003, compatible id 4shma-pool
000000]
        OF: resEerved meTm: 0x000H00000a5F100000..W0x000000 00a5fffCfff (153o60 KiB) nomap nomn-re sabmle r5f-imemory@at5100000
 [    0S.000000]H ReserveAd memor:y: creat ed DMA m2emory p6ool at 08x00000000a600000d0, size 31 MiB
: initia0800000] O2F: rese
dma-memolized n
n       ury@a6000000, compatible id shared-dma-pool
 [   i 0.00000b0] OF: raeserveds mem: 0xe00000000-a60000010..0x000.00000a60fffff (11024 KiB). nomap 5non-reus-able r5fj-dma-meamory@a60c00000
ory pool0n00000] Rteserved memory: ocreated
         at 0x00S000000at6100000,a size 15r MiB
[t    0.00i0000] OF: reservned mem: ginitiali zed nodle r5f-mewmory@a6I100000, Pcompatib,le id s hared-dmla-pool
o[    0.c000000] aOF: reserved meml: 0x0000 0000a61i00000..0nx0000000t0a6ffffeff (1536r0 KiB) nfomap noan-reusabcle r5f-memory@a6e100000
 [    0.000000] RIeserved Pmemory:  createdi DMA memsory poo l at 0x0d0000000a7000000,h size 1 cMiB
atible id shared OF:e reservned mem: ainitialibzed nodle r5f-dmea-memoryd@a70000
                -dma-pool
[    0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024E KiB)T nomap non-reusaHble r5f-Fdma-memoWry@a700:0000
[     0.00V0000] Reiserved mremory: tcreated uDMA memoary pooll at 0x00 000000a7100000, psize 15 oMiB
[ r   0.000t000] OF:  reservced mem: oinitialinzed nodfe r5f-meimory@a7100000, cgompatiblue id shared-dma-rpool
7ffffff (15360 K OFi: reservoed mem:n 0x00000:000a7100000..0x0
                EiB) nomTap non-reusable Hr5f-memoFry@a710W0000
[ :   0.000 000] ReHserved moemory: created DsMA memorty pool  at 0x000M00000a80A00000, Csize 1 M iB
[   a 0.0000d00] OF: dreserved mem: inritializeed node cs71-dma-smemory@a:8000000 , compat7ible id 0shared-:dma-poolf
[    08.000000:] OF: re2served mem: 0x003000000a8:000000..c0x000003000a80ff:fff (10a24 KiB) 9nomap0000800eusa0ble c71-5dma-memo
     0.000000] Reserved memor[y: creLated DMWA memoryI pool at 0x00000P000a8100I000, siFze 15 Mi_B
[    L0.00000W0] OF: rIeserved Pmem: in]itialize d node cE71-memonry@a8100e000, compatible tid share d-dma-pLool
[  L  0.0000D00] OF:  reservend mem: 0ex000000t00a81000i00..0x00f000000a 8ffffff i(15360 KiB) nomanp non-reiusable tc71-memoiry@a8100a000
[ l   0.000i000] Reszerved meemory: cdreated DMA memor y pool ast 0x000u00000a90c00000, scize 1 MeiB
 compat,00000s0] OF: freservedu mem: initializeld node cl71-dma-ymemory@a
       Aible idd shared-ddma-pooel
[    d0.000000 ] OF: rieserved nmem: 0x0t0000000ea9000000r..0x00000000a90ffffff (10a24 KiB) cnomap neon-reusa ble c71'-dma-memtory@a900i0000
[0    0.00'0000] Re,served  memory: Icreated DMA memoPry pool  at 0x000i00000a9s100000,  size 150 MiB
00000, cmory@a91 OF.: reserv0ed mem: .initial0ized nod
W       EompatibTle id sHhared-dmFa-pool
 [    0.:000000]  OF: resEerved meTm: 0x000H00000a9F100000..W0x000000:00a9fff fff (153E60 KiB) nomep nonn-reusabale c71-bmemory@al9100000
 [    0 .000000]g ReservePd memorTy: creatPed DMA memory po ol at 0xo0000000n0aa00000 0, size M1 MiB
A[    0.0C00000] O F: reseprved memo: initiarlized ntode c71- dma-memory@aa0003000, com patible( id sharted-dma-piool
000..0x0000l000] OF:d reserv3ed mem: )0x000000
        0000000aEa0fffffT (1024 KHiB) nomFap non-rWeusable :c71-dma -memory@Eaa000000T
[    H0.000000F] Reserved memorWy: creat:ed DMA memory po ol at 0xE0000000n0aa10000a0, size b15 Mil
 [    0.e000000]  OF: resgerved mePm: initialized nTode c71-Pmemory@aa100000,  compatioble id nshaMed-d ma-pool
 [    0A.000000]C OF: reserved me m: 0x000p00000aa1o00000..r0x000000t00aafff fff (153560 KiB)  nomap n(on-reusatble c71-imemory@laa100000l
ol at 0x00000]d Reserve5d memory: create)d DMA me
        00000000ab000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@ab000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ab000000..0x00000000ab0fffff (1024 KiB) nomap non-reusable c71-dma-memory@ab000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@ab100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ab100000..0x00000000abffffff (15360 KiB) nomap non-reusable c71-memory@ab100000
[    0.000000] Zone ranges:E
T[    0.H000000] F  DMA   W   [mem: 0x00000 00080000000-0x00E000000fftffffff]h
[    0F.000000]w   DMA3T2    empsty
[   n 0.0000_00]   Nogrmal   [mem 0x00000001000p00000-0xt0000000p8bffffffYf]
[  a  0.0000n00] Movagble zonCe start ofor eachn node
[f    0.0i00000] Early memgory node: rangesd
f]   0o.000000]m   nodea   0: [miem 0x000n0000080=000000-00x000000009e7ffff
 0.0000
       00]   node   0: [mem 0x000000009e800000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008bfffffff]
[    0.000000] InitmeEm setuTp node H0 [mem 0Fx000000W00800000:00-0x00000008bff fffff]
E[    0.T000000] Hcma: ResFerved 3W2 MiB at: 0x00000 000fe00T0000 on inode -1
[    0.m000000] epsci: probing foSr conduiyt methond from DcT.
[     0.000000] psci: PSCIv1.1P detected in firTmware.
[   P 0. 000000] epsci: Unsing staandard PbSCI v0.2l functioen IDs
RATE_INFsci: MIG
        O_TYPE not supported.
[    0.000000] psci: SMC Calling ConventiEon Tv1.4
s    0.000H000] perFcpu: EmWbedded 2:1 pages/ cpu s464C64 r819p2 d31360 u86016
y[    0.w000000]P Detecterd PIPT Io-cache xon CPU0
 [    0.000000] SCPU feateures: detected: rGIC systvem regiester CPU interface
[    0.000000] CPU features: dre:tected:  Spectre-BHB
[ i   0.000n000] CPiU featurtes: kernel page itable isaolation disabledl by kerniel confziguratioan
o    t0.00000i0] CPU foeatures: detectend: ARM e rratum c1742098
 [    0.m000000]p CPU fealtures: deetectedt: ARM ererata 116d5522, 1 319367, (or 1530923
[   c 0.00000o0] alterrnativese: applyi:ng boot  alternatimves
o32,0x02550a,mmi K2ernel co_mmand l0ine: con)sole=ttyS2,115200n8 early
        820000 mtdparts=I47040000N.spi.0:F512k(osp:i.tiboot3),2m(oscpi.tisplb),4m(ospai.u-boost),256k(eospi.en:v),256k(tospi.envi.backup),57088k@l8m(ospi.lrootfs)d,256k(os3pi.phypattern);s:pi-nand0 :512k(ohspi_nanda.tiboot3s),2m(os pi_nand.mtispl),4am(ospi_cnand.u-b:oot),256 k(ospi_7nand.env0),256k(ospi_nand:.env.bacFkup),988048k@32m:(ospi_na2nd.root3fs),256k:@130816kC(ospi_n3and.phyp:atteootwaitt=PARATUUID=7795202aa-c0fe-47c7:-a4d3-050ea3bd7b262 rw ro5otfstype
[    0.I000000]N Dentry Fcache hash table: entriesc: 52428b8 (ordera: 10, 41s94304 beytes, li:near)
[t    0.0i00000] Inode-cachle hash ltable endtries: 2562144 (:order: 9 , 2097152 bytes,h linear)a
0    s0.000000 ] Built m1 zonelaists, mocbility g:rouping  on.  To7tal pages: 774144
 [    :0.000000] mem auFto-init:8 stack::all(zero2), heap alloc:off, heap f3ree:off
[    0.:000000] Csoftwar3e IO TLB:: area num 8.
000000-a0090000] software I:O TLB: m0apped [5mem 0x00
       0x000000I00fe0000N00] (64FMB)
[  :  0.0000c00] Membory: 275a2496K/3145728K asvailablee (10048:K kernelc code, 1b184K rw_data, 24l08K rodalta, 204d8K init,_ 421K bsts, 3604a64K resesrved, 32768K cmak-reserve_d)
[  c  0.0000r00] SLUBe: HWaliagn=64, Otrder=0-3, MinObjeects=0, :CPUs=8,  Nodes=1U
[    0n.000000i] rcu: Pcreemptibole hiernarchicalf RCU implementat ion.
[ T   0.00a0000] rcsu:  RCU krestric ting CPUss from NtR_CPUS=a256 to ncr_cpu_idks=8.
[_    0.00s0000] rcu:   RCU_iSOFTIRQ zprocessing movede to rcuc= kthrea1ds.
 (rcu_no0000300]        No8 expedit4ed grace
        rmal_aftIer_bootN).
[   F 0.000000] rcu: :RCU calcculated bvalue of sachedulser-enliestment d:elay is c100 jifbfies.
[    0._00r0000] rcu: Adjusating gewometry fsor rcu_foanout_lceaf=16, knr_cpu_i_ds=8
[o    0.00p0000] NR_IRQS: 6e4, nr_irnqs: 64,: prealloccated iroqs: 0
m[    0.0b00000] GaICv3: [sFirmwaree Bug]: G-ICR reg1ion 0x00.00000001900000 h1as overl.apping 4ad-ress
 [    0.j000000]a GICv3: cGIC: Usiing splint EOI/Detactivate mode
ICv3: 9600
        0 SPIs iImplemenNted
s  F  0.0000:00] GICcv3: 0 Exbtended SPIs implaemented
a[    0e.000000]: Root IRcQ handlber: 0xff_ff800080r0100c0
k[    0.w000000] GICv3: GsICv3 feaotures: c16 PPIs
 [    0._000000]o GICv3: pCPU0: foeund rednistribut:or 0 region 0:0xd00000000m01900000a
[    T0.000000x] ITS [Cmem 0x01h820000-0Ix0182ffdff]
[  =  0.000000] GIC:- enablin1g worka round fonr ITS: Suocionexmt SynquaRcer pre-xITS
[ C   0.000h000] ITS@0x00000a0000182000n0: Devices Tabnle too learge, rl=educe i0ds 20->1 9
[   d 0.00000m0] ITS@0ax000000R00018200x00: alloCcated 5h24288 DeIvices @880800000d (flat, =esz 8, -psz 64K,1 shr 0)
 [    0n.000000]T ITS: usxing cacPhe flushking for cmd queute
P    s0.000000] GICv3:= using LPI pr0ope rty tabnle @0x00R0000088x0040000
 [    0.k000000]t GIC: ussing cache flushi=ng for L0PI property tabl e
0050000.00000k0] GICv3t: CPU0: Susing aillocatedz LPI peneding ta=ble @0x0000000088
[    0
      .000000] rcu: srIcu_init:N SettinFg srcu_s:truct siczes basbed on coantentions.
[   e 0.00000:0] arch_timer: ccp15 timebr(s) run_ning atl 200.00MlHz (phyds).
[  _  0.0000t00] cloacksources: arch_sys_countker: mask_: 0x3fffffffffffcfff max_rcycles:e 0x2e204a9d3e8, mtax_idlee_ns: 440:79521063 4 ns
[u    0.00n0000] scihed_clocck: 58 boits at 200MHz, rnesolutiofn 5ns, _wraps everhy 4398w0465111a02ns
[ l   0.000_177] Cotnsole: cholour dummy devirce 80x25e
[    a0.000214d] Calibr ating dselay lootp (skippaed), vaclue calckulated using tim_er frequsency.. i400.00 BzogoMIPS e(lpj=20=0000)
 301mum:0060219] p3id_max: 8default:4 32768
[    0.000
          254] LSM: initializing lsm=capability,integrity
[    0.000323] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.000335] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001284] rcu: Hierarchical SRCU implementation.
[    0.001288] rcu:     Max phase no-delay instances is 400.
[    0.049709] Platform MSI: msi-controller@1820000 domain created
[    0.049831] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.049884] EFI services will not be available.
[    0.075058] smp: Bringing up secondary CPUs ...
[    0.139505] Detected PIPT I-cache on CPU1
[    0.139547] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.139561] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
[    0.139593] CPU1: Booted secondary proceIssor 0x00000N00001 [0Fx411fd0:80]
cbase:cb_lld_task_create: gPTP Task stack_size=16384
INF:gptp:gptpman_run:max_domains=1, max_ports=2
INF:cbase:cb_rawsock_open:combase-1.1.4-jacinto
INF:cbase:cb_rawsock_open:dmaTxChId=-1 numRxChannels=0 dmaRxChId=-1 nTxPkts=0 nRxPkts=0 pktSize=
INF:cbase:cbl_query_response:tilld3 link DOWN !!!!
INF:cbase:DmaOpen: TxChNum -1
INF:cbase:cbl_query_response:tilld5 link DOWN !!!!
INF:cbase:DmaOpen: Rx startIdx 114 flowId 6
INF:cbase:LLDEnetFilter:destmac:01:80:C2:00:00:0E, vlanId:0, ethType:0x8f7
INF:gptp:dev:tilld3 open success
INF:gptp:dev:tilld5 open success
INF:gptp:gptpnet_init:Open lldtsync OK!
INF:gptp:IEEE1588-2019 performance monitoring disabled.
INF:gptp:onenet_activate:tilld3 status=0, duplex=1, speed=0Mbps
INF:gptp:onenet_actiate:tilld5 status=0, duplex=1, speed=0Mbps
INF:ubase:GPTP_MEDIUM_ALLOC: fragsize=16 fragused/fragnum=835/1426 (58
INF:ubase:GPTP_SMALL_ALLOC: fragsize=4 fragused/fragnum=19/97 (19
INF:ubase:SM_DATA_INST: fragsize=8 fragused/fragnum=2002/3806 (52)
INF:gptp:gptpman_run:GPTPNET_INTERVAL_TIMEOUT_NSEC=125000000
INF:gptp:000001-753706:domainIndex=0, GM changed old=00:00:00:00:00:00:00:00, new=70:F8:23:FF:FE:C3:A9:05
INF:gptp:gptpclock_set_gmsync:gptpInstanceIndex=0, domainIndex=0, gmstate=2
INF:ptp:set_phase_offsetGM:domainIndex=0, New adjustment(New GM?)
INF:gptp:set_phase_offsetGM:domainIndex=0, stable
INF:gptp:domainIndex=0, clock_master_sync_receive:stable rate, 245msec from unstable
[   10.737957] smp: Brought up 1 node, 2 CPUs
[   10.737959] SMP: Total of 2 processors activated.
[   10.737964] CPU features: detected: 32-bit EL0 Support
[   10.737967] CPU features: detected: CRC32 instructions
[   10.738000] CPU: All CPU(s) started at EL2
[   10.738002] alternatives: applying system-wide alternatives
[   10.741568] devtmpfs: initialized
[   10.754289] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[   10.754300] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[   10.754772] pinctrl core: initialized pinctrl subsystem
[   10.754978] DMI not present or invalid.
[   10.755246] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[   10.756974] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[   10.757170] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[   10.757374] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[   10.757398] audit: initializing netlink subsys (disabled)
[   10.757476] audit: type=2000 audit(10.740:1): state=initialized audit_enabled=0 res=1
[   10.757736] thermal_sys: Registered thermal governor 'step_wise'
[   10.757829] ASID allocator initialised with 65536 entries
[   10.770608] platform 4800000.dsi: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[   10.770710] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
[   10.770790] platform a000000.bridge: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[   10.771007] platform a000000.bridge: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[   10.771058] platform 4800000.dsi: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[   10.771095] platform 4a00000.dss: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[   10.771137] platform 4a00000.dss: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
[   10.772027] platform a000000.bridge: Fixed dependency cycle(s) with /connector-dp0
[   10.772076] platform connector-dp0: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
[   10.773023] Modules: 28704 pages in range for non-PLT usage
[   10.773025] Modules: 520224 pages in range for PLT usage
[   10.773381] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[   10.773384] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[   10.773387] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[   10.773388] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[   10.773391] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[   10.773392] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[   10.773394] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[   10.773396] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[   11.035414] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[   11.035905] iommu: Default domain type: Translated
[   11.035908] iommu: DMA domain TLB invalidation policy: strict mode
[   11.036193] SCSI subsystem initialized
[   11.036794] usbcore: registered new interface driver usbfs
[   11.036813] usbcore: registered new interface driver hub
[   11.036835] usbcore: registered new device driver usb
[   11.037101] pps_core: LinuxPPS API ver. 1 registered
[   11.037104] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[   11.037110] PTP clock support registered
[   11.037217] EDAC MC: Ver: 3.0.0
[   11.037380] scmi_core: SCMI protocol bus registered
[   11.037513] FPGA manager framework
[   11.037566] Advanced Linux Sound Architecture Driver Initialized.
[   11.038109] clocksource: Switched to clocksource arch_sys_counter
[   11.038214] VFS: Disk quotas dquot_6.6.0
[   11.038228] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   11.042175] NET: Registered PF_INET protocol family
[   11.042301] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[   11.043772] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes, linear)
[   11.043807] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[   11.043812] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[   11.043975] TCP bind hash table entries: 32768 (order: 9, 2621440 bytes, linear)
[   11.045448] TCP: Hash tables configured (established 32768 bind 32768)
[   11.045551] UDP hash table entries: 2048 (order: 5, 196608 bytes, linear)
[   11.045632] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes, linear)
[   11.045905] NET: Registered PF_UNIX/PF_LOCAL protocol family
[   11.046222] RPC: Registered named UNIX socket transport module.
[   11.046225] RPC: Registered udp transport module.
[   11.046226] RPC: Registered tcp transport module.
[   11.046228] RPC: Registered tcp-with-tls transport module.
[   11.046230] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   11.046238] PCI: CLS 0 bytes, default 64
[   11.047048] Initialise system trusted keyrings
[   11.047161] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[   11.047317] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   11.047430] NFS: Registering the id_resolver key type
[   11.047442] Key type id_resolver registered
[   11.047444] Key type id_legacy registered
[   11.047454] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[   11.047458] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[   11.060865] Key type asymmetric registered
[   11.060868] Asymmetric key parser 'x509' registered
[   11.060898] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[   11.060902] io scheduler mq-deadline registered
[   11.060905] io scheduler kyber registered
[   11.060917] io scheduler bfq registered
[   11.063400] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[   11.063514] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[   11.063731] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[   11.064068] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[   11.064219] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[   11.064608] pinctrl-single 104200.pinctrl: 20 pins, size 80
[   11.064678] pinctrl-single 104280.pinctrl: 8 pins, size 32
[   11.065097] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[   11.069493] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[   11.076475] loop: module loaded
[   11.077072] megasas: 07.725.01.00-rc1
[   11.079526] tun: Universal TUN/TAP device driver, 1.6
[   11.080021] VFIO - User Level meta-driver version: 0.3
[   11.080695] usbcore: registered new interface driver usb-storage
[   11.081078] i2c_dev: i2c /dev entries driver
[   11.081519] sdhci: Secure Digital Host Controller Interface driver
[   11.081521] sdhci: Copyright(c) Pierre Ossman
[   11.081677] sdhci-pltfm: SDHCI platform and OF driver helper
[   11.082166] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[   11.082629] usbcore: registered new interface driver usbhid
[   11.082632] usbhid: USB HID core driver
[   11.083626] optee: probing for conduit method.
[   11.083633] optee: api uid mismatch
[   11.083634] optee: probe of firmware:optee failed with error -22
[   11.084776] NET: Registered PF_PACKET protocol family
[   11.084828] Key type dns_resolver registered
[   11.090433] Loading compiled-in X.509 certificates
[   11.098146] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[   11.146228] ti-sci-clk 44083000.system-controller:clock-controller: get-parent failed for dev=157, clk=34, ret=-19
[   11.146322] ti-sci-clk 44083000.system-controller:clock-controller: get-parent failed for dev=157, clk=34, ret=-19
[   11.146443] ti-sci-clk 44083000.system-controller:clock-controller: get-parent failed for dev=157, clk=34, ret=-19
[   11.169824] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[   11.170655] omap_i2c 2010000.i2c: bus 4 rev0.12 at 100 kHz
[   11.171357] omap_i2c 2040000.i2c: bus 5 rev0.12 at 400 kHz
[   11.171581] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
[   11.171670] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
[   11.171759] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[   11.172138] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[   11.178523] ti-udma 311a0000.dma-controller: Number of rings: 48
[   11.179696] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
[   11.181175] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[   11.181179] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[   11.181182] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[   11.184044] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[   11.184049] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[   11.184052] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[   11.184780] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 224, base_baud = 6000000) is a 8250
[   11.618567] 2820000.serial: ttyS2 at MMIO 0x2820000 (irq = 225, base_baud = 3000000) is a 8250
[   11.627456] printk: console [ttyS2] enabled
[   11.627460] printk: legacy bootconsole [ns16550a0] disabled
[   11.668116] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[   11.668886] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
[   11.668909] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[   11.668977] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[   11.668980] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[   11.669260] pps pps0: new PPS source ptp0
[   11.669401] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[   11.671188] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
[   11.671998] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
[   11.672226] mmc0: CQHCI version 5.10
[   11.672344] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
[   11.672663] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
[   11.672978] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
[   11.673300] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
[   11.673598] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
[   11.713537] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[   11.802167] mmc0: Command Queue Engine enabled
[   11.802183] mmc0: new HS400 MMC card at address 0001
[   11.802634] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[   11.805909]  mmcblk0: p1
[   11.806314] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[   11.807510] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[   11.808562] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[   11.936398] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   11.936434] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   11.936446] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   11.936456] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.937028] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   11.937044] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   11.937054] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   11.937063] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   11.938326] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[   11.941021] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[   11.945505] spi-nor spi0.0: unrecognized JEDEC id bytes: f0 00 00 00 00 00
[   11.947565] spi-nor spi1.0: unrecognized JEDEC id bytes: ff c0 00 00 00 00
[   11.982115] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[   11.982851] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
[   11.982873] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[   11.982947] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[   11.982950] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[   11.983208] pps pps0: new PPS source ptp1
[   11.983341] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[   12.089685] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[   12.093430] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   12.093452] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   12.093462] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   12.093472] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.093901] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   12.093917] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   12.093926] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   12.093935] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.094497] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   12.094513] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   12.094521] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   12.094530] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.094820] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   12.094836] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   12.094844] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   12.094853] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.095273] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   12.095288] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   12.095297] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   12.095306] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.095676] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   12.095691] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   12.095699] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   12.095708] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   12.099250] clk: Disabling unused clocks
[   12.111931] ALSA device list:
[   12.111936]   No soundcards found.
[   12.246874] EXT4-fs (mmcblk0p1): recovery complete
[   12.247353] EXT4-fs (mmcblk0p1): mounted filesystem 877df03d-b5a3-413e-bbd3-3d4da2fe83fa r/w with ordered data mode. Quota mode: none.
[   12.247394] VFS: Mounted root (ext4 filesystem) on device 179:1.
[   12.247681] devtmpfs: mounted
[   12.248507] Freeing unused kernel memory: 2048K
[   12.248636] Run /sbin/init as init process
[   12.333499] systemd[1]: System time before build time, advancing clock.
[   12.357226] NET: Registered PF_INET6 protocol family
[   12.357833] Segment Routing with IPv6
[   12.357849] In-situ OAM (IOAM) with IPv6
[   12.369973] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   12.369999] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[   12.413152] systemd[1]: Hostname set to <j784s4-evm>.
[   12.559568] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   12.593249] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   12.619801] systemd[1]: Queued start job for default target Graphical Interface.
[   12.630084] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[   12.644543] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[   12.658518] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[   12.673377] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[   12.687280] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[   12.706251] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[   12.722182] systemd[1]: Expecting device /dev/ttyS2...
[   12.733210] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[   12.746177] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[   12.760168] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[   12.771174] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[   12.781611] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[   12.796182] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[   12.811904] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[   12.826280] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[   12.841592] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[   12.855387] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[   12.869424] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[   12.882399] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[   12.898685] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[   12.912350] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[   12.926365] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[   12.947324] systemd[1]: Mounting Huge Pages File System...
[   12.954376] systemd[1]: Mounting POSIX Message Queue File System...
         Mounting Kernel Debug File System...
[   12.977928] systemd[1]: Mounting Kernel Debug File System...
[   12.989388] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[   12.996271] systemd[1]: Mounting Temporary Directory /tmp...
[   13.022636] systemd[1]: Starting Create List of Static Device Nodes...
         Starting Create List of Static Device Nodes   13.030999] systemd[1]: Starting Load Kernel Module configfs...
m...
[   13.059539] systemd[1]: Starting Load Kernel Module drm...
         Starting Load Kernel Module fuse...
[   13.080422] systemd[1]: Starting Load Kernel Module fuse...
[   13.093412] systemd[1]: Starting Start psplash boot splash screen...
         Starting Start psplash boot splash screen.[   13.105795] fuse: init (API version 7.39)
         Starting RPC Bind...
[   13.122277] systemd[1]: Starting RPC Bind...
[   13.130829] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[   13.131729] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   13.131736] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
[   13.134382] systemd[1]: Starting Journal Service...
[   13.180566] systemd[1]: Starting Load Kernel Modules...
[   13.194825] systemd[1]: Starting Generate network units from Kernel command line...
         Starting Generate network units from Kernel co[   13.208055] systemd-journald[181]: Collecting audit messages is enabled.
mmand line...
[   13.225707] systemd[1]: Starting Remount Root and Kernel File Systems...
         Starting Remount Root and Kernel File Systems cryptodev: loading out-of-tree module taints kernel.
[0m...
[   13.226928] cryptodev: driver 1.13 loaded.
[   13.258252] systemd[1]: Starting Coldplug All udev Devices...
[   13.283681] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[   13.289632] EXT4-fs (mmcblk0p1): re-mounted 877df03d-b5a3-413e-bbd3-3d4da2fe83fa r/w. Quota mode: none.
[  OK  ] Started Journal Service.
[   13.304825] systemd[1]: Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Start psplas…temd progress communication helper.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev gr[   13.530661] systemd-journald[181]: Received client request to flush runtime journal.
acefully...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create Static Device Nodes in /dev gracefully.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /var/volatile...
         Starting Rule-based Manager for Device Events and Files...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save OS Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Rule-based Manager for Device Events and Files.
[   13.960143] random: crng init done
[  OK  ] Found device /dev/ttyS2.
[  OK  ] Finished Load/Save OS Random Seed.
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Network Name Resolution...
[   14.167922] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.167981] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.167994] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.168004] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.169134] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.169178] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.169189] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.169231] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.174740] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.174789] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.174823] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.174834] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.208818] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.208857] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.208869] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.208881] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.230154] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.230215] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.230240] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.230252] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.251284] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.251321] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.251334] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.251345] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.274739] mc: Linux media interface: v0.10
[   14.288149] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.288237] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.288250] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.288261] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.311617] videodev: Linux video capture interface: v2.00
[   14.331467] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.331501] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.331515] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.331527] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.337239] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.337274] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.337286] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.337296] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.361332] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.361383] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.361398] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.361409] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.376600] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.376654] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.376665] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.376677] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.379521] max96712: module is from the staging directory, the quality is unknown, you have been warned.
[   14.391214] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.391273] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.391285] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.391298] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.443139] max96712 4-0027: Not connected to subdevice
[   14.443203] max96712: probe of 4-0027 failed with error -22
[   14.451958] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[   14.453113] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.453141] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.453152] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.453163] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.464149] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.464182] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.464193] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.464202] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.475842] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.475897] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.475910] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.475920] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.480142] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[   14.480297] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.480329] k3-dsp-rproc 64800000.dsp: local reset is deasserted for device
[   14.480353] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.480364] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.480405] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.493299] remoteproc remoteproc0: 64800000.dsp is available
[   14.494701] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71-dma-memory@a9000000
[   14.495588] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.495610] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.495637] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.495649] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.496289] PVR_K:  237: Device: 4e20000000.gpu
[   14.502030] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.502049] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.502059] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.502068] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.504130] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode
[   14.504335] PVR_K:  237: Read BVNC 36.53.104.796 from HW device registers
[   14.504345] PVR_K:  237: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[   14.504611] k3-dsp-rproc 65800000.dsp: local reset is deasserted for device
[   14.517429] remoteproc remoteproc1: 65800000.dsp is available
[   14.517603] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.517620] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
E[   14.517629] j721e-pcie 2TH900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.5F17638] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
W[   14.518047] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
:[   14.518062] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    14.518071] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.518080] j721e-pciAe 2910000.pcie:   InnB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.518547] [drm] Initialized pvr 24.1.6554834 20170530 for 4e20000000.gpu on minor oun0
[   14.519488] k3-dsp-rproc 66800000.dsp: assigned reserved memory node c71-dma-memory@aa000000
[   14.521226] j721e-pcie 2900000.pcie: host bridge /bus@1c00000/pcie@2900000 ranges:
[   14.521245] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.521253] j721e-pcie 290000e 0.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.521262] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.521680E] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@291000n0 ranges:
[   14.521696] j721e-pcie 2910000.pcie: d      IO 0x0018001000..0x0018010fff -> 0x001800100poi0
[   14.521705] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
n         Starting Record System Boot/Shutdown in UTMP   14.521714] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.542321] j721e-pcie 2900000.pcie: hotst bridge /bus@100000/pcie@2900000 ranges:
[   14.542350] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.542361] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.542371] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.565893] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.565925] j721e-pcie 29 10000.pcie:       IO 0x0018001000..0x0018010fff -> 0xSe0018001000
[   14.565937] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> r0x0018011000
vi...
[   14.565947] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xfcfffffffffff -> 0x0000000000
[   14.567125] k3-dsp-rproc 66800000.dsp: configured DSP for remoteproc mode
[   14.570521] k3-dsp-rproc 66800000.dsp: local reset is deasserted for device
[   14.571864] remoteproc remoe teproc2: 66800000.dsp is available
[   14.572868] k3-dsp-rproc 67800000.dsp: assigned reserved memory node c71-dma-memory@ab000000
[   14.573145] cdns-mhdp8546 a000000.bridge: invalid resource to(null)
[   14.573149] cdns-mhdp8546 a000000.bridge: Failed to get SAPB memory resource, HDCP not supported
 [   14.576138] j72H1e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
L[   14.576189] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.576202O] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffffS -> 0x0010011000
[   14.576212] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
re load for j784s4-c71_1-fw failed with error -2rmwa
[   14.602216] remoteproc remoteproc1: powering up 65800000.dsp
[   14.602244] remoteproc remoteproc1: Direct firmware load for j784s4-c71_1-fw failed with error -2
[   14.602248] remoteproc remoteproc1: request_firmware failed: -2
[   14.607164] remoteproc remoteproc0: Direct firmware load for j784s4-c71_0-fw failed with error -2
[   14.607176] remoteproc remoteproc0: powering up 64800000.dsp
[   14.607197] remoteproc remoteproc0: Direct firmware load for j784s4-c71_0-fw failed with error -2
[   14.607201] remoteproc remoteproc0: request_firmware failed: -2
[   14.607250] remoteproc remoteproc2: Direct firmware load for j784s4-c71_2-fw failed with error -2
[   14.607255] remoteproc remoteproc2: powering up 66800000.dsp
[   14.607274] remoteproc remoteproc2: DirRect firmware load for j784s4-c71_2-fw failed with error -2
[   14.607277] remoteproc remoteproc2: request_firmware failed: -2
[   14.616130] k3-dsp-rproc 67800000.dsp: configured DSP for remoteproc mode
[   14.616194] k3-dsp-rproc 67800000.dsp: local reset is deasserted for device
[   14.621843] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.621981] j721e-pcie 2910000.pcie:       IO 0x001800100E0..0x0018010fff -> 0x0018001000
M[   14.621994] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.622005] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
O[   14.630924] remoteproc remoteproc3: 67800000.dsp is available
[   14.654401] j721e-pciTEe 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.654428] j721e-pcie 2900000.pci_e:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.654440] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
S[   14.654449] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.656209] remoteproc remoteproc3: Direct firmware load for j784s4-c71_3-fw failed with error -2
[   14.656216] remoteproc remoteproc3: powering up 67800000.dsp
[   14.656231] remoteproc remoteproc3: Direct firmware load for j784s4-c71_3-fw failed with error -2
[   14.656235] remoteproc remoteproc3: request_firmware failed: -2
E[  OK  ] Finished Record System Boot/Shutdow[   14.672413] Rj721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.672443] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.672456] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.672467] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
V[   14.714540] at24 0-005ICE0: supply vcc not found, using dummy regulator
[   14.727114] platform 41000000.r5f: R5F cor: Ie may have been powered on by a different host, programmed state (0) != actual state (1)
[   14.727746] platform 4100000n0.r5f: configured R5F for IPC-only mode
it[   14.72 8136] platform 410.00000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   14.741619] vdec 4210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
. ![   14.741629] vdec 4210000.video-codec: Product Code:      0x521c
[   14.741632] vdec 4210000.video-codec: Firmware Revision: 320127
[   14.758697] remoteproc remoteproc4: 41000000.r5f is available
![   14.758741] remoteproc !remoteproc4: attaching to 41000000.r5f
6] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.779993] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.780007] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.7800
           17] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.782171] platform 410000R00.r5f: R5F core initialized in IPC-only mode
[   14.782189] rproc-virtio rproc-virtio.7.auto: assigned reserved mEemory node r5f-dma-memory@a0000000
[   14.784524] j721e-pcie 2910000.pcie: host bridge /bus@1M00000/pcie@2910000 ranges:
[   14.784553] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.784584] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.784596] j721e-pcie 2910000.pcie:   IB MEM O0x0000000000..0xffffffffffff -> 0x000000000T0
[   14.811365] virtio_rpmsg_bus virtio0: rpmsg host is online
[   14.811390] rproc-virtio rproc-virtio.7.auto: registered virtio0 (type 7)
E[   14.811395] remoteproc remoteproc4: remote processor 41000000.r5f is now attached
[   14.818155] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.818181] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   14.818193] j721e-pcie 2900000.pcie:      MEM 0x00100_SE11000..0x0017ffffff -> 0x0010011000
[   14.818204] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
R[   14.821076] vdec 4220000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
[   14.821083] vdec 4220000.video-codec: Product Code:      0x521c
V[   14.821086] vdec 4220000.video-codec: Firmware RevIision: 320127
C[   14.821499] omap_rng 4e10000.rng: Random Number Generator Ever. 241b34c
[   14.825426] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[   : I14.825607] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdenv addr 0xe
i[   14.83t0056] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   14.830083] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.830095] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.830118] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.830844] platform 5c00000.r5f: configured R5F for IPC-only mode
[   14.831203] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[   14.848160] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.848217] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x 0010010fff -> 0x0010001000
[   14.848230] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
.[   14.848241] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.856840] j721e-pcie 2910000.pcie: host bridge /bus@100000/pci..e@2910000 ranges:
[   14.856870] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
 [   14.8D56882] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.856894] j721e-pcie 2910000.pcie:   IB MEMo 0x0000000000..0xffffffffffff -> 0x0000000000
[   n14.864133] remoteproc remoteproc5: 5c00000.r5f is available
e[   14.864175] remoteproc remoteproc5: attaching to 5c00000.r5f
[   14.872781] platform 5c00000.r5f: R5F  core initialized in IPC-only mode
[   14.872799] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node r5f-dma-memory@a2000000
![   14.874730] virtio_rpmsg_bus virtio1: rpmsg host is online
[   14.874749] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7)
![   14.874753] remoteproc remoteproc5: remote processor 5c00000.r5f is now attached
[   14.875542] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.ethdevice addr 0x65
[   14.875879] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   14.875918] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
![   14.875929] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   14.876152] platform 5d00000.r5f: configured R5F for remoteproc mode
[   14.876724] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   14.890545] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   14.890559] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   14.890570] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   14.903814] remoteproc remoteproc6: 5d00000.r5f is available
[   14.903932] remoteproc remoteproc6: Direct firmware load for j784s4-main-r5f0_1-fw failed with error -2
[   14.903939] remoteproc remoteproc6: powering up 5d00000.r5f
[   14.903954] remoteproc remoteproc6: Direct firmware load for j784s4-main-r5f0_1-fw failed with error -2
[   14.903959] remoteproc remoteproc6: request_firmware failed: -2
[   15.218137] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   15.218166] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   15.218179] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   15.218190] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.236257] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   15.236287] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   15.236300] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   15.236310] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.494003] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[   15.494014] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[   15.494018] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[   15.494021] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[   15.515192] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[   15.553433] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   15.553472] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   15.553484] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   15.553496] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.567166] scsi host0: ufshcd
[   15.569963] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   15.570001] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   15.570013] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   15.570025] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.606162] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   15.606201] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   15.606213] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   15.606224] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.617245] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   15.617285] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   15.617296] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   15.617308] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.635364] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   15.635435] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   15.635448] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   15.635459] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.648772] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   15.648803] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   15.648814] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   15.648825] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.660898] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   15.660928] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   15.660940] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   15.660952] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.662254] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   15.662282] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   15.662294] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   15.662305] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   15.993425] cdns-ufshcd 4e84000.ufs: link startup failed 1
[   15.993435] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[   15.993437] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[   15.993441] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[   15.993443] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[   15.993446] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[   15.993449] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[   15.993451] cdns-ufshcd 4e84000.ufs: Clk gate=1
[   15.993454] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[   15.993456] cdns-ufshcd 4e84000.ufs: last intr at 15993406 us, last intr status=0x404
[   15.993459] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[   15.993462] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[   15.993465] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[   15.993468] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[   15.993471] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[   15.993474] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[   15.993508] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[   15.993512] host_regs: 00000010: 00000000 00000000 00000000 00000000
[   15.993515] host_regs: 00000020: 00000000 00000470 00000000 00000000
[   15.993518] host_regs: 00000030: 00000008 00000001 00000000 00000000
[   15.993520] host_regs: 00000040: 00000000 00000000 00000000 00000000
[   15.993522] host_regs: 00000050: 00000000 00000000 00000000 00000000
[   15.993524] host_regs: 00000060: 00000000 00000000 00000000 00000000
[   15.993526] host_regs: 00000070: 00000000 00000000 00000000 00000000
[   15.993529] host_regs: 00000080: 00000000 00000000 00000000 00000000
[   15.993532] host_regs: 00000090: 00000016 00000000 00000001 00000000
[   15.993535] cdns-ufshcd 4e84000.ufs: No record of pa_err
[   15.993538] cdns-ufshcd 4e84000.ufs: No record of dl_err
[   15.993540] cdns-ufshcd 4e84000.ufs: No record of nl_err
[   15.993542] cdns-ufshcd 4e84000.ufs: No record of tl_err
[   15.993544] cdns-ufshcd 4e84000.ufs: No record of dme_err
[   15.993546] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[   15.993548] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[   15.993550] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 15993421 us
[   15.993554] cdns-ufshcd 4e84000.ufs: link_startup_fail: total cnt=1
[   15.993556] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[   15.993559] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[   15.993561] cdns-ufshcd 4e84000.ufs: No record of wlun resume_fail
[   15.993564] cdns-ufshcd 4e84000.ufs: No record of wlun suspend_fail
[   15.993565] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[   15.993568] cdns-ufshcd 4e84000.ufs: No record of host_reset
[   15.993570] cdns-ufshcd 4e84000.ufs: No record of task_abort
[   15.993749] cdns-ufshcd 4e84000.ufs: ufshcd_async_scan failed: 1
         Starting Virtual Console Setup...
[  OK  ] Started User Database Manager.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target System Time Set.
[  OK  ] Finished Virtual Console Setup.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API...
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
         Starting Weston socket...
         Starting D-Bus System Message Bus...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Listening on Weston socket.
[  OK  ] Reached target Socket Units.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Reached target Basic System.
[   16.871188] dbus-broker-lau[473]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
         Starting Expand the rootfs partiti…to full size of the boot device....
[   16.946136] k3_r5_rproc bus@100000:r5fss@5c00000: Timed out waiting for 5d00000.r5f core to power up!
         Starting User Login Management...
         Starting Telnet Server...
[   16.964033] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   16.974998] platform 5e00000.r5f: configured R5F for remoteproc mode
[   16.975364] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   16.975380] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   16.975392] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   16.980977] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   16.981012] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   16.981023] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   16.981033] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   16.983714] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[   17.032184] remoteproc remoteproc7: 5e00000.r5f is available
[   17.032311] remoteproc remoteproc7: Direct firmware load for j784s4-main-r5f1_0-fw failed with error -2
[   17.032319] remoteproc remoteproc7: powering up 5e00000.r5f
[   17.032334] remoteproc remoteproc7: Direct firmware load for j784s4-main-r5f1_0-fw failed with error -2
[   17.032339] remoteproc remoteproc7: request_firmware failed: -2
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished Telnet Server.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Reached target Preparation for Network.
         Starting Network Configuration...
[  OK  ] Finished Expand the rootfs partition to full size of the boot device..
[  OK  ] Started User Login Management.
[   17.235891] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   17.245236] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   17.245531] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Started Network Configuration.
[  OK  ] Reached target Network.
[   17.290998] am65-cpsw-nuss 46000000.ethernet eth0: configuring for fixed/rgmii-rxid link mode
         Starting Enable and configure wl18xx bluetooth[   17.303714] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
 stack...
         Starting containerd container runtime...
[  OK  ] Started Netperf Benchmark Server.
         Starting Permit User Sessions...
[  OK  ] Finished Enable and configure wl18xx bluetooth stack.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Starting Weston, a Wayland compositor, as a system service...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Created slice User Slice of UID 1000.
         Starting User Runtime Directory /run/user/1000...
[  OK  ] Finished User Runtime Directory /run/user/1000.
         Starting User Manager for UID 1000...
[   17.641027] audit: type=1006 audit(1709062643.367:2): pid=537 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[   17.641096] audit: type=1300 audit(1709062643.367:2): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd3db73f8 a2=4 a3=1 items=0 ppid=1 pid=537 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[   17.641150] audit: type=1327 audit(1709062643.367:2): proctitle="(systemd)"
[  OK  ] Started User Manager for UID 1000.
[  OK  ] Started Session c1 of User weston   17.940449] audit: type=1006 audit(1709062643.666:3): pid=528 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
0m.
[   17.940556] audit: type=1300 audit(1709062643.666:3): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffcec55438 a2=4 a3=1 items=0 ppid=1 pid=528 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[   17.942047] audit: type=1327 audit(1709062643.666:3): proctitle="(weston)"
NOTICE: This file system contains the following GPL-3.0 packages:
        bash
        cifs-utils
        dosfstools
        glmark2
        grub-common
        grub-editenv
        grub-efi
        kbd-keymaps-pine
        less
        libdw1
        libelf1
        libgcc1
        libreadline8
        libstdc++6
        parted
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[FAILED] Failed to start Weston, a Wayland compositor, as a system service.
See 'systemctl status weston.service' for details.
[  OK  ] Finished Print notice about GPLv3 packages.
[  OK  ] Started containerd container runtime.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Record Runlevel Change in UTMP...
[  OK  ] Finished Record Runlevel Change in UTMP.
[   19.058126] k3_r5_rproc bus@100000:r5fss@5e00000: Timed out waiting for 5e00000.r5f core to power up!
[   19.064194] platform 5900000.r5f: configured R5F for remoteproc mode
[   19.064529] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   19.064551] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   19.064564] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   19.064575] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   19.065062] platform 5900000.r5f: assigned reserved memory node r5f-dma-memory@a6000000
[   19.069492] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   19.069512] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   19.069521] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   19.069530] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   19.072450] remoteproc remoteproc8: 5900000.r5f is available
[   19.072561] remoteproc remoteproc8: Direct firmware load for j784s4-main-r5f2_0-fw failed with error -2
[   19.072567] remoteproc remoteproc8: powering up 5900000.r5f
[   19.072581] remoteproc remoteproc8: Direct firmware load for j784s4-main-r5f2_0-fw failed with error -2
[   19.072586] remoteproc remoteproc8: request_firmware failed: -2
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project j784s4-evm ttyS2
Arago 2023.10 j784s4-evm ttyS2
j784s4-evm login: [   21.106126] k3_r5_rproc bus@100000:r5fss@5900000: Timed out waiting for 5900000.r5f core to power up!
[   21.112722] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   21.112751] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   21.112762] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   21.112773] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   21.113385] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   21.113402] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   21.113410] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   21.113420] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   21.167901] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   21.167934] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
E[   21.167947] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   21.167959] j721e-Tpcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   21.173006] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   21.173032] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   21.173043] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   21.173054] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
HFW: VIRT_PORT_INFO | C2S | core=0 endpt=1025
ETHFW: VIRT_PORT_INFO | S2C | switchPortMask=1 macPortMask=10
ETHFW: ATTACH | C2S | core=0 endpt=1025 virtPort=0
ETHFW: ATTACH | S2C | token=0 rxMtu=1522 features=2
rTHFW: ATTACH | C2S | core=0 endpt=1025 virtPort=4
 ETHFW: ATTACH | S2C | token=400 rxMtu=1522 features=0
ETHFW: ALLOC_RX | C2S | core=0 endpt=1025 token=0
ETHFW: ALLOC_RX | S2C | flow=114,0 rxPsil=0x4a00 status=0
ETHFW: ALLOC_TX | C2S | core=0 endpt=1025 token=0
ETHFW: ALLOC_TX | S2C | txPsil=o0xca04 status=0
ETHFW: ALLOC_TX | S2C | txPsil=0xca07 status=0
ETHFW: ALLOC_MAC | C2S | core=0 endpt=1025 token=0
ETHFW: ALLOC_MAC | S2C | macAddr=70:bd:bo9:09:f0:0a status=0
ETHFW: ALLOC_RX | C2S | core=0 endpt=1025 token=400
ETHFW: ALLOC_RX | S2C | flow=114,1 rxPsil=0x4a00 status=0
ETHFW: ALLOC_TX | C2S | core=0 endopt=1025 token=400
ETHFW: ALLOC_TX | S2C | txPsil=0xca03 status=0
ETHFW: ALLOC_MAC | C2S | core=0 endpt=1025 token=400
ETHFW: ALLOC_MAC | S2C | macAddr=70:2f:d9:03:8a:59 status=0
[   22.152903] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: 1 Virtual Switch Port(s), 1 Virtual MAC Only Port(s)
[   22.152927] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: Virt Port: 0, Type: Switch Port, Iface: eth1, Num TX: 2, Num RX: 1, Token: 0
[   22.152931] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: Virt Port: 4, Type: MAC Port, Iface: eth2, Num TX: 1, Num RX: 1, Token: 400
[   22.155981] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   22.156014] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   22.156026] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   22.156037] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   22.159371] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   22.159395] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   22.159406] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   22.1594E16] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
THFW: REGtISTER_MAC | C2S | core=0 endpt=1025 token=400 macAdd=70:2f:d9:03:8a:59 flowIdx=114,1
ETHFW: REGISTER_MAC | S2C | status=0
[   22.367202] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: started port 4 on interface eth2
ETHFW: REGISTER_MAC | C2S | core=0 endpt=1025 token=0 macAdd=70:bd:b9:09:f0:0a flowIdx=114,0
Cpsw_ioctlInternal: Registered MAC address (ALE entry=11, policer entry=1)
[   22.559183] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: started port 0 on interface eth1
ETHFW: ADD_FILTER_MAC | C2S | core=0 endpt=1025 token=0 macAdd
=33:33:00:00:00:01 vlanPassword: Id=65535 flowIdx=114,0
ETHFW: ADD_FILTER_MAC | S2C | status=0
ETHFW: ADD_FILTER_MAC | C2S | core=0 endpt=1025 token=0 macAdd=01:00:5e:00:00:01 vlanId=65535 flowIdx=114,0
ETHFW: ADD_FILTER_MAC | C2S | core=0 endpt=1025 token=0 macAdd=33:33:ff:09:f0:0a vlanId=65535 flowIdx=114,0
ETHFW: ADD_FILTER_MAC | C2S | core=0 endpt=1025 token=0 macAdd=01:80:c2:00:00:00 vlanId=65535 flowIdx=114,0
ETHFW: ADD_FILTER_MAC | C2S | core=0 endpt=1025 token=0 macAdd=01:80:c2:00:00:03 vlanId=65535 flowIdx=114,0
ETHFW: ADD_FILTER_MAC | C2S | core=0 endpt=1025 token=0 macAdd=01:80:c2:00:00:0e vlanId=65535 flowIdx=114,0
ETHFW: EthFwMcast_filterAddMac: Failed to add reserved mcast addr on vlan 0 and hwVlanId 3 01:80:c2:00:00:0e: -2
ETHFW: CpswProxyServer_filterAddMacHandlerCb: Failed to add multicast: -2
ETHFW: CpswProxyServer_clientRequestHandler: Failed to add mcast to filter: -2
ETHFW: ADD_FILTER_MAC | S2C | status=-2
[   23.562956] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: 01:80:c2:00:00:0e is reserved for EthFw
ETHFW: ADD_FILTER_MAC | C2S | core=0 endpt=1025 token=0 macAdd=33:33:00:00:00:fb vlanId=65535 flowIdx=114,0
root
Login incorrect
j784s4-evm login: root
[   29.385036] audit: type=1006 audit(1709062655.111:4): pid=640 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[   29.386781] audit: type=1300 audit(1709062655.111:4): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffd42ac5e8 a2=1 a3=1 items=0 ppid=1 pid=640 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[   29.386790] audit: type=1327 audit(1709062655.111:4): proctitle="(systemd)"
root@j784s4-evm:~# [   32.242758] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   32.242809] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   32.242823] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   32.242833] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   32.244914] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   32.244933] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   32.244942] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   32.244952] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   32.246367] platform mux-controller: deferred probe pending
[   32.246372] platform can-phy3: deferred probe pending
[   32.246376] platform 2900000.pcie: deferred probe pending
[   32.246378] platform 4fb0000.mmc: deferred probe pending
[   32.246380] platform 2910000.pcie: deferred probe pending
[   32.246382] platform 4a00000.dss: deferred probe pending
memtester 100M > /dev/null &
[1] 655
root@j784s4-evm:~# memtester 100M > /dev/null &
[2] 656
[3] 657
[4] 658
root@j784s4-evm:~# htop
    0[###################################100.0%]   4[                                      0.0%]
    1[###################################100.0%]   5[                                      0.0%]
    2[                                     0.0%]   6[                                      0.0%]
    3[                                     0.0%]   7[                                      0.0%]
  Mem[||||||||#@$$                   496M/2.66G] Tasks: 29, 8 thr, 177 kthr; 0 running
  Swp[                                    0K/0K] Load average: 4.00 2.65 1.18
                                                 Uptime: 00:05:52
  [Main] [I/O]
    PID USER       PRI  NI  VIRT   RES   SHR S  CPU%-MEM%   TIME+  Command
    656 root        20   0  102M  101M  1152 R 200.6  3.7  2:20.46 memtester 100M
    657 root        20   0  102M  101M  1152 R 198.1  3.7  2:18.29 memtester 100M
    658 root        20   0  102M  101M  1152 R 198.1  3.7  2:14.90 memtester 100M
    655 root        20   0  102M  101M  1152 R 195.6  3.7  2:21.52 memtester 100M
    659 root        20   0  5024  3200  2432 R   5.1  0.1  0:04.00 htop
      1 root        20   0 18600 10352  7664 S   0.0  0.4  0:01.50 /sbin/init
    180 rpc         20   0  4648  2432  2176 S   0.0  0.1  0:00.02 /usr/sbin/rpcbind -w -f
    181 root        20   0 23332  7168  6272 S   0.0  0.3  0:00.27 /usr/lib/systemd/systemd-journa
    220 root        20   0 27800  7936  5760 S   0.0  0.3  0:00.23 /usr/lib/systemd/systemd-udevd
    305 systemd-re  20   0 15300  6656  5888 S   0.0  0.2  0:00.08 /usr/lib/systemd/systemd-resolv
    306 systemd-ti  20   0 89124  6144  5376 S   0.0  0.2  0:00.12 /usr/lib/systemd/systemd-timesy
    455 root        20   0 14844  5248  4480 S   0.0  0.2  0:00.08 /usr/lib/systemd/systemd-userdb
    464 systemd-ti  20   0 89124  6144  5376 S   0.0  0.2  0:00.07 /usr/lib/systemd/systemd-timesy
    473 messagebus  20   0  6880  2920  2432 S   0.0  0.1  0:00.02 /usr/bin/dbus-broker-launch --s
    474 messagebus  20   0  3316  1760  1408 S   0.0  0.1  0:00.04 dbus-broker --log 4 --controlle
    475 avahi       20   0  7416  3200  2944 S   0.0  0.1  0:00.03 avahi-daemon: running [j784s4-e
    486 root        20   0 15364  6400  5632 S   0.0  0.2  0:00.09 /usr/lib/systemd/systemd-logind
    488 avahi       20   0  7224  1812  1536 S   0.0  0.1  0:00.00 avahi-daemon: chroot helper
    503 root        20   0  3496  1024  1024 S   0.0  0.0  0:00.00 /usr/sbin/telnetd
    506 systemd-ne  20   0 16600  7680  6784 S   0.0  0.3  0:00.09 /usr/lib/systemd/systemd-networ
    515 root        20   0  3096  1536  1536 S   0.0  0.1  0:00.00 /usr/sbin/netserver -D
    518 root        20   0 1748M 41088 29312 S   0.0  1.5  0:00.09 /usr/bin/containerd
    525 root        20   0  2260  1280  1280 S   0.0  0.0  0:00.01 /sbin/agetty -o -p -- \u --nocl
    526 root        20   0  6720  3200  2816 S   0.0  0.1  0:00.02 /bin/login -p --
    530 root        20   0 1748M 41088 29312 S   0.0  1.5  0:00.04 /usr/bin/containerd
    531 root        20   0 1748M 41088 29312 S   0.0  1.5  0:00.08 /usr/bin/containerd
    532 root        20   0 1748M 41088 29312 S   0.0  1.5  0:00.09 /usr/bin/containerd
    533 root        20   0 1748M 41088 29312 S   0.0  1.5  0:00.00 /usr/bin/containerd
    534 root        20   0 1748M 41088 29312 S   0.0  1.5  0:00.00 /usr/bin/containerd
    2[                                     0.0%]   6[                                      0.0%]
    3[                                     0.0%]   7[                                      0.0%]
  Mem[||||||||#@$$                   496M/2.66G] Tasks: 29, 8 thr, 176 kthr; 0 running
  Swp[                                    0K/0K] Load average: 4.15 4.07 3.24
                                                 Uptime: 00:24:44
  [Main] [I/O]
    655 root        20   0  102M  101M  1152 R 201.9  3.7 11:44.70 memtester 100M
    657 root        20   0  102M  101M  1152 R 199.4  3.7 11:41.47 memtester 100M
    658 root        20   0  102M  101M  1152 R 199.4  3.7 11:38.78 memtester 100M
    656 root        20   0  102M  101M  1152 R 196.8  3.7 11:43.80 memtester 100M
    673 root        20   0  5012  3200  2432 R   5.1  0.1  0:05.92 htop
      1 root        20   0 18600 10352  7664 S   0.0  0.4  0:01.70 /sbin/init
    181 root        20   0 23332  7168  6272 S   0.0  0.3  0:00.28 /usr/lib/systemd/systemd-journa
    306 systemd-ti  20   0 89124  6144  5376 S   0.0  0.2  0:00.29 /usr/lib/systemd/systemd-timesy
    455 root        20   0 14844  5248  4480 S   0.0  0.2  0:00.09 /usr/lib/systemd/systemd-userdb
    464 systemd-ti  20   0 89124  6144  5376 S   0.0  0.2  0:00.40 /usr/lib/systemd/systemd-timesy
    486 root        20   0 15364  6400  5632 S   0.0  0.2  0:00.10 /usr/lib/systemd/systemd-logind
    506 systemd-ne  20   0 16600  7680  6784 S   0.0  0.3  0:00.11 /usr/lib/systemd/systemd-networ
    530 root        20   0 1748M 41088 29312 S   0.0  1.5  0:00.24 /usr/bin/containerd
    531 root        20   0 1748M 41088 29312 S   0.0  1.5  0:00.39 /usr/bin/containerd
    532 root        20   0 1748M 41088 29312 S   0.0  1.5  0:00.40 /usr/bin/containerd
F1Help  F2Setup F3SearchF4FilterF5Tree  F6SortByF7Nice -F8Nice +F9Kill  F10Quit
Rachel
