Other Parts Discussed in Thread: TPS40400
Hi guys,
Now we are facing AVS issue , we use tps40400, we just modified i2c address from 0x00 to 0x08( we assign tps40400 0x08 address in our borad)
we use hardware machine to detect output voltage is almost unchanged , the total log about tps40400 is as below.
we have selected “ Regulator debug support “ and excluded “GPIO voltage regulator” in linux kernel configuration.
our using psp version is TI816X-LINUX-PSP-04.00.00.12
176:tps40400_enable Read PMBUS_OPERATION: 0x0
180:tps40400_enable Set: Enable PMBUS_OPERATION: 0
85:tps40400_get_voltage Current Output voltage -1678679uV register value=0xa10
regulator: pmbus_vr: 800 <--> 1100 mV
272:tps40400_probe TPS40400 exponent:-10
285:tps40400_probe PMBUS_REVISION: 17
288:tps40400_probe VOUT_CAL_OFFSET: 0
291:tps40400_probe VOUT_CAL_GAIN: 0
294:tps40400_probe PMBUS_VOUT_SCALE_LOOP: b900
298:tps40400_probe Set PMBUS_VOUT_SCALE_LOOP: 0
301:tps40400_probe PMBUS_VOUT_SCALE_LOOP: b933
305:tps40400_probe PMBUS_VOUT_MARGIN_HIGH: 547
309:tps40400_probe PMBUS_VOUT_MARGIN_LOW: 451
317:tps40400_probe PMBUS_VOUT_MARGIN_LOW: 33d
321:tps40400_probe PMBUS_READ_VOUT: a10
327:tps40400_probe Read VOUT_TRIM: 0x0
340:tps40400_probe VOUT_CAL_OFFSET: 241
