Other Parts Discussed in Thread: AM62P
Hi experts,
Customer is having an issue with am62p encoder with sdk 10.0. They found in some complex environment, the bitrate will be very high and encoder will stop working. Below is the setting customer is using. They are using ioctl directly not gstreamer.
V4L2_CID_MPEG_VIDEO_HEVC_LEVEL: V4L2_MPEG_VIDEO_HEVC_LEVEL_4_1
V4L2_CID_MPEG_VIDEO_BITRATE_MODE: V4L2_MPEG_VIDEO_BITRATE_MODE_VBR
V4L2_CID_MPEG_VIDEO_FRAME_RC_ENABLE: 1
V4L2_CID_MPEG_VIDEO_HEVC_I_FRAME_QP:30
V4L2_CID_MPEG_VIDEO_HEVC_CONST_INTRA_PRED:1
V4L2_CID_MPEG_VIDEO_HEVC_STRONG_SMOOTHING:1
V4L2_CID_MPEG_VIDEO_HEVC_MAX_NUM_MERGE_MV_MINUS1:2
V4L2_CID_MPEG_VIDEO_HEVC_TMV_PREDICTION:1
V4L2_CID_MPEG_VIDEO_PREPEND_SPSPPS_TO_IDR:1
V4L2_CID_MPEG_VIDEO_AU_DELIMITER:0
V4L2_CID_MPEG_VIDEO_HEVC_MIN_QP:8
V4L2_CID_MPEG_VIDEO_HEVC_MAX_QP:51
V4L2_BUF_TYPE_VIDEO_OUTPUT_MPLANE:format.fmt.pix_mp.pixelformat = fmt; format.fmt.pix_mp.width = w; format.fmt.pix_mp.height = h; format.fmt.pix_mp.colorspace = V4L2_COLORSPACE_REC709;
V4L2_BUF_TYPE_VIDEO_CAPTURE_MPLANE:CAPTURE_CODEC
V4L2_CID_MPEG_VIDEO_HEVC_REFRESH_PERIOD: 5
they have tried to set V4L2_CID_MPEG_VIDEO_BITRATE_MODE to CBR but it dose not work.
They way they check the bitrate output is through rtsp on am62p to send out streams and using vlc to get the stream and get the bitrate statics.
Adam
