Hi Expert,
The production program failed when loading software. X'ray checks that there is no abnormality in the solder ball soldering.
Re-heating the IC Date code 39C on the board(using a BGA desoldering machine) still does not work. Replacement a new IC (Date code 34C) from board and loading software were successed. But the replacement a new IC (Date code 39C) still cannot be loading software successful. The same result was obtained on two different boards.
Total failed quantity:78
Total units run:300
Could you help to fix this issue?
Daniel
