TDA4AL-Q1: [IPC] how to enable IPC between MCU R5F(freertos) and A72 Linux
Part Number: TDA4AL-Q1
Dear TI-export
I would like to use enable IPC between MCU1_0 FreeRTOS and A73 LINUX.
i can use following command under default MCU1_0 FW ti-dm-fw under A73 LINUX
rpmsg_char_simple -r 0 -n 2 -p 14
However, I can not use ipc_rtos_echo_testb_freertos  to do the same test.
What should i use ipc_rtos_echo_testb_freertos or ipc_rtos_echo_test_freertos?
What does the difference  ipc_rtos_echo_testb_freertos and ipc_rtos_echo_test_freertos
I am use Linux R5 SPL , will it cause this issue like following link?
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1406740/tda4vm-issue-while-loading-the-ipc_rtos_echo_test-with-tispl-bin/5415365?tisearch=e2e-sitesearch&keymatch=ipc_rtos_echo_test#5415365
Thank you very much
  • Dear TI
    Please check the attach log,
    There are following error log about 41000000.r5f
    k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: rproc_add failed, ret = -22
    k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: k3_r5_cluster_rproailed, ret = -22
    k3_r5_rproc: probe of bus@100000:bus@28380000:r5fss@41000000 failed with error -22
    U-Boot SPL 2024.04-ti-gfe2afb809358 (Mar 18 2025 - 14:36:28 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.6--v10.01.06 (Fiery Fox)')
    Enable MCU ADC1 as GPI input
    MCU_CTRL_MMR_CFG0_MCU_ADC1_CTRL:10001
    MCU_ADC1_AIN0 value:0
    MCU_ADC1_AIN1 value:0
    MCU_ADC1_AIN2 value:0
    MCU_ADC1_AIN3 value:0
    hwid:0000
    hwid:0
    EEPROM not available at 0x50, trying to read at 0x51
    Reading on-board EEPROM at 0x51 failed -121
    SPL initial stack usage: 13456 bytes
    Trying to boot from MMC2
    Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the
    Loading Environment from nowhere... OK
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.11.0(release):v2.11.0-906-g58b25570c9-dirty
    NOTICE:  BL31: Built : 04:20:32, Nov  1 2024
    I/TC:
    I/TC: OP-TEE version: 4.4.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Oct 18 17:45:27 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.6--v10.01.06 (Fiery Fox)')
    I/TC: Activated SA2UL device
    I/TC: Fixing SA2UL firewall owner for GP device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: HUK Initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2024.04-ti-gfe2afb809358 (Mar 20 2025 - 11:34:33 +0000)
    hwid:0000
    hwid:0
    i2c_omap i2c@42120000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
    U-Boot 2024.04-ti-gfe2afb809358 (Mar 19 2025 - 06:54:11 +0000)
    SoC:   J721S2 SR1.0 GP
    Model: Texas Instruments J721S2 EVM
    Board: J721S2X-PM1-SOM rev E1
    DRAM:  2 GiB (effective 8 GiB)
    hwid:0000
    hwid:0
    Core:  111 devices, 31 uclasses, devicetree: separate
    Flash: 0 Bytes
    MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
    Loading Environment from MMC... *** Warning - bad CRC, using default environment
    In:    serial@2880000
    Out:   serial@2880000
    Err:   serial@2880000
    am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1
    name dtb is  ti/k3-j721s2-common-proc-board_pvt.dtb
    global hwid is  3
    Net:   eth0: ethernet@46000000port@1
    Press ESCESCESC to abort autoboot in 2 seconds
    switch to partitions #0, OK
    mmc0(part 0) is current device
    SD/MMC found on device 0
    Can't set block device
    33516032 bytes read in 115 ms (277.9 MiB/s)
    92674 bytes read in 49 ms (1.8 MiB/s)
    Working FDT set to 88000000
       Loading Device Tree to 000000008fee6000, end 000000008fffffff ... OK
    Working FDT set to 8fee6000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 6.6.32-ti-gc41847bf00f4 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binuti
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments J721S2 EVM
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000009dac00000, size 596 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000009dac00000..0x00000009ffffffff (610304 KiB) map reusable linux,cma
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable c71-dma-memory@a6000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable c71-memory@a6100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable c71-dma-memory@a7000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable c71-memory@a7100000
    [    0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a9bfffff (28672 KiB) nomap non-reusable ipc-memories@a8000000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a3ffffff]
    [    0.000000]   node   0: [mem 0x00000000a4000000-0x00000000a5ffffff]
    [    0.000000]   node   0: [mem 0x00000000a6000000-0x00000000a9bfffff]
    [    0.000000]   node   0: [mem 0x00000000a9c00000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: Spectre-v3a
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(opi.phypattern);spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.08-678a09f8de05 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2064384
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] Memory: 7363044K/8388608K available (11392K kernel code, 15130K rwdata, 3724K rodata, 2368K init, 4458K bss, 4
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880040000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008409] Console: colour dummy device 80x25
    [    0.012979] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023651] pid_max: default: 32768 minimum: 301
    [    0.028408] LSM: initializing lsm=capability,integrity
    [    0.033726] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.041489] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.050657] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.057921] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.065776] rcu: Hierarchical SRCU implementation.
    [    0.070675] rcu:     Max phase no-delay instances is 1000.
    [    0.076334] Platform MSI: msi-controller@1820000 domain created
    [    0.082615] EFI services will not be available.
    [    0.087384] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.100492] Detected PIPT I-cache on CPU1
    [    0.100542] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.100556] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
    [    0.100591] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.100658] smp: Brought up 1 node, 2 CPUs
    [    0.130009] SMP: Total of 2 processors activated.
    [    0.134815] CPU features: detected: 32-bit EL0 Support
    [    0.140070] CPU features: detected: CRC32 instructions
    [    0.145347] CPU: All CPU(s) started at EL2
    [    0.149530] alternatives: applying system-wide alternatives
    [    0.156138] devtmpfs: initialized
    [    0.168238] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.178211] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.194250] pinctrl core: initialized pinctrl subsystem
    [    0.200112] DMI not present or invalid.
    [    0.204405] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.211103] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.218587] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.226760] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.234991] audit: initializing netlink subsys (disabled)
    [    0.240620] audit: type=2000 audit(0.160:1): state=initialized audit_enabled=0 res=1
    [    0.248956] thermal_sys: Registered thermal governor 'step_wise'
    [    0.248959] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.261795] cpuidle: using governor menu
    [    0.265949] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.272914] ASID allocator initialised with 65536 entries
    [    0.306177] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
    [    0.319316] Modules: 23456 pages in range for non-PLT usage
    [    0.319319] Modules: 514976 pages in range for PLT usage
    [    0.331005] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.337947] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.344350] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.351284] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.357685] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.364618] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.371020] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.377953] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.385515] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
    [    0.394713] iommu: Default domain type: Translated
    [    0.399619] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.406074] SCSI subsystem initialized
    [    0.410713] usbcore: registered new interface driver usbfs
    [    0.416352] usbcore: registered new interface driver hub
    [    0.421811] usbcore: registered new device driver usb
    [    0.427251] pps_core: LinuxPPS API ver. 1 registered
    [    0.432324] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.441672] PTP clock support registered
    [    0.445830] EDAC MC: Ver: 3.0.0
    [    0.449496] scmi_core: SCMI protocol bus registered
    [    0.454743] FPGA manager framework
    [    0.458931] clocksource: Switched to clocksource arch_sys_counter
    [    0.465298] VFS: Disk quotas dquot_6.6.0
    [    0.469321] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.481153] NET: Registered PF_INET protocol family
    [    0.486438] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.496853] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.505648] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.513583] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.521897] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    0.531188] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.538002] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.545048] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.552618] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.558792] RPC: Registered named UNIX socket transport module.
    [    0.564851] RPC: Registered udp transport module.
    [    0.569656] RPC: Registered tcp transport module.
    [    0.574459] RPC: Registered tcp-with-tls transport module.
    [    0.580065] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.586648] NET: Registered PF_XDP protocol family
    [    0.592447] Initialise system trusted keyrings
    [    0.597146] workingset: timestamp_bits=46 max_order=21 bucket_order=0
    [    0.603954] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.610101] NFS: Registering the id_resolver key type
    [    0.615285] Key type id_resolver registered
    [    0.619558] Key type id_legacy registered
    [    0.623665] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.630514] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.651651] Key type asymmetric registered
    [    0.655837] Asymmetric key parser 'x509' registered
    [    0.660860] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.668420] io scheduler mq-deadline registered
    [    0.673047] io scheduler kyber registered
    [    0.677167] io scheduler bfq registered
    [    0.683690] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
    [    0.689795] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
    [    0.696110] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
    [    0.702859] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
    [    0.708892] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.715251] pinctrl-single 104200.pinctrl: 20 pins, size 80
    [    0.721085] pinctrl-single 104280.pinctrl: 8 pins, size 32
    [    0.728300] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.738199] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.752379] loop: module loaded
    [    0.759347] tun: Universal TUN/TAP device driver, 1.6
    [    0.764700] CAN device driver interface
    [    0.769129] VFIO - User Level meta-driver version: 0.3
    [    0.775014] usbcore: registered new interface driver usb-storage
    [    0.782337] sdhci: Secure Digital Host Controller Interface driver
    [    0.788673] sdhci: Copyright(c) Pierre Ossman
    [    0.793264] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.799415] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.805776] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.813007] usbcore: registered new interface driver usbhid
    [    0.818703] usbhid: USB HID core driver
    [    0.823629] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.832270] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.836827] optee: revision 4.4 (8f645256efc0dc66)
    [    0.858201] optee: dynamic shared memory is enabled
    [    0.863675] random: crng init done
    [    0.867226] optee: initialized driver
    [    0.871538] NET: Registered PF_PACKET protocol family
    [    0.876723] can: controller area network core
    [    0.881210] NET: Registered PF_CAN protocol family
    [    0.886105] can: raw protocol
    [    0.889134] can: broadcast manager protocol
    [    0.893406] can: netlink gateway - max_hops=1
    [    0.897918] Key type dns_resolver registered
    [    0.909406] registered taskstats version 1
    [    0.913677] Loading compiled-in X.509 certificates
    [    0.927395] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.1.6--v10.01.06 (Fiery Fox)')
    [    0.991522] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
    [    1.000146] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
    [    1.009543] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
    [    1.018263] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
    [    1.027087] ti-udma 311a0000.dma-controller: Number of rings: 48
    [    1.034194] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
    [    1.044032] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
    [    1.053916] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.060681] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.070592] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
    [    1.080783] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.087543] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.096053] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 226, base_baud = 6000000) is a 8250
    [    1.106128] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 227, base_baud = 3000000) is a 8250
    [    1.115058] printk: console [ttyS2] enabled
    [    1.123514] printk: bootconsole [ns16550a0] disabled
    [    1.136329] m_can_plat_probe Enter
    [    1.140351] m_can_platform 26a1000.can: m_can device registered (irq=229, version=32)
    [    1.148311] m_can_plat_probe exit
    [    1.152437] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.198934] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.447268] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83TG721CS1.0
    [    1.456164] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Port
    [    1.469052] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.476261] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.482521] pps pps0: new PPS source ptp0
    [    1.486688] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
    [    1.497978] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0
    [    1.506776] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    1.513638] mmc0: CQHCI version 5.10
    [    1.517266] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    1.524258] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    1.537626] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.548717] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16)
    [    1.562409] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.567463] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    1.574072] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.574086] Creating 7 MTD partitions on "47040000.spi.0":
    [    1.587018] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.593669] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.599862] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.606041] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.612095] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.618852] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.625271] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.632319] m_can_plat_probe Enter
    [    1.636419] m_can_platform 40528000.can: m_can device registered (irq=489, version=32)
    [    1.644462] m_can_plat_probe exit
    [    1.648019] m_can_plat_probe Enter
    [    1.651976] m_can_platform 40568000.can: m_can device registered (irq=490, version=32)
    [    1.660021] m_can_plat_probe exit
    [    1.663550] m_can_plat_probe Enter
    [    1.667483] m_can_platform 2731000.can: m_can device registered (irq=491, version=32)
    [    1.675430] m_can_plat_probe exit
    [    1.678949] m_can_plat_probe Enter
    [    1.682873] m_can_platform 2751000.can: m_can device registered (irq=492, version=32)
    [    1.690834] m_can_plat_probe exit
    [    1.694914] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.724063] mmc0: Command Queue Engine enabled
    [    1.728512] mmc0: new HS400 MMC card at address 0001
    [    1.733876] mmcblk0: mmc0:0001 AAM20E 29.6 GiB
    [    1.738953] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.749620]  mmcblk0: p1
    [    1.752517] mmcblk0boot0: mmc0:0001 AAM20E 31.5 MiB
    [    1.758266] mmcblk0boot1: mmc0:0001 AAM20E 31.5 MiB
    [    1.763950] mmcblk0rpmb: mmc0:0001 AAM20E 4.00 MiB, chardev (239:0)
    [    1.987230] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83TG721CS1.0
    [    1.996140] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Port
    [    2.009057] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.016267] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.022538] pps pps0: new PPS source ptp1
    [    2.026703] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
    [    2.041977] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    2.052283] mmc1: CQHCI version 5.10
    [    2.059429] clk: Disabling unused clocks
    [    2.091528] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    2.153586] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
    [    2.160648] mmcblk1: mmc1:aaaa ABLCD 29.7 GiB
    [    2.169784]  mmcblk1: p1 p2
    [    2.192184] EXT4-fs (mmcblk0p1): recovery complete
    [    2.198522] EXT4-fs (mmcblk0p1): mounted filesystem 6984f383-6ac6-49ab-9206-9b05ad037595 r/w with ordered data mode. Quota
    [    2.210640] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [    2.217448] devtmpfs: mounted
    [    2.221476] Freeing unused kernel memory: 2368K
    [    2.226138] Run /sbin/init as init process
    [    2.310442] systemd[1]: System time before build time, advancing clock.
    [    2.334282] NET: Registered PF_INET6 protocol family
    [    2.339857] Segment Routing with IPv6
    [    2.343533] In-situ OAM (IOAM) with IPv6
    [    2.365355] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPTQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unifi
    [    2.397147] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.10!
    [    2.416549] systemd[1]: Hostname set to <j721s2-evm>.
    [    2.590789] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automaticall
    [    2.648653] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically
    [    2.696778] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.738109] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    2.760306] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    2.784128] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    2.807847] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    2.831182] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    2.855111] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    2.879016] systemd[1]: Expecting device /dev/ttyS2...
    [    2.895052] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    2.911006] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    2.931011] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    2.947005] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    2.990134] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.015112] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.038725] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.059261] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.083633] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    3.107352] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.131367] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.151411] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.176898] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.199302] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.219285] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    3.259255] systemd[1]: Mounting Huge Pages File System...
    [    3.281416] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.307393] systemd[1]: Mounting Kernel Debug File System...
    [    3.327328] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys
    [    3.359006] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.384649] systemd[1]: Starting Create List of Static Device Nodes...
             Starting Create List of Static Device Nodes    3.394171] systemd[1]: Starting Load Kernel Module configfs...
    m...
    [    3.447585] systemd[1]: Starting Load Kernel Module drm...
    [    3.471662] systemd[1]: Starting Load Kernel Module fuse...
    [    3.507482] systemd[1]: Starting Start psplash boot splash screen...
    [    3.520259] fuse: init (API version 7.39)
    [    3.528197] systemd[1]: Starting RPC Bind...
    [    3.547237] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsR
    [    3.574107] systemd[1]: Starting Journal Service...
    [    3.603782] systemd[1]: Starting Load Kernel Modules...
    [    3.618014] systemd[1]: Starting Generate network units from Kernel command line...
    [    3.647364] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    3.657146] systemd-journald[103]: Collecting audit messages is enabled.
    [    3.683499] cryptodev: loading out-of-tree module taints kernel.
    [    3.690242] systemd[1]: Starting Coldplug All udev Devices...
    [    3.711476] cryptodev: driver 1.13 loaded.
    [    3.714013] EXT4-fs (mmcblk0p1): re-mounted 6984f383-6ac6-49ab-9206-9b05ad037595 r/w. Quota mode: none.
    [    3.742415] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    3.755691] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    3.771622] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    3.799611] systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [    3.827624] systemd[1]: Mounted Temporary Directory /tmp.
    [  OK  ] Mounted Temporary Directory /tmp.
    [    3.856268] systemd[1]: Finished Create List of Static Device Nodes.
    [  OK  ] Finished Create List of Static Device Nodes.
    [    3.884012] systemd[1]: modprobe@configfs.service: Deactivated successfully.
    [    3.895732] systemd[1]: Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module configfs.
    [    3.912316] systemd[1]: modprobe@drm.service: Deactivated successfully.
    [    3.923826] systemd[1]: Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module drm.
    [    3.948151] systemd[1]: modprobe@fuse.service: Deactivated successfully.
    [    3.959718] systemd[1]: Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Module fuse.
    [    3.987653] systemd[1]: psplash-start.service: Main process exited, code=exited, status=255/EXCEPTION
    [    4.003501] systemd[1]: psplash-start.service: Failed with result 'exit-code'.
    [    4.015771] systemd[1]: Failed to start Start psplash boot splash screen.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [    4.047205] systemd[1]: Dependency failed for Start psplash-systemd progress communication helper.
    [DEPEND] Dependency failed for Start psplas…temd progress communication helper.
    [    4.075106] systemd[1]: psplash-systemd.service: Job psplash-systemd.service/start failed with result 'dependency'.
    [    4.092325] systemd[1]: Finished Load Kernel Modules.
    [  OK  ] Finished Load Kernel Modules.
    [    4.116183] systemd[1]: Finished Generate network units from Kernel command line.
    [  OK  ] Finished Generate network units from Kernel command line.
    [    4.143098] systemd[1]: Finished Remount Root and Kernel File Systems.
    [  OK  ] Finished Remount Root and Kernel File Systems.
    [    4.168368] systemd[1]: Finished Coldplug All udev Devices.
    [  OK  ] Finished Coldplug All udev Devices.
    [    4.206894] systemd[1]: Mounting FUSE Control File System...
    [    4.239484] systemd[1]: Mounting Kernel Configuration File System...
    [    4.272650] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/e
    [    4.299471] systemd[1]: Starting Apply Kernel Variables...
    [    4.331872] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
    [    4.357315] systemd[1]: Mounted FUSE Control File System.
    [  OK  ] Mounted FUSE Control File System.
    [    4.379744] systemd[1]: Mounted Kernel Configuration File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [    4.407007] systemd[1]: Finished Apply Kernel Variables.
    [  OK  ] Finished Apply Kernel Variables.
    [    4.435022] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
    [    4.459932] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
    [    4.487466] systemd[1]: Starting Create Static Device Nodes in /dev...
    [    4.514362] systemd[1]: Finished Create Static Device Nodes in /dev.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [    4.539428] systemd[1]: Reached target Preparation for Local File Systems.
    [  OK  ] Reached target Preparation for Local File Systems.
    [    4.583289] systemd[1]: Mounting /var/volatile...
    [    4.600689] audit: type=1334 audit(1709054766.288:2): prog-id=6 op=LOAD
    [    4.611518] systemd[1]: Starting Rule-based Manager for Device Events and Files...
    [    4.619142] audit: type=1334 audit(1709054766.296:3): prog-id=7 op=LOAD
    [    4.652692] systemd[1]: Mounted /var/volatile.
    [  OK  ] Mounted /var/volatile.
    [    4.675645] systemd[1]: Bind mount volatile /var/cache was skipped because of an unmet condition check (ConditionPathIsRea
    [    4.694423] systemd[1]: Bind mount volatile /var/lib was skipped because of an unmet condition check (ConditionPathIsReadW
    [    4.727479] systemd[1]: Starting Load/Save OS Random Seed...
    [    4.743281] systemd[1]: Bind mount volatile /var/spool was skipped because of an unmet condition check (ConditionPathIsRea
    [    4.757699] systemd[1]: Bind mount volatile /srv was skipped because of an unmet condition check (ConditionPathIsReadWrite
    [    4.770874] systemd[1]: Reached target Local File Systems.
    [  OK  ] Reached target Local File Systems.
    [    4.787378] systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
    [    4.852810] systemd[1]: Finished Load/Save OS Random Seed.
    [  OK  ] Finished Load/Save OS Random Seed.
    [    4.879445] systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
    [    4.890638] systemd[1]: Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPatPoint=/etc/machine-id).
    [    4.913255] systemd[1]: Started Rule-based Manager for Device Events and Files.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [    5.099423] m_can_platform 26a1000.can main_mcan16: renamed from can0
    [    5.188268] m_can_platform 2731000.can main_mcan3: renamed from can3
    [    5.273821] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [    5.440352] m_can_platform 2751000.can main_mcan5: renamed from can4
             Starting Flush Journal to Persistent Storage...
    [    5.502582] systemd-journald[103]: Received client request to flush runtime journal.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Finished Flush Journal to Persisten[    5.537136] m_can_platform 40528000.can mcu_mcan0: renamed from can1
    t Storage.
    [    5.634285] m_can_platform 40568000.can mcu_mcan1: renamed from can2
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Create Volatile Files and Directories.
    [    5.907776] audit: type=1334 audit(1709054767.596:4): prog-id=8 op=LOAD
             Starting Network Name Resolution...
    [    5.942066] audit: type=1334 audit(1709054767.628:5): prog-id=9 op=LOAD
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [    6.061045] audit: type=1334 audit(1709054767.748:6): prog-id=10 op=LOAD
    [    6.075033] audit: type=1334 audit(1709054767.756:7): prog-id=11 op=LOAD
    [    6.087156] audit: type=1334 audit(1709054767.756:8): prog-id=12 op=LOAD
             Starting User Database Manager...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started User Database Manager.
    [    6.320468] mc: Linux media interface: v0.10
    [    6.340860] videodev: Linux video capture interface: v2.00
    [    6.373886] pinctrl-single 4301c068.pinctrl: pin PIN54 already requested by 42110000.gpio; cannot claim for 40200000.tscad
    [    6.398047] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a6000000
    [    6.427203] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [    6.462276] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [  OK  ] Started Network Time Synchronization.
    [    6.523929] pinctrl-single 4301c068.pinctrl: pin-54 (40200000.tscadc) status -22
    [  OK  ] Reached target System Time Set.
    [    6.543428] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Reached target System Initializatio[    6.577531] k3-dsp-rproc 64800000.dsp: local reset is deasserted for device
    n.
    [    6.596586] pinctrl-single 4301c068.pinctrl: could not request pin 54 (PIN54) from group mcu-adc0-default-pins  on device single
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stac[    6.640190] remoteproc remoteproc0: 64800000.dsp is available
    k Activation Socket.
    [  OK  ] Listening on D-Bus System Message B[    6.659056] ti_am3359-tscadc 40200000.tscadc: Error applying setting, reverse ack
    us Socket.
             Starting Docker Socket for the API...
    [    6.701776] vdec 4210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    6.710070] vdec 4210000.video-codec: Product Code:      0x521c
    [    6.716485] vdec 4210000.video-codec: Firmware Revision: 320127
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
             Starting Weston socket...
    [    6.797707] remoteproc remoteproc0: powering up 64800000.dsp
    [    6.822214] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual s
    [    6.822774] remoteproc remoteproc0: Booting fw image j721s2-c71_0-fw, size 15077408
    [    6.866843] platform 41000000.r5f: configured R5F for IPC-only mode
    [    6.873667] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [    6.881869] audit: type=1334 audit(1709059606.788:9): prog-id=13 op=LOAD
    [    6.884925] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71-dma-memory@a7000000
    [    6.898717] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode
    [    6.905889] k3-dsp-rproc 65800000.dsp: local reset is deasserted for device
    [    6.915256] remoteproc remoteproc1: 41000000.r5f is available
    [    6.922206] remoteproc remoteproc1: attaching to 41000000.r5f
    [    6.928706] remoteproc remoteproc1: rsc table is truncated
    [    6.934531] remoteproc remoteproc1: Failed to process resources: -22
    [    6.934715] remoteproc remoteproc2: 65800000.dsp is available
    [    6.950989] remoteproc remoteproc0: unsupported resource 65538
    [    6.959077] remoteproc remoteproc0: bad phdr da 0xb0100000 mem 0x98
    [    6.974980] remoteproc remoteproc0: Failed to load program segments: -22
    [    7.004367] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: rproc_add failed, ret = -22
    [    7.011869] remoteproc remoteproc2: powering up 65800000.dsp
    [    7.034521] remoteproc remoteproc2: Booting fw image j721s2-c71_1-fw, size 9703384
    [    7.044694] remoteproc remoteproc1: releasing 41000000.r5f
    [    7.051614] remoteproc remoteproc2: unsupported resource 65538
    [    7.061192] remoteproc remoteproc2: bad phdr da 0xb6100000 mem 0x98
    [    7.069742] remoteproc remoteproc2: Failed to load program segments: -22
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Listening on Weston socket.
    [  OK  ] Started D-Bus System Message Bus
    7.173200] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: k3_r5_cluster_rproailed, ret = -22
    m.
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [    7.239958] dbus-broker-lau[456]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
    [    7.258884] k3_r5_rproc: probe of bus@100000:bus@28380000:r5fss@41000000 failed with error -22
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
             Starting Avahi mDNS/DNS-SD Stack...
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
    [    7.373454] platform 5c00000.r5f: configured R5F for remoteproc mode
             Starting IPv4 Packet Filtering Framework...
    [    7.408900] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
    [  OK  ] Started FIH Camera Demo Service.
             Starting Expand the rootfs partiti…to full size of the boot device....
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv[    7.488020] audit: type=1334 audit(1709059607.400:10): prog-id=14 op=LOAD
    2 daemon using ipsec.conf.
    [    7.500856] audit: type=1334 audit(1709059607.412:11): prog-id=15 op=LOAD
    [    7.509362] audit: type=1334 audit(1709059607.424:12): prog-id=16 op=LOAD
             Starting User Login Management...
             Starting Telnet Server...
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Preparation for Netw[    7.560967] audit: type=1334 audit(1709059607.472:13): prog-id=17 op=LOAD
    ork.
    [    7.568587] at24 0-0050: supply vcc not found, using dummy regulator
             Starting Network Configuration...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
             Starting Virtual Console Setup...
    [    7.653038] remoteproc remoteproc1: 5c00000.r5f is available
    [    7.716258] remoteproc remoteproc1: powering up 5c00000.r5f
    [    7.724763] remoteproc remoteproc1: Booting fw image j721s2-main-r5f0_0-fw, size 875980
    [    7.741470] remoteproc remoteproc1: bad phdr da 0xa3ffec00 mem 0x1400
    [    7.751531] remoteproc remoteproc1: Failed to load program segments: -22
    [  OK  ] Finished Telnet Server.
    [  OK  ] Started Telephony service.
    [    7.844684] Bluetooth: Core ver 2.22
    [    7.848372] NET: Registered PF_BLUETOOTH protocol family
    [    7.858972] Bluetooth: HCI device and connection manager initialized
    [    7.865685] Bluetooth: HCI socket layer initialized
    [    7.872891] Bluetooth: L2CAP socket layer initialized
    [    7.884062] Bluetooth: SCO socket layer initialized
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [  OK  ] Started User Login Management.
    [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [    8.131304] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.150559] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.159773] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [  OK  ] Finished Virtual Console Setup.
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
             Starting Enable and configure wl18xx bluetooth stack...
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston, a Wayland compositor, as a system service...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Created slice User Slice of UID 1000.
             Starting User Runtime Directory /run/user/1000...
    [    8.852756] tps6594-rtc tps6594-rtc.5.auto: registered as rtc0
    [  OK  ] Finished User Runtime Directory /run/user/1000.
    [    8.888919] tps6594-rtc tps6594-rtc.5.auto: hctosys: unable to read the hardware clock
             Starting User Manager for UID 1000...
    [    9.247795] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83TG721CS1.0] (irq=POLL)
    [    9.277278] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Session c1 of User weston.
    [FAILED] Failed to start Weston, a Wayland compositor, as a system service.
    See 'systemctl status weston.service' for details.
    [    9.671216] k3_r5_rproc bus@100000:r5fss@5c00000: Timed out waiting for 5c00000.r5f core to power up!
    [  OK  ] Created slice Slice /system/systemd-fsck.
             Expecting device /dev/mmcblk1p2...
             Expecting device /dev/mmcblk1p1...
    [  OK  ] Started containerd container runtime.
    [  OK  ] Found device /dev/mmcblk1p2.
             Starting File System Check on /dev/mmcblk1p2...
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/BOOT-mmcblk1p1...
    [  OK  ] Mounted /run/media/BOOT-mmcblk1p1.
    [  OK  ] Finished File System Check on /dev/mmcblk1p2.
             Mounting /run/media/mmcblk1p2...
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            binutils
            cifs-utils
            cpp-symlinks
            cpp
            dosfstools
            g++-symlinks
            g++
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp10
            libidn2-0
            libmpc3
            libmpfr6
            libopcodes
            libqt5charts-examples
            libqt5charts-plugins
            libqt5charts-qmlplugins
            libqt5charts5
            libqt5serialport-examples
            libqt5serialport-plugins
            libqt5serialport-qmlplugins
            libqt5serialport5
            libqt5svg-examples
            libqt5svg-plugins
            libqt5svg-qmlplugins
            libqt5svg5
            libqt5virtualkeyboard-plugins
            libqt5virtualkeyboard-qmlplugins
            libqt5virtualkeyboard5
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libunistring5
            m4
            make
            nettle
            parted
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase
            qtconnectivity-plugins
            qtconnectivity-qmlplugins
            qtconnectivity
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-tools
            qtdeclarative
            qtgraphicaleffects-qmlplugins
            qtlocation-examples
            qtlocation-plugins
            qtlocation-qmlplugins
            qtlocation
            qtmultimedia-examples
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquics-qmlplugins.control
            qtquics2-plugins.control
            qtquics2-qmlplugins.control
            qtquics2.control
            qtscript-examples
            qtscript-plugins
            qtscript-qmlplugins
            qtscript
            qtwayland-examples
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Mounted /run/media/mmcblk1p2.
    [  OK  ] Finished Print notice about GPLv3 packages.
    [  OK  ] Reached target Multi-User System.
    [  OK  ] Reached target Graphical Interface.
             Starting Record Runlevel Change in UTMP...
    [  OK  ] Finished Record Runlevel Change in UTMP.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project j721s2-evm ttyS2
    Arago 2023.10 j721s2-evm ttyS2
    j721s2-evm login: root
    [   15.885409] kauditd_printk_skb: 6 callbacks suppressed
    [   15.885416] audit: type=1006 audit(1709059615.796:16): pid=986 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   15.902989] audit: type=1300 audit(1709059615.796:16): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff1ecd5f8 a2=1 a3=1 items=0 ppid=1 pid=986 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   15.929487] audit: type=1327 audit(1709059615.796:16): proctitle="(systemd)"
    [   15.936661] audit: type=1334 audit(1709059615.816:17): prog-id=18 op=LOAD
    [   15.943585] audit: type=1300 audit(1709059615.816:17): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffccdd81e8 a2=90 a3=0 items=0 ppid=1 pid=986 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   15.969289] audit: type=1327 audit(1709059615.816:17): proctitle="(systemd)"
    [   15.976385] audit: type=1334 audit(1709059615.844:18): prog-id=18 op=UNLOAD
    [   15.983348] audit: type=1300 audit(1709059615.844:18): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffb1c2ec60 items=0 ppid=1 pid=986 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   15.983356] audit: type=1327 audit(1709059615.844:18): proctitle="(systemd)"
    [   15.983366] audit: type=1334 audit(1709059615.844:19): prog-id=19 op=LOAD
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~# rpmsg_char_simple -r 0 -n 2 -p 1
    file_deref_link: readlink failed for /sys/bus/platform/devices/41000000.r5f
    _rpmsg_char_find_rproc: 41000000.r5f device is mostly yet to be created!
    Can't create an endpoint device: Bad address
    TEST STATUS: FAILED
    root@j721s2-evm:~# rpmsg_char_simple -r 2 -n 2 -p 1
    _rpmsg_char_find_rproc: 5c00000.r5f does not have any virtio devices!
    Can't create an endpoint device: No such file or directory
    TEST STATUS: FAILED
    root@j721s2-evm:~# rpmsg_char_simple -r 2 -n 1 -p 1
    TEST STATUS: FAILED
    root@j721s2-evm:~# rpmsg_char_simple -r 1 -n 1 -p 1
    file_deref_link: readlink failed for /sys/bus/platform/devices/41400000.r5f
    _rpmsg_char_find_rproc: 41400000.r5f device is mostly yet to be created!
    TEST STATUS: FAILED
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~# rpmsg_char_simple -r 0 -n 1 -p 1
    TEST STATUS: FAILED
    root@j721s2-evm:~#
    root@j721s2-evm:~#
    root@j721s2-evm:~# head /sys/class/remoteproc/remoteproc*/name
    ==> /sys/class/remoteproc/remoteproc0/name <==
    64800000.dsp
    ==> /sys/class/remoteproc/remoteproc1/name <==
    5c00000.r5f
    ==> /sys/class/remoteproc/remoteproc2/name <==
    65800000.dsp
    TEST STATUS: FAILED
    root@j721s2-evm:~#
  • rpmsg_char_simple -r 0 -n 2 -p 14
    This is a sample application with linux on A72 and ipc_echo_test on R5F.
    If you change ipc_echo_test then this application might not work.
    You have to use ipc_rtos_echo_testb_freertos  for MCU R5F because in SPL mode only BTCM will be enabled by default . so the ipc_rtos_echo_testb_freertos has the reset vectors at BTCM location.
    whereas ipc_rtos_echo_test_freertos has reset vectors in ATCM location which is not enabled by default for MCU R5F in SPL.
    Tarun Mukesh
  • Dear Tarun Mukesh
    I use ipc_rtos_echo_testb_freertos but the A72 log have following error.
    How to fixed it?
    Thank you very much
    May i know what steps you followed to add in ti-dm ?
    Tarun Mukesh
  • Dear Tarun Mukesh
    i prebuild the ipc_rtos_echo_testb_freertos at pdk_j721s2_10_01_00_25\packages\ti
    copy pdk_j721s2_10_01_00_25\packages\ti\binary\ipc_rtos_echo_testb_freertos\bin\j721s2_evm\ipc_rtos_echo_testb_freertos_mcu1_0_release_strip.xer5f to yocto-build\sources\meta-ti\meta-ti-bsp\recipes-bsp\ti-dm-fw
    and replease the origin ipc_echo_testb_mcu1_0_release_strip.xer5f file
    Rebuild the tispl.bin file by build all image under yocto SW
    Do i miss any steps
    Thank you
  • Dear Tarun Mukesh
    Do you have any update?
    Thank you very much
    Did you use the same name  ipc_echo_testb_mcu1_0_release_strip.xer5f for ipc_rtos_echo_testb_freertos executable ?
    You build the ipc_rtos_echo_testb_freertos executable but replace the name as "ipc_echo_testb_mcu1_0_release_strip.xer5f" then REBUILD the tispl.bin ,since tispl is looking for the name of ipc_echo_testb
    RegardS
    TARUN MUKESH
  • Dear Tarun Mukesh
    Yes, i use the same name.
    you can check the attached .bb file
    SUMMARY = "TI DM prebuilt binary firmware images"
    LICENSE = "TI-TFL"
    LIC_FILES_CHKSUM = "file://${THISDIR}/../../licenses/TI-TFL;md5=a1b59cb7ba626b9dbbcbf00f3fbc438a"
    COMPATIBLE_MACHINE = "k3"
    PACKAGE_ARCH = "${MACHINE_ARCH}"
    INHIBIT_DEFAULT_DEPS = "1"
    inherit deploy
    inherit update-alternatives
    require recipes-bsp/ti-linux-fw/ti-linux-fw.inc
    DM_FIRMWARE_FIH = "fih_dm_firmware_v1_strip.xer5f"
    SRC_URI += "file://${DM_FIRMWARE_FIH}"
    PV = "${TI_DM_FW_VERSION}"
    PR = "${INC_PR}.0"
    # Secure Build
    inherit ti-secdev
    PLAT_SFX = ""
    PLAT_SFX:j721e = "j721e"
    PLAT_SFX:j7200 = "j7200"
    PLAT_SFX:j721s2 = "j721s2"
    PLAT_SFX:j784s4 = "j784s4"
    PLAT_SFX:j722s = "j722s"
    PLAT_SFX:j742s2 = "j742s2"
    PLAT_SFX:am65xx = "am65xx"
    PLAT_SFX:am64xx = "am64xx"
    PLAT_SFX:am62xx = "am62xx"
    PLAT_SFX:am62axx = "am62axx"
    PLAT_SFX:am62pxx = "am62pxx"
    DM_FW_DIR = "ti-dm/${PLAT_SFX}"
    INSTALL_DM_FW_DIR  = "${nonarch_base_libdir}/firmware/${DM_FW_DIR}"
    DM_FIRMWARE = "ipc_echo_testb_mcu1_0_release_strip.xer5f"
    DM_FW_LIST = ""
    DM_FW_LIST:j721e =   "${DM_FIRMWARE}"
    DM_FW_LIST:j7200 =   "${DM_FIRMWARE}"
    DM_FW_LIST:j721s2 =  "${DM_FIRMWARE}"
    DM_FW_LIST:j784s4 =  "${DM_FIRMWARE}"
    DM_FW_LIST:j722s =   "${DM_FIRMWARE}"
    DM_FW_LIST:j742s2 =  "${DM_FIRMWARE}"
    DM_FW_LIST:am65xx =  ""
    DM_FW_LIST:am64xx =  ""
    DM_FW_LIST:am62xx =  "${DM_FIRMWARE}"
    DM_FW_LIST:am62axx = "${DM_FIRMWARE}"
    DM_FW_LIST:am62pxx = "${DM_FIRMWARE}"
    do_install() {
        install -d ${S}/${DM_FW_DIR}
        install -m 0644 ${S}/../${DM_FIRMWARE_FIH} ${S}/${DM_FW_DIR}/${DM_FIRMWARE}
        # Sign the firmware
        # DM Firmware
        for FW_NAME in ${DM_FW_LIST}
        do
            ${TI_SECURE_DEV_PKG}/scripts/secure-binary-image.sh ${S}/${DM_FW_DIR}/${FW_NAME} ${S}/${DM_FW_DIR}/${FW_NAME}.signed
        done
        # DM Firmware
        install -d ${D}${INSTALL_DM_FW_DIR}
        do
            install -m 0644 ${S}/${DM_FW_DIR}/${FW_NAME}        ${D}${INSTALL_DM_FW_DIR}/
            install -m 0644 ${S}/${DM_FW_DIR}/${FW_NAME}.signed ${D}${INSTALL_DM_FW_DIR}/
        done
    do_deploy() {
        # DM Firmware is needed for rebuilding U-Boot
        install -d ${DEPLOYDIR}/${DM_FW_DIR}
        do
            install -m 0644 ${S}/${DM_FW_DIR}/${FW_NAME}        ${DEPLOYDIR}/${DM_FW_DIR}
            install -m 0644 ${S}/${DM_FW_DIR}/${FW_NAME}.signed ${DEPLOYDIR}/${DM_FW_DIR}
        done
    # Set up names for the firmwares
    ALTERNATIVE:${PN}:am62xx  = "am62-main-r5f0_0-fw"
    ALTERNATIVE:${PN}:am62pxx  = "am62p-main-r5f0_0-fw"
    ALTERNATIVE:${PN}:am62axx = "am62a-main-r5f0_0-fw"
    ALTERNATIVE:${PN}:j721e   = "j7-mcu-r5f0_0-fw"
    ALTERNATIVE:${PN}:j7200   = "j7200-mcu-r5f0_0-fw"
    ALTERNATIVE:${PN}:j721s2  = "j721s2-mcu-r5f0_0-fw"
    ALTERNATIVE:${PN}:j784s4  = "j784s4-mcu-r5f0_0-fw"
    ALTERNATIVE:${PN}:j722s   = "j722s-wkup-r5f0_0-fw"
    ALTERNATIVE:${PN}:j742s2  = "j742s2-mcu-r5f0_0-fw"
    # Set up link names for the firmwares
    ALTERNATIVE_LINK_NAME[am62-main-r5f0_0-fw]  = "${nonarch_base_libdir}/firmware/am62-main-r5f0_0-fw"
    ALTERNATIVE_LINK_NAME[am62p-main-r5f0_0-fw]  = "${nonarch_base_libdir}/firmware/am62p-main-r5f0_0-fw"
    ALTERNATIVE_LINK_NAME[am62a-main-r5f0_0-fw] = "${nonarch_base_libdir}/firmware/am62a-main-r5f0_0-fw"
    ALTERNATIVE_LINK_NAME[j7-mcu-r5f0_0-fw]     = "${nonarch_base_libdir}/firmware/j7-mcu-r5f0_0-fw"
    ALTERNATIVE_LINK_NAME[j7200-mcu-r5f0_0-fw]  = "${nonarch_base_libdir}/firmware/j7200-mcu-r5f0_0-fw"
    ALTERNATIVE_LINK_NAME[j721s2-mcu-r5f0_0-fw] = "${nonarch_base_libdir}/firmware/j721s2-mcu-r5f0_0-fw"
    ALTERNATIVE_LINK_NAME[j784s4-mcu-r5f0_0-fw] = "${nonarch_base_libdir}/firmware/j784s4-mcu-r5f0_0-fw"
    ALTERNATIVE_LINK_NAME[j722s-wkup-r5f0_0-fw] = "${nonarch_base_libdir}/firmware/j722s-wkup-r5f0_0-fw"
    ALTERNATIVE_LINK_NAME[j742s2-mcu-r5f0_0-fw] = "${nonarch_base_libdir}/firmware/j742s2-mcu-r5f0_0-fw"
    # Create the firmware alternatives
    ALTERNATIVE_TARGET[am62-main-r5f0_0-fw]  = "${INSTALL_DM_FW_DIR}/${DM_FIRMWARE}"
    ALTERNATIVE_TARGET[am62p-main-r5f0_0-fw]  = "${INSTALL_DM_FW_DIR}/${DM_FIRMWARE}"
    ALTERNATIVE_TARGET[am62a-main-r5f0_0-fw] = "${INSTALL_DM_FW_DIR}/${DM_FIRMWARE}"
    ALTERNATIVE_TARGET[j7-mcu-r5f0_0-fw]     = "${INSTALL_DM_FW_DIR}/${DM_FIRMWARE}"
    ALTERNATIVE_TARGET[j7200-mcu-r5f0_0-fw]  = "${INSTALL_DM_FW_DIR}/${DM_FIRMWARE}"
    ALTERNATIVE_TARGET[j721s2-mcu-r5f0_0-fw] = "${INSTALL_DM_FW_DIR}/${DM_FIRMWARE}"
    ALTERNATIVE_TARGET[j784s4-mcu-r5f0_0-fw] = "${INSTALL_DM_FW_DIR}/${DM_FIRMWARE}"
    ALTERNATIVE_TARGET[j722s-wkup-r5f0_0-fw] = "${INSTALL_DM_FW_DIR}/${DM_FIRMWARE}"
    ALTERNATIVE_TARGET[j742s2-mcu-r5f0_0-fw] = "${INSTALL_DM_FW_DIR}/${DM_FIRMWARE}"
    ALTERNATIVE_PRIORITY = "10"
    addtask deploy after do_install
  • Dear Tarun Mukesh
    The origin fw name is ipc_rtos_echo_testb_freertos_mcu1_0_release_strip.xer5f
    and i rename it to ipc_echo_testb_mcu1_0_release_strip.xer5f
  • Hello Daniel,
    One more point to add here,
    This example "ipc_rtos_echo_testb_freertos_mcu1_0_release_strip.xer5f" only communicates with R5 cores running RTOS. If you see the example in PDK RTOS, It echoes back messages from other RTOS cores.
    rpmsg_char_simple command cannot work with ipc_rtos_echo_testb_freertos_mcu1_0_release_strip.xer5f application executable.
    In your case you are running A72 with linux , so you need to use ipc_echo_testb_mcu1_0_release_strip.xer5f  only (This is same example as above but for linux)
    Tarun Mukesh
  • Dear Tarun Mukesh,
    The ipc_echo_testb_mcu1_0_release_strip.xer5f seem the prebuild image under yocto codebase.
    I would like to have a mcu1_0 fw (builded by our) that can use ipc to communicates with   A72 with rpmsg_char_simple.
    Do you have any comment about this request?
    Thank you very much
  • Hello Daniel,
    I understood your request but the ipc_echo_test example we have in PDK we did the same way and linked so that rpmsg_char_simple will work.
    May be you can build the same example ipc_echo_test in PDK and attach as you did similar way for ipc_rtos_echo_test. ipc_rtos_echo_test doesn't communicate with A72 running linux.
    If you are interested to build MCAL directory other than PDK then we have cdd_ipc example based on MCU1_0 communicates with A72 running linux.
    Tarun MUkesh
  • Dear Tarun Mukesh
    Thank you.
    I can let MCU do echo test with A72 Linux if i use ipc_echo_test of my build.
    I had try the cdd_ipc mcuss demo example
    However, it seem not run after SPL mode.
    Does it cause by ATCM mode?
    I had try both  mcal example cddipc and can profile
    How to run mcuss demo under SPL mode?
    Thank you very much
    Thank you.
    Thats great!!
    No i am not saying about CDD IPC In MCUSS demos
    Please follow the below link
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/latest/exports/docs/mcusw/mcal_drv/docs/drv_docs/ug_cdd_ipc_top.html#:~:text=Build%20MCAL%20example%20application%20for%20Linux%20communication
    This application you rename to ipc_echo_test and do the build steps you followed above, this application communicates with A72 running linux and works fine for prmsg_char_simple test as well.
    Tarun Mukesh
