I used the following command to control M core, and found that the stop command did not take effect, and the start command indicated that the device was busy
Hello Bu,
Please read through this page in the AM62x academy:
Linux > Booting remote cores
https://dev.ti.com/tirex/explore/node?node=A__AckaMLLzyxszvNaSLSFIQg__AM62-ACADEMY__uiYMDcq__LATEST
You also might be interested in running the out-of-the-box IPC example:
AM62x academy > Linux > IPC example
https://dev.ti.com/tirex/explore/node?node=A__AXINfJJ0T8V7CR5pTK41ww__AM62-ACADEMY__uiYMDcq__LATEST
And once you start doing MCU+ development, you will want to refer to the multicore academy module:
https://dev.ti.com/tirex/explore/node?node=A__AJa64F6ctzZNbb.TYx4mCA__AM62-ACADEMY__uiYMDcq__LATEST
Nick
