Part Number: TDA4VH-Q1
Hi TI Experts,
Could you please provide some explanation of the function of the below ESM?
SDLR_WKUP_ESM0_ESM_LVL_EVENT_WKUP_PSC0_PSC_MOD_WKLP_MCU_R5_1_CS1_CLKSTOP_REQ_0
The background is customer works normally before using Linux SDK10.1 + RTOS SDK10.1, recently they received our early drop on Linux SDK11 to migrate firstly, and now becomes Linux SDK11 + RTOS SDK10.1. Then they found a problem when their application is running, if they close the R5F1-1 core the system will reset (previously no this issue with Linux SDK10.1 + RTOS SDK10.1). After a lot of deep diving testing, they finally found the root cause about SDLR_WKUP_ESM0_ESM_LVL_EVENT_WKUP_PSC0_PSC_MOD_WKLP_MCU_R5_1_CS1_CLKSTOP_REQ_0. If they disable this ESM error bit, then there will be no problem.
Hence, customer would like to know what is the meaning or function of this ESM error bit? Could you provide some explanation please?
Kevin
