Part Number: AM625
Hello TI
We are using yocto SDK 9.0
May you guide how to remove all kernel log during boot up?
On console, we want not to show kernel log , but show only when login prompt as below.
We try to modified both U-boot and kernel as below but kernel log still exists.
U-boot, we added logvel=0 and other,
paul@43Server:~/300G_HDD/ti_am62x/build/arago-tmp-default-glibc/work/am62xx_evm_k3r5-oe-linux-gnueabi/u-boot-ti-staging/1_2023.04+gitAUTOINC+24098ea90d-r0.psdk3/git$ cat arch/arm/dts/k3-am62x-sk-common-u-boot.dtsi | grep bootarg
bootargs = "console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait vt.global_cursor_default=0 vt.color=0x00 loglevel=0 quiet systemd.show_status=0 rd.udev.log_priority=0";
Kernel, added boot bootargs and CONFIG_CMDLINEx
paul@43Server:~/300G_HDD/ti_am62x/build/arago-tmp-default-glibc/work-shared/am62xx-evm/kernel-source$ cat arch/arm64/boot/dts/ti/k3-am62x-sk-common.dtsi | grep bootargs
paul@43Server:~/300G_HDD/ti_am62x/build/arago-tmp-default-glibc/work-shared/am62xx-evm/kernel-source$ cat arch/arm64/configs/defconfig
CONFIG_CMDLINE="console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait vt.global_cursor_default=0 vt.color=0x00 loglevel=0 quiet systemd.show_status=0 rd.udev.log_priority=0"
CONFIG_CMDLINE_OVERRIDE=y
Kernel log:
U-Boot 2023.04-g24098ea90d (Jul 06 2023 - 12:59:40 +0000)
SoC: AM62X SR1.0 GP
Model: Texas Instruments AM625 SK
EEPROM not available at 80, trying to read at 81
Reading on-board EEPROM at 0x51 failed -1
DRAM: 2 GiB
Core: 67 devices, 29 uclasses, devicetree: separate
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
574 bytes read in 17 ms (32.2 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
## Error: "main_cpsw0_qsgmii_phyinit" not defined
23233024 bytes read in 979 ms (22.6 MiB/s)
58806 bytes read in 21 ms (2.7 MiB/s)
Working FDT set to 88000000
ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000 flags=4)
Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
Working FDT set to 8feee000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.33-g40c32565ca (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Thu Jul 6 14:17:24 UTC 2023
[ 0.000000] Machine model: Texas Instruments AM625 SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: OVERLAP DETECTED!
[ 0.000000] framebuffer@0 (0x00000000ff700000--0x00000000fffca000) overlaps with framebuffer@ff700000 (0x00000000ff700000--0x00000000fffca000)
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[ 0.000000] node 0: [mem 0x00000000ff700000-0x00000000fffc9fff]
[ 0.000000] node 0: [mem 0x00000000fffca000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 19 pages/cpu s38760 r8192 d30872 u77824
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=dc183efc-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1835532K/2097152K available (13696K kernel code, 1440K rwdata, 4720K rodata, 2688K init, 506K bss, 130548K reserved, 131072K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008542] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.019228] pid_max: default: 32768 minimum: 301
[ 0.024003] LSM: Security Framework initializing
[ 0.028863] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.036447] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.046281] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.053744] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.060052] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.066446] rcu: Hierarchical SRCU implementation.
[ 0.071352] rcu: Max phase no-delay instances is 1000.
[ 0.076965] Platform MSI: msi-controller@1820000 domain created
[ 0.083291] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.093184] EFI services will not be available.
[ 0.098123] smp: Bringing up secondary CPUs ...
[ 0.103426] Detected VIPT I-cache on CPU1
[ 0.103539] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.103559] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000
[ 0.103616] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.104343] Detected VIPT I-cache on CPU2
[ 0.104417] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.104431] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000
[ 0.104465] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.105086] Detected VIPT I-cache on CPU3
[ 0.105166] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.105177] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000
[ 0.105204] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.105278] smp: Brought up 1 node, 4 CPUs
[ 0.185013] SMP: Total of 4 processors activated.
[ 0.189825] CPU features: detected: 32-bit EL0 Support
[ 0.195098] CPU features: detected: CRC32 instructions
[ 0.200420] CPU: All CPU(s) started at EL2
[ 0.204617] alternatives: applying system-wide alternatives
[ 0.212227] devtmpfs: initialized
[ 0.223879] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.233881] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.245473] pinctrl core: initialized pinctrl subsystem
[ 0.251470] DMI not present or invalid.
[ 0.256038] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.263311] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.270876] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.278986] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.287179] audit: initializing netlink subsys (disabled)
[ 0.292883] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[ 0.293307] thermal_sys: Registered thermal governor 'step_wise'
[ 0.300814] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.306998] cpuidle: using governor menu
[ 0.317879] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.324910] ASID allocator initialised with 65536 entries
[ 0.343834] platform 30200000.dss: Fixed dependency cycle(s) with /display
[ 0.352769] KASLR disabled due to lack of seed
[ 0.365712] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.372683] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.379143] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.386084] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.392492] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.399431] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.405839] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.412778] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.420989] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[ 0.432033] iommu: Default domain type: Translated
[ 0.437047] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.443746] SCSI subsystem initialized
[ 0.447947] usbcore: registered new interface driver usbfs
[ 0.453591] usbcore: registered new interface driver hub
[ 0.459043] usbcore: registered new device driver usb
[ 0.464803] mc: Linux media interface: v0.10
[ 0.469211] videodev: Linux video capture interface: v2.00
[ 0.474852] pps_core: LinuxPPS API ver. 1 registered
[ 0.479928] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.489276] PTP clock support registered
[ 0.493422] EDAC MC: Ver: 3.0.0
[ 0.497606] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 0.504750] FPGA manager framework
[ 0.508323] Advanced Linux Sound Architecture Driver Initialized.
[ 0.515579] clocksource: Switched to clocksource arch_sys_counter
[ 0.522090] VFS: Disk quotas dquot_6.6.0
[ 0.526144] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.534314] NET: Registered PF_INET protocol family
[ 0.539605] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.548858] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.557665] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.565604] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.573809] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.581805] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.588716] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.595648] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.603179] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.609460] RPC: Registered named UNIX socket transport module.
[ 0.615539] RPC: Registered udp transport module.
[ 0.620349] RPC: Registered tcp transport module.
[ 0.625157] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.631748] NET: Registered PF_XDP protocol family
[ 0.636662] PCI: CLS 0 bytes, default 64
[ 0.641481] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.651665] Initialise system trusted keyrings
[ 0.656475] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.668679] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.675343] NFS: Registering the id_resolver key type
[ 0.680567] Key type id_resolver registered
[ 0.684845] Key type id_legacy registered
[ 0.689009] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.695864] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.703448] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.710054] 9p: Installing v9fs 9p2000 file system support
[ 0.750347] Key type asymmetric registered
[ 0.754539] Asymmetric key parser 'x509' registered
[ 0.759600] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.767335] io scheduler mq-deadline registered
[ 0.771978] io scheduler kyber registered
[ 0.779694] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.786256] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.793082] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[ 0.801528] clk_mcasp1: gpio_clk_driver_probe: Can't get 'enable' named GPIO property
[ 0.809558] gpio-clk: probe of clk_mcasp1 failed with error -2
[ 0.821294] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[ 0.840104] loop: module loaded
[ 0.844748] megasas: 07.719.03.00-rc1
[ 0.852871] tun: Universal TUN/TAP device driver, 1.6
[ 0.858855] thunder_xcv, ver 1.0
[ 0.862206] thunder_bgx, ver 1.0
[ 0.865538] nicpf, ver 1.0
[ 0.868749] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.876137] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.881641] hclge is initializing
[ 0.885050] e1000: Intel(R) PRO/1000 Network Driver
[ 0.890035] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.895947] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.901022] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.907101] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.912620] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.918347] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.924755] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.930952] sky2: driver version 1.30
[ 0.935458] VFIO - User Level meta-driver version: 0.3
[ 0.942346] usbcore: registered new interface driver usb-storage
[ 0.948600] usbcore: registered new interface driver cp210x
[ 0.954318] usbserial: USB Serial support registered for cp210x
[ 0.960412] usbcore: registered new interface driver ftdi_sio
[ 0.966306] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 0.973800] usbcore: registered new interface driver option
[ 0.979513] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.986986] UDC core: g_mass_storage: couldn't find an available UDC
[ 0.993511] UDC core: g_serial: couldn't find an available UDC
[ 0.999497] UDC core: g_cdc: couldn't find an available UDC
[ 1.005213] UDC core: g_ncm: couldn't find an available UDC
[ 1.011126] Gt9xx driver installing..
[ 1.014914] >> i2c_add_driver - ret : 0x0
[ 1.019597] i2c_dev: i2c /dev entries driver
[ 1.024882] usbcore: registered new interface driver uvcvideo
[ 1.032747] sdhci: Secure Digital Host Controller Interface driver
[ 1.039113] sdhci: Copyright(c) Pierre Ossman
[ 1.044156] Synopsys Designware Multimedia Card Interface Driver
[ 1.050802] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.057573] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.063949] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.070951] usbcore: registered new interface driver usbhid
[ 1.076656] usbhid: USB HID core driver
[ 1.081981] optee: probing for conduit method.
[ 1.086587] optee: revision 3.20 (8e74d476)
[ 1.086906] optee: dynamic shared memory is enabled
[ 1.096443] optee: initialized driver
[ 1.102799] Initializing XFRM netlink socket
[ 1.107236] NET: Registered PF_PACKET protocol family
[ 1.112559] 9pnet: Installing 9P2000 support
[ 1.116997] Key type dns_resolver registered
[ 1.121822] registered taskstats version 1
[ 1.126049] Loading compiled-in X.509 certificates
[ 1.141413] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
[ 1.211324] at24 0-0051: supply vcc not found, using dummy regulator
[ 1.239760] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 64 bytes/write
[ 1.247218] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.254306] i2c 1-0044: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[ 1.264594] tas2505-codec 1-0018: tas2505_i2c_probe: clock-source = MCLK
[ 1.271533] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.277681] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 1.286022] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 1.295283] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 1.305585] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.313771] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 1.324857] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.334869] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.345142] printk: console [ttyS2] disabled
[ 1.349648] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 240, base_baud = 3000000) is a 8250
[ 1.358544] printk: console [ttyS2] enabled
[ 1.367005] printk: bootconsole [ns16550a0] disabled
[ 1.378271] 2840000.serial: ttyS4 at MMIO 0x2840000 (irq = 242, base_baud = 3000000) is a 8250
[ 1.388020] 2860000.serial: ttyS6 at MMIO 0x2860000 (irq = 243, base_baud = 3000000) is a 8250
[ 1.401167] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.406287] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.413252] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.418644] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.425412] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.431898] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.438346] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.444647] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.451456] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.457993] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.466517] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.511606] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.520809] mdio_bus 8000f00.mdio: MDIO device at address 1 is missing.
[ 1.527430] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.535550] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.548505] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[ 1.554773] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.561899] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.568376] pps pps0: new PPS source ptp0
[ 1.572690] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[ 1.583174] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.592713] dwc3 31000000.usb: Configuration mismatch. dr_mode forced to gadget
[ 1.602367] Mass Storage Function, version: 2009/09/11
[ 1.607569] LUN: removable file: (no medium)
[ 1.611896] no file given for LUN0
[ 1.615320] udc 31000000.usb: failed to start g_mass_storage: -22
[ 1.621415] g_mass_storage: probe of gadget.0 failed with error -22
[ 1.627946] g_serial gadget.0: Gadget Serial v2.4
[ 1.632657] g_serial gadget.0: g_serial ready
[ 1.641698] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.647263] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 1.655049] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[ 1.661053] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010
[ 1.670491] xhci-hcd xhci-hcd.0.auto: irq 250, io mem 0x31100000
[ 1.677264] hub 1-0:1.0: USB hub found
[ 1.681046] hub 1-0:1.0: 1 port detected
[ 1.686434] (NULL device *): taeha0203x, Searching for format with pixel format: 0x59565955
[ 1.694797] (NULL device *): taeha0203x Format found: 0x59565955
[ 1.700797] (NULL device *): Filling V4L2 format for CSI format: 0x59565955
[ 1.707757] (NULL device *): Initial width: 640, height: 480, bpp: 16
[ 1.714190] (NULL device *): Pixels in word: 8
[ 1.718625] (NULL device *): Clamped and rounded width: 640
[ 1.724187] (NULL device *): Clamped height: 480
[ 1.729656] (NULL device *): taeha0203x, Searching for format with pixel format: 0x59565955
[ 1.738009] (NULL device *): taeha0203x Format found: 0x59565955
[ 1.744007] (NULL device *): Filling V4L2 format for CSI format: 0x59565955
[ 1.750956] (NULL device *): Initial width: 640, height: 480, bpp: 16
[ 1.757384] (NULL device *): Pixels in word: 8
[ 1.761825] (NULL device *): Clamped and rounded width: 640
[ 1.767389] (NULL device *): Clamped height: 480
[ 1.772726] (NULL device *): taeha0203x, Searching for format with pixel format: 0x59565955
[ 1.781073] (NULL device *): taeha0203x Format found: 0x59565955
[ 1.787071] (NULL device *): Filling V4L2 format for CSI format: 0x59565955
[ 1.794021] (NULL device *): Initial width: 640, height: 480, bpp: 16
[ 1.800451] (NULL device *): Pixels in word: 8
[ 1.804886] (NULL device *): Clamped and rounded width: 640
[ 1.810449] (NULL device *): Clamped height: 480
[ 1.815765] (NULL device *): taeha0203x, Searching for format with pixel format: 0x59565955
[ 1.824108] (NULL device *): taeha0203x Format found: 0x59565955
[ 1.830106] (NULL device *): Filling V4L2 format for CSI format: 0x59565955
[ 1.837055] (NULL device *): Initial width: 640, height: 480, bpp: 16
[ 1.843485] (NULL device *): Pixels in word: 8
[ 1.847922] (NULL device *): Clamped and rounded width: 640
[ 1.853484] (NULL device *): Clamped height: 480
[ 1.860126] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY
[ 1.873174] mmc0: CQHCI version 5.10
[ 1.875086] mmc2: CQHCI version 5.10
[ 1.880957] mmc1: CQHCI version 5.10
[ 1.889304] [gtp_probe:1962]
[ 1.893191] goodix-ts 0-005d: GTP Driver Version: V2.8.0.2<2017/12/14>
[ 1.899712] goodix-ts 0-005d: GTP I2C Address: 0x5d
[ 1.904591] goodix-ts 0-005d: Unset touchscreen-max-id, use default
[ 1.910924] goodix-ts 0-005d: touch input parameters is [id x y w p]<16 800 480 1024 1024>
[ 1.912304] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[ 1.914216] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[ 1.919406] goodix-ts 0-005d: int-sync enabled
[ 1.919900] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[ 1.946135] goodix-ts 0-005d: driver-send-cfg enabled
[ 1.951216] goodix-ts 0-005d: auto-update-cfg enabled
[ 1.956308] goodix-ts 0-005d: esd-protect enabled
[ 1.961019] goodix-ts 0-005d: type-a-report enabled
[ 1.965975] goodix-ts 0-005d: get RST [0x1f2] INT [0x1f1] from DTS
[ 1.973358] goodix-ts 0-005d: supply vdd_ana not found, using dummy regulator
[ 1.985998] goodix-ts 0-005d: supply vcc_i2c not found, using dummy regulator
[ 1.995349] goodix-ts 0-005d: Failed get pinctrl state:output_high
[ 2.004465] goodix-ts 0-005d: Success request irq-gpio
[ 2.010925] goodix-ts 0-005d: Success request rst-gpio
[ 2.016403] goodix-ts 0-005d: Guitar reset
[ 2.016522] mmc0: Command Queue Engine enabled
[ 2.022626] mmc1: new high speed SDHC card at address aaaa
[ 2.025016] mmc0: new HS200 MMC card at address 0001
[ 2.031385] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[ 2.036071] mmcblk0: mmc0:0001 0IM20E 29.6 GiB
[ 2.046541] mmcblk0: p1
[ 2.046611] mmcblk1: p1 p2
[ 2.049720] mmcblk0boot0: mmc0:0001 0IM20E 31.5 MiB
[ 2.058215] mmcblk0boot1: mmc0:0001 0IM20E 31.5 MiB
[ 2.064250] mmcblk0rpmb: mmc0:0001 0IM20E 4.00 MiB, chardev (238:0)
[ 2.115745] goodix-ts 0-005d: GTP reset Guitar
[ 2.120383] goodix-ts 0-005d: I2C Addr is 5d
[ 2.124953] goodix-ts 0-005d: IC Version: 911_1060
[ 2.131135] goodix-ts 0-005d: Config group5 used,length: 186
[ 2.137603] goodix-ts 0-005d: Driver send config
[ 2.159441] goodix-ts 0-005d: Use type A report protocol
[ 2.171068] input: goodix-ts as /devices/virtual/input/input0
[ 2.183000] goodix-ts 0-005d: INT num 277, trigger type:2
[ 2.196284] goodix-ts 0-005d: create proc entry gt9xx_config success
[ 2.205429] goodix-ts 0-005d: Alloc memory size:1534.
[ 2.210812] goodix-ts 0-005d: I2C function: without pre and end cmd!
[ 2.217169] goodix-ts 0-005d: Create proc entry success!
[ 2.222478] goodix-ts 0-005d: ESD on
[ 2.226459] tp2855 1-0044: tp2855 probe starts
[ 2.231049] tp2855 1-0044: tp2855 probe reset gpio = 0
[ 2.236218] tp2855 1-0044: tp2855 probe tp2855->clk = 31840640
[ 2.242048] tp2855 1-0044: xvclk rate: 27000000 Hz
[ 2.246834] tp2855 1-0044: tp2855 Probe hardware reset
[ 2.263593] tp2855 1-0044: tp2855 probe init decoder registers IN/OUT
[ 2.345643] tp2855 1-0044: tp2855, tp2855_start_stream and init ALL registors
[ 2.395588] tp2855 1-0044: tp2855, init ALL registors end
[ 2.402119] tp2855 1-0044: tp2855 chip id found id_high = 0x28, id_low = 0x55
[ 2.409367] tp2855 1-0044: Initialize the subdev and its controls finish.
[ 2.416224] tp2855 1-0044: Consider updating driver tp2855 to match on endpoints
[ 2.425104] tp2855 1-0044: tp2855 probed successfully
[ 2.435640] tas2505-codec 1-0018: tas2505_codec_probe: Probe finished
[ 2.442194] tas2505-codec 1-0018: tas2505_set_dai_sysclk: clk_id: 0, freq: 12288000
[ 2.452483] tas2505-codec 1-0018: tas2505_set_dai_sysclk: id [0] tas2505->sysclk: 12288000, freq: 12288000
[ 2.469402] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[ 2.477277] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present!
[ 2.498032] ALSA device list:
[ 2.501043] #0: TAS2505
[ 2.563329] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.571993] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.582727] devtmpfs: mounted
[ 2.587680] Freeing unused kernel memory: 2688K
[ 2.592342] Run /sbin/init as init process
[ 3.873028] systemd[1]: System time before build time, advancing clock.
[ 4.165784] NET: Registered PF_INET6 protocol family
[ 4.173816] Segment Routing with IPv6
[ 4.177647] In-situ OAM (IOAM) with IPv6
[ 4.320016] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 4.353092] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.04!
[ 4.469122] systemd[1]: Hostname set to <am62xx-evm>.
[ 4.497575] systemd[1]: Initializing machine ID from random generator.
[ 6.014379] systemd-sysv-generator[162]: SysV service '/etc/init.d/resize_rootfs.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 6.133364] systemd-sysv-generator[162]: SysV service '/etc/init.d/psplash.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 6.181831] systemd-sysv-generator[162]: SysV service '/etc/init.d/telnetd' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 6.262018] systemd-sysv-generator[162]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 6.288051] systemd-sysv-generator[162]: SysV service '/etc/init.d/netperf' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 6.312118] systemd-sysv-generator[162]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 6.337060] systemd-sysv-generator[162]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[ 7.114948] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 7.208663] systemd[1]: Queued start job for default target Multi-User System.
[ 7.280362] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 7.306002] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 7.330027] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 7.386355] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 7.408169] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 7.444303] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 7.473909] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 7.487781] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 7.507797] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 7.523814] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 7.605203] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 7.628191] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 7.668314] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 7.692721] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 7.717717] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 7.741184] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 7.766483] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 7.785811] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 7.813594] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 7.838232] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 7.862448] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 7.916256] systemd[1]: Mounting Huge Pages File System...
[ 7.939237] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.984310] systemd[1]: Mounting Kernel Debug File System...
[ 8.000749] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[ 8.028532] systemd[1]: Mounting Temporary Directory /tmp...
[ 8.050158] systemd[1]: Starting Create List of Static Device Nodes...
[ 8.079840] systemd[1]: Starting Load Kernel Module configfs...
[ 8.102224] systemd[1]: Starting Load Kernel Module drm...
[ 8.126127] systemd[1]: Starting Load Kernel Module fuse...
[ 8.181125] fuse: init (API version 7.37)
[ 8.212895] systemd[1]: Starting Start psplash boot splash screen...
[ 8.292795] systemd[1]: Starting RPC Bind...
[ 8.308217] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 8.336271] systemd[1]: Starting Journal Service...
[ 8.396679] systemd[1]: Starting Load Kernel Modules...
[ 8.418632] systemd[1]: Starting Generate network units from Kernel command line...
Starting Generate network …ts from Kernel command line...
[ 8.470735] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.556347] cryptodev: loading out-of-tree module taints kernel.
[ 8.651191] cryptodev: driver 1.12 loaded.
[ 8.875503] systemd[1]: Starting Coldplug All udev Devices...
[ 9.445614] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 9.523505] systemd[1]: Mounted Huge Pages File System.
[ OK ] Mounted Huge Pages File System.
[ 9.570730] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 9.720526] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
[ 9.986101] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 10.023072] systemd[1]: Mounted Temporary Directory /tmp.
[ OK ] Mounted Temporary Directory /tmp.
[ 10.102271] systemd[1]: Finished Create List of Static Device Nodes.
[ OK ] Finished Create List of Static Device Nodes.
[ 10.194438] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 10.253437] systemd[1]: Finished Load Kernel Module configfs.
[ OK ] Finished Load Kernel Module configfs.
[ 10.333634] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 10.394829] systemd[1]: Finished Load Kernel Module drm.
[ OK ] Finished Load Kernel Module drm.
[ 10.468717] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 10.523078] systemd[1]: Finished Load Kernel Module fuse.
[ OK ] Finished Load Kernel Module fuse.
[ 10.562293] systemd[1]: psplash-start.service: Main process exited, code=exited, status=255/EXCEPTION
[ 10.601450] systemd[1]: psplash-start.service: Failed with result 'exit-code'.
[ 10.658616] systemd[1]: Failed to start Start psplash boot splash screen.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[ 10.774151] systemd[1]: Finished Load Kernel Modules.
[ OK ] Finished Load Kernel Modules.
[ 10.865939] systemd[1]: Finished Generate network units from Kernel command line.
[ OK ] Finished Generate network units from Kernel command line.
[ 10.966025] systemd[1]: Finished Remount Root and Kernel File Systems.
[ OK ] Finished Remount Root and Kernel File Systems.
[ 11.257559] systemd[1]: Mounting FUSE Control File System...
[ 11.481272] systemd[1]: Mounting Kernel Configuration File System...
[ 11.552383] systemd[1]: Rebuild Hardware Database was skipped because all trigger condition checks failed.
[ 11.573380] systemd[1]: Platform Persistent Storage Archival was skipped because of a failed condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[ 11.774358] systemd[1]: Starting Apply Kernel Variables...
[ 12.044568] systemd[1]: Starting Create System Users...
[ 12.627462] systemd[1]: Mounted FUSE Control File System.
[ OK ] Mounted FUSE Control File System.
[ 12.697844] systemd[1]: Mounted Kernel Configuration File System.
[ OK ] Mounted Kernel Configuration File System.
[ 12.717471] pwm-backlight backlight: supply power not found, using dummy regulator
[ 12.878378] platform backlight: deferred probe pending
[ 12.884723] platform display: deferred probe pending
[ 12.890574] platform 30200000.dss: deferred probe pending
[ 13.123494] systemd[1]: Finished Apply Kernel Variables.
[ OK ] Finished Apply Kernel Variables.
[ 13.394446] systemd[1]: Finished Create System Users.
[ OK ] Finished Create System Users.
[ 13.625512] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 14.883453] systemd[1]: Finished Create Static Device Nodes in /dev.
[ OK ] Finished Create Static Device Nodes in /dev.
[ 14.932333] systemd[1]: Reached target Preparation for Local File Systems.
[ OK ] Reached target Preparation for Local File Systems.
[ 15.182817] systemd[1]: Mounting /media/ram...
[ 15.411210] systemd[1]: Mounting /var/volatile...
[ 15.647234] audit: type=1334 audit(1651167756.784:2): prog-id=5 op=LOAD
[ 15.666130] audit: type=1334 audit(1651167756.804:3): prog-id=6 op=LOAD
[ 15.761834] systemd[1]: Starting Rule-based Manager for Device Events and Files...
Starting Rule-based Manage…for Device Events and Files...
[ 15.986049] systemd[1]: Mounted /media/ram.
[ OK ] Mounted /media/ram.
[ 16.035556] systemd[1]: Mounted /var/volatile.
[ OK ] Mounted /var/volatile.
[ 16.085498] systemd[1]: Bind mount volatile /var/cache was skipped because of a failed condition check (ConditionPathIsReadWrite=!/var/cache).
[ 16.105857] systemd[1]: Bind mount volatile /var/lib was skipped because of a failed condition check (ConditionPathIsReadWrite=!/var/lib).
[ 16.348662] systemd[1]: Starting Load/Save Random Seed...
[ 16.392357] systemd[1]: Bind mount volatile /var/spool was skipped because of a failed condition check (ConditionPathIsReadWrite=!/var/spool).
[ 16.432992] systemd[1]: Bind mount volatile /srv was skipped because of a failed condition check (ConditionPathIsReadWrite=!/srv).
[ 16.477591] systemd[1]: Reached target Local File Systems.
[ OK ] Reached target Local File Systems.
[ 16.749955] systemd[1]: Starting Rebuild Dynamic Linker Cache...
[ 18.044442] random: crng init done
[ 18.306070] systemd[1]: Finished Load/Save Random Seed.
[ OK ] Finished Load/Save Random Seed.
[ 18.392847] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 18.416878] systemd[1]: Commit a transient machine-id on disk was skipped because of a failed condition check (ConditionPathIsMountPoint=/etc/machine-id).
[ 19.450481] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage...
[ 20.647356] systemd-journald[178]: Received client request to flush runtime journal.
[ OK ] Finished Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories...
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Finished Rebuild Dynamic Linker Cache.
[ OK ] Finished Create Volatile Files and Directories.
Starting Rebuild Journal Catalog...
Starting Network Time Synchronization...
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ OK ] Finished Rebuild Journal Catalog.
Starting Update is Completed...
[ OK ] Finished Update is Completed.
[ OK ] Finished Coldplug All udev Devices.
[* ] (1 of 2) A start job is running for…e Synchronization (31s / 1min 46s)
[** ] (2 of 2) A start job is running for /dev/ttyS2 (32s / 1min 30s)
[ 39.858566] panel-simple display: supply power not found, using dummy regulator
[ 39.889273] panel-simple display: Specify missing bus_flags
[*** ] (2 of 2) A start job is running for /dev/ttyS2 (32s / 1min 30s)
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Set.
[ OK ] Reached target Timer Units.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ 41.637526] rtc rtc0: Unknown quartz-load-femtofarads value: 1250. Assuming 12500
[ 41.725346] rtc-pcf8523 1-0068: registered as rtc0
[ 41.768870] rtc-pcf8523 1-0068: setting system clock to 2025-04-14T06:37:14 UTC (1744612634)
[ 41.771273] systemd-journald[178]: Oldest entry in /run/log/journal/5596cb88e3c4492cb8e319f7d0c211a0/system.journal is older than the configured file retention duration (1month), suggesting rotation.
[ 41.806215] systemd-journald[178]: /run/log/journal/5596cb88e3c4492cb8e319f7d0c211a0/system.journal: Journal header limits reached or header out-of-date, rotating.
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Socket Units.
[ 42.317974] systemd-journald[178]: Oldest entry in /run/log/journal/5596cb88e3c4492cb8e319f7d0c211a0/system.journal is older than the configured file retention duration (1month), suggesting rotation.
[ 42.337547] systemd-journald[178]: /run/log/journal/5596cb88e3c4492cb8e319f7d0c211a0/system.journal: Journal header limits reached or header out-of-date, rotating.
Starting D-Bus System Message Bus...
[ OK ] Found device /dev/ttyS2.
[ OK ] Started D-Bus System Message Bus.
[ 48.007499] CAN device driver interface
[ OK ] Reached target Basic System.
[ 48.257532] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
[ 48.269565] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[ 48.278414] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[ 48.303405] remoteproc remoteproc0: 5000000.m4fss is available
[ 48.317374] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[ 48.328375] remoteproc remoteproc0: powering up 5000000.m4fss
[ 48.341356] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2
[ 48.356535] remoteproc remoteproc0: request_firmware failed: -2
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
Starting psplash.service...
[ 50.602488] audit: type=1334 audit(1744612643.328:4): prog-id=7 op=LOAD
[ 50.629904] audit: type=1334 audit(1744612643.352:5): prog-id=8 op=LOAD
Starting User Login Management...
[ OK ] Started TEE Supplicant.
Starting telnetd.service...
[ OK ] Finished IPv6 Packet Filtering Framework.
[ OK ] Finished IPv4 Packet Filtering Framework.
[ OK ] Started psplash.service.
[ OK ] Reached target Preparation for Network.
[ OK ] Started Start psplash-syst…progress communication helper.
Starting Network Configuration...
[ OK ] Started telnetd.service.
[ 55.265672] audit: type=1701 audit(1744612647.988:6): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=265 comm="psplash" exe="/usr/bin/psplash-default" sig=5 res=1
Starting LSB: Expand Rootfs of boot device...
[ OK ] Created slice Slice /system/systemd-coredump.
[ 58.048418] audit: type=1334 audit(1744612650.772:7): prog-id=9 op=LOAD
[ 58.075022] audit: type=1334 audit(1744612650.800:8): prog-id=10 op=LOAD
[ OK ] Started Process Core Dump (PID 278/UID 0).
[ 62.366421] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[ 64.573155] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 64.748278] platform 78000000.r5f: configured R5F for IPC-only mode
[ 64.757992] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
[ 64.789667] remoteproc remoteproc1: 78000000.r5f is available
[ 64.867157] remoteproc remoteproc1: attaching to 78000000.r5f
[ 65.070542] platform 78000000.r5f: R5F core initialized in IPC-only mode
[ 65.157169] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@9da00000
[ 65.948648] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 65.957117] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 65.971358] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 66.114796] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
[ 66.205635] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[ OK ] Reached target Hardware activated USB gadget.
[ 71.267205] m_can_platform 4e00000.can: m_can device registered (irq=0, version=32)
[ 71.592560] m_can_platform 4e10000.can: m_can device registered (irq=0, version=32)
[ OK ] Started User Login Management.
[ 75.501703] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 76.073588] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 76.090833] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 76.104846] cfg80211: failed to load regulatory.db
[ OK ] Started Network Configuration.
Starting Wait for Network to be Configured...
[ 80.667125] EXT4-fs (mmcblk1p2): resizing filesystem from 393564 to 15426048 blocks
Starting Network Name Resolution...
[ 81.635298] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 81.729069] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ OK ] Finished Print notice about GPLv3 packages.
[ *** ] (3 of 3) A start job is running for… boot device (1min 22s / 5min 48s)
[ *] (1 of 3) A start job is running for…e Configured (1min 26s / no limit)
[ 96.172294] audit: type=1334 audit(1744612688.896:9): prog-id=10 op=UNLOAD
[ ***] (1 of 3) A start job is running for…e Configured (1min 32s / no limit)
Starting Save/Restore Sound Card State...
[ OK ] Finished Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
[ 105.252095] EXT4-fs (mmcblk1p2): resized filesystem to 15426048
[ OK ] Started LSB: Expand Rootfs of boot device.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Netperf Benchmark Server.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Permit User Sessions...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Finished Permit User Sessions.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Finished Synchronize System and HW clocks.
[ 120.967229] remoteproc remoteproc2: 30074000.pru is available
[ 121.122020] remoteproc remoteproc3: 30078000.pru is available
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project am62xx-evm -
Arago 2023.04 am62xx-evm -
am62xx-evm login: [ 130.430134] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none.
am62xx-evm login: root
[ 449.809101] audit: type=1334 audit(1744613042.536:11): prog-id=11 op=LOAD
[ 449.816073] audit: type=1334 audit(1744613042.544:12): prog-id=12 op=LOAD
[ 450.255266] audit: type=1006 audit(1744613042.980:13): pid=665 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ 450.267734] audit: type=1300 audit(1744613042.980:13): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffde18f5c8 a2=1 a3=0 items=0 ppid=1 pid=665 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[ 450.293164] audit: type=1327 audit(1744613042.980:13): proctitle="(systemd)"
[ 450.333504] audit: type=1334 audit(1744613043.060:14): prog-id=13 op=LOAD
[ 450.340357] audit: type=1300 audit(1744613043.060:14): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe38bbe80 a2=78 a3=0 items=0 ppid=1 pid=665 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/lib/systemd/systemd" key=(null)
[ 450.365821] audit: type=1327 audit(1744613043.060:14): proctitle="(systemd)"
[ 450.372948] audit: type=1334 audit(1744613043.060:15): prog-id=13 op=UNLOAD
[ 450.379978] audit: type=1334 audit(1744613043.060:16): prog-id=14 op=LOAD
root@am62xx-evm:~# cat /proc/cmdline
root@am62xx-evm:~#
