PROCESSOR-SDK-AM437X: sometimes MDIO is not detected after power cycle
Part Number: PROCESSOR-SDK-AM437X
following are my device specifications
PHY: DP83822
Linux SDK version: 08.06.01.03
Processor AM437x
my kernel is unable to detect eth0 sometimes during power up but it doesn't happen with eth1 phy and i am unable to understand why i am getting this issue if anyone know please let me know it will be a great help for us.
    A detection failure could be that the PHY is not initializing correctly. This is typically not a processor issue as the PHY has to have the correct voltages. Is the same PHY on both CPSW ports? (I have assumed here that the ethernet ports are the CPSW ports, is this correct?) There needs to be an initial review by the TI Ethernet team to make sure the board implementation is correct, I will ask them to take a look at this post.
    Also please take a look at this app note, there is a section on PHY analysis.
    https://www.ti.com/lit/an/spradj8/spradj8.pdf
    Schuyler
    Just one thing to correct here is that we are using PRU ports and not CPSW ports so please take a not of that for further actions.
    Bhavya Mehta
  • for more on this you can find the following data
    root@am437x-evm:~# ifconfig
    lo Link encap:Local Loopback
    inet addr:127.0.0.1 Mask:255.0.0.0
    inet6 addr: ::1/128 Scope:Host
    UP LOOPBACK RUNNING MTU:65536 Metric:1
    RX packets:2 errors:0 dropped:0 overruns:0 frame:0
    TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:140 (140.0 B) TX bytes:140 (140.0 B)
    [ 29.885331] davinci_mdio 54432400.mdio: davinci mdio revision 1.6, bus freq 1000000
    [ 29.885735] mdio_bus 54432400.mdio: MDIO device at address 0 is missing.
    [ 30.067961] davinci_mdio 54432400.mdio: phy[1]: device 54432400.mdio:01, driver TI DP83822
    root@am437x-evm:~# ethtool eth0
    netlink error: no device matches name (offset 24)
    netlink error: No such device
    No data available
    root@am437x-evm:~# dmesg | grep mdio
    [ 4.150965] mdio_bus fixed-0: GPIO lookup for consumer reset
    [ 4.151001] mdio_bus fixed-0: using lookup tables for GPIO lookup
    [ 4.151019] mdio_bus fixed-0: No GPIO consumer reset found
    [ 29.828709] mdio_bus 54432400.mdio: GPIO lookup for consumer reset
    [ 29.828747] mdio_bus 54432400.mdio: using device tree for GPIO lookup
    [ 29.828799] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/target-module@54400000/pruss@0/mdio@32400[0]'
    [ 29.828903] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/target-module@54400000/pruss@0/mdio@32400[0]'
    [ 29.828974] mdio_bus 54432400.mdio: using lookup tables for GPIO lookup
    [ 29.828995] mdio_bus 54432400.mdio: No GPIO consumer reset found
    [ 30.034715] mdio_bus 54432400.mdio:01: GPIO lookup for consumer reset
    [ 30.034753] mdio_bus 54432400.mdio:01: using device tree for GPIO lookup
    [ 30.034932] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp@44000000/target-module@54400000/pruss@0/mdio@32400/ethernet-phy@1[0]' - status (0)
    Thank you for the console log. The messages captured are consistent with a PHY that is not answering the MDIO Probe and is possibly indicating the PHY in a bad state. To continue further debug there needs to be a hardware analysis of the PHY when the boot process has left the PHY in this condition. I will ask the Ethernet team that supports this PHY to review this thread. In preparation the Ethernet team will need some measurements taken. Please refer to Section 6 of the basic Ethernet app note. The Ethernet team also has provided a troubleshooting guide.
    https://www.ti.com/lit/an/snla437/snla437.pdf
    Is this issue happening rarely or fairly often?
    Schuyler
    I wanted to follow up on this thread. Have the associated health checks on the PHY that have been described in this app note been conducted?
    Sincerely,
    Gerome
    This part has been checked a long time back from out team and we have also shown this to TI India team. and they have confirmed that there is no issue with respect to hardware in this. You can check with Ti India team for the same.
    Bhavya
    Can you please provide contact with TI India team member who confirmed this part's health? If everything looks good from an electrical side, this may be more of a SW issue and I shall reassign back to AM team.
    Sincerely,
    Gerome
    Manikya Sharma(m-sharma2@ti.com) is the main person who was coordinating. but there were other people as well. you can connect with him he can guide you or you can share me your mail ID I can share you the whole mail chain with respect to this.
    Bhavya
  • Hello Bhavya,
    I will connect with Manikya on this topic. Please note TI is closed tomorrow for holiday.
    Sincerely,
    Gerome
  • HI Gerome,
    Thanks for the update.
    Bhavya
  • Hi Bhavya,
    I have closed the loop with Manikya. I will be reassigning this back to EP team as this looks to be a SW matter.
    Sincerely,
    Gerome
  • Hi Gerome,
    Bhavya
    I wanted to follow up on this thread. Have this issue been assigned to any SW person?
    Bhavya
    Bhavya
    Gentle Reminder.
    Bhavya
    To continue debug we will need a scope or logic analyzer capture of the MDIO lines that shows when the PHY is not being detected by the processor. Since this condition happens after a power cycle this should be easily captured on a scope/logic analyzer. I would recommend using the Power on Reset signal of the board to know when the system is starting after a power cycle. Then use the console log to look for when the PHY was not detected and then review the scope capture to look at the MDIO transaction of the processor sending out a message and the PHY not responding. A good beginning step would be to gain knowledge of what a successful MDIO transaction looks like after a boot.
    To simplify the debug you have to isolate to only this PHY. If there are other PHYs on the same MDIO bus they will have to be disabled in the board DTS file. Disabling other PHYs in the board DTS will do the isolation needed.
    Schuyler
  • Hi Schuyler,
    we are checking the point which you have told and once we are ready with results I will update you.
    Bhavya
  • HI Schuyler,
    One doubt I was having with respect to disabling via DTS. Currently we are having 2 Port device. and in that if eth0 is not detected it won't go ahead. But could you tell me where specifically I have to disable port 1 in DTS file than that would be great because we are not having that much grip in kernel as you are.
    Bhavya
    This debug approach I am suggesting is to focus only if the eth0 interface is able to communicate with PHY attached. Other application testing for example would not be necessary. The testing I am proposing is the power cycle the board and look to see if the PHY was identified. Keep powering cycling the board until you see in the console log the PHY was not identified and then review the logic analyzer trace to confirm that the PHY actually responded to the processor request.
    To disable the interface you will need to disable the interface and remove the PHY definition for ethernet 1. If you attach your DTS source file I will indicate the portions of the file you will need to modify.
    Schuyler
  • Hi Schuyler,
    I got your point and have tried todo the change in the following file.
    https://schneiderelectric-my.sharepoint.com/:u:/g/personal/sesa770790_se_com/EZP3ylpfkQlBuwtfQSvDMywBt_Fx_mnHxACPa56LAf1OLg?e=ZfjTbZ
    pruss1-eth {
    		compatible = "ti,am4376-prueth";
    		ti,prus = <&pru1_0>, <&pru1_1>;
    		sram = <&ocmcram>;
    		interrupt-parent = <&pruss1_intc>;
    		mii-rt = <&pruss1_mii_rt>;
    		iep = <&pruss1_iep>;
    		status = "okay"; // added because PRU is not getting reg
    		pinctrl-0 = <&pruss1_eth_default>;
    		pinctrl-names = "default";
    		interrupts = <20 2 2>, <21 3 3>;
    		interrupt-names = "rx_lre_hp", "rx_lre_lp";
    		pruss1_emac0: ethernet-mii0 {
    			phy-handle = <&pruss1_eth0_phy>;
    			phy-mode = "mii";
    			interrupts = <20 2 2>;
    			interrupt-names = "rx";
    			ti,no-half-duplex;
    			/* Filled in by bootloader */
    			local-mac-address = [00 00 00 00 00 00];
    		pruss1_emac1: ethernet-mii1 {
    			status = "disabled"; // added because PRU is not getting reg
    			phy-handle = <&pruss1_eth1_phy>;
    			phy-mode = "mii";
    			interrupts = <21 3 3>;
    			ti,no-half-duplex;
    In above snippet I have changed the specific line status = "disabled"; for eth1. Which I think you are expecting me to do if I am not wrong. Based on that in console log if I will do ifconfig than I will only get eth0 and eth1 will not come as you can see in below console logs.
    [   34.172614] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
    [   34.213299] omap-des 53701000.des: will run requests pump with realtime priority
    [   34.559319] davinci_mdio 54432400.mdio: davinci mdio revision 1.6, bus freq 1000000
    [   34.897827] davinci_mdio 54432400.mdio: phy[0]: device 54432400.mdio:00, driver TI DP83822
    [   34.897868] davinci_mdio 54432400.mdio: phy[1]: device 54432400.mdio:01, driver TI DP83822
    [  OK  ] Started LSB: Raise network interfaces and configure them.
    [   35.369564] PM: no-rtc available, rtc-only mode disabled.
    [   35.369715] PM: Leaving EFUSE power domain active
    [   35.532576] remoteproc remoteproc1: 54434000.pru is available
    [   35.533834] remoteproc remoteproc2: 54438000.pru is available
    [   35.535013] remoteproc remoteproc3: 54474000.pru is available
    [   35.536166] remoteproc remoteproc4: 54478000.pru is available
    [   36.195910] prueth pruss1-eth: Test PRU firmware bhavya
    [   47.864585] prueth pruss1-eth: Test PRU firmware bhavya
    [   47.865305] prueth pruss1-eth: Test bhavya
    [   47.865330] prueth pruss1-eth: could not get ptp tx irq. Skipping PTP support
    [   47.865348] prueth pruss1-eth: could not get hsr ptp tx irq. Skipping PTP support
    [   47.901376] prueth pruss1-eth: dev_infoTI PRU removing link mode bhavya
    [   47.901414] prueth pruss1-eth: dev_err TI PRU removing link mode bhavya err
    [   47.901427] printk  TI PRU removing link mode bhavya
    [   47.903977] prueth pruss1-eth: TI PRU ethernet driver initialized: single EMAC mode
    NOTICE: This file system contains the following GPLv3 packages:
            bash-dev
            bash
            cifs-utils
            dosfstools
            gdb
            less
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm6
            libreadline8
            parted
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Stopped Login Service.
    [FAILED] Failed to start Login Service.
    See 'systemctl status systemd-logind.service' for details.
             Starting Network Service...
             Starting telnetd.service...
    [  OK  ] Started telnetd.service.
    [  OK  ] Started Network Service.
             Starting Wait for Network to be Configured...
    [   56.201126] prueth_init_ethernet_mode bhavya.............
    [   56.201126]
    [   56.215694] remoteproc remoteproc1: powering up 54434000.pru
    [   56.270915] remoteproc remoteproc1: Booting fw image ti-pruss/am437x-pru0-prueth-fw.elf, size 7320
    [FAILED] Failed to start Network Name Resolution.
    See 'systemctl status systemd-resolved.service' for[   56.270992] remoteproc remoteproc1: unsupported resource 5
     details.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
    [   56.271253] remoteproc remoteproc1: remote processor 54434000.pru is now up
    [   56.300228] net eth0: started
             Starting Avahi mDNS/DNS-SD Stack...
    [   56.300790] 8021q: adding VLAN 0 to HW filter on device eth0
    [FAILED] Failed to start LLDP daemon.
    eth0      Link encap:Ethernet  HWaddr 88:01:F9:35:D9:A2
              UP BROADCAST MULTICAST  MTU:1500  Metric:1
              RX packets:0 errors:0 dropped:0 overruns:0 frame:0
              TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
    Weather I have done correct or not just confirm and if you are expecting anything else please let me know.
    Bhavya
  • Hi Schuyler,
    Could you kindly check that the above section is correct? If not, could you give the dts file with the appropriate changes so that we can begin to examining the waveforms?
    Bhavya
    What you have done is correct. There a couple of an additional steps. You will need to comment out this node as well, pruss1_eth1_phy. You do not want the second interface to probe for a PHY.
    After commenting out the phy node to get a successful DTS compile you will need to comment out this line in the pruss1_emac1: ethernet-mii1 node
    The goal is not see the the second PHY show up during the boot log. After making these changes please attach the boot log.
    Schuyler
  • HI Schuyler,
    please find the logs.
    CCCCCCCC
    U-Boot SPL 2023.04-00001-gd63f266198-dirty (Feb 04 2025 - 14:09:52 +0530)
    Boot mode as per spl_boot_device is 5
    Trying to boot from NAND
    Global Cold Reset Occured
    Cleared the Reset Cause register = 1
             current spl : 0x0
    Currently Running OS1
    Authentication passed
    Jumping to U-Boot...
    loaded - jumping to U-Boot...
    U-Boot 2023.04-00001-gd63f266198-dirty (Feb 04 2025 - 14:09:52 +0530)
    CPU  : AM437X-HS rev 1.2
    Model: TI AM437x GP EVM
    DRAM:  512 MiB
    Core:  36 devices, 18 uclasses, devicetree: separate
    PMIC:  TPS65218
    NAND:  512 MiB
    MMC:   OMAP SD/MMC: 0
    Loading Environment from FAT... Card did not respond to voltage select! : -110
    ** Bad device specification mmc 0 **
    Net:   Could not get PHY for ethernet@4a100000: addr 0
    eth2: ethernet@4a100000
    Hit any key to stop autoboot:  0
    NAND read: device 0 offset 0x19b00000, size 0x28
     40 bytes read: OK
    Current SPL Value = 0
    1. Currently Running OS1
    Booting with ROOTFS 1
    BootRFS1 with uboot 1
    WARNING: Could not determine device tree
    starting USB...
    Bus usb@483d0000: Register 2000440 NbrPorts 2
    Starting the controller
    USB XHCI 1.00
    scanning bus usb@483d0000 for devices... 1 USB Device(s) found
           scanning usb for storage devices... 0 Storage Device(s) found
    Device 0: unknown device
    Booting from nand...
    NAND read: incorrect device type in NAND.u-boot-spl-os
    NAND read: device 0 offset 0x300000, size 0x700000
     7340032 bytes read: OK
    ## Loading kernel from FIT Image at 90000000 ...
       Using 'conf@1' configuration
       Trying 'kernel@1' kernel subimage
         Description:  unavailable
         Type:         Kernel Image
         Compression:  uncompressed
         Data Start:   0x900000c4
         Data Size:    5067800 Bytes = 4.8 MiB
         Architecture: ARM
         OS:           Linux
         Load Address: 0x80008000
         Entry Point:  0x80008000
         Hash algo:    sha256
         Hash value:   e3e8f2ce6f31ad9ff4f6f4d65cf855155400f96e6597c589ac0fe1861fadc1c3
       Verifying Hash Integrity ... sha256+ OK
    ## Loading fdt from FIT Image at 90000000 ...
       Trying 'fdt@1' fdt subimage
         Type:         Flat Device Tree
         Data Start:   0x904d55b4
         Data Size:    74692 Bytes = 72.9 KiB
         Architecture: ARM
         Hash algo:    sha256
         Hash value:   4b9b0802b03dcc43efa19e3a836f1708e6a2b492810dc706a572ecf7c46ebcdb
       Booting using the fdt blob at 0x904d55b4
    Working FDT set to 904d55b4
       Loading Kernel Image
       Loading Device Tree to 8ffea000, end 8ffff1aa ... OK
    Working FDT set to 8ffea000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.10.100-rt62-g204ec708dc (root@lin06200233d) (arm-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #1 PREEMPT_RT Tue May 20 22:15:00 IST 2025
    [    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: TI AM437x Industrial Development Kit
    [    0.000000] Memory policy: Data cache writeback
    [    0.000000] cma: Reserved 48 MiB at 0x9d000000
    [    0.000000] Zone ranges:
    [    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fffffff]
    [    0.000000]   HighMem  empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
    [    0.000000] CPU: All CPU(s) started in SVC mode.
    [    0.000000] AM437x ES1.2 (neon)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
    [    0.000000] Kernel command line: console=ttyS0,115200n8 root=ubi0:rootfs rw ubi.mtd=NAND.file-system-1,4096 rootfstype=ubifs rootwait=10
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 453316K/524288K available (10240K kernel code, 728K rwdata, 3416K rodata, 1024K init, 291K bss, 21820K reserved, 49152K cma-reserved, 0K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU priority boosting: priority 1 delay 500 ms.
    [    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000]  No expedited grace period (rcu_normal_after_boot).
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
    [    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
    [    0.000000] L2C-310 enabling early BRESP for Cortex-A9
    [    0.000000] OMAP L2C310: ROM does not support power control setting
    [    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
    [    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
    [    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
    [    0.000000] random: get_random_bytes called from start_kernel+0x318/0x4c4 with crng_init=0
    [    0.000000] TI gptimer clocksource: always-on /ocp@44000000/interconnect@44c00000/segment@200000/target-module@31000
    [    0.000002] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    [    0.000044] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.000370] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000387] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.001055] TI gptimer clockevent: 24000000 Hz at /ocp@44000000/interconnect@48000000/segment@0/target-module@40000
    [    0.004073] Console: colour dummy device 80x30
    [    0.004232] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
    [    0.064166] pid_max: default: 32768 minimum: 301
    [    0.064612] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    [    0.064653] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    [    0.066712] CPU: Testing write buffer coherency: ok
    [    0.066822] CPU0: Spectre v2: using BPIALL workaround
    [    0.068561] Setting up static identity map for 0x80100000 - 0x80100060
    [    0.068888] rcu: Hierarchical SRCU implementation.
    [    0.069650] EFI services will not be available.
    [    0.070448] devtmpfs: initialized
    [    0.108948] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    [    0.109425] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.109481] futex hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    0.115494] pinctrl core: initialized pinctrl subsystem
    [    0.117088] DMI not present or invalid.
    [    0.117920] NET: Registered protocol family 16
    [    0.122411] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.142021] thermal_sys: Registered thermal governor 'fair_share'
    [    0.142048] thermal_sys: Registered thermal governor 'bang_bang'
    [    0.142059] thermal_sys: Registered thermal governor 'step_wise'
    [    0.142069] thermal_sys: Registered thermal governor 'user_space'
    [    0.166186] ------------[ cut here ]------------
    [    0.166207] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x254/0x374
    [    0.166273] 44000000.ocp:L3 Custom Error: MASTER M2 (64-bit) TARGET GPMC (Read): Data Access in User mode during Debug access
    [    0.166298] Modules linked in:
    [    0.166318] CPU: 0 PID: 1 Comm: swapper Not tainted 5.10.100-rt62-g204ec708dc #1
    [    0.166346] Hardware name: Generic AM43 (Flattened Device Tree)
    [    0.166377] [<c010d664>] (unwind_backtrace) from [<c010a044>] (show_stack+0x10/0x14)
    [    0.166441] [<c010a044>] (show_stack) from [<c09feac0>] (__warn+0xbc/0xd4)
    [    0.166489] [<c09feac0>] (__warn) from [<c09feb6c>] (warn_slowpath_fmt+0x94/0xbc)
    [    0.166528] [<c09feb6c>] (warn_slowpath_fmt) from [<c04da02c>] (l3_interrupt_handler+0x254/0x374)
    [    0.166576] [<c04da02c>] (l3_interrupt_handler) from [<c016993c>] (__handle_irq_event_percpu+0x50/0x13c)
    [    0.166641] [<c016993c>] (__handle_irq_event_percpu) from [<c0169a74>] (handle_irq_event_percpu+0x4c/0x9c)
    [    0.166692] [<c0169a74>] (handle_irq_event_percpu) from [<c0169b10>] (handle_irq_event+0x4c/0x9c)
    [    0.166741] [<c0169b10>] (handle_irq_event) from [<c016daa8>] (handle_fasteoi_irq+0xc4/0x1a4)
    [    0.166793] [<c016daa8>] (handle_fasteoi_irq) from [<c0168aa8>] (generic_handle_irq+0x34/0x44)
    [    0.166837] [<c0168aa8>] (generic_handle_irq) from [<c0169278>] (__handle_domain_irq+0x54/0xa8)
    [    0.166885] [<c0169278>] (__handle_domain_irq) from [<c04d8c68>] (gic_handle_irq+0x74/0x88)
    [    0.166931] [<c04d8c68>] (gic_handle_irq) from [<c0100b0c>] (__irq_svc+0x6c/0xbc)
    [    0.166970] Exception stack(0xc1469c58 to 0xc1469ca0)
    [    0.166990] 9c40:                                                       00000000 ffffffea
    [    0.167019] 9c60: 00000104 00000000 c1408800 00000000 00000000 c15701c0 00000014 c14088cc
    [    0.167046] 9c80: 60000013 c1408814 00000200 c1469ca8 c016e15c c016b24c 00000013 ffffffff
    [    0.167062] [<c0100b0c>] (__irq_svc) from [<c016b24c>] (__setup_irq+0x394/0x7c0)
    [    0.167111] [<c016b24c>] (__setup_irq) from [<c016b748>] (request_threaded_irq+0xd0/0x148)
    [    0.167162] [<c016b748>] (request_threaded_irq) from [<c016ed7c>] (devm_request_threaded_irq+0x64/0xb8)
    [    0.167213] [<c016ed7c>] (devm_request_threaded_irq) from [<c04da310>] (omap_l3_probe+0x1c4/0x258)
    [    0.167256] [<c04da310>] (omap_l3_probe) from [<c0641744>] (platform_drv_probe+0x48/0x98)
    [    0.167309] [<c0641744>] (platform_drv_probe) from [<c063f9b0>] (really_probe+0xf0/0x398)
    [    0.167351] [<c063f9b0>] (really_probe) from [<c063fdc0>] (driver_probe_device+0x5c/0xb4)
    [    0.167388] [<c063fdc0>] (driver_probe_device) from [<c063de5c>] (bus_for_each_drv+0x80/0xc4)
    [    0.167447] [<c063de5c>] (bus_for_each_drv) from [<c063f84c>] (__device_attach+0xe0/0x14c)
    [    0.167490] [<c063f84c>] (__device_attach) from [<c063eb28>] (bus_probe_device+0x84/0x8c)
    [    0.167525] [<c063eb28>] (bus_probe_device) from [<c063b238>] (device_add+0x3fc/0x768)
    [    0.167566] [<c063b238>] (device_add) from [<c07ec0f4>] (of_platform_device_create_pdata+0x98/0xd4)
    [    0.167624] [<c07ec0f4>] (of_platform_device_create_pdata) from [<c07ec2d0>] (of_platform_bus_create+0x194/0x234)
    [    0.167666] [<c07ec2d0>] (of_platform_bus_create) from [<c07ec4dc>] (of_platform_populate+0x70/0xe0)
    [    0.167707] [<c07ec4dc>] (of_platform_populate) from [<c0f0bb24>] (pdata_quirks_init+0x70/0x80)
    [    0.167770] [<c0f0bb24>] (pdata_quirks_init) from [<c0f0ba9c>] (omap_generic_init+0x10/0x18)
    [    0.167818] [<c0f0ba9c>] (omap_generic_init) from [<c0f0362c>] (customize_machine+0x20/0x30)
    [    0.167863] [<c0f0362c>] (customize_machine) from [<c0101660>] (do_one_initcall+0x7c/0x1cc)
    [    0.167905] [<c0101660>] (do_one_initcall) from [<c0f01018>] (kernel_init_freeable+0x1b0/0x214)
    [    0.167968] [<c0f01018>] (kernel_init_freeable) from [<c0a0b0e4>] (kernel_init+0x8/0x118)
    [    0.168021] [<c0a0b0e4>] (kernel_init) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [    0.168056] Exception stack(0xc1469fb0 to 0xc1469ff8)
    [    0.168078] 9fa0:                                     00000000 00000000 00000000 00000000
    [    0.168102] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    0.168122] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    0.168136] ---[ end trace 0000000000000001 ]---
    [    2.328841] No ATAGs?
    [    2.328880] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    [    2.328902] hw-breakpoint: maximum watchpoint size is 4 bytes.
    [    2.378187] ------------[ cut here ]------------
    [    2.378207] WARNING: CPU: 0 PID: 1 at fs/sysfs/group.c:61 internal_create_group+0x384/0x3f0
    [    2.378273] Attribute early_enable: Invalid permissions 01
    [    2.378288] Modules linked in:
    [    2.378309] CPU: 0 PID: 1 Comm: swapper Tainted: G        W         5.10.100-rt62-g204ec708dc #1
    [    2.378338] Hardware name: Generic AM43 (Flattened Device Tree)
    [    2.378364] [<c010d664>] (unwind_backtrace) from [<c010a044>] (show_stack+0x10/0x14)
    [    2.378427] [<c010a044>] (show_stack) from [<c09feac0>] (__warn+0xbc/0xd4)
    [    2.378477] [<c09feac0>] (__warn) from [<c09feb6c>] (warn_slowpath_fmt+0x94/0xbc)
    [    2.378517] [<c09feb6c>] (warn_slowpath_fmt) from [<c02d23e0>] (internal_create_group+0x384/0x3f0)
    [    2.378563] [<c02d23e0>] (internal_create_group) from [<c0f0cf34>] (param_sysfs_init+0x1c0/0x204)
    [    2.378633] [<c0f0cf34>] (param_sysfs_init) from [<c0101660>] (do_one_initcall+0x7c/0x1cc)
    [    2.378684] [<c0101660>] (do_one_initcall) from [<c0f01018>] (kernel_init_freeable+0x1b0/0x214)
    [    2.378749] [<c0f01018>] (kernel_init_freeable) from [<c0a0b0e4>] (kernel_init+0x8/0x118)
    [    2.378803] [<c0a0b0e4>] (kernel_init) from [<c0100150>] (ret_from_fork+0x14/0x24)
    [    2.378839] Exception stack(0xc1469fb0 to 0xc1469ff8)
    [    2.378863] 9fa0:                                     00000000 00000000 00000000 00000000
    [    2.378888] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [    2.378910] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [    2.378924] ---[ end trace 0000000000000002 ]---
    [    2.406874] V3_3D: supplied by V24_0D
    [    2.408462] VDD_COREREG: supplied by V24_0D
    [    2.409658] VDD_CORE: supplied by VDD_COREREG
    [    2.410833] V1_8DREG: supplied by V24_0D
    [    2.411978] V1_8D: supplied by V1_8DREG
    [    2.413102] V1_5DREG: supplied by V24_0D
    [    2.415658] V1_5D: supplied by V1_5DREG
    [    2.419566] iommu: Default domain type: Translated
    [    2.426115] SCSI subsystem initialized
    [    2.427535] mc: Linux media interface: v0.10
    [    2.427636] videodev: Linux video capture interface: v2.00
    [    2.427899] pps_core: LinuxPPS API ver. 1 registered
    [    2.427913] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    2.427965] PTP clock support registered
    [    2.428089] EDAC MC: Ver: 3.0.0
    [    2.430909] Advanced Linux Sound Architecture Driver Initialized.
    [    2.433845] clocksource: Switched to clocksource dmtimer
    [    2.456041] NET: Registered protocol family 2
    [    2.456425] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    2.458941] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 7168 bytes, linear)
    [    2.459039] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
    [    2.459176] TCP bind hash table entries: 4096 (order: 4, 98304 bytes, linear)
    [    2.459604] TCP: Hash tables configured (established 4096 bind 4096)
    [    2.459845] UDP hash table entries: 256 (order: 2, 16384 bytes, linear)
    [    2.459967] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes, linear)
    [    2.460409] NET: Registered protocol family 1
    [    2.461603] RPC: Registered named UNIX socket transport module.
    [    2.461626] RPC: Registered udp transport module.
    [    2.461637] RPC: Registered tcp transport module.
    [    2.461646] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    2.461669] PCI: CLS 0 bytes, default 64
    [    2.466475] Initialise system trusted keyrings
    [    2.466901] workingset: timestamp_bits=14 max_order=17 bucket_order=3
    [    2.480058] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    2.481856] NFS: Registering the id_resolver key type
    [    2.481923] Key type id_resolver registered
    [    2.481938] Key type id_legacy registered
    [    2.482184] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    2.482220] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    2.482317] ntfs: driver 2.1.32 [Flags: R/O].
    [    2.754789] NET: Registered protocol family 38
    [    2.754835] Key type asymmetric registered
    [    2.754853] Asymmetric key parser 'x509' registered
    [    2.754974] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    2.754993] io scheduler mq-deadline registered
    [    2.755008] io scheduler kyber registered
    [    3.068665] OMAP GPIO hardware version 0.1
    [    3.546071] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
    [    3.748554] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
    [    3.748601] edma 49000000.dma: TI EDMA DMA engine driver
    [    3.771994] pinctrl-single 44e10800.pinmux: 199 pins, size 796
    [    3.916980] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    3.926038] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
    [    3.927400] printk: console [ttyS0] disabled
    [    3.927808] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 57, base_baud = 3000000) is a 8250
    [    3.928049] printk: console [ttyS0] enabled
    [    3.929722] omap8250 48022000.serial: No clock speed specified: using default: 48000000
    [    3.931705] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 61, base_baud = 3000000) is a 8250
    [    3.934035] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
    [    3.936045] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 69, base_baud = 3000000) is a 8250
    [    3.938081] omap8250 481a8000.serial: No clock speed specified: using default: 48000000
    [    3.940126] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 70, base_baud = 3000000) is a 8250
    [    3.947769] omap_rng 48310000.rng: Random Number Generator ver. 20
    [    3.954543] random: fast init done
    [    3.955229] random: crng init done
    [    4.003484] brd: module loaded
    [    4.025027] loop: module loaded
    [    4.025466] Major = 243 Minor = 0
    [    4.025850] Allocating space to LED_STATUS structure ...Done!!!
    [    4.025865] Allocating space to LED_ structure ...Done!!!
    [    4.026032] Device Driver Insert...Done!!!
    [    4.051127] i2c /dev entries driver
    [    4.058573] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    4.061520] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
    [    4.062935] sdhci: Secure Digital Host Controller Interface driver
    [    4.062949] sdhci: Copyright(c) Pierre Ossman
    [    4.066501] sdhci-pltfm: SDHCI platform and OF driver helper
    [    4.071237] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
    [    4.105103] NET: Registered protocol family 10
    [    4.107339] Segment Routing with IPv6
    [    4.107554] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    4.109102] NET: Registered protocol family 17
    [    4.109381] 8021q: 802.1Q VLAN Support v1.8
    [    4.110004] Key type dns_resolver registered
    [    4.111396] omap_voltage_late_init: Voltage driver support not added
    [    4.114067] printk: console [ttyS0]: printing thread started
    [    4.146825] Loading compiled-in X.509 certificates
    [    4.238024] omap-gpmc 50000000.gpmc: GPMC revision 6.0
    [    4.238067] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [    4.248083] nand: device found, Manufacturer ID: 0x9d, Chip ID: 0x6c
    [    4.248105] nand: Unknown IS34ML04G088
    [    4.248119] nand: 512 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 256
    [    4.248452] Using OMAP_ECC_BCH16_CODE_HW ECC scheme
    [    4.248678] 12 fixed-partitions partitions found on MTD device omap2-nand.0
    [    4.248702] Creating 12 MTD partitions on "omap2-nand.0":
    [    4.248722] 0x000000000000-0x000000040000 : "NAND.SPL"
    [    4.253611] 0x000000040000-0x000000080000 : "NAND.SPL.backup1"
    [    4.268997] 0x000000080000-0x0000000c0000 : "NAND.SPL.backup2"
    [    4.272509] 0x0000000c0000-0x000000100000 : "NAND.SPL.backup3"
    [    4.275999] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
    [    4.276997] 0x000000100000-0x000000300000 : "NAND.u-boot-1"
    [    4.289581] 0x000000300000-0x000000a00000 : "NAND.kernel-1"
    [    4.295931] 0x000000a00000-0x000016000000 : "NAND.file-system-1"
    [    4.430221] 0x000016000000-0x000016200000 : "NAND.u-boot-2"
    [    4.435337] 0x000016200000-0x000016900000 : "NAND.kernel-2"
    [    4.446183] 0x000016900000-0x000019b00000 : "NAND.file-system-2"
    [    4.468271] 0x000019b00000-0x000019c00000 : "NAND.sw-env"
    [    4.486921] 0x000019c00000-0x000020000000 : "NAND.Application"
    [    4.561231] tps62360 0-0060: tps62360_init_dcdc(): register 4 write failed with err -121
    [    4.561271] tps62360 0-0060: tps62360_probe(): Init failed with err = -121
    [    4.561557] tps62360: probe of 0-0060 failed with error -121
    [    4.561914] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 400 kHz
    Welcome to Arago 2021.09!
    [    4.565416] i2c i2c-1: Invalid 7-bit I2C address 0x00
    [    4.565445] i2c i2c-1: of_i2c: Failure registering /ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/TI_adc121@0
    [    4.565519] i2c i2c-1: Failed to create I2C device for /ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/TI_adc121@0
    [    4.565631] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz
    [    4.569569] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 100 kHz
    [    4.592694] omap_reset_deassert: timedout waiting for gfx:0
    [    4.592835] ti-sysc: probe of 5600fe00.target-module failed with error -110
    [    4.609742] ubi0: attaching mtd6
    [    5.389789] ubi0: scanning is finished
    [    5.438458] ubi0: volume 0 ("rootfs") re-sized from 726 to 1324 LEBs
    [    5.452696] ubi0: attached mtd6 (name "NAND.file-system-1", size 342 MiB)
    [    5.452734] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
    [    5.452757] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 1024
    [    5.452776] ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
    [    5.452793] ubi0: good PEBs: 1368, bad PEBs: 0, corrupted PEBs: 0
    [    5.452810] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
    [    5.452827] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1891072672
    [    5.452850] ubi0: available PEBs: 0, total reserved PEBs: 1368, PEBs reserved for bad PEB handling: 40
    [    5.456124] ALSA device list:
    [    5.456147]   No soundcards found.
    [    5.456259] ubi0: background thread "ubi_bgt0d" started, PID 106
    [    5.485977] UBIFS (ubi0:0): Mounting in unauthenticated mode
    [    5.494026] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 108
    [    5.581344] UBIFS (ubi0:0): start fixing up free space
    [    5.816534] UBIFS (ubi0:0): free space fixup complete
    [    5.869099] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
    [    5.869148] UBIFS (ubi0:0): LEB size: 253952 bytes (248 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
    [    5.869178] UBIFS (ubi0:0): FS size: 333692928 bytes (318 MiB, 1314 LEBs), journal size 9404416 bytes (8 MiB, 38 LEBs)
    [    5.869212] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
    [    5.869232] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID 09E8B5D1-D025-4863-8D4E-0663F111F95C, small LPT model
    [    5.886657] VFS: Mounted root (ubifs filesystem) on device 0:15.
    [    5.888005] devtmpfs: mounted
    [    5.890608] Freeing unused kernel memory: 1024K
    [    5.891194] Run /sbin/init as init process
    [    6.832459] systemd[1]: System time before build time, advancing clock.
    [    7.021419] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    7.021491] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [    7.028076] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    7.028143] systemd[1]: Configuration file /lib/systemd/system.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [    7.075503] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    7.087464] systemd[1]: Detected architecture arm.
    [    7.214324] systemd[1]: Set hostname to <am437x-evm>.
    [    9.883686] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    9.883763] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [    9.987923] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    9.988002] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [    9.992287] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    9.992361] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.011798] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.011872] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.053227] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.053304] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.137811] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.137887] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.229479] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.229554] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.255865] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.255939] systemd[1]: Configuration file /lib/systemd/system/systemd-update-done.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.280880] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.280953] systemd[1]: Configuration file /etc/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.322113] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.322187] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-kernel.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.331566] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.331641] systemd[1]: Configuration file /lib/systemd/system/systemd-udevd-control.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.357679] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.357753] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-trigger.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.381938] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.382011] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.393150] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.393226] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup-dev.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.420477] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.420551] systemd[1]: Configuration file /lib/systemd/system/systemd-timesyncd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.472740] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.472817] systemd[1]: Configuration file /lib/systemd/system/time-sync.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.494530] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.494606] systemd[1]: Configuration file /lib/systemd/system/time-set.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.499613] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.499683] systemd[1]: Configuration file /lib/systemd/system/systemd-sysusers.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.525120] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.525205] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.532942] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.533017] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.560979] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.561054] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.605420] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.605495] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.634095] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.634170] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-flush.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.660973] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.661051] systemd[1]: Configuration file /lib/systemd/system/systemd-journal-catalog-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.693106] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.693181] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.702675] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.702748] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.730489] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.730562] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.758519] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.758593] systemd[1]: Configuration file /lib/systemd/system/systemd-vconsole-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.782126] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.782200] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.791852] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.791923] systemd[1]: Configuration file /lib/systemd/system/initrd-cleanup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.828948] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.829019] systemd[1]: Configuration file /lib/systemd/system/initrd.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.850917] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.850989] systemd[1]: Configuration file /lib/systemd/system/rescue.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.859401] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.859478] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp-runlevel.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.886653] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.886725] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.964797] systemd[1]: Configuration file /lib/systemd/system/nss-lookup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.964871] systemd[1]: Configuration file /lib/systemd/system/nss-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.970548] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.970619] systemd[1]: Configuration file /lib/systemd/system/network-online.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   10.999871] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd-wait-online.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   10.999946] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd-wait-online.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.028532] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.028606] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.057570] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.057643] systemd[1]: Configuration file /lib/systemd/system/network-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.063067] systemd[1]: Configuration file /lib/systemd/system/network.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.063137] systemd[1]: Configuration file /lib/systemd/system/network.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.083232] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.083301] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.088304] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.088374] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.117936] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.118009] systemd[1]: Configuration file /lib/systemd/system/multi-user.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.237974] systemd[1]: Configuration file /lib/systemd/system/vsftpd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.238049] systemd[1]: Configuration file /lib/systemd/system/vsftpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.241967] systemd[1]: Configuration file /etc/systemd/system/tftp.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.242040] systemd[1]: Configuration file /etc/systemd/system/tftp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.247941] systemd[1]: Configuration file /etc/systemd/system/tesyst.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.248012] systemd[1]: Configuration file /etc/systemd/system/tesyst.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.257473] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.257546] systemd[1]: Configuration file /lib/systemd/system/systemd-user-sessions.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.284278] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.284352] systemd[1]: Configuration file /lib/systemd/system/nss-user-lookup.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.291387] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.291456] systemd[1]: Configuration file /lib/systemd/system/systemd-resolved.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.321490] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.321565] systemd[1]: Configuration file /lib/systemd/system/systemd-logind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.380606] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.380681] systemd[1]: Configuration file /lib/systemd/system/dbus.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.387463] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.387539] systemd[1]: Configuration file /lib/systemd/system/user.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.408191] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.408260] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.412495] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.412567] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Created slice system-getty.slice   11.440003] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    m.
    [   11.440076] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-wall.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.468375] systemd[1]: Configuration file /lib/systemd/system/snmptrapd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.468448] systemd[1]: Configuration file /lib/systemd/system/snmptrapd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Created slice system-serial\x2dgett[   11.473241] systemd[1]: Configuration file /lib/systemd/system/snmpd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    y.slice.
    [   11.473315] systemd[1]: Configuration file /lib/systemd/system/snmpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.492795] systemd[1]: Configuration file /lib/systemd/system/rpcbind.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.492866] systemd[1]: Configuration file /lib/systemd/system/rpcbind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Created slice User and Session Slic[   11.498267] systemd[1]: Configuration file /lib/systemd/system/rpcbind.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    e.
    [   11.498338] systemd[1]: Configuration file /lib/systemd/system/rpcbind.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.517979] systemd[1]: Configuration file /lib/systemd/system/rpcbind.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.518048] systemd[1]: Configuration file /lib/systemd/system/rpcbind.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Started Dispatch Password …ts to [   11.539648] systemd[1]: Configuration file /lib/systemd/system/ntpdate.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    Console Directory Watch.
    [   11.539718] systemd[1]: Configuration file /lib/systemd/system/ntpdate.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.560551] systemd[1]: Configuration file /lib/systemd/system/ntpd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Started Forward Password R…uests [   11.560622] systemd[1]: Configuration file /lib/systemd/system/ntpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    to Wall Directory Watch.
    [   11.565073] systemd[1]: Configuration file /lib/systemd/system/nfs-statd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.565144] systemd[1]: Configuration file /lib/systemd/system/nfs-statd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Reached target Paths.[   11.585182] systemd[1]: Configuration file /lib/systemd/system/lldpd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.585253] systemd[1]: Configuration file /lib/systemd/system/lldpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.591838] systemd[1]: Configuration file /lib/systemd/system/lighttpd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Reached target Remote File Systems systemd[1]: Configuration file /lib/systemd/system/lighttpd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [0m.
    [   11.610990] systemd[1]: Configuration file /lib/systemd/system/iptables.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.611062] systemd[1]: Configuration file /lib/systemd/system/iptables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Reached target Slices.[   11.615676] systemd[1]: Configuration file /lib/systemd/system/ip6tables.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.615747] systemd[1]: Configuration file /lib/systemd/system/ip6tables.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.634549] systemd[1]: Configuration file /lib/systemd/system/gplv3-notice.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Reached target Swap.[   11.634620] systemd[1]: Configuration file /lib/systemd/system/gplv3-notice.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.640996] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.641067] systemd[1]: Configuration file /lib/systemd/system/getty.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.663502] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Listening on RPCbind Server Activat[   11.663575] systemd[1]: Configuration file /lib/systemd/system/serial-getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    ion Socket.
    [   11.726311] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.726397] systemd[1]: Configuration file /lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Reached target RPC Port Mapper.[   11.733609] systemd[1]: Configuration file /lib/systemd/system/getty-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.733683] systemd[1]: Configuration file /lib/systemd/system/getty-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.752297] systemd[1]: Configuration file /lib/systemd/system/getty@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.752372] systemd[1]: Configuration file /lib/systemd/system/getty@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.802135] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Listening on Process Core Dump Sock[   11.802210] systemd[1]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    et.
    [   11.822847] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.822921] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Listening on initctl Compatibility [   11.851127] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    Named Pipe.
    [   11.851215] systemd[1]: Configuration file /lib/systemd/system/avahi-daemon.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.877656] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.877733] systemd[1]: Configuration file /lib/systemd/system/rescue.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.882443] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.882516] systemd[1]: Configuration file /lib/systemd/system/initrd-parse-etc.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.908553] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Listening on Journal Socket (/dev/l[   11.908629] systemd[1]: Configuration file /lib/systemd/system/initrd-root-device.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    og).
    [   11.936316] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.936391] systemd[1]: Configuration file /lib/systemd/system/basic.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Listening on Journal Socket.[   11.941880] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.941950] systemd[1]: Configuration file /lib/systemd/system/timers.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   11.965646] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   11.965722] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.timer is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Listening on Network Service Netlin[   11.989030] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    k Socket.
    [   11.989103] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.012926] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.012998] systemd[1]: Configuration file /lib/systemd/system/initrd-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Listening on udev Control Socket   12.018822] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    m.
    [   12.018893] systemd[1]: Configuration file /lib/systemd/system/initrd-root-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.041727] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Listening on udev Kernel Socket[   12.041795] systemd[1]: Configuration file /lib/systemd/system/initrd-udevadm-cleanup-db.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.053761] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.068324] systemd[1]: Configuration file /lib/systemd/system/systemd-udev-settle.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.092931] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked executable. Please remove executable permission bits. Proceeding anyway.
             Mounting POSIX Message Queue File System..[   12.093004] systemd[1]: Configuration file /lib/systemd/system/initrd-switch-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.101230] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.101302] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.119242] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.119314] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
             Mounting Kernel Debug File System...[   12.143948] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-config.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.144028] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-config.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.152565] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.152638] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
             Mounting Temporary Directory (/tmp)...[   12.179279] systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.179353] systemd[1]: Configuration file /etc/systemd/system/sync-clocks.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.189231] systemd[1]: Configuration file /lib/systemd/system/psplash-systemd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.189304] systemd[1]: Configuration file /lib/systemd/system/psplash-systemd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.207095] systemd[1]: Configuration file /lib/systemd/system/psplash-start.service is marked executable. Please remove executable permission bits. Proceeding anyway.
             Starting Start psplash boot splash screen.[   12.207166] systemd[1]: Configuration file /lib/systemd/system/psplash-start.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.212811] systemd[1]: Configuration file /lib/systemd/system/ldconfig.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.212879] systemd[1]: Configuration file /lib/systemd/system/ldconfig.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
             Starting RPC Bind...[   12.231894] systemd[1]: Configuration file /lib/systemd/system/kmod-static-nodes.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.231968] systemd[1]: Configuration file /lib/systemd/system/kmod-static-nodes.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.240321] systemd[1]: Configuration file /lib/systemd/system/dev-mqueue.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.240395] systemd[1]: Configuration file /lib/systemd/system/dev-mqueue.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.261848] systemd[1]: Configuration file /lib/systemd/system/dev-hugepages.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
             Starting Journal Service...[   12.261919] systemd[1]: Configuration file /lib/systemd/system/dev-hugepages.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.268349] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.268421] systemd[1]: Configuration file /lib/systemd/system/emergency.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.287827] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.287901] systemd[1]: Configuration file /lib/systemd/system/syslog.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
             Starting Load Kernel Modules...[   12.309494] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.309568] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-audit.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.332804] systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
             Starting Remount Root and Kernel File Systems systemd[1]: Configuration file /lib/systemd/system/systemd-journald-dev-log.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [0m...
    [   12.361492] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.361565] systemd[1]: Configuration file /lib/systemd/system/sockets.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
             Starting udev Coldplug all Devices...
    [   12.405189] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.405264] systemd[1]: Configuration file /lib/systemd/system/systemd-networkd.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Started RPC Bind.[   12.427250] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.427324] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Mounted POSIX Message Queue File Sy[   12.450904] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    stem.
    [  OK  ] Mounted Kernel Debug File System   12.450977] systemd[1]: Configuration file /lib/systemd/system/systemd-initctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    m.
    [  OK  ] Mounted Temporary Directory (/tmp) systemd[1]: Configuration file /lib/systemd/system/systemd-coredump.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    [0m.
    [   12.457085] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [FAILED] Failed to start Start psplash boo[   12.478967] systemd[1]: Configuration file /lib/systemd/system/dropbear.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
    t splash screen.
    See 'systemctl status psplash-start.service' for details.[   12.479038] systemd[1]: Configuration file /lib/systemd/system/dropbear.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [   12.488886] systemd[1]: Configuration file /lib/systemd/system/var-volatile-srv.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Started Load Kernel Modules.[   12.488959] systemd[1]: Configuration file /lib/systemd/system/var-volatile-srv.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.501655] systemd[1]: Configuration file /lib/systemd/system/var-volatile-spool.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.501729] systemd[1]: Configuration file /lib/systemd/system/var-volatile-spool.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Started Remount Root and Kernel Fil[   12.521720] systemd[1]: Configuration file /lib/systemd/system/var-volatile-lib.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    e Systems.
    [   12.521795] systemd[1]: Configuration file /lib/systemd/system/var-volatile-lib.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.556223] systemd[1]: Configuration file /lib/systemd/system/var-volatile-cache.service is marked executable. Please remove executable permission bits. Proceeding anyway.
             Mounting Kernel Configuration File System.[   12.556297] systemd[1]: Configuration file /lib/systemd/system/var-volatile-cache.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.570785] systemd[1]: Configuration file /lib/systemd/system/tmp.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
             Starting Apply Kernel Variables...[   12.570859] systemd[1]: Configuration file /lib/systemd/system/tmp.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.591427] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked executable. Please remove executable permission bits. Proceeding anyway.
             Starting Create System Users...[   12.591501] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.600721] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Mounted Kernel Configuration File S[   12.600795] systemd[1]: Configuration file /lib/systemd/system/systemd-fsck-root.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    ystem.
    [   12.626067] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Started Apply Kernel Variables.[   12.626138] systemd[1]: Configuration file /lib/systemd/system/emergency.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   12.630396] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.630467] systemd[1]: Configuration file /lib/systemd/system/local-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [  OK  ] Started Create System Users.[   12.640404] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   12.640474] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
             Starting Create Static Device Nodes in /dev   12.773335] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    m...
    [   12.773399] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [   12.806238] systemd[1]: Created slice system-getty.slice.
    [   12.884243] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [   12.948959] systemd[1]: Created slice User and Session Slice.
    [   13.018490] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [   13.094206] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [   13.151805] systemd[1]: Reached target Paths.
    [   13.204615] systemd[1]: Reached target Remote File Systems.
    [   13.259029] systemd[1]: Reached target Slices.
    [   13.312664] systemd[1]: Reached target Swap.
    [   13.384458] systemd[1]: Listening on RPCbind Server Activation Socket.
    [   13.441861] systemd[1]: Reached target RPC Port Mapper.
    [   13.495549] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump@.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Started Create Static Device Nodes [   13.495622] systemd[1]: Configuration file /lib/systemd/system/systemd-coredump@.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    in /dev.
    [  OK  ] Reached target Local File Systems ([   13.543159] systemd[1]: Listening on Process Core Dump Socket.
    Pre).
    [   13.604451] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [   13.733077] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [   13.736617] systemd[1]: Listening on Journal Socket (/dev/log).
    [   13.806515] systemd[1]: Listening on Journal Socket.
             Mounting /media/ram...[   13.863506] systemd[1]: Listening on Network Service Netlink Socket.
    [   13.939040] systemd[1]: Listening on udev Control Socket.
    [   14.010019] systemd[1]: Listening on udev Kernel Socket.
    [   14.068407] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
             Mounting /var/volatile...[   14.100488] systemd[1]: Mounting POSIX Message Queue File System...
    [   14.235018] systemd[1]: Mounting Kernel Debug File System...
    [   14.345588] systemd[1]: Mounting Temporary Directory (/tmp)...
    [   14.425062] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
             Starting udev Kernel Device Manager...[   14.469307] systemd[1]: Starting Start psplash boot splash screen...
    [   14.573597] systemd[1]: Starting RPC Bind...
    [   14.658919] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [   14.729931] systemd[1]: Starting Journal Service...
    [   14.905888] systemd[1]: Starting Load Kernel Modules...
    [   14.969628] systemd-journald[125]: Configuration file /etc/systemd/journald.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
    [  OK  ] Started Journal Service.[   14.969704] systemd-journald[125]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   14.976404] systemd-journald[125]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
    [   14.976480] systemd-journald[125]: Configuration file /lib/systemd/journald.conf.d/00-systemd-conf.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
    [   15.095704] systemd[1]: Starting Remount Root and Kernel File Systems...
    [  OK  ] Mounted /media/ram.[   15.209709] systemd[1]: Starting udev Coldplug all Devices...
    [   15.448115] systemd[1]: Started RPC Bind.
    [   15.563566] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted /var/volatile.[   15.616141] systemd[1]: Mounted Kernel Debug File System.
    [   15.660234] systemd[1]: Mounted Temporary Directory (/tmp).
    [   15.750011] systemd[1]: psplash-start.service: Main process exited, code=exited, status=255/EXCEPTION
    [   15.765215] systemd[1]: psplash-start.service: Failed with result 'exit-code'.
    [   15.824309] systemd[1]: Failed to start Start psplash boot splash screen.
             Starting Flush Journal to Persistent Storage   15.964547] systemd[1]: Dependency failed for Start psplash-systemd progress communication helper.
    0m...
    [   15.994623] systemd[1]: psplash-systemd.service: Job psplash-systemd.service/start failed with result 'dependency'.
    [   16.024348] systemd[1]: Started Load Kernel Modules.
    [   16.179543] systemd[1]: Started Remount Root and Kernel File Systems.
             Starting Load/Save Random Seed...[   16.278015] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
    [   16.365142] systemd[1]: Mounting Kernel Configuration File System...
    [   16.470738] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    [   16.546056] systemd[1]: Starting Apply Kernel Variables...
    [   16.706587] systemd[1]: Starting Create System Users...
    [   16.811539] systemd[1]: Mounted Kernel Configuration File System.
    [  OK  ] Reached target Local File Systems   17.054345] systemd[1]: Started Apply Kernel Variables.
    0m.
    [   17.234601] systemd[1]: Started Create System Users.
    [   17.342689] systemd[1]: Starting Create Static Device Nodes in /dev...
    [   17.767036] systemd[1]: Started Create Static Device Nodes in /dev.
             Starting Rebuild Dynamic Linker Cache...[   17.866074] systemd[1]: Reached target Local File Systems (Pre).
    [   17.996670] systemd[1]: Mounting /media/ram...
    [   18.115595] systemd[1]: Mounting /var/volatile...
    [   18.277244] systemd[1]: Starting udev Kernel Device Manager...
    [  OK  ] Started Flush Journal to Persistent[   18.372550] systemd[1]: Started Journal Service.
     Storage.[   19.099897] systemd-journald[125]: Received client request to flush runtime journal.
    [  OK  ] Started Load/Save Random Seed.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Rebuild Journal Catalog...
    [FAILED] Failed to start Network Time Synchronization.
    See 'systemctl status systemd-timesyncd.service' for details.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Stopped Network Time Synchronization.
    [  OK  ] Started Rebuild Journal Catalog.
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Rebuild Dynamic Linker Cache.
             Starting Update is Completed...
    [  OK  ] Started Update is Completed.
    [   25.786367] omap_wdt: module is already loaded
    [   25.800575] remoteproc remoteproc0: wkup_m3 is available
    [   26.003522] omap_wdt: module is already loaded
    [   26.409182] at24 0-0050: supply vcc not found, using dummy regulator
    [   26.507464] at24 2-0050: supply vcc not found, using dummy regulator
    [   26.508722] remoteproc remoteproc0: powering up wkup_m3
    [   26.626029] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 243288
    [   26.626940] remoteproc remoteproc0: remote processor wkup_m3 is now up
    [   26.627080] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
             Starting LSB: Raise networ…terfaces and configure them...
             Starting Network Time Service (one-shot ntpdate mode)...
    [FAILED] Failed to start Login Service.
    See 'systemctl status systemd-logind.service' for details.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [   33.832687] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1
    [   33.864046] omap-aes 53501000.aes: will run requests pump with realtime priority
    [   33.869120] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
    [   33.879127] omap-sham 53100000.sham: hw accel on OMAP rev 0.0
    [   33.905070] omap-des 53701000.des: will run requests pump with realtime priority
    [   33.905369] omap-sham 53100000.sham: will run requests pump with realtime priority
    [   34.164404] davinci_mdio 54432400.mdio: davinci mdio revision 1.6, bus freq 1000000
    [   34.361182] davinci_mdio 54432400.mdio: phy[0]: device 54432400.mdio:00, driver TI DP83822
    [   34.806800] PM: no-rtc available, rtc-only mode disabled.
    [   34.806951] PM: Leaving EFUSE power domain active
    [   35.049555] remoteproc remoteproc1: 54434000.pru is available
    [   35.050871] remoteproc remoteproc2: 54438000.pru is available
    [   35.052076] remoteproc remoteproc3: 54474000.pru is available
    [   35.053185] remoteproc remoteproc4: 54478000.pru is available
    [  OK  ] Started Network Time Service (one-shot ntpdate mode).
    [   35.802001] prueth pruss1-eth: Test PRU firmware bhavya
    [  OK  ] Started LSB: Raise network interfaces and configure them.
    [   46.938806] prueth pruss1-eth: Test PRU firmware bhavya
    [   46.939530] prueth pruss1-eth: Test bhavya
    [   46.939552] prueth pruss1-eth: could not get ptp tx irq. Skipping PTP support
    [   46.939571] prueth pruss1-eth: could not get hsr ptp tx irq. Skipping PTP support
    [   46.981140] prueth pruss1-eth: dev_infoTI PRU removing link mode bhavya
    [   46.981178] prueth pruss1-eth: dev_err TI PRU removing link mode bhavya err
    [   46.981192] printk  TI PRU removing link mode bhavya
    [   46.983731] prueth pruss1-eth: TI PRU ethernet driver initialized: single EMAC mode
    NOTICE: This file system contains the following GPLv3 packages:
            bash-dev
            bash
            cifs-utils
            dosfstools
            gdb
            less
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm6
            libreadline8
            parted
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Reached target Network (Pre).
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [  OK  ] Stopped Login Service.
             Starting Network Service...
             Starting telnetd.service...
    [  OK  ] Started telnetd.service.
    [   54.781531] prueth_init_ethernet_mode bhavya.............
    [   54.781531]
    [   54.787592] remoteproc remoteproc1: powering up 54434000.pru
    [  OK  ] Started Network Service.[   54.791136] remoteproc remoteproc1: Booting fw image ti-pruss/am437x-pru0-prueth-fw.elf, size 7320
    [   54.791210] remoteproc remoteproc1: unsupported resource 5
    [   54.791462] remoteproc remoteproc1: remote processor 54434000.pru is now up
    [   54.819025] net eth0: started
    [   54.819584] 8021q: adding VLAN 0 to HW filter on device eth0
             Starting Wait for Network to be Configured...
    [FAILED] Failed to start Network Name Resolution.
    See 'systemctl status systemd-resolved.service' for details.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Avahi mDNS/DNS-SD Stack...
    [FAILED] Failed to start LLDP daemon.
    See 'systemctl status lldpd.service' for details.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Network Time Service...
             Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
             Starting Simple Network Ma…rotocol (SNMP) Trap Daemon....
             Starting Permit User Sessions...
    [  OK  ] Started A description for your custom service goes here.
    [  OK  ] Started Vsftpd ftp daemon.
    [FAILED] Failed to start Simple Net…ement Protocol (SNMP) Daemon..
    See 'systemctl status snmpd.service' for details.
    [FAILED] Failed to start Simple Net… Protocol (SNMP) Trap Daemon..
    See 'systemctl status snmptrapd.service' for details.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Stopped LLDP daemon.
    [  OK  ] Started Serial Getty on ttyS0.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [  OK  ] Stopped Network Name Resolution.
    [  OK  ] Started Network Time Service.
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [   61.714216] ioctl_mod: loading out-of-tree module taints kernel.
    [   61.715675] Major = 240 Minor = 0
    [   61.731541] Allocating space to rtc structure ...Done!!!
    [   61.731572] Device Driver Insert...Done!!!
     _____                    _____
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am437x-evm ttyS0
    Arago 2021.09 am437x-evm ttyS0
    am437x-evm login: root (automatic login)
    [   61.929698] Major = 239 Minor = 0
    [   61.946472] Allocating space to rtc structure ...Done!!!
    [   61.946563]
    [   61.946563]  All Relay GPIO Register
    [   61.946571]
    [   61.946571]  All Relay GPIO Status is SET pin = HIGH, RESET pin = Low
    [   61.946694]
    [   61.946694]  Done !
    [   61.946703]
    [   61.946703]  Hello GPIO KEY Module loaded success
    [   61.946709]
    [   61.946709]  GPIO : 96 is mapped to IRQ number : 112
    [   61.964940] hour = 0
    [   62.526904] remoteproc remoteproc1: stopped remote processor 54434000.pru
    [   62.527723] net eth0: stopped
    [   62.729377] prueth_init_ethernet_mode bhavya.............
    [   62.729377]
    [   62.743700] remoteproc remoteproc1: powering up 54434000.pru
    [   62.755262] remoteproc remoteproc1: Booting fw image ti-pruss/am437x-pru0-prueth-fw.elf, size 7320
    [   62.755337] remoteproc remoteproc1: unsupported resource 5
    [   62.755588] remoteproc remoteproc1: remote processor 54434000.pru is now up
    [   62.769330] net eth0: started
    [   62.769645] 8021q: adding VLAN 0 to HW filter on device eth0
    MIO Verification Done
    TCP Server is listening on port 1111...
    Reading Device Name from the dev.txt file
    Device Name DEV_NO1
    Server is listening on port 1234...
             Stopping LSB: Raise network interfaces and configure them...
    [  OK  ] Stopped LSB: Raise network interfaces and configure them.
             Starting LSB: Raise network interfaces and configure them...
    [   77.050675] Gpio irq signal : Userspace with PID 588 is registered
    [   96.498057] cryptd: max_cpu_qlen set to 1000
             Stopping Network Time Service...
    [  OK  ] Stopped Network Time Service.
    [  116.516976] remoteproc remoteproc1: stopped remote processor 54434000.pru
    [  116.518148] net eth0: stopped
    [  117.727215] prueth_init_ethernet_mode bhavya.............
    [  117.727215]
    [  117.741779] remoteproc remoteproc1: powering up 54434000.pru
    [  117.742075] remoteproc remoteproc1: Booting fw image ti-pruss/am437x-pru0-prueth-fw.elf, size 7320
    [  117.742135] remoteproc remoteproc1: unsupported resource 5
    [  117.742395] remoteproc remoteproc1: remote processor 54434000.pru is now up
    [  117.777901] net eth0: started
    [  117.784290] 8021q: adding VLAN 0 to HW filter on device eth0
    [  120.884936] prueth pruss1-eth eth0: Link is Up - 100Mbps/Full - flow control off
    [  120.885044] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [  124.915445] br0: port 1(eth0) entered blocking state
    [  124.915587] br0: port 1(eth0) entered disabled state
    [  124.921786] device eth0 entered promiscuous mode
    [  124.947979] br0: port 1(eth0) entered blocking state
    [  124.948038] br0: port 1(eth0) entered forwarding state
    [  124.960126] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
    ^Croot@am437x-evm:~# systemctl d[  131.706512] device br0 entered promiscuous mode
    isabl[  133.364626] prueth pruss1-eth eth0: Link is Down
    [  133.394462] br0: port 1(eth0) entered disabled state
    e tesyst
    Removed /etc/systemd/system/default.target.wants/tesyst.service.
    [  136.485219] prueth pruss1-eth eth0: Link is Up - 100Mbps/Full - flow control off
    [  136.485407] br0: port 1(eth0) entered blocking state
    [  136.485445] br0: port 1(eth0) entered forwarding state
    [  136.486064] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
    [  140.123360] device br0 left promiscuous mode
    [  140.198611] device br0 entered promiscuous mode
    ^C
    root@am437x-evm:~#
    root@am437x-evm:~#
    root@am437x-evm:~#
    root@am437x-evm:~#
    root@am437x-evm:~# ifconfig
    br0       Link encap:Ethernet  HWaddr 88:01:F9:35:D9:A2
              inet addr:192.168.0.50  Bcast:192.168.0.255  Mask:255.255.255.0
              inet6 addr: fe80::8a01:f9ff:fe35:d9a2/64 Scope:Link
              UP BROADCAST RUNNING PROMISC  MTU:1500  Metric:1
              RX packets:142 errors:0 dropped:0 overruns:0 frame:0
              TX packets:42 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:1000
              RX bytes:25691 (25.0 KiB)  TX bytes:5866 (5.7 KiB)
    eth0      Link encap:Ethernet  HWaddr 88:01:F9:35:D9:A2
              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
              RX packets:188 errors:0 dropped:6 overruns:0 frame:0
              TX packets:63 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:31403 (30.6 KiB)  TX bytes:8436 (8.2 KiB)
    lo        Link encap:Local Loopback
              inet addr:127.0.0.1  Mask:255.0.0.0
              inet6 addr: ::1/128 Scope:Host
              UP LOOPBACK RUNNING  MTU:65536  Metric:1
              RX packets:2 errors:0 dropped:0 overruns:0 frame:0
              TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:140 (140.0 B)  TX bytes:140 (140.0 B)
    root@am437x-evm:~# ethtool eth0
    Settings for eth0:
            Supported ports: [ TP    MII ]
            Supported link modes:   10baseT/Half 10baseT/Full
                                    100baseT/Full
            Supported pause frame use: No
            Supports auto-negotiation: Yes
            Supported FEC modes: Not reported
            Advertised link modes:  10baseT/Half 10baseT/Full
                                    100baseT/Full
            Advertised pause frame use: No
            Advertised auto-negotiation: Yes
            Advertised FEC modes: Not reported
            Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                                 100baseT/Half 100baseT/Full
            Link partner advertised pause frame use: Symmetric Receive-only
            Link partner advertised auto-negotiation: Yes
            Link partner advertised FEC modes: Not reported
            Speed: 100Mb/s
            Duplex: Full
            Auto-negotiation: on
            Port: Twisted Pair
            PHYAD: 0
            Transceiver: external
            MDI-X: Unknown
            Link detected: yes
    According to me I am unable to see any part of eth1 as you said in the pervious comment. However you can confirm for the same so that we can proceed further for checking the waveform.
    Bhavya
  • Hi Schuyler,
    Could you please confirm.
    Bhavya
  • Hi Schuyler,
    any update?
    Bhavya
  • Hi Schuyler,
    any update?
    Bhavya
  • Hi Bhavya,
    I agree that I do not see any eth1 interface and I also only see this for the PHY
    I do not see anything for phy[1], so only phy[0] traffic should be on the mdio bus.
    Schuyler
  • Hi Schuyler,
    Please find the link (image.jfif ) for the waveform image. As per the observation there is no change in signal when port is detected as well as when port is not detected.
    Bhavya Mehta
  • Hi Schuyler,
    any update?
    Bhavya
  • Hi Bhavya,
    I am not able to see the image, could you please attach it directly to this post?
    To summarize what you are saying is that you are capturing traffic on the bus even though there is not a message indicating PHY detection?
    Schuyler
  • Hi Schuyler,
    I was trying to upload the image but it's not uploading so I have kept the zip file in the attachment. The thing which I am saying is there is no difference in signal detection when phy is detected and when phy is not detected so I have kept single image in the given attachment.
    Bhavya
    TI_MDIO_Image.zip
  • Hi Bhavya,
    What is the waveform a capture of? At the moment the traces do not look like an MDIO clock and data signals. This document provides an example timing diagram of the what expected interaction with a PHY looks like, section 2.4.6. Please note this PHY analysis app note may not be the PHY that is in use but it provides an example of how to look at the MDIO bus.
    https://www.ti.com/lit/pdf/snla443
    Is the scope attached to the MDIO lines?
    Schuyler
  • Hi Schuyler,
    our hardware team check this part as well but still the result is same. you can check in the given attachment.
    Bhavya
    MDIO_Signal.zip
