AM62P: How to make image for linux and boot while securebooting?
Part Number: AM62P
Hi team,
I have encounter some issues while try to boot from encrypt images.
 Where is need to adjust in linux SDK to encrypt for secure booting?
Thank you for your support.
Best Regards, KONG XIANGXU
    The Processor SDK doesn't have the encrypted boot support.
    The MCU+ SDK does have the support which can be enabled using the flags "ENC_ENABLED" & "ENC_SBL_ENABLED" defined in the "devconfig/devconfig.mak" file.
    Prashant
    mcu_plus_sdk_am62px_10_00_00_14/examples/drivers/boot/sbl_sd_linux/am62px-sk/wkup-r5fss0-0_nortos/ti-arm-clang/sbl_sd_linux.debug.hs.tiimage   ->tiboot3.bin
    /home/a/ti/mcu_plus_sdk_am62px_10_00_00_14/examples/hello_world/am62px-sk/wkup-r5fss0-0_freertos/ti-arm-clang/hello_world.debug.appimage.hs  ->wkup_r5_image
    /a/ti/mcu_plus_sdk_am62px_10_00_00_14/examples/hello_world/am62px-sk/mcu-r5fss0-0_freertos/ti-arm-clang/hello_world.debug.appimage.hs ->mcu_r5_image
    ti/mcu_plus_sdk_am62px_10_00_00_14/tools/boot/linuxAppimageGen/board/am62px-sk/linux.appimage.hs  ->linux_a53_image
    There are how I did it. Is this ok?
    Is that all images I need to flash in order to boot on hs device?
    XIANGXU
  • There are how I did it. Is this ok?
    I think yes. The boot should be successful.
  • Drivers_open()
    SYSFW Firmware Version 10.0.8--v10.00.08 (Fiery Fox)
    SYSFW Firmware revision 0xa
    SYSFW ABI revision 4.0
    Sciclient_getVersionCheck(1)
    Bootloader_Handle bootHandleLinux
    Bootloader_Params_init
    Bootloader_BootImageInfo_init(&bootImageInfoLinux);
    noOfFiles < BOOTLOADER_SD_MAX_NO_OF_FILES
    pp_OpenloadableImage(pFiles[noOfFiles]) == SystemP_SUCCESS
    bootHandle = Bootloader_open(CONFIG_BOOTLOADER_APP, &bootParams);
    bootHandle != NULL 10:54
    in  Bootloader_getMulticoreImageSize
    --- Bootloader Configuration ---
    bootMedia:        0xB0070001
    bootImageSize:    0 bytes
    coresPresentMap:  0x00000000
    enableDma:        false
    scratchMemPtr:    00000000
    socCoreOpMode:    43C273D4
    fxns:             43C26E64
    args:             43C27304
    Core Presence Map Interpretation:
    enableDma:        false
    fxns:             43C26E64
    args:             43C27304
    Multicore image size: 0 bytes
    Image loading status: -1
    status = App_loadImages(bootHandle, &bootImageInfo);
    Error: Failed to load images (0xFFFFFFFF)
    if(App_OpenloadableImage(BOOTLOADER_SD_A53_APPIMAGE_FILENAME) == SystemP_SUCCESS)
    [BOOTLOADER_PROFILE] Boot Media       : SD Card
    [BOOTLOADER_PROFILE] Boot Image Size  : 0 KB
    [BOOTLOADER_PROFILE] Cores present    :
    [BOOTLOADER PROFILE] System_init                      :      29532us
    [BOOTLOADER PROFILE] Drivers_open                     :       2911us
    [BOOTLOADER PROFILE] Board_driversOpen                :       1465us
    [BOOTLOADER PROFILE] Sciclient Get Version            :      10167us
    [BOOTLOADER_PROFILE] SBL Total Time Taken             :      44076us
    Image loading done, switching to application ...
    Starting linux and RTOS/Baremetal applications
    Some tests have failed!!
    Here are logs from my tiboot3.bin(I added some logs).
    Can you tell what might went wrong?
  • Can you tell what might went wrong?
    There is nothing in the logs that could give any insights.
    Could you please check where exactly the execution is failing inside the "App_loadImages" function?
    Thanks!
  • Drivers_open()
    bootHandle != NULL
    enableDma:        false
    socCoreOpMode:    43C27454
    fxns:             43C26EE4
    args:             43C27384
    enableDma:        false
    fxns:             43C26EE4
    args:             43C27384
    Bootloader_Config *bootConfig;
    bootConfig->coresPresentMap = 0;
    Bootloader_parseMultiCoreAppImage
    [BOOTLOADER PROFILE] System_init                      :      29388us
    [BOOTLOADER PROFILE] Drivers_open                     :       2909us
    [BOOTLOADER PROFILE] Board_driversOpen                :       1464us
    [BOOTLOADER PROFILE] Sciclient Get Version            :      10159us
    [BOOTLOADER_PROFILE] SBL Total Time Taken             :      43921us
     *  Copyright (C) 2023 Texas Instruments Incorporated
     *  Redistribution and use in source and binary forms, with or without
     *  modification, are permitted provided that the following conditions
     *  are met:
     *    Redistributions of source code must retain the above copyright
     *    Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the
     *    distribution.
     *    Neither the name of Texas Instruments Incorporated nor the names of
     *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include <stdlib.h>
    #include <string.h>
    #include "ti_drivers_config.h"
    #include "ti_drivers_open_close.h"
    #include "ti_board_open_close.h"
    #include <drivers/device_manager/sciclient.h>
    #include <drivers/bootloader.h>
    #define BOOTLOADER_SD_MCU_R5_APPIMAGE_FILENAME          ("/sd0/mcu_r5_image")
    #define BOOTLOADER_SD_WKUP_APPIMAGE_FILENAME            ("/sd0/wkup_r5_image")
    #define BOOTLOADER_SD_A53_APPIMAGE_FILENAME             ("/sd0/linux_a53_image")
    #define BOOTLOADER_SD_APP_IMAGE_LOADED                  (1)
    #define BOOTLOADER_SD_MAX_NO_OF_FILES                   (2)
    #define BOOTLOADER_APPIMAGE_MAX_FILE_SIZE (0x2000000) /* Size of section DDR specified in linker.cmd */
    uint8_t gAppimage[BOOTLOADER_APPIMAGE_MAX_FILE_SIZE] __attribute__((aligned(128), section(".bss.filebuf")));
    uint8_t socCpuCores[CSL_CORE_ID_MAX] = {0};
    Bootloader_CpuInfo bootCpuInfo[CSL_CORE_ID_MAX];
    char* gBootLoaderSDFiles[BOOTLOADER_SD_MAX_NO_OF_FILES] =
               {BOOTLOADER_SD_MCU_R5_APPIMAGE_FILENAME,
    char** pFiles = gBootLoaderSDFiles;
    /* call this API to stop the booting process and spin, do that you can connect
     * debugger, load symbols and then make the 'loop' variable as 0 to continue execution
     * with debugger connected.
    void loop_forever()
        volatile uint32_t loop = 1;
        while(loop)
    int App_OpenloadableImage(char* imageName)
        int status = SystemP_SUCCESS;
        /* File I/O */
        /* Open app file */
        FF_FILE *appFp = ff_fopen(imageName, "rb");
        /* Check if file open succeeded */
        if(appFp == NULL)
            status =  SystemP_FAILURE;
        else
            /* Check file size */
            uint32_t fileSize = ff_filelength(appFp);
            if(fileSize >= BOOTLOADER_APPIMAGE_MAX_FILE_SIZE)
                /* Application size more than buffer size, abort */
                DebugP_log("Appimage size exceeded limit !!\r\n");
            else
                /* Read the file into RAM buffer */
                memset(gAppimage, 0x0, sizeof(gAppimage));
                ff_fread(gAppimage, fileSize, 1, appFp);
            /* Close the file */
            ff_fclose(appFp);
        return status;
    int32_t App_loadImages(Bootloader_Handle bootHandle, Bootloader_BootImageInfo *bootImageInfo)
    	int32_t status = SystemP_FAILURE;
        DebugP_log("Bootloader_Config *bootConfig;\r\n");
        if(bootHandle != NULL)
            bootConfig = (Bootloader_Config *)bootHandle;
            DebugP_log("bootConfig->coresPresentMap = 0;\r\n");
            status = Bootloader_parseMultiCoreAppImage(bootHandle, bootImageInfo);
            DebugP_log("Bootloader_parseMultiCoreAppImage\r\n");
            /* Load CPUs */
            if((SystemP_SUCCESS == status) && (TRUE == Bootloader_isCorePresent(bootHandle, CSL_CORE_ID_MCU_R5FSS0_0)))
                DebugP_log("(SystemP_SUCCESS == status) && (TRUE == Bootloader_isCorePresent(bootHandle, CSL_CORE_ID_MCU_R5FSS0_0)\r\n");
                bootImageInfo->cpuInfo[CSL_CORE_ID_MCU_R5FSS0_0].clkHz = Bootloader_socCpuGetClkDefault(CSL_CORE_ID_MCU_R5FSS0_0);
                Bootloader_profileAddCore(CSL_CORE_ID_MCU_R5FSS0_0);
                status = Bootloader_loadCpu(bootHandle, &(bootImageInfo->cpuInfo[CSL_CORE_ID_MCU_R5FSS0_0]));
                DebugP_log("Bootloader_loadCpu(bootHandle, &(bootImageInfo->cpuInfo[CSL_CORE_ID_MCU_R5FSS0_0]));\r\n");
                socCpuCores[CSL_CORE_ID_MCU_R5FSS0_0] = BOOTLOADER_SD_APP_IMAGE_LOADED;
                bootCpuInfo[CSL_CORE_ID_MCU_R5FSS0_0] = bootImageInfo->cpuInfo[CSL_CORE_ID_MCU_R5FSS0_0];
            if((SystemP_SUCCESS == status) && (TRUE == Bootloader_isCorePresent(bootHandle, CSL_CORE_ID_WKUP_R5FSS0_0)))
                bootImageInfo->cpuInfo[CSL_CORE_ID_WKUP_R5FSS0_0].clkHz = Bootloader_socCpuGetClkDefault(CSL_CORE_ID_WKUP_R5FSS0_0);
                status = Bootloader_loadSelfCpu(bootHandle, &(bootImageInfo->cpuInfo[CSL_CORE_ID_WKUP_R5FSS0_0]));
                DebugP_log("Bootloader_loadSelfCpu(bootHandle, &(bootImageInfo->cpuInfo[CSL_CORE_ID_WKUP_R5FSS0_0]));\r\n");
                Bootloader_profileAddCore(CSL_CORE_ID_WKUP_R5FSS0_0);
                Bootloader_profileAddProfilePoint("App_loadImages(CSL_CORE_ID_WKUP_R5FSS0_0)");
                DebugP_log("Bootloader_profileAddProfilePoint(App_loadImages(CSL_CORE_ID_WKUP_R5FSS0_0));\r\n");
        return status;
    int32_t App_loadLinuxImages(Bootloader_Handle bootHandle, Bootloader_BootImageInfo *bootImageInfo)
            if((SystemP_SUCCESS == status) && (TRUE == Bootloader_isCorePresent(bootHandle, CSL_CORE_ID_A53SS0_0)))
    		    bootImageInfo->cpuInfo[CSL_CORE_ID_A53SS0_0].clkHz = Bootloader_socCpuGetClkDefault(CSL_CORE_ID_A53SS0_0);
    	        Bootloader_profileAddCore(CSL_CORE_ID_A53SS0_0);
                status = Bootloader_loadCpu(bootHandle, &(bootImageInfo->cpuInfo[CSL_CORE_ID_A53SS0_0]));
                socCpuCores[CSL_CORE_ID_A53SS0_0] = BOOTLOADER_SD_APP_IMAGE_LOADED;
                bootCpuInfo[CSL_CORE_ID_A53SS0_0] = bootImageInfo->cpuInfo[CSL_CORE_ID_A53SS0_0];
    	return status;
    int32_t App_runCpus(Bootloader_Handle bootHandle)
        uint8_t cpuId;
        for(cpuId = 0; cpuId < CSL_CORE_ID_MAX; cpuId++)
            if(cpuId == CSL_CORE_ID_A53SS0_0)
                continue;
            if(socCpuCores[cpuId] == BOOTLOADER_SD_APP_IMAGE_LOADED)
                status = Bootloader_runCpu(bootHandle, &bootCpuInfo[cpuId]);
        return status;
    int32_t App_runLinuxCpu(Bootloader_Handle bootHandle, Bootloader_BootImageInfo *bootImageInfo)
        /* Unlock all the control MMRs. Linux/U-boot expects all the MMRs to be unlocked */
        SOC_unlockAllMMR();
        if(socCpuCores[CSL_CORE_ID_A53SS0_0] == BOOTLOADER_SD_APP_IMAGE_LOADED)
    	    status = Bootloader_runCpu(bootHandle, &bootCpuInfo[CSL_CORE_ID_A53SS0_0]);
    	return status;
    int main()
        int32_t status;
        uint32_t appImageSize = 0;
        uint8_t noOfFiles = 0;
        DebugP_log("11111111111111111\r\n");
        Bootloader_profileReset();
        Bootloader_socWaitForFWBoot();
        status = Bootloader_socOpenFirewalls();
        DebugP_assertNoLog(status == SystemP_SUCCESS);
        DebugP_log("Bootloader_socOpenFirewalls()\r\n");
        System_init();
        Bootloader_profileAddProfilePoint("System_init");
        Drivers_open();
        Bootloader_profileAddProfilePoint("Drivers_open");
        DebugP_log("Drivers_open()\r\n");
        status = Board_driversOpen();
        DebugP_assert(status == SystemP_SUCCESS);
        Bootloader_profileAddProfilePoint("Board_driversOpen");
        status = Sciclient_getVersionCheck(1);
        Bootloader_profileAddProfilePoint("Sciclient Get Version");
        DebugP_log("Sciclient_getVersionCheck(1)\r\n");
        if(SystemP_SUCCESS == status)
            Bootloader_BootImageInfo bootImageInfo;
    		Bootloader_Params bootParams;
            Bootloader_Handle bootHandle;
    		Bootloader_BootImageInfo bootImageInfoLinux;
    		Bootloader_Params bootParamsLinux;
            Bootloader_Handle bootHandleLinux;
            DebugP_log("Bootloader_Handle bootHandleLinux\r\n");
            Bootloader_Params_init(&bootParams);
            DebugP_log("Bootloader_Params_init\r\n");
    		Bootloader_Params_init(&bootParamsLinux);
    		Bootloader_BootImageInfo_init(&bootImageInfo);
            DebugP_log("Bootloader_BootImageInfo_init(&bootImageInfoLinux);\r\n");
            while(noOfFiles < BOOTLOADER_SD_MAX_NO_OF_FILES)
                DebugP_log("noOfFiles < BOOTLOADER_SD_MAX_NO_OF_FILES\r\n");
                bootParams.memArgsAppImageBaseAddr = (uintptr_t)gAppimage;
                if(App_OpenloadableImage(pFiles[noOfFiles]) == SystemP_SUCCESS)
                    DebugP_log("pp_OpenloadableImage(pFiles[noOfFiles]) == SystemP_SUCCESS\r\n");
                    DebugP_log("bootHandle = Bootloader_open(CONFIG_BOOTLOADER_APP, &bootParams);\r\n");
                        DebugP_log("bootHandle != NULL \r\n");
                        appImageSize += Bootloader_getMulticoreImageSize(bootHandle);
                        //DebugP_log("%un\r\n",appImageSize);
                        DebugP_log("Multicore image size: %u bytes\r\n", appImageSize);
                        //DebugP_log("%ld\r\n",status);
                        DebugP_log("Image loading status: %d\r\n", status);  // Changed to %d for int32_t
                        DebugP_log("status = App_loadImages(bootHandle, &bootImageInfo);\r\n");
                if(status == SystemP_SUCCESS)
                    noOfFiles++;
                    DebugP_log("noOfFiles++;\r\n");
                else
                {    DebugP_log("Error: Failed to load images (0x%08X)\r\n", status);
                    break;
            bootParamsLinux.memArgsAppImageBaseAddr = (uintptr_t)gAppimage;
                DebugP_log("if(App_OpenloadableImage(BOOTLOADER_SD_A53_APPIMAGE_FILENAME) == SystemP_SUCCESS)\r\n");
                bootHandleLinux = Bootloader_open(CONFIG_BOOTLOADER_APP, &bootParamsLinux);
                    if(bootHandleLinux != NULL)
                        appImageSize+=Bootloader_getMulticoreImageSize(bootHandleLinux);
                        status = App_loadLinuxImages(bootHandleLinux, &bootImageInfoLinux);
                        Bootloader_profileAddProfilePoint("App_loadLinuxImages");
            /* Power off MMC 1 instance */
            status = SOC_moduleClockEnable(TISCI_DEV_MMCSD1, 0);
            Bootloader_profileUpdateAppimageSize(appImageSize);
            Bootloader_profileUpdateMediaAndClk(BOOTLOADER_MEDIA_SD, 0);
    			/* Print SBL log as Linux prints log to the same UART port */
    			Bootloader_profilePrintProfileLog();
    			DebugP_log("Image loading done, switching to application ...\r\n");
    			DebugP_log("Starting linux and RTOS/Baremetal applications\r\n");
    			UART_flushTxFifo(gUartHandle[CONFIG_UART0]);
    			status = App_runLinuxCpu(bootHandleLinux, &bootImageInfoLinux);
                Bootloader_close(bootHandleLinux);
    			status = App_runCpus(bootHandle);
                Bootloader_close(bootHandle);
        if(status != SystemP_SUCCESS )
            DebugP_log("Some tests have failed!!\r\n");
        /* Call DPL deinit to close the tick timer and disable interrupts before jumping to DM*/
        Dpl_deinit();
        Bootloader_JumpSelfCpu();
        DebugP_log("Bootloader_JumpSelfCpu();\r\n");
        Drivers_close();
        System_deinit();
        return 0;
  • Can you check if the execution is failing at the function "Bootloader_socAuthImage" which is executed as part of the Bootloader_parseMultiCoreAppImage:
    github.com/.../bootloader.c
    If it is indeed failing at this stage then you may not have the correctly signed images for the different cores.
  • int32_t Bootloader_verifyMulticoreImage(Bootloader_Handle handle)
        int32_t status = SystemP_SUCCESS, authStatus = SystemP_FAILURE;
        uint32_t certLen = 0U, imageLen = 0U, ddrCopy = 1U;
        uint32_t certLoadAddr = 0xFFFFFFFFU;
        Bootloader_Config *config = (Bootloader_Config *)handle;
        if (config->fxns->imgReadFxn == NULL || config->fxns->imgSeekFxn == NULL)
        else
            uint8_t x509Header[4];
            if (config->bootMedia == BOOTLOADER_MEDIA_MEM)
                Bootloader_MemArgs *memArgs = (Bootloader_MemArgs *)(config->args);
                certLoadAddr = memArgs->appImageBaseAddr;
                config->fxns->imgReadFxn(x509Header, 4, config->args);
                config->fxns->imgSeekFxn(0, config->args);
                certLen = Bootloader_getX509CertLen(x509Header);
                imageLen = Bootloader_getMsgLen((uint8_t *)certLoadAddr, certLen);
                /* Get the 128B cache-line aligned image length */
                uint32_t cacheAlignedLen = (certLen + imageLen + (uint32_t)128) & ~(127);
                /* Write back and invalidate the cache before passing to HSM */
                CacheP_wbInv((void *)certLoadAddr, cacheAlignedLen, CacheP_TYPE_ALL);
            else if (config->bootMedia == BOOTLOADER_MEDIA_FLASH || config->bootMedia == BOOTLOADER_MEDIA_EMMC)
                if (config->bootMedia == BOOTLOADER_MEDIA_FLASH)
                    Bootloader_FlashArgs *flashArgs = (Bootloader_FlashArgs *)(config->args);
                    if (flashArgs->flashType == CONFIG_FLASH_TYPE_SERIAL_NOR)
                        ddrCopy = 0;
                        certLoadAddr = FLASH_BASE_ADDRESS + flashArgs->appImageOffset;
                        imageLen = Bootloader_getMsgLen((uint8_t *)(certLoadAddr), certLen);
                        /* Invalidate 128B cache-line aligned destination region before TIFS writes to it */
                        CacheP_inv((void *)config->scratchMemPtr, (imageLen + (uint32_t)128) & ~(127), CacheP_TYPE_ALL);
                        /* Enable OSPI Phy if configured to do so*/
                        flashArgs->enablePhyPipeline = TRUE;
                        status = config->fxns->imgCustomFxn(config->args);
                    else
                        certLoadAddr = flashArgs->appImageOffset;
    #if defined(DRV_VERSION_MMCSD_V0) || defined(DRV_VERSION_MMCSD_V1)
                if (config->bootMedia == BOOTLOADER_MEDIA_EMMC)
                    Bootloader_MmcsdArgs *mmcsdArgs = (Bootloader_MmcsdArgs *)(config->args);
                    certLoadAddr = mmcsdArgs->appImageOffset;
    #endif
                if (config->scratchMemPtr != NULL && ddrCopy == 1U)
                    config->fxns->imgReadFxn((void *)config->scratchMemPtr, 0x800, config->args);
                    imageLen = Bootloader_getMsgLen((uint8_t *)config->scratchMemPtr, certLen);
                    uint32_t totalLen = (certLen + imageLen + (uint32_t)128) & ~(127);
                    config->fxns->imgReadFxn((void *)config->scratchMemPtr, totalLen, config->args);
                    certLoadAddr = (uint32_t)(&(config->scratchMemPtr[0]));
            DebugP_log("  before Check if the certificate length is within valid range \r\n");
            /* Check if the certificate length is within valid range */
            if ((certLen > (uint32_t)0x100) && (certLen < (uint32_t)0x800) && status == SystemP_SUCCESS)
                DebugP_log("  after Check if the certificate length is within valid range \r\n");
                authStatus = Bootloader_socAuthImage(certLoadAddr);
                DebugP_log("  after Bootloader_socAuthImage(certLoadAddr);\r\n");
                if (config->bootMedia == BOOTLOADER_MEDIA_BUFIO)
                    /* Authentication will fail in Buf Io because we don't have full data yet, so make it pass here for testing. Default behaviour is to assert. */
                    /* authStatus = SystemP_SUCCESS; */
                    DebugP_assertNoLog(authStatus == SystemP_SUCCESS);
                if (authStatus == SystemP_FAILURE)
                    DebugP_logError("Failed to authenticate Image\r\n");
                else
                    /* Authentication passed, all good. Now re-init bootloader params to point to image start instead of start of x509 certificate */
                        flashArgs->curOffset = flashArgs->appImageOffset;
                            /* Disable only the PHY pipeline*/
                            flashArgs->enablePhyPipeline = FALSE;
                    else if (config->bootMedia == BOOTLOADER_MEDIA_BUFIO)
                        Bootloader_BufIoArgs *bufIoArgs = (Bootloader_BufIoArgs *)(config->args);
                        bufIoArgs->curOffset = bufIoArgs->appImageOffset;
                    else if (config->bootMedia == BOOTLOADER_MEDIA_EMMC)
                        mmcsdArgs->curOffset = mmcsdArgs->appImageOffset;
    #endif
            else
        return status;
    int32_t Bootloader_socAuthImage(uint32_t certLoadAddr)
        struct tisci_msg_proc_auth_boot_req authReq;
        DebugP_log("  struct tisci_msg_proc_auth_boot_req authReq;\r\n");
        /* Request TIFS (SYSFW) to authenticate (and decrypt if mentioned in the x509 cert) the image */
        authReq.certificate_address_hi = 0U;
        authReq.certificate_address_lo = certLoadAddr;
        status = Sciclient_procBootAuthAndStart(&authReq, SystemP_WAIT_FOREVER);
        DebugP_log(" Sciclient_procBootAuthAndStart(&authReq, SystemP_WAIT_FOREVER);%d\r\n", status);
        return status;
    bootHandle != NULL
    enableDma:        false
    socCoreOpMode:    43C274D4
    fxns:             43C26F64
    args:             43C27404
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
    [BOOTLOADER PROFILE] System_init                      :      29533us
    [BOOTLOADER PROFILE] Drivers_open                     :       2879us
    [BOOTLOADER PROFILE] Sciclient Get Version            :      10169us
    [BOOTLOADER_PROFILE] SBL Total Time Taken             :      44048us
    It seems that it never enter Bootloader_socAuthImage function.
    Here is my .mak file. I only change this for signing .
    # Device type (HS/GP)
    DEVICE_TYPE?=HS
    VERSION?=1.5
    # Path to the signing tools, keys etc
    SIGNING_TOOL_PATH=$(MCU_PLUS_SDK_PATH)/tools/boot/signing
    # Path to the keys
    ROM_DEGENERATE_KEY:=$(SIGNING_TOOL_PATH)/rom_degenerateKey.pem
    APP_DEGENERATE_KEY:=$(SIGNING_TOOL_PATH)/app_degenerateKey.pem
    ifeq ($(DEVICE),am263x)
        CUST_MPK=$(SIGNING_TOOL_PATH)/mcu_custMpk.pem
    else ifeq ($(DEVICE),am273x)
    else ifeq ($(DEVICE),awr294x)
    else ifeq ($(DEVICE),am62x)
        CUST_MPK=$(SIGNING_TOOL_PATH)/custMpk_am62x.pem
        CUST_MEK=$(SIGNING_TOOL_PATH)/custMek_am62x.txt
    else ifeq ($(DEVICE),am62ax)
        CUST_MPK=$(SIGNING_TOOL_PATH)/custMpk_am62ax.pem
        CUST_MEK=$(SIGNING_TOOL_PATH)/custMek_am62ax.txt
    else ifeq ($(DEVICE),am62dx)
        CUST_MPK=$(SIGNING_TOOL_PATH)/custMpk_am62dx.pem
        CUST_MEK=$(SIGNING_TOOL_PATH)/custMek_am62dx.txt
    else ifeq ($(DEVICE),am62px)
        CUST_MPK=$(SIGNING_TOOL_PATH)/custMpk_am62px.pem
        CUST_MEK=$(SIGNING_TOOL_PATH)/custMek_am62px.txt
    else
        CUST_MPK=$(SIGNING_TOOL_PATH)/custMpk_am64x_am243x.pem
        CUST_MEK=$(SIGNING_TOOL_PATH)/custMek_am64x_am243x.txt
    endif
    # Encryption option for application (yes/no)
    ENC_ENABLED?=yes
    # Encryption option for SBL (yes/no)
    ENC_SBL_ENABLED?=yes
    # Debug option for HS (yes/no)
    DBG_ENABLED?=no
    # Generic macros to be used depending on the device type
    APP_SIGNING_KEY=
    APP_ENCRYPTION_KEY=
    ifeq ($(DEVICE_TYPE),HS)
    	APP_SIGNING_KEY=$(CUST_MPK)
    	APP_ENCRYPTION_KEY=$(CUST_MEK)
    else
    	APP_SIGNING_KEY=$(APP_DEGENERATE_KEY)
    endif
    ti/mcu_plus_sdk_am62px_10_00_00_14$ make clean PROFILE=debug
    ti/mcu_plus_sdk_am62px_10_00_00_14$ make PROFILE=debug
    Then I run these two command.
  • Drivers_open()
    bootHandle != NULL
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
    This is the same SD card output in the TI official board.
  • Can you once try the following images:
    appimages.zip
  • Drivers_open()
    bootHandle != NULL
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
     Sciclient_procBootAuthAndStart(&authReq, SystemP_WAIT_FOREVER);0
    Image loading status: 0
    noOfFiles++;
    bootHandle != NULL
    bootImageSize:    26600 bytes
    coresPresentMap:  0x00000001
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
      Core 0: Present
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
      Core 0: Present
    Multicore image size: 26600 bytes
    noOfFiles++;
    bootImageSize:    179076 bytes
    coresPresentMap:  0x00000002
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
      Core 1: Present
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
      Core 1: Present
     Bootloader_loadCpu(bootHandle, &(bootImageInfo->cpuInfo[CSL_CORE_ID_A53SS0_0]));0
    [BOOTLOADER_PROFILE] Boot Image Size  : 200 KB
    mcu-r5f0-0
    wkup-r5f0-0
    a530-0
    [BOOTLOADER PROFILE] System_init                      :      39303us
    [BOOTLOADER PROFILE] Drivers_open                     :       2878us
    [BOOTLOADER PROFILE] Board_driversOpen                :       1463us
    [BOOTLOADER PROFILE] Sciclient Get Version            :      10171us
    [BOOTLOADER PROFILE] App_loadImages(CSL_CORE_ID_WKUP_R5FSS0_0) :     808256us
    [BOOTLOADER PROFILE] App_loadLinuxImages              :     486337us
    [BOOTLOADER_PROFILE] SBL Total Time Taken             :    1348410us
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
    U-Boot SPL 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    SPL initial stack usage: 1904 bytes
    Trying to boot from MMC2
    U-Boot 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    SoC:   AM62PX SR1.0 HS-SE
    Model: Texas Instruments AM62P5 SK
    DRAM:  2 GiB (effective 8 GiB)
    Core:  84 devices, 30 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0: ethernet@8000000port@1
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - 12:72:1b:e2:9d:75
    , eth1: ethernet@8000000port@2
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'uEnv.txt'
    Failed to load '/boot/fitImage'
    Wrong Image Type for bootm command
    ERROR -91: can't get kernel image!
    Scanning for bootflows in all bootdevs
    Seq  Method       State   Uclass    Part  Name                      Filename
    Scanning global bootmeth 'efi_mgr':
    No EFI system partition
    Failed to persist EFI variables
      0  efi_mgr      ready   (none)       0  <NULL>
    ** Booting bootflow '<NULL>' with efi_mgr
    Loading Boot0000 'mmc 1' failed
    Loading Boot0001 'mmc 0' failed
    EFI boot manager: Cannot load any image
    Boot failed (err=-14)
    Scanning bootdev 'mmc@fa00000.bootdev':
    Scanning bootdev 'mmc@fa10000.bootdev':
    Bus usb@31100000: Register 1000840 NbrPorts 1
    Starting the controller
    USB XHCI 1.10
    scanning bus usb@31100000 for devices... 1 USB Device(s) found
    ethernet@8000000port@1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
    am65_cpsw_nuss_port ethernet@8000000port@1: phy_startup failed
    am65_cpsw_nuss_port ethernet@8000000port@1: am65_cpsw_start end error
    ethernet@8000000port@2 Waiting for PHY auto negotiation to complete......... TIMEOUT !
    am65_cpsw_nuss_port ethernet@8000000port@2: phy_startup failed
    am65_cpsw_nuss_port ethernet@8000000port@2: am65_cpsw_start end error
    No more bootdevs
    (1 bootflow, 1 valid)
    I use the images you gave me and u-boot.img in /mcu_plus_sdk_am62px_10_00_00_14/tools/boot/linuxAppimageGen/board/am62px-s. I get the  above output.
    So,I think it's time to make sure if I build the images correctly. Can you help me check my .mak file(in our previous conversation) and comman I used.
  • The images I shared were built with the same mak configuration except the "ENC_ENABLED" was set to NO. Can you try the same as well?
    If your images still do not boot, please share them for me to evaluate the differences.
  • I followed your advice and change ENC_ENABLED to no.And it can boot as same as the image you gave me.
    now I want to find out why the same boot SD CARD  appear differently in my customer board and ti official board.
    Drivers_open()
    bootHandle != NULL
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
    [BOOTLOADER PROFILE] System_init                      :      29424us
    [BOOTLOADER_PROFILE] SBL Total Time Taken             :      43938us
    Drivers_open()
    bootHandle != NULL
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
    noOfFiles++;
    bootHandle != NULL
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
      Core 0: Present
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
      Core 0: Present
    noOfFiles++;
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
      Core 1: Present
    enableDma:        false
    fxns:             43C26F64
    args:             43C27404
      Core 1: Present
    mcu-r5f0-0
    wkup-r5f0-0
    a530-0
    In:    serial
    Out:   serial
    Err:   serial
    USB XHCI 1.10
    No more bootdevs
    The first file is the output of my customer board, which seems not to boot successfully. The second one is the official Ti board, which seems to boot in HS mode already. I am using the same SD card. Also both are using TI public key. Can you tell me what is the possible reason for this?
  • now I want to find out why the same boot SD CARD  appear differently in my customer board and ti official board.
    I did not get this.
    You said after setting the ENC_ENABLED to NO, the images built by you are booting successfully. Then, with what configuration you are still seeing failure on your custom board?
  • yes, both the image you gave me and I rebuild after ENC_ENABLED to no can boot on TI 's official board.But both failed on my customer board in the same way.Confused
    Understood.
    Assuming you are using custom DDR part on your custom board, have you modified the DDR config file in the SBL SD bootloader:
    software-dl.ti.com/.../DRIVERS_DDR_PAGE.html
  • U-Boot SPL 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    i2c_write: error waiting for data ACK (status=0x116)
    pca953x gpio@22: Error reading output register
    Error reading cluster
    In:    serial
    Out:   serial
    Err:   serial
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - ca:15:05:97:20:2e
    USB XHCI 1.10
    No more bootdevs
    => 2
    Unknown command '2' - try 'help'
    => 2d
    Unknown command '2d' - try 'help'
    => print bootpart
    bootpart=1:2
    => ext
      ext2load ext2ls ext4load ext4ls ext4size ext4write
    => ext4l
      ext4load ext4ls
    => ex
      exit ext2load ext2ls ext4load ext4ls ext4size ext4write
    => ext4
    => ext4ls mmc 1:2
    <DIR>       4096 .
    <DIR>       4096 ..
    <DIR>      16384 lost+found
    <SYM>          7 bin
    <DIR>       4096 boot
    <DIR>       4096 data
    <DIR>       4096 dev
    <DIR>       4096 etc
    <DIR>       4096 home
    <SYM>          7 lib
    <DIR>       4096 media
    <DIR>       4096 mnt
    <DIR>       4096 opt
    <DIR>       4096 proc
    <DIR>       4096 root
    <DIR>       4096 run
    <SYM>          8 sbin
    <DIR>       4096 srv
    <DIR>       4096 sys
    <DIR>       4096 tmp
    <DIR>       4096 usr
    <DIR>       4096 var
                  19 version
    => ext4ls mmc 1:2 /boot
    <DIR>       4096 .
    <DIR>       4096 ..
            21107200 Image
    <DIR>       4096 dtb
    => boot
    Hi,Prashant
    After solving the ddr problems ,I encountered some new problems .
    The first output is on my customer board. The second one is from the official board.
    Can you tell me the possible reason for this ?
  • Please see if the workarounds mentioned in the following guide helps:
    software-dl.ti.com/.../UG-Memory.html
