Part Number: AM69A
Hi Expert,
The PS11 (T-branch: 35/70) in the DDR layout guide does not match the EVM board (33/66), such as the CA signal. Which one should we refer to mainly?
Daniel
Part Number: AM69A
Hi Expert,
Daniel
The difference between 33-ohm and 35-ohm is very small - the PCB etching tolerances will have more variance than that - so really doesn't matter. The T-branch PS12 will likely not be achievable. It is recommended to route them minimum trace width to get 'as close to desired' as possible. For this reason, 33/66 is a little lower than 35/70...thus will be slightly closer to PS12 targets. That is reason EVM went with 33/66.
