SK-TDA4VM: TI instructions to create an SD card image are resulting in failed boot
Part Number: SK-TDA4VM
I successfully created and booted from an SD card with the image downloaded from https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-SK-TDA4VM/10.01.00.04, so I think the board is functioning correctly.
I installed the Processor SDK (ti-processor-sdk-linux-edgeai-j721e-evm-10_01_00_04) per https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/latest/exports/docs/linux/Overview_Building_the_SDK.html without any problems.
I then followed the following steps to create an image from CM per the instructions:
  1. git clone https://git.ti.com/cgit/arago-project/oe-layersetup/ yocto_build      # commit bc9f09c0b4dc6d403271db19745890589f1115ec
  2. cd yocto_build
  3. ./oe-layertool-setup.sh -f configs/processor-sdk-analytics/processor-sdk-analytics-10.01.00-config.txt
  4. echo 'ARAGO_BRAND = "edgeai"' >> build/conf/local.conf
  5. cd build
  6. source conf/setenv
  7. MACHINE="j721e-evm" bitbake -k tisdk-edgeai-image
  8. cd deploy-ti/images/j721e-evm
  9. unxz tisdk-edgeai-image-j721e-evm.rootfs.wic.xz
  10. sudo dd bs=4M if=tisdk-edgeai-image-j721e-evm.rootfs.wic of=/dev/sde bs=4M status=progress conv=fsync
This fails to boot.  This is the output:
U-Boot SPL 2024.04-ti-ga970f6e51043 (Nov 13 2024 - 14:26:23 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.6--v10.01.06 (Fiery Fox)')
Trying to boot from MMC2
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.11.0(release):v2.11.0-906-g58b25570c9-dirty
NOTICE:  BL31: Built : 04:20:32, Nov  1 2024
I/TC:
I/TC: OP-TEE version: 4.4.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Oct 18 17:45:27 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.6--v10.01.06 (Fiery Fox)')
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: HUK Initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2024.04-ti-ga970f6e51043 (Nov 13 2024 - 14:26:23 +0000)
SoC:   J721E SR1.1 GP
Model: Texas Instruments J721e EVM
Board: J721EX-EAIK rev A1
DRAM:  2 GiB (effective 4 GiB)
Core:  144 devices, 35 uclasses, devicetree: separate
Flash: 0 Bytes
MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1
Net:   eth0: ethernet@46000000port@1
Hit any key to stop autoboot:  0
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
mmc_init: -70, time 99
mmc_init: -70, time 62
** Bad device specification mmc 1 **
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
mmc_init: -70, time 61
Couldn't find partition mmc 1:2
Can't set block device
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Bad Linux ARM64 Image magic!
Scanning for bootflows in all bootdevs
Seq  Method       State   Uclass    Part  Name                      Filename
Scanning global bootmeth 'efi_mgr':
Card did not respond to voltage select! : -110
mmc_init: -95, time 37
No EFI system partition
Failed to persist EFI variables
Scanning bootdev 'mmc@4fb0000.bootdev':
Scanning bootdev 'mmc@4f80000.bootdev':
Bus usb@6400000: cdns-usb3-host usb@6400000: DRD version v1 (ID: 0004024e, rev: 00000200)
Register 2000840 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@6400000 for devices... 2 USB Device(s) found
k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled
am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 3
link up on port 1, speed 1000, full duplex
BOOTP broadcast 1
DHCP client bound to address 172.16.100.12 (3 ms)
Scanning bootdev 'port@1.bootdev':
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-34-08-e1-56-3f-1c
Using ethernet@46000000port@1 device
TFTP from server 172.16.0.1; our IP address is 172.16.100.12
Filename 'pxelinux.cfg/01-34-08-e1-56-3f-1c'.
Load address: 0x80100000
Loading: T T T
I'm debugging this now, but I would expect that since I followed the instructions and did not modify anything yet, that it should have booted identically to the released image.  What am I doing wrong?  Can anybody tell me which commit the release was created from?  I can't find it.
