AM625: Unable to find toolchain for QT in populated SDK
Part Number: AM625
Hello TI
We are using yocto SDK 9.0
We need to setup toolchain to develop QT application (QT Creator) for AM62.
We downloaded and installed  ti-processor-sdk-linux-am62xx-evm-09.00.00.03.bin from TI website, also try from bitbake -c populate_sdk  tisdk-default-image in our SDK.
Then we could not find the crosscompilers,  arm-arago-linux-*, but only below are available but not fit QT.
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-readelf
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-size
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gdb
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-g++
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-cpp
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov-tool
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-c++filt
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-as
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-objdump
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-strip
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-ar
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-nm
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov-dump
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-7.3.1
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ranlib
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-nm
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gprof
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gdb-py
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ld.bfd
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-ranlib
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-objcopy
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-addr2line
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-strings
./usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-elfedit
./usr/share/ti/cgt-pru/example/arm.c
./usr/share/gdb/syscalls/arm-linux.xml
./usr/include/linux/arm_sdei.h
./usr/include/drm/armada_drm.h
paul@43Server:~/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/linux-devkit/sysroots/x86_64-arago-linux$
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-readelf
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-size
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gdb
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-g++
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-cpp
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov-tool
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-c++filt
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-as
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-objdump
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-strip
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-ar
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-nm
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov-dump
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-7.3.1
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ranlib
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-nm
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gprof
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gdb-py
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ld.bfd
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-ranlib
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-objcopy
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-addr2line
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-strings
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-elfedit
./x86_64-arago-linux/usr/share/ti/cgt-pru/example/arm.c
./x86_64-arago-linux/usr/share/gdb/syscalls/arm-linux.xml
./x86_64-arago-linux/usr/include/linux/arm_sdei.h
./x86_64-arago-linux/usr/include/drm/armada_drm.h
[linux-devkit]:~/arago-2023.04/sysroots>
