TDA4VEN-Q1: [TDA4VEN][J722S] [SDK10.1]Setting ltm lut caused flicker on the screen with two 3M camera
Part Number: TDA4VEN-Q1
Other Parts Discussed in Thread: TDA4VL
Hi Ti team
there are two camera with 1920*1536 resolution on J722s platform in SDK 10.1
when we set lookup Table of glbce to isp driver . one camera stream is ok,
but the other camera is flicking on the screen .
when we don't set the   lookup Table of glbce , both of  two cameras are ok .
please help me check.
best regards
sungenben
  • Hi sungenben,
    Which sdk release are you using? Are both of these camera complete different? Is GLBCE context save and restore are enabled for these camera?
    Brijesh
  • Hi Brijesh
    we use sdk 10.1
    yes both of two cameras are the same ,but have own parameters .
    yes we are enable the save and restore as below
    vissDrvPrms->enableGlbceSaveRestoreCtx=TRUE;
    BTW ,if we set the same lookup Table of glbce for two cameras ,
    both of camera streams are ok .
    best regards
    sungenben
  • Hi Brijesh
    I had added my source code ,could you help me check?
     * vx_vpac_ce_viss_target.c
     * Target of ISP kernel for Cogent ISP framework.
     * Copyright (c) 2015-2020 Cogent Embedded Inc.
     * ALL RIGHTS RESERVED.
     * The source code contained or described herein and all documents related to the
     * source code("Software") or their modified versions are owned by
     * Cogent Embedded Inc. or its affiliates.
     * No part of the Software may be used, copied, reproduced, modified, published,
     * uploaded, posted, transmitted, distributed, or disclosed in any way without
     * prior express written permission from Cogent Embedded Inc.
     * Cogent Embedded Inc. grants a nonexclusive, non-transferable, royalty-free
     * license to use the Software to Licensee without the right to sublicense.
     * Licensee agrees not to distribute the Software to any third-party without
     * the prior written permission of Cogent Embedded Inc.
     * Unless otherwise agreed by Cogent Embedded Inc. in writing, you may not remove
     * or alter this notice or any other notice embedded in Software in any way.
     * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
     * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
     * FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENt-> IN NO EVENT SHALL THE
     * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
     * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
     * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
     * THE SOFTWARE.
    /*                             Include Files                                  */
    #include "tivx_hwa_ce_viss_priv.h"
    #include "tivx_kernel_vpac_ce_viss.h"
    #include "utils/perf_stats/include/app_perf_stats.h"
    #include <utils/udma/include/app_udma.h>
    #include <common_sensor_api.h>
    #include <vx_vpac_ce_common.h>
    #include <inttypes.h>
    #include <stdlib.h>
    /*                           Macros & Typedefs                                */
    /* #undef below to see performance without VISS GLBCE context save/restore */
    #define VHWA_VISS_GLBCE_CTX_SAVE_RESTORE_ENABLE
    /* #undef below to see performance using CPU for VISS GLBCE context save/restore */
    #define VHWA_VISS_GLBCE_CTX_SAVE_RESTORE_USE_DMA
    /*                         Structure Declarations                             */
    /*                          Function Declarations                             */
    static vx_status VX_CALLBACK tivxVpacCeVissCreate(
        tivx_target_kernel_instance kernel,
        tivx_obj_desc_t *obj_desc[],
        uint16_t num_params, void *priv_arg);
    static vx_status VX_CALLBACK tivxVpacCeVissDelete(
    static vx_status VX_CALLBACK tivxVpacCeVissProcess(
    static void tivxVpacVissSetInputParams(tivxVpacCeIspObj *ispObj,
                                           const tivx_obj_desc_raw_image_t *raw_img_desc);
    static vx_status tivxVpacVissSetOutputParams(tivxVpacCeIspObj *ispObj,
                                                 const tivx_vpac_ce_isp_params_t *vissPrms,
                                                 tivx_obj_desc_image_t *obj_desc[]);
    static vx_status tivxVpacVissMapFormat(uint32_t *fmt, uint32_t *ccsFmt,
                                           uint32_t out_id, uint32_t vxFmt, uint32_t mux_val);
    static vx_status tivxVpacVissMapStorageFormat(uint32_t *ccsFmt, uint32_t vxFmt);
    static void tivxVpacVissSetIsInvalidFlag(tivx_obj_desc_t *obj_desc[]);
    int32_t tivxVpacCeVissFrameComplCb(Fvid2_Handle handle, void *appData);
    static vx_status vhwaVissAllocMemForCtx(tivxVpacCeIspObj *ispObj);
    static void vhwaVissFreeCtxMem(tivxVpacCeIspObj *ispObj);
    static void vhwaVissRestoreCtx(const tivxVpacCeIspObj *ispObj);
    static void vhwaVissSaveCtx(const tivxVpacCeIspObj *ispObj);
    /*                            Global Variables                                */
    static tivx_target_kernel vx_vpac_ce_viss_target_kernel = NULL;
    extern tivxVpacCeIspObj g_ceIspObjs[VHWA_M2M_VISS_MAX_HANDLES];
    /*                          Function Definitions                              */
    void tivxAddTargetKernelVpacCeViss(void)
        vx_status status = (vx_status)VX_FAILURE;
        char target_name[TIVX_TARGET_MAX_NAME];
        vx_enum self_cpu;
        self_cpu = tivxGetSelfCpuId();
    if (self_cpu == (vx_enum)TIVX_CPU_ID_MCU2_0)
            strncpy(target_name, TIVX_TARGET_VPAC_CE_VISS, TIVX_TARGET_MAX_NAME);
            status = (vx_status)VX_SUCCESS;
        else
            VX_PRINT(VX_ZONE_ERROR, "Invalid CPU ID\n");
        if (status == (vx_status)VX_SUCCESS)
            vx_vpac_ce_viss_target_kernel = tivxAddTargetKernelByName(
                TIVX_KERNEL_VPAC_CE_VISS_NAME, target_name,
                tivxVpacCeVissProcess, tivxVpacCeVissCreate,
                tivxVpacCeVissDelete, NULL, NULL);
        if (NULL == vx_vpac_ce_viss_target_kernel)
            VX_PRINT(VX_ZONE_ERROR, "Failed to add target kernel by name %s\n",
                     TIVX_TARGET_VPAC_CE_VISS);
    void tivxRemoveTargetKernelVpacCeViss(void)
        vx_status status = (vx_status)VX_SUCCESS;
        status = tivxRemoveTargetKernel(vx_vpac_ce_viss_target_kernel);
        else
            VX_PRINT(VX_ZONE_ERROR, "Failed to Remove Viss TargetKernel\n");
    /* Setting the output descriptor flags to invalid if received raw_image is invalid */
        uint32_t cnt;
        uint32_t out_start;
        if (tivxFlagIsBitSet(obj_desc[TIVX_KERNEL_VPAC_CE_VISS_RAW_IDX]->flags,
                             TIVX_REF_FLAG_IS_INVALID) == 1U)
            for (cnt = 0U; cnt < TIVX_KERNEL_VPAC_CE_VISS_MAX_IMAGE_OUTPUT; cnt++)
                out_start = TIVX_KERNEL_VPAC_CE_VISS_OUT0_IDX;
                if (NULL != obj_desc[out_start])
                    tivxFlagBitSet(&obj_desc[out_start]->flags, TIVX_REF_FLAG_IS_INVALID);
                out_start++;
        else
                    tivxFlagBitClear(&obj_desc[out_start]->flags, TIVX_REF_FLAG_IS_INVALID);
                out_start++;
    /*                              OPENVX Callbacks                              */
        uint32_t cnt;
        tivxVpacCeIspObj *ispObj = NULL;
        tivx_vpac_ce_isp_params_t *ispPrms = NULL;
        tivx_obj_desc_image_t *img_desc[TIVX_KERNEL_VPAC_CE_VISS_MAX_IMAGE_OUTPUT];
        tivx_obj_desc_raw_image_t *raw_img_desc =
            (tivx_obj_desc_raw_image_t *)obj_desc[TIVX_KERNEL_VPAC_CE_VISS_RAW_IDX];
        tivx_obj_desc_user_data_object_t *config_desc =
            (tivx_obj_desc_user_data_object_t *)obj_desc[TIVX_KERNEL_VPAC_CE_VISS_CONFIGURATION_IDX];
            img_desc[cnt] = (tivx_obj_desc_image_t *)
                obj_desc[TIVX_KERNEL_VPAC_CE_VISS_OUT0_IDX + cnt];
        status = tivxVpacCeMapUserDesc((void **)&ispPrms, config_desc,
                                       sizeof(tivx_vpac_ce_isp_params_t),
                                       (vx_enum)VX_READ_ONLY);
        if ((vx_status)VX_SUCCESS != status)
            VX_PRINT(VX_ZONE_ERROR, "Failed to Map Parameters Descriptor\n");
        else
            ispObj = &g_ceIspObjs[ispPrms->context_id];
            /* local copy  */
            memcpy((void *)&ispObj->ispPrms, (void *)ispPrms,
                   sizeof(tivx_vpac_ce_isp_params_t));
            tivxVpacCeUnmapUserDesc((void **)&ispPrms, config_desc,
            ispPrms = &ispObj->ispPrms;
        if ((vx_status)VX_SUCCESS == status)
            status = tivxEventCreate(&ispObj->eventProcessCmpl);
                VX_PRINT(VX_ZONE_ERROR, "Failed to allocate Event\n");
            status = tivxEventCreate(&ispObj->eventVissCmpl);
            tivxEventPost(ispObj->eventVissCmpl);
            status = tivxEventCreate(&ispObj->eventRcCmpl);
            Vhwa_M2mVissCreateArgs createArgs;
            Vhwa_m2mVissCreateArgsInit(&createArgs);
            Fvid2_CbParams cbPrms;
            cbPrms.cbFxn = tivxVpacCeVissFrameComplCb;
            cbPrms.appData = ispObj;
            ispObj->handle = Fvid2_create(FVID2_VHWA_M2M_VISS_DRV_ID,
                                          VHWA_M2M_VISS_DRV_INST0, &createArgs, NULL, &cbPrms);
            if (NULL == ispObj->handle)
                VX_PRINT(VX_ZONE_ERROR, "Failed to Open Driver\n");
                status = (vx_status)VX_ERROR_NO_RESOURCES;
        /* #<{(| before writing configuration set application buffer |)}># */
        if ((vx_status) VX_SUCCESS == status)
            status = tivxVpacCeVissSetConfigBuffer(ispObj);
            if (VX_SUCCESS != status)
                VX_PRINT(VX_ZONE_ERROR, "Failed to set ConfigBuf in driver\n");
        /* Allocate memory for the GLBCE Statistics */
            status = vhwaVissAllocMemForCtx(ispObj);
            Vhwa_M2mVissParams *vissDrvPrms = &ispObj->vissPrms;
            Vhwa_m2mVissParamsInit(vissDrvPrms);
            vissDrvPrms->enableDpc = (uint32_t)FALSE;
            vissDrvPrms->enableGlbce = (uint32_t)TRUE;
            vissDrvPrms->enableNsf4 = (uint32_t)TRUE;
            vissDrvPrms->edgeEnhancerMode = VHWA_M2M_VISS_EE_ON_LUMA8;
          //  vissDrvPrms->cfa_mode=1;
            vissDrvPrms->chromaMode=0;
            vissDrvPrms->enableCac=0;
            tivxVpacVissSetInputParams(ispObj, raw_img_desc);
            status = tivxVpacVissSetOutputParams(ispObj, ispPrms, img_desc);
                VX_PRINT(VX_ZONE_ERROR, "Failed to set Output Params\n");
            int32_t fvid2_status = Fvid2_control(ispObj->handle,
                                         IOCTL_VHWA_M2M_VISS_SET_PARAMS,
                                         (void *)&ispObj->vissPrms, NULL);
            if (FVID2_SOK != fvid2_status)
                VX_PRINT(VX_ZONE_ERROR, "Failed to set Params in driver\n");
            status = tivxSetTargetKernelInstanceContext(kernel, ispObj,
                                                        sizeof(tivxVpacCeIspObj));
                VX_PRINT(VX_ZONE_ERROR, "Failed to set target kernel instance\n");
            /* Set up the input frame list */
            for (cnt = 0U; cnt < ispObj->num_in_buf; cnt++)
                ispObj->inFrmList.frames[cnt] = &ispObj->inFrm[cnt];
            ispObj->inFrmList.numFrames = ispObj->num_in_buf;
            /* Set up the output frame list */
            for (cnt = 0U; cnt < VHWA_M2M_VISS_MAX_OUTPUTS; cnt++)
                ispObj->outFrmList.frames[cnt] = &ispObj->outFrm[cnt];
            ispObj->outFrmList.numFrames = VHWA_M2M_VISS_MAX_OUTPUTS;
            if (NULL != ispObj)
                if (NULL != ispObj->handle)
                    Fvid2_delete(ispObj->handle, NULL);
                    ispObj->handle = NULL;
                if (NULL != ispObj->eventProcessCmpl)
                    tivxEventDelete(&ispObj->eventProcessCmpl);
                if (NULL != ispObj->eventRcCmpl)
                    tivxEventDelete(&ispObj->eventRcCmpl);
                if (NULL != ispObj->eventVissCmpl)
                    tivxEventDelete(&ispObj->eventVissCmpl);
                vhwaVissFreeCtxMem(ispObj);
        return (status);
        uint32_t size;
        status = tivxGetTargetKernelInstanceContext(kernel, (void **)&ispObj,
                                                    &size);
            VX_PRINT(VX_ZONE_ERROR, "Incorrect kernel instance context\n");
        else if ((NULL == ispObj) ||
                 (sizeof(tivxVpacCeIspObj) != size))
            VX_PRINT(VX_ZONE_ERROR, "Incorrect Object Size\n");
        else
        return (status);
        int32_t fvid2_status = FVID2_SOK;
        uint32_t cnt;
        uint32_t buf_cnt;
        uint32_t size;
        uint64_t cur_time;
                                                    &size);
        else if ((NULL == ispObj) || (sizeof(tivxVpacCeIspObj) != size))
            tivxVpacVissSetIsInvalidFlag(obj_desc);
            for (cnt = 0u; cnt < ispObj->num_in_buf; cnt++)
                ispObj->inFrm[cnt].addr[0u] = tivxMemShared2PhysPtr(
                    raw_img_desc->img_ptr[cnt].shared_ptr,
                    (int32_t)raw_img_desc->img_ptr[cnt].mem_heap_region);
            for (cnt = 0u; cnt < TIVX_KERNEL_VPAC_CE_VISS_MAX_IMAGE_OUTPUT; cnt++)
                for (buf_cnt = 0U; buf_cnt < ispObj->num_out_buf_addr[cnt];
                     buf_cnt++)
                    ispObj->outFrm[cnt].addr[buf_cnt] = tivxMemShared2PhysPtr(
                        img_desc[cnt]->mem_ptr[buf_cnt].shared_ptr,
                        (int32_t)img_desc[cnt]->mem_ptr[buf_cnt].mem_heap_region);
            ispObj->outFrm[VHWA_M2M_VISS_OUT_H3A_IDX].addr[0u] = (uint64_t)ispObj->h3a_stats_data;
            /*.. Propagate timestamps. WARNING: Output index 2 is YUV image */
            img_desc[2u]->base.timestamp = raw_img_desc->base.timestamp;
        tivxEventWait(ispObj->eventRcCmpl, TIVX_EVENT_TIMEOUT_WAIT_FOREVER);
        cur_time = tivxPlatformGetTimeInUsecs();
            vhwaVissRestoreCtx(ispObj);
            fvid2_status = Fvid2_processRequest(ispObj->handle, &ispObj->inFrmList,
                                                &ispObj->outFrmList, FVID2_TIMEOUT_FOREVER);
                VX_PRINT(VX_ZONE_ERROR, "Failed to Submit Request\n");
            else
                tivxEventWait(ispObj->eventProcessCmpl,
                fvid2_status = Fvid2_getProcessedRequest(ispObj->handle,
                                                         &ispObj->inFrmList, &ispObj->outFrmList, 0);
                    VX_PRINT(VX_ZONE_ERROR, "Failed to Get Processed Request\n");
    			//VX_PRINT(VX_ZONE_ERROR, "success  to Get Processed Request\n");
            vhwaVissSaveCtx(ispObj);
            if (ispObj->yuvData.valid)
                tivxYuvEmbData *g = &ispObj->yuvData;
                tivx_shared_mem_ptr_t *ptr = &img_desc[g->output_idx]->mem_ptr[g->buf_idx];
                uint8_t *data = (uint8_t *)tivxMemShared2TargetPtr(ptr);
                tivxMemBufferMap((void *)data, sizeof(g->data),
                                 (vx_enum)VX_MEMORY_TYPE_HOST,
                                 (vx_enum)VX_WRITE_ONLY);
                if (NULL == data)
                    VX_PRINT(VX_ZONE_ERROR, "Failed to map YUV embedded data image patch\n");
                else
                    memcpy(data, g->data, sizeof(g->data));
                    tivxMemBufferUnmap((void *)data, sizeof(g->data),
            cur_time = tivxPlatformGetTimeInUsecs() - cur_time;
            appPerfStatsHwaUpdateLoad(APP_PERF_HWA_CE_VISS, (uint32_t)cur_time,
                                      raw_img_desc->params.width * raw_img_desc->params.height);
        return (status);
    /*                          Local Functions                                   */
                                                 const tivx_vpac_ce_isp_params_t *ispPrms,
        uint32_t cnt;
        uint32_t out_cnt;
        uint32_t mux_val[TIVX_KERNEL_VPAC_CE_VISS_MAX_IMAGE_OUTPUT];
        uint32_t out_start;
        Vhwa_M2mVissOutputParams *outPrms = NULL;
        Vhwa_M2mVissParams *vissDrvPrms;
        tivx_obj_desc_image_t *im_desc;
        mux_val[0U] = ispPrms->mux_output0;
        mux_val[1U] = ispPrms->mux_output1;
        mux_val[2U] = ispPrms->mux_output2;
        mux_val[3U] = ispPrms->mux_output3;
        mux_val[4U] = ispPrms->mux_output4;
        for (out_cnt = 0u; out_cnt < TIVX_KERNEL_VPAC_CE_VISS_MAX_IMAGE_OUTPUT; out_cnt++)
            ispObj->num_out_buf_addr[out_cnt] = 0U;
            im_desc = obj_desc[out_cnt];
            if (NULL != obj_desc[out_cnt])
                outPrms = &vissDrvPrms->outPrms[out_cnt];
                status = tivxVpacVissMapFormat(&outPrms->fmt.dataFormat,
                                               &outPrms->fmt.ccsFormat, out_start,
                                               im_desc->format, mux_val[out_cnt]);
                    outPrms->enable = TRUE;
                    outPrms->fmt.width = im_desc->width;
                    outPrms->fmt.height = im_desc->height;
                    for (cnt = 0u; cnt < TIVX_IMAGE_MAX_PLANES; cnt++)
                        outPrms->fmt.pitch[cnt] =
                            (uint32_t)im_desc->imagepatch_addr[cnt].stride_y;
                else
                    VX_PRINT(VX_ZONE_ERROR, "Failed to map format for output%d\n", out_cnt);
                /* TODO: See if there are any others here */
                if ((FVID2_DF_YUV420SP_UV == outPrms->fmt.dataFormat) ||
                    (FVID2_DF_YUV422SP_UV == outPrms->fmt.dataFormat))
                    ispObj->num_out_buf_addr[out_cnt] = 2U;
                else
                    ispObj->num_out_buf_addr[out_cnt] = 1U;
                break;
            out_start++;
            outPrms = &vissDrvPrms->outPrms[VHWA_M2M_VISS_OUT_H3A_IDX];
            outPrms->enable = (uint32_t)TRUE;
            outPrms->fmt.dataFormat = FVID2_DF_RAW;
        return (status);
        Fvid2_Format *fmt;
        fmt = &vissDrvPrms->inFmt;
        /* Set number of inputs */
        if (1U == raw_img_desc->params.num_exposures)
            vissDrvPrms->inputMode = VHWA_M2M_VISS_MODE_SINGLE_FRAME_INPUT;
        else if (2U == raw_img_desc->params.num_exposures)
            vissDrvPrms->inputMode = VHWA_M2M_VISS_MODE_TWO_FRAME_MERGE;
        else if (3U == raw_img_desc->params.num_exposures)
            vissDrvPrms->inputMode = VHWA_M2M_VISS_MODE_THREE_FRAME_MERGE;
        else
            /* do nothing */
        /* Set the Input Format */
        fmt->width = raw_img_desc->params.width;
        fmt->height = raw_img_desc->params.height;
        fmt->pitch[0] = (uint32_t)raw_img_desc->imagepatch_addr[0U].stride_y;
        fmt->dataFormat = FVID2_DF_RAW;
        switch (raw_img_desc->params.format[0U].pixel_container)
        case (vx_enum)TIVX_RAW_IMAGE_8_BIT:
            fmt->ccsFormat = FVID2_CCSF_BITS8_PACKED;
            break;
        case (vx_enum)TIVX_RAW_IMAGE_16_BIT:
            fmt->ccsFormat = FVID2_CCSF_BITS12_UNPACKED16;
            break;
        case (vx_enum)TIVX_RAW_IMAGE_P12_BIT:
            fmt->ccsFormat = FVID2_CCSF_BITS12_PACKED;
            break;
        default:
            /* do nothing */
            break;
        ispObj->num_in_buf = 1u;
        switch (vissDrvPrms->inputMode)
        case VHWA_M2M_VISS_MODE_SINGLE_FRAME_INPUT:
            break;
        case VHWA_M2M_VISS_MODE_TWO_FRAME_MERGE:
            ispObj->num_in_buf = 2u;
            break;
        case VHWA_M2M_VISS_MODE_THREE_FRAME_MERGE:
            ispObj->num_in_buf = 3u;
            break;
        default:
            break;
        return;
        if ((vx_df_image)VX_DF_IMAGE_U16 == vxFmt)
            *ccsFmt = FVID2_CCSF_BITS12_UNPACKED16;
        else if ((vx_df_image)TIVX_DF_IMAGE_P12 == vxFmt)
            *ccsFmt = FVID2_CCSF_BITS12_PACKED;
        else if ((vx_df_image)VX_DF_IMAGE_U8 == vxFmt)
            *ccsFmt = FVID2_CCSF_BITS8_PACKED;
        else
            VX_PRINT(VX_ZONE_ERROR, "Invalid Storage Format \n");
            status = (vx_status)VX_ERROR_INVALID_PARAMETERS;
        return (status);
        switch (mux_val)
        case 0U:
            /* Map single plane storage format */
            status = tivxVpacVissMapStorageFormat(ccsFmt, vxFmt);
                VX_PRINT(VX_ZONE_ERROR, "Map Storage Format Failed\n");
            /* Map data format on mux val0 */
            else if ((TIVX_KERNEL_VPAC_CE_VISS_OUT0_IDX == out_id) ||
                     (TIVX_KERNEL_VPAC_CE_VISS_OUT2_IDX == out_id))
                *fmt = FVID2_DF_LUMA_ONLY;
            else if ((TIVX_KERNEL_VPAC_CE_VISS_OUT1_IDX == out_id) ||
                     (TIVX_KERNEL_VPAC_CE_VISS_OUT3_IDX == out_id))
                *fmt = FVID2_DF_CHROMA_ONLY;
            else
                VX_PRINT(VX_ZONE_ERROR, "mux0 not supported on output4\n");
            break;
        case 1U:
            /* Map data format on mux val1 */
            else if (TIVX_KERNEL_VPAC_CE_VISS_OUT2_IDX == out_id)
                *fmt = FVID2_DF_RED;
            else if (TIVX_KERNEL_VPAC_CE_VISS_OUT3_IDX == out_id)
                *fmt = FVID2_DF_GREEN;
            else if (TIVX_KERNEL_VPAC_CE_VISS_OUT4_IDX == out_id)
                *fmt = FVID2_DF_BLUE;
            else
                VX_PRINT(VX_ZONE_ERROR, "mux1 not supported on output0/1\n");
            break;
        case 2U:
            /* Map data format on mux val2 */
                     (TIVX_KERNEL_VPAC_CE_VISS_OUT2_IDX == out_id) ||
                     (TIVX_KERNEL_VPAC_CE_VISS_OUT3_IDX == out_id) ||
                     (TIVX_KERNEL_VPAC_CE_VISS_OUT4_IDX == out_id))
                *fmt = FVID2_DF_RAW;
            else
                VX_PRINT(VX_ZONE_ERROR, "mux2 not supported on output0\n");
            break;
        case 3U:
                *fmt = FVID2_DF_GREY;
                *fmt = FVID2_DF_SATURATION;
            else
                VX_PRINT(VX_ZONE_ERROR, "mux3 not supported on output1/3\n");
            break;
        case 4U:
            if ((vx_df_image)VX_DF_IMAGE_NV12 == vxFmt)
            else if ((vx_df_image)TIVX_DF_IMAGE_NV12_P12 == vxFmt)
            else
                VX_PRINT(VX_ZONE_ERROR, "only NV12 supported on mux4\n");
                    *fmt = FVID2_DF_YUV420SP_UV;
                else
                    VX_PRINT(VX_ZONE_ERROR, "only output0/2 supports on mux4\n");
            break;
        case 5U:
            if (TIVX_KERNEL_VPAC_CE_VISS_OUT2_IDX == out_id ||
                  TIVX_KERNEL_VPAC_CE_VISS_OUT0_IDX== out_id )
                if ((vx_df_image)VX_DF_IMAGE_UYVY == vxFmt)
                    *fmt = FVID2_DF_YUV422I_UYVY;
                else if ((vx_df_image)VX_DF_IMAGE_YUYV == vxFmt)
                    *fmt = FVID2_DF_YUV422I_YUYV;
                else
                    VX_PRINT(VX_ZONE_ERROR, "only UYVY/YUYV formats supported \n");
            else
                VX_PRINT(VX_ZONE_ERROR, "mux5 is supported only on output2 \n");
            break;
            #ifdef VPAC3L
            case 6U:
                /* Only packed 8 and unpacked 16 IR supported in this case*/
                if (TIVX_KERNEL_VPAC_CE_VISS_OUT0_IDX == out_id)
                    *fmt = FVID2_DF_RAW08;
                    *fmt = FVID2_DF_RAW16;
                    *ccsFmt = FVID2_CCSF_BITS16_PACKED;
                else
                    VX_PRINT(VX_ZONE_ERROR, "mux6 is supported only on output0/2 \n");
                break;
            case 7U:
                /* Only packed 12 IR supported in this case */
                    *fmt = FVID2_DF_RAW12;
                else
                    VX_PRINT(VX_ZONE_ERROR, "mux7 is supported only on output0 \n");
                break;
            #endif
        default:
            VX_PRINT(VX_ZONE_ERROR, "Invalid value of mux \n");
            break;
        return (status);
        Glbce_Control       glbceCtrl;
        if (NULL != ispObj)
            glbceCtrl.module = GLBCE_MODULE_GET_STATS_INFO;
            glbceCtrl.statsInfo = &ispObj->glbceStatInfo;
                IOCTL_GLBCE_GET_CONFIG, (void *)&glbceCtrl, NULL);
                ispObj->glbce_ctx_mem_phys_ptr = 0u;
                VX_PRINT(VX_ZONE_ERROR, "Failed to get GLBCE Stats Info!!!\n");
            else
                tivxMemBufferAlloc(&ispObj->glbce_ctx_mem_ptr,
                    ispObj->glbceStatInfo.size, (vx_enum)TIVX_MEM_EXTERNAL);
                if ((int32_t)NULL == (int32_t)ispObj->glbce_ctx_mem_ptr.host_ptr)
                    status = (vx_status)VX_ERROR_NO_MEMORY;
                    VX_PRINT(VX_ZONE_ERROR, "Failed to allocate memory!!!\n");
                else
                    ispObj->glbce_ctx_mem_phys_ptr = tivxMemShared2PhysPtr(
                        ispObj->glbce_ctx_mem_ptr.shared_ptr,
                        (int32_t)ispObj->glbce_ctx_mem_ptr.mem_heap_region);
                    VX_PRINT(VX_ZONE_INFO, "TIOVX: VISS: GLBCE ctx mem @ 0x%08x or size %d B\n",
                             (uint32_t)ispObj->glbce_ctx_mem_phys_ptr, ispObj->glbceStatInfo.size);
                                        #if defined(SOC_AM62A) || defined(SOC_J722S)
                        /* Set Buffer for GLBCE ctx */
                            IOCTL_GLBCE_SET_EXT_CNTXT_PTR, (void *)ispObj->glbce_ctx_mem_ptr.shared_ptr, NULL);
                            VX_PRINT(VX_ZONE_ERROR, "Failed to set Buffer for GLBCE ctx\n");
                        #endif
        else
        return (status);
        if (NULL != ispObj)
            if (0u != ispObj->glbce_ctx_mem_phys_ptr)
                tivxMemBufferFree(&ispObj->glbce_ctx_mem_ptr,
        int32_t status;
    #if !defined(SOC_AM62A) && !defined(SOC_J722S)
        #ifdef VHWA_VISS_GLBCE_CTX_SAVE_RESTORE_ENABLE
        #ifdef VHWA_VISS_GLBCE_CTX_SAVE_RESTORE_USE_DMA
        int32_t status;
        #endif
        app_udma_copy_1d_prms_t prms;
        if ((NULL != ispObj) && (0u != ispObj->glbce_ctx_mem_phys_ptr))
            prms.src_addr = ispObj->glbce_ctx_mem_phys_ptr;
            prms.dest_addr = ispObj->glbceStatInfo.addr;
            prms.length = ispObj->glbceStatInfo.size;
            status = appUdmaCopy1D(NULL, &prms);
            if (0 != status)
                VX_PRINT(VX_ZONE_ERROR, "Failed to restore Context !!!\n");
            #else
            memcpy((void*)(uint32_t)prms.dest_addr, (void*)(uint32_t)prms.src_addr, prms.length);
            #endif
        #endif
    #endif
        int32_t status;
        int32_t status;
        #endif
            prms.src_addr = ispObj->glbceStatInfo.addr;
            prms.dest_addr = ispObj->glbce_ctx_mem_phys_ptr;
            if (0 != status)
            #else
            #endif
        #endif
    #endif
    /*                    Control Command Implementation                          */
    /*                              Driver Callbacks                              */
        tivxVpacCeIspObj *ispObj = (tivxVpacCeIspObj *)appData;
        if (NULL != ispObj)
            tivxEventPost(ispObj->eventProcessCmpl);
        return FVID2_SOK;
    best regards
    sungenben
  • hi sungenben,
    but here i see below code, which means glbce context save/restore is not enabled for J722S device.
    Can you please check in the file ti-processor-sdk-rtos-j722s-evm-10_01_00_04\imaging\utils\hwa\src\app_hwa.c, below code is present?
    #if defined(MCU_PLUS_SDK)
    initPrms.udmaDrvHndl = drvHandle;
    initPrms.udmaDrvHndlBcdma = drvHandleBcdma;
    /* enable config through UDMA */
    initPrms.configThroughUdmaFlag = gConfigThroughUDMA;
    initPrms.copyGlbceCtxThroughBcdmaFlag = true;
    #else
    initPrms.udmaDrvHndl = appUdmaGetObj();
    /* Set configThroughUDMA to true to support multi handle */
    initPrms.configThroughUdmaFlag = true;
    #endif
    status = Vhwa_m2mVissInit(&initPrms);
    Brijesh
  • Hi Brijesh
    yes  , I can see the source the same as you show .
    what can I do for support two cameras ?
    best regards
    sungenben
  • Hi sun genben,
    Then the GLBCE context save/restore is already enabled. Most likely this flicker in one camera is not coming because of GLBCE, is Exposure changing very frequently? This could be one reason why you are observing flicker.
    Brijesh
  • Hi Brijesh
    you can see the video that I had attached .
    currently we set the GLBCE every frame with the different environment .
    we had checked the flicker caused by GPBCE .
    if we use the same GBLCE for two cameras , the streams don't occur flicker
    best regards
    sungenben
  • Hi sungenben,
    Sorry, did not get the last statement, what do you mean by "same GBLCE for two cameras"? Is GLBCE settings are different for both the cameras?
    Brijesh
  • Hi Brijesh
    if we set different look lut of GLBCE for two cameras every frame , one screen is flickering ,the other is ok .
    if we set look lut of GLBCE for A camera every frame (different look lut), B camera is set the same look lut with A every frame .  both two camera streams are ok ,no flicker occur.
    if we don't update Look lut of GLBCE ,both two camera streams are ok ,no flicker occur.
    best regards
    sungenben.
  • Hi sungenben,
    Which look lut do you mean here?
    Brijesh
  • Hi Brijesh
        uint32_t                    asymLut[GLBCE_ASYMMETRY_LUT_SIZE];
    which is in the glbce_cfg.h in the below path
    rtos_sdk/mcu_plus_sdk_j722s/source/drivers/vhwa/include/
    best regards
    sungenben
  • Hi sungenben,
    Yes, if you hare Asym LUT difference for both the cameras, you need to see them to both the camera before submitting the frame. Any specific reason for using different Aym Lut for both these cameras?
    Brijesh
  • Hi Brijesh
    currently our production is CMS , the cameras are located both side of car
    we are dynamic to adjust the  asymLut with environment , so if different environment in two cameras , the asymLut is different .
    In order to have own parameters for different cameras ,so TI set the save/restore function
    is that right ?  we had used our algorithms in the TDA4VL ,and It's OK
    best regards
    sungenben
  • Hi sungenben,
    on TDA4VL, we have support for restoring the context for each camera on every frame. This feature is not yet supported on TDA4AEN. This is why GLBCE Asym Lut is not being restored and we will need to explicitly set it in the Node.. You might have update the node to call API for setting GLBCE settings for both the cameras.
    Brijesh
  • Hi Brijesh
    ->on TDA4VL, we have support for restoring the context for each camera on every frame. This feature is not yet supported on TDA4AEN
    when does TI plan to achieve this feature on TDA4VEN?
    best regards
    sungenben
  • Hi sungenben,
    Please refer to roadmap slides for this. Only GLBCE context save and restore is supported on TDA4AEN.
    Brijesh
  • Hi Brijesh
    Could you help me check  because I don't know the roadmap slides ?
    best regards
    sungenben
  • Hi sungenben,
    ok, let me check with the team.
    Brijesh
  • Hi sungenben,
    As per the current plan, this feature will be available in the SDK11.2 timeframe.
    Brijesh
  • Hi sungenben,
    Is that a horizontal tearing line in your attached video?
